2路米皮接5路YUV和3路raw12,无法正常取图
#include <string.h> #include <iostream> #include <unistd.h> #include <map> #include <TI/j7.h> #include <TI/tivx_config.h> #include <TI/tivx_event.h> #include <TI/tivx_task.h> #include "math.h" #include <limits.h> #include <sys/time.h> #include <time.h> extern "C" { #include "remote_service/include/app_remote_service.h" #include "ipc/include/app_ipc.h" #include "iss/include/app_iss.h" #include "sensors/include/app_sensors.h" } #include "camera_inst.h" #include "camera_tool.h" #include "camera.h" using namespace std; namespace baidu { namespace idg { namespace gaia { #define RAW_DATA 1 #define YUV_DATA 1 #define TIVX_TARGET_DEFAULT_STACK_SIZE (256U * 1024U) #define TIVX_TARGET_DEFAULT_TASK_PRIORITY1 (8u) #define ENABLED_NUM_CHANNELS (4U) #define NUM_BUF (4) #define MAX_ABS_FILENAME (1024u) #define NUM_CHANNELS_PER_MIPI (4U) #define NUM_INST (1U) #define IMAGE_WIDTH (1920) #define IMAGE_HEIGHT (1080) #define IMAGE_FORMAT (VX_DF_IMAGE_UYVY) #define APP_MAX_FILE_PATH (255) #define CAPTURE_NODE_ERROR (1U) static char gs_sensor_name[128] = SENSOR_OV1F_HIK_MAX96717F; static int gs_channel_mask = 0xFF; static std::map<std::string, Camera*> gs_camera_name_map; static const vx_char user_data_object_name[] = "tivx_capture_params_t"; static CameraConfig _config[8]; Camera* get_camera_instance() { static Camera_inst cam; return &cam; } CameraParam& Camera_inst::get_cameraparam(void) { return _param; } int32_t Camera_inst::set_cameraparam(CameraParam& para) { _param.sync_call_back = para.sync_call_back; _param.call_back_period_us = para.call_back_period_us; return 0; } int32_t copy_image(vx_object_array out_capture_frames, uint32_t buf_id, void *user_ptr) { uint32_t width, height; vx_imagepatch_addressing_t image_addr; vx_rectangle_t rect; vx_map_id map_id; void *data_ptr = NULL; uint32_t num_bytes_per_pixel = 2; vx_df_image format; vx_image img; vx_bool is_invalid = 1; if (user_ptr == nullptr) { return -1; } // if (not_lock[buf_id] == 1) { // //printf("camera %d not lock\n", buf_id); // return -2; // } //printf("get item buf_id=%d\n", buf_id); img = (vx_image)vxGetObjectArrayItem(out_capture_frames, buf_id); if (img == nullptr) { // printf("Get image failed buf_id:%d\n", buf_id); return -3; } vxQueryReference((vx_reference)img, TIVX_REFERENCE_INVALID, &is_invalid, sizeof(is_invalid)); if (is_invalid != 0) { //printf("[%s]buf_id:%d, is_invalid\n", __FUNCTION__, buf_id); return -4; } vxQueryImage(img, VX_IMAGE_WIDTH, &width, sizeof(vx_uint32)); vxQueryImage(img, VX_IMAGE_HEIGHT, &height, sizeof(vx_uint32)); vxQueryImage(img, VX_IMAGE_FORMAT, &format, sizeof(format)); rect.start_x = 0; rect.start_y = 0; rect.end_x = width; rect.end_y = height; vxMapImagePatch(img, &rect, 0, &map_id, &image_addr, &data_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, VX_NOGAP_X ); if (!data_ptr) { printf("Map Image Patch failed,data_ptr is NULL \n"); return -2; } memcpy(user_ptr, data_ptr, width * height * num_bytes_per_pixel); vxUnmapImagePatch(img, map_id); vxReleaseImage(&img); return 0; } int32_t copy_raw_image(vx_object_array out_capture_frames, uint32_t buf_id, void *user_ptr) { uint32_t width, height; vx_imagepatch_addressing_t image_addr; vx_rectangle_t rect; vx_map_id map_id; void *data_ptr = NULL; uint32_t num_bytes_per_pixel = 2; vx_df_image format; #ifndef RAW_IMAGE vx_image img = NULL; #else tivx_raw_image img; #endif vx_bool is_invalid = 1; if (user_ptr == nullptr) { return -1; } // if (not_lock[buf_id] == 1) { // //printf("camera %d not lock\n", buf_id); // return -2; // } //printf("get item buf_id=%d\n", buf_id); #ifndef RAW_IMAGE img = (vx_image)vxGetObjectArrayItem(out_capture_frames, buf_id); if (img == nullptr) { // printf("Get image failed buf_id:%d\n", buf_id); return -3; } vxQueryReference((vx_reference)img, TIVX_REFERENCE_INVALID, &is_invalid, sizeof(is_invalid)); if (is_invalid != 0) { //printf("[%s]buf_id:%d, is_invalid\n", __FUNCTION__, buf_id); return -4; } vxQueryImage(img, VX_IMAGE_WIDTH, &width, sizeof(vx_uint32)); vxQueryImage(img, VX_IMAGE_HEIGHT, &height, sizeof(vx_uint32)); vxQueryImage(img, VX_IMAGE_FORMAT, &format, sizeof(format)); rect.start_x = 0; rect.start_y = 0; rect.end_x = width; rect.end_y = height; vxMapImagePatch(img, &rect, 0, &map_id, &image_addr, &data_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, VX_NOGAP_X ); if (!data_ptr) { printf("Map Image Patch failed,data_ptr is NULL \n"); return -2; } memcpy(user_ptr, data_ptr, width * height * num_bytes_per_pixel); vxUnmapImagePatch(img, map_id); vxReleaseImage(&img); #else img = (tivx_raw_image)vxGetObjectArrayItem(out_capture_frames, buf_id); vxQueryReference((vx_reference)img, TIVX_REFERENCE_INVALID, &is_invalid, sizeof(is_invalid)); if (is_invalid != 0) { //printf("[%s]buf_id:%d, is_invalid\n", __FUNCTION__, buf_id); return -4; } tivxQueryRawImage(img, TIVX_RAW_IMAGE_WIDTH, &width, sizeof(vx_uint32)); tivxQueryRawImage(img, TIVX_RAW_IMAGE_HEIGHT, &height, sizeof(vx_uint32)); tivxQueryRawImage(img, TIVX_RAW_IMAGE_FORMAT, &format, sizeof(format)); // printf("width %d height%d\n",width,height); rect.start_x = 0; rect.start_y = 0; rect.end_x = width; rect.end_y = height; tivxMapRawImagePatch(img, &rect, 0, &map_id, &image_addr, &data_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, TIVX_RAW_IMAGE_PIXEL_BUFFER ); if (!data_ptr) { printf("Map Image Patch failed,data_ptr is NULL \n"); return -2; } memcpy(user_ptr, data_ptr, width * height * num_bytes_per_pixel); tivxUnmapRawImagePatch(img, map_id); tivxReleaseRawImage(&img); #endif return 0; } /* * Utility API used to add a raw_graph parameter from a node, node parameter index */ void add_graph_parameter_by_node_index(vx_graph raw_graph, vx_node node, vx_uint32 node_parameter_index) { vx_parameter parameter = vxGetParameterByIndex(node, node_parameter_index); vxAddParameterToGraph(raw_graph, parameter); vxReleaseParameter(¶meter); } int32_t Camera_inst::power_up() { appPowerOnImageSensor(gs_sensor_name, 0, gs_channel_mask); appInitImageSensor(gs_sensor_name, 0, gs_channel_mask); appStartImageSensor(gs_sensor_name, gs_channel_mask); return 0; } int32_t Camera_inst::power_down() { appStopImageSensor(gs_sensor_name, gs_channel_mask); appDeInitImageSensor(gs_sensor_name); return 0; } void _init_config(CameraConfig config[]) { config[0].width = 1280; config[0].height = 960; config[0].name = "v0"; config[0].format = FMT_YUV422_UYVY; config[1].width = 1920; config[1].height = 1080; config[1].name = "v1"; config[1].format = FMT_YUV422_UYVY; config[2].width = 1920; config[2].height = 1080; config[2].name = "v2"; config[2].format = FMT_YUV422_UYVY; config[3].width = 1920; config[3].height = 1080; config[3].name = "v3"; config[3].format = FMT_YUV422_UYVY; // config[4].width = 1920; // config[4].height = 1080; // config[4].name = "v4"; // config[4].format = FMT_YUV422_UYVY; // config[5].width = 1280; // config[5].height = 960; // config[5].name = "v5"; // config[5].format = FMT_YUV422_UYVY; // config[6].width = 1280; // config[6].height = 960; // config[6].name = "v6"; // config[6].format = FMT_YUV422_UYVY; // config[7].width = 1280; // config[7].height = 960; // config[7].name = "v7"; // config[7].format = FMT_YUV422_UYVY; } #define MAX_NUM_BUF (8u) #define NUM_CHANNELS (1U) #define NUM_2_CHANNELS (3U) #define CAPT1_INST_ID (0U) #define CAPT2_INST_ID (1U) #define CAPT1_INST_SENSOR_MASK ((1 << NUM_CHANNELS) - 1U) #define CAPT2_INST_SENSOR_MASK (((1 << NUM_CHANNELS) - 1U) << 4U) #define CAPTURE1_ENABLE (1U) #define CAPTURE2_ENABLE (1U) static uint32_t num_buf = 4; static tivx_event eventHandle_RxFinished; static tivx_event eventHandle_RxFinished1; static tivx_event eventHandle_SensorCfgDone; uint32_t sensorCfgDone = 0U; static vx_context context; static tivx_raw_image raw_img_exemplar; static vx_image img_exemplar; vx_graph graph = nullptr; vx_graph raw_graph = nullptr; static void VX_CALLBACK tivxTask_capture(void *app_var) { vx_node csirx_node = 0; int num_buf = 4; vx_object_array capture_frames[MAX_NUM_BUF]; vx_user_data_object capture_config; tivx_capture_params_t local_capture_config; uint32_t buf_id, loop_id, loopCnt; vx_graph_parameter_queue_params_t csirx_graph_parameters_queue_params_list[1]; printf("tivxTask_capture \n"); vx_graph csirx_graph = (vx_graph)app_var; /* allocate Input and Output refs, multiple refs created to allow pipelining of csirx_graph */ for(buf_id=0; buf_id<num_buf; buf_id++) { capture_frames[buf_id] = vxCreateObjectArray(context, (vx_reference)img_exemplar, NUM_CHANNELS); } /* CSIRX Config initialization */ tivx_capture_params_init(&local_capture_config); local_capture_config.numInst = 1U; local_capture_config.numCh = NUM_CHANNELS; local_capture_config.instId[0U] = CAPT1_INST_ID; local_capture_config.instCfg[0U].enableCsiv2p0Support = (uint32_t)vx_true_e; local_capture_config.instCfg[0U].numDataLanes = 4U; for (loopCnt = 0U ; loopCnt < local_capture_config.instCfg[0U].numDataLanes ; loopCnt++) { local_capture_config.instCfg[0U].dataLanesMap[loopCnt] = (loopCnt + 1u); } for (loopCnt = 0U; loopCnt < NUM_CHANNELS; loopCnt++) { local_capture_config.chVcNum[loopCnt] = loopCnt; local_capture_config.chInstMap[loopCnt] = CAPT1_INST_ID; } capture_config = vxCreateUserDataObject(context, "tivx_capture_params_t", sizeof(tivx_capture_params_t), &local_capture_config); csirx_node = tivxCaptureNode(csirx_graph, capture_config, capture_frames[0]); /* input @ node index 0, becomes csirx_graph parameter 1 */ add_graph_parameter_by_node_index(csirx_graph, csirx_node, 1); /* set csirx_graph schedule config such that csirx_graph parameter @ index 0 and 1 are enqueuable */ csirx_graph_parameters_queue_params_list[0].graph_parameter_index = 0; csirx_graph_parameters_queue_params_list[0].refs_list_size = num_buf; csirx_graph_parameters_queue_params_list[0].refs_list = (vx_reference*)&capture_frames[0]; /* Schedule mode auto is used, here we dont need to call vxScheduleGraph * Graph gets scheduled automatically as refs are enqueued to it */ vxSetGraphScheduleConfig(csirx_graph, VX_GRAPH_SCHEDULE_MODE_QUEUE_AUTO, 1, csirx_graph_parameters_queue_params_list ); vxSetNodeTarget(csirx_node, VX_TARGET_STRING, TIVX_TARGET_CAPTURE1); vxVerifyGraph(csirx_graph); /* iniitalizing sensor */ //appStartImageSensor(sensor_name, CAPT1_INST_SENSOR_MASK);/*Mask for 2 cameras*/ /* enqueue capture buffers for pipeup but dont trigger graph executions */ for(buf_id=0; buf_id<num_buf-1; buf_id++) { tivxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&capture_frames[buf_id], 1, TIVX_GRAPH_PARAMETER_ENQUEUE_FLAG_PIPEUP); } /* after pipeup, now enqueue a buffer to trigger graph scheduling */ vxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&capture_frames[buf_id], 1); /* wait for csirx_graph instances to complete, compare output and recycle data buffers, schedule again */ for(loop_id=0; loop_id<1000; loop_id++) { uint32_t num_refs; vx_object_array captured_frames = NULL; /* Get captured frame reference, waits until a reference is available */ vxGraphParameterDequeueDoneRef(csirx_graph, 0, (vx_reference*)&captured_frames, 1, &num_refs); #if (CAPTURE2_ENABLE == 1U) printf("%s %d sensorCfgDone %d\n",__func__,__LINE__,sensorCfgDone); if (sensorCfgDone == 0U) { tivxEventPost(eventHandle_SensorCfgDone); printf("%s %d\n",__func__,__LINE__); sensorCfgDone = 1U; } #endif if(captured_frames == NULL){ printf("captured_frames NULL\n"); continue; } CameraData data; uint8_t *yuv_ptr = (uint8_t*)malloc(IMAGE_WIDTH * IMAGE_HEIGHT * 2); if (copy_image(captured_frames, 0, yuv_ptr) == 0) { printf("---------------------YUV OK\n"); }else{ printf("---------------------YUV no\n"); } free(yuv_ptr); vxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&captured_frames, 1); } /* ensure all csirx_graph processing is complete */ //vxWaitGraph(csirx_graph); //appStopImageSensor(sensor_name, CAPT1_INST_SENSOR_MASK)); /*Mask for 2 cameras*/ // vxReleaseNode(&csirx_node); // for(buf_id=0; buf_id<num_buf; buf_id++) // { // VX_CALL(vxReleaseObjectArray(&capture_frames[buf_id])); // } // VX_CALL(vxReleaseUserDataObject(&capture_config)); /*Signal the completion of csirx graph processing*/ printf("eventHandle_RxFinished post1\n"); tivxEventPost(eventHandle_RxFinished); printf("eventHandle_RxFinished post2\n"); } static void VX_CALLBACK tivxTask_capture1(void *app_var) { vx_node csirx_node = 0; vx_object_array capture_frames[MAX_NUM_BUF]; vx_user_data_object capture_config; tivx_capture_params_t local_capture_config; uint32_t buf_id, loop_id, loopCnt; vx_graph_parameter_queue_params_t csirx_graph_parameters_queue_params_list[1]; printf("tivxTask_capture1 \n"); vx_graph csirx_graph = (vx_graph)app_var; printf("%s %d\n",__func__,__LINE__); // ASSERT(num_buf > 0); if(CAPTURE1_ENABLE == 1U){ tivxEventWait(eventHandle_SensorCfgDone, TIVX_EVENT_TIMEOUT_WAIT_FOREVER); } printf("%s %d\n",__func__,__LINE__); /* allocate Input and Output refs, multiple refs created to allow pipelining of csirx_graph */ for(buf_id=0; buf_id<num_buf; buf_id++) { capture_frames[buf_id] = vxCreateObjectArray(context, (vx_reference)raw_img_exemplar, NUM_2_CHANNELS); } printf("%s %d\n",__func__,__LINE__); /* CSIRX Config initialization */ tivx_capture_params_init(&local_capture_config); local_capture_config.timeout = 33; local_capture_config.timeoutInitial = 500; local_capture_config.numInst = 1U; local_capture_config.numCh = NUM_2_CHANNELS; local_capture_config.instId[0U] = CAPT2_INST_ID; local_capture_config.instCfg[0U].enableCsiv2p0Support = (uint32_t)vx_true_e; local_capture_config.instCfg[0U].numDataLanes = 4U; int chIdx = 0U; for (loopCnt = 0U ; loopCnt < local_capture_config.instCfg[0U].numDataLanes ; loopCnt++) { local_capture_config.instCfg[0U].dataLanesMap[loopCnt] = (loopCnt + 1u); } for (loopCnt = 1U; loopCnt < 4; loopCnt++) { local_capture_config.chVcNum[chIdx] = loopCnt; local_capture_config.chInstMap[chIdx] = CAPT2_INST_ID; chIdx++; } capture_config = vxCreateUserDataObject(context, "tivx_capture_params_t", sizeof(tivx_capture_params_t), &local_capture_config); printf("%s %d\n",__func__,__LINE__); csirx_node = tivxCaptureNode(csirx_graph, capture_config, capture_frames[0]); printf("%s %d\n",__func__,__LINE__); vxSetNodeTarget(csirx_node, VX_TARGET_STRING, TIVX_TARGET_CAPTURE1); printf("%s %d\n",__func__,__LINE__); /* input @ node index 0, becomes csirx_graph parameter 1 */ add_graph_parameter_by_node_index(csirx_graph, csirx_node, 1); printf("%s %d\n",__func__,__LINE__); /* set csirx_graph schedule config such that csirx_graph parameter @ index 0 and 1 are enqueuable */ csirx_graph_parameters_queue_params_list[0].graph_parameter_index = 0; csirx_graph_parameters_queue_params_list[0].refs_list_size = num_buf; csirx_graph_parameters_queue_params_list[0].refs_list = (vx_reference*)&capture_frames[0]; /* Schedule mode auto is used, here we dont need to call vxScheduleGraph * Graph gets scheduled automatically as refs are enqueued to it */ vxSetGraphScheduleConfig(csirx_graph, VX_GRAPH_SCHEDULE_MODE_QUEUE_AUTO, 1, csirx_graph_parameters_queue_params_list ); printf("%s %d\n",__func__,__LINE__); vxVerifyGraph(csirx_graph); vx_status status = vxVerifyGraph(csirx_graph); if (status == (vx_status)VX_SUCCESS) { printf("camera:verify raw_graph success\n"); } else { printf("camera:verify raw_graph failed\n"); } /* iniitalizing sensor */ //appStartImageSensor(sensor_name1, CAPT2_INST_SENSOR_MASK));/*Mask for 2 cameras*/ /* enqueue capture buffers for pipeup but dont trigger graph executions */ for(buf_id=0; buf_id<num_buf-1; buf_id++) { tivxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&capture_frames[buf_id], 1, TIVX_GRAPH_PARAMETER_ENQUEUE_FLAG_PIPEUP); } /* after pipeup, now enqueue a buffer to trigger graph scheduling */ vxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&capture_frames[buf_id], 1); /*after pipeup, trigger again with last buffer */ vxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&capture_frames[num_buf-1], 1); /* wait for csirx_graph instances to complete, compare output and recycle data buffers, schedule again */ for(loop_id=0; loop_id<1000; loop_id++) { uint32_t num_refs; vx_object_array captured_frames = NULL; /* Get captured frame reference, waits until a reference is available */ vxGraphParameterDequeueDoneRef(csirx_graph, 0, (vx_reference*)&captured_frames, 1, &num_refs); for (int i = 0; i < 3; i++) { int frame_size = 1920*1080; CameraData data; uint8_t *yuv_ptr = (uint8_t*)malloc(IMAGE_WIDTH * IMAGE_HEIGHT * 2); if (copy_raw_image(captured_frames, i, yuv_ptr) == 0) { data.chan_id = i; data.img_ptr = yuv_ptr; data.framesize = frame_size *2; // data.camera_name = _config[i].name; // data.frame_cnt = 0;//TODO // data.height = _config[i].height; // data.width = _config[i].width; // data.format = _config[i].format; clock_gettime(CLOCK_REALTIME, &(data.capture_ts)); memcpy(&(data.trigger_ts), &(data.capture_ts), sizeof(data.capture_ts)); //output->push_back(data); printf("%d RAW OK \n",i); } free(yuv_ptr); } vxGraphParameterEnqueueReadyRef(csirx_graph, 0, (vx_reference*)&captured_frames, 1); } // /* ensure all csirx_graph processing is complete */ // vxWaitGraph(csirx_graph); // VX_CALL(appStopImageSensor(sensor_name1, CAPT2_INST_SENSOR_MASK)); // VX_CALL(vxReleaseNode(&csirx_node)); // for(buf_id=0; buf_id<num_buf; buf_id++) // { // VX_CALL(vxReleaseObjectArray(&capture_frames[buf_id])); // } // VX_CALL(vxReleaseUserDataObject(&capture_config)); /*Signal the completion of csirx graph processing*/ printf("eventHandle_RxFinished post3\n"); tivxEventPost(eventHandle_RxFinished1); printf("eventHandle_RxFinished post4\n"); } tivx_task taskHandle_capture; tivx_task taskHandle_capture1; int32_t Camera_inst::init() { std::cout << "init camera start" << std::endl; IssSensor_CreateParams sensorParams; uint32_t channel_mask = 0xff; vx_status status; // _init_config(_config); tivx_task_create_params_t taskParams_capture; context = vxCreateContext(); tivxHwaLoadKernels(context); //CT_RegisterForGarbageCollection(context, ct_teardown_hwa_kernels, CT_GC_OBJECT); tivx_clr_debug_zone(VX_ZONE_INFO); graph = vxCreateGraph(context); status = vxGetStatus((vx_reference)graph); if (VX_SUCCESS == status) { printf("camera:graph create success\n"); vxSetReferenceName((vx_reference)raw_graph, "CAMERA_CAPTURE_GRAPH"); }else{ printf("camera:raw_graph create fail\n"); } raw_graph = vxCreateGraph(context); status = vxGetStatus((vx_reference)raw_graph); if (VX_SUCCESS == status) { printf("camera:raw_graph create success\n"); vxSetReferenceName((vx_reference)raw_graph, "CAMERA_CAPTURE_GRAPH"); }else{ printf("camera:raw_graph create fail\n"); } memset(&sensorParams, 0, sizeof(sensorParams)); appQueryImageSensor(gs_sensor_name, &sensorParams); appInitImageSensor(sensorParams.name, 0, channel_mask); sensorParams.sensorInfo.raw_params.width = 1920; sensorParams.sensorInfo.raw_params.height = 1080; sensorParams.sensorInfo.raw_params.format[0] = {TIVX_RAW_IMAGE_16_BIT, 11}; printf("raw size width %d height %d\n",sensorParams.sensorInfo.raw_params.width,sensorParams.sensorInfo.raw_params.height); printf("sensorParams.sensorInfo.raw_params.format %d \n",sensorParams.sensorInfo.raw_params.format[0]); sensorParams.sensorInfo.raw_params.num_exposures = 1; sensorParams.sensorInfo.raw_params.line_interleaved = vx_false_e; sensorParams.sensorInfo.raw_params.meta_height_before = 0;//1280; sensorParams.sensorInfo.raw_params.meta_height_after = 4;//1280; raw_img_exemplar = tivxCreateRawImage(context, &(sensorParams.sensorInfo.raw_params)); status = vxGetStatus((vx_reference)raw_img_exemplar); if (status == (vx_status)VX_SUCCESS) { printf("camera:raw_img_exemplar create success\n"); } else { printf("camera:raw_img_exemplar create failed\n"); vxReleaseGraph(&raw_graph); tivxHwaUnLoadKernels(context); vxReleaseContext(&context); return -1; } img_exemplar = vxCreateImage(context, IMAGE_WIDTH, IMAGE_HEIGHT, IMAGE_FORMAT); status = vxGetStatus((vx_reference)img_exemplar); if (status == (vx_status)VX_SUCCESS) { printf("camera:img_exemplar create success\n"); } else { printf("camera:img_exemplar create failed\n"); vxReleaseGraph(&raw_graph); tivxHwaUnLoadKernels(context); vxReleaseContext(&context); return -1; } #if (CAPTURE1_ENABLE == 1U) tivxEventCreate(&eventHandle_RxFinished); // Setting up task params for capture_task tivxTaskSetDefaultCreateParams(&taskParams_capture); taskParams_capture.task_main = &tivxTask_capture; taskParams_capture.app_var = graph; taskParams_capture.stack_ptr = NULL; taskParams_capture.stack_size = TIVX_TARGET_DEFAULT_STACK_SIZE; taskParams_capture.core_affinity = TIVX_TASK_AFFINITY_ANY; taskParams_capture.priority = TIVX_TARGET_DEFAULT_TASK_PRIORITY1; tivxTaskCreate(&taskHandle_capture, &taskParams_capture); #endif #if (CAPTURE2_ENABLE == 1U) tivxEventCreate(&eventHandle_RxFinished1); tivxEventCreate(&eventHandle_SensorCfgDone); // Setting up task params for capture_task 1 tivxTaskSetDefaultCreateParams(&taskParams_capture); taskParams_capture.task_main = &tivxTask_capture1; taskParams_capture.app_var = raw_graph; taskParams_capture.stack_ptr = NULL; taskParams_capture.stack_size = TIVX_TARGET_DEFAULT_STACK_SIZE; taskParams_capture.core_affinity = TIVX_TASK_AFFINITY_ANY; taskParams_capture.priority = TIVX_TARGET_DEFAULT_TASK_PRIORITY1; tivxTaskCreate(&taskHandle_capture1, &taskParams_capture); #endif //Wait for both Graph Processing to complete #if (CAPTURE1_ENABLE == 1U) tivxEventWait(eventHandle_RxFinished, TIVX_EVENT_TIMEOUT_WAIT_FOREVER); #endif #if (CAPTURE2_ENABLE == 1U) tivxEventWait(eventHandle_RxFinished1, TIVX_EVENT_TIMEOUT_WAIT_FOREVER); #endif std::cout << "init camera success" << std::endl; return 0; } int32_t Camera_inst::uninit() { uint32_t buf_id = 0; uint32_t num_buf = NUM_BUF; uint32_t num_refs; vx_object_array out_capture_frames; printf("uinit\n"); /* ensure all raw_graph processing is complete */ appStopImageSensor(gs_sensor_name, gs_channel_mask); #if (CAPTURE1_ENABLE == 1U) // appDeInitImageSensor(sensor_name); #endif #if (CAPTURE2_ENABLE == 1U) // appDeInitImageSensor(sensor_name1); #endif #if (CAPTURE1_ENABLE == 1U) tivxReleaseRawImage(&raw_img_exemplar); #endif #if (CAPTURE2_ENABLE == 1U) vxReleaseImage(&img_exemplar); #endif #if (CAPTURE1_ENABLE == 1U) vxReleaseGraph(&graph); #endif #if (CAPTURE2_ENABLE == 1U) vxReleaseGraph(&raw_graph); #endif #if (CAPTURE1_ENABLE == 1U) tivxEventDelete(&eventHandle_RxFinished); tivxTaskDelete(&taskHandle_capture); #endif #if (CAPTURE2_ENABLE == 1U) tivxEventDelete(&eventHandle_RxFinished1); tivxEventDelete(&eventHandle_SensorCfgDone); tivxTaskDelete(&taskHandle_capture1); #endif tivxHwaUnLoadKernels(context); tivx_clr_debug_zone(VX_ZONE_INFO); std::cout << "uninit camera success" << std::endl; return 0; } void Camera_inst::check_camera_reg() { int32_t ret = 0; RemoteI2cParams param; int i = 0; param.nRegAddrWidth = 16; param.nI2cId = 3; param.nSlaveAddr = 0x29; param.nRegAddr = 0x1A; ret = appWriteReadRegImageSensor(gs_sensor_name, 0x1, IMAGE_SENSOR_CTRLCMD_READ_SENSOR_REG, ¶m); //printf("read reg slave=0x%x,reg=0x%x,val=0x%x\n", param.nSlaveAddr,param.nRegAddr, param.nRegValue); if((param.nRegValue & 0x08) == 0) { not_lock[0] = 1; } param.nRegAddrWidth = 16; param.nI2cId = 3; param.nSlaveAddr = 0x29; param.nRegAddr = 0x0A; ret = appWriteReadRegImageSensor(gs_sensor_name, 0x1, IMAGE_SENSOR_CTRLCMD_READ_SENSOR_REG, ¶m); //printf("read reg slave=0x%x,reg=0x%x,val=0x%x\n", param.nSlaveAddr,param.nRegAddr, param.nRegValue); if((param.nRegValue & 0x08) == 0) { not_lock[1] = 1; } param.nRegAddrWidth = 16; param.nI2cId = 3; param.nSlaveAddr = 0x29; param.nRegAddr = 0x0B; ret = appWriteReadRegImageSensor(gs_sensor_name, 0x1, IMAGE_SENSOR_CTRLCMD_READ_SENSOR_REG, ¶m); //printf("read reg slave=0x%x,reg=0x%x,val=0x%x\n", param.nSlaveAddr,param.nRegAddr, param.nRegValue); if((param.nRegValue & 0x08) == 0) { not_lock[2] = 1; } param.nRegAddrWidth = 16; param.nI2cId = 3; param.nSlaveAddr = 0x29; param.nRegAddr = 0x0C; ret = appWriteReadRegImageSensor(gs_sensor_name, 0x1, IMAGE_SENSOR_CTRLCMD_READ_SENSOR_REG, ¶m); //printf("read reg slave=0x%x,reg=0x%x,val=0x%x\n", param.nSlaveAddr,param.nRegAddr, param.nRegValue); if((param.nRegValue & 0x08) == 0) { not_lock[3] = 1; } param.nRegAddrWidth = 16; param.nI2cId = 3; param.nSlaveAddr = 0x28; param.nRegAddr = 0x13; ret = appWriteReadRegImageSensor(gs_sensor_name, 0x1, IMAGE_SENSOR_CTRLCMD_READ_SENSOR_REG, ¶m); //printf("read reg slave=0x%x,reg=0x%x,val=0x%x\n", param.nSlaveAddr,param.nRegAddr, param.nRegValue); if((param.nRegValue & 0x08) == 0) { not_lock[4] = 1; } } int32_t Camera_inst::capture_sync(std::vector<CameraData> *output) { uint32_t num_refs; uint32_t i = 0; uint32_t frame_size = 0; vx_size out_size = 0; int32_t ret = 0; char sensor_name[128] = SENSOR_OV1F_HIK_MAX96717F; // RemoteI2cParams param; output->clear(); vx_object_array out_capture_frames = NULL; vx_object_array out_raw_capture_frames = NULL; //memset(not_lock, 0, sizeof(not_lock) * 5); /* Get output reference, waits until a reference is available */ #if 0 /* Error frame params */ vx_event_t event; vxWaitEvent(context, &event, vx_true_e); /* Verifying that the capture node error event is not hit */ if (event.app_value == CAPTURE_NODE_ERROR) { printf("[%s] capture node error\n", __FUNCTION__, event.app_value); } #endif // #if YUV_DATA // vxGraphParameterDequeueDoneRef(graph, 0, (vx_reference*)&out_capture_frames, 1, &num_refs); // for (i = 0; i < 1; i++) { // frame_size = _config[i].height * _config[i].width; // CameraData data; // uint8_t *yuv_ptr = (uint8_t*)malloc(IMAGE_WIDTH * IMAGE_HEIGHT * 2); // if (copy_image(out_capture_frames, i, yuv_ptr) == 0) { // data.chan_id = i; // data.img_ptr = yuv_ptr; // data.framesize = frame_size * 2; // data.camera_name = _config[i].name; // data.frame_cnt = 0;//TODO // data.height = _config[i].height; // data.width = _config[i].width; // data.format = _config[i].format; // clock_gettime(CLOCK_REALTIME, &(data.capture_ts)); // memcpy(&(data.trigger_ts), &(data.capture_ts), sizeof(data.capture_ts)); // output->push_back(data); // } else { // free(yuv_ptr); // } // } // vxGraphParameterEnqueueReadyRef(graph, 0, (vx_reference*)&out_capture_frames, 1); // #endif // check_camera_reg(); #if RAW_DATA // vxGraphParameterDequeueDoneRef(raw_graph, 0, (vx_reference*)&out_raw_capture_frames, 1, &num_refs); // for (i = 1; i < 4; i++) { // frame_size = _config[i].height * _config[i].width; // CameraData data; // uint8_t *yuv_ptr = (uint8_t*)malloc(IMAGE_WIDTH * IMAGE_HEIGHT * 2); // if (copy_raw_image(out_capture_frames, i, yuv_ptr) == 0) { // data.chan_id = i; // data.img_ptr = yuv_ptr; // data.framesize = frame_size *2; // data.camera_name = _config[i].name; // data.frame_cnt = 0;//TODO // data.height = _config[i].height; // data.width = _config[i].width; // data.format = _config[i].format; // clock_gettime(CLOCK_REALTIME, &(data.capture_ts)); // memcpy(&(data.trigger_ts), &(data.capture_ts), sizeof(data.capture_ts)); // output->push_back(data); // } else { // free(yuv_ptr); // } // } // vxGraphParameterEnqueueReadyRef(raw_graph, 0, (vx_reference*)&out_raw_capture_frames, 1); #endif return 0; } void Camera_inst::release(uint32_t chan_id, uint8_t* img_ptr) { if (img_ptr != nullptr) { free(img_ptr); } //TODO return; } } } }
