PROCESSOR-SDK-AM68A: TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
Part Number: PROCESSOR-SDK-AM68A
Other Parts Discussed in Thread: AM68A
I am running a segmentation model on TI-EVM for AM68A. The artifacts are successfully generated using edgeai-benchmark without any errors.
During the inference on TI board, I recieved this error,
 APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
14120.976291 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
14120.976366 s: VX_ZONE_INIT:Enabled
14120.976378 s: VX_ZONE_ERROR:Enabled
14120.976386 s: VX_ZONE_WARNING:Enabled
14120.977218 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
14120.978125 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
14121.132763 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1
14121.132797 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed.
14121.132824 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
14121.132835 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core
14121.132843 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
14121.132854 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
14121.132872 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
14121.132882 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
Can you guide me to solve this issue?
Ahmed
  • Hi Nikhil,
    Yes, the issue seems to be related but the solutions that are provided are already tried from my side.
    Another thing, I want to mention is that while I was generating artifacts, I received the warning shown below,
    NC running for device: 1
    Running with OTF buffer optimizations
    Segmentation fault (core dumped)
    Could not open /home/edgeai/code/edgeai-modelzoo/modelartifacts/AM68A/8bits/segmentation/artifacts/tempDir/output_tidl_net/perfSimInfo.bin
    WARNING: [TIDL_E_DATAFLOW_INFO_NULL] Network compiler returned with error or didn't executed, this model can only be used on PC/Host emulation mode, it is not expected to work on target/EVM.
    This warning does not hinder the artifacts generation, and the artifacts are successfully emulated on PC environment. However, when ported to TI-EVM, the inference throws the error.
    Ahmed
    Can you please confirm my understanding on this thread,
    1. You able to generate the model artifacts
    2. Host side inference is fine
    3. Target side inference is failing with above logs ?
    I suspect model compilation is not successful in this case.
    Can you share model compilation logs with debug flag set to 2.
    Also which flow you are using for model artifacts generation (TIDL-RT or OSRT), what sdk version you are using ?
    Yes, we are able to generate artifacts.
    Yes.
    While generating artifacts on PC, we got this warning,
    While inference on TI EVM, we got this error,
     APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
    Yes.
    target_device/SOC: AM68A
    Pass the appropriate commandline argument to use another target_device
    argv: ['./scripts/benchmark_modelzoo.py', 'settings_import_on_pc.yaml', '--target_device', 'AM68A']
    settings: {'include_files': None, 'pipeline_type': 'accuracy', 'num_frames': 1, 'calibration_frames': 1, 'calibration_iterations': 1, 'configs_path': './configs', 'models_path': './edgeai-modelzoo/models', 'modelartifacts_path': './edgeai-benchmark/work_dirs/modelartifacts/AM68A', 'datasets_path': './dependencies/datasets', 'target_device': 'AM68A', 'target_machine': 'pc', 'run_suffix': None, 'parallel_devices': 1, 'tensor_bits': 8, 'runtime_options': {'debug_level': 2}, 'run_import': True, 'run_inference': True, 'run_missing': True, 'detection_threshold': 0.3, 'detection_top_k': 200, 'detection_nms_threshold': None, 'detection_keep_top_k': None, 'save_output': True, 'num_output_frames': 50, 'model_selection': ['segmentation_unet'], 'model_shortlist': None, 'model_exclusion': None, 'task_selection': 'segmentation', 'runtime_selection': None, 'session_type_dict': {'onnx': 'onnxrt', 'tflite': 'tflitert', 'mxnet': 'tvmdlr'}, 'dataset_type_dict': {'ade20k': 'ade_20k'}, 'dataset_selection': 'ade20k32', 'dataset_loading': True, 'config_range': None, 'enable_logging': True, 'verbose': False, 'capture_log': False, 'experimental_models': False, 'rewrite_results': False, 'with_udp': False, 'flip_test': False, 'model_transformation_dict': None, 'report_perfsim': False, 'tidl_offload': True, 'input_optimization': None, 'run_dir_tree_depth': None, 'settings_file': 'settings_import_on_pc.yaml', 'basic_keys': ['include_files', 'pipeline_type', 'num_frames', 'calibration_frames', 'calibration_iterations', 'configs_path', 'models_path', 'modelartifacts_path', 'datasets_path', 'target_device', 'target_machine', 'run_suffix', 'parallel_devices', 'tensor_bits', 'runtime_options', 'run_import', 'run_inference', 'run_missing', 'detection_threshold', 'detection_top_k', 'detection_nms_threshold', 'detection_keep_top_k', 'save_output', 'num_output_frames', 'model_selection', 'model_shortlist', 'model_exclusion', 'task_selection', 'runtime_selection', 'session_type_dict', 'dataset_type_dict', 'dataset_selection', 'dataset_loading', 'config_range', 'enable_logging', 'verbose', 'capture_log', 'experimental_models', 'rewrite_results', 'with_udp', 'flip_test', 'model_transformation_dict', 'report_perfsim', 'tidl_offload', 'input_optimization', 'run_dir_tree_depth', 'settings_file'], 'dataset_cache': None}
    work_dir: ./edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits
    INFO:20231129-015533: dataset exists - will reuse - ./dependencies/datasets/ADEChallengeData2016
    download_ok: True
    configs to run: ['segmentation_dev_Unet_V1.1_onnx']
    number of configs: 1
    TASKS                                                       |   0%|          || 0/1 [00:00<?, ?it/s]
    TASKS                                                       |          |     0% 0/1| [< ]
    INFO:20231129-015533: starting process on parallel_device - 0
    INFO:20231129-015533: starting - segmentation_dev_Unet_V1.1_onnx
    INFO:20231129-015533: model_path - /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-modelzoo/models/vision/segmentation/ade20k32/edgeai-tv/segmentation_DV_Segmentation_dev_Unet_V1.1.onnx
    INFO:20231129-015533: model_file - /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/model/segmentation_DV_Segmentation_dev_Unet_V1.1.onnx
    INFO:20231129-015533: running - segmentation_dev_Unet_V1.1_onnx
    INFO:20231129-015533: pipeline_config - {'task_type': 'segmentation', 'dataset_category': 'ade20k32', 'calibration_dataset': <edgeai_benchmark.datasets.ade20k.ADE20KSegmentation object at 0x7f96a8ee82b0>, 'input_dataset': <edgeai_benchmark.datasets.ade20k.ADE20KSegmentation object at 0x7f96a8ee8908>, 'preprocess': <edgeai_benchmark.preprocess.PreProcessTransforms object at 0x7f96a8ee8c18>, 'session': <edgeai_benchmark.sessions.onnxrt_session.ONNXRTSession object at 0x7f97123c5048>, 'postprocess': <edgeai_benchmark.postprocess.PostProcessTransforms object at 0x7f97123c50b8>, 'model_info': {'metric_reference': {'accuracy_mean_iou%': 50.85}, 'model_shortlist': None}}
    INFO:20231129-015533: import  - segmentation_dev_Unet_V1.1_onnx - this may take some time...tidl_tools_path                                 = /home/edgeai/code/edgeai-benchmark_v8.6_mod/tools/AM68A/tidl_tools
    artifacts_folder                                = /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts
    tidl_tensor_bits                                = 8
    debug_level                                     = 2
    num_tidl_subgraphs                              = 16
    tidl_denylist                                   =
    tidl_denylist_layer_name                        =
    tidl_denylist_layer_type                         =
    tidl_allowlist_layer_name                        =
    model_type                                      =
    tidl_calibration_accuracy_level                 = 7
    tidl_calibration_options:num_frames_calibration = 1
    tidl_calibration_options:bias_calibration_iterations = 1
    mixed_precision_factor = -1.000000
    model_group_id = 0
    power_of_2_quantization                         = 2
    enable_high_resolution_optimization             = 0
    pre_batchnorm_fold                              = 1
    add_data_convert_ops                          = 3
    output_feature_16bit_names_list                 =
    m_params_16bit_names_list                       =
    reserved_compile_constraints_flag               = 1601
    ti_internal_reserved_1                          =
     ****** WARNING : Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options******
    Supported TIDL layer type ---            Cast --
    Supported TIDL layer type ---             Add --
    Supported TIDL layer type ---             Mul --
    Supported TIDL layer type ---            Conv -- /backbone/net/p1/p1.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p1/p1.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p1/p1.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p2/p2.1/res_m.0/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p2/p2.1/res_m.1/Add
    Supported TIDL layer type ---          Concat -- /backbone/net/p2/p2.1/Concat
    Supported TIDL layer type ---            Conv -- /backbone/net/p2/p2.1/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p2/p2.1/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p2/p2.1/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p3/p3.1/res_m.0/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p3/p3.1/res_m.1/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p3/p3.1/res_m.2/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p3/p3.1/res_m.3/Add
    Supported TIDL layer type ---          Concat -- /backbone/net/p3/p3.1/Concat
    Supported TIDL layer type ---            Conv -- /backbone/net/p3/p3.1/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p3/p3.1/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p3/p3.1/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p4/p4.1/res_m.0/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p4/p4.1/res_m.1/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p4/p4.1/res_m.2/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p4/p4.1/res_m.3/Add
    Supported TIDL layer type ---          Concat -- /backbone/net/p4/p4.1/Concat
    Supported TIDL layer type ---            Conv -- /backbone/net/p4/p4.1/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p4/p4.1/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p4/p4.1/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p5/p5.1/res_m.0/Add
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---             Add -- /backbone/net/p5/p5.1/res_m.1/Add
    Supported TIDL layer type ---          Concat -- /backbone/net/p5/p5.1/Concat
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.1/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.1/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.1/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.2/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.2/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.2/conv1/relu/Mul
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0/MaxPool
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1/MaxPool
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_1/MaxPool
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1_1/MaxPool
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_2/MaxPool
    Supported TIDL layer type ---         MaxPool -- /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1_2/MaxPool
    Supported TIDL layer type ---          Concat -- /backbone/net/p5/p5.2/Concat
    Supported TIDL layer type ---            Conv -- /backbone/net/p5/p5.2/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/net/p5/p5.2/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/net/p5/p5.2/conv2/relu/Mul
    Supported TIDL layer type ---          Resize -- /backbone/fpn/up/Resize
    Supported TIDL layer type ---          Concat -- /backbone/fpn/Concat
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/h1/Concat
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h1/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h1/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h1/conv3/relu/Mul
    Supported TIDL layer type ---          Resize -- /backbone/fpn/up_1/Resize
    Supported TIDL layer type ---          Concat -- /backbone/fpn/Concat_1
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/h2/Concat
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h2/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h2/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h2/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h3/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/Concat_2
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/h4/Concat
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h4/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h4/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h4/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h5/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h5/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h5/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/Concat_3
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/conv1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/conv1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/conv1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/conv2/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/conv2/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/conv2/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/res_m.0/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/res_m.0/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/res_m.0/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/res_m.0/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/res_m.0/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/res_m.0/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/res_m.1/res_m/res_m.0/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/res_m.1/res_m/res_m.0/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/res_m.1/res_m/res_m.0/relu/Mul
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/res_m.1/res_m/res_m.1/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/res_m.1/res_m/res_m.1/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/res_m.1/res_m/res_m.1/relu/Mul
    Supported TIDL layer type ---          Concat -- /backbone/fpn/h6/Concat
    Supported TIDL layer type ---            Conv -- /backbone/fpn/h6/conv3/conv/Conv
    Supported TIDL layer type ---         Sigmoid -- /backbone/fpn/h6/conv3/relu/Sigmoid
    Supported TIDL layer type ---             Mul -- /backbone/fpn/h6/conv3/relu/Mul
    Supported TIDL layer type ---            Conv -- /decoder/conv/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/conv/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/conv/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/conv/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/conv/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/conv/Add
    Supported TIDL layer type ---            Relu -- /decoder/conv/relu/Relu
    Supported TIDL layer type ---            Conv -- /decoder/conv1/Conv
    Supported TIDL layer type ---          Resize -- /decoder/upsample/Resize
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb1/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb1/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb1/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb1/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb1/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm2/ftb1/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb1/relu/Relu
    Supported TIDL layer type ---             Add -- /decoder/ffm2/Add
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb2/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb2/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb2/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb2/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm2/ftb2/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm2/ftb2/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm2/ftb2/relu/Relu
    Supported TIDL layer type ---          Resize -- /decoder/ffm2/upsample/Resize
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb1/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb1/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb1/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb1/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb1/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm1/ftb1/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb1/relu/Relu
    Supported TIDL layer type ---             Add -- /decoder/ffm1/Add
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb2/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb2/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb2/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb2/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm1/ftb2/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm1/ftb2/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm1/ftb2/relu/Relu
    Supported TIDL layer type ---          Resize -- /decoder/ffm1/upsample/Resize
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb1/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb1/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb1/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb1/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb1/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm0/ftb1/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb1/relu/Relu
    Supported TIDL layer type ---             Add -- /decoder/ffm0/Add
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb2/conv1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb2/conv_branch/conv_branch.0/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb2/conv_branch/conv_branch.1/Conv
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb2/conv_branch/conv_branch.3/Relu
    Supported TIDL layer type ---            Conv -- /decoder/ffm0/ftb2/conv_branch/conv_branch.4/Conv
    Supported TIDL layer type ---             Add -- /decoder/ffm0/ftb2/Add
    Supported TIDL layer type ---            Relu -- /decoder/ffm0/ftb2/relu/Relu
    Supported TIDL layer type ---          Resize -- /decoder/ffm0/upsample/Resize
    Supported TIDL layer type ---            Conv -- /decoder/outconv/conv/Conv
    Supported TIDL layer type ---          Resize -- /decoder/outconv/upsample/Resize
    Preliminary subgraphs created = 1
    Final number of subgraphs created are : 1, - Offloaded Nodes - 314, Total Nodes - 314
    INFORMATION -- [TIDL_ResizeLayer]  Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    Running runtimes graphviz - /home/edgeai/code/edgeai-benchmark_v8.6_mod/tools/AM68A/tidl_tools/tidl_graphVisualiser_runtimes.out /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts/allowedNode.txt /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts/tempDir/graphvizInfo.txt /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts/tempDir/runtimes_visualization.svg
    *** In TIDL_createStateImportFunc ***
    Compute on node : TIDLExecutionProvider_TIDL_0_0
      0,            Cast, 1, 1, inputNet_IN, TIDL_cast_in
      1,             Add, 2, 1, TIDL_cast_in, TIDL_Scale_In
      2,             Mul, 2, 1, TIDL_Scale_In, input
      3,            Conv, 3, 1, input, /backbone/net/p1/p1.0/conv/Conv_output_0
      4,         Sigmoid, 1, 1, /backbone/net/p1/p1.0/conv/Conv_output_0, /backbone/net/p1/p1.0/relu/Sigmoid_output_0
      5,             Mul, 2, 1, /backbone/net/p1/p1.0/conv/Conv_output_0, /backbone/net/p1/p1.0/relu/Mul_output_0
      6,            Conv, 3, 1, /backbone/net/p1/p1.0/relu/Mul_output_0, /backbone/net/p2/p2.0/conv/Conv_output_0
      7,         Sigmoid, 1, 1, /backbone/net/p2/p2.0/conv/Conv_output_0, /backbone/net/p2/p2.0/relu/Sigmoid_output_0
      8,             Mul, 2, 1, /backbone/net/p2/p2.0/conv/Conv_output_0, /backbone/net/p2/p2.0/relu/Mul_output_0
      9,            Conv, 3, 1, /backbone/net/p2/p2.0/relu/Mul_output_0, /backbone/net/p2/p2.1/conv1/conv/Conv_output_0
     10,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/conv1/conv/Conv_output_0, /backbone/net/p2/p2.1/conv1/relu/Sigmoid_output_0
     11,             Mul, 2, 1, /backbone/net/p2/p2.1/conv1/conv/Conv_output_0, /backbone/net/p2/p2.1/conv1/relu/Mul_output_0
     12,            Conv, 3, 1, /backbone/net/p2/p2.0/relu/Mul_output_0, /backbone/net/p2/p2.1/conv2/conv/Conv_output_0
     13,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/conv2/conv/Conv_output_0, /backbone/net/p2/p2.1/conv2/relu/Sigmoid_output_0
     14,             Mul, 2, 1, /backbone/net/p2/p2.1/conv2/conv/Conv_output_0, /backbone/net/p2/p2.1/conv2/relu/Mul_output_0
     15,            Conv, 3, 1, /backbone/net/p2/p2.1/conv2/relu/Mul_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/conv/Conv_output_0
     16,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
     17,             Mul, 2, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/relu/Mul_output_0
     18,            Conv, 3, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/conv/Conv_output_0
     19,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
     20,             Mul, 2, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/relu/Mul_output_0
     21,             Add, 2, 1, /backbone/net/p2/p2.1/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p2/p2.1/res_m.0/Add_output_0
     22,            Conv, 3, 1, /backbone/net/p2/p2.1/res_m.0/Add_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/conv/Conv_output_0
     23,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
     24,             Mul, 2, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/relu/Mul_output_0
     25,            Conv, 3, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/conv/Conv_output_0
     26,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
     27,             Mul, 2, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/relu/Mul_output_0
     28,             Add, 2, 1, /backbone/net/p2/p2.1/res_m.1/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p2/p2.1/res_m.1/Add_output_0
     29,          Concat, 4, 1, /backbone/net/p2/p2.1/conv1/relu/Mul_output_0, /backbone/net/p2/p2.1/Concat_output_0
     30,            Conv, 3, 1, /backbone/net/p2/p2.1/Concat_output_0, /backbone/net/p2/p2.1/conv3/conv/Conv_output_0
     31,         Sigmoid, 1, 1, /backbone/net/p2/p2.1/conv3/conv/Conv_output_0, /backbone/net/p2/p2.1/conv3/relu/Sigmoid_output_0
     32,             Mul, 2, 1, /backbone/net/p2/p2.1/conv3/conv/Conv_output_0, /backbone/net/p2/p2.1/conv3/relu/Mul_output_0
     33,            Conv, 3, 1, /backbone/net/p2/p2.1/conv3/relu/Mul_output_0, /backbone/net/p3/p3.0/conv/Conv_output_0
     34,         Sigmoid, 1, 1, /backbone/net/p3/p3.0/conv/Conv_output_0, /backbone/net/p3/p3.0/relu/Sigmoid_output_0
     35,             Mul, 2, 1, /backbone/net/p3/p3.0/conv/Conv_output_0, /backbone/net/p3/p3.0/relu/Mul_output_0
     36,            Conv, 3, 1, /backbone/net/p3/p3.0/relu/Mul_output_0, /backbone/net/p3/p3.1/conv1/conv/Conv_output_0
     37,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/conv1/conv/Conv_output_0, /backbone/net/p3/p3.1/conv1/relu/Sigmoid_output_0
     38,             Mul, 2, 1, /backbone/net/p3/p3.1/conv1/conv/Conv_output_0, /backbone/net/p3/p3.1/conv1/relu/Mul_output_0
     39,            Conv, 3, 1, /backbone/net/p3/p3.0/relu/Mul_output_0, /backbone/net/p3/p3.1/conv2/conv/Conv_output_0
     40,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/conv2/conv/Conv_output_0, /backbone/net/p3/p3.1/conv2/relu/Sigmoid_output_0
     41,             Mul, 2, 1, /backbone/net/p3/p3.1/conv2/conv/Conv_output_0, /backbone/net/p3/p3.1/conv2/relu/Mul_output_0
     42,            Conv, 3, 1, /backbone/net/p3/p3.1/conv2/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/conv/Conv_output_0
     43,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
     44,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/relu/Mul_output_0
     45,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/conv/Conv_output_0
     46,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
     47,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/relu/Mul_output_0
     48,             Add, 2, 1, /backbone/net/p3/p3.1/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.0/Add_output_0
     49,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.0/Add_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/conv/Conv_output_0
     50,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
     51,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/relu/Mul_output_0
     52,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/conv/Conv_output_0
     53,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
     54,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/relu/Mul_output_0
     55,             Add, 2, 1, /backbone/net/p3/p3.1/res_m.1/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.1/Add_output_0
     56,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.1/Add_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/conv/Conv_output_0
     57,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/relu/Sigmoid_output_0
     58,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/relu/Mul_output_0
     59,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/conv/Conv_output_0
     60,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/relu/Sigmoid_output_0
     61,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/relu/Mul_output_0
     62,             Add, 2, 1, /backbone/net/p3/p3.1/res_m.2/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.2/Add_output_0
     63,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.2/Add_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/conv/Conv_output_0
     64,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/relu/Sigmoid_output_0
     65,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/relu/Mul_output_0
     66,            Conv, 3, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/conv/Conv_output_0
     67,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/relu/Sigmoid_output_0
     68,             Mul, 2, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/relu/Mul_output_0
     69,             Add, 2, 1, /backbone/net/p3/p3.1/res_m.3/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p3/p3.1/res_m.3/Add_output_0
     70,          Concat, 6, 1, /backbone/net/p3/p3.1/conv1/relu/Mul_output_0, /backbone/net/p3/p3.1/Concat_output_0
     71,            Conv, 3, 1, /backbone/net/p3/p3.1/Concat_output_0, /backbone/net/p3/p3.1/conv3/conv/Conv_output_0
     72,         Sigmoid, 1, 1, /backbone/net/p3/p3.1/conv3/conv/Conv_output_0, /backbone/net/p3/p3.1/conv3/relu/Sigmoid_output_0
     73,             Mul, 2, 1, /backbone/net/p3/p3.1/conv3/conv/Conv_output_0, /backbone/net/p3/p3.1/conv3/relu/Mul_output_0
     74,            Conv, 3, 1, /backbone/net/p3/p3.1/conv3/relu/Mul_output_0, /backbone/net/p4/p4.0/conv/Conv_output_0
     75,         Sigmoid, 1, 1, /backbone/net/p4/p4.0/conv/Conv_output_0, /backbone/net/p4/p4.0/relu/Sigmoid_output_0
     76,             Mul, 2, 1, /backbone/net/p4/p4.0/conv/Conv_output_0, /backbone/net/p4/p4.0/relu/Mul_output_0
     77,            Conv, 3, 1, /backbone/net/p4/p4.0/relu/Mul_output_0, /backbone/net/p4/p4.1/conv1/conv/Conv_output_0
     78,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/conv1/conv/Conv_output_0, /backbone/net/p4/p4.1/conv1/relu/Sigmoid_output_0
     79,             Mul, 2, 1, /backbone/net/p4/p4.1/conv1/conv/Conv_output_0, /backbone/net/p4/p4.1/conv1/relu/Mul_output_0
     80,            Conv, 3, 1, /backbone/net/p4/p4.0/relu/Mul_output_0, /backbone/net/p4/p4.1/conv2/conv/Conv_output_0
     81,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/conv2/conv/Conv_output_0, /backbone/net/p4/p4.1/conv2/relu/Sigmoid_output_0
     82,             Mul, 2, 1, /backbone/net/p4/p4.1/conv2/conv/Conv_output_0, /backbone/net/p4/p4.1/conv2/relu/Mul_output_0
     83,            Conv, 3, 1, /backbone/net/p4/p4.1/conv2/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/conv/Conv_output_0
     84,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
     85,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/relu/Mul_output_0
     86,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/conv/Conv_output_0
     87,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
     88,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/relu/Mul_output_0
     89,             Add, 2, 1, /backbone/net/p4/p4.1/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.0/Add_output_0
     90,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.0/Add_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/conv/Conv_output_0
     91,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
     92,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/relu/Mul_output_0
     93,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/conv/Conv_output_0
     94,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
     95,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/relu/Mul_output_0
     96,             Add, 2, 1, /backbone/net/p4/p4.1/res_m.1/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.1/Add_output_0
     97,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.1/Add_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/conv/Conv_output_0
     98,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/relu/Sigmoid_output_0
     99,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/relu/Mul_output_0
    100,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/conv/Conv_output_0
    101,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/relu/Sigmoid_output_0
    102,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/relu/Mul_output_0
    103,             Add, 2, 1, /backbone/net/p4/p4.1/res_m.2/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.2/Add_output_0
    104,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.2/Add_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/conv/Conv_output_0
    105,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/relu/Sigmoid_output_0
    106,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/relu/Mul_output_0
    107,            Conv, 3, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/conv/Conv_output_0
    108,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/relu/Sigmoid_output_0
    109,             Mul, 2, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/relu/Mul_output_0
    110,             Add, 2, 1, /backbone/net/p4/p4.1/res_m.3/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p4/p4.1/res_m.3/Add_output_0
    111,          Concat, 6, 1, /backbone/net/p4/p4.1/conv1/relu/Mul_output_0, /backbone/net/p4/p4.1/Concat_output_0
    112,            Conv, 3, 1, /backbone/net/p4/p4.1/Concat_output_0, /backbone/net/p4/p4.1/conv3/conv/Conv_output_0
    113,         Sigmoid, 1, 1, /backbone/net/p4/p4.1/conv3/conv/Conv_output_0, /backbone/net/p4/p4.1/conv3/relu/Sigmoid_output_0
    114,             Mul, 2, 1, /backbone/net/p4/p4.1/conv3/conv/Conv_output_0, /backbone/net/p4/p4.1/conv3/relu/Mul_output_0
    115,            Conv, 3, 1, /backbone/net/p4/p4.1/conv3/relu/Mul_output_0, /backbone/net/p5/p5.0/conv/Conv_output_0
    116,         Sigmoid, 1, 1, /backbone/net/p5/p5.0/conv/Conv_output_0, /backbone/net/p5/p5.0/relu/Sigmoid_output_0
    117,             Mul, 2, 1, /backbone/net/p5/p5.0/conv/Conv_output_0, /backbone/net/p5/p5.0/relu/Mul_output_0
    118,            Conv, 3, 1, /backbone/net/p5/p5.0/relu/Mul_output_0, /backbone/net/p5/p5.1/conv1/conv/Conv_output_0
    119,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/conv1/conv/Conv_output_0, /backbone/net/p5/p5.1/conv1/relu/Sigmoid_output_0
    120,             Mul, 2, 1, /backbone/net/p5/p5.1/conv1/conv/Conv_output_0, /backbone/net/p5/p5.1/conv1/relu/Mul_output_0
    121,            Conv, 3, 1, /backbone/net/p5/p5.0/relu/Mul_output_0, /backbone/net/p5/p5.1/conv2/conv/Conv_output_0
    122,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/conv2/conv/Conv_output_0, /backbone/net/p5/p5.1/conv2/relu/Sigmoid_output_0
    123,             Mul, 2, 1, /backbone/net/p5/p5.1/conv2/conv/Conv_output_0, /backbone/net/p5/p5.1/conv2/relu/Mul_output_0
    124,            Conv, 3, 1, /backbone/net/p5/p5.1/conv2/relu/Mul_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/conv/Conv_output_0
    125,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
    126,             Mul, 2, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/relu/Mul_output_0
    127,            Conv, 3, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/conv/Conv_output_0
    128,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
    129,             Mul, 2, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/relu/Mul_output_0
    130,             Add, 2, 1, /backbone/net/p5/p5.1/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p5/p5.1/res_m.0/Add_output_0
    131,            Conv, 3, 1, /backbone/net/p5/p5.1/res_m.0/Add_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/conv/Conv_output_0
    132,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
    133,             Mul, 2, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/relu/Mul_output_0
    134,            Conv, 3, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/conv/Conv_output_0
    135,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
    136,             Mul, 2, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/relu/Mul_output_0
    137,             Add, 2, 1, /backbone/net/p5/p5.1/res_m.1/res_m/res_m.1/relu/Mul_output_0, /backbone/net/p5/p5.1/res_m.1/Add_output_0
    138,          Concat, 4, 1, /backbone/net/p5/p5.1/conv1/relu/Mul_output_0, /backbone/net/p5/p5.1/Concat_output_0
    139,            Conv, 3, 1, /backbone/net/p5/p5.1/Concat_output_0, /backbone/net/p5/p5.1/conv3/conv/Conv_output_0
    140,         Sigmoid, 1, 1, /backbone/net/p5/p5.1/conv3/conv/Conv_output_0, /backbone/net/p5/p5.1/conv3/relu/Sigmoid_output_0
    141,             Mul, 2, 1, /backbone/net/p5/p5.1/conv3/conv/Conv_output_0, /backbone/net/p5/p5.1/conv3/relu/Mul_output_0
    142,            Conv, 3, 1, /backbone/net/p5/p5.1/conv3/relu/Mul_output_0, /backbone/net/p5/p5.2/conv1/conv/Conv_output_0
    143,         Sigmoid, 1, 1, /backbone/net/p5/p5.2/conv1/conv/Conv_output_0, /backbone/net/p5/p5.2/conv1/relu/Sigmoid_output_0
    144,             Mul, 2, 1, /backbone/net/p5/p5.2/conv1/conv/Conv_output_0, /backbone/net/p5/p5.2/conv1/relu/Mul_output_0
    145,         MaxPool, 1, 1, /backbone/net/p5/p5.2/conv1/relu/Mul_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0/MaxPool_output_0
    146,         MaxPool, 1, 1, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0/MaxPool_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1/MaxPool_output_0
    147,         MaxPool, 1, 1, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1/MaxPool_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_1/MaxPool_output_0
    148,         MaxPool, 1, 1, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_1/MaxPool_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1_1/MaxPool_output_0
    149,         MaxPool, 1, 1, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1_1/MaxPool_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_2/MaxPool_output_0
    150,         MaxPool, 1, 1, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.0_2/MaxPool_output_0, /backbone/net/p5/p5.2/res_m_shared/res_m_shared.1_2/MaxPool_output_0
    151,          Concat, 4, 1, /backbone/net/p5/p5.2/conv1/relu/Mul_output_0, /backbone/net/p5/p5.2/Concat_output_0
    152,            Conv, 3, 1, /backbone/net/p5/p5.2/Concat_output_0, /backbone/net/p5/p5.2/conv2/conv/Conv_output_0
    153,         Sigmoid, 1, 1, /backbone/net/p5/p5.2/conv2/conv/Conv_output_0, /backbone/net/p5/p5.2/conv2/relu/Sigmoid_output_0
    154,             Mul, 2, 1, /backbone/net/p5/p5.2/conv2/conv/Conv_output_0, /backbone/net/p5/p5.2/conv2/relu/Mul_output_0
    155,          Resize, 3, 1, /backbone/net/p5/p5.2/conv2/relu/Mul_output_0, /backbone/fpn/up/Resize_output_0
    156,          Concat, 2, 1, /backbone/fpn/up/Resize_output_0, /backbone/fpn/Concat_output_0
    157,            Conv, 3, 1, /backbone/fpn/Concat_output_0, /backbone/fpn/h1/conv1/conv/Conv_output_0
    158,         Sigmoid, 1, 1, /backbone/fpn/h1/conv1/conv/Conv_output_0, /backbone/fpn/h1/conv1/relu/Sigmoid_output_0
    159,             Mul, 2, 1, /backbone/fpn/h1/conv1/conv/Conv_output_0, /backbone/fpn/h1/conv1/relu/Mul_output_0
    160,            Conv, 3, 1, /backbone/fpn/Concat_output_0, /backbone/fpn/h1/conv2/conv/Conv_output_0
    161,         Sigmoid, 1, 1, /backbone/fpn/h1/conv2/conv/Conv_output_0, /backbone/fpn/h1/conv2/relu/Sigmoid_output_0
    162,             Mul, 2, 1, /backbone/fpn/h1/conv2/conv/Conv_output_0, /backbone/fpn/h1/conv2/relu/Mul_output_0
    163,            Conv, 3, 1, /backbone/fpn/h1/conv2/relu/Mul_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.0/conv/Conv_output_0
    164,         Sigmoid, 1, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
    165,             Mul, 2, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.0/relu/Mul_output_0
    166,            Conv, 3, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.1/conv/Conv_output_0
    167,         Sigmoid, 1, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
    168,             Mul, 2, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h1/res_m.0/res_m/res_m.1/relu/Mul_output_0
    169,            Conv, 3, 1, /backbone/fpn/h1/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.0/conv/Conv_output_0
    170,         Sigmoid, 1, 1, /backbone/fpn/h1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
    171,             Mul, 2, 1, /backbone/fpn/h1/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.0/relu/Mul_output_0
    172,            Conv, 3, 1, /backbone/fpn/h1/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.1/conv/Conv_output_0
    173,         Sigmoid, 1, 1, /backbone/fpn/h1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
    174,             Mul, 2, 1, /backbone/fpn/h1/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h1/res_m.1/res_m/res_m.1/relu/Mul_output_0
    175,          Concat, 4, 1, /backbone/fpn/h1/conv1/relu/Mul_output_0, /backbone/fpn/h1/Concat_output_0
    176,            Conv, 3, 1, /backbone/fpn/h1/Concat_output_0, /backbone/fpn/h1/conv3/conv/Conv_output_0
    177,         Sigmoid, 1, 1, /backbone/fpn/h1/conv3/conv/Conv_output_0, /backbone/fpn/h1/conv3/relu/Sigmoid_output_0
    178,             Mul, 2, 1, /backbone/fpn/h1/conv3/conv/Conv_output_0, /backbone/fpn/h1/conv3/relu/Mul_output_0
    179,          Resize, 3, 1, /backbone/fpn/h1/conv3/relu/Mul_output_0, /backbone/fpn/up_1/Resize_output_0
    180,          Concat, 2, 1, /backbone/fpn/up_1/Resize_output_0, /backbone/fpn/Concat_1_output_0
    181,            Conv, 3, 1, /backbone/fpn/Concat_1_output_0, /backbone/fpn/h2/conv1/conv/Conv_output_0
    182,         Sigmoid, 1, 1, /backbone/fpn/h2/conv1/conv/Conv_output_0, /backbone/fpn/h2/conv1/relu/Sigmoid_output_0
    183,             Mul, 2, 1, /backbone/fpn/h2/conv1/conv/Conv_output_0, /backbone/fpn/h2/conv1/relu/Mul_output_0
    184,            Conv, 3, 1, /backbone/fpn/Concat_1_output_0, /backbone/fpn/h2/conv2/conv/Conv_output_0
    185,         Sigmoid, 1, 1, /backbone/fpn/h2/conv2/conv/Conv_output_0, /backbone/fpn/h2/conv2/relu/Sigmoid_output_0
    186,             Mul, 2, 1, /backbone/fpn/h2/conv2/conv/Conv_output_0, /backbone/fpn/h2/conv2/relu/Mul_output_0
    187,            Conv, 3, 1, /backbone/fpn/h2/conv2/relu/Mul_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.0/conv/Conv_output_0
    188,         Sigmoid, 1, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
    189,             Mul, 2, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.0/relu/Mul_output_0
    190,            Conv, 3, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.1/conv/Conv_output_0
    191,         Sigmoid, 1, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
    192,             Mul, 2, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h2/res_m.0/res_m/res_m.1/relu/Mul_output_0
    193,            Conv, 3, 1, /backbone/fpn/h2/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.0/conv/Conv_output_0
    194,         Sigmoid, 1, 1, /backbone/fpn/h2/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
    195,             Mul, 2, 1, /backbone/fpn/h2/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.0/relu/Mul_output_0
    196,            Conv, 3, 1, /backbone/fpn/h2/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.1/conv/Conv_output_0
    197,         Sigmoid, 1, 1, /backbone/fpn/h2/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
    198,             Mul, 2, 1, /backbone/fpn/h2/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h2/res_m.1/res_m/res_m.1/relu/Mul_output_0
    199,          Concat, 4, 1, /backbone/fpn/h2/conv1/relu/Mul_output_0, /backbone/fpn/h2/Concat_output_0
    200,            Conv, 3, 1, /backbone/fpn/h2/Concat_output_0, /backbone/fpn/h2/conv3/conv/Conv_output_0
    201,         Sigmoid, 1, 1, /backbone/fpn/h2/conv3/conv/Conv_output_0, /backbone/fpn/h2/conv3/relu/Sigmoid_output_0
    202,             Mul, 2, 1, /backbone/fpn/h2/conv3/conv/Conv_output_0, /backbone/fpn/h2/conv3/relu/Mul_output_0
    203,            Conv, 3, 1, /backbone/fpn/h2/conv3/relu/Mul_output_0, /backbone/fpn/h3/conv/Conv_output_0
    204,         Sigmoid, 1, 1, /backbone/fpn/h3/conv/Conv_output_0, /backbone/fpn/h3/relu/Sigmoid_output_0
    205,             Mul, 2, 1, /backbone/fpn/h3/conv/Conv_output_0, /backbone/fpn/h3/relu/Mul_output_0
    206,          Concat, 2, 1, /backbone/fpn/h3/relu/Mul_output_0, /backbone/fpn/Concat_2_output_0
    207,            Conv, 3, 1, /backbone/fpn/Concat_2_output_0, /backbone/fpn/h4/conv1/conv/Conv_output_0
    208,         Sigmoid, 1, 1, /backbone/fpn/h4/conv1/conv/Conv_output_0, /backbone/fpn/h4/conv1/relu/Sigmoid_output_0
    209,             Mul, 2, 1, /backbone/fpn/h4/conv1/conv/Conv_output_0, /backbone/fpn/h4/conv1/relu/Mul_output_0
    210,            Conv, 3, 1, /backbone/fpn/Concat_2_output_0, /backbone/fpn/h4/conv2/conv/Conv_output_0
    211,         Sigmoid, 1, 1, /backbone/fpn/h4/conv2/conv/Conv_output_0, /backbone/fpn/h4/conv2/relu/Sigmoid_output_0
    212,             Mul, 2, 1, /backbone/fpn/h4/conv2/conv/Conv_output_0, /backbone/fpn/h4/conv2/relu/Mul_output_0
    213,            Conv, 3, 1, /backbone/fpn/h4/conv2/relu/Mul_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.0/conv/Conv_output_0
    214,         Sigmoid, 1, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
    215,             Mul, 2, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.0/relu/Mul_output_0
    216,            Conv, 3, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.1/conv/Conv_output_0
    217,         Sigmoid, 1, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
    218,             Mul, 2, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h4/res_m.0/res_m/res_m.1/relu/Mul_output_0
    219,            Conv, 3, 1, /backbone/fpn/h4/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.0/conv/Conv_output_0
    220,         Sigmoid, 1, 1, /backbone/fpn/h4/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
    221,             Mul, 2, 1, /backbone/fpn/h4/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.0/relu/Mul_output_0
    222,            Conv, 3, 1, /backbone/fpn/h4/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.1/conv/Conv_output_0
    223,         Sigmoid, 1, 1, /backbone/fpn/h4/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
    224,             Mul, 2, 1, /backbone/fpn/h4/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h4/res_m.1/res_m/res_m.1/relu/Mul_output_0
    225,          Concat, 4, 1, /backbone/fpn/h4/conv1/relu/Mul_output_0, /backbone/fpn/h4/Concat_output_0
    226,            Conv, 3, 1, /backbone/fpn/h4/Concat_output_0, /backbone/fpn/h4/conv3/conv/Conv_output_0
    227,         Sigmoid, 1, 1, /backbone/fpn/h4/conv3/conv/Conv_output_0, /backbone/fpn/h4/conv3/relu/Sigmoid_output_0
    228,             Mul, 2, 1, /backbone/fpn/h4/conv3/conv/Conv_output_0, /backbone/fpn/h4/conv3/relu/Mul_output_0
    229,            Conv, 3, 1, /backbone/fpn/h4/conv3/relu/Mul_output_0, /backbone/fpn/h5/conv/Conv_output_0
    230,         Sigmoid, 1, 1, /backbone/fpn/h5/conv/Conv_output_0, /backbone/fpn/h5/relu/Sigmoid_output_0
    231,             Mul, 2, 1, /backbone/fpn/h5/conv/Conv_output_0, /backbone/fpn/h5/relu/Mul_output_0
    232,          Concat, 2, 1, /backbone/fpn/h5/relu/Mul_output_0, /backbone/fpn/Concat_3_output_0
    233,            Conv, 3, 1, /backbone/fpn/Concat_3_output_0, /backbone/fpn/h6/conv1/conv/Conv_output_0
    234,         Sigmoid, 1, 1, /backbone/fpn/h6/conv1/conv/Conv_output_0, /backbone/fpn/h6/conv1/relu/Sigmoid_output_0
    235,             Mul, 2, 1, /backbone/fpn/h6/conv1/conv/Conv_output_0, /backbone/fpn/h6/conv1/relu/Mul_output_0
    236,            Conv, 3, 1, /backbone/fpn/Concat_3_output_0, /backbone/fpn/h6/conv2/conv/Conv_output_0
    237,         Sigmoid, 1, 1, /backbone/fpn/h6/conv2/conv/Conv_output_0, /backbone/fpn/h6/conv2/relu/Sigmoid_output_0
    238,             Mul, 2, 1, /backbone/fpn/h6/conv2/conv/Conv_output_0, /backbone/fpn/h6/conv2/relu/Mul_output_0
    239,            Conv, 3, 1, /backbone/fpn/h6/conv2/relu/Mul_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.0/conv/Conv_output_0
    240,         Sigmoid, 1, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.0/relu/Sigmoid_output_0
    241,             Mul, 2, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.0/relu/Mul_output_0
    242,            Conv, 3, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.1/conv/Conv_output_0
    243,         Sigmoid, 1, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.1/relu/Sigmoid_output_0
    244,             Mul, 2, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h6/res_m.0/res_m/res_m.1/relu/Mul_output_0
    245,            Conv, 3, 1, /backbone/fpn/h6/res_m.0/res_m/res_m.1/relu/Mul_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.0/conv/Conv_output_0
    246,         Sigmoid, 1, 1, /backbone/fpn/h6/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.0/relu/Sigmoid_output_0
    247,             Mul, 2, 1, /backbone/fpn/h6/res_m.1/res_m/res_m.0/conv/Conv_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.0/relu/Mul_output_0
    248,            Conv, 3, 1, /backbone/fpn/h6/res_m.1/res_m/res_m.0/relu/Mul_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.1/conv/Conv_output_0
    249,         Sigmoid, 1, 1, /backbone/fpn/h6/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.1/relu/Sigmoid_output_0
    250,             Mul, 2, 1, /backbone/fpn/h6/res_m.1/res_m/res_m.1/conv/Conv_output_0, /backbone/fpn/h6/res_m.1/res_m/res_m.1/relu/Mul_output_0
    251,          Concat, 4, 1, /backbone/fpn/h6/conv1/relu/Mul_output_0, /backbone/fpn/h6/Concat_output_0
    252,            Conv, 3, 1, /backbone/fpn/h6/Concat_output_0, /backbone/fpn/h6/conv3/conv/Conv_output_0
    253,         Sigmoid, 1, 1, /backbone/fpn/h6/conv3/conv/Conv_output_0, /backbone/fpn/h6/conv3/relu/Sigmoid_output_0
    254,             Mul, 2, 1, /backbone/fpn/h6/conv3/conv/Conv_output_0, /backbone/fpn/h6/conv3/relu/Mul_output_0
    255,            Conv, 3, 1, /backbone/fpn/h6/conv3/relu/Mul_output_0, /decoder/conv/conv1/Conv_output_0
    256,            Relu, 1, 1, /decoder/conv/conv1/Conv_output_0, /decoder/conv/conv_branch/conv_branch.0/Relu_output_0
    257,            Conv, 3, 1, /decoder/conv/conv_branch/conv_branch.0/Relu_output_0, /decoder/conv/conv_branch/conv_branch.1/Conv_output_0
    258,            Relu, 1, 1, /decoder/conv/conv_branch/conv_branch.1/Conv_output_0, /decoder/conv/conv_branch/conv_branch.3/Relu_output_0
    259,            Conv, 3, 1, /decoder/conv/conv_branch/conv_branch.3/Relu_output_0, /decoder/conv/conv_branch/conv_branch.4/Conv_output_0
    260,             Add, 2, 1, /decoder/conv/conv_branch/conv_branch.0/Relu_output_0, /decoder/conv/Add_output_0
    261,            Relu, 1, 1, /decoder/conv/Add_output_0, /decoder/conv/relu/Relu_output_0
    262,            Conv, 3, 1, /decoder/conv/relu/Relu_output_0, /decoder/conv1/Conv_output_0
    263,          Resize, 3, 1, /decoder/conv1/Conv_output_0, /decoder/upsample/Resize_output_0
    264,            Conv, 3, 1, /backbone/fpn/h4/conv3/relu/Mul_output_0, /decoder/ffm2/ftb1/conv1/Conv_output_0
    265,            Relu, 1, 1, /decoder/ffm2/ftb1/conv1/Conv_output_0, /decoder/ffm2/ftb1/conv_branch/conv_branch.0/Relu_output_0
    266,            Conv, 3, 1, /decoder/ffm2/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm2/ftb1/conv_branch/conv_branch.1/Conv_output_0
    267,            Relu, 1, 1, /decoder/ffm2/ftb1/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm2/ftb1/conv_branch/conv_branch.3/Relu_output_0
    268,            Conv, 3, 1, /decoder/ffm2/ftb1/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm2/ftb1/conv_branch/conv_branch.4/Conv_output_0
    269,             Add, 2, 1, /decoder/ffm2/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm2/ftb1/Add_output_0
    270,            Relu, 1, 1, /decoder/ffm2/ftb1/Add_output_0, /decoder/ffm2/ftb1/relu/Relu_output_0
    271,             Add, 2, 1, /decoder/ffm2/ftb1/relu/Relu_output_0, /decoder/ffm2/Add_output_0
    272,            Conv, 3, 1, /decoder/ffm2/Add_output_0, /decoder/ffm2/ftb2/conv1/Conv_output_0
    273,            Relu, 1, 1, /decoder/ffm2/ftb2/conv1/Conv_output_0, /decoder/ffm2/ftb2/conv_branch/conv_branch.0/Relu_output_0
    274,            Conv, 3, 1, /decoder/ffm2/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm2/ftb2/conv_branch/conv_branch.1/Conv_output_0
    275,            Relu, 1, 1, /decoder/ffm2/ftb2/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm2/ftb2/conv_branch/conv_branch.3/Relu_output_0
    276,            Conv, 3, 1, /decoder/ffm2/ftb2/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm2/ftb2/conv_branch/conv_branch.4/Conv_output_0
    277,             Add, 2, 1, /decoder/ffm2/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm2/ftb2/Add_output_0
    278,            Relu, 1, 1, /decoder/ffm2/ftb2/Add_output_0, /decoder/ffm2/ftb2/relu/Relu_output_0
    279,          Resize, 3, 1, /decoder/ffm2/ftb2/relu/Relu_output_0, /decoder/ffm2/upsample/Resize_output_0
    280,            Conv, 3, 1, /backbone/fpn/h2/conv3/relu/Mul_output_0, /decoder/ffm1/ftb1/conv1/Conv_output_0
    281,            Relu, 1, 1, /decoder/ffm1/ftb1/conv1/Conv_output_0, /decoder/ffm1/ftb1/conv_branch/conv_branch.0/Relu_output_0
    282,            Conv, 3, 1, /decoder/ffm1/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm1/ftb1/conv_branch/conv_branch.1/Conv_output_0
    283,            Relu, 1, 1, /decoder/ffm1/ftb1/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm1/ftb1/conv_branch/conv_branch.3/Relu_output_0
    284,            Conv, 3, 1, /decoder/ffm1/ftb1/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm1/ftb1/conv_branch/conv_branch.4/Conv_output_0
    285,             Add, 2, 1, /decoder/ffm1/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm1/ftb1/Add_output_0
    286,            Relu, 1, 1, /decoder/ffm1/ftb1/Add_output_0, /decoder/ffm1/ftb1/relu/Relu_output_0
    287,             Add, 2, 1, /decoder/ffm1/ftb1/relu/Relu_output_0, /decoder/ffm1/Add_output_0
    288,            Conv, 3, 1, /decoder/ffm1/Add_output_0, /decoder/ffm1/ftb2/conv1/Conv_output_0
    289,            Relu, 1, 1, /decoder/ffm1/ftb2/conv1/Conv_output_0, /decoder/ffm1/ftb2/conv_branch/conv_branch.0/Relu_output_0
    290,            Conv, 3, 1, /decoder/ffm1/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm1/ftb2/conv_branch/conv_branch.1/Conv_output_0
    291,            Relu, 1, 1, /decoder/ffm1/ftb2/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm1/ftb2/conv_branch/conv_branch.3/Relu_output_0
    292,            Conv, 3, 1, /decoder/ffm1/ftb2/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm1/ftb2/conv_branch/conv_branch.4/Conv_output_0
    293,             Add, 2, 1, /decoder/ffm1/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm1/ftb2/Add_output_0
    294,            Relu, 1, 1, /decoder/ffm1/ftb2/Add_output_0, /decoder/ffm1/ftb2/relu/Relu_output_0
    295,          Resize, 3, 1, /decoder/ffm1/ftb2/relu/Relu_output_0, /decoder/ffm1/upsample/Resize_output_0
    296,            Conv, 3, 1, /backbone/net/p2/p2.1/conv3/relu/Mul_output_0, /decoder/ffm0/ftb1/conv1/Conv_output_0
    297,            Relu, 1, 1, /decoder/ffm0/ftb1/conv1/Conv_output_0, /decoder/ffm0/ftb1/conv_branch/conv_branch.0/Relu_output_0
    298,            Conv, 3, 1, /decoder/ffm0/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm0/ftb1/conv_branch/conv_branch.1/Conv_output_0
    299,            Relu, 1, 1, /decoder/ffm0/ftb1/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm0/ftb1/conv_branch/conv_branch.3/Relu_output_0
    300,            Conv, 3, 1, /decoder/ffm0/ftb1/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm0/ftb1/conv_branch/conv_branch.4/Conv_output_0
    301,             Add, 2, 1, /decoder/ffm0/ftb1/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm0/ftb1/Add_output_0
    302,            Relu, 1, 1, /decoder/ffm0/ftb1/Add_output_0, /decoder/ffm0/ftb1/relu/Relu_output_0
    303,             Add, 2, 1, /decoder/ffm0/ftb1/relu/Relu_output_0, /decoder/ffm0/Add_output_0
    304,            Conv, 3, 1, /decoder/ffm0/Add_output_0, /decoder/ffm0/ftb2/conv1/Conv_output_0
    305,            Relu, 1, 1, /decoder/ffm0/ftb2/conv1/Conv_output_0, /decoder/ffm0/ftb2/conv_branch/conv_branch.0/Relu_output_0
    306,            Conv, 3, 1, /decoder/ffm0/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm0/ftb2/conv_branch/conv_branch.1/Conv_output_0
    307,            Relu, 1, 1, /decoder/ffm0/ftb2/conv_branch/conv_branch.1/Conv_output_0, /decoder/ffm0/ftb2/conv_branch/conv_branch.3/Relu_output_0
    308,            Conv, 3, 1, /decoder/ffm0/ftb2/conv_branch/conv_branch.3/Relu_output_0, /decoder/ffm0/ftb2/conv_branch/conv_branch.4/Conv_output_0
    309,             Add, 2, 1, /decoder/ffm0/ftb2/conv_branch/conv_branch.0/Relu_output_0, /decoder/ffm0/ftb2/Add_output_0
    310,            Relu, 1, 1, /decoder/ffm0/ftb2/Add_output_0, /decoder/ffm0/ftb2/relu/Relu_output_0
    311,          Resize, 3, 1, /decoder/ffm0/ftb2/relu/Relu_output_0, /decoder/ffm0/upsample/Resize_output_0
    312,            Conv, 3, 1, /decoder/ffm0/upsample/Resize_output_0, /decoder/outconv/conv/Conv_output_0
    313,          Resize, 3, 1, /decoder/outconv/conv/Conv_output_0, output
    Input tensor name -  inputNet_IN
    Output tensor name - output
    In TIDL_onnxRtImportInit subgraph_name=output
    Layer 0, subgraph id output, name=output
    Layer 1, subgraph id output, name=inputNet_IN
    In TIDL_runtimesOptimizeNet: LayerIndex = 316, dataIndex = 315
     ************** Frame index 1 : Running float import *************
    In TIDL_runtimesPostProcessNet
    INFORMATION: [TIDL_ResizeLayer] /backbone/fpn/up/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /backbone/fpn/up_1/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm2/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm1/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm0/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/outconv/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    **          7 WARNINGS          0 ERRORS          **
    ************ in TIDL_subgraphRtCreate ************
     The soft limit is 2048
    The hard limit is 2048
    MEM: Init ... !!!
    MEM: Init ... Done !!!
     0.0s:  VX_ZONE_INIT:Enabled
     0.3s:  VX_ZONE_ERROR:Enabled
     0.4s:  VX_ZONE_WARNING:Enabled
     0.990s:  VX_ZONE_INIT:[tivxInit:184] Initialization Done !!!
    Alg Alloc for Layer # -    0
    Alg Alloc for Layer # -    1
    Alg Alloc for Layer # -    2
    Alg Alloc for Layer # -    3
    Alg Alloc for Layer # -    4
    Alg Alloc for Layer # -    5
    Alg Alloc for Layer # -    6
    Alg Alloc for Layer # -    7
    Alg Alloc for Layer # -    8
    Alg Alloc for Layer # -    9
    Alg Alloc for Layer # -   10
    Alg Alloc for Layer # -   11
    Alg Alloc for Layer # -   12
    Alg Alloc for Layer # -   13
    Alg Alloc for Layer # -   14
    Alg Alloc for Layer # -   15
    Alg Alloc for Layer # -   16
    Alg Alloc for Layer # -   17
    Alg Alloc for Layer # -   18
    Alg Alloc for Layer # -   19
    Alg Alloc for Layer # -   20
    Alg Alloc for Layer # -   21
    Alg Alloc for Layer # -   22
    Alg Alloc for Layer # -   23
    Alg Alloc for Layer # -   24
    Alg Alloc for Layer # -   25
    Alg Alloc for Layer # -   26
    Alg Alloc for Layer # -   27
    Alg Alloc for Layer # -   28
    Alg Alloc for Layer # -   29
    Alg Alloc for Layer # -   30
    Alg Alloc for Layer # -   31
    Alg Alloc for Layer # -   32
    Alg Alloc for Layer # -   33
    Alg Alloc for Layer # -   34
    Alg Alloc for Layer # -   35
    Alg Alloc for Layer # -   36
    Alg Alloc for Layer # -   37
    Alg Alloc for Layer # -   38
    Alg Alloc for Layer # -   39
    Alg Alloc for Layer # -   40
    Alg Alloc for Layer # -   41
    Alg Alloc for Layer # -   42
    Alg Alloc for Layer # -   43
    Alg Alloc for Layer # -   44
    Alg Alloc for Layer # -   45
    Alg Alloc for Layer # -   46
    Alg Alloc for Layer # -   47
    Alg Alloc for Layer # -   48
    Alg Alloc for Layer # -   49
    Alg Alloc for Layer # -   50
    Alg Alloc for Layer # -   51
    Alg Alloc for Layer # -   52
    Alg Alloc for Layer # -   53
    Alg Alloc for Layer # -   54
    Alg Alloc for Layer # -   55
    Alg Alloc for Layer # -   56
    Alg Alloc for Layer # -   57
    Alg Alloc for Layer # -   58
    Alg Alloc for Layer # -   59
    Alg Alloc for Layer # -   60
    Alg Alloc for Layer # -   61
    Alg Alloc for Layer # -   62
    Alg Alloc for Layer # -   63
    Alg Alloc for Layer # -   64
    Alg Alloc for Layer # -   65
    Alg Alloc for Layer # -   66
    Alg Alloc for Layer # -   67
    Alg Alloc for Layer # -   68
    Alg Alloc for Layer # -   69
    Alg Alloc for Layer # -   70
    Alg Alloc for Layer # -   71
    Alg Alloc for Layer # -   72
    Alg Alloc for Layer # -   73
    Alg Alloc for Layer # -   74
    Alg Alloc for Layer # -   75
    Alg Alloc for Layer # -   76
    Alg Alloc for Layer # -   77
    Alg Alloc for Layer # -   78
    Alg Alloc for Layer # -   79
    Alg Alloc for Layer # -   80
    Alg Alloc for Layer # -   81
    Alg Alloc for Layer # -   82
    Alg Alloc for Layer # -   83
    Alg Alloc for Layer # -   84
    Alg Alloc for Layer # -   85
    Alg Alloc for Layer # -   86
    Alg Alloc for Layer # -   87
    Alg Alloc for Layer # -   88
    Alg Alloc for Layer # -   89
    Alg Alloc for Layer # -   90
    Alg Alloc for Layer # -   91
    Alg Alloc for Layer # -   92
    Alg Alloc for Layer # -   93
    Alg Alloc for Layer # -   94
    Alg Alloc for Layer # -   95
    Alg Alloc for Layer # -   96
    Alg Alloc for Layer # -   97
    Alg Alloc for Layer # -   98
    Alg Alloc for Layer # -   99
    Alg Alloc for Layer # -  100
    Alg Alloc for Layer # -  101
    Alg Alloc for Layer # -  102
    Alg Alloc for Layer # -  103
    Alg Alloc for Layer # -  104
    Alg Alloc for Layer # -  105
    Alg Alloc for Layer # -  106
    Alg Alloc for Layer # -  107
    Alg Alloc for Layer # -  108
    Alg Alloc for Layer # -  109
    Alg Alloc for Layer # -  110
    Alg Alloc for Layer # -  111
    Alg Alloc for Layer # -  112
    Alg Alloc for Layer # -  113
    Alg Alloc for Layer # -  114
    Alg Alloc for Layer # -  115
    Alg Alloc for Layer # -  116
    Alg Alloc for Layer # -  117
    Alg Alloc for Layer # -  118
    Alg Alloc for Layer # -  119
    Alg Alloc for Layer # -  120
    Alg Alloc for Layer # -  121
    Alg Alloc for Layer # -  122
    Alg Alloc for Layer # -  123
    Alg Alloc for Layer # -  124
    Alg Alloc for Layer # -  125
    Alg Alloc for Layer # -  126
    Alg Alloc for Layer # -  127
    Alg Alloc for Layer # -  128
    Alg Alloc for Layer # -  129
    Alg Alloc for Layer # -  130
    Alg Alloc for Layer # -  131
    Alg Alloc for Layer # -  132
    Alg Alloc for Layer # -  133
    Alg Alloc for Layer # -  134
    Alg Alloc for Layer # -  135
    Alg Alloc for Layer # -  136
    Alg Alloc for Layer # -  137
    Alg Alloc for Layer # -  138
    Alg Alloc for Layer # -  139
    Alg Alloc for Layer # -  140
    Alg Alloc for Layer # -  141
    Alg Alloc for Layer # -  142
    Alg Alloc for Layer # -  143
    Alg Alloc for Layer # -  144
    Alg Alloc for Layer # -  145
    Alg Alloc for Layer # -  146
    Alg Alloc for Layer # -  147
    Alg Alloc for Layer # -  148
    Alg Alloc for Layer # -  149
    Alg Alloc for Layer # -  150
    Alg Alloc for Layer # -  151
    Alg Alloc for Layer # -  152
    Alg Alloc for Layer # -  153
    Alg Alloc for Layer # -  154
    Alg Alloc for Layer # -  155
    Alg Alloc for Layer # -  156
    Alg Alloc for Layer # -  157
    Alg Alloc for Layer # -  158
    Alg Alloc for Layer # -  159
    Alg Alloc for Layer # -  160
    Alg Alloc for Layer # -  161
    Alg Alloc for Layer # -  162
    Alg Alloc for Layer # -  163
    Alg Alloc for Layer # -  164
    Alg Alloc for Layer # -  165
    Alg Alloc for Layer # -  166
    Alg Alloc for Layer # -  167
    Alg Alloc for Layer # -  168
    Alg Alloc for Layer # -  169
    Alg Alloc for Layer # -  170
    Alg Alloc for Layer # -  171
    Alg Alloc for Layer # -  172
    Alg Alloc for Layer # -  173
    Alg Alloc for Layer # -  174
    Alg Alloc for Layer # -  175
    Alg Alloc for Layer # -  176
    Alg Alloc for Layer # -  177
    Alg Alloc for Layer # -  178
    Alg Alloc for Layer # -  179
    Alg Alloc for Layer # -  180
    Alg Alloc for Layer # -  181
    Alg Alloc for Layer # -  182
    Alg Alloc for Layer # -  183
    Alg Alloc for Layer # -  184
    Alg Alloc for Layer # -  185
    Alg Alloc for Layer # -  186
    Alg Alloc for Layer # -  187
    Alg Alloc for Layer # -  188
    Alg Alloc for Layer # -  189
    Alg Alloc for Layer # -  190
    Alg Alloc for Layer # -  191
    Alg Alloc for Layer # -  192
    Alg Alloc for Layer # -  193
    Alg Alloc for Layer # -  194
    Alg Alloc for Layer # -  195
    Alg Alloc for Layer # -  196
    Alg Alloc for Layer # -  197
    Alg Alloc for Layer # -  198
    Alg Alloc for Layer # -  199
    Alg Alloc for Layer # -  200
    Alg Alloc for Layer # -  201
    Alg Alloc for Layer # -  202
    Alg Alloc for Layer # -  203
    Alg Alloc for Layer # -  204
    Alg Alloc for Layer # -  205
    Alg Alloc for Layer # -  206
    Alg Alloc for Layer # -  207
    Alg Alloc for Layer # -  208
    Alg Alloc for Layer # -  209
    Alg Alloc for Layer # -  210
    Alg Alloc for Layer # -  211
    Alg Alloc for Layer # -  212
    Alg Alloc for Layer # -  213
    Alg Alloc for Layer # -  214
    Alg Alloc for Layer # -  215
    Alg Alloc for Layer # -  216
    Alg Alloc for Layer # -  217
    Alg Alloc for Layer # -  218
    Alg Alloc for Layer # -  219
    Alg Alloc for Layer # -  220
    Alg Alloc for Layer # -  221
    Alg Alloc for Layer # -  222
    Alg Alloc for Layer # -  223
    Alg Alloc for Layer # -  224
    Alg Alloc for Layer # -  225
    Alg Alloc for Layer # -  226
    Alg Alloc for Layer # -  227
    Alg Alloc for Layer # -  228
    Alg Alloc for Layer # -  229
    Alg Alloc for Layer # -  230
    Alg Alloc for Layer # -  231
    Alg Alloc for Layer # -  232
    Alg Alloc for Layer # -  233
    Alg Alloc for Layer # -  234
    Alg Alloc for Layer # -  235
    Alg Alloc for Layer # -  236
    Alg Alloc for Layer # -  237
    Alg Alloc for Layer # -  238
    Alg Alloc for Layer # -  239
    Alg Alloc for Layer # -  240
    Alg Alloc for Layer # -  241
    Alg Alloc for Layer # -  242
    Alg Alloc for Layer # -  243
    Alg Alloc for Layer # -  244
    Alg Alloc for Layer # -  245
    Alg Alloc for Layer # -  246
    Alg Alloc for Layer # -  247
    Alg Alloc for Layer # -  248
    Alg Alloc for Layer # -  249
    Alg Alloc for Layer # -  250
    Alg Alloc for Layer # -  251
    Alg Alloc for Layer # -  252
    Alg Alloc for Layer # -  253
    Alg Alloc for Layer # -  254
    Alg Alloc for Layer # -  255
    Alg Alloc for Layer # -  256
    Alg Alloc for Layer # -  257
    Alg Alloc for Layer # -  258
    Alg Alloc for Layer # -  259
    Alg Alloc for Layer # -  260
    Alg Alloc for Layer # -  261
    Alg Alloc for Layer # -  262
    Alg Alloc for Layer # -  263
    Alg Alloc for Layer # -  264
    Alg Alloc for Layer # -  265
    Alg Alloc for Layer # -  266
    Alg Alloc for Layer # -  267
    Alg Alloc for Layer # -  268
    Alg Alloc for Layer # -  269
    Alg Alloc for Layer # -  270
    Alg Alloc for Layer # -  271
    Alg Alloc for Layer # -  272
    Alg Alloc for Layer # -  273
    Alg Alloc for Layer # -  274
    Alg Alloc for Layer # -  275
    Alg Alloc for Layer # -  276
    Alg Alloc for Layer # -  277
    Alg Alloc for Layer # -  278
    Alg Alloc for Layer # -  279
    Alg Alloc for Layer # -  280
    Alg Alloc for Layer # -  281
    Alg Alloc for Layer # -  282
    Alg Alloc for Layer # -  283
    Alg Alloc for Layer # -  284
    Alg Alloc for Layer # -  285
    Alg Alloc for Layer # -  286
    Alg Alloc for Layer # -  287
    Alg Alloc for Layer # -  288
    Alg Alloc for Layer # -  289
    Alg Alloc for Layer # -  290
    Alg Alloc for Layer # -  291
    Alg Alloc for Layer # -  292
    Alg Alloc for Layer # -  293
    TIDL Memory size requiement (record wise):
    MemRecNum   , Space       , Attribute   , Size(KBytes)
    0           , DDR Cacheable, Persistent  , 14.84
    1           , DDR Cacheable, Persistent  , 0.14
    2           , DDR Cacheable, Scratch     , 16.00
    3           , DDR Cacheable, Scratch     , 4.00
    4           , DDR Cacheable, Scratch     , 56.00
    5           , DDR Cacheable, Persistent  , 624.29
    6           , DDR Cacheable, Scratch     , 258231.33
    7           , DDR Cacheable, Scratch     , 0.12
    8           , DDR Cacheable, Scratch     , 230400.12
    9           , DDR Cacheable, Scratch     , 230403.00
    10          , DDR Cacheable, Scratch     , 0.12
    11          , DDR Cacheable, Persistent  , 2865.12
    12          , DDR Cacheable, Scratch     , 512.25
    13          , DDR Cacheable, Persistent  , 0.12
    14          , DDR Cacheable, Persistent  , 102989.97
    Total memory size requirement (space wise):
    Mem Space , Size(KBytes)
    DDR Cacheable, 826117.44
    NOTE: Memory requirement in host emulation can be different from the same on EVM
          To get the actual TIDL memory requirement make sure to run on EVM with
          debugTraceLevel = 2
    Alg Init for Layer # -    0 out of  293
    Alg Init for Layer # -    1 out of  293
    Alg Init for Layer # -    2 out of  293
    Alg Init for Layer # -    3 out of  293
    Alg Init for Layer # -    4 out of  293
    Alg Init for Layer # -    5 out of  293
    Alg Init for Layer # -    6 out of  293
    Alg Init for Layer # -    7 out of  293
    Alg Init for Layer # -    8 out of  293
    Alg Init for Layer # -    9 out of  293
    Alg Init for Layer # -   10 out of  293
    Alg Init for Layer # -   11 out of  293
    Alg Init for Layer # -   12 out of  293
    Alg Init for Layer # -   13 out of  293
    Alg Init for Layer # -   14 out of  293
    Alg Init for Layer # -   15 out of  293
    Alg Init for Layer # -   16 out of  293
    Alg Init for Layer # -   17 out of  293
    Alg Init for Layer # -   18 out of  293
    Alg Init for Layer # -   19 out of  293
    Alg Init for Layer # -   20 out of  293
    Alg Init for Layer # -   21 out of  293
    Alg Init for Layer # -   22 out of  293
    Alg Init for Layer # -   23 out of  293
    Alg Init for Layer # -   24 out of  293
    Alg Init for Layer # -   25 out of  293
    Alg Init for Layer # -   26 out of  293
    Alg Init for Layer # -   27 out of  293
    Alg Init for Layer # -   28 out of  293
    Alg Init for Layer # -   29 out of  293
    Alg Init for Layer # -   30 out of  293
    Alg Init for Layer # -   31 out of  293
    Alg Init for Layer # -   32 out of  293
    Alg Init for Layer # -   33 out of  293
    Alg Init for Layer # -   34 out of  293
    Alg Init for Layer # -   35 out of  293
    Alg Init for Layer # -   36 out of  293
    Alg Init for Layer # -   37 out of  293
    Alg Init for Layer # -   38 out of  293
    Alg Init for Layer # -   39 out of  293
    Alg Init for Layer # -   40 out of  293
    Alg Init for Layer # -   41 out of  293
    Alg Init for Layer # -   42 out of  293
    Alg Init for Layer # -   43 out of  293
    Alg Init for Layer # -   44 out of  293
    Alg Init for Layer # -   45 out of  293
    Alg Init for Layer # -   46 out of  293
    Alg Init for Layer # -   47 out of  293
    Alg Init for Layer # -   48 out of  293
    Alg Init for Layer # -   49 out of  293
    Alg Init for Layer # -   50 out of  293
    Alg Init for Layer # -   51 out of  293
    Alg Init for Layer # -   52 out of  293
    Alg Init for Layer # -   53 out of  293
    Alg Init for Layer # -   54 out of  293
    Alg Init for Layer # -   55 out of  293
    Alg Init for Layer # -   56 out of  293
    Alg Init for Layer # -   57 out of  293
    Alg Init for Layer # -   58 out of  293
    Alg Init for Layer # -   59 out of  293
    Alg Init for Layer # -   60 out of  293
    Alg Init for Layer # -   61 out of  293
    Alg Init for Layer # -   62 out of  293
    Alg Init for Layer # -   63 out of  293
    Alg Init for Layer # -   64 out of  293
    Alg Init for Layer # -   65 out of  293
    Alg Init for Layer # -   66 out of  293
    Alg Init for Layer # -   67 out of  293
    Alg Init for Layer # -   68 out of  293
    Alg Init for Layer # -   69 out of  293
    Alg Init for Layer # -   70 out of  293
    Alg Init for Layer # -   71 out of  293
    Alg Init for Layer # -   72 out of  293
    Alg Init for Layer # -   73 out of  293
    Alg Init for Layer # -   74 out of  293
    Alg Init for Layer # -   75 out of  293
    Alg Init for Layer # -   76 out of  293
    Alg Init for Layer # -   77 out of  293
    Alg Init for Layer # -   78 out of  293
    Alg Init for Layer # -   79 out of  293
    Alg Init for Layer # -   80 out of  293
    Alg Init for Layer # -   81 out of  293
    Alg Init for Layer # -   82 out of  293
    Alg Init for Layer # -   83 out of  293
    Alg Init for Layer # -   84 out of  293
    Alg Init for Layer # -   85 out of  293
    Alg Init for Layer # -   86 out of  293
    Alg Init for Layer # -   87 out of  293
    Alg Init for Layer # -   88 out of  293
    Alg Init for Layer # -   89 out of  293
    Alg Init for Layer # -   90 out of  293
    Alg Init for Layer # -   91 out of  293
    Alg Init for Layer # -   92 out of  293
    Alg Init for Layer # -   93 out of  293
    Alg Init for Layer # -   94 out of  293
    Alg Init for Layer # -   95 out of  293
    Alg Init for Layer # -   96 out of  293
    Alg Init for Layer # -   97 out of  293
    Alg Init for Layer # -   98 out of  293
    Alg Init for Layer # -   99 out of  293
    Alg Init for Layer # -  100 out of  293
    Alg Init for Layer # -  101 out of  293
    Alg Init for Layer # -  102 out of  293
    Alg Init for Layer # -  103 out of  293
    Alg Init for Layer # -  104 out of  293
    Alg Init for Layer # -  105 out of  293
    Alg Init for Layer # -  106 out of  293
    Alg Init for Layer # -  107 out of  293
    Alg Init for Layer # -  108 out of  293
    Alg Init for Layer # -  109 out of  293
    Alg Init for Layer # -  110 out of  293
    Alg Init for Layer # -  111 out of  293
    Alg Init for Layer # -  112 out of  293
    Alg Init for Layer # -  113 out of  293
    Alg Init for Layer # -  114 out of  293
    Alg Init for Layer # -  115 out of  293
    Alg Init for Layer # -  116 out of  293
    Alg Init for Layer # -  117 out of  293
    Alg Init for Layer # -  118 out of  293
    Alg Init for Layer # -  119 out of  293
    Alg Init for Layer # -  120 out of  293
    Alg Init for Layer # -  121 out of  293
    Alg Init for Layer # -  122 out of  293
    Alg Init for Layer # -  123 out of  293
    Alg Init for Layer # -  124 out of  293
    Alg Init for Layer # -  125 out of  293
    Alg Init for Layer # -  126 out of  293
    Alg Init for Layer # -  127 out of  293
    Alg Init for Layer # -  128 out of  293
    Alg Init for Layer # -  129 out of  293
    Alg Init for Layer # -  130 out of  293
    Alg Init for Layer # -  131 out of  293
    Alg Init for Layer # -  132 out of  293
    Alg Init for Layer # -  133 out of  293
    Alg Init for Layer # -  134 out of  293
    Alg Init for Layer # -  135 out of  293
    Alg Init for Layer # -  136 out of  293
    Alg Init for Layer # -  137 out of  293
    Alg Init for Layer # -  138 out of  293
    Alg Init for Layer # -  139 out of  293
    Alg Init for Layer # -  140 out of  293
    Alg Init for Layer # -  141 out of  293
    Alg Init for Layer # -  142 out of  293
    Alg Init for Layer # -  143 out of  293
    Alg Init for Layer # -  144 out of  293
    Alg Init for Layer # -  145 out of  293
    Alg Init for Layer # -  146 out of  293
    Alg Init for Layer # -  147 out of  293
    Alg Init for Layer # -  148 out of  293
    Alg Init for Layer # -  149 out of  293
    Alg Init for Layer # -  150 out of  293
    Alg Init for Layer # -  151 out of  293
    Alg Init for Layer # -  152 out of  293
    Alg Init for Layer # -  153 out of  293
    Alg Init for Layer # -  154 out of  293
    Alg Init for Layer # -  155 out of  293
    Alg Init for Layer # -  156 out of  293
    Alg Init for Layer # -  157 out of  293
    Alg Init for Layer # -  158 out of  293
    Alg Init for Layer # -  159 out of  293
    Alg Init for Layer # -  160 out of  293
    Alg Init for Layer # -  161 out of  293
    Alg Init for Layer # -  162 out of  293
    Alg Init for Layer # -  163 out of  293
    Alg Init for Layer # -  164 out of  293
    Alg Init for Layer # -  165 out of  293
    Alg Init for Layer # -  166 out of  293
    Alg Init for Layer # -  167 out of  293
    Alg Init for Layer # -  168 out of  293
    Alg Init for Layer # -  169 out of  293
    Alg Init for Layer # -  170 out of  293
    Alg Init for Layer # -  171 out of  293
    Alg Init for Layer # -  172 out of  293
    Alg Init for Layer # -  173 out of  293
    Alg Init for Layer # -  174 out of  293
    Alg Init for Layer # -  175 out of  293
    Alg Init for Layer # -  176 out of  293
    Alg Init for Layer # -  177 out of  293
    Alg Init for Layer # -  178 out of  293
    Alg Init for Layer # -  179 out of  293
    Alg Init for Layer # -  180 out of  293
    Alg Init for Layer # -  181 out of  293
    Alg Init for Layer # -  182 out of  293
    Alg Init for Layer # -  183 out of  293
    Alg Init for Layer # -  184 out of  293
    Alg Init for Layer # -  185 out of  293
    Alg Init for Layer # -  186 out of  293
    Alg Init for Layer # -  187 out of  293
    Alg Init for Layer # -  188 out of  293
    Alg Init for Layer # -  189 out of  293
    Alg Init for Layer # -  190 out of  293
    Alg Init for Layer # -  191 out of  293
    Alg Init for Layer # -  192 out of  293
    Alg Init for Layer # -  193 out of  293
    Alg Init for Layer # -  194 out of  293
    Alg Init for Layer # -  195 out of  293
    Alg Init for Layer # -  196 out of  293
    Alg Init for Layer # -  197 out of  293
    Alg Init for Layer # -  198 out of  293
    Alg Init for Layer # -  199 out of  293
    Alg Init for Layer # -  200 out of  293
    Alg Init for Layer # -  201 out of  293
    Alg Init for Layer # -  202 out of  293
    Alg Init for Layer # -  203 out of  293
    Alg Init for Layer # -  204 out of  293
    Alg Init for Layer # -  205 out of  293
    Alg Init for Layer # -  206 out of  293
    Alg Init for Layer # -  207 out of  293
    Alg Init for Layer # -  208 out of  293
    Alg Init for Layer # -  209 out of  293
    Alg Init for Layer # -  210 out of  293
    Alg Init for Layer # -  211 out of  293
    Alg Init for Layer # -  212 out of  293
    Alg Init for Layer # -  213 out of  293
    Alg Init for Layer # -  214 out of  293
    Alg Init for Layer # -  215 out of  293
    Alg Init for Layer # -  216 out of  293
    Alg Init for Layer # -  217 out of  293
    Alg Init for Layer # -  218 out of  293
    Alg Init for Layer # -  219 out of  293
    Alg Init for Layer # -  220 out of  293
    Alg Init for Layer # -  221 out of  293
    Alg Init for Layer # -  222 out of  293
    Alg Init for Layer # -  223 out of  293
    Alg Init for Layer # -  224 out of  293
    Alg Init for Layer # -  225 out of  293
    Alg Init for Layer # -  226 out of  293
    Alg Init for Layer # -  227 out of  293
    Alg Init for Layer # -  228 out of  293
    Alg Init for Layer # -  229 out of  293
    Alg Init for Layer # -  230 out of  293
    Alg Init for Layer # -  231 out of  293
    Alg Init for Layer # -  232 out of  293
    Alg Init for Layer # -  233 out of  293
    Alg Init for Layer # -  234 out of  293
    Alg Init for Layer # -  235 out of  293
    Alg Init for Layer # -  236 out of  293
    Alg Init for Layer # -  237 out of  293
    Alg Init for Layer # -  238 out of  293
    Alg Init for Layer # -  239 out of  293
    Alg Init for Layer # -  240 out of  293
    Alg Init for Layer # -  241 out of  293
    Alg Init for Layer # -  242 out of  293
    Alg Init for Layer # -  243 out of  293
    Alg Init for Layer # -  244 out of  293
    Alg Init for Layer # -  245 out of  293
    Alg Init for Layer # -  246 out of  293
    Alg Init for Layer # -  247 out of  293
    Alg Init for Layer # -  248 out of  293
    Alg Init for Layer # -  249 out of  293
    Alg Init for Layer # -  250 out of  293
    Alg Init for Layer # -  251 out of  293
    Alg Init for Layer # -  252 out of  293
    Alg Init for Layer # -  253 out of  293
    Alg Init for Layer # -  254 out of  293
    Alg Init for Layer # -  255 out of  293
    Alg Init for Layer # -  256 out of  293
    Alg Init for Layer # -  257 out of  293
    Alg Init for Layer # -  258 out of  293
    Alg Init for Layer # -  259 out of  293
    Alg Init for Layer # -  260 out of  293
    Alg Init for Layer # -  261 out of  293
    Alg Init for Layer # -  262 out of  293
    Alg Init for Layer # -  263 out of  293
    Alg Init for Layer # -  264 out of  293
    Alg Init for Layer # -  265 out of  293
    Alg Init for Layer # -  266 out of  293
    Alg Init for Layer # -  267 out of  293
    Alg Init for Layer # -  268 out of  293
    Alg Init for Layer # -  269 out of  293
    Alg Init for Layer # -  270 out of  293
    Alg Init for Layer # -  271 out of  293
    Alg Init for Layer # -  272 out of  293
    Alg Init for Layer # -  273 out of  293
    Alg Init for Layer # -  274 out of  293
    Alg Init for Layer # -  275 out of  293
    Alg Init for Layer # -  276 out of  293
    Alg Init for Layer # -  277 out of  293
    Alg Init for Layer # -  278 out of  293
    Alg Init for Layer # -  279 out of  293
    Alg Init for Layer # -  280 out of  293
    Alg Init for Layer # -  281 out of  293
    Alg Init for Layer # -  282 out of  293
    Alg Init for Layer # -  283 out of  293
    Alg Init for Layer # -  284 out of  293
    Alg Init for Layer # -  285 out of  293
    Alg Init for Layer # -  286 out of  293
    Alg Init for Layer # -  287 out of  293
    Alg Init for Layer # -  288 out of  293
    Alg Init for Layer # -  289 out of  293
    Alg Init for Layer # -  290 out of  293
    Alg Init for Layer # -  291 out of  293
    Alg Init for Layer # -  292 out of  293
    Alg Init for Layer # -  293 out of  293
    PREEMPTION: Adding a new priority object for targetPriority = 1, handle = 0x7f9767c72000
    PREEMPTION: Now total number of priority objects = 1 at priorityId = 1,    with new memRec of base = 0x7f9754478000 and size = 128
    PREEMPTION: Requesting context memory addr for handle 0x7f9767c72000, return Addr = 0x7f9754478000
    ************ TIDL_subgraphRtCreate done ************
     *******   In TIDL_subgraphRtInvoke  ********
    TIDL_activate is called with handle : 67c72000
    Starting Layer # -    1
    Processing Layer # -    1
    End of Layer # -    1 with outPtrs[0] = 0x7f962df3e000
    Starting Layer # -    2
    Processing Layer # -    2
    End of Layer # -    2 with outPtrs[0] = 0x7f962e2c9100
    Starting Layer # -    3
    Processing Layer # -    3
    End of Layer # -    3 with outPtrs[0] = 0x7f962f0d9100
    Starting Layer # -    4
    Processing Layer # -    4
    End of Layer # -    4 with outPtrs[0] = 0x7f962fee9100
    Starting Layer # -    5
    Processing Layer # -    5
    End of Layer # -    5 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -    6
    Processing Layer # -    6
    End of Layer # -    6 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -    7
    Processing Layer # -    7
    End of Layer # -    7 with outPtrs[0] = 0x7f9631b41780
    Starting Layer # -    8
    Processing Layer # -    8
    End of Layer # -    8 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -    9
    Processing Layer # -    9
    End of Layer # -    9 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   10
    Processing Layer # -   10
    End of Layer # -   10 with outPtrs[0] = 0x7f9632249780
    Starting Layer # -   11
    Processing Layer # -   11
    End of Layer # -   11 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   12
    Processing Layer # -   12
    End of Layer # -   12 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   13
    Processing Layer # -   13
    End of Layer # -   13 with outPtrs[0] = 0x7f96325cd780
    Starting Layer # -   14
    Processing Layer # -   14
    End of Layer # -   14 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   15
    Processing Layer # -   15
    End of Layer # -   15 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   16
    Processing Layer # -   16
    End of Layer # -   16 with outPtrs[0] = 0x7f963296dc00
    Starting Layer # -   17
    Processing Layer # -   17
    End of Layer # -   17 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   18
    Processing Layer # -   18
    End of Layer # -   18 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   19
    Processing Layer # -   19
    End of Layer # -   19 with outPtrs[0] = 0x7f9631b41780
    Starting Layer # -   20
    Processing Layer # -   20
    End of Layer # -   20 with outPtrs[0] = 0x7f963296dc00
    Starting Layer # -   21
    Processing Layer # -   21
    End of Layer # -   21 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   22
    Processing Layer # -   22
    End of Layer # -   22 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   23
    Processing Layer # -   23
    End of Layer # -   23 with outPtrs[0] = 0x7f9632d0e080
    Starting Layer # -   24
    Processing Layer # -   24
    End of Layer # -   24 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   25
    Processing Layer # -   25
    End of Layer # -   25 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   26
    Processing Layer # -   26
    End of Layer # -   26 with outPtrs[0] = 0x7f9631b41780
    Starting Layer # -   27
    Processing Layer # -   27
    End of Layer # -   27 with outPtrs[0] = 0x7f96330ae500
    Starting Layer # -   28
    Processing Layer # -   28
    End of Layer # -   28 with outPtrs[0] = 0x7f9633432500
    Starting Layer # -   29
    Processing Layer # -   29
    End of Layer # -   29 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -   30
    Processing Layer # -   30
    End of Layer # -   30 with outPtrs[0] = 0x7f9631439780
    Starting Layer # -   31
    Processing Layer # -   31
    End of Layer # -   31 with outPtrs[0] = 0x7f9634242500
    Starting Layer # -   32
    Processing Layer # -   32
    End of Layer # -   32 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   33
    Processing Layer # -   33
    End of Layer # -   33 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   34
    Processing Layer # -   34
    End of Layer # -   34 with outPtrs[0] = 0x7f963508ad80
    Starting Layer # -   35
    Processing Layer # -   35
    End of Layer # -   35 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   36
    Processing Layer # -   36
    End of Layer # -   36 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   37
    Processing Layer # -   37
    End of Layer # -   37 with outPtrs[0] = 0x7f963540ed80
    Starting Layer # -   38
    Processing Layer # -   38
    End of Layer # -   38 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   39
    Processing Layer # -   39
    End of Layer # -   39 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   40
    Processing Layer # -   40
    End of Layer # -   40 with outPtrs[0] = 0x7f96355d0d80
    Starting Layer # -   41
    Processing Layer # -   41
    End of Layer # -   41 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   42
    Processing Layer # -   42
    End of Layer # -   42 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   43
    Processing Layer # -   43
    End of Layer # -   43 with outPtrs[0] = 0x7f96357af400
    Starting Layer # -   44
    Processing Layer # -   44
    End of Layer # -   44 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   45
    Processing Layer # -   45
    End of Layer # -   45 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   46
    Processing Layer # -   46
    End of Layer # -   46 with outPtrs[0] = 0x7f963508ad80
    Starting Layer # -   47
    Processing Layer # -   47
    End of Layer # -   47 with outPtrs[0] = 0x7f96357af400
    Starting Layer # -   48
    Processing Layer # -   48
    End of Layer # -   48 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   49
    Processing Layer # -   49
    End of Layer # -   49 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   50
    Processing Layer # -   50
    End of Layer # -   50 with outPtrs[0] = 0x7f963598da80
    Starting Layer # -   51
    Processing Layer # -   51
    End of Layer # -   51 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   52
    Processing Layer # -   52
    End of Layer # -   52 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   53
    Processing Layer # -   53
    End of Layer # -   53 with outPtrs[0] = 0x7f963508ad80
    Starting Layer # -   54
    Processing Layer # -   54
    End of Layer # -   54 with outPtrs[0] = 0x7f963598da80
    Starting Layer # -   55
    Processing Layer # -   55
    End of Layer # -   55 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   56
    Processing Layer # -   56
    End of Layer # -   56 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   57
    Processing Layer # -   57
    End of Layer # -   57 with outPtrs[0] = 0x7f9635b6c100
    Starting Layer # -   58
    Processing Layer # -   58
    End of Layer # -   58 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   59
    Processing Layer # -   59
    End of Layer # -   59 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   60
    Processing Layer # -   60
    End of Layer # -   60 with outPtrs[0] = 0x7f963508ad80
    Starting Layer # -   61
    Processing Layer # -   61
    End of Layer # -   61 with outPtrs[0] = 0x7f9635b6c100
    Starting Layer # -   62
    Processing Layer # -   62
    End of Layer # -   62 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   63
    Processing Layer # -   63
    End of Layer # -   63 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   64
    Processing Layer # -   64
    End of Layer # -   64 with outPtrs[0] = 0x7f9635d4a780
    Starting Layer # -   65
    Processing Layer # -   65
    End of Layer # -   65 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   66
    Processing Layer # -   66
    End of Layer # -   66 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   67
    Processing Layer # -   67
    End of Layer # -   67 with outPtrs[0] = 0x7f963508ad80
    Starting Layer # -   68
    Processing Layer # -   68
    End of Layer # -   68 with outPtrs[0] = 0x7f9635f28e00
    Starting Layer # -   69
    Processing Layer # -   69
    End of Layer # -   69 with outPtrs[0] = 0x7f96360eae00
    Starting Layer # -   70
    Processing Layer # -   70
    End of Layer # -   70 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -   71
    Processing Layer # -   71
    End of Layer # -   71 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -   72
    Processing Layer # -   72
    End of Layer # -   72 with outPtrs[0] = 0x7f9636b76e00
    Starting Layer # -   73
    Processing Layer # -   73
    End of Layer # -   73 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   74
    Processing Layer # -   74
    End of Layer # -   74 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   75
    Processing Layer # -   75
    End of Layer # -   75 with outPtrs[0] = 0x7f96372b7b00
    Starting Layer # -   76
    Processing Layer # -   76
    End of Layer # -   76 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   77
    Processing Layer # -   77
    End of Layer # -   77 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   78
    Processing Layer # -   78
    End of Layer # -   78 with outPtrs[0] = 0x7f9637479b00
    Starting Layer # -   79
    Processing Layer # -   79
    End of Layer # -   79 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   80
    Processing Layer # -   80
    End of Layer # -   80 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   81
    Processing Layer # -   81
    End of Layer # -   81 with outPtrs[0] = 0x7f963755ab00
    Starting Layer # -   82
    Processing Layer # -   82
    End of Layer # -   82 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   83
    Processing Layer # -   83
    End of Layer # -   83 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   84
    Processing Layer # -   84
    End of Layer # -   84 with outPtrs[0] = 0x7f9637658600
    Starting Layer # -   85
    Processing Layer # -   85
    End of Layer # -   85 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   86
    Processing Layer # -   86
    End of Layer # -   86 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   87
    Processing Layer # -   87
    End of Layer # -   87 with outPtrs[0] = 0x7f96372b7b00
    Starting Layer # -   88
    Processing Layer # -   88
    End of Layer # -   88 with outPtrs[0] = 0x7f9637658600
    Starting Layer # -   89
    Processing Layer # -   89
    End of Layer # -   89 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   90
    Processing Layer # -   90
    End of Layer # -   90 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   91
    Processing Layer # -   91
    End of Layer # -   91 with outPtrs[0] = 0x7f9637756100
    Starting Layer # -   92
    Processing Layer # -   92
    End of Layer # -   92 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   93
    Processing Layer # -   93
    End of Layer # -   93 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   94
    Processing Layer # -   94
    End of Layer # -   94 with outPtrs[0] = 0x7f96372b7b00
    Starting Layer # -   95
    Processing Layer # -   95
    End of Layer # -   95 with outPtrs[0] = 0x7f9637756100
    Starting Layer # -   96
    Processing Layer # -   96
    End of Layer # -   96 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -   97
    Processing Layer # -   97
    End of Layer # -   97 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -   98
    Processing Layer # -   98
    End of Layer # -   98 with outPtrs[0] = 0x7f9637853c00
    Starting Layer # -   99
    Processing Layer # -   99
    End of Layer # -   99 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  100
    Processing Layer # -  100
    End of Layer # -  100 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  101
    Processing Layer # -  101
    End of Layer # -  101 with outPtrs[0] = 0x7f96372b7b00
    Starting Layer # -  102
    Processing Layer # -  102
    End of Layer # -  102 with outPtrs[0] = 0x7f9637853c00
    Starting Layer # -  103
    Processing Layer # -  103
    End of Layer # -  103 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  104
    Processing Layer # -  104
    End of Layer # -  104 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  105
    Processing Layer # -  105
    End of Layer # -  105 with outPtrs[0] = 0x7f9637951700
    Starting Layer # -  106
    Processing Layer # -  106
    End of Layer # -  106 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  107
    Processing Layer # -  107
    End of Layer # -  107 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  108
    Processing Layer # -  108
    End of Layer # -  108 with outPtrs[0] = 0x7f96372b7b00
    Starting Layer # -  109
    Processing Layer # -  109
    End of Layer # -  109 with outPtrs[0] = 0x7f9637a4f200
    Starting Layer # -  110
    Processing Layer # -  110
    End of Layer # -  110 with outPtrs[0] = 0x7f9637b30200
    Starting Layer # -  111
    Processing Layer # -  111
    End of Layer # -  111 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  112
    Processing Layer # -  112
    End of Layer # -  112 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  113
    Processing Layer # -  113
    End of Layer # -  113 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  114
    Processing Layer # -  114
    End of Layer # -  114 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  115
    Processing Layer # -  115
    End of Layer # -  115 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  116
    Processing Layer # -  116
    End of Layer # -  116 with outPtrs[0] = 0x7f96383c3000
    Starting Layer # -  117
    Processing Layer # -  117
    End of Layer # -  117 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  118
    Processing Layer # -  118
    End of Layer # -  118 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  119
    Processing Layer # -  119
    End of Layer # -  119 with outPtrs[0] = 0x7f963846bc00
    Starting Layer # -  120
    Processing Layer # -  120
    End of Layer # -  120 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  121
    Processing Layer # -  121
    End of Layer # -  121 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  122
    Processing Layer # -  122
    End of Layer # -  122 with outPtrs[0] = 0x7f96384c0200
    Starting Layer # -  123
    Processing Layer # -  123
    End of Layer # -  123 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  124
    Processing Layer # -  124
    End of Layer # -  124 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  125
    Processing Layer # -  125
    End of Layer # -  125 with outPtrs[0] = 0x7f963852a700
    Starting Layer # -  126
    Processing Layer # -  126
    End of Layer # -  126 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  127
    Processing Layer # -  127
    End of Layer # -  127 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  128
    Processing Layer # -  128
    End of Layer # -  128 with outPtrs[0] = 0x7f96383c3000
    Starting Layer # -  129
    Processing Layer # -  129
    End of Layer # -  129 with outPtrs[0] = 0x7f963852a700
    Starting Layer # -  130
    Processing Layer # -  130
    End of Layer # -  130 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  131
    Processing Layer # -  131
    End of Layer # -  131 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  132
    Processing Layer # -  132
    End of Layer # -  132 with outPtrs[0] = 0x7f9638594c00
    Starting Layer # -  133
    Processing Layer # -  133
    End of Layer # -  133 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  134
    Processing Layer # -  134
    End of Layer # -  134 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  135
    Processing Layer # -  135
    End of Layer # -  135 with outPtrs[0] = 0x7f96383c3000
    Starting Layer # -  136
    Processing Layer # -  136
    End of Layer # -  136 with outPtrs[0] = 0x7f96385ff100
    Starting Layer # -  137
    Processing Layer # -  137
    End of Layer # -  137 with outPtrs[0] = 0x7f9638653700
    Starting Layer # -  138
    Processing Layer # -  138
    End of Layer # -  138 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  139
    Processing Layer # -  139
    End of Layer # -  139 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  140
    Processing Layer # -  140
    End of Layer # -  140 with outPtrs[0] = 0x7f96383c3000
    Starting Layer # -  141
    Processing Layer # -  141
    End of Layer # -  141 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  142
    Processing Layer # -  142
    End of Layer # -  142 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  143
    Processing Layer # -  143
    End of Layer # -  143 with outPtrs[0] = 0x7f9638594c00
    Starting Layer # -  144
    Processing Layer # -  144
    End of Layer # -  144 with outPtrs[0] = 0x7f96387a4f00
    Starting Layer # -  145
    Processing Layer # -  145
    End of Layer # -  145 with outPtrs[0] = 0x7f963880f400
    Starting Layer # -  146
    Processing Layer # -  146
    End of Layer # -  146 with outPtrs[0] = 0x7f96387a4f00
    Starting Layer # -  147
    Processing Layer # -  147
    End of Layer # -  147 with outPtrs[0] = 0x7f9638879900
    Starting Layer # -  148
    Processing Layer # -  148
    End of Layer # -  148 with outPtrs[0] = 0x7f96387a4f00
    Starting Layer # -  149
    Processing Layer # -  149
    End of Layer # -  149 with outPtrs[0] = 0x7f96388e3e00
    Starting Layer # -  150
    Processing Layer # -  150
    End of Layer # -  150 with outPtrs[0] = 0x7f9638653700
    Starting Layer # -  151
    Processing Layer # -  151
    End of Layer # -  151 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  152
    Processing Layer # -  152
    End of Layer # -  152 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  153
    Processing Layer # -  153
    End of Layer # -  153 with outPtrs[0] = 0x7f9638938400
    Starting Layer # -  154
    Processing Layer # -  154
    End of Layer # -  154 with outPtrs[0] = 0x7f9638a0ce00
    Starting Layer # -  155
    Processing Layer # -  155
    End of Layer # -  155 with outPtrs[0] = 0x7f9637b30200
    Starting Layer # -  156
    Processing Layer # -  156
    End of Layer # -  156 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  157
    Processing Layer # -  157
    End of Layer # -  157 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  158
    Processing Layer # -  158
    End of Layer # -  158 with outPtrs[0] = 0x7f9637a4f200
    Starting Layer # -  159
    Processing Layer # -  159
    End of Layer # -  159 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  160
    Processing Layer # -  160
    End of Layer # -  160 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  161
    Processing Layer # -  161
    End of Layer # -  161 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  162
    Processing Layer # -  162
    End of Layer # -  162 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  163
    Processing Layer # -  163
    End of Layer # -  163 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  164
    Processing Layer # -  164
    End of Layer # -  164 with outPtrs[0] = 0x7f9637951700
    Starting Layer # -  165
    Processing Layer # -  165
    End of Layer # -  165 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  166
    Processing Layer # -  166
    End of Layer # -  166 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  167
    Processing Layer # -  167
    End of Layer # -  167 with outPtrs[0] = 0x7f9637951700
    Starting Layer # -  168
    Processing Layer # -  168
    End of Layer # -  168 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  169
    Processing Layer # -  169
    End of Layer # -  169 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  170
    Processing Layer # -  170
    End of Layer # -  170 with outPtrs[0] = 0x7f9637853c00
    Starting Layer # -  171
    Processing Layer # -  171
    End of Layer # -  171 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  172
    Processing Layer # -  172
    End of Layer # -  172 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  173
    Processing Layer # -  173
    End of Layer # -  173 with outPtrs[0] = 0x7f9637479b00
    Starting Layer # -  174
    Processing Layer # -  174
    End of Layer # -  174 with outPtrs[0] = 0x7f9637b30200
    Starting Layer # -  175
    Processing Layer # -  175
    End of Layer # -  175 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  176
    Processing Layer # -  176
    End of Layer # -  176 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  177
    Processing Layer # -  177
    End of Layer # -  177 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  178
    Processing Layer # -  178
    End of Layer # -  178 with outPtrs[0] = 0x7f9638cafe00
    Starting Layer # -  179
    Processing Layer # -  179
    End of Layer # -  179 with outPtrs[0] = 0x7f96360eae00
    Starting Layer # -  180
    Processing Layer # -  180
    End of Layer # -  180 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  181
    Processing Layer # -  181
    End of Layer # -  181 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  182
    Processing Layer # -  182
    End of Layer # -  182 with outPtrs[0] = 0x7f9635f28e00
    Starting Layer # -  183
    Processing Layer # -  183
    End of Layer # -  183 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  184
    Processing Layer # -  184
    End of Layer # -  184 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  185
    Processing Layer # -  185
    End of Layer # -  185 with outPtrs[0] = 0x7f9636b76e00
    Starting Layer # -  186
    Processing Layer # -  186
    End of Layer # -  186 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  187
    Processing Layer # -  187
    End of Layer # -  187 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  188
    Processing Layer # -  188
    End of Layer # -  188 with outPtrs[0] = 0x7f9635d4a780
    Starting Layer # -  189
    Processing Layer # -  189
    End of Layer # -  189 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  190
    Processing Layer # -  190
    End of Layer # -  190 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  191
    Processing Layer # -  191
    End of Layer # -  191 with outPtrs[0] = 0x7f9635d4a780
    Starting Layer # -  192
    Processing Layer # -  192
    End of Layer # -  192 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  193
    Processing Layer # -  193
    End of Layer # -  193 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  194
    Processing Layer # -  194
    End of Layer # -  194 with outPtrs[0] = 0x7f9635b6c100
    Starting Layer # -  195
    Processing Layer # -  195
    End of Layer # -  195 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  196
    Processing Layer # -  196
    End of Layer # -  196 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  197
    Processing Layer # -  197
    End of Layer # -  197 with outPtrs[0] = 0x7f963540ed80
    Starting Layer # -  198
    Processing Layer # -  198
    End of Layer # -  198 with outPtrs[0] = 0x7f96360eae00
    Starting Layer # -  199
    Processing Layer # -  199
    End of Layer # -  199 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  200
    Processing Layer # -  200
    End of Layer # -  200 with outPtrs[0] = 0x7f9634d06d80
    Starting Layer # -  201
    Processing Layer # -  201
    End of Layer # -  201 with outPtrs[0] = 0x7f9636b76e00
    Starting Layer # -  202
    Processing Layer # -  202
    End of Layer # -  202 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  203
    Processing Layer # -  203
    End of Layer # -  203 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  204
    Processing Layer # -  204
    End of Layer # -  204 with outPtrs[0] = 0x7f9637a4f200
    Starting Layer # -  205
    Processing Layer # -  205
    End of Layer # -  205 with outPtrs[0] = 0x7f9637b30200
    Starting Layer # -  206
    Processing Layer # -  206
    End of Layer # -  206 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  207
    Processing Layer # -  207
    End of Layer # -  207 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  208
    Processing Layer # -  208
    End of Layer # -  208 with outPtrs[0] = 0x7f9637a4f200
    Starting Layer # -  209
    Processing Layer # -  209
    End of Layer # -  209 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  210
    Processing Layer # -  210
    End of Layer # -  210 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  211
    Processing Layer # -  211
    End of Layer # -  211 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  212
    Processing Layer # -  212
    End of Layer # -  212 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  213
    Processing Layer # -  213
    End of Layer # -  213 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  214
    Processing Layer # -  214
    End of Layer # -  214 with outPtrs[0] = 0x7f9637951700
    Starting Layer # -  215
    Processing Layer # -  215
    End of Layer # -  215 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  216
    Processing Layer # -  216
    End of Layer # -  216 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  217
    Processing Layer # -  217
    End of Layer # -  217 with outPtrs[0] = 0x7f9637951700
    Starting Layer # -  218
    Processing Layer # -  218
    End of Layer # -  218 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  219
    Processing Layer # -  219
    End of Layer # -  219 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  220
    Processing Layer # -  220
    End of Layer # -  220 with outPtrs[0] = 0x7f9637853c00
    Starting Layer # -  221
    Processing Layer # -  221
    End of Layer # -  221 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  222
    Processing Layer # -  222
    End of Layer # -  222 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  223
    Processing Layer # -  223
    End of Layer # -  223 with outPtrs[0] = 0x7f9637479b00
    Starting Layer # -  224
    Processing Layer # -  224
    End of Layer # -  224 with outPtrs[0] = 0x7f9637b30200
    Starting Layer # -  225
    Processing Layer # -  225
    End of Layer # -  225 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  226
    Processing Layer # -  226
    End of Layer # -  226 with outPtrs[0] = 0x7f96370f5b00
    Starting Layer # -  227
    Processing Layer # -  227
    End of Layer # -  227 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  228
    Processing Layer # -  228
    End of Layer # -  228 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  229
    Processing Layer # -  229
    End of Layer # -  229 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  230
    Processing Layer # -  230
    End of Layer # -  230 with outPtrs[0] = 0x7f96383c3000
    Starting Layer # -  231
    Processing Layer # -  231
    End of Layer # -  231 with outPtrs[0] = 0x7f9638653700
    Starting Layer # -  232
    Processing Layer # -  232
    End of Layer # -  232 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  233
    Processing Layer # -  233
    End of Layer # -  233 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  234
    Processing Layer # -  234
    End of Layer # -  234 with outPtrs[0] = 0x7f96385ff100
    Starting Layer # -  235
    Processing Layer # -  235
    End of Layer # -  235 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  236
    Processing Layer # -  236
    End of Layer # -  236 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  237
    Processing Layer # -  237
    End of Layer # -  237 with outPtrs[0] = 0x7f9638938400
    Starting Layer # -  238
    Processing Layer # -  238
    End of Layer # -  238 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  239
    Processing Layer # -  239
    End of Layer # -  239 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  240
    Processing Layer # -  240
    End of Layer # -  240 with outPtrs[0] = 0x7f9638594c00
    Starting Layer # -  241
    Processing Layer # -  241
    End of Layer # -  241 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  242
    Processing Layer # -  242
    End of Layer # -  242 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  243
    Processing Layer # -  243
    End of Layer # -  243 with outPtrs[0] = 0x7f9638594c00
    Starting Layer # -  244
    Processing Layer # -  244
    End of Layer # -  244 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  245
    Processing Layer # -  245
    End of Layer # -  245 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  246
    Processing Layer # -  246
    End of Layer # -  246 with outPtrs[0] = 0x7f963852a700
    Starting Layer # -  247
    Processing Layer # -  247
    End of Layer # -  247 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  248
    Processing Layer # -  248
    End of Layer # -  248 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  249
    Processing Layer # -  249
    End of Layer # -  249 with outPtrs[0] = 0x7f963846bc00
    Starting Layer # -  250
    Processing Layer # -  250
    End of Layer # -  250 with outPtrs[0] = 0x7f9638653700
    Starting Layer # -  251
    Processing Layer # -  251
    End of Layer # -  251 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  252
    Processing Layer # -  252
    End of Layer # -  252 with outPtrs[0] = 0x7f963831a400
    Starting Layer # -  253
    Processing Layer # -  253
    End of Layer # -  253 with outPtrs[0] = 0x7f9638938400
    Starting Layer # -  254
    Processing Layer # -  254
    End of Layer # -  254 with outPtrs[0] = 0x7f96393b7e00
    Starting Layer # -  255
    Processing Layer # -  255
    End of Layer # -  255 with outPtrs[0] = 0x7f96393fec00
    Starting Layer # -  256
    Processing Layer # -  256
    End of Layer # -  256 with outPtrs[0] = 0x7f9638271800
    Starting Layer # -  257
    Processing Layer # -  257
    End of Layer # -  257 with outPtrs[0] = 0x7f9638938400
    Starting Layer # -  258
    Processing Layer # -  258
    End of Layer # -  258 with outPtrs[0] = 0x7f96393fec00
    Starting Layer # -  259
    Processing Layer # -  259
    End of Layer # -  259 with outPtrs[0] = 0x7f9638a0ce00
    Starting Layer # -  260
    Processing Layer # -  260
    End of Layer # -  260 with outPtrs[0] = 0x7f9639445a00
    Starting Layer # -  261
    Processing Layer # -  261
    End of Layer # -  261 with outPtrs[0] = 0x7f96394c4780
    Starting Layer # -  262
    Processing Layer # -  262
    End of Layer # -  262 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  263
    Processing Layer # -  263
    End of Layer # -  263 with outPtrs[0] = 0x7f9637a4f200
    Starting Layer # -  264
    Processing Layer # -  264
    End of Layer # -  264 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  265
    Processing Layer # -  265
    End of Layer # -  265 with outPtrs[0] = 0x7f96394c4780
    Starting Layer # -  266
    Processing Layer # -  266
    End of Layer # -  266 with outPtrs[0] = 0x7f9639445a00
    Starting Layer # -  267
    Processing Layer # -  267
    End of Layer # -  267 with outPtrs[0] = 0x7f9636f33b00
    Starting Layer # -  268
    Processing Layer # -  268
    End of Layer # -  268 with outPtrs[0] = 0x7f9638076200
    Starting Layer # -  269
    Processing Layer # -  269
    End of Layer # -  269 with outPtrs[0] = 0x7f9638cafe00
    Starting Layer # -  270
    Processing Layer # -  270
    End of Layer # -  270 with outPtrs[0] = 0x7f9639543500
    Starting Layer # -  271
    Processing Layer # -  271
    End of Layer # -  271 with outPtrs[0] = 0x7f9639721b80
    Starting Layer # -  272
    Processing Layer # -  272
    End of Layer # -  272 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  273
    Processing Layer # -  273
    End of Layer # -  273 with outPtrs[0] = 0x7f9635f28e00
    Starting Layer # -  274
    Processing Layer # -  274
    End of Layer # -  274 with outPtrs[0] = 0x7f9636b76e00
    Starting Layer # -  275
    Processing Layer # -  275
    End of Layer # -  275 with outPtrs[0] = 0x7f9639721b80
    Starting Layer # -  276
    Processing Layer # -  276
    End of Layer # -  276 with outPtrs[0] = 0x7f9639543500
    Starting Layer # -  277
    Processing Layer # -  277
    End of Layer # -  277 with outPtrs[0] = 0x7f9634982d80
    Starting Layer # -  278
    Processing Layer # -  278
    End of Layer # -  278 with outPtrs[0] = 0x7f9636b76e00
    Starting Layer # -  279
    Processing Layer # -  279
    End of Layer # -  279 with outPtrs[0] = 0x7f9639900200
    Starting Layer # -  280
    Processing Layer # -  280
    End of Layer # -  280 with outPtrs[0] = 0x7f963a008200
    Starting Layer # -  281
    Processing Layer # -  281
    End of Layer # -  281 with outPtrs[0] = 0x7f963a748a80
    Starting Layer # -  282
    Processing Layer # -  282
    End of Layer # -  282 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -  283
    Processing Layer # -  283
    End of Layer # -  283 with outPtrs[0] = 0x7f9631b41780
    Starting Layer # -  284
    Processing Layer # -  284
    End of Layer # -  284 with outPtrs[0] = 0x7f9634242500
    Starting Layer # -  285
    Processing Layer # -  285
    End of Layer # -  285 with outPtrs[0] = 0x7f963a748a80
    Starting Layer # -  286
    Processing Layer # -  286
    End of Layer # -  286 with outPtrs[0] = 0x7f963a008200
    Starting Layer # -  287
    Processing Layer # -  287
    End of Layer # -  287 with outPtrs[0] = 0x7f9630d31780
    Starting Layer # -  288
    Processing Layer # -  288
    End of Layer # -  288 with outPtrs[0] = 0x7f9634242500
    Starting Layer # -  289
    Processing Layer # -  289
    End of Layer # -  289 with outPtrs[0] = 0x7f963ae89300
    Starting Layer # -  290
    Processing Layer # -  290
    End of Layer # -  290 with outPtrs[0] = 0x7f963caa9300
    Starting Layer # -  291
    Processing Layer # -  291
    End of Layer # -  291 with outPtrs[0] = 0x7f963cd56c80
    Starting Layer # -  292
    Processing Layer # -  292
    End of Layer # -  292 with outPtrs[0] = 0x7f964bdd2000
    TIDL_process is completed with handle : 67c72000
     Layer,   Layer Cycles,kernelOnlyCycles, coreLoopCycles,LayerSetupCycles,dmaPipeupCycles, dmaPipeDownCycles, PrefetchCycles,copyKerCoeffCycles,LayerDeinitCycles,LastBlockCycles, paddingTrigger,    paddingWait,LayerWithoutPad,LayerHandleCopy,   BackupCycles,  RestoreCycles,
         1,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         2,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         3,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         4,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         5,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         6,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         7,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         8,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
         9,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        10,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        11,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        12,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        13,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        14,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        15,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        16,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        17,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        18,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        19,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        20,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        21,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        22,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        23,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        24,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        25,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        26,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        27,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        28,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        29,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        30,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        31,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        32,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        33,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        34,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        35,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        36,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        37,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        38,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        39,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        40,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        41,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        42,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        43,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        44,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        45,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        46,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        47,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        48,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        49,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        50,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        51,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        52,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        53,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        54,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        55,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        56,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        57,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        58,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        59,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        60,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        61,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        62,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        63,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        64,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        65,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        66,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        67,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        68,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        69,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        70,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        71,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        72,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        73,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        74,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        75,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        76,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        77,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        78,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        79,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        80,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        81,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        82,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        83,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        84,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        85,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        86,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        87,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        88,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        89,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        90,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        91,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        92,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        93,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        94,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        95,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        96,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        97,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        98,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
        99,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       100,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       101,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       102,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       103,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       104,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       105,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       106,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       107,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       108,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       109,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       110,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       111,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       112,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       113,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       114,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       115,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       116,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       117,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       118,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       119,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       120,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       121,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       122,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       123,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       124,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       125,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       126,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       127,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       128,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       129,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       130,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       131,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       132,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       133,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       134,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       135,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       136,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       137,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       138,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       139,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       140,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       141,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       142,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       143,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       144,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       145,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       146,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       147,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       148,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       149,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       150,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       151,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       152,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       153,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       154,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       155,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       156,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       157,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       158,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       159,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       160,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       161,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       162,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       163,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       164,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       165,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       166,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       167,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       168,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       169,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       170,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       171,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       172,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       173,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       174,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       175,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       176,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       177,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       178,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       179,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       180,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       181,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       182,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       183,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       184,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       185,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       186,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       187,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       188,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       189,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       190,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       191,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       192,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       193,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       194,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       195,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       196,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       197,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       198,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       199,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       200,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       201,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       202,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       203,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       204,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       205,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       206,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       207,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       208,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       209,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       210,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       211,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       212,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       213,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       214,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       215,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       216,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       217,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       218,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       219,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       220,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       221,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       222,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       223,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       224,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       225,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       226,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       227,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       228,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       229,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       230,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       231,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       232,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       233,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       234,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       235,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       236,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       237,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       238,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       239,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       240,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       241,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       242,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       243,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       244,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       245,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       246,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       247,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       248,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       249,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       250,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       251,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       252,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       253,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       254,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       255,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       256,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       257,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       258,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       259,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       260,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       261,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       262,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       263,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       264,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       265,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       266,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       267,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       268,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       269,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       270,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       271,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       272,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       273,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       274,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       275,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       276,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       277,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       278,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       279,              0,              0,              0,              0,              0,
    Processing config file #0 : /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts/tempDir/output_tidl_io_.qunat_stats_config.txt
     Freeing memory for user provided Net
     ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
    #    0 . .. T   81719.80  .... ..... ... .... .....       0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       280,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       281,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       282,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       283,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       284,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       285,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       286,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       287,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       288,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       289,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       290,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       291,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       292,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
     Sum of Layer Cycles 0
    Sub Graph Stats 396.000000 85485456.000000 3045.000000
    *******  TIDL_subgraphRtInvoke done  ********
    **********  Frame Index 1 : Running fixed point mode for calibration **********
    In TIDL_runtimesPostProcessNet
    ~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
    #    0 . .. T   45265.13  .... ..... ... .... .....
    ------------------ Network Compiler Traces -----------------------------
    NC running for device: 1
    Running with OTF buffer optimizations
    INFO:20231129-015922: import completed  - segmentation_dev_Unet_V1.1_onnx - 229 sec
    INFO:20231129-015922: infer  - segmentation_dev_Unet_V1.1_onnx - this may take some time...~~~~~
     *****************   Calibration iteration number 0 completed ************************
    Could not open /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts/tempDir/output_tidl_net/perfSimInfo.bin
    INFORMATION: [TIDL_ResizeLayer] /backbone/fpn/up/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /backbone/fpn/up_1/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm2/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm1/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/ffm0/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /decoder/outconv/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    WARNING: [TIDL_E_DATAFLOW_INFO_NULL] Network compiler returned with error or didn't executed, this model can only be used on PC/Host emulation mode, it is not expected to work on target/EVM.
    **          8 WARNINGS          0 ERRORS          **
    libtidl_onnxrt_EP loaded 0x5638ca55bcd0
    artifacts_folder                                = /home/edgeai/code/edgeai-benchmark_v8.6_mod/edgeai-benchmark/work_dirs/modelartifacts/AM68A/8bits/segmentation_dev_Unet_V1.1_onnx/artifacts
    debug_level                                     = 2
    target_priority                                 = 0
    max_pre_empt_delay                              = 340282346638528859811704183484516925440.000000
    Final number of subgraphs created are : 1, - Offloaded Nodes - 314, Total Nodes - 314
    In TIDL_createStateInfer
    Compute on node : TIDLExecutionProvider_TIDL_0_0
    ************ in TIDL_subgraphRtCreate ************
     Alg Alloc for Layer # -    0
    Alg Alloc for Layer # -    1
    Alg Alloc for Layer # -    2
    Alg Alloc for Layer # -    3
    Alg Alloc for Layer # -    4
    Alg Alloc for Layer # -    5
    Alg Alloc for Layer # -    6
    Alg Alloc for Layer # -    7
    Alg Alloc for Layer # -    8
    Alg Alloc for Layer # -    9
    Alg Alloc for Layer # -   10
    Alg Alloc for Layer # -   11
    Alg Alloc for Layer # -   12
    Alg Alloc for Layer # -   13
    Alg Alloc for Layer # -   14
    Alg Alloc for Layer # -   15
    Alg Alloc for Layer # -   16
    Alg Alloc for Layer # -   17
    Alg Alloc for Layer # -   18
    Alg Alloc for Layer # -   19
    Alg Alloc for Layer # -   20
    Alg Alloc for Layer # -   21
    Alg Alloc for Layer # -   22
    Alg Alloc for Layer # -   23
    Alg Alloc for Layer # -   24
    Alg Alloc for Layer # -   25
    Alg Alloc for Layer # -   26
    Alg Alloc for Layer # -   27
    Alg Alloc for Layer # -   28
    Alg Alloc for Layer # -   29
    Alg Alloc for Layer # -   30
    Alg Alloc for Layer # -   31
    Alg Alloc for Layer # -   32
    Alg Alloc for Layer # -   33
    Alg Alloc for Layer # -   34
    Alg Alloc for Layer # -   35
    Alg Alloc for Layer # -   36
    Alg Alloc for Layer # -   37
    Alg Alloc for Layer # -   38
    Alg Alloc for Layer # -   39
    Alg Alloc for Layer # -   40
    Alg Alloc for Layer # -   41
    Alg Alloc for Layer # -   42
    Alg Alloc for Layer # -   43
    Alg Alloc for Layer # -   44
    Alg Alloc for Layer # -   45
    Alg Alloc for Layer # -   46
    Alg Alloc for Layer # -   47
    Alg Alloc for Layer # -   48
    Alg Alloc for Layer # -   49
    Alg Alloc for Layer # -   50
    Alg Alloc for Layer # -   51
    Alg Alloc for Layer # -   52
    Alg Alloc for Layer # -   53
    Alg Alloc for Layer # -   54
    Alg Alloc for Layer # -   55
    Alg Alloc for Layer # -   56
    Alg Alloc for Layer # -   57
    Alg Alloc for Layer # -   58
    Alg Alloc for Layer # -   59
    Alg Alloc for Layer # -   60
    Alg Alloc for Layer # -   61
    Alg Alloc for Layer # -   62
    Alg Alloc for Layer # -   63
    Alg Alloc for Layer # -   64
    Alg Alloc for Layer # -   65
    Alg Alloc for Layer # -   66
    Alg Alloc for Layer # -   67
    Alg Alloc for Layer # -   68
    Alg Alloc for Layer # -   69
    Alg Alloc for Layer # -   70
    Alg Alloc for Layer # -   71
    Alg Alloc for Layer # -   72
    Alg Alloc for Layer # -   73
    Alg Alloc for Layer # -   74
    Alg Alloc for Layer # -   75
    Alg Alloc for Layer # -   76
    Alg Alloc for Layer # -   77
    Alg Alloc for Layer # -   78
    Alg Alloc for Layer # -   79
    Alg Alloc for Layer # -   80
    Alg Alloc for Layer # -   81
    Alg Alloc for Layer # -   82
    Alg Alloc for Layer # -   83
    Alg Alloc for Layer # -   84
    Alg Alloc for Layer # -   85
    Alg Alloc for Layer # -   86
    Alg Alloc for Layer # -   87
    Alg Alloc for Layer # -   88
    Alg Alloc for Layer # -   89
    Alg Alloc for Layer # -   90
    Alg Alloc for Layer # -   91
    Alg Alloc for Layer # -   92
    Alg Alloc for Layer # -   93
    Alg Alloc for Layer # -   94
    Alg Alloc for Layer # -   95
    Alg Alloc for Layer # -   96
    Alg Alloc for Layer # -   97
    Alg Alloc for Layer # -   98
    Alg Alloc for Layer # -   99
    Alg Alloc for Layer # -  100
    Alg Alloc for Layer # -  101
    Alg Alloc for Layer # -  102
    Alg Alloc for Layer # -  103
    Alg Alloc for Layer # -  104
    Alg Alloc for Layer # -  105
    Alg Alloc for Layer # -  106
    Alg Alloc for Layer # -  107
    Alg Alloc for Layer # -  108
    Alg Alloc for Layer # -  109
    Alg Alloc for Layer # -  110
    Alg Alloc for Layer # -  111
    Alg Alloc for Layer # -  112
    Alg Alloc for Layer # -  113
    Alg Alloc for Layer # -  114
    Alg Alloc for Layer # -  115
    Alg Alloc for Layer # -  116
    Alg Alloc for Layer # -  117
    Alg Alloc for Layer # -  118
    Alg Alloc for Layer # -  119
    Alg Alloc for Layer # -  120
    Alg Alloc for Layer # -  121
    Alg Alloc for Layer # -  122
    Alg Alloc for Layer # -  123
    Alg Alloc for Layer # -  124
    Alg Alloc for Layer # -  125
    Alg Alloc for Layer # -  126
    Alg Alloc for Layer # -  127
    Alg Alloc for Layer # -  128
    Alg Alloc for Layer # -  129
    Alg Alloc for Layer # -  130
    Alg Alloc for Layer # -  131
    Alg Alloc for Layer # -  132
    Alg Alloc for Layer # -  133
    Alg Alloc for Layer # -  134
    Alg Alloc for Layer # -  135
    Alg Alloc for Layer # -  136
    Alg Alloc for Layer # -  137
    Alg Alloc for Layer # -  138
    Alg Alloc for Layer # -  139
    Alg Alloc for Layer # -  140
    Alg Alloc for Layer # -  141
    Alg Alloc for Layer # -  142
    Alg Alloc for Layer # -  143
    Alg Alloc for Layer # -  144
    Alg Alloc for Layer # -  145
    Alg Alloc for Layer # -  146
    Alg Alloc for Layer # -  147
    Alg Alloc for Layer # -  148
    Alg Alloc for Layer # -  149
    Alg Alloc for Layer # -  150
    Alg Alloc for Layer # -  151
    Alg Alloc for Layer # -  152
    Alg Alloc for Layer # -  153
    Alg Alloc for Layer # -  154
    Alg Alloc for Layer # -  155
    Alg Alloc for Layer # -  156
    Alg Alloc for Layer # -  157
    Alg Alloc for Layer # -  158
    Alg Alloc for Layer # -  159
    Alg Alloc for Layer # -  160
    Alg Alloc for Layer # -  161
    Alg Alloc for Layer # -  162
    Alg Alloc for Layer # -  163
    Alg Alloc for Layer # -  164
    Alg Alloc for Layer # -  165
    Alg Alloc for Layer # -  166
    Alg Alloc for Layer # -  167
    Alg Alloc for Layer # -  168
    Alg Alloc for Layer # -  169
    Alg Alloc for Layer # -  170
    Alg Alloc for Layer # -  171
    Alg Alloc for Layer # -  172
    Alg Alloc for Layer # -  173
    Alg Alloc for Layer # -  174
    Alg Alloc for Layer # -  175
    Alg Alloc for Layer # -  176
    Alg Alloc for Layer # -  177
    Alg Alloc for Layer # -  178
    Alg Alloc for Layer # -  179
    Alg Alloc for Layer # -  180
    Alg Alloc for Layer # -  181
    Alg Alloc for Layer # -  182
    Alg Alloc for Layer # -  183
    Alg Alloc for Layer # -  184
    Alg Alloc for Layer # -  185
    Alg Alloc for Layer # -  186
    Alg Alloc for Layer # -  187
    Alg Alloc for Layer # -  188
    Alg Alloc for Layer # -  189
    Alg Alloc for Layer # -  190
    Alg Alloc for Layer # -  191
    Alg Alloc for Layer # -  192
    Alg Alloc for Layer # -  193
    Alg Alloc for Layer # -  194
    Alg Alloc for Layer # -  195
    Alg Alloc for Layer # -  196
    Alg Alloc for Layer # -  197
    Alg Alloc for Layer # -  198
    Alg Alloc for Layer # -  199
    Alg Alloc for Layer # -  200
    Alg Alloc for Layer # -  201
    Alg Alloc for Layer # -  202
    Alg Alloc for Layer # -  203
    Alg Alloc for Layer # -  204
    Alg Alloc for Layer # -  205
    Alg Alloc for Layer # -  206
    Alg Alloc for Layer # -  207
    Alg Alloc for Layer # -  208
    Alg Alloc for Layer # -  209
    Alg Alloc for Layer # -  210
    Alg Alloc for Layer # -  211
    Alg Alloc for Layer # -  212
    Alg Alloc for Layer # -  213
    Alg Alloc for Layer # -  214
    Alg Alloc for Layer # -  215
    Alg Alloc for Layer # -  216
    Alg Alloc for Layer # -  217
    Alg Alloc for Layer # -  218
    Alg Alloc for Layer # -  219
    Alg Alloc for Layer # -  220
    Alg Alloc for Layer # -  221
    Alg Alloc for Layer # -  222
    Alg Alloc for Layer # -  223
    Alg Alloc for Layer # -  224
    Alg Alloc for Layer # -  225
    Alg Alloc for Layer # -  226
    Alg Alloc for Layer # -  227
    Alg Alloc for Layer # -  228
    Alg Alloc for Layer # -  229
    Alg Alloc for Layer # -  230
    Alg Alloc for Layer # -  231
    Alg Alloc for Layer # -  232
    Alg Alloc for Layer # -  233
    Alg Alloc for Layer # -  234
    Alg Alloc for Layer # -  235
    Alg Alloc for Layer # -  236
    Alg Alloc for Layer # -  237
    Alg Alloc for Layer # -  238
    Alg Alloc for Layer # -  239
    Alg Alloc for Layer # -  240
    Alg Alloc for Layer # -  241
    Alg Alloc for Layer # -  242
    Alg Alloc for Layer # -  243
    Alg Alloc for Layer # -  244
    Alg Alloc for Layer # -  245
    Alg Alloc for Layer # -  246
    Alg Alloc for Layer # -  247
    Alg Alloc for Layer # -  248
    Alg Alloc for Layer # -  249
    Alg Alloc for Layer # -  250
    Alg Alloc for Layer # -  251
    Alg Alloc for Layer # -  252
    Alg Alloc for Layer # -  253
    Alg Alloc for Layer # -  254
    Alg Alloc for Layer # -  255
    Alg Alloc for Layer # -  256
    Alg Alloc for Layer # -  257
    Alg Alloc for Layer # -  258
    Alg Alloc for Layer # -  259
    Alg Alloc for Layer # -  260
    Alg Alloc for Layer # -  261
    Alg Alloc for Layer # -  262
    Alg Alloc for Layer # -  263
    Alg Alloc for Layer # -  264
    Alg Alloc for Layer # -  265
    Alg Alloc for Layer # -  266
    Alg Alloc for Layer # -  267
    Alg Alloc for Layer # -  268
    Alg Alloc for Layer # -  269
    Alg Alloc for Layer # -  270
    Alg Alloc for Layer # -  271
    Alg Alloc for Layer # -  272
    Alg Alloc for Layer # -  273
    Alg Alloc for Layer # -  274
    Alg Alloc for Layer # -  275
    Alg Alloc for Layer # -  276
    Alg Alloc for Layer # -  277
    Alg Alloc for Layer # -  278
    Alg Alloc for Layer # -  279
    Alg Alloc for Layer # -  280
    Alg Alloc for Layer # -  281
    Alg Alloc for Layer # -  282
    Alg Alloc for Layer # -  283
    Alg Alloc for Layer # -  284
    Alg Alloc for Layer # -  285
    Alg Alloc for Layer # -  286
    Alg Alloc for Layer # -  287
    Alg Alloc for Layer # -  288
    Alg Alloc for Layer # -  289
    Alg Alloc for Layer # -  290
    Alg Alloc for Layer # -  291
    Alg Alloc for Layer # -  292
    Alg Alloc for Layer # -  293
    TIDL Memory size requiement (record wise):
    MemRecNum   , Space       , Attribute   , Size(KBytes)
    0           , DDR Cacheable, Persistent  , 14.84
    1           , DDR Cacheable, Persistent  , 0.14
    2           , DDR Cacheable, Scratch     , 16.00
    3           , DDR Cacheable, Scratch     , 4.00
    4           , DDR Cacheable, Scratch     , 56.00
    5           , DDR Cacheable, Persistent  , 580.27
    6           , DDR Cacheable, Scratch     , 67273.30
    7           , DDR Cacheable, Scratch     , 0.12
    8           , DDR Cacheable, Scratch     , 28800.12
    9           , DDR Cacheable, Scratch     , 86403.00
    10          , DDR Cacheable, Scratch     , 0.12
    11          , DDR Cacheable, Persistent  , 2865.12
    12          , DDR Cacheable, Scratch     , 512.25
    13          , DDR Cacheable, Persistent  , 0.12
    14          , DDR Cacheable, Persistent  , 27588.33
    Total memory size requirement (space wise):
    Mem Space , Size(KBytes)
    DDR Cacheable, 214113.75
    NOTE: Memory requirement in host emulation can be different from the same on EVM
          To get the actual TIDL memory requirement make sure to run on EVM with
          debugTraceLevel = 2
    Alg Init for Layer # -    0 out of  293
    Alg Init for Layer # -    1 out of  293
    Alg Init for Layer # -    2 out of  293
    Alg Init for Layer # -    3 out of  293
    Alg Init for Layer # -    4 out of  293
    Alg Init for Layer # -    5 out of  293
    Alg Init for Layer # -    6 out of  293
    Alg Init for Layer # -    7 out of  293
    Alg Init for Layer # -    8 out of  293
    Alg Init for Layer # -    9 out of  293
    Alg Init for Layer # -   10 out of  293
    Alg Init for Layer # -   11 out of  293
    Alg Init for Layer # -   12 out of  293
    Alg Init for Layer # -   13 out of  293
    Alg Init for Layer # -   14 out of  293
    Alg Init for Layer # -   15 out of  293
    Alg Init for Layer # -   16 out of  293
    Alg Init for Layer # -   17 out of  293
    Alg Init for Layer # -   18 out of  293
    Alg Init for Layer # -   19 out of  293
    Alg Init for Layer # -   20 out of  293
    Alg Init for Layer # -   21 out of  293
    Alg Init for Layer # -   22 out of  293
    Alg Init for Layer # -   23 out of  293
    Alg Init for Layer # -   24 out of  293
    Alg Init for Layer # -   25 out of  293
    Alg Init for Layer # -   26 out of  293
    Alg Init for Layer # -   27 out of  293
    Alg Init for Layer # -   28 out of  293
    Alg Init for Layer # -   29 out of  293
    Alg Init for Layer # -   30 out of  293
    Alg Init for Layer # -   31 out of  293
    Alg Init for Layer # -   32 out of  293
    Alg Init for Layer # -   33 out of  293
    Alg Init for Layer # -   34 out of  293
    Alg Init for Layer # -   35 out of  293
    Alg Init for Layer # -   36 out of  293
    Alg Init for Layer # -   37 out of  293
    Alg Init for Layer # -   38 out of  293
    Alg Init for Layer # -   39 out of  293
    Alg Init for Layer # -   40 out of  293
    Alg Init for Layer # -   41 out of  293
    Alg Init for Layer # -   42 out of  293
    Alg Init for Layer # -   43 out of  293
    Alg Init for Layer # -   44 out of  293
    Alg Init for Layer # -   45 out of  293
    Alg Init for Layer # -   46 out of  293
    Alg Init for Layer # -   47 out of  293
    Alg Init for Layer # -   48 out of  293
    Alg Init for Layer # -   49 out of  293
    Alg Init for Layer # -   50 out of  293
    Alg Init for Layer # -   51 out of  293
    Alg Init for Layer # -   52 out of  293
    Alg Init for Layer # -   53 out of  293
    Alg Init for Layer # -   54 out of  293
    Alg Init for Layer # -   55 out of  293
    Alg Init for Layer # -   56 out of  293
    Alg Init for Layer # -   57 out of  293
    Alg Init for Layer # -   58 out of  293
    Alg Init for Layer # -   59 out of  293
    Alg Init for Layer # -   60 out of  293
    Alg Init for Layer # -   61 out of  293
    Alg Init for Layer # -   62 out of  293
    Alg Init for Layer # -   63 out of  293
    Alg Init for Layer # -   64 out of  293
    Alg Init for Layer # -   65 out of  293
    Alg Init for Layer # -   66 out of  293
    Alg Init for Layer # -   67 out of  293
    Alg Init for Layer # -   68 out of  293
    Alg Init for Layer # -   69 out of  293
    Alg Init for Layer # -   70 out of  293
    Alg Init for Layer # -   71 out of  293
    Alg Init for Layer # -   72 out of  293
    Alg Init for Layer # -   73 out of  293
    Alg Init for Layer # -   74 out of  293
    Alg Init for Layer # -   75 out of  293
    Alg Init for Layer # -   76 out of  293
    Alg Init for Layer # -   77 out of  293
    Alg Init for Layer # -   78 out of  293
    Alg Init for Layer # -   79 out of  293
    Alg Init for Layer # -   80 out of  293
    Alg Init for Layer # -   81 out of  293
    Alg Init for Layer # -   82 out of  293
    Alg Init for Layer # -   83 out of  293
    Alg Init for Layer # -   84 out of  293
    Alg Init for Layer # -   85 out of  293
    Alg Init for Layer # -   86 out of  293
    Alg Init for Layer # -   87 out of  293
    Alg Init for Layer # -   88 out of  293
    Alg Init for Layer # -   89 out of  293
    Alg Init for Layer # -   90 out of  293
    Alg Init for Layer # -   91 out of  293
    Alg Init for Layer # -   92 out of  293
    Alg Init for Layer # -   93 out of  293
    Alg Init for Layer # -   94 out of  293
    Alg Init for Layer # -   95 out of  293
    Alg Init for Layer # -   96 out of  293
    Alg Init for Layer # -   97 out of  293
    Alg Init for Layer # -   98 out of  293
    Alg Init for Layer # -   99 out of  293
    Alg Init for Layer # -  100 out of  293
    Alg Init for Layer # -  101 out of  293
    Alg Init for Layer # -  102 out of  293
    Alg Init for Layer # -  103 out of  293
    Alg Init for Layer # -  104 out of  293
    Alg Init for Layer # -  105 out of  293
    Alg Init for Layer # -  106 out of  293
    Alg Init for Layer # -  107 out of  293
    Alg Init for Layer # -  108 out of  293
    Alg Init for Layer # -  109 out of  293
    Alg Init for Layer # -  110 out of  293
    Alg Init for Layer # -  111 out of  293
    Alg Init for Layer # -  112 out of  293
    Alg Init for Layer # -  113 out of  293
    Alg Init for Layer # -  114 out of  293
    Alg Init for Layer # -  115 out of  293
    Alg Init for Layer # -  116 out of  293
    Alg Init for Layer # -  117 out of  293
    Alg Init for Layer # -  118 out of  293
    Alg Init for Layer # -  119 out of  293
    Alg Init for Layer # -  120 out of  293
    Alg Init for Layer # -  121 out of  293
    Alg Init for Layer # -  122 out of  293
    Alg Init for Layer # -  123 out of  293
    Alg Init for Layer # -  124 out of  293
    Alg Init for Layer # -  125 out of  293
    Alg Init for Layer # -  126 out of  293
    Alg Init for Layer # -  127 out of  293
    Alg Init for Layer # -  128 out of  293
    Alg Init for Layer # -  129 out of  293
    Alg Init for Layer # -  130 out of  293
    Alg Init for Layer # -  131 out of  293
    Alg Init for Layer # -  132 out of  293
    Alg Init for Layer # -  133 out of  293
    Alg Init for Layer # -  134 out of  293
    Alg Init for Layer # -  135 out of  293
    Alg Init for Layer # -  136 out of  293
    Alg Init for Layer # -  137 out of  293
    Alg Init for Layer # -  138 out of  293
    Alg Init for Layer # -  139 out of  293
    Alg Init for Layer # -  140 out of  293
    Alg Init for Layer # -  141 out of  293
    Alg Init for Layer # -  142 out of  293
    Alg Init for Layer # -  143 out of  293
    Alg Init for Layer # -  144 out of  293
    Alg Init for Layer # -  145 out of  293
    Alg Init for Layer # -  146 out of  293
    Alg Init for Layer # -  147 out of  293
    Alg Init for Layer # -  148 out of  293
    Alg Init for Layer # -  149 out of  293
    Alg Init for Layer # -  150 out of  293
    Alg Init for Layer # -  151 out of  293
    Alg Init for Layer # -  152 out of  293
    Alg Init for Layer # -  153 out of  293
    Alg Init for Layer # -  154 out of  293
    Alg Init for Layer # -  155 out of  293
    Alg Init for Layer # -  156 out of  293
    Alg Init for Layer # -  157 out of  293
    Alg Init for Layer # -  158 out of  293
    Alg Init for Layer # -  159 out of  293
    Alg Init for Layer # -  160 out of  293
    Alg Init for Layer # -  161 out of  293
    Alg Init for Layer # -  162 out of  293
    Alg Init for Layer # -  163 out of  293
    Alg Init for Layer # -  164 out of  293
    Alg Init for Layer # -  165 out of  293
    Alg Init for Layer # -  166 out of  293
    Alg Init for Layer # -  167 out of  293
    Alg Init for Layer # -  168 out of  293
    Alg Init for Layer # -  169 out of  293
    Alg Init for Layer # -  170 out of  293
    Alg Init for Layer # -  171 out of  293
    Alg Init for Layer # -  172 out of  293
    Alg Init for Layer # -  173 out of  293
    Alg Init for Layer # -  174 out of  293
    Alg Init for Layer # -  175 out of  293
    Alg Init for Layer # -  176 out of  293
    Alg Init for Layer # -  177 out of  293
    Alg Init for Layer # -  178 out of  293
    Alg Init for Layer # -  179 out of  293
    Alg Init for Layer # -  180 out of  293
    Alg Init for Layer # -  181 out of  293
    Alg Init for Layer # -  182 out of  293
    Alg Init for Layer # -  183 out of  293
    Alg Init for Layer # -  184 out of  293
    Alg Init for Layer # -  185 out of  293
    Alg Init for Layer # -  186 out of  293
    Alg Init for Layer # -  187 out of  293
    Alg Init for Layer # -  188 out of  293
    Alg Init for Layer # -  189 out of  293
    Alg Init for Layer # -  190 out of  293
    Alg Init for Layer # -  191 out of  293
    Alg Init for Layer # -  192 out of  293
    Alg Init for Layer # -  193 out of  293
    Alg Init for Layer # -  194 out of  293
    Alg Init for Layer # -  195 out of  293
    Alg Init for Layer # -  196 out of  293
    Alg Init for Layer # -  197 out of  293
    Alg Init for Layer # -  198 out of  293
    Alg Init for Layer # -  199 out of  293
    Alg Init for Layer # -  200 out of  293
    Alg Init for Layer # -  201 out of  293
    Alg Init for Layer # -  202 out of  293
    Alg Init for Layer # -  203 out of  293
    Alg Init for Layer # -  204 out of  293
    Alg Init for Layer # -  205 out of  293
    Alg Init for Layer # -  206 out of  293
    Alg Init for Layer # -  207 out of  293
    Alg Init for Layer # -  208 out of  293
    Alg Init for Layer # -  209 out of  293
    Alg Init for Layer # -  210 out of  293
    Alg Init for Layer # -  211 out of  293
    Alg Init for Layer # -  212 out of  293
    Alg Init for Layer # -  213 out of  293
    Alg Init for Layer # -  214 out of  293
    Alg Init for Layer # -  215 out of  293
    Alg Init for Layer # -  216 out of  293
    Alg Init for Layer # -  217 out of  293
    Alg Init for Layer # -  218 out of  293
    Alg Init for Layer # -  219 out of  293
    Alg Init for Layer # -  220 out of  293
    Alg Init for Layer # -  221 out of  293
    Alg Init for Layer # -  222 out of  293
    Alg Init for Layer # -  223 out of  293
    Alg Init for Layer # -  224 out of  293
    Alg Init for Layer # -  225 out of  293
    Alg Init for Layer # -  226 out of  293
    Alg Init for Layer # -  227 out of  293
    Alg Init for Layer # -  228 out of  293
    Alg Init for Layer # -  229 out of  293
    Alg Init for Layer # -  230 out of  293
    Alg Init for Layer # -  231 out of  293
    Alg Init for Layer # -  232 out of  293
    Alg Init for Layer # -  233 out of  293
    Alg Init for Layer # -  234 out of  293
    Alg Init for Layer # -  235 out of  293
    Alg Init for Layer # -  236 out of  293
    Alg Init for Layer # -  237 out of  293
    Alg Init for Layer # -  238 out of  293
    Alg Init for Layer # -  239 out of  293
    Alg Init for Layer # -  240 out of  293
    Alg Init for Layer # -  241 out of  293
    Alg Init for Layer # -  242 out of  293
    Alg Init for Layer # -  243 out of  293
    Alg Init for Layer # -  244 out of  293
    Alg Init for Layer # -  245 out of  293
    Alg Init for Layer # -  246 out of  293
    Alg Init for Layer # -  247 out of  293
    Alg Init for Layer # -  248 out of  293
    Alg Init for Layer # -  249 out of  293
    Alg Init for Layer # -  250 out of  293
    Alg Init for Layer # -  251 out of  293
    Alg Init for Layer # -  252 out of  293
    Alg Init for Layer # -  253 out of  293
    Alg Init for Layer # -  254 out of  293
    Alg Init for Layer # -  255 out of  293
    Alg Init for Layer # -  256 out of  293
    Alg Init for Layer # -  257 out of  293
    Alg Init for Layer # -  258 out of  293
    Alg Init for Layer # -  259 out of  293
    Alg Init for Layer # -  260 out of  293
    Alg Init for Layer # -  261 out of  293
    Alg Init for Layer # -  262 out of  293
    Alg Init for Layer # -  263 out of  293
    Alg Init for Layer # -  264 out of  293
    Alg Init for Layer # -  265 out of  293
    Alg Init for Layer # -  266 out of  293
    Alg Init for Layer # -  267 out of  293
    Alg Init for Layer # -  268 out of  293
    Alg Init for Layer # -  269 out of  293
    Alg Init for Layer # -  270 out of  293
    Alg Init for Layer # -  271 out of  293
    Alg Init for Layer # -  272 out of  293
    Alg Init for Layer # -  273 out of  293
    Alg Init for Layer # -  274 out of  293
    Alg Init for Layer # -  275 out of  293
    Alg Init for Layer # -  276 out of  293
    Alg Init for Layer # -  277 out of  293
    Alg Init for Layer # -  278 out of  293
    Alg Init for Layer # -  279 out of  293
    Alg Init for Layer # -  280 out of  293
    Alg Init for Layer # -  281 out of  293
    Alg Init for Layer # -  282 out of  293
    Alg Init for Layer # -  283 out of  293
    Alg Init for Layer # -  284 out of  293
    infer : segmentation|   0%|          || 0/1 [00:00<?, ?it/s]
    infer : segmentation|          |     0% 0/1| [< ]285 out of  293
    Alg Init for Layer # -  286 out of  293
    Alg Init for Layer # -  287 out of  293
    Alg Init for Layer # -  288 out of  293
    Alg Init for Layer # -  289 out of  293
    Alg Init for Layer # -  290 out of  293
    Alg Init for Layer # -  291 out of  293
    Alg Init for Layer # -  292 out of  293
    Alg Init for Layer # -  293 out of  293
    PREEMPTION: Adding a new priority object for targetPriority = 1, handle = 0x7f972b476000
    PREEMPTION: Now total number of priority objects = 2 at priorityId = 1,    with new memRec of base = 0x7f9743c74000 and size = 128
    PREEMPTION: Requesting context memory addr for handle 0x7f972b476000, return Addr = 0x7f9754478000
    ************ TIDL_subgraphRtCreate done ************
     ************ in TIDL_subgraphRtDelete ************
     TIDL_deactivate is called with handle : 67c72000
    PREEMPTION: Removing priroty object with handle = 0x7f9767c72000 and targetPriority = 1,      Number of obejcts left are = 1, removed object with base  = 0x7f9743c74000 and size =128
    *******   In TIDL_subgraphRtInvoke  ********
    TIDL_activate is called with handle : 2b476000
    End of Layer # -    1 with outPtrs[0] = 0x7f95e1c2f000
    End of Layer # -    2 with outPtrs[0] = 0x7f95e1d11c80
    Starting Layer # -    3
    Processing Layer # -    3
    End of Layer # -    3 with outPtrs[0] = 0x7f95e2095c80
    Starting Layer # -    4
    Processing Layer # -    4
    End of Layer # -    4 with outPtrs[0] = 0x7f95e2419c80
    Starting Layer # -    5
    Processing Layer # -    5
    End of Layer # -    5 with outPtrs[0] = 0x7f95e27abe80
    Starting Layer # -    6
    Processing Layer # -    6
    End of Layer # -    6 with outPtrs[0] = 0x7f95e296de80
    Starting Layer # -    7
    Processing Layer # -    7
    End of Layer # -    7 with outPtrs[0] = 0x7f95e2b2fe80
    Starting Layer # -    8
    Processing Layer # -    8
    End of Layer # -    8 with outPtrs[0] = 0x7f95e27abe80
    Starting Layer # -    9
    Processing Layer # -    9
    End of Layer # -    9 with outPtrs[0] = 0x7f95e296de80
    Starting Layer # -   10
    Processing Layer # -   10
    End of Layer # -   10 with outPtrs[0] = 0x7f95e2cf1e80
    End of Layer # -   11 with outPtrs[0] = 0x7f95e27abe80
    End of Layer # -   12 with outPtrs[0] = 0x7f95e296de80
    End of Layer # -   13 with outPtrs[0] = 0x7f95e2dd2e80
    End of Layer # -   14 with outPtrs[0] = 0x7f95e27abe80
    End of Layer # -   15 with outPtrs[0] = 0x7f95e296de80
    End of Layer # -   16 with outPtrs[0] = 0x7f95e2ebb000
    End of Layer # -   17 with outPtrs[0] = 0x7f95e27abe80
    End of Layer # -   18 with outPtrs[0] = 0x7f95e296de80
    End of Layer # -   19 with outPtrs[0] = 0x7f95e2b2fe80
    End of Layer # -   20 with outPtrs[0] = 0x7f95e2ebb000
    End of Layer # -   21 with outPtrs[0] = 0x7f95e27abe80
    End of Layer # -   22 with outPtrs[0] = 0x7f95e296de80
    End of Layer # -   23 with outPtrs[0] = 0x7f95e2fa3180
    End of Layer # -   24 with outPtrs[0] = 0x7f95e27abe80
    End of Layer # -   25 with outPtrs[0] = 0x7f95e296de80
    End of Layer # -   26 with outPtrs[0] = 0x7f95e2b2fe80
    End of Layer # -   27 with outPtrs[0] = 0x7f95e308b300
    End of Layer # -   28 with outPtrs[0] = 0x7f95e316c300
    End of Layer # -   29 with outPtrs[0] = 0x7f95e27abe80
    Starting Layer # -   30
    Processing Layer # -   30
    End of Layer # -   30 with outPtrs[0] = 0x7f95e296de80
    Starting Layer # -   31
    Processing Layer # -   31
    End of Layer # -   31 with outPtrs[0] = 0x7f95e34f0300
    Starting Layer # -   32
    Processing Layer # -   32
    End of Layer # -   32 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   33
    Processing Layer # -   33
    End of Layer # -   33 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   34
    Processing Layer # -   34
    End of Layer # -   34 with outPtrs[0] = 0x7f95e3882580
    Starting Layer # -   35
    Processing Layer # -   35
    End of Layer # -   35 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   36
    Processing Layer # -   36
    End of Layer # -   36 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   37
    Processing Layer # -   37
    End of Layer # -   37 with outPtrs[0] = 0x7f95e3963580
    Starting Layer # -   38
    Processing Layer # -   38
    End of Layer # -   38 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   39
    Processing Layer # -   39
    End of Layer # -   39 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   40
    Processing Layer # -   40
    End of Layer # -   40 with outPtrs[0] = 0x7f95e39d3d80
    Starting Layer # -   41
    Processing Layer # -   41
    End of Layer # -   41 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   42
    Processing Layer # -   42
    End of Layer # -   42 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   43
    Processing Layer # -   43
    End of Layer # -   43 with outPtrs[0] = 0x7f95e3a4b780
    Starting Layer # -   44
    Processing Layer # -   44
    End of Layer # -   44 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   45
    Processing Layer # -   45
    End of Layer # -   45 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   46
    Processing Layer # -   46
    End of Layer # -   46 with outPtrs[0] = 0x7f95e3882580
    Starting Layer # -   47
    Processing Layer # -   47
    End of Layer # -   47 with outPtrs[0] = 0x7f95e3a4b780
    Starting Layer # -   48
    Processing Layer # -   48
    End of Layer # -   48 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   49
    Processing Layer # -   49
    End of Layer # -   49 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   50
    Processing Layer # -   50
    End of Layer # -   50 with outPtrs[0] = 0x7f95e3ac3180
    Starting Layer # -   51
    Processing Layer # -   51
    End of Layer # -   51 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   52
    Processing Layer # -   52
    End of Layer # -   52 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   53
    Processing Layer # -   53
    End of Layer # -   53 with outPtrs[0] = 0x7f95e3882580
    Starting Layer # -   54
    Processing Layer # -   54
    End of Layer # -   54 with outPtrs[0] = 0x7f95e3ac3180
    Starting Layer # -   55
    Processing Layer # -   55
    End of Layer # -   55 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   56
    Processing Layer # -   56
    End of Layer # -   56 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   57
    Processing Layer # -   57
    End of Layer # -   57 with outPtrs[0] = 0x7f95e3b3ab80
    Starting Layer # -   58
    Processing Layer # -   58
    End of Layer # -   58 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   59
    Processing Layer # -   59
    End of Layer # -   59 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   60
    Processing Layer # -   60
    End of Layer # -   60 with outPtrs[0] = 0x7f95e3882580
    Starting Layer # -   61
    Processing Layer # -   61
    End of Layer # -   61 with outPtrs[0] = 0x7f95e3b3ab80
    Starting Layer # -   62
    Processing Layer # -   62
    End of Layer # -   62 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   63
    Processing Layer # -   63
    End of Layer # -   63 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   64
    Processing Layer # -   64
    End of Layer # -   64 with outPtrs[0] = 0x7f95e3bb2580
    Starting Layer # -   65
    Processing Layer # -   65
    End of Layer # -   65 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   66
    Processing Layer # -   66
    End of Layer # -   66 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   67
    Processing Layer # -   67
    End of Layer # -   67 with outPtrs[0] = 0x7f95e3882580
    Starting Layer # -   68
    Processing Layer # -   68
    End of Layer # -   68 with outPtrs[0] = 0x7f95e3c29f80
    Starting Layer # -   69
    Processing Layer # -   69
    End of Layer # -   69 with outPtrs[0] = 0x7f95e3c9a780
    Starting Layer # -   70
    Processing Layer # -   70
    End of Layer # -   70 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -   71
    Processing Layer # -   71
    End of Layer # -   71 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -   72
    Processing Layer # -   72
    End of Layer # -   72 with outPtrs[0] = 0x7f95e3f3d780
    Starting Layer # -   73
    Processing Layer # -   73
    End of Layer # -   73 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   74
    Processing Layer # -   74
    End of Layer # -   74 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   75
    Processing Layer # -   75
    End of Layer # -   75 with outPtrs[0] = 0x7f95e410db00
    Starting Layer # -   76
    Processing Layer # -   76
    End of Layer # -   76 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   77
    Processing Layer # -   77
    End of Layer # -   77 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   78
    Processing Layer # -   78
    End of Layer # -   78 with outPtrs[0] = 0x7f95e417e300
    Starting Layer # -   79
    Processing Layer # -   79
    End of Layer # -   79 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   80
    Processing Layer # -   80
    End of Layer # -   80 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   81
    Processing Layer # -   81
    End of Layer # -   81 with outPtrs[0] = 0x7f95e41b6700
    Starting Layer # -   82
    Processing Layer # -   82
    End of Layer # -   82 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   83
    Processing Layer # -   83
    End of Layer # -   83 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   84
    Processing Layer # -   84
    End of Layer # -   84 with outPtrs[0] = 0x7f95e41f5e00
    Starting Layer # -   85
    Processing Layer # -   85
    End of Layer # -   85 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   86
    Processing Layer # -   86
    End of Layer # -   86 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   87
    Processing Layer # -   87
    End of Layer # -   87 with outPtrs[0] = 0x7f95e410db00
    Starting Layer # -   88
    Processing Layer # -   88
    End of Layer # -   88 with outPtrs[0] = 0x7f95e41f5e00
    Starting Layer # -   89
    Processing Layer # -   89
    End of Layer # -   89 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   90
    Processing Layer # -   90
    End of Layer # -   90 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   91
    Processing Layer # -   91
    End of Layer # -   91 with outPtrs[0] = 0x7f95e4235500
    Starting Layer # -   92
    Processing Layer # -   92
    End of Layer # -   92 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   93
    Processing Layer # -   93
    End of Layer # -   93 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   94
    Processing Layer # -   94
    End of Layer # -   94 with outPtrs[0] = 0x7f95e410db00
    Starting Layer # -   95
    Processing Layer # -   95
    End of Layer # -   95 with outPtrs[0] = 0x7f95e4235500
    Starting Layer # -   96
    Processing Layer # -   96
    End of Layer # -   96 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -   97
    Processing Layer # -   97
    End of Layer # -   97 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -   98
    Processing Layer # -   98
    End of Layer # -   98 with outPtrs[0] = 0x7f95e4274c00
    Starting Layer # -   99
    Processing Layer # -   99
    End of Layer # -   99 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  100
    Processing Layer # -  100
    End of Layer # -  100 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  101
    Processing Layer # -  101
    End of Layer # -  101 with outPtrs[0] = 0x7f95e410db00
    Starting Layer # -  102
    Processing Layer # -  102
    End of Layer # -  102 with outPtrs[0] = 0x7f95e4274c00
    Starting Layer # -  103
    Processing Layer # -  103
    End of Layer # -  103 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  104
    Processing Layer # -  104
    End of Layer # -  104 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  105
    Processing Layer # -  105
    End of Layer # -  105 with outPtrs[0] = 0x7f95e42b4300
    Starting Layer # -  106
    Processing Layer # -  106
    End of Layer # -  106 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  107
    Processing Layer # -  107
    End of Layer # -  107 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  108
    Processing Layer # -  108
    End of Layer # -  108 with outPtrs[0] = 0x7f95e410db00
    Starting Layer # -  109
    Processing Layer # -  109
    End of Layer # -  109 with outPtrs[0] = 0x7f95e42f3a00
    Starting Layer # -  110
    Processing Layer # -  110
    End of Layer # -  110 with outPtrs[0] = 0x7f95e432be00
    Starting Layer # -  111
    Processing Layer # -  111
    End of Layer # -  111 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  112
    Processing Layer # -  112
    End of Layer # -  112 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  113
    Processing Layer # -  113
    End of Layer # -  113 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  114
    Processing Layer # -  114
    End of Layer # -  114 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  115
    Processing Layer # -  115
    End of Layer # -  115 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  116
    Processing Layer # -  116
    End of Layer # -  116 with outPtrs[0] = 0x7f95e4550980
    Starting Layer # -  117
    Processing Layer # -  117
    End of Layer # -  117 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  118
    Processing Layer # -  118
    End of Layer # -  118 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  119
    Processing Layer # -  119
    End of Layer # -  119 with outPtrs[0] = 0x7f95e457ac80
    Starting Layer # -  120
    Processing Layer # -  120
    End of Layer # -  120 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  121
    Processing Layer # -  121
    End of Layer # -  121 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  122
    Processing Layer # -  122
    End of Layer # -  122 with outPtrs[0] = 0x7f95e458fe00
    Starting Layer # -  123
    Processing Layer # -  123
    End of Layer # -  123 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  124
    Processing Layer # -  124
    End of Layer # -  124 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  125
    Processing Layer # -  125
    End of Layer # -  125 with outPtrs[0] = 0x7f95e45aa780
    Starting Layer # -  126
    Processing Layer # -  126
    End of Layer # -  126 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  127
    Processing Layer # -  127
    End of Layer # -  127 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  128
    Processing Layer # -  128
    End of Layer # -  128 with outPtrs[0] = 0x7f95e4550980
    Starting Layer # -  129
    Processing Layer # -  129
    End of Layer # -  129 with outPtrs[0] = 0x7f95e45aa780
    Starting Layer # -  130
    Processing Layer # -  130
    End of Layer # -  130 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  131
    Processing Layer # -  131
    End of Layer # -  131 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  132
    Processing Layer # -  132
    End of Layer # -  132 with outPtrs[0] = 0x7f95e45c5100
    Starting Layer # -  133
    Processing Layer # -  133
    End of Layer # -  133 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  134
    Processing Layer # -  134
    End of Layer # -  134 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  135
    Processing Layer # -  135
    End of Layer # -  135 with outPtrs[0] = 0x7f95e4550980
    Starting Layer # -  136
    Processing Layer # -  136
    End of Layer # -  136 with outPtrs[0] = 0x7f95e45dfa80
    Starting Layer # -  137
    Processing Layer # -  137
    End of Layer # -  137 with outPtrs[0] = 0x7f95e45f4c00
    Starting Layer # -  138
    Processing Layer # -  138
    End of Layer # -  138 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  139
    Processing Layer # -  139
    End of Layer # -  139 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  140
    Processing Layer # -  140
    End of Layer # -  140 with outPtrs[0] = 0x7f95e4550980
    Starting Layer # -  141
    Processing Layer # -  141
    End of Layer # -  141 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  142
    Processing Layer # -  142
    End of Layer # -  142 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  143
    Processing Layer # -  143
    End of Layer # -  143 with outPtrs[0] = 0x7f95e45c5100
    Starting Layer # -  144
    Processing Layer # -  144
    End of Layer # -  144 with outPtrs[0] = 0x7f95e4649200
    Starting Layer # -  145
    Processing Layer # -  145
    End of Layer # -  145 with outPtrs[0] = 0x7f95e4663b80
    Starting Layer # -  146
    Processing Layer # -  146
    End of Layer # -  146 with outPtrs[0] = 0x7f95e4649200
    Starting Layer # -  147
    Processing Layer # -  147
    End of Layer # -  147 with outPtrs[0] = 0x7f95e467e500
    Starting Layer # -  148
    Processing Layer # -  148
    End of Layer # -  148 with outPtrs[0] = 0x7f95e4649200
    Starting Layer # -  149
    Processing Layer # -  149
    End of Layer # -  149 with outPtrs[0] = 0x7f95e4698e80
    Starting Layer # -  150
    Processing Layer # -  150
    End of Layer # -  150 with outPtrs[0] = 0x7f95e45f4c00
    Starting Layer # -  151
    Processing Layer # -  151
    End of Layer # -  151 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  152
    Processing Layer # -  152
    End of Layer # -  152 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  153
    Processing Layer # -  153
    End of Layer # -  153 with outPtrs[0] = 0x7f95e46ae000
    Starting Layer # -  154
    Processing Layer # -  154
    End of Layer # -  154 with outPtrs[0] = 0x7f95e46e3280
    Starting Layer # -  155
    Processing Layer # -  155
    End of Layer # -  155 with outPtrs[0] = 0x7f95e432be00
    Starting Layer # -  156
    Processing Layer # -  156
    End of Layer # -  156 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  157
    Processing Layer # -  157
    End of Layer # -  157 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  158
    Processing Layer # -  158
    End of Layer # -  158 with outPtrs[0] = 0x7f95e42f3a00
    Starting Layer # -  159
    Processing Layer # -  159
    End of Layer # -  159 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  160
    Processing Layer # -  160
    End of Layer # -  160 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  161
    Processing Layer # -  161
    End of Layer # -  161 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  162
    Processing Layer # -  162
    End of Layer # -  162 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  163
    Processing Layer # -  163
    End of Layer # -  163 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  164
    Processing Layer # -  164
    End of Layer # -  164 with outPtrs[0] = 0x7f95e42b4300
    Starting Layer # -  165
    Processing Layer # -  165
    End of Layer # -  165 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  166
    Processing Layer # -  166
    End of Layer # -  166 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  167
    Processing Layer # -  167
    End of Layer # -  167 with outPtrs[0] = 0x7f95e42b4300
    Starting Layer # -  168
    Processing Layer # -  168
    End of Layer # -  168 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  169
    Processing Layer # -  169
    End of Layer # -  169 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  170
    Processing Layer # -  170
    End of Layer # -  170 with outPtrs[0] = 0x7f95e4274c00
    Starting Layer # -  171
    Processing Layer # -  171
    End of Layer # -  171 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  172
    Processing Layer # -  172
    End of Layer # -  172 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  173
    Processing Layer # -  173
    End of Layer # -  173 with outPtrs[0] = 0x7f95e417e300
    Starting Layer # -  174
    Processing Layer # -  174
    End of Layer # -  174 with outPtrs[0] = 0x7f95e432be00
    Starting Layer # -  175
    Processing Layer # -  175
    End of Layer # -  175 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  176
    Processing Layer # -  176
    End of Layer # -  176 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  177
    Processing Layer # -  177
    End of Layer # -  177 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  178
    Processing Layer # -  178
    End of Layer # -  178 with outPtrs[0] = 0x7f95e478be80
    Starting Layer # -  179
    Processing Layer # -  179
    End of Layer # -  179 with outPtrs[0] = 0x7f95e3c9a780
    Starting Layer # -  180
    Processing Layer # -  180
    End of Layer # -  180 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  181
    Processing Layer # -  181
    End of Layer # -  181 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  182
    Processing Layer # -  182
    End of Layer # -  182 with outPtrs[0] = 0x7f95e3c29f80
    Starting Layer # -  183
    Processing Layer # -  183
    End of Layer # -  183 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  184
    Processing Layer # -  184
    End of Layer # -  184 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  185
    Processing Layer # -  185
    End of Layer # -  185 with outPtrs[0] = 0x7f95e3f3d780
    Starting Layer # -  186
    Processing Layer # -  186
    End of Layer # -  186 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  187
    Processing Layer # -  187
    End of Layer # -  187 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  188
    Processing Layer # -  188
    End of Layer # -  188 with outPtrs[0] = 0x7f95e3bb2580
    Starting Layer # -  189
    Processing Layer # -  189
    End of Layer # -  189 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  190
    Processing Layer # -  190
    End of Layer # -  190 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  191
    Processing Layer # -  191
    End of Layer # -  191 with outPtrs[0] = 0x7f95e3bb2580
    Starting Layer # -  192
    Processing Layer # -  192
    End of Layer # -  192 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  193
    Processing Layer # -  193
    End of Layer # -  193 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  194
    Processing Layer # -  194
    End of Layer # -  194 with outPtrs[0] = 0x7f95e3b3ab80
    Starting Layer # -  195
    Processing Layer # -  195
    End of Layer # -  195 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  196
    Processing Layer # -  196
    End of Layer # -  196 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  197
    Processing Layer # -  197
    End of Layer # -  197 with outPtrs[0] = 0x7f95e3963580
    Starting Layer # -  198
    Processing Layer # -  198
    End of Layer # -  198 with outPtrs[0] = 0x7f95e3c9a780
    Starting Layer # -  199
    Processing Layer # -  199
    End of Layer # -  199 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  200
    Processing Layer # -  200
    End of Layer # -  200 with outPtrs[0] = 0x7f95e37a1580
    Starting Layer # -  201
    Processing Layer # -  201
    End of Layer # -  201 with outPtrs[0] = 0x7f95e3f3d780
    Starting Layer # -  202
    Processing Layer # -  202
    End of Layer # -  202 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  203
    Processing Layer # -  203
    End of Layer # -  203 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  204
    Processing Layer # -  204
    End of Layer # -  204 with outPtrs[0] = 0x7f95e42f3a00
    Starting Layer # -  205
    Processing Layer # -  205
    End of Layer # -  205 with outPtrs[0] = 0x7f95e432be00
    Starting Layer # -  206
    Processing Layer # -  206
    End of Layer # -  206 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  207
    Processing Layer # -  207
    End of Layer # -  207 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  208
    Processing Layer # -  208
    End of Layer # -  208 with outPtrs[0] = 0x7f95e42f3a00
    Starting Layer # -  209
    Processing Layer # -  209
    End of Layer # -  209 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  210
    Processing Layer # -  210
    End of Layer # -  210 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  211
    Processing Layer # -  211
    End of Layer # -  211 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  212
    Processing Layer # -  212
    End of Layer # -  212 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  213
    Processing Layer # -  213
    End of Layer # -  213 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  214
    Processing Layer # -  214
    End of Layer # -  214 with outPtrs[0] = 0x7f95e42b4300
    Starting Layer # -  215
    Processing Layer # -  215
    End of Layer # -  215 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  216
    Processing Layer # -  216
    End of Layer # -  216 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  217
    Processing Layer # -  217
    End of Layer # -  217 with outPtrs[0] = 0x7f95e42b4300
    Starting Layer # -  218
    Processing Layer # -  218
    End of Layer # -  218 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  219
    Processing Layer # -  219
    End of Layer # -  219 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  220
    Processing Layer # -  220
    End of Layer # -  220 with outPtrs[0] = 0x7f95e4274c00
    Starting Layer # -  221
    Processing Layer # -  221
    End of Layer # -  221 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  222
    Processing Layer # -  222
    End of Layer # -  222 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  223
    Processing Layer # -  223
    End of Layer # -  223 with outPtrs[0] = 0x7f95e417e300
    Starting Layer # -  224
    Processing Layer # -  224
    End of Layer # -  224 with outPtrs[0] = 0x7f95e432be00
    Starting Layer # -  225
    Processing Layer # -  225
    End of Layer # -  225 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  226
    Processing Layer # -  226
    End of Layer # -  226 with outPtrs[0] = 0x7f95e409d300
    Starting Layer # -  227
    Processing Layer # -  227
    End of Layer # -  227 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  228
    Processing Layer # -  228
    End of Layer # -  228 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  229
    Processing Layer # -  229
    End of Layer # -  229 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  230
    Processing Layer # -  230
    End of Layer # -  230 with outPtrs[0] = 0x7f95e4550980
    Starting Layer # -  231
    Processing Layer # -  231
    End of Layer # -  231 with outPtrs[0] = 0x7f95e45f4c00
    Starting Layer # -  232
    Processing Layer # -  232
    End of Layer # -  232 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  233
    Processing Layer # -  233
    End of Layer # -  233 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  234
    Processing Layer # -  234
    End of Layer # -  234 with outPtrs[0] = 0x7f95e45dfa80
    Starting Layer # -  235
    Processing Layer # -  235
    End of Layer # -  235 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  236
    Processing Layer # -  236
    End of Layer # -  236 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  237
    Processing Layer # -  237
    End of Layer # -  237 with outPtrs[0] = 0x7f95e46ae000
    Starting Layer # -  238
    Processing Layer # -  238
    End of Layer # -  238 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  239
    Processing Layer # -  239
    End of Layer # -  239 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  240
    Processing Layer # -  240
    End of Layer # -  240 with outPtrs[0] = 0x7f95e45c5100
    Starting Layer # -  241
    Processing Layer # -  241
    End of Layer # -  241 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  242
    Processing Layer # -  242
    End of Layer # -  242 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  243
    Processing Layer # -  243
    End of Layer # -  243 with outPtrs[0] = 0x7f95e45c5100
    Starting Layer # -  244
    Processing Layer # -  244
    End of Layer # -  244 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  245
    Processing Layer # -  245
    End of Layer # -  245 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  246
    Processing Layer # -  246
    End of Layer # -  246 with outPtrs[0] = 0x7f95e45aa780
    Starting Layer # -  247
    Processing Layer # -  247
    End of Layer # -  247 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  248
    Processing Layer # -  248
    End of Layer # -  248 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  249
    Processing Layer # -  249
    End of Layer # -  249 with outPtrs[0] = 0x7f95e457ac80
    Starting Layer # -  250
    Processing Layer # -  250
    End of Layer # -  250 with outPtrs[0] = 0x7f95e45f4c00
    Starting Layer # -  251
    Processing Layer # -  251
    End of Layer # -  251 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  252
    Processing Layer # -  252
    End of Layer # -  252 with outPtrs[0] = 0x7f95e4526680
    Starting Layer # -  253
    Processing Layer # -  253
    End of Layer # -  253 with outPtrs[0] = 0x7f95e46ae000
    Starting Layer # -  254
    Processing Layer # -  254
    End of Layer # -  254 with outPtrs[0] = 0x7f95e494de80
    Starting Layer # -  255
    Processing Layer # -  255
    End of Layer # -  255 with outPtrs[0] = 0x7f95e495fa00
    Starting Layer # -  256
    Processing Layer # -  256
    End of Layer # -  256 with outPtrs[0] = 0x7f95e44fc380
    Starting Layer # -  257
    Processing Layer # -  257
    End of Layer # -  257 with outPtrs[0] = 0x7f95e46ae000
    Starting Layer # -  258
    Processing Layer # -  258
    End of Layer # -  258 with outPtrs[0] = 0x7f95e495fa00
    Starting Layer # -  259
    Processing Layer # -  259
    End of Layer # -  259 with outPtrs[0] = 0x7f95e46e3280
    Starting Layer # -  260
    Processing Layer # -  260
    End of Layer # -  260 with outPtrs[0] = 0x7f95e4971580
    Starting Layer # -  261
    Processing Layer # -  261
    End of Layer # -  261 with outPtrs[0] = 0x7f95e4991100
    Starting Layer # -  262
    Processing Layer # -  262
    End of Layer # -  262 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  263
    Processing Layer # -  263
    End of Layer # -  263 with outPtrs[0] = 0x7f95e42f3a00
    Starting Layer # -  264
    Processing Layer # -  264
    End of Layer # -  264 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  265
    Processing Layer # -  265
    End of Layer # -  265 with outPtrs[0] = 0x7f95e4991100
    Starting Layer # -  266
    Processing Layer # -  266
    End of Layer # -  266 with outPtrs[0] = 0x7f95e4971580
    Starting Layer # -  267
    Processing Layer # -  267
    End of Layer # -  267 with outPtrs[0] = 0x7f95e402cb00
    Starting Layer # -  268
    Processing Layer # -  268
    End of Layer # -  268 with outPtrs[0] = 0x7f95e447d600
    Starting Layer # -  269
    Processing Layer # -  269
    End of Layer # -  269 with outPtrs[0] = 0x7f95e478be80
    Starting Layer # -  270
    Processing Layer # -  270
    End of Layer # -  270 with outPtrs[0] = 0x7f95e49b0c80
    Starting Layer # -  271
    Processing Layer # -  271
    End of Layer # -  271 with outPtrs[0] = 0x7f95e4a28680
    Starting Layer # -  272
    Processing Layer # -  272
    End of Layer # -  272 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  273
    Processing Layer # -  273
    End of Layer # -  273 with outPtrs[0] = 0x7f95e3c29f80
    Starting Layer # -  274
    Processing Layer # -  274
    End of Layer # -  274 with outPtrs[0] = 0x7f95e3f3d780
    Starting Layer # -  275
    Processing Layer # -  275
    End of Layer # -  275 with outPtrs[0] = 0x7f95e4a28680
    Starting Layer # -  276
    Processing Layer # -  276
    End of Layer # -  276 with outPtrs[0] = 0x7f95e49b0c80
    Starting Layer # -  277
    Processing Layer # -  277
    End of Layer # -  277 with outPtrs[0] = 0x7f95e36c0580
    Starting Layer # -  278
    Processing Layer # -  278
    End of Layer # -  278 with outPtrs[0] = 0x7f95e3f3d780
    Starting Layer # -  279
    Processing Layer # -  279
    End of Layer # -  279 with outPtrs[0] = 0x7f95e4aa0080
    Starting Layer # -  280
    Processing Layer # -  280
    End of Layer # -  280 with outPtrs[0] = 0x7f95e4c62080
    Starting Layer # -  281
    Processing Layer # -  281
    End of Layer # -  281 with outPtrs[0] = 0x7f95e4e32300
    Starting Layer # -  282
    Processing Layer # -  282
    End of Layer # -  282 with outPtrs[0] = 0x7f95e27abe80
    Starting Layer # -  283
    Processing Layer # -  283
    End of Layer # -  283 with outPtrs[0] = 0x7f95e2b2fe80
    Starting Layer # -  284
    Processing Layer # -  284
    End of Layer # -  284 with outPtrs[0] = 0x7f95e34f0300
    Starting Layer # -  285
    Processing Layer # -  285
    End of Layer # -  285 with outPtrs[0] = 0x7f95e4e32300
    Starting Layer # -  286
    Processing Layer # -  286
    End of Layer # -  286 with outPtrs[0] = 0x7f95e4c62080
    Starting Layer # -  287
    Processing Layer # -  287
    End of Layer # -  287 with outPtrs[0] = 0x7f95e27abe80
    Starting Layer # -  288
    Processing Layer # -  288
    End of Layer # -  288 with outPtrs[0] = 0x7f95e34f0300
    Starting Layer # -  289
    Processing Layer # -  289
    End of Layer # -  289 with outPtrs[0] = 0x7f95e5002580
    Starting Layer # -  290
    Processing Layer # -  290
    End of Layer # -  290 with outPtrs[0] = 0x7f95e570a580
    Starting Layer # -  291
    Processing Layer # -  291
    End of Layer # -  291 with outPtrs[0] = 0x7f95e57b5c00
    Starting Layer # -  292
    Processing Layer # -  292
    End of Layer # -  292 with outPtrs[0] = 0x7f966241f000
    TIDL_process is completed with handle : 2b476000
     Layer,   Layer Cycles,kernelOnlyCycles, coreLoopCycles,LayerSetupCycles,dmaPipeupCycles, dmaPipeDownCycles, PrefetchCycles,copyKerCoeffCycles,LayerDeinitCycles,LastBlockCycles, paddingTrigger,    paddingWait,LayerWithoutPad,LayerHandleCopy,   BackupCycles,  RestoreCycles,
       100,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       101,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       102,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       103,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       104,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       105,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       106,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       107,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       108,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       109,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       110,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       111,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       112,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       113,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       114,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       115,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       116,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       117,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       118,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       119,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       120,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       121,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       122,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       123,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       124,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       125,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       126,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       127,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       128,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       129,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       130,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       131,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       132,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       133,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       134,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       135,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       136,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       137,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       138,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       139,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       140,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       141,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       142,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       143,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       144,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       145,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       146,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       147,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       148,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       149,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       150,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       151,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       152,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       153,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       154,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       155,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       156,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       157,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       158,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       159,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       160,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       161,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       162,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       163,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       164,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       165,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       166,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       167,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       168,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       169,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       170,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       171,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       172,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       173,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       174,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       175,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       176,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       177,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       178,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       179,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       180,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       181,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       182,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       183,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       184,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       185,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       186,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       187,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       188,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       189,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       190,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       191,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       192,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       193,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       194,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       195,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       196,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       197,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       198,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       199,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       200,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       201,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       202,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       203,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       204,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       205,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       206,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       207,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       208,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       209,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       210,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       211,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       212,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       213,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       214,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       215,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       216,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       217,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       218,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       219,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       220,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       221,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       222,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       223,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       224,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       225,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       226,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       227,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       228,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       229,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       230,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       231,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       232,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       233,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       234,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       235,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       236,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       237,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       238,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       239,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       240,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       241,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       242,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       243,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       244,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       245,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       246,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       247,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       248,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       249,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       250,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       251,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       252,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       253,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       254,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       255,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       256,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       257,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       258,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       259,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       260,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       261,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       262,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       263,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       264,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       265,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       266,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       267,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       268,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       269,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       270,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       271,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       272,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       273,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       274,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       275,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       276,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       277,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       278,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       279,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       280,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       281,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       282,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       283,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       284,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       285,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       286,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       287,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       288,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       289,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       290,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,              0,              0,              0,              0,
       291,              0,              0,              0,              0,              0,                 0,              0,                 0,              0,              0,              0,              0,
    infer : segmentation| 100%|##########|| 1/1 [00:54<00:00, 54.00s/it]
    INFO:20231129-020016: infer completed  - segmentation_dev_Unet_V1.1_onnx - 54 sec
    SUCCESS:20231129-020016: benchmark results - {'infer_path': 'segmentation_dev_Unet_V1.1_onnx', 'accuracy_mean_iou%': 6.071408, 'num_subgraphs': 1, 'infer_time_core_ms': 53984.311582, 'infer_time_subgraph_ms': 53984.199606, 'ddr_transfer_mb': 0.0, 'perfsim_time_ms': 0.0, 'perfsim_ddr_transfer_mb': 0.0, 'perfsim_gmacs': 0.0}
    TASKS                                                       | 100%|##########|| 1/1 [04:43<00:00, 283.46s/it]
    settings: {'include_files': None, 'pipeline_type': 'accuracy', 'num_frames': 1, 'calibration_frames': 1, 'calibration_iterations': 1, 'configs_path': './configs', 'models_path': './edgeai-modelzoo/models', 'modelartifacts_path': './edgeai-benchmark/work_dirs/modelartifacts/AM68A', 'datasets_path': './dependencies/datasets', 'target_device': 'AM68A', 'target_machine': 'pc', 'run_suffix': None, 'parallel_devices': 1, 'tensor_bits': 8, 'runtime_options': {'debug_level': 2}, 'run_import': True, 'run_inference': True, 'run_missing': True, 'detection_threshold': 0.3, 'detection_top_k': 200, 'detection_nms_threshold': None, 'detection_keep_top_k': None, 'save_output': True, 'num_output_frames': 50, 'model_selection': ['segmentation_unet'], 'model_shortlist': None, 'model_exclusion': None, 'task_selection': 'segmentation', 'runtime_selection': None, 'session_type_dict': {'onnx': 'onnxrt', 'tflite': 'tflitert', 'mxnet': 'tvmdlr'}, 'dataset_type_dict': {'ade20k': 'ade_20k'}, 'dataset_selection': 'ade20k32', 'dataset_loading': True, 'config_range': None, 'enable_logging': True, 'verbose': False, 'capture_log': False, 'experimental_models': False, 'rewrite_results': False, 'with_udp': False, 'flip_test': False, 'model_transformation_dict': None, 'report_perfsim': False, 'tidl_offload': True, 'input_optimization': None, 'run_dir_tree_depth': None, 'settings_file': 'settings_import_on_pc.yaml', 'basic_keys': ['include_files', 'pipeline_type', 'num_frames', 'calibration_frames', 'calibration_iterations', 'configs_path', 'models_path', 'modelartifacts_path', 'datasets_path', 'target_device', 'target_machine', 'run_suffix', 'parallel_devices', 'tensor_bits', 'runtime_options', 'run_import', 'run_inference', 'run_missing', 'detection_threshold', 'detection_top_k', 'detection_nms_threshold', 'detection_keep_top_k', 'save_output', 'num_output_frames', 'model_selection', 'model_shortlist', 'model_exclusion', 'task_selection', 'runtime_selection', 'session_type_dict', 'dataset_type_dict', 'dataset_selection', 'dataset_loading', 'config_range', 'enable_logging', 'verbose', 'capture_log', 'experimental_models', 'rewrite_results', 'with_udp', 'flip_test', 'model_transformation_dict', 'report_perfsim', 'tidl_offload', 'input_optimization', 'run_dir_tree_depth', 'settings_file'], 'dataset_cache': None}
    results found for 6 models
    Report generated at ./edgeai-benchmark/work_dirs/modelartifacts/AM68A
    Also which flow you are using for model artifacts generation (TIDL-RT or OSRT), what sdk version you are using ?
    We are using OSRT, specifically ONNX runtime. And, our SDK version is 8.6.
    Ahmed
  • Thanks for sharing the logs.
    Can you share SDK tag you are using for tidl tools repo and if its possible to share the model for our debugging purpose.
  • We are using edgeai-benchmark for artifacts generation with version 8.6. In the documentation, it is mentioned has edgeai-benchmark internally downloads and uses tidl-tools.
    You can access the model on this drive link,
    https://drive.google.com/file/d/1v1EZUXn_gaA4mui6ajmec6UQ7cLYKkh1/view?usp=sharing
    Ahmed
  • Hi Pratik,
    Is there any updates on this issue?
    Ahmed
    We have added few fixes in our recent sdk, this could have addressed TIDL_E_DATAFLOW_INFO_NULL issue.
    Can you try out experiment of model import on 9.1 and revert with the observation.
