Part Number: BQ40Z50-R1
Other Parts Discussed in Thread: BQ40Z50
We are using BQ40Z50-R1 to design a 3S2P Li-ion battery pack.
We are facing some issues regarding parameters setting.
1. FCC/RSOC drop significantly when the battery is discharged at higher current under the low temperature.
How to adjust the parameters to minimize the drop?
2. RSOC is not compliance with LED display. RSOC=0%, but LED shows 3.
3.When OverCurrent and short-circuit protection kick in, we hope that the battery is not recovered until we remove the it
from the device
I am attaching the log file of low temperature test and also the GG file we use now.
Thank you very much for your help!
Joycehttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/BQ40Z50_2D00_R1.7z
