AM5728: MPEG2 HW decoder
Part Number: AM5728
From customer
A stream data has been decoded by MPEG2 HW decoder (ducatimpeg2dec) and they have faced an error.
The attached is the log file.
 It should be caused by a stream data, a field encoder, GStreamer is utilized, etc.
 On the other hand the software decode by GStreamer (avdec_mpeg2video) works OK.
However, the performance is insufficient so customer190529_log_ducatimpeg2dec_IOnly.txt would like to use HW decoder but they faced error.
If the stream data is necessary, please let us know so that we could consider to share it with you somehow.
  • Hello Rogerio,
    What is the PSDK version that they are using?
    Is it possible to share this stream?
    Are they able to reproduce the issue with viddec3test demo?
    I am wondering, is the below pipeline working:
    gst-launch-1.0 filesrc location=IOnlyBlack480i10s.mp2 ! mpegvideoparse ! queue ! mpegvideoparse ! ducatimpeg2decvpe ! queue ! kmssink
    Margarita
  • Margarita,
    Thanks. Field is aware of this link and field should be posting reply to your questions. They should post here next week.
  • Hello Rogerio,
    Thanks for information. I will wait.
    One more question, is this video interlaced or progressive format?
    Margarita
  • Margarita,
    I do not know. If we have no post from either customer or field with the comments on your questions, I recommend to close this post and open again in case we get answers.
    Thanks a lot.
    I am closing this thread.
    Margarita
  • Hi Team,
    I am sorry I am late to reply.
    I would like to re-start the thread. Thanks.
    PSDK version is ti-processor-sdk-linux-am57xx-evm-04.02.00.09.
    It is possible to share the stream from the customer.
      In addition, the stream is P-only.
      Dummy I frame has to be inserted to the HW decoder when the decode starts.
      The HW decoder needs I frame to start function.
    "Are they able to reproduce the issue with viddec3test demo?"
    "I am wondering, is the below pipeline working:
    gst-launch-1.0 filesrc location=IOnlyBlack480i10s.mp2 ! mpegvideoparse ! queue ! mpegvideoparse ! ducatimpeg2decvpe ! queue ! kmssink"
    Yes, they are.
    It was confirmed with a BeagleBoard too just after the SDK was newly installed and complied.
    The log files are attached.
    If the stream data is needed, please let me know so that I could share it offline.
    Hitoshi
    root@am57xx-evm:/home# viddec3test -s 31:720x480 IOnlyBlack480i10s.mp2
    0x2e008: Opening Display..
    using 1 connectors, 720x480 display, multiplanar: 1
    Setting mode 720x480 on connector 31, crtc 34
    0x2e008: Opening Demuxer..
    [mpegvideo @ 0x2f600] Estimating duration from bitrate, this may be inaccurate
    Input #0, mpegvideo, from 'IOnlyBlack480i10s.mp2':
      Duration: 00:00:08.39, bitrate: 6312 kb/s
        Stream #0:0: Video: mpeg2video (Main), yuv420p(tv), 720x480 [SAR 8:9 DAR 4:3], 6312 kb/s, 29.97 fps, 29.97 tbr, 1200k tbn, 59.94 tbc
    0x2e008: infile=IOnlyBlack480i10s.mp2, width=720, height=480
    0x2e008: padded_width=720, padded_height=480, num_buffers=19
    Page flip: frame=8444, sec=1092, usec=363932, remaining=0
    0x2e008: Opening Engine..
    displayBufsMode: 1
    ERROR:decoder_process:427: 0x2e008: process returned error: -1
    ERROR:decoder_process:428: 0x2e008: extendedError: 23000040
    ERROR:decoder_process:428: 0x2e008: extendedError: 22000040
    0x2e008: end of input
    ERROR:decoder_process:428: 0x2e008: extendedError: 00008000
    root@am57xx-evm:/home# gst-launch-1.0 filesrc location=IOnlyBlack480i10s.mp2 ! mpegvideoparse ! queue ! mpegvideoparse ! avdec_mpeg2video ! videoconvert ! queue ! kmssink Setting pipeline to PAUSED ...
    Pipeline is PREROLLING ...
    Redistribute latency...
    ERROR: from element /GstPipeline:pipeline0/GstKMSSink:kmssink0: GStreamer encountered a general resource error.
    Additional debug info:
    gstkmssink.c(1536): gst_kms_sink_show_frame (): /GstPipeline:pipeline0/GstKMSSink:kmssink0:
    drmModeSetPlane failed: Permission denied (-13)
    ERROR: pipeline doesn't want to preroll.
    Setting pipeline to NULL ...
    Freeing pipeline ...
    ------------------------NDC-1485
    ERROR:post_buffer:298: Could not post buffer on crtc 34: Permission denied (-13)
    [mpegvideo @ 0x2f6d0] Estimating duration from bitrate, this may be inaccurate
    ERROR:post_buffer:325: Timeout waiting for flip complete: Permis[  142.155873] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    sion denied (0)
    displayBufsMode: 1
    ERROR:post_vid_buffer:419: failed to enable plane 35: Permission denied
    This error
    means that the weston is not stopped.
    Please stop weston first before t start the pipeline(/etc/init.d/weston stop).
    Please share the video.
    Thank you!
    Margarita
    There is an error 22000240 in gstreamer and viddec3test. But what is the impact of error ? Are they seeing any artifacts in displayed video or else?
    Without the stream will be difficult to suspect what is going wrong.
    Margarita
  • HI Margarita,
    I would like to share the stream file with you for further investigation.
    Please allow me to communicate with you offline from now on.
    Thank you very much for your kind support and cooperation.
    HItoshi
