Part Number: SK-TDA4VM
Let me confirm about below.
* When I run following model, I found error message.
* ONR-OD-8220-yolox-s-lite-mmdet-coco-640x640
Since I could run following model, I suspect I need to change image size for inference.
* TFL-OD-2020-ssdLite-mobDet-DSP-coco-320x320
Both first and second models are implemented by default on edge AI img file. However, is my understanding even if we use such models, I need to change python scripts themselves not only custom configuration file(yaml file) correct ?
(Or, is there case that not only change script, but also change source code(It means that I need to rebuild) ?)
