I am using a processor with a DM R5F (AM62x, AM62Ax, AM62Px). I am using SDK 9.2.1 or SDK 10.0. The Device Manager (RM) R5F core is listed in the Linux devicetree, so Linux should use the remoteproc driver to attach to the DM R5F during Linux boot time, and initialize RPMsg communication with the DM R5F [1] [2]. However, the Linux remoteproc driver is failing with error -19. What is going on?
Here is an example of a "working" attach to the DM R5F core:
[ 6.569096] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 6.572660] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.573291] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.573941] remoteproc remoteproc3: 78000000.r5f is available [ 6.574088] remoteproc remoteproc3: attaching to 78000000.r5f [ 6.589108] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 6.589191] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.589483] rproc-virtio rproc-virtio.5.auto: registered virtio1 (type 7) [ 6.589504] remoteproc remoteproc3: remote processor 78000000.r5f is now attached
And here is an example of a failing case:
[ 6.670963] platform 78000000.r5f: ti-sci processor request failed: -19 [ 6.671050] platform 78000000.r5f: ti_sci_proc_request failed, ret = -19 [ 6.674274] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_core_of_init failed, ret = -19 [ 6.674301] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_of_init failed, ret = -19
Additional notes:
[1] The DM R5F core starts running earlier in the boot process than Linux. For most remote cores (i.e., non-Linux cores), the Linux remoteproc driver both initializes the core, and sets up the infrastructure to enable RPMsg communication with the remote core. However, since the DM R5F core is already running, the Linux remoteproc driver simply "attaches" to the already-running DM R5F, and initializes the RPMsg infrastructure. For more information about booting & disabling processor cores, refer to the Multicore module of the associated processor academy:
AM62x: https://dev.ti.com/tirex/explore/node?node=A__AdnCtmyMLBJQE.U38-Dw4w__AM62-ACADEMY__uiYMDcq__LATEST
AM62Ax: https://dev.ti.com/tirex/explore/node?node=A__Ada-WjvmUg3JmB109NavGA__AM62A-ACADEMY__WeZ9SsL__LATEST
AM62Px: https://dev.ti.com/tirex/explore/node?node=A__AYnQdcxcEc8wt-WsqMumsA__AM62P-ACADEMY__fp5YxRM__LATEST
[2] If RPMsg communication is not used with the DM R5F, and Linux does not interact with the DM R5F code during runtime, then the remoteproc driver does not need to attach to the DM R5F in the first place. However, keep in mind that the DM R5F's DDR memory allocations should ALWAYS be reserved in the Linux devicetree file, in order to prevent Linux from overwriting the DM R5F's data. For more information, refer to the Multicore module of the associated processor academy:
AM62x: https://dev.ti.com/tirex/explore/node?node=A__ASVmm1hNWx7CjUJCy91Aig__AM62-ACADEMY__uiYMDcq__LATEST
AM62Ax: https://dev.ti.com/tirex/explore/node?node=A__Ab1lHTiDEw5GmFW034IFNw__AM62A-ACADEMY__WeZ9SsL__LATEST
AM62Px: https://dev.ti.com/tirex/explore/node?node=A__AUiUIYaptWENZHufiXw.FQ__AM62P-ACADEMY__fp5YxRM__LATEST
