[FAQ] TDA4AEN-Q1: How to run Fls app INDAC example with performance numbers ?
Part Number: TDA4AEN-Q1
 FLS APP INDAC example is not showing performance numbers on SDK 11.0. How to get performance numbers similar to other jacinto devices ?
  • The default example doesn't have PERF TEST enabled for J722S.
    * Copyright (C) 2024 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file     FlsApp.c
     *  \brief    This file contains the Fls Test App
    #include "Std_Types.h"
    #if defined (SOC_J721E) || defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4) || defined (SOC_J742S2)
    #include <ti/board/board.h>
    #include <ti/board/board_cfg.h>
    #endif
    #include "stdio.h"
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "EcuM_Cbk.h"
    #include "app_utils.h"
    #include "Fee.h"
    #include "string.h"
    #include "stdio.h"
    #include "stdarg.h"
    #include "stdlib.h"
    #include "Det.h"
    #include "Dem.h"
    #include "Os.h"
    #include "Fls_Cfg.h"
    #include "Fls.h"
    #include "Fls_Ospi.h"
    #include "FlsApp_Startup.h"
    #include "SchM_Fls.h"
    #include "Fls_Cbk.h"
    #include <hw_include/arch/lld_arch.h>
    #include <hw_include/soc.h>
    #include <hw_include/lldr.h>
    /* Interrupt Registrations */
    #include <ti/osal/osal.h>
    #include <ti/drv/udma/udma.h>
    #else
    #include <kernel/dpl/ClockP.h>
    #endif
    #include "nor_spi_patterns.h"
     ************************** Macros ************************************
    #define APP_NAME                        "FLS_APP_INDAC"
    #if defined (SOC_J721E) || defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4) || defined (SOC_J742S2) || defined (SOC_J722S)
    #define PERF_TEST /* enable flag to log performance data*/
    #endif
     ************************** Global Variables **************************
    volatile uint32 Fls_JobDoneSuccess;
    volatile uint32 Fls_JobDoneError;
    volatile uint8 expectFail = FALSE;
    volatile uint8 testPass = TRUE;
    #if defined (SOC_AM275X) || defined (SOC_J7200) || defined (SOC_J721E) || defined (SOC_J721S2) || defined (SOC_J784S4) || defined (SOC_J742S2)
    #define DATA_SIZE_TEST 0x100000U
    #else
    #define DATA_SIZE_TEST 0x200000U
    #endif
    #define DATA_VALUE 0xABU
    uint32 offset = 0x00U;
    uint32 Total_datasize;
    uint32 numOfSectorsOrBlocks;
    uint32 CfgSectorOrBlockSize;
    uint32 numofseccfg;
    #if defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4) || defined (SOC_J742S2)
    #define TEST_TUNE_PATTERN_OFFSET    0x3fc0000/*NOR_TUNING_DATA_OFFSET*/
    #define DATA_SIZE_TEST_TUNE              0x100U /*NOR_ATTACK_VECTOR_SIZE*/
    uint32 offset_tune = TEST_TUNE_PATTERN_OFFSET;
    #endif /*SOC_J7200 SOC_J721S2 SOC_J784S4*/
    /* Buffer containing the known data that needs to be written to flash */
    uint8 txBuf_test[DATA_SIZE_TEST];
    /* Buffer containing the received data */
    uint8 rxBuf_test[DATA_SIZE_TEST];
    #ifdef PERF_TEST
    uint64          startTime; /* start time stamp in usec */
    uint64          elapsedTime; /* elapsed time in usec */
    float            xferRate;
    uint32          xferRateInt;
    #endif
     ************************** Function Declarations **************************
    void main_handling()
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,
                APP_NAME ": Job Processing in Progress.\n");
        while (1U)
            Fls_MainFunction();
            if ( Fls_JobDoneSuccess == 1U)
                        APP_NAME ": Job Ends: SUCCESS\n");
                if (expectFail == TRUE)
                        APP_NAME ": However job should've failed\n");
                    testPass = FALSE;
                    expectFail = FALSE;
                break;
            if ( Fls_JobDoneError == 1U)
                        APP_NAME ": Job Ends: ERROR\n");
                if (expectFail == FALSE)
                    testPass = FALSE;
                else
                    expectFail = FALSE;
                break;
        Fls_JobDoneSuccess = 0U;
        Fls_JobDoneError = 0U;
        return;
    void main_cancel_handling()
                APP_NAME ": Cancel job Processing in Progress.\n");
    #if ( STD_ON == FLS_CANCEL_API)
        Fls_Cancel();
    #endif
        while (1U)
            Fls_MainFunction();
          //Only error Notification for Cancelled Job
                        APP_NAME ": Error is expected as we are cancelling the operation. \n");
                break;
        return;
    void run_erase(uint32 ofs, uint32 size, uint8 yesCancel)
        while (1U)
            Std_ReturnType job_accepted = Fls_Erase(ofs, size);
            if (E_OK == job_accepted)
                break;
        if (yesCancel == TRUE)
            main_cancel_handling();
        else
            main_handling();
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL," \n");
    void run_read(uint32 ofs, uint32 size, uint8 *rxBuf, uint8 yesCancel)
        while (1U)
            Std_ReturnType job_accepted = Fls_Read(ofs, &rxBuf[0], size);
                break;
    #ifdef PERF_TEST
        /* Get start time stamp for the write performance measurement */
        startTime = ClockP_getTimeUsec();
    #endif
        else
            main_handling();
    #ifdef PERF_TEST
        elapsedTime = ClockP_getTimeUsec() - startTime;
        /* calculate the write transfer rate in Kbps */
        xferRate = (float) (((float) (size * 8)) / elapsedTime) * 1000U;
        xferRateInt = (uint32)xferRate;
                APP_NAME ": \n Read %d bytes at transfer rate %d Kbps \n",  size, xferRateInt);
    #endif
    void run_write(uint32 ofs, uint32 size, uint8 *txBuf, uint8 yesCancel)
        while (1U)
            Std_ReturnType job_accepted = Fls_Write(ofs, &txBuf[0], size);
                break;
        #ifdef PERF_TEST
        #endif
            else
                main_handling();
        #ifdef PERF_TEST
                    APP_NAME ": \n Write %d bytes at transfer rate %d Kbps \n",  size, xferRateInt);
        #endif
    #if ( STD_ON == FLS_COMPARE_API)
    void run_compare(uint32 ofs, uint32 size, uint8 *txBuf, uint8 yesCancel)
        while (1U)
            Std_ReturnType job_accepted = Fls_Compare(ofs, &txBuf[0], size);
                break;
            else
                main_handling();
    #endif
    #if ( STD_ON == FLS_BLANK_CHECK_API)
    void run_blankCheck(uint32 ofs, uint32 size, uint8 yesCancel)
        while (1U)
            Std_ReturnType job_accepted = Fls_BlankCheck(ofs, size);
                break;
            else
                main_handling();
    #endif
    /* Reminder that QSPI does not have Phy Tuning support in DAC mode yet so below is unnecessary*/
    #if defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4)  || defined (SOC_J742S2) || defined (SOC_J742S2)/* Use INDAC mode to write PHY tune data for J7200/J721S2/J784S4 */
    void write_phy()
            /* PHY Tuning Data Write */
        uint8 *pBuf;
        pBuf = nor_attack_vector;
                APP_NAME ":\n*****************Writing PHY Tune Data to last sector in memory*****************\n");
               APP_NAME ": Erasing \n");
        run_erase(offset_tune, DATA_SIZE_TEST_TUNE, FALSE);
               APP_NAME ": Blank checking \n");
        run_blankCheck(offset_tune, DATA_SIZE_TEST_TUNE, FALSE);
    #endif /*STD_OFF == FLS_BLANKCHECK*/
               APP_NAME ": Writing \n");
        run_write(offset_tune, DATA_SIZE_TEST_TUNE, pBuf, FALSE);
               APP_NAME ": Comparing \n");
        run_compare(offset_tune, DATA_SIZE_TEST_TUNE, pBuf, FALSE);
    #endif /*STD_ON == FLS_COMPARE_API*/
                APP_NAME ":\n*************************Writing PHY Tune Data complete*************************\n\n");
    #endif
      *  ======== test function ========
    void spi_test_init()
            APP_NAME ": FLS spi_test Initiating and Starting.\n");
    #if (STD_ON == FLS_PRE_COMPILE_VARIANT)
                APP_NAME ": Variant - Pre Compile being used !!!\n");
        Fls_Init((const Fls_ConfigType *) NULL_PTR);
                APP_NAME ": Configuring Clocks.\n");
        sint32 Clk_retVal = Fls_OSPI_configClk(FLS_INIT_CONFIG_PC.ospiClkSpeed);
        if (Clk_retVal != LLD_PASS)
                    APP_NAME ": Configuring Clocks : Failed.\n");
            testPass = FALSE;
        else
                    APP_NAME ": Clock Configured at %dHz\n", FLS_INIT_CONFIG_PC.ospiClkSpeed);
    #else
                APP_NAME ": Variant - Post Build being used !!!\n");
        Fls_Init(&FlsConfigSet);
        sint32 Clk_retVal = Fls_OSPI_configClk(FlsConfigSet.ospiClkSpeed);
            testPass = FALSE;
        else
                    APP_NAME ": Clock Configured at %dHz\n", FlsConfigSet.ospiClkSpeed);
    #endif
    #if (STD_ON == FLS_VERSION_INFO_API)
        Std_VersionInfoType versioninfo;
        /* Get and print version */
        Fls_GetVersionInfo(&versioninfo);
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"FLS MCAL Version Info\n");
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"---------------------\n");
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"Vendor ID           : %d\n", versioninfo.vendorID);
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"Module ID           : %d\n", versioninfo.moduleID);
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"SW Major Version    : %d\n", versioninfo.sw_major_version);
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"SW Minor Version    : %d\n", versioninfo.sw_minor_version);
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL,"SW Patch Version    : %d\n", versioninfo.sw_patch_version);
    #endif  /* #if (FLS_VERSION_INFO_API == STD_ON) */
    /* FLS driver should be free now - check */
    #if ( STD_ON == FLS_GET_STATUS_API)
        MemIf_StatusType      status;
        status = Fls_GetStatus();
        if (status != MEMIF_IDLE)
            APP_NAME ": FLS driver is not IDLE!!\n");
            testPass = FALSE;
    #endif
    void spi_test()
        volatile uint32 idx;
        volatile uint8 *txPtr_test = txBuf_test;
        volatile uint8 *rxPtr_test = rxBuf_test;
        #if defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4) || defined (SOC_J742S2) /* Use INDAC mode to write PHY tune data for J7200/J721S2/J784S4 */
        /*SDR mode only support 3 byte addressing
        phy data resides 4 byte addresses*/
        if (FlsConfigSet.dtrEnable)
            write_phy();
        for (numofseccfg = 1; numofseccfg < FLS_NUMBER_OF_SECTOR_CFG; numofseccfg++)
        #else
        for (numofseccfg = 0; numofseccfg < FLS_NUMBER_OF_SECTOR_CFG - 1U; numofseccfg++)
        #endif
            CfgSectorOrBlockSize = FlsConfigSet.sectorList[numofseccfg].sectorSize;
            numOfSectorsOrBlocks = FlsConfigSet.sectorList[numofseccfg].numberOfSectors;
            Total_datasize = numOfSectorsOrBlocks * CfgSectorOrBlockSize;
            offset = FlsConfigSet.sectorList[numofseccfg].sectorStartaddress;
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ":Executing Sector configuration number :  %d \n\r", numofseccfg + 1);
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ":Number of sector/blocks to erase/read/write: %d \n\r", numOfSectorsOrBlocks);
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ":Total data size: 0x%X \n\r", Total_datasize);
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ":Offset is 0x%X \n\r", offset);
            for (idx = 0U; idx < Total_datasize; idx++)
                *txPtr_test++ = (uint8)(DATA_VALUE + idx);
                *rxPtr_test++ = (uint8)0U;
                run_erase(offset, Total_datasize, FALSE);
               APP_NAME ": Blank Checking \n");
                run_blankCheck(offset, Total_datasize, FALSE);
    #endif /*STD_ON == FLS_BLANK_CHECK_API*/
                run_write(offset, Total_datasize, txBuf_test, FALSE);
                APP_NAME ": Cancel while Erasing \n");
                run_erase(offset, Total_datasize, TRUE);
               APP_NAME ": Cancel while Writing \n");
                run_write(offset, Total_datasize, txBuf_test, TRUE);
    #endif //Cancel
                APP_NAME ": Comparing.Expected to fail as data is erased. \n");
        expectFail = TRUE;
                run_compare(offset, Total_datasize, txBuf_test, FALSE);
    #endif/*STD_ON == FLS_COMPARE_API*/
               APP_NAME ": Cancel while Comparing.Expected to fail as data is erased. \n");
                run_compare(offset, Total_datasize, txBuf_test, TRUE);
    #endif //Cancel
               APP_NAME ": Writing to compare again \n");
               APP_NAME ": Reading \n");
                run_read(offset, Total_datasize, rxBuf_test, FALSE);
                APP_NAME ": Cancel while Reading \n");
                run_read(offset, Total_datasize, rxBuf_test, TRUE);
    #endif //Cancel
                APP_NAME ": \n .......................Changing mode to DAC....................... \n");
        Fls_SwitchMode(TRUE, FALSE);
                APP_NAME ": \n ....................Changing mode to INDAC..................... \n");
        Fls_SwitchMode(FALSE, FALSE);
                APP_NAME ": Cancel Erase Job\n");
                APP_NAME ": Blank Checking after erase cancel-----Expect to fail\n");
        expectFail = TRUE;
    #endif //Cancel
                APP_NAME ": Erasing again \n");
                APP_NAME ": Blank Checking after erase again\n");
                APP_NAME ": Cancel after Writing \n");
                APP_NAME ": Comparing after write cancel---Expect to fail\n");
        expectFail = TRUE;
    #endif
    #endif //Cancel
                APP_NAME ": Writing again. Will pass\n");
                APP_NAME ": Comparing.Expected to pass since write passed. \n");
    #endif
                APP_NAME ": Writing.\n");
    #endif //Cancel
                APP_NAME ": Reading again\n");
                APP_NAME ": Cancel while Comparing \n");
    #endif //Cancel
                APP_NAME ": Comparing again\n");
    #if (STD_ON == OSPI_REGISTER_READBACK_API)
                CSL_ospi_flash_cfgRegs RegReadback, *RegRbPtr;
                RegRbPtr = &RegReadback;
                Std_ReturnType retVal = Ospi_RegisterReadback(RegRbPtr);
                if (retVal != E_OK)
                        APP_NAME ": OSPI configuration Register Readback Failed!!\n");
                    testPass = FALSE;
                        APP_NAME ": Some tests have failed for sector configuration index %u :( \n",
                        numofseccfg);
                else
                    /* TESTS DONE FOR CURRENT SECTOR CONFIGURATION */
                        APP_NAME ":FLS SPI Test Passed for sector configuration index %u \n",
                        numofseccfg);
                        ": Ospi configuration Register Readback values  \n" );
                    AppUtils_Printf( APP_UTILS_PRINT_MSG_NORMAL, APP_NAME
                        ": CONFIG_REG 			              : 0x%x\n", RegRbPtr->CONFIG_REG);
                        ": DEV_INSTR_RD_CONFIG_REG 			: 0x%x\n", RegRbPtr->DEV_INSTR_RD_CONFIG_REG);
                        ": DEV_INSTR_WR_CONFIG_REG 			: 0x%x\n", RegRbPtr->DEV_INSTR_WR_CONFIG_REG);
                        ": DEV_DELAY_REG 			          : 0x%x\n", RegRbPtr->DEV_DELAY_REG);
                        ": DEV_SIZE_CONFIG_REG 			    : 0x%x\n", RegRbPtr->DEV_SIZE_CONFIG_REG);
                        ": SRAM_PARTITION_CFG_REG 			  : 0x%x\n", RegRbPtr->SRAM_PARTITION_CFG_REG);
                        ": DMA_PERIPH_CONFIG_REG 			  : 0x%x\n", RegRbPtr->DMA_PERIPH_CONFIG_REG);
                        ": MODE_BIT_CONFIG_REG 			    : 0x%x\n", RegRbPtr->MODE_BIT_CONFIG_REG);
                        ": TX_THRESH_REG 			          : 0x%x\n", RegRbPtr->TX_THRESH_REG);
                        ": RX_THRESH_REG 			          : 0x%x\n", RegRbPtr->RX_THRESH_REG);
                        ": PHY_CONFIGURATION_REG 			  : 0x%x\n", RegRbPtr->PHY_CONFIGURATION_REG);
                    AppUtils_Printf( APP_UTILS_PRINT_MSG_NORMAL, "\n");
        #endif /* (STD_ON == OSPI_REGISTER_READBACK_API) */
     *  ======== main ========
    int main(void)
        /* Call board init functions */
        Board_initCfg boardCfg;
        boardCfg = BOARD_INIT_PLL | BOARD_INIT_PINMUX_CONFIG |
        BOARD_INIT_MODULE_CLOCK |
        BOARD_INIT_UART_STDIO;
        Board_init(boardCfg);
    #elif defined (SOC_AM62X) || defined (SOC_AM62AX) || defined (SOC_AM62DX) || defined (SOC_AM62PX) || defined (SOC_J722S) || defined (SOC_AM275X)
    	System_init();
    #endif
    #ifdef UART_ENABLED
        AppUtils_Init();
    #if defined (SOC_AM62X) || defined (SOC_AM62AX) || defined (SOC_AM62PX) || defined (SOC_J722S) || defined (SOC_AM62DX) || defined (SOC_AM275X)
    	Drivers_open();
    #endif
    #endif
                APP_NAME ": \n------------------FLS Sample Application - STARTS !!! ------------------\n");
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on J7 VCL \n");
        #elif defined (SOC_J721E)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on J7 ES \n");
        #elif defined (SOC_J721S2)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on J7 AEP \n");
        #elif defined (SOC_J784S4) || defined (SOC_J742S2)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on J7 AHP \n");
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on AM62X\n");
        #elif defined (SOC_AM62AX)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on AM62AX\n");
        #elif defined (SOC_AM62DX)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on AM62DX\n");
        #elif defined (SOC_AM275X)
        AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": \n Running on AM275X\n");
        #endif
        spi_test_init();
        if (testPass)
            spi_test();
        else
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, "\n");
            AppUtils_Printf(APP_UTILS_PRINT_MSG_NORMAL, APP_NAME ": spi_test_init() failed, skip main spi_test\n");
        /*ALL TESTS DONE*/
        if (testPass)
                    APP_NAME ": All tests have passed! \n");
        else
                    APP_NAME ": Some tests have failed :( \n");
        return 0;
    The FlsApp.c file has been modified to run with Performance numbers on J722S
    Core READ WRITE ERASE
    MCU_R5 (Example ONLY) 150ms 1.8s 3.6s
    Tarun Mukesh
