Part Number: PROCESSOR-SDK-OMAPL138
Other Parts Discussed in Thread: OMAPL138
I'm working on OMAPL138 custom board in that now I'm working in UPP protocol last couple of days i was facing some issue in Upp driver. My Upp communication is like it is interfacing with FPGA
Main requirement is transmitting the data Double data rate 60MHZ with 480megabit per second.
Single - Data Rate it's working up-to (60Mhz /2 )30MHZ for achieving DDR UPP clock frequency in that I'm not losing the data i have cross verified multiple times with different different data . Further we had increase the UPP clock frequency to (120Mhz /2) to achieve the requirement In that data corruption is happening in between of every frame not able to receive proper data also I'll attach the log of 120Mhz SDR 2048 bytes in a single frame.
Please find the below attached log for Single data rate.
/*******************************SDR 120MHZ with 2048 Bytes of every DMA burst****************************/ // Start with one zero only but first two array of data i'm receiving two zero of data. // Data swap is happening. 0. RX[1] = 0x00 0. RX[3] = 0x00 0. RX[5] = 0x01 0. RX[7] = 0x02 0. RX[9] = 0x03 0. RX[11] = 0x04 0. RX[13] = 0x05 0. RX[15] = 0x06 0. RX[17] = 0x0f 0. RX[19] = 0x08 0. RX[21] = 0x09 0. RX[23] = 0x0a 0. RX[25] = 0x0b 0. RX[27] = 0x0c 0. RX[29] = 0x0d 0. RX[31] = 0x0e 0. RX[33] = 0x1f //Error 0. RX[35] = 0x10 0. RX[37] = 0x11 0. RX[39] = 0x12 0. RX[41] = 0x13 0. RX[43] = 0x14 0. RX[45] = 0x15 0. RX[47] = 0x16 0. RX[49] = 0x1f //Error 0. RX[51] = 0x18 0. RX[53] = 0x19 0. RX[55] = 0x1a 0. RX[57] = 0x1b 0. RX[59] = 0x1c 0. RX[61] = 0x1d 0. RX[63] = 0x1e 0. RX[65] = 0x1f 0. RX[67] = 0x20 0. RX[69] = 0x21 0. RX[71] = 0x22 0. RX[73] = 0x23 0. RX[75] = 0x24 0. RX[77] = 0x25 0. RX[79] = 0x26 0. RX[81] = 0x2f //Error 0. RX[83] = 0x28 0. RX[85] = 0x29 0. RX[87] = 0x2a 0. RX[89] = 0x2b 0. RX[91] = 0x2c 0. RX[93] = 0x2d 0. RX[95] = 0x2e 0. RX[97] = 0x3f //Error 0. RX[99] = 0x30 0. RX[101] = 0x31 0. RX[103] = 0x32 0. RX[105] = 0x33 0. RX[107] = 0x34 0. RX[109] = 0x35 0. RX[111] = 0x36 0. RX[113] = 0x3f 0. RX[115] = 0x38 0. RX[117] = 0x39 0. RX[119] = 0x3a 0. RX[121] = 0x3b 0. RX[123] = 0x3c 0. RX[125] = 0x3d 0. RX[127] = 0x3e 0. RX[129] = 0x3f 0. RX[131] = 0x40 0. RX[133] = 0x41 0. RX[135] = 0x42 0. RX[137] = 0x43 0. RX[139] = 0x44 0. RX[141] = 0x45 0. RX[143] = 0x46 0. RX[145] = 0x4f 0. RX[147] = 0x48 0. RX[149] = 0x49 0. RX[151] = 0x4a 0. RX[153] = 0x4b 0. RX[155] = 0x4c 0. RX[157] = 0x4d 0. RX[159] = 0x4e 0. RX[161] = 0x5f 0. RX[163] = 0x50 0. RX[165] = 0x51 0. RX[167] = 0x52 0. RX[169] = 0x53 0. RX[171] = 0x54 0. RX[173] = 0x55 0. RX[175] = 0x56 0. RX[177] = 0x5f 0. RX[179] = 0x58 0. RX[181] = 0x59 0. RX[183] = 0x5a 0. RX[185] = 0x5b 0. RX[187] = 0x5c 0. RX[189] = 0x5d 0. RX[191] = 0x5e 0. RX[193] = 0x5f 0. RX[195] = 0x60 0. RX[197] = 0x61 0. RX[199] = 0x62 0. RX[201] = 0x63 0. RX[203] = 0x64 0. RX[205] = 0x65 0. RX[207] = 0x66 0. RX[209] = 0x6f 0. RX[211] = 0x68 0. RX[213] = 0x69 0. RX[215] = 0x6a 0. RX[217] = 0x6b 0. RX[219] = 0x6c 0. RX[221] = 0x6d 0. RX[223] = 0x6e 0. RX[225] = 0x7f 0. RX[227] = 0x70 0. RX[229] = 0x71 0. RX[231] = 0x72 0. RX[233] = 0x73 0. RX[235] = 0x74 0. RX[237] = 0x75 0. RX[239] = 0x76 0. RX[241] = 0x7f 0. RX[243] = 0x78 0. RX[245] = 0x79 0. RX[247] = 0x7a 0. RX[249] = 0x7b 0. RX[251] = 0x7c 0. RX[253] = 0x7d 0. RX[255] = 0x7e 0. RX[257] = 0xff 0. RX[259] = 0x80 0. RX[261] = 0x81 0. RX[263] = 0x82 0. RX[265] = 0x83 0. RX[267] = 0x84 0. RX[269] = 0x85 0. RX[271] = 0x86 0. RX[273] = 0x8f 0. RX[275] = 0x88 0. RX[277] = 0x89 0. RX[279] = 0x8a 0. RX[281] = 0x8b 0. RX[283] = 0x8c 0. RX[285] = 0x8d 0. RX[287] = 0x8e 0. RX[289] = 0x9f 0. RX[291] = 0x90 0. RX[293] = 0x91 0. RX[295] = 0x92 0. RX[297] = 0x93 0. RX[299] = 0x94 0. RX[301] = 0x95 0. RX[303] = 0x96 0. RX[305] = 0x9f 0. RX[307] = 0x98 0. RX[309] = 0x99 0. RX[311] = 0x9a 0. RX[313] = 0x9b 0. RX[315] = 0x9c 0. RX[317] = 0x9d 0. RX[319] = 0x9e 0. RX[321] = 0x9f 0. RX[323] = 0xa0 0. RX[325] = 0xa1 0. RX[327] = 0xa2 0. RX[329] = 0xa3 0. RX[331] = 0xa4 0. RX[333] = 0xa5 0. RX[335] = 0xa6 0. RX[337] = 0xaf 0. RX[339] = 0xa8 0. RX[341] = 0xa9 0. RX[343] = 0xaa 0. RX[345] = 0xab 0. RX[347] = 0xac 0. RX[349] = 0xad 0. RX[351] = 0xae 0. RX[353] = 0xbf 0. RX[355] = 0xb0 0. RX[357] = 0xb1 0. RX[359] = 0xb2 0. RX[361] = 0xb3 0. RX[363] = 0xb4 0. RX[365] = 0xb5 0. RX[367] = 0xb6 0. RX[369] = 0xbf 0. RX[371] = 0xb8 0. RX[373] = 0xb9 0. RX[375] = 0xba 0. RX[377] = 0xbb 0. RX[379] = 0xbc 0. RX[381] = 0xbd 0. RX[383] = 0xbe 0. RX[385] = 0xbf 0. RX[387] = 0xc0 0. RX[389] = 0xc1 0. RX[391] = 0xc2 0. RX[393] = 0xc3 0. RX[395] = 0xc4 0. RX[397] = 0xc5 0. RX[399] = 0xc6 0. RX[401] = 0xcf 0. RX[403] = 0xc8 0. RX[405] = 0xc9 0. RX[407] = 0xca 0. RX[409] = 0xcb 0. RX[411] = 0xcc 0. RX[413] = 0xcd 0. RX[415] = 0xce 0. RX[417] = 0xdf 0. RX[419] = 0xd0 0. RX[421] = 0xd1 0. RX[423] = 0xd2 0. RX[425] = 0xd3 0. RX[427] = 0xd4 0. RX[429] = 0xd5 0. RX[431] = 0xd6 0. RX[433] = 0xdf 0. RX[435] = 0xd8 0. RX[437] = 0xd9 0. RX[439] = 0xda 0. RX[441] = 0xdb 0. RX[443] = 0xdc 0. RX[445] = 0xdd 0. RX[447] = 0xde 0. RX[449] = 0xdf 0. RX[451] = 0xe0 0. RX[453] = 0xe1 0. RX[455] = 0xe2 0. RX[457] = 0xe3 0. RX[459] = 0xe4 0. RX[461] = 0xe5 0. RX[463] = 0xe6 0. RX[465] = 0xef 0. RX[467] = 0xe8 0. RX[469] = 0xe9 0. RX[471] = 0xea 0. RX[473] = 0xeb 0. RX[475] = 0xec 0. RX[477] = 0xed 0. RX[479] = 0xee 0. RX[481] = 0xff 0. RX[483] = 0xf0 0. RX[485] = 0xf1 0. RX[487] = 0xf2 0. RX[489] = 0xf3 0. RX[491] = 0xf4 0. RX[493] = 0xf5 0. RX[495] = 0xf6 0. RX[497] = 0xff 0. RX[499] = 0xf8 0. RX[501] = 0xf9 0. RX[503] = 0xfa 0. RX[505] = 0xfb 0. RX[507] = 0xfc 0. RX[509] = 0xfd 0. RX[511] = 0xfe 0. RX[513] = 0xff 0. RX[515] = 0x00 0. RX[517] = 0x01 0. RX[519] = 0x02 0. RX[521] = 0x03 0. RX[523] = 0x04 0. RX[525] = 0x05 0. RX[527] = 0x06 0. RX[529] = 0x0f 0. RX[531] = 0x08 0. RX[533] = 0x09 0. RX[535] = 0x0a 0. RX[537] = 0x0b 0. RX[539] = 0x0c 0. RX[541] = 0x0d 0. RX[543] = 0x0e 0. RX[545] = 0x1f 0. RX[547] = 0x10 0. RX[549] = 0x11 0. RX[551] = 0x12 0. RX[553] = 0x13 0. RX[555] = 0x14 0. RX[557] = 0x15 0. RX[559] = 0x16 0. RX[561] = 0x1f 0. RX[563] = 0x18 0. RX[565] = 0x19 0. RX[567] = 0x1a 0. RX[569] = 0x1b 0. RX[571] = 0x1c 0. RX[573] = 0x1d 0. RX[575] = 0x1e 0. RX[577] = 0x1f 0. RX[579] = 0x20 0. RX[581] = 0x21 0. RX[583] = 0x22 0. RX[585] = 0x23 0. RX[587] = 0x24 0. RX[589] = 0x25 0. RX[591] = 0x26 0. RX[593] = 0x2f 0. RX[595] = 0x28 0. RX[597] = 0x29 0. RX[599] = 0x2a 0. RX[601] = 0x2b 0. RX[603] = 0x2c 0. RX[605] = 0x2d 0. RX[607] = 0x2e 0. RX[609] = 0x3f 0. RX[611] = 0x30 0. RX[613] = 0x31 0. RX[615] = 0x32 0. RX[617] = 0x33 0. RX[619] = 0x34 0. RX[621] = 0x35 0. RX[623] = 0x36 0. RX[625] = 0x3f 0. RX[627] = 0x38 0. RX[629] = 0x39 0. RX[631] = 0x3a 0. RX[633] = 0x3b 0. RX[635] = 0x3c 0. RX[637] = 0x3d 0. RX[639] = 0x3e 0. RX[641] = 0x3f 0. RX[643] = 0x40 0. RX[645] = 0x41 0. RX[647] = 0x42 0. RX[649] = 0x43 0. RX[651] = 0x44 0. RX[653] = 0x45 0. RX[655] = 0x46 0. RX[657] = 0x4f 0. RX[659] = 0x48 0. RX[661] = 0x49 0. RX[663] = 0x4a 0. RX[665] = 0x4b 0. RX[667] = 0x4c 0. RX[669] = 0x4d 0. RX[671] = 0x4e 0. RX[673] = 0x5f 0. RX[675] = 0x50 0. RX[677] = 0x51 0. RX[679] = 0x52 0. RX[681] = 0x53 0. RX[683] = 0x54 0. RX[685] = 0x55 0. RX[687] = 0x56 0. RX[689] = 0x5f 0. RX[691] = 0x58 0. RX[693] = 0x59 0. RX[695] = 0x5a 0. RX[697] = 0x5b 0. RX[699] = 0x5c 0. RX[701] = 0x5d 0. RX[703] = 0x5e 0. RX[705] = 0x5f 0. RX[707] = 0x60 0. RX[709] = 0x61 0. RX[711] = 0x62 0. RX[713] = 0x63 0. RX[715] = 0x64 0. RX[717] = 0x65 0. RX[719] = 0x66 0. RX[721] = 0x6f 0. RX[723] = 0x68 0. RX[725] = 0x69 0. RX[727] = 0x6a 0. RX[729] = 0x6b 0. RX[731] = 0x6c 0. RX[733] = 0x6d 0. RX[735] = 0x6e 0. RX[737] = 0x7f 0. RX[739] = 0x70 0. RX[741] = 0x71 0. RX[743] = 0x72 0. RX[745] = 0x73 0. RX[747] = 0x74 0. RX[749] = 0x75 0. RX[751] = 0x76 0. RX[753] = 0x7f 0. RX[755] = 0x78 0. RX[757] = 0x79 0. RX[759] = 0x7a 0. RX[761] = 0x7b 0. RX[763] = 0x7c 0. RX[765] = 0x7d 0. RX[767] = 0x7e 0. RX[769] = 0xff 0. RX[771] = 0x80 0. RX[773] = 0x81 0. RX[775] = 0x82 0. RX[777] = 0x83 0. RX[779] = 0x84 0. RX[781] = 0x85 0. RX[783] = 0x86 0. RX[785] = 0x8f 0. RX[787] = 0x88 0. RX[789] = 0x89 0. RX[791] = 0x8a 0. RX[793] = 0x8b 0. RX[795] = 0x8c 0. RX[797] = 0x8d 0. RX[799] = 0x8e 0. RX[801] = 0x9f 0. RX[803] = 0x90 0. RX[805] = 0x91 0. RX[807] = 0x92 0. RX[809] = 0x93 0. RX[811] = 0x94 0. RX[813] = 0x95 0. RX[815] = 0x96 0. RX[817] = 0x9f 0. RX[819] = 0x98 0. RX[821] = 0x99 0. RX[823] = 0x9a 0. RX[825] = 0x9b 0. RX[827] = 0x9c 0. RX[829] = 0x9d 0. RX[831] = 0x9e 0. RX[833] = 0x9f 0. RX[835] = 0xa0 0. RX[837] = 0xa1 0. RX[839] = 0xa2 0. RX[841] = 0xa3 0. RX[843] = 0xa4 0. RX[845] = 0xa5 0. RX[847] = 0xa6 0. RX[849] = 0xaf 0. RX[851] = 0xa8 0. RX[853] = 0xa9 0. RX[855] = 0xaa 0. RX[857] = 0xab 0. RX[859] = 0xac 0. RX[861] = 0xad 0. RX[863] = 0xae 0. RX[865] = 0xbf 0. RX[867] = 0xb0 0. RX[869] = 0xb1 0. RX[871] = 0xb2 0. RX[873] = 0xb3 0. RX[875] = 0xb4 0. RX[877] = 0xb5 0. RX[879] = 0xb6 0. RX[881] = 0xbf 0. RX[883] = 0xb8 0. RX[885] = 0xb9 0. RX[887] = 0xba 0. RX[889] = 0xbb 0. RX[891] = 0xbc 0. RX[893] = 0xbd 0. RX[895] = 0xbe 0. RX[897] = 0xbf 0. RX[899] = 0xc0 0. RX[901] = 0xc1 0. RX[903] = 0xc2 0. RX[905] = 0xc3 0. RX[907] = 0xc4 0. RX[909] = 0xc5 0. RX[911] = 0xc6 0. RX[913] = 0xcf 0. RX[915] = 0xc8 0. RX[917] = 0xc9 0. RX[919] = 0xca 0. RX[921] = 0xcb 0. RX[923] = 0xcc 0. RX[925] = 0xcd 0. RX[927] = 0xce 0. RX[929] = 0xdf 0. RX[931] = 0xd0 0. RX[933] = 0xd1 0. RX[935] = 0xd2 0. RX[937] = 0xd3 0. RX[939] = 0xd4 0. RX[941] = 0xd5 0. RX[943] = 0xd6 0. RX[945] = 0xdf 0. RX[947] = 0xd8 0. RX[949] = 0xd9 0. RX[951] = 0xda 0. RX[953] = 0xdb 0. RX[955] = 0xdc 0. RX[957] = 0xdd 0. RX[959] = 0xde 0. RX[961] = 0xdf 0. RX[963] = 0xe0 0. RX[965] = 0xe1 0. RX[967] = 0xe2 0. RX[969] = 0xe3 0. RX[971] = 0xe4 0. RX[973] = 0xe5 0. RX[975] = 0xe6 0. RX[977] = 0xef 0. RX[979] = 0xe8 0. RX[981] = 0xe9 0. RX[983] = 0xea 0. RX[985] = 0xeb 0. RX[987] = 0xec 0. RX[989] = 0xed 0. RX[991] = 0xee 0. RX[993] = 0xff 0. RX[995] = 0xf0 0. RX[997] = 0xf1 0. RX[999] = 0xf2 0. RX[1001] = 0xf3 0. RX[1003] = 0xf4 0. RX[1005] = 0xf5 0. RX[1007] = 0xf6 0. RX[1009] = 0xff 0. RX[1011] = 0xf8 0. RX[1013] = 0xf9 0. RX[1015] = 0xfa 0. RX[1017] = 0xfb 0. RX[1019] = 0xfc 0. RX[1021] = 0xfd 0. RX[1023] = 0xfe 0. RX[1025] = 0xff 0. RX[1027] = 0x00 0. RX[1029] = 0x01 0. RX[1031] = 0x02 0. RX[1033] = 0x03 0. RX[1035] = 0x04 0. RX[1037] = 0x05 0. RX[1039] = 0x06 0. RX[1041] = 0x0f 0. RX[1043] = 0x08 0. RX[1045] = 0x09 0. RX[1047] = 0x0a 0. RX[1049] = 0x0b 0. RX[1051] = 0x0c 0. RX[1053] = 0x0d 0. RX[1055] = 0x0e 0. RX[1057] = 0x1f 0. RX[1059] = 0x10 0. RX[1061] = 0x11 0. RX[1063] = 0x12 0. RX[1065] = 0x13 0. RX[1067] = 0x14 0. RX[1069] = 0x15 0. RX[1071] = 0x16 0. RX[1073] = 0x1f 0. RX[1075] = 0x18 0. RX[1077] = 0x19 0. RX[1079] = 0x1a 0. RX[1081] = 0x1b 0. RX[1083] = 0x1c 0. RX[1085] = 0x1d 0. RX[1087] = 0x1e 0. RX[1089] = 0x1f 0. RX[1091] = 0x20 0. RX[1093] = 0x21 0. RX[1095] = 0x22 0. RX[1097] = 0x23 0. RX[1099] = 0x24 0. RX[1101] = 0x25 0. RX[1103] = 0x26 0. RX[1105] = 0x2f 0. RX[1107] = 0x28 0. RX[1109] = 0x29 0. RX[1111] = 0x2a 0. RX[1113] = 0x2b 0. RX[1115] = 0x2c 0. RX[1117] = 0x2d 0. RX[1119] = 0x2e 0. RX[1121] = 0x3f 0. RX[1123] = 0x30 0. RX[1125] = 0x31 0. RX[1127] = 0x32 0. RX[1129] = 0x33 0. RX[1131] = 0x34 0. RX[1133] = 0x35 0. RX[1135] = 0x36 0. RX[1137] = 0x3f 0. RX[1139] = 0x38 0. RX[1141] = 0x39 0. RX[1143] = 0x3a 0. RX[1145] = 0x3b 0. RX[1147] = 0x3c 0. RX[1149] = 0x3d 0. RX[1151] = 0x3e 0. RX[1153] = 0x3f 0. RX[1155] = 0x40 0. RX[1157] = 0x41 0. RX[1159] = 0x42 0. RX[1161] = 0x43 0. RX[1163] = 0x44 0. RX[1165] = 0x45 0. RX[1167] = 0x46 0. RX[1169] = 0x4f 0. RX[1171] = 0x48 0. RX[1173] = 0x49 0. RX[1175] = 0x4a 0. RX[1177] = 0x4b 0. RX[1179] = 0x4c 0. RX[1181] = 0x4d 0. RX[1183] = 0x4e 0. RX[1185] = 0x5f 0. RX[1187] = 0x50 0. RX[1189] = 0x51 0. RX[1191] = 0x52 0. RX[1193] = 0x53 0. RX[1195] = 0x54 0. RX[1197] = 0x55 0. RX[1199] = 0x56 0. RX[1201] = 0x5f 0. RX[1203] = 0x58 0. RX[1205] = 0x59 0. RX[1207] = 0x5a 0. RX[1209] = 0x5b 0. RX[1211] = 0x5c 0. RX[1213] = 0x5d 0. RX[1215] = 0x5e 0. RX[1217] = 0x5f 0. RX[1219] = 0x60 0. RX[1221] = 0x61 0. RX[1223] = 0x62 0. RX[1225] = 0x63 0. RX[1227] = 0x64 0. RX[1229] = 0x65 0. RX[1231] = 0x66 0. RX[1233] = 0x6f 0. RX[1235] = 0x68 0. RX[1237] = 0x69 0. RX[1239] = 0x6a 0. RX[1241] = 0x6b 0. RX[1243] = 0x6c 0. RX[1245] = 0x6d 0. RX[1247] = 0x6e 0. RX[1249] = 0x7f 0. RX[1251] = 0x70 0. RX[1253] = 0x71 0. RX[1255] = 0x72 0. RX[1257] = 0x73 0. RX[1259] = 0x74 0. RX[1261] = 0x75 0. RX[1263] = 0x76 0. RX[1265] = 0x7f 0. RX[1267] = 0x78 0. RX[1269] = 0x79 0. RX[1271] = 0x7a 0. RX[1273] = 0x7b 0. RX[1275] = 0x7c 0. RX[1277] = 0x7d 0. RX[1279] = 0x7e 0. RX[1281] = 0xff 0. RX[1283] = 0x80 0. RX[1285] = 0x81 0. RX[1287] = 0x82 0. RX[1289] = 0x83 0. RX[1291] = 0x84 0. RX[1293] = 0x85 0. RX[1295] = 0x86 0. RX[1297] = 0x8f 0. RX[1299] = 0x88 0. RX[1301] = 0x89 0. RX[1303] = 0x8a 0. RX[1305] = 0x8b 0. RX[1307] = 0x8c 0. RX[1309] = 0x8d 0. RX[1311] = 0x8e 0. RX[1313] = 0x9f 0. RX[1315] = 0x90 0. RX[1317] = 0x91 0. RX[1319] = 0x92 0. RX[1321] = 0x93 0. RX[1323] = 0x94 0. RX[1325] = 0x95 0. RX[1327] = 0x96 0. RX[1329] = 0x9f 0. RX[1331] = 0x98 0. RX[1333] = 0x99 0. RX[1335] = 0x9a 0. RX[1337] = 0x9b 0. RX[1339] = 0x9c 0. RX[1341] = 0x9d 0. RX[1343] = 0x9e 0. RX[1345] = 0x9f 0. RX[1347] = 0xa0 0. RX[1349] = 0xa1 0. RX[1351] = 0xa2 0. RX[1353] = 0xa3 0. RX[1355] = 0xa4 0. RX[1357] = 0xa5 0. RX[1359] = 0xa6 0. RX[1361] = 0xaf 0. RX[1363] = 0xa8 0. RX[1365] = 0xa9 0. RX[1367] = 0xaa 0. RX[1369] = 0xab 0. RX[1371] = 0xac 0. RX[1373] = 0xad 0. RX[1375] = 0xae 0. RX[1377] = 0xbf 0. RX[1379] = 0xb0 0. RX[1381] = 0xb1 0. RX[1383] = 0xb2 0. RX[1385] = 0xb3 0. RX[1387] = 0xb4 0. RX[1389] = 0xb5 0. RX[1391] = 0xb6 0. RX[1393] = 0xbf 0. RX[1395] = 0xb8 0. RX[1397] = 0xb9 0. RX[1399] = 0xba 0. RX[1401] = 0xbb 0. RX[1403] = 0xbc 0. RX[1405] = 0xbd 0. RX[1407] = 0xbe 0. RX[1409] = 0xbf 0. RX[1411] = 0xc0 0. RX[1413] = 0xc1 0. RX[1415] = 0xc2 0. RX[1417] = 0xc3 0. RX[1419] = 0xc4 0. RX[1421] = 0xc5 0. RX[1423] = 0xc6 0. RX[1425] = 0xcf 0. RX[1427] = 0xc8 0. RX[1429] = 0xc9 0. RX[1431] = 0xca 0. RX[1433] = 0xcb 0. RX[1435] = 0xcc 0. RX[1437] = 0xcd 0. RX[1439] = 0xce 0. RX[1441] = 0xdf 0. RX[1443] = 0xd0 0. RX[1445] = 0xd1 0. RX[1447] = 0xd2 0. RX[1449] = 0xd3 0. RX[1451] = 0xd4 0. RX[1453] = 0xd5 0. RX[1455] = 0xd6 0. RX[1457] = 0xdf 0. RX[1459] = 0xd8 0. RX[1461] = 0xd9 0. RX[1463] = 0xda 0. RX[1465] = 0xdb 0. RX[1467] = 0xdc 0. RX[1469] = 0xdd 0. RX[1471] = 0xde 0. RX[1473] = 0xdf 0. RX[1475] = 0xe0 0. RX[1477] = 0xe1 0. RX[1479] = 0xe2 0. RX[1481] = 0xe3 0. RX[1483] = 0xe4 0. RX[1485] = 0xe5 0. RX[1487] = 0xe6 0. RX[1489] = 0xef 0. RX[1491] = 0xe8 0. RX[1493] = 0xe9 0. RX[1495] = 0xea 0. RX[1497] = 0xeb 0. RX[1499] = 0xec 0. RX[1501] = 0xed 0. RX[1503] = 0xee 0. RX[1505] = 0xff 0. RX[1507] = 0xf0 0. RX[1509] = 0xf1 0. RX[1511] = 0xf2 0. RX[1513] = 0xf3 0. RX[1515] = 0xf4 0. RX[1517] = 0xf5 0. RX[1519] = 0xf6 0. RX[1521] = 0xff 0. RX[1523] = 0xf8 0. RX[1525] = 0xf9 0. RX[1527] = 0xfa 0. RX[1529] = 0xfb 0. RX[1531] = 0xfc 0. RX[1533] = 0xfd 0. RX[1535] = 0xfe 0. RX[1537] = 0xff 0. RX[1539] = 0x00 0. RX[1541] = 0x01 0. RX[1543] = 0x02 0. RX[1545] = 0x03 0. RX[1547] = 0x04 0. RX[1549] = 0x05 0. RX[1551] = 0x06 0. RX[1553] = 0x0f 0. RX[1555] = 0x08 0. RX[1557] = 0x09 0. RX[1559] = 0x0a 0. RX[1561] = 0x0b 0. RX[1563] = 0x0c 0. RX[1565] = 0x0d 0. RX[1567] = 0x0e 0. RX[1569] = 0x1f 0. RX[1571] = 0x10 0. RX[1573] = 0x11 0. RX[1575] = 0x12 0. RX[1577] = 0x13 0. RX[1579] = 0x14 0. RX[1581] = 0x15 0. RX[1583] = 0x16 0. RX[1585] = 0x1f 0. RX[1587] = 0x18 0. RX[1589] = 0x19 0. RX[1591] = 0x1a 0. RX[1593] = 0x1b 0. RX[1595] = 0x1c 0. RX[1597] = 0x1d 0. RX[1599] = 0x1e 0. RX[1601] = 0x1f 0. RX[1603] = 0x20 0. RX[1605] = 0x21 0. RX[1607] = 0x22 0. RX[1609] = 0x23 0. RX[1611] = 0x24 0. RX[1613] = 0x25 0. RX[1615] = 0x26 0. RX[1617] = 0x2f 0. RX[1619] = 0x28 0. RX[1621] = 0x29 0. RX[1623] = 0x2a 0. RX[1625] = 0x2b 0. RX[1627] = 0x2c 0. RX[1629] = 0x2d 0. RX[1631] = 0x2e 0. RX[1633] = 0x3f 0. RX[1635] = 0x30 0. RX[1637] = 0x31 0. RX[1639] = 0x32 0. RX[1641] = 0x33 0. RX[1643] = 0x34 0. RX[1645] = 0x35 0. RX[1647] = 0x36 0. RX[1649] = 0x3f 0. RX[1651] = 0x38 0. RX[1653] = 0x39 0. RX[1655] = 0x3a 0. RX[1657] = 0x3b 0. RX[1659] = 0x3c 0. RX[1661] = 0x3d 0. RX[1663] = 0x3e 0. RX[1665] = 0x3f 0. RX[1667] = 0x40 0. RX[1669] = 0x41 0. RX[1671] = 0x42 0. RX[1673] = 0x43 0. RX[1675] = 0x44 0. RX[1677] = 0x45 0. RX[1679] = 0x46 0. RX[1681] = 0x4f 0. RX[1683] = 0x48 0. RX[1685] = 0x49 0. RX[1687] = 0x4a 0. RX[1689] = 0x4b 0. RX[1691] = 0x4c 0. RX[1693] = 0x4d 0. RX[1695] = 0x4e 0. RX[1697] = 0x5f 0. RX[1699] = 0x50 0. RX[1701] = 0x51 0. RX[1703] = 0x52 0. RX[1705] = 0x53 0. RX[1707] = 0x54 0. RX[1709] = 0x55 0. RX[1711] = 0x56 0. RX[1713] = 0x5f 0. RX[1715] = 0x58 0. RX[1717] = 0x59 0. RX[1719] = 0x5a 0. RX[1721] = 0x5b 0. RX[1723] = 0x5c 0. RX[1725] = 0x5d 0. RX[1727] = 0x5e 0. RX[1729] = 0x5f 0. RX[1731] = 0x60 0. RX[1733] = 0x61 0. RX[1735] = 0x62 0. RX[1737] = 0x63 0. RX[1739] = 0x64 0. RX[1741] = 0x65 0. RX[1743] = 0x66 0. RX[1745] = 0x6f 0. RX[1747] = 0x68 0. RX[1749] = 0x69 0. RX[1751] = 0x6a 0. RX[1753] = 0x6b 0. RX[1755] = 0x6c 0. RX[1757] = 0x6d 0. RX[1759] = 0x6e 0. RX[1761] = 0x7f 0. RX[1763] = 0x70 0. RX[1765] = 0x71 0. RX[1767] = 0x72 0. RX[1769] = 0x73 0. RX[1771] = 0x74 0. RX[1773] = 0x75 0. RX[1775] = 0x76 0. RX[1777] = 0x7f 0. RX[1779] = 0x78 0. RX[1781] = 0x79 0. RX[1783] = 0x7a 0. RX[1785] = 0x7b 0. RX[1787] = 0x7c 0. RX[1789] = 0x7d 0. RX[1791] = 0x7e 0. RX[1793] = 0xff 0. RX[1795] = 0x80 0. RX[1797] = 0x81 0. RX[1799] = 0x82 0. RX[1801] = 0x83 0. RX[1803] = 0x84 0. RX[1805] = 0x85 0. RX[1807] = 0x86 0. RX[1809] = 0x8f 0. RX[1811] = 0x88 0. RX[1813] = 0x89 0. RX[1815] = 0x8a 0. RX[1817] = 0x8b 0. RX[1819] = 0x8c 0. RX[1821] = 0x8d 0. RX[1823] = 0x8e 0. RX[1825] = 0x9f 0. RX[1827] = 0x90 0. RX[1829] = 0x91 0. RX[1831] = 0x92 0. RX[1833] = 0x93 0. RX[1835] = 0x94 0. RX[1837] = 0x95 0. RX[1839] = 0x96 0. RX[1841] = 0x9f 0. RX[1843] = 0x98 0. RX[1845] = 0x99 0. RX[1847] = 0x9a 0. RX[1849] = 0x9b 0. RX[1851] = 0x9c 0. RX[1853] = 0x9d 0. RX[1855] = 0x9e 0. RX[1857] = 0x9f 0. RX[1859] = 0xa0 0. RX[1861] = 0xa1 0. RX[1863] = 0xa2 0. RX[1865] = 0xa3 0. RX[1867] = 0xa4 0. RX[1869] = 0xa5 0. RX[1871] = 0xa6 0. RX[1873] = 0xaf 0. RX[1875] = 0xa8 0. RX[1877] = 0xa9 0. RX[1879] = 0xaa 0. RX[1881] = 0xab 0. RX[1883] = 0xac 0. RX[1885] = 0xad 0. RX[1887] = 0xae 0. RX[1889] = 0xbf 0. RX[1891] = 0xb0 0. RX[1893] = 0xb1 0. RX[1895] = 0xb2 0. RX[1897] = 0xb3 0. RX[1899] = 0xb4 0. RX[1901] = 0xb5 0. RX[1903] = 0xb6 0. RX[1905] = 0xbf 0. RX[1907] = 0xb8 0. RX[1909] = 0xb9 0. RX[1911] = 0xba 0. RX[1913] = 0xbb 0. RX[1915] = 0xbc 0. RX[1917] = 0xbd 0. RX[1919] = 0xbe 0. RX[1921] = 0xbf 0. RX[1923] = 0xc0 0. RX[1925] = 0xc1 0. RX[1927] = 0xc2 0. RX[1929] = 0xc3 0. RX[1931] = 0xc4 0. RX[1933] = 0xc5 0. RX[1935] = 0xc6 0. RX[1937] = 0xcf 0. RX[1939] = 0xc8 0. RX[1941] = 0xc9 0. RX[1943] = 0xca 0. RX[1945] = 0xcb 0. RX[1947] = 0xcc 0. RX[1949] = 0xcd 0. RX[1951] = 0xce 0. RX[1953] = 0xdf 0. RX[1955] = 0xd0 0. RX[1957] = 0xd1 0. RX[1959] = 0xd2 0. RX[1961] = 0xd3 0. RX[1963] = 0xd4 0. RX[1965] = 0xd5 0. RX[1967] = 0xd6 0. RX[1969] = 0xdf 0. RX[1971] = 0xd8 0. RX[1973] = 0xd9 0. RX[1975] = 0xda 0. RX[1977] = 0xdb 0. RX[1979] = 0xdc 0. RX[1981] = 0xdd 0. RX[1983] = 0xde 0. RX[1985] = 0xdf 0. RX[1987] = 0xe0 0. RX[1989] = 0xe1 0. RX[1991] = 0xe2 0. RX[1993] = 0xe3 0. RX[1995] = 0xe4 0. RX[1997] = 0xe5 0. RX[1999] = 0xe6 0. RX[2001] = 0xef 0. RX[2003] = 0xe8 0. RX[2005] = 0xe9 0. RX[2007] = 0xea 0. RX[2009] = 0xeb 0. RX[2011] = 0xec 0. RX[2013] = 0xed 0. RX[2015] = 0xee 0. RX[2017] = 0xff //Error 0. RX[2019] = 0xf0 0. RX[2021] = 0xf1 0. RX[2023] = 0xf2 0. RX[2025] = 0xf3 0. RX[2027] = 0xf4 0. RX[2029] = 0xf5 0. RX[2031] = 0xf6 0. RX[2033] = 0xff //Error 0. RX[2035] = 0xf8 0. RX[2037] = 0xf9 0. RX[2039] = 0xfa 0. RX[2041] = 0xfb 0. RX[2043] = 0xfc 0. RX[2045] = 0xfd 0. RX[2047] = 0xfe upp_enable()...OK. line_count = 1
Double - Data Rate i can able to receive the all data but first byte of the data 0x00 it has swapping in some frame why it is happening in some frame idk i will attach the DDR log also please find the attachment in below.
[ARM9_0] upp_pin_mux_init()...OK. PSC_REVID = 0x44825A00....OK upp_power_and_clocks()...OK. UPP_UPPID = 0x44231100....OK upp_swrst()...OK. upp_config()...OK. upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x01 RX[127] = 0x00 // 0. RX[3] = 0x02 RX[125] = 0x3f 0. RX[5] = 0x03 RX[123] = 0x3e 0. RX[7] = 0x04 RX[121] = 0x3d 0. RX[9] = 0x05 RX[119] = 0x3c upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x00 RX[127] = 0x3f // 0. RX[3] = 0x01 RX[125] = 0x3e 0. RX[5] = 0x02 RX[123] = 0x3d 0. RX[7] = 0x03 RX[121] = 0x3c 0. RX[9] = 0x04 RX[119] = 0x3b upp_enable()...OK. line_count = 1 uppISR Entered = 800`x received End of Window Interrupt 0. RX[1] = 0x01 RX[127] = 0x00 0. RX[3] = 0x02 RX[125] = 0x3f 0. RX[5] = 0x03 RX[123] = 0x3e 0. RX[7] = 0x04 RX[121] = 0x3d 0. RX[9] = 0x05 RX[119] = 0x3c upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x00 RX[127] = 0x3f 0. RX[3] = 0x01 RX[125] = 0x3e 0. RX[5] = 0x02 RX[123] = 0x3d 0. RX[7] = 0x03 RX[121] = 0x3c 0. RX[9] = 0x04 RX[119] = 0x3b upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x00 RX[127] = 0x3f 0. RX[3] = 0x01 RX[125] = 0x3e 0. RX[5] = 0x02 RX[123] = 0x3d 0. RX[7] = 0x03 RX[121] = 0x3c 0. RX[9] = 0x04 RX[119] = 0x3b upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x00 RX[127] = 0x3f 0. RX[3] = 0x01 RX[125] = 0x3e 0. RX[5] = 0x02 RX[123] = 0x3d 0. RX[7] = 0x03 RX[121] = 0x3c 0. RX[9] = 0x04 RX[119] = 0x3b upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt 0. RX[1] = 0x01 RX[127] = 0x00 0. RX[3] = 0x02 RX[125] = 0x3f 0. RX[5] = 0x03 RX[123] = 0x3e 0. RX[7] = 0x04 RX[121] = 0x3d 0. RX[9] = 0x05 RX[119] = 0x3c upp_enable()...OK. line_count = 1 uppISR Entered = 800 received End of Window Interrupt
