Part Number: AM62L
HI TI experts,
I have the below queries regarding LVCMOS hysteresis
LVCMOS IOs that support (implements) hysteresis
LVCMOS IOs hysteresis specifications
Enabling LVCMOS IOs hysteresis
Part Number: AM62L
HI TI experts,
Hi Board designers,
Refer below:
To answer the question, you simply need to look in the datasheet.
Data sheet reference
Electrical Characteristics
LVCMOS Electrical Characteristics
TRM reference for AM62D
14.2.1.2 Pad Configuration Registers
14.2.1.2.1 Pad Configuration Register Functional Description
Sreenivasa
Hi Board designers,
Refer below inputs for Hysteresis implemented on the Reset inputs
We have discussed on the cold reset input MCU_PORz having internal hysteresis enabled and the need to apply signal with Min slew or use a discrete push pull buffer to avoid glitching of the internal reset.
Does the MCU_RESETz and RESET_REQz warm reset inputs implement similar hysteresis and the above recommendations be valid for these warm reset inputs.
For the second part of your question, the datasheet defines the same minimum active pulse width of 1200ns for both MCU_RESETz and RESET_REQz inputs that was defined for MCU_PORz. Therefore, I think these reset inputs have the same requirements as MCU_PORz.
Sreenivasa
