Part Number: BQ24070
Other Parts Discussed in Thread: BQ24073
Hi all,
How to disable battery charging ?
Requirement: I want continuously system power from input at the same how to disable battery charging.
siva
Hi Raheem,
Thank you for your quick reply,
Can I control TS pin with I/O.
siva
Siva,
You can. You can also take a look at the BQ24073 for a better solution to this problem.
Hi Raheem,
1. we have done design, PCB and functional testing also, now it is in production stage.
In design we are connected TS pin to battery, for your reference I am adding schematics
if I pull TS to low battery charging is disable how to enable charging by using I/O
siva
