TDA4VH-Q1: Processors forum
Part Number: TDA4VH-Q1
while building the code on windows using msys2 mingw64 shell. after the compiling process when we start the linking, tiarmclang2.1.3 raise this error
tiarmclang: error: unable to execute command: Couldn't execute program 'C:\ti\ti-cgt-armllvm_2.1.3.LTS\bin\tiarmlnk.exe': The filename or extension is too long.  (0xCE) .
it didn't appear before as we didn't have too many SWC to link. attach the screen shoot of the error and a .txt of the invoking line of the compiler to link the SWCs.
cd C:/proj6/0_Logs/App/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC && C:/ti/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe  -mcpu=cortex-r5 -flto -Oz -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common   -g -O3 --no-warnings -Wl,-c -Wl,-w -Wl,-q -Wl,-u_c_int00 -Wl,-x -Wl,--opt=' -mcpu=cortex-r5 -flto -Oz -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common'  -Xlinker -mStartup_SwC.map @CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/objects1.rsp -o APP_Monolithic_MidPlus_SwC   -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC/.  -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/__j784s4/__OUT/R5F_MCU1_0/lib/B_Sample_Libs  ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -lsciserver_baremetal.aer5f -lsciclient_direct.aer5f -lrm_pm_hal.aer5f -lti.osal.aer5f -lti.drv.uart_console.aer5f -lti.drv.uart.aer5f -lti.csl.init.aer5f -lti.csl.aer5f -lti.board.aer5f -lti.drv.spi.aer5f -lti.drv.gpio.aer5f -lti.drv.i2c.aer5f -ludma.aer5f -lsbl_lib_ospi_hlos.aer5f -Xlinker -lC:/proj6/2_Product/1_Software/Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/Config/BSW_GenData/Source/vLinkGen_Template.ld ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a
  • We do not test the compiler under msys2.  That said, I expect it would work like any other Windows executable.
    Just as an experiment, arrange for the input to tiarmclang (options, filenames, etc.) to be in a simple text file.  Typically, this file has one option or filename per line, though that is not a strict requirement.  Then invoke the compiler with a command similar to ...
    tiarmclang @name_of_file.txt
    Does that work?
    Thanks and regards,
    -George
  • Hello George,
    I tried running the command for linking through cmd using the way you mentioned as you can see in the attached screenshot, but the error still exist
    -mcpu=cortex-r5 -flto -O0 -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common -fno-inline-functions   -g -O3 --no-warnings -Wl,-c -Wl,-w -Wl,-q -Wl,-u_c_int00 -Wl,-x -Wl,--opt=' -mcpu=cortex-r5 -flto -O0 -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common -fno-inline-functions'  -Xlinker -mStartup_SwC.map @CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/objects1.rsp -o APP_Monolithic_MidPlus_SwC   -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC/.  -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/__j784s4/__OUT/R5F_MCU1_0/lib/B_Sample_Libs  ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -lsciserver_baremetal.aer5f -lsciclient_direct.aer5f -lrm_pm_hal.aer5f -lti.osal.aer5f -lti.drv.uart_console.aer5f -lti.drv.uart.aer5f -lti.csl.init.aer5f -lti.csl.aer5f -lti.board.aer5f -lti.drv.spi.aer5f -lti.drv.gpio.aer5f -lti.drv.i2c.aer5f -ludma.aer5f -lsbl_lib_ospi_hlos.aer5f -Xlinker -lC:/proj6/2_Product/1_Software/Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/Config/BSW_GenData/Source/vLinkGen_Template.ld ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a
  • Please try two different experiments..
    Please add -v and build again.  Capture all of he system output in a text file and attach that to the next post.  I expect that to show the problem invocation of  tiarmlnk.
    Please disable link time optimization by removing -flto.  Does that work?
    Thanks and regards,
    -George
  • C:\proj6\0_Logs\App\External\PIPP\1_Software\Sources\App\APP_Monolithic_MidPlus_SwE\APP_Monolithic_MidPlus_SwC>cd C:/proj6/0_Logs/App/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC && C:/ti/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe  @txt.txt
    TI Arm Clang Compiler 2.1.3.LTS
    Target: arm-ti-none-eabi
    Thread model: posix
    InstalledDir: C:\ti\ti-cgt-armllvm_2.1.3.LTS\bin
     "C:\\ti\\ti-cgt-armllvm_2.1.3.LTS\\bin\\tiarmlnk" --search_path C:/proj6/2_Product/1_Software/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC/. --search_path C:/proj6/2_Product/1_Software/External/PIPP/1_Software/__j784s4/__OUT/R5F_MCU1_0/lib/B_Sample_Libs "-IC:\\ti\\ti-cgt-armllvm_2.1.3.LTS\\lib" -o APP_Monolithic_MidPlus_SwC -c -w -q -u_c_int00 -x "--opt= -mcpu=cortex-r5 -flto -O0 -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common -fno-inline-functions" -mStartup_SwC.map CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/BswM/Implementation/BswM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Crc/Implementation/Crc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Det/Implementation/Det.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_BlockHandler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_DatasetHandler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_EepCoordinator.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_InstanceHandler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer1_Erase.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer1_Invalidate.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer1_Read.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer1_Write.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer2_InstanceFinder.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer2_InvalidateInstance.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer2_WriteInstance.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_Layer3_ReadManagementBytes.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_PartitionHandler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Ea/Implementation/Ea_TaskManager.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EcuM/Implementation/EcuM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eep_30_XXi2c01/Implementation/Eep_30_XXi2c01.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eep_30_XXi2c01/Implementation/Eep_30_XXi2c01_Proc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/I2c/Implementation/I2c.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/I2c/Implementation/I2c_PerMgr.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/I2c/Implementation/I2c_PrioQueueMgr.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/I2c/Implementation/I2c_TransProc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/MemIf/Implementation/MemIf.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_Act.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_Crc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_DataIntegrity.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_JobProc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_Mac.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_MemIfAbstraction.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_MemIfMemoryCore.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_Qry.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/NvM/Implementation/NvM_Queue.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_AccessCheck.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Alarm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Application.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_ArrayList.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Barrier.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Bit.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_BitArray.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Counter.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Deque.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Error.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Event.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Fifo.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Fifo08.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Fifo16.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Fifo32.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_FifoRef.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Compiler_Arm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Compiler_GccNxp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Compiler_Iar.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Compiler_LlvmDiab.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Compiler_LlvmTI.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Context.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Core_E3.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Core_G9x.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Core_Jacinto7.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hal_Entry.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Hook.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Interrupt.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Ioc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Isr.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Job.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Lock.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_MemoryProtection.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Peripheral.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_PriorityQueue.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Resource.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Scheduler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_ScheduleTable.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_ServiceFunction.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Spinlock.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Stack.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Task.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Thread.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Timer.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_TimingProtection.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Trace.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_Trap.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Os/Implementation/Os_XSignal.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/ComM/Implementation/ComM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/8bc608987f1cf4c7111e3961c6944831/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_CtrlModeHdl.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/8bc608987f1cf4c7111e3961c6944831/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_HeaderAccess.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_MacHdl.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_MiiAccess.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_Rx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/8bc608987f1cf4c7111e3961c6944831/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_Statistics.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_TimeSync.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/bc816d19f545fc602f6da3307ac101e5/Implementation/Eth_30_Wrapper_TrafficHandling.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_Tx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_30_Wrapper/Implementation/Eth_30_Wrapper_ZeroCopy.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/Eth_Callouts/Implementation/Appl_Rand.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthSwt_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthTrcv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthTrcv_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Gw.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Gw_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Link.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Link_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_MacSec.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_MacSec_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Mirror.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Mirror_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Mode.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Mode_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Rx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Rx_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Stats.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Stats_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Tx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Tx_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Utils.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_Utils_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_ZeroCopy.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_ZeroCopy_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthCtrl.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthCtrl_Int.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthIf/Implementation/EthIf_EthSwt.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/EthSM/Implementation/EthSM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase_Sock.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase_String.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase_Ber.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase_Code.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/IpBase/Implementation/IpBase_PBuf.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/LdCom/Implementation/LdCom.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_Bm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_EvC.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_Fm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_IFQ.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_Lock.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_McQ.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_Mm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_MultipleSourceHandler.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_QAL.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_Reporting.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmIf.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmIf_DeferredProcessing.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmIf_QueueProcessing.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmTp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmTp_RxInst.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmTp_RxRouting.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmTp_TxInst.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RmTp_TxRouting.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_RPG.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/PduR/Implementation/PduR_SingleBuffer.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_Anomaly.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_BestMatch.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_EventQueue.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_LocalAddr.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_RemoteAddr.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_RouteGrp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_Rx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_SoCon.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_State.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_TimeoutList.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_Tx.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/SoAd/Implementation/SoAd_Util.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Arp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_DhcpV4.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_DhcpV4Server.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_DhcpV6.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IcmpV4.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IcmpV6.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IpSec.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IpV4.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IpV4_Priv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IpV6.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_IpV6_Priv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Ndp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Priv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tcp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tls.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tls12Client.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tls12Core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tls13Client.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Tls13Core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_TlsClientCommon.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_TlsCoreCommon.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_TlsPriv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_TlsServer.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/BSW/BSW_Pckg/Components/TcpIp/Implementation/TcpIp_Udp.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/AppStub.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/app_utils_eth.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/board.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/EEP_mapping.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/NVM_Block_RAM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl/Sources/SciServer_CA.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl_BSW/startup.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/ADC_Callback/src/Adc_Cbk.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/EMMC/src/MMCSD_AL.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/EMMC/src/MMCSD_drv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/EMMC/src/MMCSD_soc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/EMMC/src/MMCSD_v2.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/Gpt/src/Gpt_Cbk.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/SPI/src/SPI_drv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/SPI/src/SPI_soc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Ext_Drv/SPI/src/SPI_v1.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/CONF/Std/src/conf_std.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ERRH/ERRH_std/src/errh.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ERRH/ERRH_std/src/errh_core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ERRH/ERRH_std/src/errh_data.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ERRH/ERRH_std/src/errh_deb.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ERRH/ERRH_std/src/errh_rte.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/TLMV/TLMV_std/TLMV.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/IO/Io_HwAb_STD/Adc/std/src/IoHwAb_Adc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/IO/Io_HwAb_STD/Dio/std/src/IoHwAb_Dio.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/IO/Io_HwAb_STD/Io_HwAb_STD/IoHwAb.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/ETHW/Sources/EthW.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl_BSW/ICOM/std/Sources/ICOM_AM62.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl_BSW/ICOM/std/Sources/ICOM_SM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Appl_BSW/ICOM/std/Sources/ICOM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/MW/VLTH/VLTH_std/src/VLTH.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/pbist/bist_stubs.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/test/osal/src/osal_interface.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/osal/src/sdl_osal.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/bist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/lbist_utils.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/soc/j784s4/lbist_defs.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/pbist_utils.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/soc/j784s4/pbist_defs.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/lbist/sdl_lbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/lbist/V0/sdl_ip_lbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/lbist/soc/j784s4/sdl_soc_lbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/pbist/sdl_pbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/pbist/V0/sdl_ip_pbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/pbist/soc/j784s4/sdl_soc_pbist.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/power_seq.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/soc/j784s4/armv8_power_utils.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/bist/soc/j784s4/bist_core_defs.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/ecc/ecc_main.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/ecc/ecc_trigger.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/ecc/sdl_ecc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/r5/sdl_ecc_r5.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/r5/sdl_exception.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/ecc/V1/sdl_ip_ecc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/esm/sdl_esm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/esm/V0/sdl_ip_esm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/esm/sdl_esm_priv.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/esm/sdl_esm_core.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/dcc/UC1/dcc_stubs.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/app/dcc/UC1/sdl_dcc_example.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/dcc/sdl_dcc.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/sdl/vtm/sdl_vtm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/vtm/V0/sdl_ip_vtm.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/AsrPckg/MCAL/MCAL_Pckg/SDK_WIN/sdl/src/ip/vtm/V0/sdl_vtm_pvt_sensor.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/VTM/src/vtm_app.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/VTM/src/main_VTM.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/VTM/src/sensor_read.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/Dio_Wrapper/src/Dio_Wrapper.c.obj CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/Core/SrcCode/SWC/OSPI/src/ospiFlashIf.c.obj ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -lsciserver_baremetal.aer5f -lsciclient_direct.aer5f -lrm_pm_hal.aer5f -lti.osal.aer5f -lti.drv.uart_console.aer5f -lti.drv.uart.aer5f -lti.csl.init.aer5f -lti.csl.aer5f -lti.board.aer5f -lti.drv.spi.aer5f -lti.drv.gpio.aer5f -lti.drv.i2c.aer5f -ludma.aer5f -lsbl_lib_ospi_hlos.aer5f -lC:/proj6/2_Product/1_Software/Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/Config/BSW_GenData/Source/vLinkGen_Template.ld ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a --start-group -llibc++.a -llibc++abi.a -llibc.a -llibsys.a -llibsysbm.a -llibclang_rt.builtins.a -llibclang_rt.profile.a --end-group --cg_opt_level=3
    tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation)
    Here is the first experiment with -v and the required text file.
    For the second experiment, it didn't work
    Thanks in advance.
  • Thank you for trying these experiments.  I think I understand what is happening.  If I'm right, it is a problem in the compiler.  I'll get back to you tomorrow.
    Thanks and regards,
    -George
  • Thank you for your patience.  Using what I learned from your experiments, I am able to reproduce the issue.  I filed EXT_EP-11784 to have this investigated.  You are welcome to follow it with that link.
    I have a workaround to suggest.  Because I can't directly try it, I cannot be certain it works.  But I am confident enough to suggest it.  In your first post, you show the command you use to link the program.  It shows this argument ...
    That contains a large list of object files, including their paths.  Remove the leading @ character.  Write it ...
    With the @, tiarmclang expands all the contents into the invocation of the linker tiarmlnk.  Without the @, it passes the file on as it if is a linker command file.  Since it only contains a list of object files, it is a valid linker command file.
    Thanks and regards,
    -George
  • Hello George,
    I followed your suggestion to remove the "@" symbol during the trial but encountered an error. Here are the details of the error message:
    C:\proj6\0_Logs\App\External\PIPP\1_Software\Sources\App\APP_Monolithic_MidPlus_SwE\APP_Monolithic_MidPlus_SwC>cd C:/proj6/0_Logs/App/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC && C:/ti/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe  -mcpu=cortex-r5 -flto -O0 -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common -fno-inline-functions   -g -O3 --no-warnings -Wl,-c -Wl,-w -Wl,-q -Wl,-u_c_int00 -Wl,-x -Wl,--opt=' -mcpu=cortex-r5 -flto -O0 -march=armv7-r -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -fno-common -fno-inline-functions  -Xlinker -mStartup_SwC.map CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/objects1.rsp -o APP_Monolithic_MidPlus_SwC   -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC/.  -LC:/proj6/2_Product/1_Software/External/PIPP/1_Software/__j784s4/__OUT/R5F_MCU1_0/lib/B_Sample_Libs  ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -lsciserver_baremetal.aer5f -lsciclient_direct.aer5f -lrm_pm_hal.aer5f -lti.osal.aer5f -lti.drv.uart_console.aer5f -lti.drv.uart.aer5f -lti.csl.init.aer5f -lti.csl.aer5f -lti.board.aer5f -lti.drv.spi.aer5f -lti.drv.gpio.aer5f -lti.drv.i2c.aer5f -ludma.aer5f -lsbl_lib_ospi_hlos.aer5f -Xlinker -lC:/proj6/2_Product/1_Software/Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/Config/BSW_GenData/Source/vLinkGen_Template.ld ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -v
    Thread model: posix
     "C:\\ti\\ti-cgt-armllvm_2.1.3.LTS\\bin\\tiarmlnk" --search_path C:/proj6/2_Product/1_Software/External/PIPP/1_Software/Sources/App/APP_Monolithic_MidPlus_SwE/APP_Monolithic_MidPlus_SwC/. --search_path C:/proj6/2_Product/1_Software/External/PIPP/1_Software/__j784s4/__OUT/R5F_MCU1_0/lib/B_Sample_Libs "-IC:\\ti\\ti-cgt-armllvm_2.1.3.LTS\\lib" -o APP_Monolithic_MidPlus_SwC -c -w -q -u_c_int00 -x --opt=' -mStartup_SwC.map CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/objects1.rsp ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a -lsciserver_baremetal.aer5f -lsciclient_direct.aer5f -lrm_pm_hal.aer5f -lti.osal.aer5f -lti.drv.uart_console.aer5f -lti.drv.uart.aer5f -lti.csl.init.aer5f -lti.csl.aer5f -lti.board.aer5f -lti.drv.spi.aer5f -lti.drv.gpio.aer5f -lti.drv.i2c.aer5f -ludma.aer5f -lsbl_lib_ospi_hlos.aer5f -lC:/proj6/2_Product/1_Software/Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/Config/BSW_GenData/Source/vLinkGen_Template.ld ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../__j784s4/R5/App/Sources/APP_MCAL_SwE/APP_McalEb_SwC/libAPP_McalEb_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenData_SwC/libAPP_ArGenData_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_TDA4H_SwC/libAPP_TDA4H_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_SourceCode_SwC/libAPP_SourceCode_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_MW_SwC/libAPP_MW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/Drv_DioWrapper_SwC/libDrv_DioWrapper_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_GTC_SwC/libAPP_GTC_SwC.a ../../MW_SwE/ECUH_SwC/libECUH_SwC.a ../../MW_SwE/PMIC_SwC/libPMIC_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/ECUHCfg_SwC/libECUHCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/PMICCfg_SwC/libPMICCfg_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DAS_SwC/libAPP_DAS_SwC.a ../../../../../../../Sources/App/MWCfg_SwE/APP_DASW_SwC/libAPP_DASW_SwC.a ../../../../../../../Sources/App/APP_VCorePlfCfg_SwE/APP_ArGenDataAsm_SwC/libAPP_ArGenDataAsm_SwC.a --llvm_lto=on --start-group -llibc++.a -llibc++abi.a -llibc.a -llibsys.a -llibsysbm.a -llibclang_rt.builtins.a -llibclang_rt.profile.a --end-group --cg_opt_level=3
    "CMakeFiles/APP_Monolithic_MidPlus_SwC.dir/objects1.rsp", line 1: fatal error:
       source line too long
    Thanks.
  • While the error is similar, it is different than before.  So far, I am unable to reproduce it.
    Thanks and regards,
    -George
  • Thank you for your patience.  I found a way to reproduce the problem.  I filed EXT_EP-11791 to have this investigated.  You are welcome to follow it with that link.  A workaround is to change the file objects1.rsp to list one object file per line.
    Thanks and regards,
    -George
