I refer to this thread Linux/AM5728: PWM on Timer15, and after "echo 0 > export", I get "-sh: echo: write error: Device or resource busy".
I want to use TIMER_IO3 and GPIO0_43 to drive the pwm signal to make the buzzer sound.
How can I fix this error?
step 1:
I add following node to k3-am62x-sk-common.dtsi
/{ buzzer1: buzzer { status = "okay"; compatible = "pwm-beeper"; pwms = <&main_pwm3 0 322580 0>; // 3.1khz }; main_pwm3: dmtimer-main-pwm-3 { compatible = "ti,omap-dmtimer-pwm"; #pwm-cells = <3>; ti,timers = <&main_timer3>; }; }; &main_timer3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&buzzer_pwm_pins_default>; }; &main_pmx0 { buzzer_pwm_pins_default: buzzer-pwm-pins-default { pinctrl-single,pins = < AM62X_IOPAD(0x00b0, PIN_OUTPUT, 7) /* (K22) GPIO0_43*/ // Buzzer GPIO >; }; }; &cbass_main { status = "okay"; };
step 2:
dmesg | grep "pwm"
[ 1.027597] omap-dmtimer-pwm dmtimer-main-pwm-3: Please implement the .get_state() callback [ 1.286667] pwm-beeper buzzer: supply amp not found, using dummy regulator [ 1.293804] input: pwm-beeper as /devices/platform/buzzer/input/input0
step 3:
dmesg | grep "timer"
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.013110] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
step 4:
cat /sys/kernel/debug/pwm
platform/dmtimer-main-pwm-3, 1 PWM device
pwm-0 (buzzer ): requested period: 322581 ns duty: 0 ns polarity: normal
step 5:
cd /sys/class/pwm/
ls -al
total 0
drwxr-xr-x 2 root root 0 Feb 24 04:51 .
drwxr-xr-x 68 root root 0 Feb 24 04:51 ..
lrwxrwxrwx 1 root root 0 Feb 24 04:51 pwmchip0 -> ../../devices/platform/dmtimer-main-pwm-3/pwm/pwmchip0
step 6:
cd pwmchip0
ls -al
total 0
drwxr-xr-x 3 root root 0 Feb 24 04:51 .
drwxr-xr-x 3 root root 0 Feb 24 04:51 ..
lrwxrwxrwx 1 root root 0 Feb 24 04:52 device -> ../../../dmtimer-main-pwm-3
--w------- 1 root root 4096 Feb 24 04:52 export
-r--r--r-- 1 root root 4096 Feb 24 04:52 npwm
drwxr-xr-x 2 root root 0 Feb 24 04:52 power
lrwxrwxrwx 1 root root 0 Feb 24 04:51 subsystem -> ../../../../../class/pwm
-rw-r--r-- 1 root root 4096 Feb 24 04:51 uevent
--w------- 1 root root 4096 Feb 24 04:52 unexport
step 7:
echo 0 > export
Andrew
