Other Parts Discussed in Thread: AM5728, SYSBIOS
In our AM5728 EVB with the IPC makefile project example provided by TI RTOS PDK 08_01_00_09 , sysbios 6_76_03_01, I have modified the code for host core to run as server , M4 core and DSP cores running as clients in this case the IPC is working fine as expected, I'm not sure how to change the configurations to make this example work between A15 core0 and A15 core1, I'm stuck here please provide some support regarding this.
In the below attached file please check main files of the Host , IPU1 and DSP1 directories for modified code.
UED_IPC_A15_M4_DSP_code_base.zip
Thanks ,
Phaneesh A Kashyap
