AM3352: USB on peripheral without PMIC like beagelbone black, what I have to do with the VBUS IRQ
Part Number: AM3352
The RNDIS gadget is not working at v5.10.35 (mainline kernel.org)
Our Board without PMIC , is this wrong ?
interrupts-extended = <&intc 18 &intc 0>;
BBB with PMIC:
interrupts-extended = <&intc 18 &tps 0>;
dts parts
ocp {
debugss: debugss@4b000000 {
compatible = "ti,debugss";
ti,hwmods = "debugss";
reg = <0x4b000000 1000000>;
status = "disabled";
musb: usb@47400000 {
status = "okay";
control@44e10620 {
status = "okay";
usb-phy@47401300 {
status = "okay";
usb-phy@47401b00 {
status = "okay";
usb@47401000 {
status = "okay";
dr_mode = "periphal";
usb@47401800 {
status = "okay";
dma-controller@47402000 {
status = "okay";
&usb0_phy {
status = "okay";
&usb0 {
dr_mode = "peripheral";
status = "okay";
interrupt-names = "mc" ,"vbus";
&usb1 {
dr_mode = "host";
Log
root@pxc4:~# lsusb
root@pxc4:~# dmesg | grep usb
[    2.523154] device: '47401300.usb-phy': device_add
[    2.523190] bus: 'platform': add device 47401300.usb-phy
[    2.523744] device: '47401400.usb': device_add
[    2.523780] bus: 'platform': add device 47401400.usb
[    2.524010] device: 'platform:47401300.usb-phy--platform:47401400.usb': device_add
[    2.524114] platform 47401400.usb: Linked as a sync state only consumer to 47401300.usb-phy
[    2.524752] device: '47401b00.usb-phy': device_add
[    2.524789] bus: 'platform': add device 47401b00.usb-phy
[    2.526193] device: 'platform:47400000.dma-controller--platform:47401400.usb': device_add
[    2.526287] platform 47401400.usb: Linked as a sync state only consumer to 47400000.dma-controller
[    3.311250] bus: 'platform': add driver am335x-control-usb
[    3.311569] bus: 'platform': driver_probe_device: matched device 44e10620.control with driver am335x-control-usb
[    3.311594] bus: 'platform': really_probe: probing driver am335x-control-usb with device 44e10620.control
[    3.311631] am335x-control-usb 44e10620.control: no pinctrl handle
[    3.311723] driver: 'am335x-control-usb': driver_bound: bound to device '44e10620.control'
[    3.311808] bus: 'platform': really_probe: bound device 44e10620.control to driver am335x-control-usb
[    3.312210] bus: 'platform': driver_probe_device: matched device 47401300.usb-phy with driver am335x-phy-driver
[    3.312275] bus: 'platform': really_probe: probing driver am335x-phy-driver with device 47401300.usb-phy
[    3.312308] am335x-phy-driver 47401300.usb-phy: no pinctrl handle
[    3.313154] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[    3.322305] device: 'regulator:regulator.0--platform:47401300.usb-phy': device_add
[    3.322455] devices_kset: Moving 47401300.usb-phy to end of list
[    3.322474] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
[    3.322503] driver: 'am335x-phy-driver': driver_bound: bound to device '47401300.usb-phy'
[    3.322589] bus: 'platform': really_probe: bound device 47401300.usb-phy to driver am335x-phy-driver
[    3.322706] bus: 'platform': driver_probe_device: matched device 47401b00.usb-phy with driver am335x-phy-driver
[    3.322755] bus: 'platform': really_probe: probing driver am335x-phy-driver with device 47401b00.usb-phy
[    3.322788] am335x-phy-driver 47401b00.usb-phy: no pinctrl handle
[    3.323582] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[    3.332685] device: 'regulator:regulator.0--platform:47401b00.usb-phy': device_add
[    3.332821] devices_kset: Moving 47401b00.usb-phy to end of list
[    3.332839] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[    3.332862] driver: 'am335x-phy-driver': driver_bound: bound to device '47401b00.usb-phy'
[    3.332947] bus: 'platform': really_probe: bound device 47401b00.usb-phy to driver am335x-phy-driver
[    3.346040] bus: 'platform': add driver musb-hdrc
[    3.346165] bus: 'platform': add driver musb-dsps
[    3.346452] bus: 'platform': driver_probe_device: matched device 47401400.usb with driver musb-dsps
[    3.346522] bus: 'platform': really_probe: probing driver musb-dsps with device 47401400.usb
[    3.346561] musb-dsps 47401400.usb: no pinctrl handle
[    3.347099] Registering platform device 'musb-hdrc.0'. Parent at 47401400.usb
[    3.347119] device: 'musb-hdrc.0': device_add
[    3.347164] bus: 'platform': add device musb-hdrc.0
[    3.347525] bus: 'platform': driver_probe_device: matched device musb-hdrc.0 with driver musb-hdrc
[    3.347549] bus: 'platform': really_probe: probing driver musb-hdrc with device musb-hdrc.0
[    3.349002] device: 'musb-hdrc.0': device_add
[    3.349278] driver: 'musb-hdrc': driver_bound: bound to device 'musb-hdrc.0'
[    3.349363] bus: 'platform': really_probe: bound device musb-hdrc.0 to driver musb-hdrc
[    3.349425] driver: 'musb-dsps': driver_bound: bound to device '47401400.usb'
[    3.349447] musb-dsps 47401400.usb: Dropping the link to 47401300.usb-phy
[    3.349459] device: 'platform:47401300.usb-phy--platform:47401400.usb': device_unregister
[    3.349587] musb-dsps 47401400.usb: Dropping the link to 47400000.dma-controller
[    3.349600] device: 'platform:47400000.dma-controller--platform:47401400.usb': device_unregister
[    3.349723] bus: 'platform': really_probe: bound device 47401400.usb to driver musb-dsps
[    3.384211] bus: 'usb': add driver usbhid
[    3.384282] usbcore: registered new interface driver usbhid
[    3.390254] usbhid: USB HID core driver
  • doing it this way does not work too
    usb_pins_default: usb_pins_default{
    pinctrl-single,pins = <
    AM33XX_PADCONF(AM335X_PIN_USB0_DRVVBUS, PIN_INPUT, MUX_MODE0)
    &usb0_phy {
    pinctrl-names = "default";
    pinctrl-0 = <&usb_pins_default>;
    status = "okay";
    &usb0 {
    status = "okay";
    interrupt-names = "mc", "vbus";
    &usb1 {
    dr_mode = "host";
    pin 135 (PIN135): 47401300.usb-phy (GPIO UNCLAIMED) function usb_pins_default group usb_pins_default
    [ 2.541726] device: '47401300.usb-phy': device_add
    [ 2.541769] bus: 'platform': add device 47401300.usb-phy
    [ 2.542009] device: 'platform:44e10800.pinmux--platform:47401300.usb-phy': device_add
    [ 2.542129] platform 47401300.usb-phy: Linked as a sync state only consumer to 44e10800.pinmux
    [ 2.542530] device: '47401400.usb': device_add
    [ 2.542563] bus: 'platform': add device 47401400.usb
    [ 2.542798] device: 'platform:47401300.usb-phy--platform:47401400.usb': device_add
    [ 2.542901] platform 47401400.usb: Linked as a sync state only consumer to 47401300.usb-phy
    [ 2.543535] device: '47401b00.usb-phy': device_add
    [ 2.543570] bus: 'platform': add device 47401b00.usb-phy
    [ 2.544811] device: 'platform:47400000.dma-controller--platform:47401400.usb': device_add
    [ 2.544917] platform 47401400.usb: Linked as a sync state only consumer to 47400000.dma-controller
    [ 3.332068] bus: 'platform': add driver am335x-control-usb
    [ 3.332397] bus: 'platform': driver_probe_device: matched device 44e10620.control with driver am335x-control-usb
    [ 3.332421] bus: 'platform': really_probe: probing driver am335x-control-usb with device 44e10620.control
    [ 3.332459] am335x-control-usb 44e10620.control: no pinctrl handle
    [ 3.332559] driver: 'am335x-control-usb': driver_bound: bound to device '44e10620.control'
    [ 3.332645] bus: 'platform': really_probe: bound device 44e10620.control to driver am335x-control-usb
    [ 3.333040] bus: 'platform': driver_probe_device: matched device 47401300.usb-phy with driver am335x-phy-driver
    [ 3.333108] bus: 'platform': really_probe: probing driver am335x-phy-driver with device 47401300.usb-phy
    [ 3.333230] am335x-phy-driver 47401300.usb-phy: no init pinctrl state
    [ 3.333257] am335x-phy-driver 47401300.usb-phy: no sleep pinctrl state
    [ 3.333268] am335x-phy-driver 47401300.usb-phy: no idle pinctrl state
    [ 3.334127] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
    [ 3.343199] device: 'regulator:regulator.0--platform:47401300.usb-phy': device_add
    [ 3.343342] devices_kset: Moving 47401300.usb-phy to end of list
    [ 3.343361] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
    [ 3.343388] driver: 'am335x-phy-driver': driver_bound: bound to device '47401300.usb-phy'
    [ 3.343410] am335x-phy-driver 47401300.usb-phy: Dropping the link to 44e10800.pinmux
    [ 3.343421] device: 'platform:44e10800.pinmux--platform:47401300.usb-phy': device_unregister
    [ 3.343601] bus: 'platform': really_probe: bound device 47401300.usb-phy to driver am335x-phy-driver
    [ 3.343742] bus: 'platform': driver_probe_device: matched device 47401b00.usb-phy with driver am335x-phy-driver
    [ 3.343797] bus: 'platform': really_probe: probing driver am335x-phy-driver with device 47401b00.usb-phy
    [ 3.343830] am335x-phy-driver 47401b00.usb-phy: no pinctrl handle
    [ 3.344632] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
    [ 3.353755] device: 'regulator:regulator.0--platform:47401b00.usb-phy': device_add
    [ 3.353895] devices_kset: Moving 47401b00.usb-phy to end of list
    [ 3.353914] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
    [ 3.353938] driver: 'am335x-phy-driver': driver_bound: bound to device '47401b00.usb-phy'
    [ 3.354022] bus: 'platform': really_probe: bound device 47401b00.usb-phy to driver am335x-phy-driver
    [ 3.367050] bus: 'platform': add driver musb-hdrc
    [ 3.367180] bus: 'platform': add driver musb-dsps
    [ 3.367466] bus: 'platform': driver_probe_device: matched device 47401400.usb with driver musb-dsps
    [ 3.367533] bus: 'platform': really_probe: probing driver musb-dsps with device 47401400.usb
    [ 3.367572] musb-dsps 47401400.usb: no pinctrl handle
    [ 3.368105] Registering platform device 'musb-hdrc.0'. Parent at 47401400.usb
    [ 3.368126] device: 'musb-hdrc.0': device_add
    [ 3.368172] bus: 'platform': add device musb-hdrc.0
    [ 3.368529] bus: 'platform': driver_probe_device: matched device musb-hdrc.0 with driver musb-hdrc
    [ 3.368551] bus: 'platform': really_probe: probing driver musb-hdrc with device musb-hdrc.0
    [ 3.370009] device: 'musb-hdrc.0': device_add
    [ 3.370290] driver: 'musb-hdrc': driver_bound: bound to device 'musb-hdrc.0'
    [ 3.370374] bus: 'platform': really_probe: bound device musb-hdrc.0 to driver musb-hdrc
    [ 3.370441] driver: 'musb-dsps': driver_bound: bound to device '47401400.usb'
    [ 3.370463] musb-dsps 47401400.usb: Dropping the link to 47401300.usb-phy
    [ 3.370475] device: 'platform:47401300.usb-phy--platform:47401400.usb': device_unregister
    [ 3.370601] musb-dsps 47401400.usb: Dropping the link to 47400000.dma-controller
    [ 3.370615] device: 'platform:47400000.dma-controller--platform:47401400.usb': device_unregister
    [ 3.370738] bus: 'platform': really_probe: bound device 47401400.usb to driver musb-dsps
    [ 3.405355] bus: 'usb': add driver usbhid
    [ 3.405422] usbcore: registered new interface driver usbhid
    [ 3.411278] usbhid: USB HID core driver
  • &usb0_phy {
    pinctrl-1 = <&usb_pins_init>;
    pinctrl-2 = <&usb_pins_sleep>;
    pinctrl-3 = <&usb_pins_idle>;
    status = "okay";
    &usb0 {
    status = "okay";
    at power up at host the gadget is avaliable
    Bus 001 Device 020: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
    but after plug event it is lost .. interrupt type / level to add ?
  • USB0_VBUS is an analog pin with mux mode 0 only.
    T19 could not be muxed as GPIO with IRQ !
    so what should be added for vbus irq in interruts-extended = <&intc 18 ? ?>
    Kernel 4.4 dts didnt has this new "interrupts-extended" gimmick and gadget worked !
  • Hi Boris,
    The VBUS IRQ (as that on BBB) is optional. If you check the AM335x GP EVM schematics and its board dts, there is no VBUS IRQ defined.
  • I talk not about kernel 4.4.y  without interrupt-extended
    I talk about kernel 5.10.y (mainline from kernel.org) with "new" interrupt-extended
    Without interrupt-extended for interupt-names "vbus" driver does not work at power up (warning vbus missing)
    Without interrupt-extended for interupt-names "mbus" driver does not start (error)
    Without interrupt-extended and  interupt-names usb driver does not start (error)
    This way RNDIS Gadget works a power up.. but plug event does not work... after unplug you will never see RNDIS again at USB host (Bus 001 Device 020: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget)
    &usb0_phy {
    status = "okay";
    &usb0 {
    status = "okay";
    interrupts-extended = <&intc 18 &intc 7>;
    If you look at https://elixir.bootlin.com/linux/v5.10.35/source/arch/arm/boot/dts/am33xx.dtsi#L368
    mc IRQ is 18 but what IRQ does vbus requires to wake up at plug event.
    vbus is analog pin and has Bit 7 in Table 16-116. USB1IRQSTAT1 Register Field Descriptions
    how is the VBUS (analog pin) plug event working correctly with interrupt-extended. We have 5V at VBUS if cable is connected and 0 V if not. Was working with 4.4 now 5.10 we have no plug detection
    How "vbus" &intc ? is mapped to Bit 7 in Table 16-116. USB1IRQSTAT1 Register Field Descriptions ?
    We do not have a PMIC with interrupt-extended = <&intc 18 &tps 0> for "vbus"
  • Where does the DT screenshot come from? The Beaglebone board DTS or your board? Like I said, the interrupts-extended for VBUS is optional, it is only used in mainline kernel Beaglebone but not other AM335x boards.
    Line #844-846 in musb_dsps.c driver checks if VBUS interrupt is defined. The driver does nothing if it is not defined. Also the function name is called dsps_setup_optional_vbus_irq() which suggests the vbus interrupt is opitonal.
    https://elixir.bootlin.com/linux/v5.10.35/source/drivers/usb/musb/musb_dsps.c#L844
    Line 368 in am33xx.dtsi defines the usb register locations, it doesn't talk about interrupts-extended. What do you want to tell with Line 368 here?
    dts is from our AM3352 module
    do you have a link for 5.10 dts where VBUS is not used at &usb0 with dr_mode ="peripheral" ?
    I used this as example
    elixir.bootlin.com/.../am335x-osd3358-sm-red.dts
    Yes - In theory if not defined not Gadget on my real hardware. May you can remove the option on BBB and check if still plug event is working.
    2 lines below 368 I can see mc and 18 .. both part of interrupts-extends section in dts .. see example
  • BBB not working RNDIS with default device tree and defconfig, is there a kernel module missing i have to load ?
    I use the sato image with modules.dep
    root@beaglebone-yocto:/lib/modules/5.10.63-yocto-standard/kernel/drivers/net/usb# lsmod
    Module Size Used by
    cdc_eem 16384 0
    cdc_subset 16384 0
    cdc_ncm 28672 0
    usb_f_ncm 20480 0
    libcomposite 57344 1 usb_f_ncm
    configfs 36864 3 usb_f_ncm,libcomposite
    rndis_host 16384 0
    cdc_ether 16384 2 rndis_host,cdc_ncm
    usbnet 36864 5 rndis_host,cdc_eem,cdc_ether,cdc_ncm,cdc_subset
    u_ether 24576 1 usb_f_ncm
    snd_soc_simple_card 20480 0
    snd_soc_simple_card_utils 20480 1 snd_soc_simple_card
    snd_soc_davinci_mcasp 28672 2
    snd_soc_ti_udma 16384 1 snd_soc_davinci_mcasp
    snd_soc_ti_edma 16384 1 snd_soc_davinci_mcasp
    snd_soc_ti_sdma 16384 1 snd_soc_davinci_mcasp
    snd_soc_hdmi_codec 16384 1
    snd_soc_core 200704 7 snd_soc_davinci_mcasp,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_ti_sdma,snd_soc_ti_edma,snd_soc_ti_udma,snd_soc_simple_card
    snd_pcm_dmaengine 16384 1 snd_soc_core
    snd_pcm 102400 4 snd_soc_davinci_mcasp,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_core
    snd_timer 32768 1 snd_pcm
    snd 65536 4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
    soundcore 16384 1 snd
    root@beaglebone-yocto:/lib/modules/5.10.63-yocto-standard/kernel/drivers/net/usb# uname -a
    Linux beaglebone-yocto 5.10.63-yocto-standard #1 PREEMPT Thu Sep 9 02:58:22 UTC 2021 armv7l GNU/Linux
  • How do you enable the ethernet (RNDIS) gadget on BBB?
    I do see u_ether module in 'lsmod', but I expect to see 'g_ether' module as well if the ethernet gadget driver is loaded from command 'modprobe g_ether'.
  • At 5.10 there is no g_ether.ko and there is no CONFIG for g_ether. only CONFIG_USB_U_ETHER.
    Is there a module missing in default omap2plus_defconfig ?
  • Correct, omap2plus_defconfig has many modules (not limited to USB) not enabled.
    To enable USB gadget drivers, including g_ether, you can do it in kernel make menuconfig:
    make menuconfig
    Device Drivers --->
        USB support --->
            USB Gadget Support --->
                USB Gadget precomposed configurations  --->
  • yocto-linux is on 5.10.63
    we are on 5.10.35
    there are to more patches on musb_core.c at 5.10.63 and that will  resolve the plug unplug event
    see last 2 commits are missing at 5.1035
    https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/log/drivers/usb/musb/musb_core.c?h=v5.10.102
    we upgrade our kernel to 5.10.latest as fix
    yes  an option in dts and can be removed  .. the vbus warning is normal
     &usb0 {
    -       interrupts-extended = <&intc 18 &tps 0>;
    -       interrupt-names = "mc", "vbus";
  • yes  an option in dts and can be removed  .. the vbus warning is normal
     &usb0 {
    Yes, this interrupts-extended shouldn't be defined for your board, which doesn't have a PMIC. This VBUS interrupt doesn't exist on your board.
