PROCESSOR-SDK-AM437X: USB disconnects randomly and cannot connect again
Part Number: PROCESSOR-SDK-AM437X
Other Parts Discussed in Thread: AM4378, AM3354
One of the USB ports disconnects randomly and cannot start again in our embedded Linux system. Our system consists of one host with AM4378 and two devices with AM3354 connected to USB port of AM4378 host.
The host device uses kernel version of 4.19.59.
Solutions:
  1. Reset the enable gpio of the USB phy device.
  2. Remove "xhci-hcd" driver and probe again.
  3. Disconnect USB cable and connect again.
  4. Reboot / Power-off-on
Here is the logs of the host.
root@evc03:~# dmesg
[    1.809672] rtc-max31343 2-0068: DT Sel: 0 Reg Value: 0x10
[    1.809922] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz
[    1.810577] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
[    1.810716] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    1.810834] DSS: OMAP DSS rev 2.0
[    1.812018] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
[    1.812579] omapdrm omapdrm.0: DMM not available, disable DMM support
[    1.812919] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.812951] [drm] No driver support for vblank timestamp query.
[    1.876253] Console: switching to colour frame buffer device 128x48
[    1.913127] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    1.914121] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    1.914634] cpu cpu0: Linked as a consumer to regulator.2
[    1.914712] cpu cpu0: Dropping the link to regulator.2
[    1.914884] cpu cpu0: Linked as a consumer to regulator.2
[    1.916182] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[    1.916193] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.916234] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/mmc@48060000[0]' - status (0)
[    1.916254] gpio gpiochip0: Persistence not supported for GPIO 6
[    1.916269] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.916304] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.916325] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[    1.916331] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.916348] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@48060000[0]'
[    1.916363] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@48060000[0]'
[    1.916372] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[    1.916379] omap_hsmmc 48060000.mmc: No GPIO consumer wp found
[    1.916812] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.4
[    1.944665] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd
[    1.944686] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[    1.944736] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.944775] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.944797] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
[    1.944816] omap_hsmmc 481d8000.mmc: No GPIO consumer cd found
[    1.944840] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp
[    1.944854] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[    1.944888] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.944921] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.944938] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
[    1.944954] omap_hsmmc 481d8000.mmc: No GPIO consumer wp found
[    1.945625] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.4
[    1.973377] rtc-max31343 2-0068: setting system clock to 2022-07-23 09:21:45 UTC (1658568105)
[    1.974966] ALSA device list:
[    1.975014]   No soundcards found.
[    1.979935] Freeing unused kernel memory: 2048K
[    1.980425] Run /init as init process
[    2.025108] mmc1: new high speed MMC card at address 0001
[    2.031841] mmcblk1: mmc1:0001 4FTE4R 3.64 GiB
[    2.032638] mmcblk1boot0: mmc1:0001 4FTE4R partition 1 4.00 MiB
[    2.033698] mmcblk1boot1: mmc1:0001 4FTE4R partition 2 4.00 MiB
[    2.033992] mmcblk1rpmb: mmc1:0001 4FTE4R partition 3 512 KiB, chardev (244:0)
[    2.041820]  mmcblk1: p1 p2 p3
[    2.768221] EXT4-fs (mmcblk1p2): 5 orphan inodes deleted
[    2.768265] EXT4-fs (mmcblk1p2): recovery complete
[    2.775200] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.132035] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    3.132730] systemd[1]: Detected architecture arm.
[    3.150842] systemd[1]: Set hostname to <evc03>.
[    3.610646] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    3.610726] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    3.770285] systemd[1]: Configuration file /etc/systemd/system/uistatemachine.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.770367] systemd[1]: Configuration file /etc/systemd/system/uistatemachine.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    3.794017] systemd[1]: Configuration file /etc/systemd/system/serialconsole.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.794096] systemd[1]: Configuration file /etc/systemd/system/serialconsole.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    3.797077] systemd[1]: Configuration file /etc/systemd/system/sensormodule.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    4.193493] cryptodev: loading out-of-tree module taints kernel.
[    4.207191] cryptodev: driver 1.9 loaded.
[    4.314066] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    6.052214] systemd-journald[123]: Received request to flush runtime journal from PID 1
[    7.392580] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    7.402018] omap_rtc 44e3e000.rtc: char device (253:1)
[    7.402035] omap_rtc 44e3e000.rtc: registered as rtc1
[    7.423132] remoteproc remoteproc0: wkup_m3 is available
[    7.753749] remoteproc remoteproc0: powering up wkup_m3
[    7.779278] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 242952
[    7.780148] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    7.780261] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[    7.847547] at24 0-0050: GPIO lookup for consumer wp
[    7.847560] at24 0-0050: using device tree for GPIO lookup
[    7.847587] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/i2c@44e0b000/at24@50[0]'
[    7.847602] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/i2c@44e0b000/at24@50[0]'
[    7.847611] at24 0-0050: using lookup tables for GPIO lookup
[    7.847619] at24 0-0050: No GPIO consumer wp found
[    7.860094] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    9.509810] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[    9.651190] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[    9.723697] omap-aes 53501000.aes: will run requests pump with realtime priority
[    9.771694] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[    9.781206] omap-des 53701000.des: will run requests pump with realtime priority
[   10.051799] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 1
[   10.609120] PM: bootloader does not support rtc-only!
[   12.971596] net eth0: initializing cpsw version 1.15 (0)
[   13.104623] Micrel KSZ8041RNLI 4a101000.mdio:01: attached PHY driver [Micrel KSZ8041RNLI] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
[   13.126740] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.362968] net eth1: initializing cpsw version 1.15 (0)
[   13.514198] Micrel KSZ8041RNLI 4a101000.mdio:05: attached PHY driver [Micrel KSZ8041RNLI] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
[   13.517152] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   14.724386] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[   15.003108] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   21.517586] input: ti-tsc as /devices/platform/44000000.ocp/44e0d000.tscadc/TI-am335x-tsc.3.auto/input/input0
[   22.828722] dwc3 48390000.usb: Failed to get clk 'ref': -2
[   22.911548] dwc3 483d0000.usb: Failed to get clk 'ref': -2
[   23.707974] remoteproc remoteproc1: 54434000.pru is available
[   23.708101] pru-rproc 54434000.pru: PRU rproc node pru@54434000 probed successfully
[   23.750680] remoteproc remoteproc2: 54438000.pru is available
[   23.750925] pru-rproc 54438000.pru: PRU rproc node pru@54438000 probed successfully
[   23.753006] usbcore: registered new interface driver usbfs
[   23.753104] usbcore: registered new interface driver hub
[   23.753259] usbcore: registered new device driver usb
[   23.767993] remoteproc remoteproc3: 54474000.pru is available
[   23.768155] pru-rproc 54474000.pru: PRU rproc node pru@54474000 probed successfully
[   23.768823] remoteproc remoteproc4: 54478000.pru is available
[   23.768935] pru-rproc 54478000.pru: PRU rproc node pru@54478000 probed successfully
[   23.935383] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[   23.935464] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[   23.936637] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
[   23.936728] xhci-hcd xhci-hcd.5.auto: irq 101, io mem 0x48390000
[   23.963963] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   23.964011] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   23.964033] usb usb1: Product: xHCI Host Controller
[   23.964051] usb usb1: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd
[   23.964070] usb usb1: SerialNumber: xhci-hcd.5.auto
[   23.966771] hub 1-0:1.0: USB hub found
[   23.976189] hub 1-0:1.0: 1 port detected
[   23.985022] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[   23.985081] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[   23.985122] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[   23.985291] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   23.985452] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   23.985482] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   23.985503] usb usb2: Product: xHCI Host Controller
[   23.985521] usb usb2: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd
[   23.985541] usb usb2: SerialNumber: xhci-hcd.5.auto
[   24.024106] hub 2-0:1.0: USB hub found
[   24.024200] hub 2-0:1.0: 1 port detected
[   24.025081] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   24.025140] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[   24.044219] xhci-hcd xhci-hcd.6.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
[   24.044317] xhci-hcd xhci-hcd.6.auto: irq 102, io mem 0x483d0000
[   24.079646] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   24.079690] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   24.079713] usb usb3: Product: xHCI Host Controller
[   24.079731] usb usb3: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd
[   24.079750] usb usb3: SerialNumber: xhci-hcd.6.auto
[   24.080544] hub 3-0:1.0: USB hub found
[   24.080615] hub 3-0:1.0: 1 port detected
[   24.081159] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   24.081202] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[   24.081241] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[   24.081377] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   24.103674] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   24.103720] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   24.103742] usb usb4: Product: xHCI Host Controller
[   24.103759] usb usb4: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd
[   24.103779] usb usb4: SerialNumber: xhci-hcd.6.auto
[   24.104626] hub 4-0:1.0: USB hub found
[   24.104698] hub 4-0:1.0: 1 port detected
[   24.343640] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[   24.443674] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[   24.525356] usb 1-1: New USB device found, idVendor=04b4, idProduct=6570, bcdDevice=32.99
[   24.525403] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   24.525425] usb 1-1: Product: USB2.0 Hub
[   24.561848] hub 1-1:1.0: USB hub found
[   24.562658] hub 1-1:1.0: 4 ports detected
[   24.634828] usb 3-1: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[   24.634873] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   24.634895] usb 3-1: Product: Android
[   24.634911] usb 3-1: Manufacturer: Android
[   24.883688] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[   25.015170] usb 1-1.1: New USB device found, idVendor=04b4, idProduct=6570, bcdDevice=32.99
[   25.015216] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   25.015239] usb 1-1.1: Product: USB2.0 Hub
[   25.134263] hub 1-1.1:1.0: USB hub found
[   25.143679] hub 1-1.1:1.0: 4 ports detected
[   25.150617] usbcore: registered new interface driver cdc_wdm
[   25.161252] usbcore: registered new interface driver option
[   25.161356] usbserial: USB Serial support registered for GSM modem (1-port)
[   25.161818] option 3-1:1.0: GSM modem (1-port) converter detected
[   25.193736] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[   25.194090] option 3-1:1.1: GSM modem (1-port) converter detected
[   25.194530] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[   25.194754] option 3-1:1.2: GSM modem (1-port) converter detected
[   25.195115] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[   25.195320] option 3-1:1.3: GSM modem (1-port) converter detected
[   25.195670] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
[   25.297937] qmi_wwan_q 3-1:1.4: cdc-wdm0: USB WDM device
[   25.299183] qmi_wwan_q 3-1:1.4: Quectel Android work on RawIP mode
[   25.300188] qmi_wwan_q 3-1:1.4: rx_urb_size = 1520
[   25.303457] qmi_wwan_q 3-1:1.4 wwan0: register 'qmi_wwan_q' at usb-xhci-hcd.6.auto-1, WWAN/QMI device, 86:75:b5:65:76:50
[   25.303940] usbcore: registered new interface driver qmi_wwan_q
[   25.311845] usbcore: registered new interface driver qmi_wwan
[   44.840606] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[   51.375279] alloc_contig_range: [9d092, 9d093) PFNs busy
[   51.376261] alloc_contig_range: [9d092, 9d093) PFNs busy
[   52.839103] gpio gpiochip1: Persistence not supported for GPIO 2
[   52.999488] gpio gpiochip1: Persistence not supported for GPIO 5
[   53.303727] usb 1-1.3: new full-speed USB device number 4 using xhci-hcd
[   53.436591] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[   53.436619] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   53.436631] usb 1-1.3: Product: CP2102N USB to UART Bridge Controller
[   53.436641] usb 1-1.3: Manufacturer: Silicon Labs
[   53.436651] usb 1-1.3: SerialNumber: 18d4f108561bec118a59f68c5139011f
[   53.583695] usb 1-1.4: new full-speed USB device number 5 using xhci-hcd
[   53.680236] usbcore: registered new interface driver cp210x
[   53.680434] usbserial: USB Serial support registered for cp210x
[   53.680659] cp210x 1-1.3:1.0: cp210x converter detected
[   53.689071] gpiochip_find_base: found new base at 508
[   53.689431] gpio gpiochip6: (cp210x): added GPIO chardev (254:6)
[   53.689587] gpiochip_setup_dev: registered GPIOs 508 to 511 on device: gpiochip6 (cp210x)
[   53.699317] usb 1-1.3: cp210x converter now attached to ttyUSB4
[   53.715852] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[   53.715881] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   53.715892] usb 1-1.4: Product: CP2102N USB to UART Bridge Controller
[   53.715903] usb 1-1.4: Manufacturer: Silicon Labs
[   53.715912] usb 1-1.4: SerialNumber: 2e9e19014c1bec11ab78ff8c5139011f
[   53.718409] cp210x 1-1.4:1.0: cp210x converter detected
[   53.730747] gpiochip_find_base: found new base at 504
[   53.731125] gpio gpiochip7: (cp210x): added GPIO chardev (254:7)
[   53.731276] gpiochip_setup_dev: registered GPIOs 504 to 507 on device: gpiochip7 (cp210x)
[   53.734284] usb 1-1.4: cp210x converter now attached to ttyUSB5
[   54.143721] usb 1-1.2: new high-speed USB device number 6 using xhci-hcd
[   54.275691] usb 1-1.2: New USB device found, idVendor=0e8d, idProduct=7668, bcdDevice= 1.00
[   54.275721] usb 1-1.2: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[   54.275732] usb 1-1.2: Product: Wireless_Device
[   54.275742] usb 1-1.2: Manufacturer: MediaTek Inc.
[   54.275751] usb 1-1.2: SerialNumber: 000000000
[   54.764485] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   55.149439] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   56.906413] [wlan][754]mtk_usb_probe:(HAL EVENT) mtk_usb_probe()
[   56.906439] [wlan][754]mtk_usb_probe:(HAL EVENT) wlan_probe()
[   56.909662] [wlan][754]glSetHifInfo:(HAL STATE) USB Device speed: 3 [512]
[   58.468160] [wlan][754]wlanAdapterStart:(INIT WARN) Send a Dummy CMD as workaround
[   58.468327] [wlan][754]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=4) Warning. Data is not completed. (receive 80/148)
[   58.468344] [wlan][754]wlanQueryNicCapability:(INIT WARN) wlanQueryNicCapability: skip unexpected event ID[0x27]
[   58.474301] [wlan][754]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=4) Warning. Data is not completed. (receive 136/2356)
[   58.475911] [wlan][754]wlanAdapterStart:(INIT WARN) wlanAdapterStart: load manufacture data fail
[   64.236362] [wlan][754]mtk_reg_notify:(RLM WARN) County Code is not assigned. Use default WW.
[   64.236394] [wlan][754]rlmDomainSearchRegdomainFromLocalDataBase:(RLM ERROR) rlmDomainSearchRegdomainFromLocalDataBase(): Error, Cannot find the correct RegDomain. country = 00.
[   64.250471] [wlan][754]wlanProbe:(INIT EVENT) wlanProbe: probe success
[   64.254625] usbcore: registered new interface driver wlan
[   64.666965] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   98.613798] usb 1-1.1.2: new high-speed USB device number 7 using xhci-hcd
[   98.745966] usb 1-1.1.2: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[   98.746017] usb 1-1.1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[   98.746045] usb 1-1.1.2: Product: Mass Storage Gadget
[   98.746071] usb 1-1.1.2: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[   98.811367] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
[   98.821107] usb-storage 1-1.1.2:1.0: Quirks match for vid 0525 pid a4a5: 10000
[   98.821347] scsi host0: usb-storage 1-1.1.2:1.0
[   98.822092] usbcore: registered new interface driver usb-storage
[   98.835241] usbcore: registered new interface driver uas
[   99.073619] usb 1-1.1.3: new high-speed USB device number 8 using xhci-hcd
[   99.205857] usb 1-1.1.3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[   99.205908] usb 1-1.1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[   99.205935] usb 1-1.1.3: Product: Mass Storage Gadget
[   99.205959] usb 1-1.1.3: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[   99.233278] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
[   99.241932] usb-storage 1-1.1.3:1.0: Quirks match for vid 0525 pid a4a5: 10000
[   99.242147] scsi host1: usb-storage 1-1.1.3:1.0
[   99.845684] scsi 0:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[   99.850940] sd 0:0:0:0: Power-on or device reset occurred
[   99.851772] sd 0:0:0:0: [sda] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[   99.969706] sd 0:0:0:0: [sda] Write Protect is off
[   99.969744] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[  100.089776] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  100.244595] scsi 1:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[  100.247431] sd 1:0:0:0: Power-on or device reset occurred
[  100.251737] sd 1:0:0:0: [sdb] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[  100.333409]  sda:
[  100.370342] sd 1:0:0:0: [sdb] Write Protect is off
[  100.370378] sd 1:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[  100.490155] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  100.580590] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  100.733069]  sdb:
[  100.970220] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[  101.399481] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  101.888345] FAT-fs (sdb): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  230.884839] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[  230.884950] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[  258.964444] cpsw 4a100000.ethernet eth1: Link is Down
[  265.741727] usb 1-1.1.2: USB disconnect, device number 7
[  265.755736] print_req_error: I/O error, dev sda, sector 1
[  265.755774] Buffer I/O error on dev sda, logical block 1, lost async page write
[  265.800003] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  265.800144] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[  266.037095] usb 1-1.1.3: USB disconnect, device number 8
[  266.054102] print_req_error: I/O error, dev sdb, sector 1
[  266.054136] Buffer I/O error on dev sdb, logical block 1, lost async page write
[  266.109719] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[  266.109860] sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[  266.134212] FAT-fs (sda): FAT read failed (blocknr 32)
[  266.478713] FAT-fs (sdb): FAT read failed (blocknr 32)
[  362.293649] usb 1-1.1.2: new high-speed USB device number 9 using xhci-hcd
[  362.426195] usb 1-1.1.2: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[  362.426228] usb 1-1.1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[  362.426238] usb 1-1.1.2: Product: Mass Storage Gadget
[  362.426248] usb 1-1.1.2: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[  362.443209] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
[  362.453749] usb-storage 1-1.1.2:1.0: Quirks match for vid 0525 pid a4a5: 10000
[  362.458774] scsi host0: usb-storage 1-1.1.2:1.0
[  362.803624] usb 1-1.1.3: new high-speed USB device number 10 using xhci-hcd
[  362.935753] usb 1-1.1.3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[  362.935785] usb 1-1.1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[  362.935800] usb 1-1.1.3: Product: Mass Storage Gadget
[  362.935812] usb 1-1.1.3: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[  362.950746] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
[  362.970307] usb-storage 1-1.1.3:1.0: Quirks match for vid 0525 pid a4a5: 10000
[  362.970536] scsi host1: usb-storage 1-1.1.3:1.0
[  363.525507] scsi 0:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[  363.531083] sd 0:0:0:0: Power-on or device reset occurred
[  363.537495] sd 0:0:0:0: [sda] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[  363.665040] sd 0:0:0:0: [sda] Write Protect is off
[  363.665097] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[  363.668909] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  363.685759]  sda:
[  363.809365] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  364.006086] scsi 1:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[  364.017086] sd 1:0:0:0: Power-on or device reset occurred
[  364.024351] sd 1:0:0:0: [sdb] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[  364.025843] sd 1:0:0:0: [sdb] Write Protect is off
[  364.025872] sd 1:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[  364.027362] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  364.038892]  sdb:
[  364.160717] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[  364.511351] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  364.907254] FAT-fs (sdb): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  420.164649] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[  451.364468] cpsw 4a100000.ethernet eth1: Link is Down
[  456.461832] usb 1-1.1.2: USB disconnect, device number 9
[  456.467984] print_req_error: I/O error, dev sda, sector 1
[  456.468019] Buffer I/O error on dev sda, logical block 1, lost async page write
[  456.516056] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  456.516206] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[  456.742038] FAT-fs (sda): FAT read failed (blocknr 32)
[  456.974099] usb 1-1.1.3: USB disconnect, device number 10
[  456.982973] print_req_error: I/O error, dev sdb, sector 1
[  456.983008] Buffer I/O error on dev sdb, logical block 1, lost async page write
[  457.035803] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[  457.035939] sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[  457.401723] FAT-fs (sdb): FAT read failed (blocknr 32)
[  552.753714] usb 1-1.1.2: new high-speed USB device number 11 using xhci-hcd
[  552.885035] usb 1-1.1.2: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[  552.885086] usb 1-1.1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[  552.885113] usb 1-1.1.2: Product: Mass Storage Gadget
[  552.885139] usb 1-1.1.2: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[  552.915990] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
[  552.928801] usb-storage 1-1.1.2:1.0: Quirks match for vid 0525 pid a4a5: 10000
[  552.929019] scsi host0: usb-storage 1-1.1.2:1.0
[  554.004668] scsi 0:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[  554.013313] sd 0:0:0:0: Power-on or device reset occurred
[  554.018696] sd 0:0:0:0: [sda] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[  554.132224] sd 0:0:0:0: [sda] Write Protect is off
[  554.132259] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[  554.251779] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  554.494595]  sda:
[  554.553665] usb 1-1.1.3: new high-speed USB device number 12 using xhci-hcd
[  554.621854] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  554.685127] usb 1-1.1.3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[  554.685156] usb 1-1.1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[  554.685167] usb 1-1.1.3: Product: Mass Storage Gadget
[  554.685176] usb 1-1.1.3: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[  554.702112] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
[  554.733846] usb-storage 1-1.1.3:1.0: Quirks match for vid 0525 pid a4a5: 10000
[  554.737678] scsi host1: usb-storage 1-1.1.3:1.0
[  555.372614] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  555.765533] scsi 1:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[  555.776092] sd 1:0:0:0: Power-on or device reset occurred
[  555.777217] sd 1:0:0:0: [sdb] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[  555.778745] sd 1:0:0:0: [sdb] Write Protect is off
[  555.778775] sd 1:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[  555.780249] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  555.795278]  sdb:
[  555.915637] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[  556.441011] FAT-fs (sdb): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 2461.834222] hrtimer: interrupt took 390917 ns
[52697.869627] usb 1-1.1.2: USB disconnect, device number 11
[52697.874971] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[52697.875106] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[52698.177559] FAT-fs (sda): FAT read failed (blocknr 32)
[52699.124067] usb 1-1.1.3: reset high-speed USB device number 12 using xhci-hcd
[52699.294153] sd 1:0:0:0: Power-on or device reset occurred
[52699.327341] VFS: busy inodes on changed media or resized disk sdb
[52699.953464] usb 1-1.1.2: new high-speed USB device number 13 using xhci-hcd
[52700.084685] usb 1-1.1.2: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.14
[52700.084713] usb 1-1.1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[52700.084724] usb 1-1.1.2: Product: Mass Storage Gadget
[52700.084735] usb 1-1.1.2: Manufacturer: Linux 4.14.67-gd315a9bb00 with musb-hdrc
[52700.097168] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
[52700.107642] usb-storage 1-1.1.2:1.0: Quirks match for vid 0525 pid a4a5: 10000
[52700.107796] scsi host0: usb-storage 1-1.1.2:1.0
[52700.281310]  sdb:
[52701.124933] scsi 0:0:0:0: Direct-Access     Linux    File-Stor Gadget 0414 PQ: 0 ANSI: 2
[52701.130635] sd 0:0:0:0: Power-on or device reset occurred
[52701.131633] sd 0:0:0:0: [sda] 1048576 512-byte logical blocks: (537 MB/512 MiB)
[52701.247632] sd 0:0:0:0: [sda] Write Protect is off
[52701.247687] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[52701.367465] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[52701.609042]  sda:
[52701.857600] sd 0:0:0:0: [sda] Attached SCSI removable disk
[52702.342052] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[173918.131993] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.132194] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.132349] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.132498] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.132661] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.132807] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.133039] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.133199] [wlan][14118]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.133350] [wlan][13822]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.133521] [wlan][123]halRxUSBReceiveDataComplete:(RX ERROR) [halRxUSBReceiveDataComplete] receive DATA fail (status = -71)
[173918.221163] usb 1-1.2: USB disconnect, device number 6
[173918.222402] [wlan][13822]mtk_usb_disconnect:(HAL STATE) mtk_usb_disconnect()
[173918.232009] [wlan][13822]halTxUSBSendCmd:(HAL ERROR) glUsbSubmitUrb() reports error (-108)
[173918.232052] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -19 retry: 0
[173918.232064] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -19 retry: 1
[173918.232074] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffed retry: 2
[173918.232085] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -19 retry: 0
[173918.232095] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -19 retry: 1
[173918.232104] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_writel() reports error: ffffffed retry: 2
[173918.283710] [wlan][13822]mtk_usb_disconnect:(HAL STATE) mtk_usb_disconnect() done
[173918.612959] usb 1-1.2: new high-speed USB device number 14 using xhci-hcd
[173918.743989] usb 1-1.2: New USB device found, idVendor=0e8d, idProduct=7668, bcdDevice= 1.00
[173918.744016] usb 1-1.2: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[173918.744028] usb 1-1.2: Product: Wireless_Device
[173918.744037] usb 1-1.2: Manufacturer: MediaTek Inc.
[173918.744046] usb 1-1.2: SerialNumber: 000000000
[173918.800977] [wlan][13822]mtk_usb_probe:(HAL EVENT) mtk_usb_probe()
[173918.801002] [wlan][13822]mtk_usb_probe:(HAL EVENT) wlan_probe()
[173918.808617] [wlan][13822]glSetHifInfo:(HAL STATE) USB Device speed: 3 [512]
[173918.832447] [wlan][13822]wlanWakeUpWiFi:(INIT WARN) Wi-Fi is already ON!, turn off before FW DL!
[173919.422484] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.422510] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.422520] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.425782] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.425807] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.425816] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.428494] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.428514] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.428523] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.429720] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.429734] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.429743] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.430858] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.430886] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.430895] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.432091] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.432106] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.432114] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.436931] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.436955] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.436965] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.438181] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.438195] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.438204] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.439349] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.439378] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.439387] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.440517] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.440543] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.440552] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.441653] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.441664] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.441687] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.447660] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.447686] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.447696] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.448983] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.448997] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.449006] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.450170] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.450183] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.450190] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.451303] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.451332] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.451340] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.452448] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.452475] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.452483] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.457091] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.457113] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.457123] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.458243] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.458272] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.458281] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.459399] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.459426] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.459576] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.460714] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.460727] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.460735] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.461834] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.461845] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.461870] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.466386] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.466408] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.466418] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.467986] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.468004] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.468013] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.469161] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.469174] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.469182] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.470809] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.470827] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.470837] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.471978] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.471991] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.471999] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.477101] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.477124] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.477134] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.478274] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.478288] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.478296] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.479900] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.479919] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.479929] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.481124] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.481138] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.481147] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.482264] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.482292] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.482301] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.486989] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.487012] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.487022] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.488145] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.488173] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.488182] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.489301] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.489328] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.489337] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.490445] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.490474] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.490482] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.491592] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.491616] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.491624] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.492745] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.492774] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.492783] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.497853] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.497875] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.497884] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.499023] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.499053] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.499062] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.500226] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.500241] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.500249] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.501352] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.501378] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.501387] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.502480] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.502492] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.502516] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.507097] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.507118] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.507127] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.508261] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.508286] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.508295] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.509460] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.509473] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.509481] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.510759] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.510773] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.510781] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.511882] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.511894] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.511918] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.516412] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.516435] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/2116)
[173919.516445] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.517990] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.518006] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/80)
[173919.518015] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.518119] [wlan][13822]mtk_usb_bulk_in_msg:(HAL ERROR) usb_bulk_msg(IN=5) Fail. Error code = -71.
[173919.518132] [wlan][13822]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=5) Warning. Data is not completed. (receive -71/32)
[173919.518140] [wlan][13822]kalDevPortRead:(HAL ERROR) usb_readsb() reports error: ffffffb9
[173919.518149] [wlan][13822]nicRxWaitResponse:(RX ERROR) halRxWaitResponse fail!
[173919.518160] [wlan][13822]wlanImageSectionDownloadStage:(INIT ERROR) Firmware download configuration failed!
[173919.518256] [wlan][13822]mtk_usb_bulk_out_msg:(HAL ERROR) usb_bulk_msg(OUT=8) Fail. Error code = -71.
[173919.518268] [wlan][13822]kalDevPortWrite:(HAL WARN) usb_bulk_msg(OUT=8) Warning. Data is not completed. (receive -71/76)
[173919.518291] [wlan][13822]kalDevPortWrite:(HAL ERROR) usb_writesb() reports error: ffffffb9
[173919.518391] [wlan][13822]mtk_usb_bulk_in_msg:(HAL ERROR) usb_bulk_msg(IN=5) Fail. Error code = -71.
[173919.518412] [wlan][13822]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=5) Warning. Data is not completed. (receive -71/32)
[173919.518421] [wlan][13822]kalDevPortRead:(HAL ERROR) usb_readsb() reports error: ffffffb9
[173919.518429] [wlan][13822]nicRxWaitResponse:(RX ERROR) halRxWaitResponse fail!
[173919.518817] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173919.518922] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173919.518933] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173919.518957] [wlan][13822]halEnableFWDownload:(HAL ERROR) [USB] kalDevRegRead fail
[173919.519036] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173919.519135] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173919.519146] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_writel() reports error: ffffffb9 retry: 2
[173919.519289] [wlan][13822]wlanProbe:(INIT ERROR) probe failed -5
[173919.519302] [wlan][13822]mtk_usb_probe:(HAL ERROR) wlan_probe() failed
[173919.519353] wlan: probe of 1-1.2:1.2 failed with error -1
[173919.536575] usb 1-1.2: USB disconnect, device number 14
[173919.862982] usb 1-1.2: new high-speed USB device number 15 using xhci-hcd
[173920.403057] usb 1-1.2: device descriptor read/64, error -71
[173920.654813] usb 1-1.2: New USB device found, idVendor=0e8d, idProduct=7668, bcdDevice= 1.00
[173920.654863] usb 1-1.2: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[173920.654891] usb 1-1.2: Product: Wireless_Device
[173920.654916] usb 1-1.2: Manufacturer: MediaTek Inc.
[173920.654940] usb 1-1.2: SerialNumber: 000000000
[173920.726426] [wlan][13822]mtk_usb_probe:(HAL EVENT) mtk_usb_probe()
[173920.726466] [wlan][13822]mtk_usb_probe:(HAL EVENT) wlan_probe()
[173920.729949] [wlan][13822]glSetHifInfo:(HAL STATE) USB Device speed: 3 [512]
[173920.783307] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.783491] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.783505] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.784765] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.785028] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.785044] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_writel() reports error: ffffffb9 retry: 2
[173920.785170] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.785269] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.785296] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.785306] [wlan][13822]wlanDownloadFW:(HAL ERROR) [USB] kalDevRegRead fail
[173920.785393] [wlan][13436]halTxUSBProcessCmdComplete:(TX ERROR) [halTxUSBProcessCmdComplete] send CMD fail (status = -71)
[173920.785453] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.785536] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.785561] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.785569] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.813272] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.813405] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.813419] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.813428] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.843190] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.843404] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.843422] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.843433] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.873255] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.873457] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.873488] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.873509] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.903137] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.903332] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.903349] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.903360] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.933378] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.933813] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.935727] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.935761] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.963193] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.963552] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.963586] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.963607] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173920.993258] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173920.993498] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173920.993527] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173920.993548] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.023187] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.023383] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.023411] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.023432] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.053361] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.053578] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.053608] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.053628] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.083423] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.083666] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.083697] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.083719] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.113145] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.113351] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.113370] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.113381] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.143156] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.143477] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.143510] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.143531] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.173202] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.173522] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.173552] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.173573] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.203156] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.203486] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.203518] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.203538] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.233256] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.233591] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.233623] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.233644] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.263156] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.263346] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.263375] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.263396] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.293167] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.293494] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.293527] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.293548] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.323179] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.323382] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.323411] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.323431] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.354006] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.354243] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.354273] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.354296] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.383100] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.383461] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.383494] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.383516] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.413244] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.413575] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.413607] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.413627] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.443141] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.443331] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.443348] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.443359] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.473294] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.473654] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.473685] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.473706] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.503250] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.503462] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.503477] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.503486] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.533173] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.533492] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.533524] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.533546] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.563133] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.563324] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.563352] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.563373] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.593192] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.593519] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.593550] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.593571] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.623181] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.623376] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.623405] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.623424] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.653281] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.653612] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.653643] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.653665] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.683238] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.683441] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.683470] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.683489] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.713170] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.713494] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.713527] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.713548] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.743151] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.743464] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.743495] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.743516] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.773365] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.773769] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.773800] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.773821] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.803173] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.803376] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.803394] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.803406] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.833163] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.833501] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.833533] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.833554] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.863159] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.863354] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.863383] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.863404] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.893197] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.893524] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.893556] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.893577] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.923152] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.923406] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.923424] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.923436] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.953161] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.953349] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.953379] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.953400] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173921.983057] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173921.983424] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173921.983455] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173921.983475] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.013226] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.013556] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.013588] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.013608] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.043186] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.043518] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.043549] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.043569] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.073190] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.073507] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.073538] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.073558] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.103265] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.103475] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.103505] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.103525] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.133146] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.133768] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.133800] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.133821] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.163161] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.163351] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.163380] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.163400] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.193191] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.193517] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.193549] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.193568] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.223258] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.224064] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.224100] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.224121] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.253284] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.253638] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.253669] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.253690] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.283666] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.283887] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.283916] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.283935] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.313218] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.313544] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.313577] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.313597] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.343171] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.343496] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.343528] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.343548] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.373130] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.373439] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.373470] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.373489] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.403208] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.403408] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.403437] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.403457] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.433203] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.433532] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.433564] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.433584] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.463170] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.463364] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.463392] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.463413] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.498597] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.498868] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.498900] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.498921] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.523236] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.523504] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.523523] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.523535] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.553178] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.553308] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.553321] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.553331] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.583220] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.583480] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.583498] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.583508] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.613128] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.613252] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.613265] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.613275] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.643160] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.643326] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.643339] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.643348] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.673224] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.673362] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.673376] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.673385] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.703166] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.703297] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.703310] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.703320] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.733171] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.733297] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.733311] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.733321] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.763764] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.764033] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.764050] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.764060] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.793107] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.793230] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.793243] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.793252] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.823210] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.823349] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.823364] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.823374] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.853106] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.853232] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.853245] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.853255] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.883161] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.883295] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.883309] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.883318] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.913135] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.913254] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.913269] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.913278] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.943313] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.943760] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.943779] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.943789] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173922.973124] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173922.973247] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173922.973260] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173922.973270] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.003185] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.003298] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.003329] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.003338] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.033430] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.033579] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.033594] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.033603] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.063160] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.063295] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.063310] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.063320] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.094095] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.094244] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.094259] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.094268] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.123082] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.123203] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.123217] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.123226] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.153271] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.153429] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.153445] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.153456] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.183132] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.183261] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.183275] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.183284] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.213170] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.213294] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.213307] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.213317] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.243261] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.243434] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.243449] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.243487] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.273150] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.273285] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.273299] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.273309] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.303100] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.303220] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.303235] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.303244] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.333169] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.333298] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.333312] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.333322] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.363103] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.363222] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.363236] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.363245] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.395835] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.395977] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.395993] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.396002] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.423179] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.423311] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.423325] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.423334] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.453223] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.453357] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.453371] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.453380] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.486412] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.486556] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.486569] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.486579] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.513120] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.513281] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.513295] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.513305] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.543193] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.543345] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.543359] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.543368] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.573159] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.573377] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.573390] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.573400] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.603210] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.603340] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.603353] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.603363] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.633193] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.633320] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.633335] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.633346] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.663145] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.663284] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.663297] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.663306] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.693095] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.693218] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.693232] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.693241] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.723116] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.723263] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.723279] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.723289] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.753203] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.753469] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.753488] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.753500] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.783090] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.783212] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.783225] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.783235] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.813175] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.813309] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.813323] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.813332] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.845959] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.846917] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.846973] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.846985] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.873237] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.873508] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.873524] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.873535] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.903184] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.903351] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.903366] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.903376] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.933147] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.933289] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.933303] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.933313] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.963137] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.963281] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.963294] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.963303] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173923.993127] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173923.993251] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173923.993265] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173923.993275] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.023162] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.023297] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.023311] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.023321] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.053120] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.053247] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.053260] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.053270] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.083219] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.083392] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.083406] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.083416] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.113158] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.113377] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.113392] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.113401] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.143089] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.143220] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.143233] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.143242] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.173232] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.173370] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.173384] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.173394] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.203118] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.203230] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.203262] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.203272] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.233152] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.233280] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.233294] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.233304] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.263123] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.263244] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.263258] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.263269] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.293106] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.293227] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.293240] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.293249] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.323154] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.323291] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.323305] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.323314] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.353108] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.353255] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.353270] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.353280] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.383156] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.383287] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.383300] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.383310] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.413405] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.413541] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.413555] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.413564] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.443259] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.443404] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.443418] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.443427] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.473247] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.473376] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.473390] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.473400] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.503125] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.503248] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.503261] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.503270] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.533120] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.533243] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.533256] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.533265] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.563155] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.563288] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.563302] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.563312] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.593159] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.593332] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.593347] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.593356] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.623147] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.623286] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.623301] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.623311] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.653253] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.653385] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.653399] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.653409] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.683378] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.683627] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.683657] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.683679] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.713279] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.713490] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.713519] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.713540] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.743232] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.743452] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.743481] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.743503] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.773150] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.773362] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.773380] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.773392] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.803192] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.803558] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.803590] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.803611] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.833149] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.833475] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.833508] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.833530] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.863177] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.863374] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.863403] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.863424] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.893153] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.893469] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.893501] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.893521] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.923191] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.923389] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.923419] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.923441] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.953689] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.954055] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.954088] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.954109] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173924.983097] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173924.983228] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173924.983244] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173924.983255] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.013250] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.013584] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.013616] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.013638] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.043265] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.043513] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.043542] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.043563] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.073376] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.073733] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.073765] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.073785] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.103161] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.103483] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.103516] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.103537] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.133305] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.133503] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.133534] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.133554] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.163173] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.163487] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.163521] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.163542] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.193164] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.193484] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.193516] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.193537] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.223190] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.223387] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.223417] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.223438] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.253160] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.253482] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.253516] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.253536] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.283204] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.283398] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.283430] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.283450] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.313191] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.313945] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.313979] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.314001] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.343194] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.343393] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.343423] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.343444] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.378609] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.379875] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.379914] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.379936] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.403096] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.403298] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.403315] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.403326] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.433354] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.433585] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.433616] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.433636] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.463154] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.463475] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.463507] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.463526] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.493323] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.493656] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.493687] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.493709] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.523211] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.523465] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.523496] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.523517] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.553164] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.553484] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.553516] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.553537] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.583208] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.583410] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.583439] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.583460] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.613192] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.613521] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.613553] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.613574] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.643946] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.644155] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.644184] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.644204] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.673096] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.673301] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.673319] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.673331] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.703195] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.703395] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.703424] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.703444] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.733232] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.733437] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.733466] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.733488] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.763149] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.763472] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.763503] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.763524] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.793454] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.793697] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.793727] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.793749] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.793973] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.794169] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.794195] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.794215] [wlan][13822]wlanCheckWifiFunc:(HAL ERROR) [USB] kalDevRegRead fail
[173925.794544] [wlan][13822]wlanCheckWifiFunc:(INIT ERROR) Waiting for power off: Timeout, Status=0xffffffff
[173925.794740] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.795054] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.795084] [wlan][13822]kalDevRegRead:(HAL ERROR) usb_readl() reports error: ffffffb9 retry: 2
[173925.795467] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 0
[173925.795602] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_control_msg() status: -71 retry: 1
[173925.795620] [wlan][13822]kalDevRegWrite:(HAL ERROR) usb_writel() reports error: ffffffb9 retry: 2
[173925.795797] [wlan][13822]wlanProbe:(INIT ERROR) probe failed -5
[173925.795813] [wlan][13822]mtk_usb_probe:(HAL ERROR) wlan_probe() failed
[173925.795870] wlan: probe of 1-1.2:1.2 failed with error -1
[173925.803782] usb 1-1.2: USB disconnect, device number 15
[173926.133079] usb 1-1.2: new high-speed USB device number 16 using xhci-hcd
[173926.134068] usb 1-1-port2: cannot reset (err = -71)
[173926.134429] usb 1-1-port2: cannot reset (err = -71)
[173926.134812] usb 1-1-port2: cannot reset (err = -71)
[173926.135103] usb 1-1-port2: cannot reset (err = -71)
[173926.135445] usb 1-1-port2: cannot reset (err = -71)
[173926.135531] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[173926.135848] usb 1-1-port2: cannot disable (err = -71)
[173926.139069] usb 1-1-port2: cannot reset (err = -71)
[173927.203170] usb 1-1-port2: cannot reset (err = -110)
[173928.243245] usb 1-1-port2: cannot reset (err = -110)
[173929.283082] usb 1-1-port2: cannot reset (err = -110)
[173930.323129] usb 1-1-port2: cannot reset (err = -110)
[173930.323169] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[173931.363202] usb 1-1-port2: cannot disable (err = -110)
[173931.363418] usb 1-1-port2: attempt power cycle
[173934.883083] usb 1-1-port2: cannot reset (err = -110)
[173935.923113] usb 1-1-port2: cannot reset (err = -110)
[173936.963132] usb 1-1-port2: cannot reset (err = -110)
[173938.003083] usb 1-1-port2: cannot reset (err = -110)
[173939.043206] usb 1-1-port2: cannot reset (err = -110)
[173939.043230] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[173940.083188] usb 1-1-port2: cannot disable (err = -110)
[173941.123762] usb 1-1-port2: cannot reset (err = -110)
[173942.163121] usb 1-1-port2: cannot reset (err = -110)
[173943.203130] usb 1-1-port2: cannot reset (err = -110)
[173944.243115] usb 1-1-port2: cannot reset (err = -110)
[173945.283034] usb 1-1-port2: cannot reset (err = -110)
[173945.283058] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[173946.323263] usb 1-1-port2: cannot disable (err = -110)
[173946.323560] usb 1-1-port2: unable to enumerate USB device
[173947.363166] usb 1-1-port2: cannot disable (err = -110)
We've already tried disabling the USB-autosuspend feature of the USB ports of the host and it did not fixed the issue.
What can be the root cause and how to fix it?
