TDA4VM-Q1: A72 low probability did not generate an ETH1 node
Part Number: TDA4VM-Q1
I used the CPSW9G module PORT1, corresponding to the a72 ETH1 node. It works fine.
ifconfig :
But there is a low probability, about 100 times there may be 1-2 times,
A72 did not generate ETH1 node, the following is the error log.
mcu2_0:
j7-evm login: root
root@j7-evm:~# /opt/vx_app_arm_remote_log.out
[MCU2_0]      4.846724 s: CIO: Init ... Done !!!
[MCU2_0]      4.846792 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0]      4.846851 s: APP: Init ... !!!
[MCU2_0]      4.846890 s: SCICLIENT: Init ... !!!
[MCU2_0]      4.847424 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi]
[MCU2_0]      4.847496 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_0]      4.847546 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0]      4.847601 s: SCICLIENT: Init ... Done !!!
[MCU2_0]      4.847645 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0]      4.847965 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.848024 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0]      4.848321 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      4.848375 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=13 freq=121359600
[MCU2_0]      4.850087 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0]      4.850140 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=4 parent=7
[MCU2_0]      4.850396 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      4.850455 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=3
[MCU2_0]      4.850659 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      4.850879 s: ==================>> Status = 0 Parent = 7
[MCU2_0]      4.851226 s: ==================>> 1 Status = 0 Parent = 3
[MCU2_0]      4.851435 s: ===================>> 1 Status = 0 Freq = 121359600
[MCU2_0]      4.851493 s: UDMA: Init ... !!!
[MCU2_0]      4.854442 s: UDMA: Init ... Done !!!
[MCU2_0]      4.854513 s: MEM: Init ... !!!
[MCU2_0]      4.854570 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
[MCU2_0]      4.854685 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0]      4.854778 s: MEM: Init ... Done !!!
[MCU2_0]      4.854818 s: IPC: Init ... !!!
[MCU2_0]      4.854898 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0]      4.854962 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0]     15.494857 s: IPC: HLOS is ready !!!
[MCU2_0]     15.511597 s: IPC: Init ... Done !!!
[MCU2_0]     15.511673 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0]     15.845410 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0]     15.845661 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0]     15.847398 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0]     15.847476 s: ETHFW: Init ... !!!
[MCU2_0]     16.151469 s: Warning: Using 6 MAC address(es) from static pool
[MCU2_0]     16.151615 s: ETHFW: Shared multicasts (software fanout):
[MCU2_0]     16.151674 s:   01:00:5e:00:00:01
[MCU2_0]     16.151745 s:   01:00:5e:00:00:fb
[MCU2_0]     16.151812 s:   01:00:5e:00:00:fc
[MCU2_0]     16.151878 s:   33:33:00:00:00:01
[MCU2_0]     16.151945 s:   33:33:ff:1d:92:c2
[MCU2_0]     16.152012 s:   01:80:c2:00:00:00
[MCU2_0]     16.152079 s:   01:80:c2:00:00:03
[MCU2_0]     16.152146 s: ETHFW: Reserved multicasts:
[MCU2_0]     16.152187 s:   01:80:c2:00:00:0e
[MCU2_0]     16.152253 s:   01:1b:19:00:00:00
[MCU2_0]     16.152552 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0]     16.168792 s: PHY 0 is alive
[MCU2_0]     16.168898 s: PHY 4 is alive
[MCU2_0]     16.169368 s: EnetPhy_bindDriver: PHY 4: OUI:006037 Model:10 Ver:02 <-> 'tja1101' : OK
[MCU2_0]     16.171917 s:
[MCU2_0] ETHFW Version   : 0.02.00
[MCU2_0]     16.172005 s: ETHFW Build Date: Jun 28, 2023
[MCU2_0]     16.172057 s: ETHFW Build Time: 14:51:33
[MCU2_0]     16.172100 s: ETHFW Commit SHA: 4cadd160
[MCU2_0]     16.172186 s: ETHFW: Init ... DONE !!!
[MCU2_0]     16.172235 s: ETHFW: Remove server Init ... !!!
[MCU2_0]     16.172481 s: CpswProxyServer: Virtual port configuration:
[MCU2_0]     16.172559 s:   mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
[MCU2_0]     16.173372 s: CpswProxyServer: initialization completed (core: mcu2_0)
[MCU2_0]     16.173456 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0]     16.174619 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0]     16.175215 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
[MCU2_0]     16.175731 s: Assertion @ Line: 1346 in enet_mcm.c: msg.cmd == MCM_RESPONSE_CORE_ATTACH : failed !!!
kernel:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.120_MV-SOC-20230628-dirty (root@motovis) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Jun 28 15:22:05 CST 2023
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d6000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps_ipc_shared-memories@d6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100400, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ddr-update-rx-fifo-region-memories@fb100400, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb102400, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ddr-update-tx-fifo-region-memories@fb102400, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb200400, size 12 MiB
[    0.000000] OF: reserved mem: initialized node ddr_update_norflash_shm_region_memories@fb200400, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000fb0fffff]
[    0.000000]   node   0: [mem 0x00000000fb101000-0x00000000fb103fff]
[    0.000000]   node   0: [mem 0x00000000fb105000-0x00000000fb1fffff]
[    0.000000]   node   0: [mem 0x00000000fb201000-0x00000000fbdfffff]
[    0.000000]   node   0: [mem 0x00000000fbe01000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] On node 0 totalpages: 1048572
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524284 pages, LIFO batch:63
[    0.000000]   Normal zone: 8192 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:63
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Failed to reserve 400 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[    0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032188
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=8ee26e06-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 2225376K/4194288K available (10816K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 1968912K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a7030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008418] Console: colour dummy device 80x25
[    0.012991] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023661] pid_max: default: 32768 minimum: 301
[    0.028423] LSM: Security Framework initializing
[    0.033187] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040767] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049643] rcu: Hierarchical SRCU implementation.
[    0.054712] Platform MSI: msi-controller@1820000 domain created
[    0.060995] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070300] EFI services will not be available.
[    0.075046] smp: Bringing up secondary CPUs ...
[    0.088468] Detected PIPT I-cache on CPU1
[    0.088493] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088504] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[    0.088549] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088607] smp: Brought up 1 node, 2 CPUs
[    0.117954] SMP: Total of 2 processors activated.
[    0.122759] CPU features: detected: 32-bit EL0 Support
[    0.128013] CPU features: detected: CRC32 instructions
[    0.142146] CPU: All CPU(s) started at EL2
[    0.146345] alternatives: patching kernel code
[    0.151423] devtmpfs: initialized
[    0.160879] KASLR disabled due to lack of seed
[    0.165534] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.175499] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.182573] pinctrl core: initialized pinctrl subsystem
[    0.188160] DMI not present or invalid.
[    0.192389] NET: Registered protocol family 16
[    0.197225] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.204527] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.212528] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.220842] thermal_sys: Registered thermal governor 'step_wise'
[    0.220845] thermal_sys: Registered thermal governor 'power_allocator'
[    0.227433] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.241070] ASID allocator initialised with 65536 entries
[    0.260804] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.267664] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.274512] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.281358] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.288856] cryptd: max_cpu_qlen set to 1000
[    0.294985] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.303787] vsys_3v3: supplied by evm_12v0
[    0.308185] vsys_5v0: supplied by evm_12v0
[    0.312533] vdd_mmc1: supplied by vsys_3v3
[    0.317293] iommu: Default domain type: Translated
[    0.322461] SCSI subsystem initialized
[    0.326515] mc: Linux media interface: v0.10
[    0.330886] videodev: Linux video capture interface: v2.00
[    0.336516] pps_core: LinuxPPS API ver. 1 registered
[    0.341589] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.350928] PTP clock support registered
[    0.354948] EDAC MC: Ver: 3.0.0
[    0.358727] FPGA manager framework
[    0.362242] Advanced Linux Sound Architecture Driver Initialized.
[    0.368870] clocksource: Switched to clocksource arch_sys_counter
[    0.375222] VFS: Disk quotas dquot_6.6.0
[    0.379256] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.388964] Carveout Heap: Exported 480 MiB at 0x00000000b8000000
[    0.395269] NET: Registered protocol family 2
[    0.400058] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.408698] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.417455] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.425661] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.433523] TCP: Hash tables configured (established 32768 bind 32768)
[    0.440359] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.447253] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.454683] NET: Registered protocol family 1
[    0.459435] RPC: Registered named UNIX socket transport module.
[    0.465492] RPC: Registered udp transport module.
[    0.470309] RPC: Registered tcp transport module.
[    0.475114] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.481698] PCI: CLS 0 bytes, default 64
[    0.486113] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.496534] Initialise system trusted keyrings
[    0.501196] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.509439] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.515688] NFS: Registering the id_resolver key type
[    0.520905] Key type id_resolver registered
[    0.525177] Key type id_legacy registered
[    0.529301] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.536150] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.543812] 9p: Installing v9fs 9p2000 file system support
[    0.568994] Key type asymmetric registered
[    0.573181] Asymmetric key parser 'x509' registered
[    0.578181] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.585741] io scheduler mq-deadline registered
[    0.590366] io scheduler kyber registered
[    0.595861] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.602063] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.610444] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.616721] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.624531] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.632639] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.640781] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.647832] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.656796] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.669705] brd: module loaded
[    0.676629] loop: module loaded
[    0.680247] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[    0.688175] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.120_MV-SOC-20230628-dirty #1
[    0.696351] Hardware name: Texas Instruments K3 J721E SoC (DT)
[    0.702307] Call trace:
[    0.704813]  dump_backtrace+0x0/0x1a0
[    0.708549]  show_stack+0x18/0x68
[    0.711933]  dump_stack+0xd0/0x12c
[    0.715404]  sysfs_warn_dup+0x60/0x80
[    0.719139]  sysfs_create_dir_ns+0xe0/0xf8
[    0.723321]  kobject_add_internal+0x98/0x288
[    0.727677]  kobject_add+0x94/0x100
[    0.731237]  device_add+0xe0/0x740
[    0.734707]  platform_device_add+0x100/0x238
[    0.739064]  platform_device_register_full+0xcc/0x150
[    0.744224]  dma_buf_phys_init+0x6c/0x9c
[    0.748226]  do_one_initcall+0x54/0x1b8
[    0.752142]  kernel_init_freeable+0x220/0x2a0
[    0.756588]  kernel_init+0x14/0x114
[    0.760145]  ret_from_fork+0x10/0x34
[    0.763802] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[    0.777000] megasas: 07.714.04.00-rc1
[    0.782371] tun: Universal TUN/TAP device driver, 1.6
[    0.787791] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.794197] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.800272] sky2: driver version 1.30
[    0.804554] VFIO - User Level meta-driver version: 0.3
[    0.810306] i2c /dev entries driver
[    0.814496] sdhci: Secure Digital Host Controller Interface driver
[    0.820811] sdhci: Copyright(c) Pierre Ossman
[    0.825421] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.831678] ledtrig-cpu: registered to indicate activity on CPUs
[    0.838001] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.845210] optee: probing for conduit method.
[    0.849764] optee: revision 3.12 (7ca85124)
[    0.850023] optee: initialized driver
[    0.859367] NET: Registered protocol family 17
[    0.863994] 9pnet: Installing 9P2000 support
[    0.868401] Key type dns_resolver registered
[    0.872873] Loading compiled-in X.509 certificates
[    0.880261] pinctrl-single 11c000.pinctrl: Invalid number of rows: 0
[    0.886813] pinctrl-single 11c000.pinctrl: no pins entries for main-i2c2-pins-default
[    0.894822] omap_i2c: probe of 2020000.i2c failed with error -22
[    0.903091] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.909426] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.917675] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[    1.020902] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.029127] pca953x 0-0020: supply vcc not found, using dummy regulator
[    1.035969] pca953x 0-0020: using no AI
[    1.060917] pca953x 0-0020: failed writing register
[    1.065960] pca953x: probe of 0-0020 failed with error -121
[    1.071949] omap_i2c 2030000.i2c: bus 0 rev0.12 at 400 kHz
[    1.078289] omap_i2c 2040000.i2c: bus 1 rev0.12 at 100 kHz
[    1.084403] omap_i2c 2050000.i2c: bus 2 rev0.12 at 100 kHz
[    1.090985] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.101091] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.110069] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.120233] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.142698] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.152600] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.159359] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.168584] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.178739] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.185504] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.193570] printk: console [ttyS2] disabled
[    1.197967] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 18, base_baud = 3000000) is a 8250
[    1.206716] printk: console [ttyS2] enabled
[    1.215152] printk: bootconsole [ns16550a0] disabled
[    1.225853] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250
[    1.234938] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 20, base_baud = 3000000) is a 8250
[    1.244810] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.255323] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.265475] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.275712] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.287085] scsi host0: ufshcd
[    1.292468] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.336872] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.345176] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver Jlsemi
[    1.353236] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.367838] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.477742] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.483971] mmc0: CQHCI version 5.10
[    1.484819] mmc1: CQHCI version 5.10
[    1.500171] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.507243] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.514198] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.521202] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.528169] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.529311] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.539929] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.553384] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    1.565237] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.608878] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.617181] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver Jlsemi
[    1.625251] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.639418] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.646864] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.654103] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.660685] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.671698] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.682801] mmc0: Command Queue Engine enabled
[    1.687257] mmc0: new HS200 MMC card at address 0001
[    1.689273] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    1.692519] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.699534] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    1.704038] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    1.711167] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.717149] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    1.722538] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.728528] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    1.734656] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    1.748131] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    1.748161] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.755487] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    1.761725] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.768993] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    1.775420] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.783487] pinctrl-single 4301c000.pinctrl: Invalid number of rows: -2
[    1.789618] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.796173] pinctrl-single 4301c000.pinctrl: no pins entries for sw11-button-pins-default
[    1.802775] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.810919] gpio-keys: probe of gpio-keys failed with error -22
[    1.817263] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.827707] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.835893] cdns-ufshcd 4e84000.ufs: last intr at 1606568 us, last intr status=0x404
[    1.843629] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.851119] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.860160] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.860189]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    1.866158] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.876531] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.882641] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.888732] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    1.900909] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.907254] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.913616] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.919966] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.926311] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.932655] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.938998] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    1.945342] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    1.951684] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    1.958026] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    1.964373] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    1.969676] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    1.974979] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    1.980283] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    1.985587] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    1.990976] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    1.997145] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.002708] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1618300 us
[    2.009832] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.015568] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.021392] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.026954] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.032603] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    2.047693] ALSA device list:
[    2.050657]   No soundcards found.
[    2.543527] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.551652] Waiting for root device PARTUUID=8ee26e06-02...
[    2.589456] mmc1: new high speed SDHC card at address 59b4
[    2.595393] mmcblk1: mmc1:59b4 SN32G 29.7 GiB
[    2.601615]  mmcblk1: p1 p2
[    2.847446] EXT4-fs (mmcblk1p2): recovery complete
[    2.855181] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.863297] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.870562] devtmpfs: mounted
[    2.874471] Freeing unused kernel memory: 1792K
[    2.879110] Run /sbin/init as init process
[    2.883197]   with arguments:
[    2.883199]     /sbin/init
[    2.883201]   with environment:
[    2.883203]     HOME=/
[    2.883205]     TERM=linux
[    3.160226] systemd[1]: System time before build time, advancing clock.
[    3.234179] NET: Registered protocol family 10
[    3.239180] Segment Routing with IPv6
[    3.264553] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    3.286324] systemd[1]: Detected architecture arm64.
[    3.321584] systemd[1]: Set hostname to <j7-evm>.
[    3.517278] systemd[1]: /etc/systemd/system/boot_script.service:11: Support for option SysVStartPriority= has been removed and it is ignored
[    3.574100] random: systemd: uninitialized urandom read (16 bytes read)
[    3.580860] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.593188] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    3.602979] systemd[1]: Created slice system-getty.slice.
[    3.624959] random: systemd: uninitialized urandom read (16 bytes read)
[    3.632119] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.652949] random: systemd: uninitialized urandom read (16 bytes read)
[    3.660002] systemd[1]: Created slice User and Session Slice.
[    3.681103] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.705016] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.728985] systemd[1]: Reached target Paths.
[    3.744939] systemd[1]: Reached target Remote File Systems.
[    3.764922] systemd[1]: Reached target Slices.
[    3.780934] systemd[1]: Reached target Swap.
[    3.799308] systemd[1]: Listening on Process Core Dump Socket.
[    3.821096] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.857553] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    3.865997] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.889225] systemd[1]: Listening on Journal Socket.
[    3.905271] systemd[1]: Listening on Network Service Netlink Socket.
[    3.929186] systemd[1]: Listening on udev Control Socket.
[    3.949075] systemd[1]: Listening on udev Kernel Socket.
[    3.971456] systemd[1]: Mounting Huge Pages File System...
[    3.991368] systemd[1]: Mounting POSIX Message Queue File System...
[    4.015211] systemd[1]: Mounting Kernel Debug File System...
[    4.038552] systemd[1]: Mounting Temporary Directory (/tmp)...
[    4.055414] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    4.083195] systemd[1]: Starting Start psplash boot splash screen...
[    4.105135] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    4.117675] systemd[1]: Starting Journal Service...
[    4.145651] systemd[1]: Starting Load Kernel Modules...
[    4.159397] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.173719] cryptodev: loading out-of-tree module taints kernel.
[    4.184742] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    4.188239] cryptodev: driver 1.10 loaded.
[    4.191828] systemd[1]: Starting udev Coldplug all Devices...
[    4.219694] systemd[1]: Started Journal Service.
[    4.436310] systemd-journald[163]: Received client request to flush runtime journal.
[    4.577115] urandom_read_iter: 44 callbacks suppressed
[    4.577120] random: systemd: uninitialized urandom read (16 bytes read)
[    4.592750] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    4.603775] random: systemd: uninitialized urandom read (16 bytes read)
[    5.220710] CAN device driver interface
[    5.402677] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[    5.449031] PVR_K:  222: Read BVNC 22.104.208.318 from HW device registers
[    5.476157] PVR_K:  222: RGX Device registered with BVNC 22.104.208.318
[    5.485144] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    5.496546] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[    5.585788] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[    5.688777] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    5.705860] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[    5.730742] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[    5.760393] remoteproc remoteproc0: 4d80800000.dsp is available
[    5.820523] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    5.848454] urandom_read_iter: 53 callbacks suppressed
[    5.848459] random: systemd: uninitialized urandom read (16 bytes read)
[    5.870168] random: systemd: uninitialized urandom read (16 bytes read)
[    5.887105] random: systemd: uninitialized urandom read (16 bytes read)
[    5.934842] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    5.968284]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    6.152140] virtio_rpmsg_bus virtio0: rpmsg host is online
[    6.158011] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    6.223144]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    6.229841] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[    6.249555] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    6.350056] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    6.393588] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:1f] driver [Jlsemi] (irq=POLL)
[    6.408459] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    6.416989] remoteproc remoteproc1: 4d81800000.dsp is available
[    6.436687] remoteproc remoteproc1: attaching to 4d81800000.dsp
[    6.461744] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    6.475882] platform 5c00000.r5f: configured R5F for IPC-only mode
[    6.515774]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    6.537163] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    6.648887] random: crng init done
[    6.652287] random: 74 urandom warning(s) missed due to ratelimiting
[    6.658210] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.664985] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    6.707831] remoteproc remoteproc2: 5c00000.r5f is available
[    6.762685] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    6.798744]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    6.815444] remoteproc remoteproc2: attaching to 5c00000.r5f
[    6.838190] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    6.850772] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
[    6.859107] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    6.867875] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[    6.878102] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    6.891859]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    6.907553] virtio_rpmsg_bus virtio2: rpmsg host is online
[    6.913611] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    6.924052] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    6.924225] remoteproc remoteproc3: 64800000.dsp is available
[    6.931743] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    6.938690] remoteproc remoteproc3: attaching to 64800000.dsp
[    6.943850]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    6.949942] remoteproc remoteproc3: unsupported resource 65538
[    6.972025] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    6.989146] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
[    6.997090]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[    7.007163] platform 5d00000.r5f: configured R5F for IPC-only mode
[    7.013599] virtio_rpmsg_bus virtio3: rpmsg host is online
[    7.019143] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    7.024776] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.026347]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    7.037360] remoteproc remoteproc4: 5d00000.r5f is available
[    7.047767] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.086027] remoteproc remoteproc4: attaching to 5d00000.r5f
[    7.094312] usbcore: registered new interface driver usbfs
[    7.097272] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    7.099869] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
[    7.107132]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.124475] usbcore: registered new interface driver hub
[    7.124510] usbcore: registered new device driver usb
[    7.155779] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.159083] remoteproc remoteproc5: b034000.pru is available
[    7.167142] remoteproc remoteproc6: b004000.rtu is available
[    7.167357] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.167376] remoteproc remoteproc7: b00a000.txpru is available
[    7.167511] remoteproc remoteproc8: b038000.pru is available
[    7.167811] remoteproc remoteproc9: b006000.rtu is available
[    7.169876] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.171262] remoteproc remoteproc10: b00c000.txpru is available
[    7.172046] remoteproc remoteproc11: b134000.pru is available
[    7.179652] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.180580] remoteproc remoteproc12: b104000.rtu is available
[    7.182464] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.183453] remoteproc remoteproc13: b10a000.txpru is available
[    7.183951] remoteproc remoteproc14: b138000.pru is available
[    7.184494] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.189339] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.190639] remoteproc remoteproc15: b106000.rtu is available
[    7.191431] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.194820] remoteproc remoteproc16: b10c000.txpru is available
[    7.195455] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.241896] virtio_rpmsg_bus virtio4: rpmsg host is online
[    7.242514] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.243243]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    7.243250] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[    7.244457] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.257441] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    7.258227] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    7.258462] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    7.258596] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    7.258718] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    7.258841] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    7.259792] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    7.267188] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    7.267694] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    7.269051] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    7.270369] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.287026] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    7.451395] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.454866] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.457228] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.459863] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.462328] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.464466] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.467494] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[    7.585909] virtio_rpmsg_bus virtio2: creating channel ti.ethfw.notifyservice addr 0x1e
[    7.586309] virtio_rpmsg_bus virtio2: creating channel rpmsg-kdrv addr 0x1a
[    7.586978] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
[    7.586984] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 28/Jun/2023 SHA:4cadd160
[    7.914649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.920365] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    7.928448] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[    7.937885] xhci-hcd xhci-hcd.0.auto: irq 590, io mem 0x06010000
[    7.944066] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.952323] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.959537] usb usb1: Product: xHCI Host Controller
[    7.964423] usb usb1: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd
[    7.971898] usb usb1: SerialNumber: xhci-hcd.0.auto
[    7.977071] hub 1-0:1.0: USB hub found
[    7.980829] hub 1-0:1.0: 1 port detected
[    7.984943] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.990432] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    7.998089] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    8.004637] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    8.012766] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    8.021016] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.028223] usb usb2: Product: xHCI Host Controller
[    8.033090] usb usb2: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd
[    8.040555] usb usb2: SerialNumber: xhci-hcd.0.auto
[    8.045670] hub 2-0:1.0: USB hub found
[    8.049433] hub 2-0:1.0: 1 port detected
[    8.053623] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    8.059120] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    8.066868] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[    8.076282] xhci-hcd xhci-hcd.1.auto: irq 593, io mem 0x06410000
[    8.082455] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    8.090721] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.097930] usb usb3: Product: xHCI Host Controller
[    8.102797] usb usb3: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd
[    8.110262] usb usb3: SerialNumber: xhci-hcd.1.auto
[    8.115397] hub 3-0:1.0: USB hub found
[    8.119167] hub 3-0:1.0: 1 port detected
[    8.123254] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    8.128742] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    8.136397] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    8.142941] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    8.151075] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    8.159327] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.166534] usb usb4: Product: xHCI Host Controller
[    8.171401] usb usb4: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd
[    8.178872] usb usb4: SerialNumber: xhci-hcd.1.auto
[    8.184004] hub 4-0:1.0: USB hub found
[    8.187772] hub 4-0:1.0: 1 port detected
[   13.785311] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   13.840950] 8021q: 802.1Q VLAN Support v1.8
[   13.845205] 8021q: adding VLAN 0 to HW filter on device eth0
[   33.848890] vdd_mmc1: disabling
[   33.852033] tlv71033: disabling
[   37.903583] PVR_K:  576: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   37.930341] PVR_K:  576: Shader binary image 'rgx.sh.22.104.208.318' loaded
Thanks.
