Part Number: AM625
After adding multillib to local.conf, there is no problem with the compilation system,
# Define multilib target require conf/multilib.conf MULTILIBS = "multilib:lib32" DEFAULTTUNE:virtclass-multilib-lib32 = "armv7athf-neon" # Specify 32-bit packages to be added IMAGE_INSTALL:append = " lib32-glibc lib32-libgcc lib32-libstdc++" # AM62x GPU drivers don't support 32-bit, remove for now MACHINE_FEATURES:remove = "gpu" # The kms++ packages are not compatible with multilib builds, remove for now RDEPENDS:packagegroup-arago-base:remove = "kms++ kms++-python"
$ MACHINE=am62xx-customer bitbake tisdk-customer-image
$ MACHINE=am62xx-customer bitbake meta-toolchain-arago-tisdk
but there is no 32-bit header file in the sysroot of the cross-compilation tool chain, error reported when compiling a 32bit program.
In file included from /home/user/cross_compile/sdk_multilib/sysroots/aarch64-oe-linux/usr/include/./features-time64.h:21:0,
from /home/user/cross_compile/sdk_multilib/sysroots/aarch64-oe-linux/usr/include/./features.h:392,
from /home/user/cross_compile/sdk_multilib/sysroots/aarch64-oe-linux/usr/include/./bits/libc-header-start.h:33,
from /home/user/cross_compile/sdk_multilib/sysroots/aarch64-oe-linux/usr/include/./stdlib.h:26,
from /home/user/APP/src/include/stdsys.h:20,
from config_parser/cfg_parser.c:15:
/home/user/cross_compile/sdk_multilib/sysroots/aarch64-oe-linux/usr/include/./bits/timesize.h:23:30: fatal error: bits/timesize-32.h: No such file or directory
compilation terminated.
<builtin>: recipe for target 'config_parser/cfg_parser.o' failed
make[1]: *** [config_parser/cfg_parser.o] Error 1
make[1]: Leaving directory '/home/user/2_m822e/app/svn_app_05_08/APP/src/lib'
Makefile:22: recipe for target 'all' failed
make: *** [all] Error 2
timesize-32.h is defined in timesize.h, but there is only timesize-64.h in the bits folder
/* * Copyright (C) 2005-2011 by Wind River Systems, Inc. * * SPDX-License-Identifier: MIT * */ #include <bits/wordsize.h> #if __WORDSIZE == 32 #ifdef _MIPS_SIM #if _MIPS_SIM == _ABIO32 #include <bits/timesize-32.h> #elif _MIPS_SIM == _ABIN32 #include <bits/timesize-n32.h> #else #error "Unknown _MIPS_SIM" #endif #else /* _MIPS_SIM is not defined */ #include <bits/timesize-32.h> #endif #elif __WORDSIZE == 64 #include <bits/timesize-64.h> #else #error "Unknown __WORDSIZE detected" #endif /* matches #if __WORDSIZE == 32 */
Even if this problem is solved, there will still be bits/long-double-32.h, gnu/stubs-32.h, bits/floatn-32.h and other similar problems. How to add the lib32 header file to the tool chain?
Regards,Stephen
