Part Number: TDA4VM
Hi
expert.
I try to build keywrite app.
I need to control eFuse power line so I 'd like to port I2C line on keywrite app.
I'm using attached main.c. I will use WKUP_I2C0 or MAIN_I2C1 because these are linked at same line.
I have 2 questions.
Q1. If I use MAIN_I2C1, do I need to add sbl of main domain? I think main.c is running on wkup domain only therefore main domain doesn't work.
Q2. Please check WKUP_I2C0 set. I can not read PMIC registor with I2C.
1. PLL1 set - write 0x00008031 to HSDIV_CTRL3(0x40d00000UL + 0x00001010U)
- I unlocked KICK0, KICK1
2. UNLOCK PADCONFIG7
3. Set Pin
- /* pinmux for I2C0 SDA */
HW_WR_REG32(0x43000000UL + 0x1C000 + 0xF8, 0x40000);
/* pinmux for I2C0 SCL */
HW_WR_REG32(0x43000000UL + 0x1C000 + 0xFC, 0x40000);
4. I2C init
- I2C_socGetInitCfg(0, &i2c_cfg);
i2c_cfg.funcClk = 12000000;
i2c_cfg.enableIntr = false;
I2C_socSetInitCfg(0, &i2c_cfg);
I2C_init();
5. create handle
- I2C_Params_init(&i2c_params);
i2c_params.bitRate = I2C_100kHz;
i2c_params.transferMode = I2C_MODE_BLOCKING;
i2c_params.transferCallbackFxn = NULL;
gI2cHandle = I2C_open(_channel, &i2c_params);
* \file main.c
* \brief This file contains main function, UART init functions & call to
* OTP Keywriter API
* Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "main.h"
volatile int dbg;
extern uint32_t keywr_end;
/* These two macros define size, and hex code of system firmware Key writer binary */
uint32_t gSciclient_firmware[(TIFS_KEYWRITER_BIN_SIZE_IN_BYTES+3)/4] = TIFS_KEYWRITER_BIN;
Sciclient_BoardCfgPrms_t sblBoardCfgPrms = {0};
Sciclient_BoardCfgPrms_t sblBoardCfgPmPrms = {0};
Sciclient_BoardCfgPrms_t sblBoardCfgSecPrms = {0};
static void OTP_SciClientInit(void)
int32_t status = CSL_EFAIL;
void *sysfw_ptr = gSciclient_firmware;
/* SYSFW board configurations */
Sciclient_DefaultBoardCfgInfo_t boardCfgInfo;
Sciclient_ConfigPrms_t config =
SCICLIENT_SERVICE_OPERATION_MODE_POLLED,
NULL,
1,
0,
TRUE
status = Sciclient_getDefaultBoardCfgInfo(&boardCfgInfo);
if (status != CSL_PASS)
UART_printf("Sciclient get default board config...FAILED \n");
KeywrErrLoop(__FILE__, __LINE__);
status = Sciclient_loadFirmware((const uint32_t *) sysfw_ptr);
/* UART_printf("TIFS load...FAILED \n"); */
status = Sciclient_init(&config);
UART_printf("Sciclient init ...FAILED \n");
sblBoardCfgPrms.boardConfigLow = (uint32_t)boardCfgInfo.boardCfgLow;
sblBoardCfgPrms.boardConfigHigh = 0;
sblBoardCfgPrms.boardConfigSize = boardCfgInfo.boardCfgLowSize;
sblBoardCfgPrms.devGrp = DEVGRP_ALL;
status = Sciclient_boardCfg(&sblBoardCfgPrms);
UART_printf("Sciclient board config ...FAILED \n");
if (KEYWRITER_LOG_LEVEL > OTP_LOG_NONE)
UART_stdioDeInit();
sblBoardCfgPmPrms.boardConfigLow = (uint32_t)boardCfgInfo.boardCfgLowPm;
sblBoardCfgPmPrms.boardConfigHigh = 0;
sblBoardCfgPmPrms.boardConfigSize = boardCfgInfo.boardCfgLowPmSize;
sblBoardCfgPmPrms.devGrp = DEVGRP_ALL;
status = Sciclient_boardCfgPm(&sblBoardCfgPmPrms);
UART_printf("Sciclient board config pm...FAILED \n");
/* Re-init UART for logging */
UART_HwAttrs uart_cfg;
UART_socGetInitCfg(BOARD_UART_INSTANCE, &uart_cfg);
uart_cfg.frequency = SBL_SYSFW_UART_MODULE_INPUT_CLK;
UART_socSetInitCfg(BOARD_UART_INSTANCE, &uart_cfg);
UART_stdioInit(BOARD_UART_INSTANCE);
sblBoardCfgSecPrms.boardConfigLow = (uint32_t)boardCfgInfo.boardCfgLowSec;
sblBoardCfgSecPrms.boardConfigHigh = 0;
sblBoardCfgSecPrms.boardConfigSize = boardCfgInfo.boardCfgLowSecSize;
sblBoardCfgSecPrms.devGrp = DEVGRP_ALL;
status = Sciclient_boardCfgSec(&sblBoardCfgSecPrms);
UART_printf("Sciclient board config sec...FAILED \n");
/* Secure ROM has left firewall regions for FSS DAT0 set. Disable them for DMA usage. */
uint16_t i;
struct tisci_msg_fwl_set_firewall_region_resp respFwCtrl = {0};
struct tisci_msg_fwl_set_firewall_region_req reqFwCtrl =
.fwl_id = (uint16_t) MCU_FSS0_S0_FWID,
.region = (uint16_t) 0,
.n_permission_regs = (uint32_t) 3,
.control = (uint32_t) 0,
.permissions[0] = (uint32_t) 0,
.permissions[1] = (uint32_t) 0,
.permissions[2] = (uint32_t) 0,
.start_address = 0,
.end_address = 0
for (i = 0; i < MCU_FSS0_S0_FW_REGIONS; i++)
reqFwCtrl.region = i;
status = Sciclient_firewallSetRegion(&reqFwCtrl, &respFwCtrl, SCICLIENT_SERVICE_WAIT_FOREVER);
UART_printf("MCU FSS0_S0 firewall region # %d disable...FAILED \n", i);
/* Skipping board cfg RM, since it is not included in sysfw for keywriter */
/* Print System Firmware Version Information */
struct tisci_msg_version_req req = {0};
const Sciclient_ReqPrm_t reqPrm =
TISCI_MSG_VERSION,
TISCI_MSG_FLAG_AOP,
(const uint8_t *)&req,
sizeof(req),
struct tisci_msg_version_resp response;
Sciclient_RespPrm_t respPrm =
0,
(uint8_t *) &response,
(uint32_t)sizeof (response)
status = Sciclient_service(&reqPrm, &respPrm);
if (CSL_PASS == status)
if (respPrm.flags == (uint32_t)TISCI_MSG_FLAG_ACK)
UART_printf("\n OTP Keywriter ver: %s\n", (char *) response.str);
else
UART_printf(" OTP Keywriter Get Version failed \n");
static void mmr_unlock(uint32_t base, uint32_t partition){
/* Translate the base address */
uint32_t part_base = base + partition * CTRL_MMR0_PARTITION_SIZE;
HW_WR_REG32(part_base + CTRLMMR_LOCK_KICK0, CTRLMMR_LOCK_KICK0_UNLOCK_VAL);
HW_WR_REG32(part_base + CTRLMMR_LOCK_KICK1, CTRLMMR_LOCK_KICK1_UNLOCK_VAL);
int main()
uint32_t debug_response = 0;
uint32_t *keywriter_cert = &keywr_end + 1;
/* padconfig unlock */
mmr_unlock(WKUP_CTRL_BASE, 7);
/* pinmux for R5 logs */
HW_WR_REG32(BOARD_MCU_UART_TX_PINMUX_ADDR, PIN_OUTPUT | PIN_MODE(0));
/* pinmux for M3 logs */
HW_WR_REG32(WKUP_UART_TXD_MUX_ADDR, PIN_OUTPUT | PIN_MODE(0) );
uart_cfg.frequency = SBL_ROM_UART_MODULE_INPUT_CLK;
uart_cfg.enableInterrupt = FALSE;
UART_printf("%s (%s - %s)\n", OTP_VERSION_STR, __DATE__, __TIME__);
OTP_SciClientInit();
UART_printf("Beginning key programming sequence \n");
UART_printf("Taking OTP configuration from 0x%x\n", (uint32_t *)keywriter_cert);
status = Sciclient_otpProcessKeyCfg((uint32_t *)keywriter_cert, SCICLIENT_SERVICE_WAIT_FOREVER, &debug_response);
UART_printf("Something wrong happened!!\n");
UART_printf("Debug response: 0x%x\n", debug_response);
UART_printf("Key programming is complete \n");
asm volatile (" wfi");
return 0;
