TDA4VH-Q1: Autosar Boot A72 two core failed
Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
when only boot A72 8core in sbl ,it;s running ok.
Log:
MCU @ 1000000000Hz.
cycles per usec = 1000
[INFO]: startup A core at 0x81000000
[INFO]: MPU1_0 is running...
[INFO]: MPU1_1 is running...
[INFO]: MPU1_2 is running...
[INFO]: MPU1_3 is running...
[INFO]: MPU2_0 is running...
[INFO]: MPU2_1 is running...
[INFO]: MPU2_2 is running...
[INFO]: MPU2_3 is running...
The when we use auotsar app to boot A72 some problems in this.
Log:
Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
Sciclient_procBootSetProcessorCfg, ProcId 0x20, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xca @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xca...
Sciclient_pmSetModuleState On, DevId 0xca...
Sciclient_
procBootReleaseProcessor, ProcId 0x20...
Calling Sciclient_procBootRequestProcessor, ProcId 0x21...
Sciclient_procBootSetProcessorCfg, ProcId 0x21, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xcb @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xcb...
Sciclient_pmSetModuleState On, DevId 0xcb...
Sciclient_
procBootReleaseProcessor, ProcId 0x21...
Calling Sciclient_procBootRequestProcessor, ProcId 0x22...
Sciclient_procBootSetProcessorCfg, ProcId 0x22, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xcc @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xcc...
Sciclient_pmSetModuleState On, DevId 0xcc...
Sciclient_
procBootReleaseProcessor, ProcId 0x22...
Calling Sciclient_procBootRequestProcessor, ProcId 0x23...
Sciclient_procBootSetProcessorCfg, ProcId 0x23, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xcd @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xcd...
Sciclient_pmSetModuleState On, DevId 0xcd...
Sciclient_
procBootReleaseProcessor, ProcId 0x23...
Calling Sciclient_procBootRequestProcessor, ProcId 0x24...
Sciclient_procBootSetProcessorCfg, ProcId 0x24, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xce @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xce...
Sciclient_pmSetModuleState On, DevId 0xce...
Sciclient_
procBootReleaseProcessor, ProcId 0x24...
Calling Sciclient_procBootRequestProcessor, ProcId 0x25...
Sciclient_procBootSetProcessorCfg, ProcId 0x25, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xcf @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xcf...
Sciclient_pmSetModuleState On, DevId 0xcf...
Sciclient_
procBootReleaseProcessor, ProcId 0x25...
Calling Sciclient_procBootRequestProcessor, ProcId 0x26...
Sciclient_procBootSetProcessorCfg, ProcId 0x26, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xd0 @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xd0...
Sciclient_pmSetModuleState On, DevId 0xd0...
Sciclient_procBootReleaseProcessor, ProcId 0x26...
Calling Sciclient_procBootRequestProcessor, ProcId 0x27...
Sciclient_procBootSetProcessorCfg, ProcId 0x27, EntryPoint 0x81000000...
Sciclient_pmSetModuleClkFreq, DevId 0xd1 @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xd1...
Sciclient_pmSetModuleState On, DevId 0xd1...
Sciclient_procBootReleaseProcessor, ProcId 0x27...
what kind of register we can check???
  • Dear supporter,
    We are use TDA4VH EVM board and SDK based on 08.05.00.11.
    Based on the same SOC, we boot soc based on default BootApp from SDK. It is Ok.
    We firstly boot classic AutoSAR by TI SBL. Then we boot A72 images by AutoSAR. The first 6 A72 Cores are OK. But the last two A72 Cores are failed. Details test information as above.
    Could you help us how to check reason by registers or special tools?  This issue has affected the delivery of our SOP project.
    We look forward to your reply ASAP.
    Thank you in advance.
    Which AUTOSAR vendor are you using? Has the vendor tested their stack on the TDA4VH and it is working?
    Also, is this a classic AUTOSAR stack on the A72, or is this some form of the Adaptive AUTOSAR?
    We've usually seen AUTOSAR solutions for the MCU R5Fs, but not the A72s yet.
    Could you share the complete SBL boot logs including the initial memory loading that happens?
    Erick
  • We use local company AUTOSAR.
    They found the problems too,and they don't know how to solve it.
    We use MCUR5 AUTOSAR boot A72 for test.,I have upload the ld file and startup code.
    The SBL load whole image from local company AUTOSAR no deletion .the boot A72 code is in the disassmbly startup code ,it's not running in the main function.We have ensure it's the disassmbly code or compiler problem.
    STACK_SIZE = 0x00004000;
    Mode_SYS_Stack_Size = 8192;
    Mode_EXE_Stack_Size = 1024;
    Mode_SVC_Stack_Size = 1024;
    Mode_IRQ_Stack_Size = 1024;
    Mode_FIQ_Stack_Size = 1024;
    OSEE_HEAP_SIZE = 8096;
    ENTRY(_start)
    MEMORY
        ATCM (RWX) : ORIGIN = 0x00000000, LENGTH = 0x00007FFF
        BTCM (RWX) : ORIGIN = 0x41010000, LENGTH = 0x00007FFF
        OCMC_RAM (RWX) : ORIGIN = 0x41C82000, LENGTH = 0x7DA00
        MSMC_CODE (RWX) : ORIGIN = 0x70040000, LENGTH = 0x000C0000
        MSMC_DATA (RWX) : ORIGIN = 0x70300000, LENGTH = 0x000FFFFF
        DDR0_MCU_R5F (RWX) : ORIGIN = 0xA0500000, LENGTH = 0x007FFFFF
        DDR0_VECTORS (RWX) : ORIGIN = 0xFFFF0000, LENGTH = 0x00010000
    SECTIONS
        .vectors 0x00000000 : {
            . = ALIGN(64);
            osee_vector_start = .;
            KEEP(*(.vectors))
            osee_vector_end = .;
        } > ATCM
        msmc_code_start_align (NOLOAD) : {
            . = ALIGN(osee_msmc_code_size_to_align);
            osee_msmc_code_start = .;
        } > OCMC_RAM
        .startup : {
            *(.startup)
            *(osee_boot_kernel_text)
        } > OCMC_RAM
        msmc_code_stop_align (NOLOAD) : {
            osee_msmc_code_stop = .;
            osee_msmc_code_log2ceil_size = ((osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 5) ? 5 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 6) ? 6 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 7) ? 7 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 8) ? 8 :(osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 9) ? 9 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 10) ? 10 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 11) ? 11 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 12) ? 12 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 13) ? 13 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 14) ? 14 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 15) ? 15 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 16) ? 16 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 17) ? 17 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 18) ? 18 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 19) ? 19 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 20) ? 20 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 21) ? 21 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 22) ? 22 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 23) ? 23 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 24) ? 24 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 25) ? 25 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 26) ? 26 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 27) ? 27 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 28) ? 28 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 29) ? 29 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 30) ? 30 : (osee_msmc_code_stop - osee_msmc_code_start) <= (1 << 31) ? 31 : -1);
            osee_msmc_code_size_to_align = 1 << osee_msmc_code_log2ceil_size;
            osee_msmc_code_end = .;
        } > OCMC_RAM
        msmc_data_start_align (NOLOAD) : {
            . = ALIGN(osee_msmc_data_size_to_align);
            osee_msmc_data_start = .;
        } > OCMC_RAM
        .kernel_bss_global (NOLOAD) : ALIGN(8) {
            *(osee_gbl_kernel_bss)
        } > OCMC_RAM
        .kernel_data_global : ALIGN(8) {
            *(osee_gbl_kernel_data)
        } > OCMC_RAM
        msmc_data_stop_align (NOLOAD) : {
            osee_msmc_data_stop = .;
            osee_msmc_data_log2ceil_size = ((osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 5) ? 5 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 6) ? 6 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 7) ? 7 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 8) ? 8 :(osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 9) ? 9 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 10) ? 10 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 11) ? 11 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 12) ? 12 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 13) ? 13 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 14) ? 14 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 15) ? 15 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 16) ? 16 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 17) ? 17 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 18) ? 18 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 19) ? 19 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 20) ? 20 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 21) ? 21 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 22) ? 22 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 23) ? 23 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 24) ? 24 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 25) ? 25 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 26) ? 26 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 27) ? 27 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 28) ? 28 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 29) ? 29 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 30) ? 30 : (osee_msmc_data_stop - osee_msmc_data_start) <= (1 << 31) ? 31 : -1);
            osee_msmc_data_size_to_align = 1 << osee_msmc_data_log2ceil_size;
            osee_msmc_data_end = .;
        } > OCMC_RAM
        .startupData : ALIGN(8) {
            *(.startupData)
        } > OCMC_RAM
        .startupCode : ALIGN(8) {
            *(.startupCode)
        } > OCMC_RAM
        .bootCode : ALIGN(8) {
            *(.bootCode)
        } > OCMC_RAM
        .text : ALIGN(8) {
            *(.text)
            *(.text.*)
        } > OCMC_RAM
        .bss : ALIGN(4) {
            *(.bss)
        } > OCMC_RAM
        .data : ALIGN(128) {
            *(.data)
            *(.data.*)
        } > OCMC_RAM
        .bss.devgroup.* : ALIGN(4) {
            *(.bss.devgroup.*)
        } > OCMC_RAM
        .const.devgroup.* : ALIGN(4) {
            *(.const.devgroup.*)
        } > OCMC_RAM
        .boardcfg_data : ALIGN(4)
            *(.boardcfg_data)
        } > OCMC_RAM
        .SciClientBoardCfgSection : ALIGN(128)
            .=ALIGN(128);
            __linker_boardcfg_data_start = .;
            . += 0x100;
            *(.boardcfg_data)
            .=ALIGN(128);
            . += 0x100;
            __linker_boardcfg_data_end = .;
        } > OCMC_RAM
        .stack : ALIGN(4) {
            *(.stack)
        } > OCMC_RAM
        .kernel_bss_percpu (NOLOAD) : ALIGN(8) {
            *(osee_kernel_bss_percpu)
        } > BTCM
        .kernel_data_percpu : ALIGN(8) {
            *(osee_kernel_data_percpu)
        } > BTCM AT > OCMC_RAM
        kernel_code_start_align (NOLOAD) : {
            . = ALIGN(osee_kernel_code_size_to_align);
            osee_kernel_code_start = .;
        } > OCMC_RAM
        .kernel_text : {
            *(.boot)
            *(.kernel_text)
            *(osee_kernel_text)
            *(.gnu.linkonce.t.*)
            *(.plt)
            *(.gnu_warning)
            *(.gcc_execpt_table)
            *(.glue_7)
            *(.glue_7t)
            *(.vfp11_veneer)
            *(.ARM.extab)
            *(.gnu.linkonce.armextab.*)
        } > OCMC_RAM
        OsApplication_DefaultEcucPartition_code_start_align : {
            osee_OsApplication_DefaultEcucPartition_code_start = .;
        } > DDR0_MCU_R5F
        .OsApplication_DefaultEcucPartition_text : ALIGN(8) {
            *(osee_OsApplication_DefaultEcucPartition_text)
            *(*_OsApplication_DefaultEcucPartition_text)
        } > DDR0_MCU_R5F
        OsApplication_DefaultEcucPartition_code_stop_align : {
            osee_OsApplication_DefaultEcucPartition_code_end = .;
        } > DDR0_MCU_R5F
        .text_cpu0 : {
            *(osee_core0_text)
            *(*_core0_text.*)
        } > OCMC_RAM
        .init : {
            KEEP (*(.init))
        } > OCMC_RAM
        .fini : {
            KEEP (*(.fini))
        } > OCMC_RAM
        .interp : {
            KEEP (*(.interp))
        } > OCMC_RAM
        .note-ABI-tag : {
            KEEP (*(.note-ABI-tag))
        } > OCMC_RAM
        .ctors : {
            __CTOR_LIST__ = .;
            ___CTORS_LIST___ = .;
            KEEP (*crtbegin.o(.ctors))
            KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors))
            KEEP (*(SORT(.ctors.*)))
            KEEP (*(.ctors))
            __CTOR_END__ = .;
            ___CTORS_END___ = .;
        } > OCMC_RAM
        .dtors : {
            __DTOR_LIST__ = .;
            ___DTORS_LIST___ = .;
            KEEP (*crtbegin.o(.dtors))
            KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors))
            KEEP (*(SORT(.dtors.*)))
            KEEP (*(.dtors))
            __DTOR_END__ = .;
            ___DTORS_END___ = .;
        } > OCMC_RAM
        .fixup : {
            *(.fixup)
        } > OCMC_RAM
        .eh_frame : {
            *(.eh_frame)
        } > OCMC_RAM
        .eh_framehdr : {
            *(.eh_framehdr)
        } > OCMC_RAM
        .gcc_except_table : {
            *(.gcc_except_table)
        } > OCMC_RAM
        kernel_code_stop_align (NOLOAD) : {
            osee_kernel_code_stop = .;
            osee_kernel_code_log2ceil_size = ((osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 5) ? 5 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 6) ? 6 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 7) ? 7 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 8) ? 8 :(osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 9) ? 9 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 10) ? 10 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 11) ? 11 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 12) ? 12 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 13) ? 13 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 14) ? 14 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 15) ? 15 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 16) ? 16 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 17) ? 17 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 18) ? 18 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 19) ? 19 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 20) ? 20 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 21) ? 21 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 22) ? 22 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 23) ? 23 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 24) ? 24 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 25) ? 25 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 26) ? 26 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 27) ? 27 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 28) ? 28 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 29) ? 29 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 30) ? 30 : (osee_kernel_code_stop - osee_kernel_code_start) <= (1 << 31) ? 31 : -1);
            osee_kernel_code_size_to_align = 1 << osee_kernel_code_log2ceil_size;
            osee_kernel_code_end = .;
        } > OCMC_RAM
        api_code_start_align (NOLOAD) : {
            . = ALIGN(osee_api_code_size_to_align);
            osee_api_code_start = .;
        } > OCMC_RAM
        .api_text : {
            *(osee_api_text)
            *(*_api_text)
            *(*TEXT_SECTION)
        } > OCMC_RAM
        /* .cbuf : {
            *(.cbuf)
        } > MSMC_DATA */
        api_code_stop_align (NOLOAD) : {
            osee_api_code_stop = .;
            osee_api_code_log2ceil_size = ((osee_api_code_stop - osee_api_code_start) <= (1 << 5) ? 5 : (osee_api_code_stop - osee_api_code_start) <= (1 << 6) ? 6 : (osee_api_code_stop - osee_api_code_start) <= (1 << 7) ? 7 : (osee_api_code_stop - osee_api_code_start) <= (1 << 8) ? 8 :(osee_api_code_stop - osee_api_code_start) <= (1 << 9) ? 9 : (osee_api_code_stop - osee_api_code_start) <= (1 << 10) ? 10 : (osee_api_code_stop - osee_api_code_start) <= (1 << 11) ? 11 : (osee_api_code_stop - osee_api_code_start) <= (1 << 12) ? 12 : (osee_api_code_stop - osee_api_code_start) <= (1 << 13) ? 13 : (osee_api_code_stop - osee_api_code_start) <= (1 << 14) ? 14 : (osee_api_code_stop - osee_api_code_start) <= (1 << 15) ? 15 : (osee_api_code_stop - osee_api_code_start) <= (1 << 16) ? 16 : (osee_api_code_stop - osee_api_code_start) <= (1 << 17) ? 17 : (osee_api_code_stop - osee_api_code_start) <= (1 << 18) ? 18 : (osee_api_code_stop - osee_api_code_start) <= (1 << 19) ? 19 : (osee_api_code_stop - osee_api_code_start) <= (1 << 20) ? 20 : (osee_api_code_stop - osee_api_code_start) <= (1 << 21) ? 21 : (osee_api_code_stop - osee_api_code_start) <= (1 << 22) ? 22 : (osee_api_code_stop - osee_api_code_start) <= (1 << 23) ? 23 : (osee_api_code_stop - osee_api_code_start) <= (1 << 24) ? 24 : (osee_api_code_stop - osee_api_code_start) <= (1 << 25) ? 25 : (osee_api_code_stop - osee_api_code_start) <= (1 << 26) ? 26 : (osee_api_code_stop - osee_api_code_start) <= (1 << 27) ? 27 : (osee_api_code_stop - osee_api_code_start) <= (1 << 28) ? 28 : (osee_api_code_stop - osee_api_code_start) <= (1 << 29) ? 29 : (osee_api_code_stop - osee_api_code_start) <= (1 << 30) ? 30 : (osee_api_code_stop - osee_api_code_start) <= (1 << 31) ? 31 : -1);
            osee_api_code_size_to_align = 1 << osee_api_code_log2ceil_size;
            osee_api_code_end = .;
        } > OCMC_RAM
        all_const_start_align (NOLOAD) : {
            . = ALIGN(osee_all_const_size_to_align);
            osee_all_const_start = .;
        } > OCMC_RAM
        .rodata : ALIGN(8) {
            *(*_const)
            *(*api_const_64)
            *(*api_const_32)
            *(*api_const_ptr)
            *(*api_const_16)
            *(*api_const_8)
            *(*api_const_bool)
            *(*api_const_unspecified)
            *(*api_const)
            *(*_const_64)
            *(*_const_32)
            *(*_const_ptr)
            *(*_const_16)
            *(*_const_8)
            *(*_const_bool)
            *(*_const_unspecified)
            *(*_postbuildstruct)
            *(*_postbuildconfig)
            *(.rodata)
            *(.rodata.*)
            *(.rodata1)
            *(.rodata1.*)
            *(*CONFIG_SECTION*)
            *(.gnu.linkonce.r.*)
            . = ALIGN(8) ;
            PROVIDE(__clear_table = .);
            LONG(0 + ADDR(.kernel_bss_global)); LONG(SIZEOF(.kernel_bss_global));
            LONG(0 + ADDR(.kernel_bss)); LONG(SIZEOF(.kernel_bss));
            LONG(0 + ADDR(.sbss)); LONG(SIZEOF(.sbss));
            LONG(0 + ADDR(.sbss2)); LONG(SIZEOF(.sbss2));
            LONG(0 + ADDR(.tbss)); LONG(SIZEOF(.tbss));
            LONG(0 + ADDR(.api_bss)); LONG(SIZEOF(.api_bss));
            LONG(0 + ADDR(.bss)); LONG(SIZEOF(.bss));
            LONG(0 + ADDR(.OsApplication_DefaultEcucPartition_bss)); LONG(SIZEOF(.OsApplication_DefaultEcucPartition_bss));
            LONG(0 + ADDR(.kernel_bss_cpu0)); LONG(SIZEOF(.kernel_bss_cpu0));
            LONG(0 + ADDR(.api_bss_cpu0)); LONG(SIZEOF(.api_bss_cpu0));
            LONG(-1); LONG(-1);
            PROVIDE(__copy_table = .) ;
            LONG(LOADADDR(.kernel_data_percpu)); LONG(ADDR(.kernel_data_percpu)); LONG(SIZEOF(.kernel_data_percpu));
            LONG(-1); LONG(-1); LONG(-1);
            . = ALIGN(8);
        } > OCMC_RAM
        .stack_sizes : ALIGN(4) {
            osEE_unwind_start = .;
            KEEP (*(.stack_sizes))
            osEE_unwind_end = .;
        } > OCMC_RAM
        all_const_stop_align (NOLOAD) : {
            osee_all_const_stop = .;
            osee_all_const_log2ceil_size = ((osee_all_const_stop - osee_all_const_start) <= (1 << 5) ? 5 : (osee_all_const_stop - osee_all_const_start) <= (1 << 6) ? 6 : (osee_all_const_stop - osee_all_const_start) <= (1 << 7) ? 7 : (osee_all_const_stop - osee_all_const_start) <= (1 << 8) ? 8 :(osee_all_const_stop - osee_all_const_start) <= (1 << 9) ? 9 : (osee_all_const_stop - osee_all_const_start) <= (1 << 10) ? 10 : (osee_all_const_stop - osee_all_const_start) <= (1 << 11) ? 11 : (osee_all_const_stop - osee_all_const_start) <= (1 << 12) ? 12 : (osee_all_const_stop - osee_all_const_start) <= (1 << 13) ? 13 : (osee_all_const_stop - osee_all_const_start) <= (1 << 14) ? 14 : (osee_all_const_stop - osee_all_const_start) <= (1 << 15) ? 15 : (osee_all_const_stop - osee_all_const_start) <= (1 << 16) ? 16 : (osee_all_const_stop - osee_all_const_start) <= (1 << 17) ? 17 : (osee_all_const_stop - osee_all_const_start) <= (1 << 18) ? 18 : (osee_all_const_stop - osee_all_const_start) <= (1 << 19) ? 19 : (osee_all_const_stop - osee_all_const_start) <= (1 << 20) ? 20 : (osee_all_const_stop - osee_all_const_start) <= (1 << 21) ? 21 : (osee_all_const_stop - osee_all_const_start) <= (1 << 22) ? 22 : (osee_all_const_stop - osee_all_const_start) <= (1 << 23) ? 23 : (osee_all_const_stop - osee_all_const_start) <= (1 << 24) ? 24 : (osee_all_const_stop - osee_all_const_start) <= (1 << 25) ? 25 : (osee_all_const_stop - osee_all_const_start) <= (1 << 26) ? 26 : (osee_all_const_stop - osee_all_const_start) <= (1 << 27) ? 27 : (osee_all_const_stop - osee_all_const_start) <= (1 << 28) ? 28 : (osee_all_const_stop - osee_all_const_start) <= (1 << 29) ? 29 : (osee_all_const_stop - osee_all_const_start) <= (1 << 30) ? 30 : (osee_all_const_stop - osee_all_const_start) <= (1 << 31) ? 31 : -1);
            osee_all_const_size_to_align = 1 << osee_all_const_log2ceil_size;
            osee_all_const_end = .;
        } > OCMC_RAM
        core0_kernel_ram_start_align (NOLOAD) : {
            . = ALIGN(osee_core0_kernel_ram_size_to_align);
            osee_core0_kernel_ram_start = .;
        } > OCMC_RAM
        OsApplication_DefaultEcucPartition_ram_start_align : {
            osee_OsApplication_DefaultEcucPartition_ram_start = .;
        } > OCMC_RAM
        .OsApplication_DefaultEcucPartition_bss (NOLOAD) : ALIGN(8) {
            *(osee_OsApplication_DefaultEcucPartition_bss)
            *(*_OsApplication_DefaultEcucPartition_bss)
            *(*_OsApplication_DefaultEcucPartition_bss_64)
            *(*_OsApplication_DefaultEcucPartition_bss_32)
            *(*_OsApplication_DefaultEcucPartition_bss_ptr)
            *(*_OsApplication_DefaultEcucPartition_bss_16)
            *(*_OsApplication_DefaultEcucPartition_bss_8)
            *(*_OsApplication_DefaultEcucPartition_bss_bool)
            *(*_OsApplication_DefaultEcucPartition_bss_unspecified)
            *(*_OsApplication_DefaultEcucPartition_postbuildbufbss)
            . = ALIGN(8);
        } > OCMC_RAM
        .OsApplication_DefaultEcucPartition_data : ALIGN(4) {
            osee_OsApplication_DefaultEcucPartition_data_start = .;
            *(osee_OsApplication_DefaultEcucPartition_data)
            *(*_OsApplication_DefaultEcucPartition_data)
            *(*_OsApplication_DefaultEcucPartition_data_64)
            *(*_OsApplication_DefaultEcucPartition_data_32)
            *(*_OsApplication_DefaultEcucPartition_data_ptr)
            *(*_OsApplication_DefaultEcucPartition_data_16)
            *(*_OsApplication_DefaultEcucPartition_data_8)
            *(*_OsApplication_DefaultEcucPartition_data_bool)
            *(*_OsApplication_DefaultEcucPartition_data_unspecified)
            *(*_OsApplication_DefaultEcucPartition_postbuildbuf)
            *(*_OsApplication_DefaultEcucPartition_postbuildbufdata)
        } > OCMC_RAM
        . = ALIGN(64);
        OsApplication_DefaultEcucPartition_ram_stop_align : {
            osee_OsApplication_DefaultEcucPartition_ram_end = .;
        } > OCMC_RAM
        .kernel_bss_cpu0 (NOLOAD) : ALIGN(8) {
            *(osee_core0_bss)
            *(*_core0_bss)
            . = ALIGN(8);
        } > OCMC_RAM
        .kernel_data_cpu0 : ALIGN(4) {
            *(osee_core0_data)
            *(*_core0_data)
        } > OCMC_RAM
        core0_kernel_ram_stop_align (NOLOAD) : {
            osee_core0_kernel_ram_stop = .;
            osee_core0_kernel_ram_log2ceil_size = ((osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 5) ? 5 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 6) ? 6 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 7) ? 7 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 8) ? 8 :(osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 9) ? 9 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 10) ? 10 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 11) ? 11 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 12) ? 12 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 13) ? 13 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 14) ? 14 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 15) ? 15 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 16) ? 16 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 17) ? 17 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 18) ? 18 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 19) ? 19 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 20) ? 20 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 21) ? 21 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 22) ? 22 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 23) ? 23 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 24) ? 24 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 25) ? 25 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 26) ? 26 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 27) ? 27 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 28) ? 28 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 29) ? 29 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 30) ? 30 : (osee_core0_kernel_ram_stop - osee_core0_kernel_ram_start) <= (1 << 31) ? 31 : -1);
            osee_core0_kernel_ram_size_to_align = 1 << osee_core0_kernel_ram_log2ceil_size;
            osee_core0_kernel_ram_end = .;
        } > OCMC_RAM
            . = ALIGN(osee_kernel_ram_size_to_align);
            osee_kernel_ram_start = .;
        } > OCMC_RAM
        .kernel_bss (NOLOAD) : ALIGN(8) {
            osEE_bss_start = .;
            *(.bss_cpu)
            *(ioc_kernel_bss)
            *(osee_kernel_bss)
            *(osee_core*_kernel_bss)
            *(*_kernel_bss)
            *(.gnu.linkonce.b.*)
            *(COMMON)
            . = ALIGN(8);
            osEE_bss_end = .;
        } > OCMC_RAM
        .tbss (NOLOAD) : ALIGN(8) {
            *(.tbss)
            *(.tbss.*)
            *(.gnu.linkonce.tb.*)
            . = ALIGN(8);
        } > OCMC_RAM
        .sbss (NOLOAD) : ALIGN(8) {
            osEE_sbss_start = .;
            *(.sbss)
            *(.sbss.*)
            *(.gnu.linkonce.sb.*)
            . = ALIGN(8);
            osEE_sbss_end = .;
        } > OCMC_RAM
        .sbss2 (NOLOAD) : ALIGN(8) {
            *(.sbss2)
            *(.sbss2.*)
            *(.gnu.linkonce.sb2.*)
            . = ALIGN(8);
        } > OCMC_RAM
        .kernel_data : ALIGN(4) {
            osee_kernel_data_start = .;
            *(.data_cpu*)
            *(ioc_kernel_data)
            *(osee_kernel_data)
            *(osee_core*_kernel_data)
            *(*_kernel_data)
            *(.gnu.linkonce.d.*)
        } > OCMC_RAM
        .data1 : ALIGN(4) {
            *(.data1)
            *(.data1.*)
        } > OCMC_RAM
        .sdata : ALIGN(4) {
            *(.sdata)
            *(.sdata.*)
            *(.gnu.linkonce.s.*)
        } > OCMC_RAM
        .sdata2 : ALIGN(4) {
            *(.sdata2)
            *(.sdata2.*)
            *(.gnu.linkonce.s2.*)
        } > OCMC_RAM
        .tdata : ALIGN(4) {
            *(.tdata)
            *(.tdata.*)
            *(.gnu.linkonce.td.*)
        } > OCMC_RAM
        .heap (NOLOAD) : ALIGN(64) {
            end = .;
        } > OCMC_RAM
            osee_kernel_ram_stop = .;
            osee_kernel_ram_log2ceil_size = ((osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 5) ? 5 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 6) ? 6 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 7) ? 7 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 8) ? 8 :(osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 9) ? 9 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 10) ? 10 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 11) ? 11 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 12) ? 12 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 13) ? 13 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 14) ? 14 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 15) ? 15 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 16) ? 16 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 17) ? 17 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 18) ? 18 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 19) ? 19 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 20) ? 20 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 21) ? 21 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 22) ? 22 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 23) ? 23 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 24) ? 24 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 25) ? 25 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 26) ? 26 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 27) ? 27 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 28) ? 28 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 29) ? 29 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 30) ? 30 : (osee_kernel_ram_stop - osee_kernel_ram_start) <= (1 << 31) ? 31 : -1);
            osee_kernel_ram_size_to_align = 1 << osee_kernel_ram_log2ceil_size;
            osee_kernel_ram_end = .;
                . = ALIGN(8);
        } > OCMC_RAM
        api_ram_start_align (NOLOAD) : {
            . = ALIGN(osee_api_ram_size_to_align);
            osee_api_ram_start = .;
        } > DDR0_MCU_R5F
        .api_bss (NOLOAD) : ALIGN(8) {
            *(osee_api_bss)
            *(*_api_bss_64)
            *(*_api_bss_32)
            *(*_api_bss_ptr)
            *(*_api_bss_16)
            *(*_api_bss_8)
            *(*_api_bss_bool)
            *(*_api_bss_unspecified)
            *(*_api_bss)
            *(*_api_postbuildbufbss)
            ALIGN(128)
            *(ETH_DATA_NO_INIT_UNSPECIFIED_SECTION)
            .api_data : ALIGN(4) {
            osee_api_data_start = .;
            *(osee_api_data)
            *(*_api_data_ptr)
            *(*_api_data_64)
            *(*_api_data_32)
            *(*_api_data_16)
            *(*_api_data_8)
            *(*_api_data_bool)
            *(*_api_data_unspecified)
            *(*_api_data)
            *(*_api_postbuildbuf)
            *(*_api_postbuildbufdata)
        } > DDR0_MCU_R5F
        api_ram_stop_align (NOLOAD) : {
            osee_api_ram_stop = .;
            osee_api_ram_log2ceil_size = ((osee_api_ram_stop - osee_api_ram_start) <= (1 << 5) ? 5 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 6) ? 6 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 7) ? 7 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 8) ? 8 :(osee_api_ram_stop - osee_api_ram_start) <= (1 << 9) ? 9 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 10) ? 10 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 11) ? 11 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 12) ? 12 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 13) ? 13 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 14) ? 14 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 15) ? 15 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 16) ? 16 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 17) ? 17 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 18) ? 18 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 19) ? 19 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 20) ? 20 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 21) ? 21 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 22) ? 22 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 23) ? 23 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 24) ? 24 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 25) ? 25 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 26) ? 26 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 27) ? 27 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 28) ? 28 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 29) ? 29 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 30) ? 30 : (osee_api_ram_stop - osee_api_ram_start) <= (1 << 31) ? 31 : -1);
            osee_api_ram_size_to_align = 1 << osee_api_ram_log2ceil_size;
            osee_api_ram_end = .;
        } > DDR0_MCU_R5F
        core0_api_ram_start_align (NOLOAD) : {
            . = ALIGN(osee_core0_api_ram_size_to_align);
            osee_core0_api_ram_start = .;
        } > DDR0_MCU_R5F
        .api_bss_cpu0 (NOLOAD) : ALIGN(8) {
            *(osee_core0_api_bss)
            *(*_core0_api_bss)
            . = ALIGN(8);
        } > DDR0_MCU_R5F
        .api_data_cpu0 : ALIGN(4) {
            *(osee_core0_api_data)
            *(*_core0_api_data)
        } > DDR0_MCU_R5F
        core0_api_ram_stop_align (NOLOAD) : {
            osee_core0_api_ram_stop = .;
            osee_core0_api_ram_log2ceil_size = ((osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 5) ? 5 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 6) ? 6 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 7) ? 7 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 8) ? 8 :(osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 9) ? 9 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 10) ? 10 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 11) ? 11 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 12) ? 12 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 13) ? 13 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 14) ? 14 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 15) ? 15 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 16) ? 16 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 17) ? 17 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 18) ? 18 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 19) ? 19 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 20) ? 20 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 21) ? 21 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 22) ? 22 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 23) ? 23 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 24) ? 24 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 25) ? 25 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 26) ? 26 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 27) ? 27 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 28) ? 28 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 29) ? 29 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 30) ? 30 : (osee_core0_api_ram_stop - osee_core0_api_ram_start) <= (1 << 31) ? 31 : -1);
            osee_core0_api_ram_size_to_align = 1 << osee_core0_api_ram_log2ceil_size;
            osee_core0_api_ram_end = .;
        } > DDR0_MCU_R5F
        os_stack_start_align (NOLOAD) : {
            . = ALIGN(osee_os_stack_size_to_align);
            osee_os_stack_start = .;
        } > DDR0_MCU_R5F
        . += 32;
        . = ALIGN(32);
        osee_OsApplication_DefaultEcucPartition_stack_start = .;
        .OsApplication_DefaultEcucPartition_stack : ALIGN(32) {
            *(osee_OsApplication_DefaultEcucPartition_stack)
            *(*_OsApplication_DefaultEcucPartition_stack)
        } > DDR0_MCU_R5F
        . = ALIGN(32);
        osee_OsApplication_DefaultEcucPartition_stack_end = .;
        . += 32;
        . = ALIGN(32);
        .cpu0.stack (NOLOAD): ALIGN(32) {
            osee_core0_stack_start = .;
            *(osee_core0_sys_stack)
            . = ALIGN(8);
            PROVIDE(osee_core0_sys_stack_top = .);
            . += Mode_SYS_Stack_Size;
            . = ALIGN(8);
            PROVIDE(osee_core0_sys_stack = .);
            PROVIDE(osee_core0_sys_stack_bottom = .);
            osEE_core0_svc_stack_top = .;
            . += Mode_SVC_Stack_Size;
            osEE_core0_svc_stack_bottom = .;
            . = ALIGN(8);
            PROVIDE(osee_core0_svc_stack = .);
            osEE_core0_irq_stack_top = .;
            . += Mode_IRQ_Stack_Size;
            osEE_core0_irq_stack_bottom = .;
            . = ALIGN(8);
            PROVIDE(osee_core0_irq_stack = .);
            osEE_core0_fiq_stack_top = .;
            . += Mode_FIQ_Stack_Size;
            osEE_core0_fiq_stack_bottom = .;
            . = ALIGN(8);
            PROVIDE(osee_core0_fiq_stack = .);
            osEE_core0_abt_stack_top = .;
            . += Mode_EXE_Stack_Size;
            osEE_core0_abt_stack_bottom = .;
            . = ALIGN(8);
            PROVIDE(osee_core0_abt_stack = .);
            osEE_core0_und_stack_top = .;
            osEE_core0_und_stack_bottom = .;
            . = ALIGN(8);
            PROVIDE(osee_core0_und_stack = .);
            osee_core0_stack_end = .;
        } > DDR0_MCU_R5F
        os_stack_stop_align (NOLOAD) : {
            osee_os_stack_stop = .;
            osee_os_stack_log2ceil_size = ((osee_os_stack_stop - osee_os_stack_start) <= (1 << 5) ? 5 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 6) ? 6 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 7) ? 7 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 8) ? 8 :(osee_os_stack_stop - osee_os_stack_start) <= (1 << 9) ? 9 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 10) ? 10 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 11) ? 11 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 12) ? 12 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 13) ? 13 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 14) ? 14 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 15) ? 15 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 16) ? 16 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 17) ? 17 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 18) ? 18 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 19) ? 19 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 20) ? 20 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 21) ? 21 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 22) ? 22 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 23) ? 23 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 24) ? 24 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 25) ? 25 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 26) ? 26 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 27) ? 27 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 28) ? 28 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 29) ? 29 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 30) ? 30 : (osee_os_stack_stop - osee_os_stack_start) <= (1 << 31) ? 31 : -1);
            osee_os_stack_size_to_align = 1 << osee_os_stack_log2ceil_size;
            osee_os_stack_end = .;
        } > DDR0_MCU_R5F
        /* .jcr : {
            *(.jcr)
        } > DDR0_MCU_R5F
        .got : {
            *(.got)
            *(.got.plt)
        } > DDR0_MCU_R5F
        .preinit_array : {
            KEEP (*(SORT(.preinit_array.*)))
            KEEP (*(.preinit_array))
        } > DDR0_MCU_R5F
        .init_array : {
            KEEP (*(SORT(.init_array.*)))
            KEEP (*(.init_array))
        } > DDR0_MCU_R5F
        .fini_array : {
            KEEP (*(SORT(.fini_array.*)))
            KEEP (*(.fini_array))
        } > DDR0_MCU_R5F
        .ARM.attributes : {
            *(.ARM.attributes)
        } > DDR0_MCU_R5F */
        /DISCARD/ : {
            *(.ARM.exidx*)
            *(.gnu.linkonce.armexidix.*.*)
    /*# ###*B*###
     * Erika Enterprise, version 3
     * Copyright (C) 2017-2019 Evidence s.r.l.
     * Copyright (C) 2019-  Huawei Technologies Co., Ltd. and its Affiliates
      # ###*E*###
     * \file  ee_cortex_r_boot.S
     * \brief Start-up code
     * \author VOS
     * \date    2019
    #include "ee_cfg.h"
    #include "ee_cortex_r_tcm.h"
    #include "ee_cortex_r_asm.h"
    #if (defined(OSEE_C_LIB))
        .global __libc_init_array
        .global __libc_fini_array
        .global exit
    #endif /* OSEE_C_LIB */
    /* Entry point for application  */
        .global main
                                       Utility Macros
    /* SCTLR Macros: */
      .equ  SCTLR_M_BIT,          0x00000001 /* MMU/MPU enable bit        */
      .equ  SCTLR_A_BIT,          0x00000002 /* Alignement Checking Bit   */
      .equ  SCTLR_C_BIT,          0x00000004 /* Data & Unified Cache Bit  */
      .equ  SCTLR_I_BIT,          0x00001000 /* Instruction Cache Bit     */
      .equ  SCTLR_BR_BIT,         (1 << 17)  /* MPU Background Region     */
                           Entry point for the Reset handler
         SECTION(.startup)
        .align 8
        .global osEE_cortex_r_C_init
        .global _reset
        ASM_FUNC_START(_reset)
    _reset:
                           reset sctrl and cpsr register
    /* Change CPSR.MODE to HYP */
        ldr   r0, .cpsr_int_value
        msr   CPSR_cxsf, r0
    /* Read SCTLR CP15 Control Register */
        mrc   p15, 0, r0, c1, c0, 0
    /* Disable MPU (M bit) & data cache (C bit) */
        bic   r0, r0, #SCTLR_M_BIT | SCTLR_C_BIT
    /* Disable instruction cache (I bit) [2 instructions needed, mask too big] */
        bic   r0, r0, #SCTLR_I_BIT
    /* Ensure all previous loads/stores have completed */
        dsb
    /* Write Back SCTLR CP15 Control Register */
        mcr   p15, 0, r0, c1, c0, 0
    /* Ensure subsequent instructionss execute wrt new MPU settings */
        isb
                   Cortex-R5 implementation-specific configuration
    /* SIZE field mask */
        mov   r1, #0x3C
    /* Read from FLASHIFREGIONR */
        mrc   p15, #0, r0, c15, c0, #1
    /* Extract SIZE and set flags */
        ands  r2, r0, r1
        beq L1
    /* Set enable bit if SIZE=!0x0 */
        orr r0, r0, #0x1
    /* Write r0 to FLASHIFREGIONR if SIZE=!0x0 */
        mcr p15, #0, r0, c15, c0, #1
    L1:
    /* Read from PERIPHPREGIONR */
        mrc   p15, #0, r0, c15, c0, #0
        ands  r2, r0, r1
        beq L2
        orr r0, r0, #0x1
    /* Write r0 to PERIPHPREGIONR if SIZE=!0x0 */
        mcr p15, #0, r0, c15, c0, #0
    L2:
    /* Init Stack Pointers */
    .start_sp_set:
        cps   #CPSR_MODE_SYS
        mrc   p15, 0, r0, c0, c0, 5
        mov   r1, #0xFFFF
        ands  r0, r0, r1
    #if (defined(OSEE_CORE0_VALID))
        mov   r1, #OSEE_CORE0_PHY_ID
        cmp   r0, r1
        beq   core0_sp_set
        b     .finish_core0_sp_set
    core0_sp_set:
        ldr   sp, =osee_core0_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core0_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core0_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core0_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core0_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core0_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core0_sp_set:
    #endif
    #if (defined(OSEE_CORE1_VALID))
        mov   r1, #OSEE_CORE1_PHY_ID
        cmp   r0, r1
        beq   core1_sp_set
        b     .finish_core1_sp_set
    core1_sp_set:
        ldr   sp, =osee_core1_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core1_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core1_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core1_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core1_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core1_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core1_sp_set:
    #endif
    #if (defined(OSEE_CORE2_VALID))
        mov   r1, #OSEE_CORE2_PHY_ID
        cmp   r0, r1
        beq   core2_sp_set
        b     .finish_core2_sp_set
    core2_sp_set:
        ldr   sp, =osee_core2_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core2_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core2_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core2_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core2_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core2_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core2_sp_set:
    #endif
    #if (defined(OSEE_CORE3_VALID))
        mov   r1, #OSEE_CORE3_PHY_ID
        cmp   r0, r1
        beq   core3_sp_set
        b     .finish_core3_sp_set
    core3_sp_set:
        ldr   sp, =osee_core3_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core3_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core3_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core3_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core3_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core3_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core3_sp_set:
    #endif
    #if (defined(OSEE_CORE4_VALID))
        mov   r1, #OSEE_CORE4_PHY_ID
        cmp   r0, r1
        beq   core4_sp_set
        b     .finish_core4_sp_set
    core4_sp_set:
        ldr   sp, =osee_core4_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core4_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core4_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core4_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core4_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core4_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core4_sp_set:
    #endif
    #if (defined(OSEE_CORE5_VALID))
        mov   r1, #OSEE_CORE5_PHY_ID
        cmp   r0, r1
        beq   core5_sp_set
        b     .finish_core5_sp_set
    core5_sp_set:
        ldr   sp, =osee_core5_sys_stack
        cps   #CPSR_MODE_UND
        ldr   sp, =osee_core5_und_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_ABT
        ldr   sp, =osee_core5_abt_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_FIQ
        ldr   sp, =osee_core5_fiq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_IRQ
        ldr   sp, =osee_core5_irq_stack
        cps   #CPSR_MODE_SYS
        cps   #CPSR_MODE_SVC
        ldr   sp, =osee_core5_svc_stack
        cps   #CPSR_MODE_SYS
        b     .finish_sp_set
    .finish_core5_sp_set:
    #endif
    .finish_sp_set:
                                     Cache invalidation.
        However Cortex-R52 provides CFG signals to invalidate cache automatically
        out of reset (CFGL1CACHEINVDISx)
    /* N.B. In Cortex-R52 You cannot invalidate all Datat Caches how
            it was possible in Cortex-R{4,5} */
    /* Complete all outstanding explicit memory operations */
        dsb
    /* Invalidate I-Cache (ICIALLU: Invalidate all Instruction Caches to PoU) */
        mov   r0, #0
        mcr   p15, #0, r0, c7, c5, #0
    /* Invalidate Data/Unified Caches */
    /* Read CLIDRCache Level ID Register */
        mrc   p15, #1, r0, c0, c0, #1
    /* Extract coherency level */
        ands  r3, r0, #0x07000000
    /* Total cache levels >> on the LSB (barrel shifter) */
        mov   r3, r3, LSR #23
    /* If 0, no need to clean */
        beq   .LCache_Data_Finished
    /* R10 holds current cache level */
        mov   r10, #0
    .LCache_Level_Loop:
    /* R2 holds cache "Set" position (barrel shifter) */
        add   r2, r10, r10, LSR #1
    /* Bottom 3 bits are the Cache-type for this level (barrel shifter) */
        mov   r1, r0, LSR r2
    /* Isolate those lower 3 bits */
        and   r1, r1, #7
        cmp   r1, #2
    /* No cache or only instruction cache at this level */
        blt   .LCache_Level_Skip
    /* Write the Cache Size selection register (CSSELR) +
       ISB to sync the change to the CacheSizeID reg */
        mcr   p15, #2, r10, c0, c0, #0
        isb
    /* Reads current Cache Size ID register (CCSIDR) */
        mrc   p15, #1, r1, c0, c0, #0
    /* Extract the line size field */
        and   r2, r1, #7
    /* Add 4 for the line size offset (log2 16 bytes) */
        add   r2, r2, #4
    /* R4 is the Associativity: max number on the way size (right aligned/LSB) */
        ldr   r4, .cache_mask_value1
        ands  r4, r4, r1, LSR #3
    /* R5 is the bit position of the way size increment */
        clz   r5, r4
    /* R7 is the max number of the index size (right aligned) */
        ldr   r7, .cache_mask_value2
        ands  r7, r7, r1, LSR #13
    .LCache_Ways_Loop:
    /* R9 working copy of the max way size (right aligned) */
        mov   r9, r4
    #if (defined(__THUMB__))
    .LCache_Set_Loop:
     /* Factor in the Way number and cache number into R11 */
        lsl   r12, r9, r5
        orr   r11, r10, r12
    /* Factor in the Set number */
        lsl   r12, r7, r2
        orr   r11, r11, r12
    #else
    .LCache_Set_Loop:
        orr   r11, r10, r9, LSL r5
        orr   r11, r11, r7, LSL r2
    #endif
    /* Invalidate by Set/Way (DCISW) */
        mcr   p15, #0, r11, c7, c6, #2
    /* Decrement the Way number */
        subs  r9, r9, #1
        bge   .LCache_Set_Loop
    /*  Decrement the Set number */
        subs  r7, r7, #1
        bge   .LCache_Ways_Loop
    .LCache_Level_Skip:
    /* Increment the cache level number, bits [3:1] so increment is 2 */
        add   r10, r10, #2
        cmp   r3, r10
        bgt   .LCache_Level_Loop
    .LCache_Data_Finished:
    #if (defined(OSEE_FPU_ENABLE))
                                        Enable VFP
     * Enable access to VFP by enabling access to Coprocessors 10 and 11.
     * Enables Full Access i.e. in both privileged and non privileged modes
    /* Read Coprocessor Access Control Register (CPACR) */
        mrc   p15, #0, r0, c1, c0, #2
    /* Enable access to CP 10 & 11 */
        orr   r0, r0, #(0xf << 20)
    /* Write Back Coprocessor Access Control Register (CPACR) */
        mcr   p15, #0, r0, c1, c0, #2
    /* Synchronize processor status */
        isb
    /* Enable FPU Access. FPEXC register, EN bit set */
        vmrs  r3, fpexc
        orr   r1, r3, #(1<<30)
        vmsr  fpexc, r1
    #endif /* OSEE_FPU_ENABLE */
                             Reset and start Cycle Counter
        mov   r0, #0x80000000         /* Clear overflow & Enable cycle counter MASK */
        mov   r1, #0xd                /* D, C, E */
    /* Clear Overflow */
        mcr   p15, #0, r0, c9, c12, #3
        mcr   p15, #0, r1, c9, c12, #0
    /* Enable Cycle Counter */
        mcr   p15, #0, r0, c9, c12, #1
        blx   osEE_cortex_r_fix_boot_mpu_setup
    /* Read System Control Register (SCTRL) */
    /* Prepare the MASK with VE, M & BR bits */
        ldr r1, .sctlr_mpu_setup
    /* Set the mask on previous SCTRL value*/
        orr r0, r0, r1
        dsb
    /* Write System Control Register */
    /* Ensure subsequent insts execute wrt new MPU settings */
        isb
    /* TCM init */
        blx   osEE_cortex_r_tcm_init
    /* Run C initialization */
        blx   osEE_cortex_r_C_init
                                      MPU Configuration
        blx   osEE_cortex_r_fix_mpu_setup
        ldr r1, =0x0
        mcr   p15, 0, r1, c6, c2, 0     /* Write RGNR to select region 0 */
        ldr r1, =0x1204                 /* Config background region with strongly-ordered */
        mcr   p15, 0, r1, c6, c1, 4     /* Write RACR0 */
                            Enable Cache
    /* Prepare the MASK with I, C bits */
        ldr r1, .sctlr_cache_setup
        orr r0, r0, r1
        dsb
        isb
                           Enable asynchronous aborts Exception
        mrs r0, cpsr
        bic r0, r0, #(1 << 8)
        msr CPSR_cxsf, r0
                                  libc initialization
    /* Run global constructors */
        blx   __libc_init_array
    /* Jump to main C code */
        blx   main
    /* Cleanup global constructors */
        blx   __libc_fini_array
    /* Libc exit */
        blx   exit
    #else
        blx   main
    .Lpanic:
        dsb         /* Clear all pending data accesses */
        wfi         /* Go to sleep */
        b   .Lpanic /* We should never get here */
        ASM_FUNC_END(_reset)
                                  init value
    #if (defined(OSEE_HIGH_VECTORS))
    .sctlr_mpu_setup    : .long (SCTRL_VE_BIT | SCTRL_V_BIT | SCTRL_BR_BIT | SCTRL_M_BIT)
    #else
    .sctlr_mpu_setup    : .long (SCTRL_VE_BIT | SCTRL_BR_BIT | SCTRL_M_BIT)
    #endif
    .sctlr_cache_setup  : .long (SCTRL_I_BIT | SCTRL_C_BIT)
    .cpsr_int_value     : .long 0x000001D3
    .cache_mask_value1: .long  0x3FF
    .cache_mask_value2: .long  0x7FFF
    Most of this code from the linker and the boot.S file looks like it is for the Cortex R core, R5F. But you are booting the Cortex A core, A72. Are you able to confirm that the code is compatible with the A72?
    We don't have support for A72 baremetal or RTOS loading like we do for the R5F. We used to have this support, you can see it as part of the RTOS SDK:
    /home/a0226667/sdk/ti-processor-sdk-rtos-j721e-evm-08_06_00_12/pdk_jacinto_08_06_00_31/packages/ti/csl/arch/a53
    Here you can find the startup files used in the past to initialize the A72 core during boot startup. Please see if that helps.
    But this is not supported anymore or used since the compiler migration from TI CGT to LLVM Clang compiler.
    Please support the following questions:
    1) Which compiler are you using?
    2) Are you referencing any particular SDK version?
    3) I see comments in the startup code that say " Cortex-R5 implementation-specific configuration", does this code work with your other A72 cores?
    Erick
  • Hi TI supporter,we find the problems the AUTOSAR intergrate the SCI lib in the project,but they don't insert the compiler C_FLAG in the makefile ,then we add C_FALG below:
     -DCONFIG_PM \
     -DCONFIG_PSC \
     -DCONFIG_CLOCK \
     -DCONFIG_CLK_ADPLLM \
     -DCONFIG_CLK_PLL_16FFT \
     -DCONFIG_CLK_PLL_DESKEW \
     -DCONFIG_CLK_PLL_16FFT_FRACF_CALIBRATION \
     -DCONFIG_PSC_PD_MAX_COUNT_64 \
     -DCONFIG_DM_BUILD \
     -DCONFIG_RM \
     -DCONFIG_RM_IRQ \
     -DCONFIG_INTERRUPT_AGGREGATOR_UNMAPPED_EVENTS \
     -DCONFIG_RM_RA \
     -DCONFIG_RM_RA_DMSS_RING \
     -DCONFIG_RM_RA_NAV_RING \
     -DCONFIG_RM_UDMAP \
     -DCONFIG_UDMAP_CHANNEL_BURST_SIZE \
     -DCONFIG_UDMAP_TX_CHANNEL_TEARDOWN_TYPE \
     -DCONFIG_UDMAP_UDMA \
     -DCONFIG_UDMAP_BCDMA \
     -DCONFIG_RM_PROXY \
     -DCONFIG_DEVICE_TYPE_GP\
     -DCONFIG_MSG_M4_ROM_USE_ALTERNATE_SPROXY
    then boot problems had solved.
