J784S4XEVM: Is MMCSD0 and 1 accessible outside the main domain
Part Number: J784S4XEVM
RE: CS1629075
  • Customer services ask me to create a new question to E2E
In the J784s4 TRM (SPRUJ52B - June 2022), Section 5.5.22 MMCSD shows MMCSD as being available in the Main domain only, not in WKUP or MCU domains.
1) Why is MMCSD shown as Main domain only?
It might be that Main only has access to the hardware registers etc, but there may be other reasons, can you clarify?
2) Can the MCU and WKUP domains directly access MMCSD, e.g. without any code at all running in the Main domain?
3) Can MMCSD be accessed with the Main domain powered off?
Table 4-1 implies not (note 3 "When in normal boot flow (MCU only = 0), but can you confirm?
Malcolm
  • Hi  Malcolm,
    There are different domain like wakeup mcu main.
    these are divided considering several aspects like safety level, power rails used ...etc.
    so mmcsd controller falls in main domain as it doesn’t require an ASIL D kind of safety requirements.
    Yes other domain can access MMCSD there no restrictions as such.
    Yes, if you see the SPL/SBL boot flow we do access mmcsd to get the next stage image using MCU r5 core which is in mcu domain. And then we boot A72 core
    Diwakar
