TDA2EXEVM: NDK : Error in opening a socket
Part Number: TDA2EXEVM
Hi All,
I have an basic NDK application that i desire to run on IPU core. I have'nt used CCS for configuring this. But i configured this application by referring a .cfg files of vision sdk.
So what i have is a basic .cfg that includes some NDK and sysbios related components.
I have created a task ( statically created from .cfg file ) that need to run some socket related code.
when NDK task runs, the socket() always had returned INVALID_SOCKET. Also when i see the return value of fdOpenSession() , it was 0.
Also I wanted to check weather memory is being allocated to file descriptor table correctly or not, So I tried to allocate a 100 Bytes of data inside a NDK task thread using mmAlloc(). Even that allocation was not successful.
But i have allocated 4096 bytes for heap through linker file "-heap 0x4096."
Can anyone please tell me why it is not able to allocate that small amount of memory. Or do i need to add something to make this application run.
Likhith C
  • Hi Likhith,
    Which SDK and version is this ? Can you post your example code ?
    Vineet
  • Hi Vineet,
    Thanks for replying.
    PFA of the application code and configuration file i'm using.
    Please let me know in case im missing something code/cfg file.
    Below are the tools i'm using.
    XDC Tools        :  xdctools_3_32_01_22_core
    BIOS                :  bios_6_46_06_00
    ARM compiler :  ti-cgt-arm_16.9.2.LTS
    NDK                :  ndk_2_24_02_31
    #include <xdc/std.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    #include <xdc/runtime/System.h>
    #include <xdc/cfg/global.h>
    #include <xdc/runtime/Error.h>
    #include <stacksys.h>
    #include <socket.h>
    int *ptr = NULL;
    Void Utils_idleFxn()
        System_printf("Nothing to do . Im and Idle function !!\n");
        System_flush();
    int Network_sessionOpen(HANDLE handle)
        if(handle == NULL)
            handle = Task_self();
        _mmCheck(0, &System_printf);
        System_flush();
        fdOpenSession( handle );
        ptr = (int*)mmAlloc(100);
        if(ptr==NULL)
            System_printf("\n Could not allocate memory for ptr ");
            System_flush();
        System_flush();
        return 0;
    int Network_sessionClose(HANDLE handle)
        if(handle==NULL)
            System_printf("\n Here i come in if loop ");
            System_flush();
        fdCloseSession( handle );
        return 0;
    int Network_open()
        SOCKET socket_fd = INVALID_SOCKET;
        //int port = 10000;
        socket_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
        if(socket_fd == INVALID_SOCKET)
            System_printf("\n Error in creating socket %d ", fdError());
            System_flush();
        return 0;
    Void ndkTaskfxn(UArg arg1, UArg arg2)
        int status, client_fd, num;
        System_printf("\n Hello !! This is from ndkTaskfxn() ");
        System_flush();
        Network_sessionOpen(NULL);
        status = Network_open();
        Network_sessionClose(NULL);
    Void taskfxn(UArg arg1, UArg arg2)
        System_printf("Hello !! This is from taskfxn() \n");
        System_flush();
    int main(int argc, char** argv)
        System_printf("Starting main()\n");
        System_flush();
        BIOS_start();
    	return 0;
    myconfig.cfg
    Likhith
  • Hi Likhith,
    Can you try with the attached file ? It's a TCP echo program written for another platform but you should be able to use the NDK part in function tcpEchoTask()
     * @file   main_am65xx.c
     * @brief  NDK/NIMU example for AM65xx
     * Copyright (c) 2018-2019, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdio.h>
    #include <string.h>
    #include <stdlib.h>
    #include <sys/time.h>
    /* BIOS Header files */
    #include <ti/sysbios/family/arm/v8a/Mmu.h>
    #include <ti/sysbios/utils/Load.h>
    #include <ti/sysbios/knl/Semaphore.h>
    /* CSL Header files */
    #include <ti/csl/soc.h>
    /* NDK headers */
    #include <ti/ndk/inc/netmain.h>
    #include <ti/ndk/inc/stkmain.h>
    /* OSAL Header files */
    #include <ti/osal/osal.h>
    /* BOARD Header files */
    #include <ti/board/board.h>
    /* UART Header files */
    #include <ti/drv/uart/UART.h>
    #include <ti/drv/uart/UART_stdio.h>
    /* UDMA Header files */
    #include <ti/drv/udma/udma.h>
    /* EMAC Driver Header File. */
    #include <ti/drv/emac/emac_drv.h>
    #include <ti/drv/emac/src/v5/emac_drv_v5.h>
    #include <ti/drv/emac/soc/emac_soc_v5.h>
    #include <ti/transport/ndk/nimu/src/v7/nimu_eth.h>
    #include <ti/ndk/inc/socket.h>
    #include <ti/ndk/inc/_stack.h>
    #include <ti/ndk/inc/socketndk.h>
    #include <ti/ndk/inc/tools/servers.h>
    #include <ti/ndk/inc/tools/console.h>
    #define NDK_htonl(a) ((((a) & 0xff000000) >> 24) | (((a) & 0x00ff0000) >> 8) | \
                      (((a) & 0x0000ff00) << 8)  | (((a) & 0x000000ff) << 24) )
    #define NDK_htons(a) ( (((a)>>8)&0xffU) + (((a)<<8)&0xff00U) )
    extern int32_t (*NimuEmacInitFxn[NIMU_NUM_EMAC_PORTS])(STKEVENT_Handle hEvent);
    extern char *LocalIPAddr;
    /*Declare to avoid compilation errors*/
    extern int NDK_send(SOCKET s,
                        void *pbuf,
                        int size,
                        int flags);
    extern int NDK_recv(SOCKET s,
                        void *pbuf,
                        int size,
                        int flags);
    extern SOCKET NDK_socket(int domain,
                             int type,
                             int protocol);
    extern int NDK_setsockopt(SOCKET s,
                              int level,
                              int op,
                              void *pbuf,
                              int bufsize);
    extern int NDK_bind(SOCKET s,
                        struct sockaddr *pName,
                        int len);
    extern int NDK_listen(SOCKET s,
                          int maxcon);
    extern SOCKET NDK_accept(SOCKET s,
                             int *plen);
    extern int NDK_bind( SOCKET s, struct sockaddr *pName, int len );
    extern int fdClose(void *hFd);
    extern int fdOpenSession(void *hOwner);
    extern void fdCloseSession(void *hTask);
    extern int fdPoll(FDPOLLITEM items[],
                      uint32_t itemcnt,
                      int32_t timeout);
    /* Semaphore to sync NDK stack init to start after NIMU application init complete */
    static Semaphore_Handle gSyncSemHandle;
    /* SOC  configuration structure */
    EMAC_HwAttrs_V5 emac_cfg;
    /* Udma driver handle and object */
    Udma_DrvHandle gUdmaDrvHandle = NULL;
    struct Udma_DrvObj gUdmaDrvObj;
    #ifdef NIMU_FTP_APP
    #include <ti/transport/ndk/nimu/example/ftpApp/ftpserver/ftpserver.h>
    #endif
    #ifdef NIMU_APP_ICSSG
    #include <ti/drv/emac/firmware/icss_dualmac/config/emac_fw_config_dual_mac.h>
    /* PRUSS Driver Header File. */
    #include <ti/drv/pruss/soc/pruicss_v1.h>
    /* TX port queue memory for 3 icss-g instances */
    uint8_t icss_tx_port_queue[1][100352] __attribute__ ((aligned (UDMA_CACHELINE_ALIGNMENT))) __attribute__ ((section (".bss:nimu_msmc_mem")));
    #endif
    #define NIMU_MAX_TABLE_ENTRIES   9U
    #define NIMU_NUM_PORTS 1U
    #define NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT 2U
    #define NIMU_TEST_MAX_CHANS_PER_PORT 1U
    #define TCPPACKETSIZE 1024
    #define TCPPORT 7
    /* brief Number of ring entries - we can prime this much memcpy operations */
    #define NIMU_TEST_APP_RING_ENTRIES      (128U)
    /* Size (in bytes) of each ring entry (Size of pointer - 64-bit) */
    #define NIMU_TEST_APP_RING_ENTRY_SIZE   (sizeof(uint64_t))
     /* Total ring memory */
    #define NIMU_TEST_APP_RING_MEM_SIZE     (NIMU_TEST_APP_RING_ENTRIES * \
                                              NIMU_TEST_APP_RING_ENTRY_SIZE)
    /* UDMA host mode buffer descriptor memory size.    *  Make it multiple of 128 byte alignment */
    #define NIMU_TEST_APP_DESC_SIZE         (sizeof(CSL_UdmapCppi5HMPD) + (128U - sizeof(CSL_UdmapCppi5HMPD)))
    /* UDMA driver objects
    struct Udma_ChObj       gUdmaTxChObj[NIMU_NUM_PORTS][NIMU_TEST_MAX_CHANS_PER_PORT];
    struct Udma_ChObj       gUdmaRxChObj[NIMU_NUM_PORTS];
    struct Udma_EventObj    gUdmaRxCqEventObj[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT];
    struct Udma_ChObj       gUdmaRxCfgPsiChObj[NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT];
    struct Udma_EventObj    gUdmaRxCfgPsiCqEventObj[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT];
    struct Udma_FlowObj gUdmaFlowHnd[NIMU_NUM_PORTS] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    struct Udma_RingObj gUdmaRxRingHnd[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    struct Udma_RingObj gUdmaRxCompRingHnd[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    struct Udma_RingObj gUdmaRxRingHndCfgPsi[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    struct Udma_RingObj gUdmaRxCompRingHndCfgPsi[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    struct Udma_FlowObj gUdmaFlowHndCfgPsi[NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gUdmapDescRamTx[NIMU_NUM_PORTS][NIMU_TEST_MAX_CHANS_PER_PORT][NIMU_TEST_APP_RING_ENTRIES * NIMU_TEST_APP_DESC_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
        __attribute__ ((section (".bss:nimu_ddr_mem")));
    static uint8_t gUdmapDescRamRx[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_ENTRIES * NIMU_TEST_APP_DESC_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gUdmapDescRamRxCfgPsi[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_ENTRIES * NIMU_TEST_APP_DESC_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
     * UDMA Memories
    static uint8_t gTxRingMem[NIMU_NUM_PORTS][NIMU_TEST_MAX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gTxCompRingMem[NIMU_NUM_PORTS][NIMU_TEST_MAX_CHANS_PER_PORT][NIMU_TEST_MAX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gRxRingMem[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gRxCompRingMem[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gRxRingMemCfgPsi[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    static uint8_t gRxCompRingMemCfgPsi[NIMU_NUM_PORTS][NIMU_TEST_MAX_SUB_RX_CHANS_PER_PORT][NIMU_TEST_APP_RING_MEM_SIZE] __attribute__ ((aligned(UDMA_CACHELINE_ALIGNMENT)))
    #define NIMU_EMAC_PORT_ICSS 0U
    #define NIMU_EMAC_PORT_CPSW 6U
    #ifdef NIMU_APP_CPSW
    uint32_t portNum = NIMU_EMAC_PORT_CPSW;
    #else
    /* ICSSG case */
    #ifdef am65xx_idk
    uint32_t portNum = NIMU_EMAC_PORT_ICSS + 4;
    #else
    #endif
    #endif
    Task_Handle main_task;
    NIMU_DEVICE_TABLE_ENTRY NIMUDeviceTable[NIMU_NUM_EMAC_PORTS];
    uint32_t gPgVersion2;
    #define APP_TEST_AM65XX_PG1_0_VERSION (0x0BB5A02FU)
    void TaskFxn(UArg a0, UArg a1);
    /* get handle to UDMA driver */
    Udma_DrvHandle nimu_app_get_udma_handle(void)
        return gUdmaDrvHandle;
    void nimu_app_setup_fw_dualmac(uint32_t port_num, EMAC_HwAttrs_V5 *pEmacCfg)
        EMAC_FW_APP_CONFIG *pFwAppCfg;
        emacGetDualMacFwAppInitCfg(port_num, &pFwAppCfg);
        pFwAppCfg->txPortQueueLowAddr = 0xFFFFFFFF & ((uint32_t) &icss_tx_port_queue[0][0]);
        pFwAppCfg->txPortQueueHighAddr = 0;
        emacSetDualMacFwAppInitCfg(port_num, pFwAppCfg);
        /* Need to update the emac configuraiton with  function required by the driver to get the FW configuration to write to shared mem */
        pEmacCfg->portCfg[port_num].getFwCfg = &emacGetDualMacFwConfig;
    #define NIMU_BUFFER_POOL_SIZE_PG2 0x2000u
    #define NIMU_MAX_NUM_BUFFER_POOLS_PG2 8u
    void nimu_app_setup_fw_dualmac_pg2(uint32_t port_num, EMAC_HwAttrs_V5 *pEmacCfg)
        uint32_t i;
        pFwAppCfg->bufferPoolLowAddr = 0xFFFFFFFF & ((uintptr_t) &icss_tx_port_queue[0][0]);
        pFwAppCfg->bufferPoolHighAddr = 0;
        pFwAppCfg->numBufferPool = NIMU_MAX_NUM_BUFFER_POOLS_PG2;
        for(i = 0; i < NIMU_MAX_NUM_BUFFER_POOLS_PG2; i++)
            pFwAppCfg->bufferPoolSize[i] = NIMU_BUFFER_POOL_SIZE_PG2;
    #endif
     *  ======== nimu_app_init_emac_k3========
    void nimu_app_init_emac_k3(uint32_t portNum, uint32_t index)
        EMAC_socGetInitCfg(0, &emac_cfg);
        int32_t chanNum = 0;
        int32_t subChanNum = 0;
        /* For ICSSG SOC config is or max channel/sub-channel config, only require 1 TX/RX channel and 1 RX sub-channel/flow for NIMU ICSSG example*/
        emac_cfg.portCfg[portNum].nTxChans = 1;
        emac_cfg.portCfg[portNum].rxChannel.nsubChan = 1;
        if (portNum != NIMU_EMAC_PORT_CPSW)
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.nsubChan = 2;
        /* rxChannel2CfgOverPSI currently not used for dual mac and cpsw use case */
        emac_cfg.portCfg[portNum].rxChannel2CfgOverPSI.nsubChan = 0;
        for (chanNum = 0; chanNum < emac_cfg.portCfg[portNum].nTxChans; chanNum++)
            emac_cfg.portCfg[portNum].txChannel[chanNum].chHandle = (void *)&gUdmaTxChObj[index][chanNum];
            emac_cfg.portCfg[portNum].txChannel[chanNum].freeRingMem= (void*)&gTxRingMem[index][chanNum][0];
            emac_cfg.portCfg[portNum].txChannel[chanNum].compRingMem= (void*)&gTxCompRingMem[index][chanNum][0];
            emac_cfg.portCfg[portNum].txChannel[chanNum].hPdMem = (void*)&gUdmapDescRamTx[index][chanNum][0];
        emac_cfg.portCfg[portNum].rxChannel.chHandle = (void *)&gUdmaRxChObj[index];
        emac_cfg.portCfg[portNum].rxChannel.flowHandle= (void *)&gUdmaFlowHnd[index];
        for (subChanNum = 0; subChanNum < emac_cfg.portCfg[portNum].rxChannel.nsubChan; subChanNum++)
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].freeRingMem[0] = (void*)&gRxRingMem[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].freeRingHandle[0] = (void*)&gUdmaRxRingHnd[index][subChanNum];
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].compRingMem= (void*)&gRxCompRingMem[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].compRingHandle= (void*)&gUdmaRxCompRingHnd[index][subChanNum];
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].hPdMem[0] = (void*)&gUdmapDescRamRx[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannel.subChan[subChanNum].eventHandle = (void *)&gUdmaRxCqEventObj[index][subChanNum];
        emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.chHandle = (void *)&gUdmaRxCfgPsiChObj[index];
        emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.flowHandle= (void *)&gUdmaFlowHndCfgPsi[index];
        for (subChanNum = 0; subChanNum < emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.nsubChan; subChanNum++)
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].freeRingMem[0] = (void*)&gRxRingMemCfgPsi[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].freeRingHandle[0] = (void*)&gUdmaRxRingHndCfgPsi[index][subChanNum];
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].compRingMem= (void*)&gRxCompRingMemCfgPsi[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].compRingHandle= (void*)&gUdmaRxCompRingHndCfgPsi[index][subChanNum];
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].hPdMem[0] = (void*)&gUdmapDescRamRxCfgPsi[index][subChanNum][0];
            emac_cfg.portCfg[portNum].rxChannelCfgOverPSI.subChan[subChanNum].eventHandle = (void *)&gUdmaRxCfgPsiCqEventObj[index][subChanNum];
        if (gPgVersion2 == APP_TEST_AM65XX_PG1_0_VERSION)
            nimu_app_setup_fw_dualmac(portNum, &emac_cfg);
        else
            nimu_app_setup_fw_dualmac_pg2(portNum, &emac_cfg);
    #endif
        EMAC_socSetInitCfg(0, &emac_cfg);
    uint32_t cpuLoadMax = 0;
    uint32_t cpuLoad = 0;
     *  \name NIMUStartUpTask
     *  \brief NIMU Startup Task
     *  \param a0
     *  \param a1
     *  \return none
    void NIMUStartUpTask(UArg a0, UArg a1)
        int32_t retVal;
        uint32_t nimu_device_index = 0U;
        Udma_InitPrms initPrms;
        uint32_t instId = 0;
        gPgVersion2 = CSL_REG32_RD(CSL_WKUP_CTRL_MMR0_CFG0_BASE + CSL_WKUP_CTRL_MMR_CFG0_JTAGID);
    #if defined (SOC_AM65XX)
    #if defined (NIMU_APP_CPSW)
            /* if A53 and pg 1.0 use mcu navss due to hw errata*/
    #if defined (BUILD_MPU1_0)
                instId = UDMA_INST_ID_MCU_0;
            else
                instId = UDMA_INST_ID_MAIN_0;
    #else
    #endif
    #else
    #if defined (__aarch64__)
    #else
    #endif
    #endif
    #endif
        UdmaInitPrms_init(instId, &initPrms);
        gUdmaDrvHandle = &gUdmaDrvObj;
        retVal = Udma_init(gUdmaDrvHandle, &initPrms);
        if(UDMA_SOK == retVal)
            UART_printf("Udma_init success\n");
        else
            UART_printf("Udma_init failure\n");
            while(1);
        nimu_app_init_emac_k3(portNum, nimu_device_index);
        NIMUDeviceTable[nimu_device_index++].init =  NimuEmacInitFxn[portNum];
        NIMUDeviceTable[nimu_device_index].init =  NULL;
        /* NIMUStartUpTask complete can post the semaphore now */
        Semaphore_post(gSyncSemHandle);
        while (1)
            Task_sleep(10000);
            cpuLoad = Load_getCPULoad();
            if (cpuLoad > cpuLoadMax)
                cpuLoadMax = cpuLoad;
            UART_printf("\ncpu load: %d, max cpu load: %d\n", cpuLoad, cpuLoadMax);
     *  \name TaskFxn
     *  \brief Task Fxn
     *  \param a0
     *  \param a1
     *  \return none
        UART_printf("\n\rSYS/BIOS Ethernet/IP () Sample application, EVM IP address I/F 1: %s\n\r", LocalIPAddr);
    #ifdef NIMU_FTP_APP
        UART_printf("TaskFxn: calling ftpserver_init\n");
        ftpserver_init();
    #endif
     *  \name tcpEchoTask
     *  \brief get statistics
     *  \param arg0
     *  \param arg1
     *  \return none
     void tcpEchoTask(UArg arg0, UArg arg1)
        SOCKET lSocket;
        struct sockaddr_in sLocalAddr;
        SOCKET clientfd;
        struct sockaddr_in client_addr;
        Int addrlen=sizeof(client_addr);
        Int status;
        Int nbytes;
        struct timeval timeout;
        char buffer[TCPPACKETSIZE];
        fdOpenSession(TaskSelf());
        lSocket = NDK_socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
        if (lSocket < 0) {
            UART_printf("connection error\n");
            Task_exit();
            return;
        memset((char *)&sLocalAddr, 0, sizeof(sLocalAddr));
        sLocalAddr.sin_family = AF_INET;
        sLocalAddr.sin_addr.s_addr = NDK_htonl(INADDR_ANY);
        sLocalAddr.sin_port = NDK_htons(arg0);
        status = NDK_bind(lSocket, (struct sockaddr *)&sLocalAddr, sizeof(sLocalAddr));
        if (status < 0) {
            UART_printf("bind error\n");
            fdClose(lSocket);
            Task_exit();
            return;
        if (NDK_listen(lSocket, 1) != 0){
            UART_printf("listen error\n");
            fdClose(lSocket);
            Task_exit();
            return;
        /* Configure our timeout to be 5 seconds */
        timeout.tv_sec  = 5;
        timeout.tv_usec = 0;
        NDK_setsockopt(lSocket, SOL_SOCKET, SO_SNDTIMEO, &timeout, sizeof( timeout));
        NDK_setsockopt(lSocket, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof( timeout));
        while (TRUE) {
            /* Wait for incoming request */
            clientfd = NDK_accept(lSocket, (struct sockaddr*)&client_addr, &addrlen);
            nbytes = NDK_recv(clientfd, (char *)buffer, TCPPACKETSIZE, 0);
            if (nbytes > 0) {
                /* Echo the data back */
                NDK_send(clientfd, (char *)buffer, nbytes, 0 );
                UART_printf("TCP socket connected, echoing back\n");
            fdClose(clientfd);
     *  ======== main ========
    int main(void)
        Task_Params taskParams;
        Semaphore_Params semParams;
        Board_STATUS boardInitStatus =0;
        Board_initCfg cfg = BOARD_INIT_UART_STDIO | BOARD_INIT_PINMUX_CONFIG | BOARD_INIT_MODULE_CLOCK  | BOARD_INIT_ICSS_ETH_PHY | BOARD_INIT_ETH_PHY;
        boardInitStatus = Board_init(cfg);
        if (boardInitStatus !=BOARD_SOK)
            UART_printf("Board_init failure\n");
            return(0);
        UART_printf("Board_init success\n");
        Semaphore_Params_init(&semParams);
        semParams.mode = Semaphore_Mode_BINARY;
        gSyncSemHandle =  Semaphore_create(0,&semParams,NULL);
        if (gSyncSemHandle == NULL)
            UART_printf("Semaphore creation failure\n");
            return 0;
        Task_Params_init(&taskParams);
        taskParams.priority = 1;
        taskParams.stackSize = 0x1400;
        main_task = Task_create (TaskFxn, &taskParams, NULL);
        taskParams.arg0 = (UArg)portNum;
        main_task = Task_create (NIMUStartUpTask, &taskParams, NULL);
        taskParams.stackSize = 0x4000;
        taskParams.arg0 = (UArg)TCPPORT;
        Task_create (tcpEchoTask, &taskParams, NULL);
        BIOS_start ();
        return 0;
    void InitMmu(void)
        bool retVal;
        uint32_t     mapIdx = 0;
        Mmu_MapAttrs attrs;
        Mmu_initMapAttrs(&attrs);
        attrs.attrIndx = 0;
        retVal = Mmu_map(0x00100000, 0x00100000, 0x00900000, &attrs); /* Main MMR0 cfg  */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x00400000, 0x00400000, 0x00001000, &attrs); /* PSC0          */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x01800000, 0x01800000, 0x00100000, &attrs); /* gicv3       */
        if (retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x02400000, 0x02400000, 0x000c0000, &attrs); /* dmtimer     */
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x02800000, 0x02800000, 0x00001000, &attrs); /* uart        */
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x02000000, 0x02000000, 0x00100000, &attrs); /* I2C            */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x02100000, 0x02100000, 0x00080000, &attrs); /* McSPI          */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x40F00000, 0x40F00000, 0x00020000, &attrs); /* MCU MMR0 CFG   */
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x40d00000, 0x40d00000, 0x00002000, &attrs); /* PLL0     CFG       */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x43000000, 0x43000000, 0x00020000, &attrs); /* WKUP     MMR0 cfg  */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x02C40000, 0x02C40000, 0x00100000, &attrs); /* pinmux     ctrl    */
        if(retVal == FALSE)
            goto mmu_exit;
            mapIdx++;
            retVal = Mmu_map(0x30800000, 0x30800000, 0x0C000000, &attrs); /* main  navss          */
            if(retVal == FALSE)
                goto mmu_exit;
            mapIdx++;
        retVal = Mmu_map(0x28380000, 0x28380000, 0x03880000, &attrs); /* mcu navss          */
        if(retVal == FALSE)
            goto mmu_exit;
        mapIdx++;
        retVal = Mmu_map(0x30000000ul, 0x30000000ul, 0x0F000000ul, &attrs); /* ctcontro10 */
            goto mmu_exit;
        mapIdx++;
        /* for CPSW */
        retVal = Mmu_map(CSL_MCU_CPSW0_NUSS_BASE, CSL_MCU_CPSW0_NUSS_BASE,
                                        (CSL_MCU_CPSW0_NUSS_SIZE*2), &attrs);
            goto mmu_exit;
        /* ICSS-G 0 */
        mapIdx++;
        retVal = Mmu_map(0xb000000ul, 0xb000000ul, 0x0100000ul, &attrs);
            goto mmu_exit;
         /* ICSS-G 1 */
         mapIdx++;
         retVal = Mmu_map(0xb100000ul, 0xb100000ul, 0x0100000ul, &attrs);
             goto mmu_exit;
         /* ICSS-G 2 */
         mapIdx++;
         retVal = Mmu_map(0xb200000ul, 0xb200000ul, 0x0100000ul, &attrs);
             goto mmu_exit;
         /* PSC WKUP*/
         mapIdx++;
         retVal = Mmu_map(0x42000000ul, 0x42000000ul, 0x00001000ul, &attrs);
             goto mmu_exit;
        /* NB0_CFG_MMRS */
        mapIdx++;
        retVal = Mmu_map(0x03802000, 0x03802000, 0x00001000, &attrs);
            goto mmu_exit;
        attrs.attrIndx = 7;
        mapIdx++;
        retVal = Mmu_map(0x70000000, 0x70000000, 0x04000000, &attrs); /* msmc        */
            goto mmu_exit;
    #define DDR_TEST
    #ifdef DDR_TEST
      attrs.attrIndx = 7;
      mapIdx++;
      retVal = Mmu_map(0x80000000, 0x80000000, 0x10000000, &attrs); /* ddr_0        */
          goto mmu_exit;
    #endif
     attrs.attrIndx = 7;
     mapIdx++;
     retVal = Mmu_map(0x41C00000, 0x41C00000, 0x00080000, &attrs); /* ocmc        */
         goto mmu_exit;
    mmu_exit:
        if(retVal == FALSE)
            UART_printf("Mmu_map idx %d returned error %d", mapIdx, retVal);
            while(1);
    #endif
    void stackInitHook(void* hCfg)
        int rc;
        rc = 16384; // increase stack size
        CfgAddEntry(hCfg, CFGTAG_OS, CFGITEM_OS_TASKSTKBOOT,CFG_ADDMODE_UNIQUE, sizeof(uint32_t), (uint8_t *)&rc, 0 );
        /* Wait for NIMU startup to complete before proceeding */
        Semaphore_pend(gSyncSemHandle, SemaphoreP_WAIT_FOREVER);
    static void *hEcho = 0;
    static void *hEchoUdp = 0;
    static void *hData = 0;
    static void *hNull = 0;
    static void *hOob = 0;
    void NimuApp_netOpenHook()
        /* Create our local servers */
        hEcho = DaemonNew( SOCK_STREAMNC, 0, 7, dtask_tcp_echo,
                           OS_TASKPRINORM, OS_TASKSTKNORM, 0, 3 );
        hEchoUdp = DaemonNew( SOCK_DGRAM, 0, 7, dtask_udp_echo,
                              OS_TASKPRINORM, OS_TASKSTKNORM, 0, 1 );
        hData = DaemonNew( SOCK_STREAM, 0, 1000, dtask_tcp_datasrv,
        hNull = DaemonNew( SOCK_STREAMNC, 0, 1001, dtask_tcp_nullsrv,
        hOob  = DaemonNew( SOCK_STREAMNC, 0, 999, dtask_tcp_oobsrv,
    void NimuApp_netCloseHook()
        DaemonFree(hOob);
        DaemonFree(hNull);
        DaemonFree(hData);
        DaemonFree(hEchoUdp);
        DaemonFree(hEcho);
    Corresponding BIOS config file (Refer to the NDK and TCP/IP part only)
    nimuExample_r5.cfg
    Create tasks from main() instead of BIOS config file.
    Vineet
  • Hi Vineet,
    Thank for replying.
    The mistake i was doing was, before initializing NDK stack, i was calling socket() api.
    After analyzing some vision SDK files and the files sent bu you, i provided hook function ( same as what vision SDK has provided).
    Now, NDK stack is configured and i'm able to open a socket.
    However, as i saw some other threads, they are saying about IP address being displayed after fdOpenSession().
    But im not able to see my IP address.
    does it mean that the initialization is still not complete ??
    Please let me know
    Likhith
