Hello TI
When i run the run_app_single_cam.sh,An error occurred causing the program to terminate.
log and find the value of node->timeout_val in ownNodeKernelInit function -1.
Complete log has been uploaded. Please help analyze it
thanks!
Hello TI
thanks!
hi Qin,
What PHY parameters are you trying to set? Are you chaning/using some invalid parameters?
Brijesh
Hi Qin,
Setting PHY parameters should not fail, unless there is a change in the parameters. So can you please put a breakpoint on the API and see/compare the settings which are going inside the driver?
Also can you please tell me for which release it was working and for which one it started failing?
Brijesh
Hi Brijesh
The normal version is 07_03_00_29,but 08_06_01_03 and 09_00_00_02 versions started failing!!
MOst importantly,new versions porting ovx3c was working but porting 0x08b40 wasn't working .ox08b40 could ported in version of 07_03_00_29
Please help analyze
thanks!
Hi Qin,
SDK 07.03 is very old release, there are many changes from this version. So can you please check the SW interface changes in imaging layer and also in CSIRX and make corresponding changes?
Brijesh
Hi Brijesh
But, most importantly,new versions porting ovx3c was working but porting 0x08b40 wasn't working .ox08b40 could ported in version of 07_03_00_29
Hi Qin,
What is 0x08b40 ? Is it the new sensor that you are porting/enabling? Are the create parameter of the sensor properly setup in the IssSensor_CreateParams? Is the csi_laneBandSpeed member of this structure properly setup? It would be helpful if you can share this structure for this new sensor.
Brijesh
Cool, thanks for sharing. please close the ticket, if the question is answered.
