TI-CGT: MSP430 compiler (21.6.0.LTS) produces redundant instructions for some left/right 8-bit shifts.
Part Number: TI-CGT
Hello everyone!
I have just checked the ASM output for the C source below and found out that in some cases where a type conversion from 16- to 8-bit integer or vice versa is performed, the compiler produces a redundant MOV.B instruction. This only seems to be the case when SWPB instruction is used on a register (not a memory location), but not always...
uint8_t shift_right_toU8(uint16_t val)
    return val >> 8U;
uint16_t shift_right_toU16(uint16_t val)
    return val >> 8U;
uint16_t shift_left_fromU8(uint8_t val)
    return val << 8U;
uint16_t shift_left_fromU16(uint16_t val)
    return val << 8U;
ASM output (stripped of additional info):
shift_right_toU8:
        SWPB      r12                   ; [] |46|
        MOV.B     r12,r12               ; [] |46|
        RET       ; []
shift_right_toU16:
        SWPB      r12                   ; [] |51|
        MOV.B     r12,r12               ; [] |51|
        RET       ; []
shift_left_fromU8:
        MOV.B     r12,r12               ; [] |56|
        SWPB      r12                   ; [] |56|
        RET       ; []
shift_left_fromU16:
        MOV.B     r12,r12               ; [] |61|
        SWPB      r12                   ; [] |61|
        RET       ; []
Cheers!
Michal
