Other Parts Discussed in Thread: AM6442, AM6422, AM6412, AM6411
HI
We are using AM6421 with Procesoor sdk 09.00.0003.
We have changed the dts file as per our requirement.
We want to use R5F0_0 and R5F1_0 core in linux to run applicatopns. from linux.
Below is the boot log and remoteproc output.
We are not able to see any R5F cores in remoteproc .PLease help us in solving ttheissue.
BootLog output:
U-Boot SPL 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000) EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 Resetting on cold boot to workaround ErrataID:i2331 Please resend tiboot3.bin in case of UART/DFU boot resetting ... U-Boot SPL 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000) EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)') SPL initial stack usage: 13376 bytes Trying to boot from MMC2 Authentication passed Authentication passed Authentication passed Authentication passed Loading Environment from MMC... *** Warning - No MMC card found, using default environment Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 00:42:57, Jan 13 2023 I/TC: I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000) EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)') Trying to boot from MMC2 Authentication passed Authentication passed U-Boot 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000) SoC: AM64X SR2.0 HS-FS Model: Texas Instruments AM642 EVM EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 DRAM: 2 GiB Core: 59 devices, 29 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 574 bytes read in 31 ms (17.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... 22622720 bytes read in 968 ms (22.3 MiB/s) 56995 bytes read in 35 ms (1.6 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK Working FDT set to 8feef000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.33-rt11celstream-v1.0-00001-g3ab301d00947-dirty (admin1@admin1-Latitude-3420) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #2 SMP PREEMPT Mon Dec 11 15:32:50 IST 2023 [ 0.000000] Machine model: Texas Instruments AM642 EVM-Celstream [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xffbf1a00-0xffbf3fff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a57fffff] [ 0.000000] node 0: [mem 0x00000000a5800000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] cma: Reserved 32 MiB at 0x00000000fba00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 20 pages/cpu s43560 r8192 d30168 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=0120bc4b-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1886768K/2097152K available (13568K kernel code, 1356K rwdata, 4448K rodata, 2560K init, 543K bss, 177616K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008621] Console: colour dummy device 80x25 [ 0.013258] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023940] pid_max: default: 32768 minimum: 301 [ 0.028729] LSM: Security Framework initializing [ 0.033581] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041166] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.051222] cblist_init_generic: Setting adjustable number of callback queues. [ 0.058700] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.065019] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.071549] rcu: Hierarchical SRCU implementation. [ 0.071552] rcu: Max phase no-delay instances is 1000. [ 0.071620] printk: bootconsole [ns16550a0] printing thread started [ 0.088508] Platform MSI: msi-controller@1820000 domain created [ 0.088801] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.089687] EFI services will not be available. [ 0.090017] smp: Bringing up secondary CPUs ... [ 5.123636] CPU1: failed to come online [ 5.123650] CPU1: failed in unknown state : 0x0 [ 5.123748] smp: Brought up 1 node, 1 CPU [ 5.123755] SMP: Total of 1 processors activated. [ 5.123765] CPU features: detected: 32-bit EL0 Support [ 5.123768] CPU features: detected: 32-bit EL1 Support [ 5.123777] CPU features: detected: CRC32 instructions [ 5.123883] CPU: All CPU(s) started at EL2 [ 5.123909] alternatives: applying system-wide alternatives [ 5.126126] devtmpfs: initialized [ 5.148183] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 5.148210] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 5.149685] pinctrl core: initialized pinctrl subsystem [ 5.150347] DMI not present or invalid. [ 5.151082] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 5.156633] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 5.156813] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 5.157002] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 5.157108] audit: initializing netlink subsys (disabled) [ 5.158028] thermal_sys: Registered thermal governor 'step_wise' [ 5.158039] thermal_sys: Registered thermal governor 'power_allocator' [ 5.158101] cpuidle: using governor menu [ 5.158340] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 5.158384] ASID allocator initialised with 65536 entries [ 5.159317] Serial: AMBA PL011 UART driver [ 5.164024] audit: type=2000 audit(5.120:1): state=initialized audit_enabled=0 res=1 [ 5.188790] KASLR disabled due to lack of seed [ 5.212379] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 5.212393] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GI/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled iB page [ 5.212399] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 5.212402] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 5.212407] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 5.212411] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 5.212416] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 5.212419] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 5.224700] ACPI: Interpreter disabled. [ 5.225171] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected [ 5.232488] iommu: Default domain type: Translated [ 5.232500] iommu: DMA domain TLB invalidation policy: strict mode [ 5.232864] SCSI subsystem initialized [ 5.233390] usbcore: registered new interface driver usbfs [ 5.233433] usbcore: registered new interface driver hub [ 5.233463] usbcore: registered new device driver usb [ 5.234135] pps_core: LinuxPPS API ver. 1 registered [ 5.234141] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 5.234159] PTP clock support registered [ 5.234295] EDAC MC: Ver: 3.0.0 [ 5.235502] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100 [ 5.235763] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100 [ 5.235926] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100 [ 5.236708] FPGA manager framework [ 5.237674] vgaarb: loaded [ 5.240916] clocksource: Switched to clocksource arch_sys_counter [ 5.241220] VFS: Disk quotas dquot_6.6.0 [ 5.241269] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 5.672597] printk: console [ttyS2] enabled [ 5.672602] printk: bootconsole [ns16550a0] disabled [ 5.672624] printk: bootconsole [ns16550a0] printing thread stopped [ 5.674768] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006 [ 5.674931] am65-cpsw-nuss 8000000.ethernet: /bus@f4000/ethernet@8000000/ethernet-ports/port@1 read phy-mode err -22 [ 5.674990] printk: console [ttyS2] printing thread started [ 5.679299] am65-cpsw-nuss: probe of 8000000.ethernet failed with error -22 [ 5.728360] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0 [ 5.740871] mmc0: CQHCI version 5.10 [ 5.745461] mmc1: CQHCI version 5.10 [ 5.761150] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present! [ 5.787667] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 5.788671] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 5.790045] Waiting for root device PARTUUID=0120bc4b-02... [ 5.843096] mmc1: new high speed SDHC card at address aaaa [ 5.844062] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 5.855958] mmcblk1: p1 p2 [ 5.890273] mmc0: Command Queue Engine enabled [ 5.890307] mmc0: new HS200 MMC card at address 0001 [ 5.891184] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 5.897496] mmcblk0: p1 p2 [ 5.898317] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 5.899635] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 5.906870] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0) [ 5.938347] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 5.938454] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 5.955739] devtmpfs: mounted [ 5.957581] Freeing unused kernel memory: 2560K [ 5.957745] Run /sbin/init as init process [ 6.430560] systemd[1]: System time before build time, advancing clock. [ 6.696479] NET: Registered PF_INET6 protocol family [ 6.702895] Segment Routing with IPv6 [ 6.702940] In-situ OAM (IOAM) with IPv6 [ 6.772373] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 6.804269] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.04! [ 6.860366] systemd[1]: Hostname set to <am64xx-evm>. [ 7.115162] systemd-sysv-generator[132]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.144306] systemd-sysv-generator[132]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.144497] systemd-sysv-generator[132]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.151800] systemd-sysv-generator[132]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.157314] systemd-sysv-generator[132]: SysV service '/etc/init.d/resize_rootfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.159447] systemd-sysv-generator[132]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.160552] systemd-sysv-generator[132]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.161582] systemd-sysv-generator[132]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.164643] systemd-sysv-generator[132]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 7.664484] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring. [ 7.679844] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring. [ 7.747328] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 7.845942] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 7.953172] systemd[1]: Queued start job for default target Graphical Interface. [ 8.028562] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 8.052866] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 8.076839] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ OK ] Created slice User and Session Slic[ 8.104074] systemd[1]: Created slice User and Session Slice. e. [ OK ] Started Dispatch Password …ts to [ 8.125594] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. Console Directory Watch. [ OK ] Started Forward Password R…uests [ 8.149531] systemd[1]: Started Forward Password Requests to Wall Directory Watch. to Wall Directory Watch. [ OK ] Reached target Path Units.[ 8.173650] systemd[1]: Reached target Path Units. [ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems. [0m. [ OK ] Reached target Slice Units.[ 8.213211] systemd[1]: Reached target Slice Units. [ OK ] Reached target Swaps.[ 8.233224] systemd[1]: Reached target Swaps. [ OK ] Listening on RPCbind Server Activat[ 8.311696] systemd[1]: Listening on RPCbind Server Activation Socket. ion Socket. [ OK ] Reached target RPC Port Mapper.[ 8.333297] systemd[1]: Reached target RPC Port Mapper. [ OK ] Listening on Process Core Dump Sock[ 8.363692] systemd[1]: Listening on Process Core Dump Socket. et. [ OK ] Listening on initctl Compatibility [ 8.385734] systemd[1]: Listening on initctl Compatibility Named Pipe. Named Pipe. [ OK ] Listening on Journal Audit Socket 8.410299] systemd[1]: Listening on Journal Audit Socket. 0m. [ OK ] Listening on Journal Socket (/dev/l[ 8.434017] systemd[1]: Listening on Journal Socket (/dev/log). og). [ OK ] Listening on Journal Socket.[ 8.458085] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Network Service Netlin[ 8.478432] systemd[1]: Listening on Network Service Netlink Socket. k Socket. [ OK ] Listening on udev Control Socket 8.502203] systemd[1]: Listening on udev Control Socket. m. [ OK ] Listening on udev Kernel Socket[ 8.525912] systemd[1]: Listening on udev Kernel Socket. . [ OK ] Listening on User Database Manager [ 8.549997] systemd[1]: Listening on User Database Manager Socket. Socket. Mounting Huge Pages File System...[ 8.585763] systemd[1]: Mounting Huge Pages File System... Mounting POSIX Message Queue File System..[ 8.617642] systemd[1]: Mounting POSIX Message Queue File System... . Mounting Kernel Debug File System...[ 8.649681] systemd[1]: Mounting Kernel Debug File System... [ 8.665955] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). Mounting Temporary Directory /tmp...[ 8.697739] systemd[1]: Mounting Temporary Directory /tmp... Starting Create List of Static Device Nodes 8.733867] systemd[1]: Starting Create List of Static Device Nodes... m... Starting Load Kernel Module configfs...[ 8.773860] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module drm...[ 8.817899] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module fuse...[ 8.854113] systemd[1]: Starting Load Kernel Module fuse... [ 8.924796] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 8.945700] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). Starting Journal Service... [ 8.978028] systemd[1]: Starting Journal Service... Starting Load Kernel Modules...[ 9.058337] systemd[1]: Starting Load Kernel Modules... Starting Generate network …ts from Kernel co[ 9.094424] systemd[1]: Starting Generate network units from Kernel command line... mmand line... [ 9.123875] fuse: init (API version 7.37) Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems... [0m... [ 9.166594] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ OK ] Mounted Huge Pages File System.[ 9.222589] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File Sy[ 9.234983] systemd[1]: Mounted POSIX Message Queue File System. stem. [ OK ] Mounted Kernel Debug File System 9.266504] systemd[1]: Mounted Kernel Debug File System. m. [ OK ] Mounted Temporary Directory /tmp 9.284758] systemd[1]: Mounted Temporary Directory /tmp. m. [ OK ] Finished Create List of Static Devi[ 9.319843] systemd[1]: Finished Create List of Static Device Nodes. ce Nodes. [ OK ] Finished Load Kernel Module configf[ 9.351585] systemd[1]: modprobe@configfs.service: Deactivated successfully. s. [ OK ] Finished Load Kernel Module drm[ 9.356051] systemd[1]: Finished Load Kernel Module configfs. . [ OK ] Finished Load Kernel Module fuse 9.383923] systemd[1]: modprobe@drm.service: Deactivated successfully. m. [ 9.390219] systemd[1]: Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Modules.[ 9.419908] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ OK ] Finished Generate network units fro[ 9.422795] systemd[1]: Finished Load Kernel Module fuse. m Kernel command line. [ 9.460087] systemd[1]: Finished Load Kernel Modules. [ OK ] Started RPC Bind.[ 9.483107] systemd[1]: Finished Generate network units from Kernel command line. [ 9.530590] systemd[1]: Started RPC Bind. [ 9.565143] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. Mounting FUSE Control File System...[ 9.587962] systemd[1]: Mounting FUSE Control File System... Mounting Kernel Configuration File System.[ 9.645783] systemd[1]: Mounting Kernel Configuration File System... .. Starting Apply Kernel Variables...[ 9.686198] systemd[1]: Starting Apply Kernel Variables... [ OK ] Finished Remount Root and Kernel Fi[ 9.719624] systemd[1]: Finished Remount Root and Kernel File Systems. le Systems. [ OK ] Mounted FUSE Control File System 9.742213] systemd[1]: Mounted FUSE Control File System. m. [ OK ] Mounted Kernel Configuration File S[ 9.766166] systemd[1]: Mounted Kernel Configuration File System. ystem. [ 9.798707] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc). [ 9.799045] systemd[1]: Platform Persistent Storage Archival was skipped because of a failed condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). Starting Create Static Device Nodes in /dev 9.799294] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc). m... [ 9.846563] systemd[1]: Starting Create Static Device Nodes in /dev... [ OK ] Finished Apply Kernel Variables[ 9.920028] systemd[1]: Finished Apply Kernel Variables. . [ OK ] Started Journal Service.[ 9.973192] systemd[1]: Started Journal Service. Starting Flush Journal to Persistent Storage... [ 10.091457] systemd-journald[146]: Received client request to flush runtime journal. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 10.243887] audit: type=1334 audit(1651167748.812:2): prog-id=5 op=LOAD [ 10.244308] audit: type=1334 audit(1651167748.812:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Finished Record System Boot/Shutdown in UTMP. [ 11.416955] random: crng init done [ OK ] Finished Load/Save Random Seed. [ OK ] Finished Coldplug All udev Devices. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Timer service to update the IP on OLED each 10s. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. Starting Weston socket... Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Listening on Weston socket. [ OK ] Reached target Socket Units. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... Starting startwlanap... Starting startwlansta... [ 12.968345] audit: type=1334 audit(1651491912.100:4): prog-id=7 op=LOAD [ 12.980244] audit: type=1334 audit(1651491912.112:5): prog-id=8 op=LOAD Starting User Login Management... [ OK ] Started TEE Supplicant. Starting telnetd.service... [ OK ] Started startwlansta. [ OK ] Started startwlanap. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Reached target Preparation for Network. Starting Network Configuration... [ OK ] Started telnetd.service. [ 13.395744] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Starting LSB: Expand Rootfs of boot device... [ 13.625067] startwlansta.sh[221]: modprobe: FATAL: Module wl18xx not found in directory /lib/modules/6.1.33-rt11celstream-v1.0-00001-g3ab301d00947-dirty [ 13.683765] startwlansta.sh[222]: modprobe: FATAL: Module wlcore_sdio not found in directory /lib/modules/6.1.33-rt11celstream-v1.0-00001-g3ab301d00947-dirty [ OK ] Started LSB: Expand Rootfs of boot device. [ OK ] Started Network Configuration. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ OK ] Started User Login Management. [ 15.378821] CAN device driver interface [ OK ] Found device /dev/ttyS2. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma…ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland…ositor, as a system service... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ 17.683581] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode [ 17.721113] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 17.721423] mdio_bus 300b2400.mdio: MDIO device at address 15 is missing. [ 17.870404] audit: type=1334 audit(1651491917.004:6): prog-id=9 op=LOAD [ 17.880521] audit: type=1334 audit(1651491917.016:7): prog-id=10 op=LOAD Starting User Database Manager... [ 17.950395] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000 [ 17.990945] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 18.004024] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ 18.027231] remoteproc remoteproc0: 5000000.m4fss is available [ 18.049237] remoteproc remoteproc0: Direct firmware load for am64-mcu-m4f0_0-fw failed with error -2 [ 18.049273] remoteproc remoteproc0: powering up 5000000.m4fss [ 18.049319] remoteproc remoteproc0: Direct firmware load for am64-mcu-m4f0_0-fw failed with error -2 [ 18.049329] remoteproc remoteproc0: request_firmware failed: -2 [ 18.972598] k3_r5_rproc bus@f4000:r5fss@78000000: MCU cluster requires both R5F cores to be enabled but num_cores is set to = 1 [ 19.006085] k3_r5_rproc bus@f4000:r5fss@78400000: MCU cluster requires both R5F cores to be enabled but num_cores is set to = 1 [ OK ] Started User Database Manager. [ 19.478916] m_can_platform 20701000.can: m_can device registered (irq=502, version=32) [ 19.583425] m_can_platform 20711000.can: m_can device registered (irq=503, version=32) [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ 20.011434] audit: type=1006 audit(1651491919.144:8): pid=276 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 20.025727] audit: type=1300 audit(1651491919.144:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcc872cc8 a2=4 a3=ffff9983e020 items=0 ppid=1 pid=276 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 20.025800] audit: type=1327 audit(1651491919.144:8): proctitle="(systemd)" [ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon.. [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston. [ 20.736325] audit: type=1006 audit(1651491919.868:9): pid=262 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 20.736415] audit: type=1300 audit(1651491919.868:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcc872cc8 a2=4 a3=ffff9983e020 items=0 ppid=1 pid=262 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 20.749502] audit: type=1327 audit(1651491919.868:9): proctitle="(weston)" [FAILED] Failed to start Weston, a …mpositor, as a system service. See 'systemctl status weston.service' for details. [DEPEND] Dependency failed for Matrix GUI. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am64xx-evm - Arago 2023.04 am64xx-evm - am64xx-evm login: [ 25.285643] remoteproc remoteproc2: 30034000.pru is available [ 25.295154] remoteproc remoteproc3: 30004000.rtu is available [ 25.330190] remoteproc remoteproc1: 3000a000.txpru is available [ 25.357387] remoteproc remoteproc4: 30038000.pru is available [ 25.379314] remoteproc remoteproc5: 30006000.rtu is available [ 25.401485] remoteproc remoteproc6: 3000c000.txpru is available [ 25.421365] remoteproc remoteproc7: 300b4000.pru is available [ 25.441134] remoteproc remoteproc8: 30084000.rtu is available [ 25.473107] remoteproc remoteproc9: 3008a000.txpru is available [ 25.488010] remoteproc remoteproc10: 300b8000.pru is available [ 25.505797] remoteproc remoteproc11: 30086000.rtu is available [ 25.521944] remoteproc remoteproc12: 3008c000.txpru is available [ 27.618294] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [ 35.599243] platform mdio-mux-1: deferred probe pending am64xx-evm login: root [ 117.828209] audit: type=1006 audit(1651492016.960:10): pid=580 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 117.828426] audit: type=1300 audit(1651492016.960:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffcc872cc8 a2=1 a3=ffff9983e020 items=0 ppid=1 pid=580 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 117.842155] audit: type=1327 audit(1651492016.960:10): proctitle="(systemd)" [ 117.914637] audit: type=1334 audit(1651492017.048:11): prog-id=11 op=LOAD [ 117.915420] audit: type=1300 audit(1651492017.048:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe1c4dd10 a2=78 a3=0 items=0 ppid=1 pid=580 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 117.916058] audit: type=1327 audit(1651492017.048:11): proctitle="(systemd)" [ 117.916450] audit: type=1334 audit(1651492017.048:12): prog-id=11 op=UNLOAD [ 117.917929] audit: type=1334 audit(1651492017.048:13): prog-id=12 op=LOAD [ 117.918392] audit: type=1300 audit(1651492017.048:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe1c4ddb0 a2=78 a3=0 items=0 ppid=1 pid=580 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 117.918433] audit: type=1327 audit(1651492017.048:13): proctitle="(systemd)" root@am64xx-evm:~# root@am64xx-evm:~# head /sys/class/remoteproc/remoteproc*/name ==> /sys/class/remoteproc/remoteproc0/name <== 5000000.m4fss ==> /sys/class/remoteproc/remoteproc1/name <== 3000a000.txpru ==> /sys/class/remoteproc/remoteproc10/name <== 300b8000.pru ==> /sys/class/remoteproc/remoteproc11/name <== 30086000.rtu ==> /sys/class/remoteproc/remoteproc12/name <== 3008c000.txpru ==> /sys/class/remoteproc/remoteproc2/name <== 30034000.pru ==> /sys/class/remoteproc/remoteproc3/name <== 30004000.rtu ==> /sys/class/remoteproc/remoteproc4/name <== 30038000.pru ==> /sys/class/remoteproc/remoteproc5/name <== 30006000.rtu ==> /sys/class/remoteproc/remoteproc6/name <== 3000c000.txpru ==> /sys/class/remoteproc/remoteproc7/name <== 300b4000.pru ==> /sys/class/remoteproc/remoteproc8/name <== 30084000.rtu ==> /sys/class/remoteproc/remoteproc9/name <== 3008a000.txpru
Thank You
