Part Number: PROCESSOR-SDK-AM62X
Hi SDK Champ
Can you please check if u-boot-tools via pip3 is still required since the following errors are shown when following SDK document?
Required Host Packages
Please run the following command to install all packages required to by the makefile targets.
host# sudo apt-get install build-essential autoconf automake bison flex libssl-dev bc u-boot-tools swig python3 python3-pip
Following pip packages are also needed for binman in u-boot targets
host# pip3 install jsonschema
host# pip3 install pyelftools
host# pip3 install u-boot-tools
jack@sitara:~/ti-processor-sdk-linux-am62xx-evm-09.00.00.03$ pip3 install u-boot-tools
Defaulting to user installation because normal site-packages is not writeable
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f4eeb3101c0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/u-boot-tools/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f4eeb3104f0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/u-boot-tools/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f4eeb3106a0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/u-boot-tools/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f4eeb310850>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/u-boot-tools/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f4eeb310a00>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/u-boot-tools/
ERROR: Could not find a version that satisfies the requirement u-boot-tools (from versions: none)
ERROR: No matching distribution found for u-boot-tools
Thanks.
Jack
