Other Parts Discussed in Thread: AM62P
I am trying to use Deep Sleep as a low power mode on AM62x/AM62A/AM62P devices using SDK 9.0+. How can we debug Deep Sleep using SYSFW Trace?
Where do we start?
The first place to start is reviewing the SDK Documentation for the SYSFW Trace: https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_01_00_08/exports/docs/linux/How_to_Guides/Host/SYSFW_Trace_Parser.html#
The TISCI API will trace message transactions in/out of the DM Firmware and dump a series of representative hex values. These hex values are not in Human Readable form, so the SYSFW Trace Parser Script helps translates the hex values.
Since the DM Firmware is running on the R5F Core, the transactions can be found on WKUP UART port (/dev/ttyUSB2).
The SYSFW Trace Parser Script can be found in:
<SDK Install Directory>/bin/sysfw_trace_parser.py
Before using the parser, there are steps required to enable the SYSFW trace to include Power Management & its respective LPM sequencing:
1. Modify the board config file
2. Modify Firmware Driver ti_sci.c
3. Add the Device Tree overlay of Wake Up Sources (Optional depending on wake-up source)
Changing the Board Configuration File
The path for the Board Configuration File:
<SDK Install Directory>/board-support/ti-u-boot-<version>/board/ti/<am62x/am62ax/am62px>/board-cfg.yaml
The changes required to the board-cfg.yaml file:
diff --git a/board/ti/am62x/board-cfg.yaml b/board/ti/am62x/board-cfg.yaml
index a26ef55bd45b..d9bfbdbb480e 100644
--- a/board/ti/am62x/board-cfg.yaml
+++ b/board/ti/am62x/board-cfg.yaml
@@ -32,5 +32,5 @@ board-cfg:
subhdr:
magic: 0x020C
- trace_dst_enables : 0x00
- trace_src_enables : 0x00
+ trace_dst_enables : 0x0d
+ trace_src_enables : 0x3f
Now, there are no more changes required on the U-Boot side. Re-build U-Boot following these instructions:
Make sure to copy the target images.
Modifying ti_sci.c
The path to ti_sci.c:
<SDK Install Directory>/board-support/ti-linux-kernel-<version>/drivers/firmware/ti_sci.c
The changes required:
diff --git a/drivers/firmware/ti_sci.c b/drivers/firmware/ti_sci.c
index 8e03488ccc5f..be9ed728044f 100644
--- a/drivers/firmware/ti_sci.c
+++ b/drivers/firmware/ti_sci.c
@@ -1881,6 +1881,9 @@ static int ti_sci_cmd_set_io_isolation(const struct ti_sci_handle *handle,
struct device *dev;
int ret = 0;
+ /*HACK: return without doing anything; required for Sysfw LPM trace */
+ return ret;
if (IS_ERR(handle))
return PTR_ERR(handle);
if (!handle)
Please note that modifying the io_isolation code will impact the functionality of any wake up source that uses IO Daisy Chain like Main Domain UART. Refer to the TRM section 6.2.4.11 I/O Power Management and Daisy Chaining for more information: https://www.ti.com/lit/ug/spruiv7b/spruiv7b.pdf.
Now, the Image needs to be re-compiled following these instructions:
Make sure to copy the new Image.
Adding the Device Tree Overlay of Wake Up Sources
Review the Documentation for adding device tree overlays which is the same for each device: https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_01_00_08/exports/docs/linux/How_to_Guides/Target/How_to_enable_DT_overlays_in_linux.html
Under boot/uEnv.txt, add this line:
name_overlays=k3-am62x-sk-lpm-wkup-sources.dtbo
Please note that the overlay file name may change in later versions of the SDK.
Generating Logs & Running the Parser Script
Boot the device with the new changes made. To isolate the Deep Sleep related logs, only start running the parser script right before entering deep sleep.
On the EVM terminal, get it ready to enter deep sleep.
root@am62xx-evm:~# echo mem > /sys/power/state
On the Host terminal, setup the script:
HOST:~$ cd <SDK Install Directory>/bin HOST:~$ python3 sysfw_trace_parser.py -d /dev/ttyUSB2 -o <output file> -Tv <version> ###For this example, this command was ran: HOST:~$ python3 sysfw_trace_parser.py -d /dev/ttyUSB2 -o am62x_deepsleep_9.1.txt -Tv 0x03007
Once both terminals are ready to go, run the Parser Script, then Deep Sleep Command. Send a keyboard interrupt (Ctrl + C) to the parser script once the device wakes up. The Human-Readable logs will be in the designated output file.
Alternatively, the parser script can write the log output directly to the terminal:
HOST:~$ python3 sysfw_trace_parser.py -d /dev/ttyUSB2 -O -Tv 0x03007
Sometimes the Parser results in an error:
invalid literal for int() with base 16: '0x6C001700H0x6C001820'
A workaround is to copy the logs directly from /dev/ttyUSB2 and save it as the input file. The error is caused by the hex values not creating a new line.
Then run the parser script with the input file (NOT /dev/ttyUSB2) and select the preferred output method:
HOST:~$ python3 sysfw_trace_parser.py -l <input hex log file> -o <output file> -Tv 0x03007 HOST:~$ python3 sysfw_trace_parser.py -l <input hex log file> -O -Tv 0x03007
How to Interpret the Logs
What does each of the Action IDs mean?
Resource Managment: https://software-dl.ti.com/tisci/esd/latest/4_trace/trace.html#resource-management-action-ids-sub-action-ids
Power Managment: https://software-dl.ti.com/tisci/esd/latest/4_trace/trace.html#power-management-action-ids
What does each Clock ID mean?
Clock ID: https://software-dl.ti.com/tisci/esd/latest/5_soc_doc/am62x/clocks.html#clocks-for-board0-device
What does each Device ID mean?
Device ID: https://downloads.ti.com/tisci/esd/latest/5_soc_doc/am62x/devices.html#enumeration-of-device-ids
What does each Host ID mean?
Host ID: https://downloads.ti.com/tisci/esd/latest/5_soc_doc/am62x/hosts.html#enumeration-of-host-ids
Other IDs can be found here: https://downloads.ti.com/tisci/esd/latest/5_soc_doc/index.html#am62x
Sample log of AM62x Entering Deep Sleep
Configuring trace data version to: 0x03007
0x6180010D: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x0000010D
0x61C00087: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 135 Clock ID: 0 #Device ID 135 = A53_Core0 set to 1.4GHz
0x61314C9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 83 Clock Frequency{Exponent}: 24
0x6180010C: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x0000010C
0x6180010E: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x0000010E
0x61C00087: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 135 Clock ID: 0 #Device ID 135 = A53_Core0 set to 200MHz
0x612B7C9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 95 Clock Frequency{Exponent}: 21
0x61C00087: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 135 Clock ID: 0 #Device ID 135 = A53_Core0 set to 1.25GHz
0x6131289D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 74 Clock Frequency{Exponent}: 24
0x612FDC9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 119 Clock Frequency{Exponent}: 23
0x612F7C9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 95 Clock Frequency{Exponent}: 23
0x612F1C9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 71 Clock Frequency{Exponent}: 23
0x612D7C9D: Power Management: CLOCK_SET_RATE(Clock Frequency has been changed: significand * 2^Exponent Hz): Clock ID: 157 Clock Frequency{significand}: 95 Clock Frequency{Exponent}: 22
0x61800100: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x00000100
0x61C018B8: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 184 Clock ID: 6
0x62000001: Power Management: MSG_PARAM_VAL(TI-SCI message content: value): Target Value: 0x00000001
0x61C020B8: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 184 Clock ID: 8
0x61800200: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x00000200
0x61C00067: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 103 Clock ID: 0
0x62000002: Power Management: MSG_PARAM_VAL(TI-SCI message content: value): Target Value: 0x00000002
0x62D00059: Power Management: PD_GET(Power Domain Get): PSC ID: 1 Power domain ID: 0 PD Usage Count: 89
0x64188027: Power Management: RETENTION_GET(Retention Get): PSC ID: 1 LPSC ID: 34 Module Retention Count: 39
0x60000067: Power Management: DEVICE_ON(Device has been Turned ON): Device ID: 103
0x63988027: Power Management: MODULE_GET(Module Get): PSC ID: 1 LPSC ID: 34 Module Use Count: 39
0x61C0183A: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 58 Clock ID: 6
0x61C0203A: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 58 Clock ID: 8
0x61C01C4B: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 75 Clock ID: 7
0x61C0204B: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 75 Clock ID: 8
0x61C01839: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 57 Clock ID: 6
0x61C02039: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 57 Clock ID: 8
0x41070000: Resource Management: RING_CONFIGURE(Configure NavSS ring): upper 16-bits of valid_params: 0x0000
0x41080004: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of valid_params: 0x0004
0x4F8A00FF: Resource Management: DEVGRP_VALIDATE(Validating device group of resource): Device group given in RM boardcfg message: 0x00FF
0x4F8B0001: Resource Management: DEVGRP_VALIDATE(Validating device group of resource): Device group of configured resource: 0x0001
0x4F80001E: Resource Management: DEVGRP_VALIDATE(Validating device group of resource): Device ID being validated: 30
0x4100001E: Resource Management: RING_CONFIGURE(Configure NavSS ring): RA device ID: 30
0x4F010013: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 19
0x4F060791: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x0791
0x4F0A000C: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): host: 12
0x41010013: Resource Management: RING_CONFIGURE(Configure NavSS ring): index: 19
0x410C0001: Resource Management: RING_CONFIGURE(Configure NavSS ring): size: 1
0x410DF76C: Resource Management: RING_CONFIGURE(Configure NavSS ring): upper 16-bits of addr_lo: 0xF76C
0x410E0000: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of addr_lo: 0x0000
0x410F0000: Resource Management: RING_CONFIGURE(Configure NavSS ring): upper 4-bits of count: 0x0
0x41100204: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of count: 0x0204
0x41110000: Resource Management: RING_CONFIGURE(Configure NavSS ring): order_id: 0
0x4F010076: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 118
0x4F060797: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x0797
0x41010076: Resource Management: RING_CONFIGURE(Configure NavSS ring): index: 118
0x410D880D: Resource Management: RING_CONFIGURE(Configure NavSS ring): upper 16-bits of addr_lo: 0x880D
0x410EA000: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of addr_lo: 0xA000
0x411001F4: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of count: 0x01F4
0x4F80001C: Resource Management: DEVGRP_VALIDATE(Validating device group of resource): Device ID being validated: 28
0x4F010007: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 7
0x4F06070A: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x070A
0x4F01000F: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 15
0x4F06070D: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x070D
0x4B4B000F: Resource Management: IRQ_RELEASE(Release interrupt route): Global event: 15
0x4BC0001C: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): IA device ID: 28
0x4F011613: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 5651
0x4F060713: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x0713
0x4BC41613: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): OES register index: 5651
0x4BC3000F: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): global event: 0x000f
0x4B83FFFF: Resource Management: IRQ_IA_OES_SET(Set OES register in Interrupt Aggregator): global event: 0xffff
0x4B80001C: Resource Management: IRQ_IA_OES_SET(Set OES register in Interrupt Aggregator): IA device ID: 28
0x4B841613: Resource Management: IRQ_IA_OES_SET(Set OES register in Interrupt Aggregator): OES register index: 5651
0x4C80001C: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): IA device ID: 28
0x4C8A0007: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): virtual interrupt: 7
0x4C8C0000: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): Virtual interrupt status bit: 0
0x4C8B000F: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): global event: 15
0x4B470000: Resource Management: IRQ_RELEASE(Release interrupt route): upper 16-bits of valid_params: 0x0000
0x4B48003C: Resource Management: IRQ_RELEASE(Release interrupt route): lower 16-bits of valid_params: 0x003C
0x4B4E001C: Resource Management: IRQ_RELEASE(Release interrupt route): Source device ID: 28
0x4B4F1613: Resource Management: IRQ_RELEASE(Release interrupt route): Source index: 5651
0x4B510007: Resource Management: IRQ_RELEASE(Release interrupt route): Virtual interrupt: 7
0x4B520000: Resource Management: IRQ_RELEASE(Release interrupt route): Virtual interrupt status bit index: 0
0x4108009F: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of valid_params: 0x009F
0x410D0000: Resource Management: RING_CONFIGURE(Configure NavSS ring): upper 16-bits of addr_lo: 0x0000
0x41100000: Resource Management: RING_CONFIGURE(Configure NavSS ring): lower 16-bits of count: 0x0000
0x4F010006: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 6
0x4F01000E: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 14
0x4B4B000E: Resource Management: IRQ_RELEASE(Release interrupt route): Global event: 14
0x4F011213: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 4627
0x4F060711: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x0711
0x4BC41213: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): OES register index: 4627
0x4BC3000E: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): global event: 0x000e
0x4B841213: Resource Management: IRQ_IA_OES_SET(Set OES register in Interrupt Aggregator): OES register index: 4627
0x4C8A0006: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): virtual interrupt: 6
0x4C8B000E: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): global event: 14
0x4B4F1213: Resource Management: IRQ_RELEASE(Release interrupt route): Source index: 4627
0x4B510006: Resource Management: IRQ_RELEASE(Release interrupt route): Virtual interrupt: 6
0x4F010005: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 5
0x4F01000D: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 13
0x4B4B000D: Resource Management: IRQ_RELEASE(Release interrupt route): Global event: 13
0x4F012400: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 9216
0x4F060718: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x0718
0x4BC42400: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): OES register index: 9216
0x4BC3000D: Resource Management: IRQ_IA_OES_GET(Get OES register configuration in Interrupt Aggregator): global event: 0x000d
0x4B842400: Resource Management: IRQ_IA_OES_SET(Set OES register in Interrupt Aggregator): OES register index: 9216
0x4C8A0005: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): virtual interrupt: 5
0x4C8B000D: Resource Management: IRQ_IA_UNMAP_VINT(Unmap an event from an IA virtual interrupt): global event: 13
0x4B4F2400: Resource Management: IRQ_RELEASE(Release interrupt route): Source index: 9216
0x4B510005: Resource Management: IRQ_RELEASE(Release interrupt route): Virtual interrupt: 5
0x4F80001A: Resource Management: DEVGRP_VALIDATE(Validating device group of resource): Device ID being validated: 26
0x4100001A: Resource Management: RING_CONFIGURE(Configure NavSS ring): RA device ID: 26
0x4F010000: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource index: 0
0x4F06068D: Resource Management: RESASG_VALIDATE_RESOURCE(RM validate resource against board configuration): Resource assignment utype: 0x068D
0x41010000: Resource Management: RING_CONFIGURE(Configure NavSS ring): index: 0
0x61C000B8: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 184 Clock ID: 0
0x62000000: Power Management: MSG_PARAM_VAL(TI-SCI message content: value): Target Value: 0x00000000
0x604000B8: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 184
0x63D58001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 22 Module Use Count: 1
0x63D88028: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 40
0x60C000BB: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 187
0x60C0008A: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 138
0x64558001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 22 Module Retention Count: 1
0x6310005A: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 90
0x64588028: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 40
0x63100059: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 89
0x61C0003A: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 58 Clock ID: 0
0x6040003A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 58
0x63D54001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 21 Module Use Count: 1
0x63D88027: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 39
0x60C000BA: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 186
0x60C00089: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 137
0x64554001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 21 Module Retention Count: 1
0x63100058: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 88
0x64588027: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 39
0x63100057: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 87
0x61C0004B: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 75 Clock ID: 0
0x6040004B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 75
0x63D70002: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 28 Module Use Count: 2
0x60C000C2: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 194
0x60C0008B: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 139
0x64570002: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 28 Module Retention Count: 2
0x63100056: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 86
0x61C0004E: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 78 Clock ID: 0
0x6040004E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 78
0x63D00016: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 0 Module Use Count: 22
0x64500015: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 0 Module Retention Count: 21
0x63100055: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 85
0x61C0004D: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 77 Clock ID: 0
0x6040004D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 77
0x63D00015: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 0 Module Use Count: 21
0x64500014: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 0 Module Retention Count: 20
0x63100054: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 84
0x61C0004F: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 79 Clock ID: 0
0x6040004F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 79
0x63C00004: Power Management: MODULE_PUT(Module Put): PSC ID: 0 LPSC ID: 0 Module Use Count: 4
0x60C000E6: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 230
0x64400004: Power Management: RETENTION_PUT(Retention Put): PSC ID: 0 LPSC ID: 0 Module Retention Count: 4
0x6300000B: Power Management: PD_PUT(Power Domain Put): PSC ID: 0 Power domain ID: 0 PD Usage Count: 11
0x61C00039: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 57 Clock ID: 0
0x60400039: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 57
0x63D50001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 20 Module Use Count: 1
0x63D88026: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 38
0x60C000B9: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 185
0x60C00088: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 136
0x64550001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 20 Module Retention Count: 1
0x63100053: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 83
0x64588026: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 38
0x63100052: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 82
0x61C0000D: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 13 Clock ID: 0
0x6040000D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 13
0x63DA4001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 41 Module Use Count: 1
0x63D88025: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 37
0x60C000B7: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 183
0x60C00038: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 56
0x60C00037: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 55
0x645A4001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 41 Module Retention Count: 1
0x63108002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 2 PD Usage Count: 2
0x64588025: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 37
0x63108001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 2 PD Usage Count: 1
0x63100051: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 81
0x61C00092: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 146 Clock ID: 0
0x60400092: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 146
0x63D88024: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 36
0x60C000DE: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 222
0x60C000D3: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 211
0x64588024: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 36
0x63100050: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 80
0x61C00095: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 149 Clock ID: 0
0x60400095: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 149
0x63C2400A: Power Management: MODULE_PUT(Module Put): PSC ID: 0 LPSC ID: 9 Module Use Count: 10
0x6442400A: Power Management: RETENTION_PUT(Retention Put): PSC ID: 0 LPSC ID: 9 Module Retention Count: 10
0x6300400A: Power Management: PD_PUT(Power Domain Put): PSC ID: 0 Power domain ID: 1 PD Usage Count: 10
0x61C000BA: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 186 Clock ID: 0
0x604000BA: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 186
0x63DCC001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 51 Module Use Count: 1
0x63D88023: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 35
0x60C000B8: Power Management: CLOCK_DISABLE(Clock has been Turned OFF): Clock ID: 184
0x645CC001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 51 Module Retention Count: 1
0x63124002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 9 PD Usage Count: 2
0x64588023: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 35
0x63124001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 9 PD Usage Count: 1
0x6310004F: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 79
0x61C0004A: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 74 Clock ID: 0
0x6040004A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 74
0x63D70001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 28 Module Use Count: 1
0x63D88022: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 34
0x64570001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 28 Module Retention Count: 1
0x6310004E: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 78
0x64588022: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 34
0x6310004D: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 77
0x60400067: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 103
0x63D88021: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 33
0x64588021: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 33
0x6310004C: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 76
0x61800201: Power Management: MSG_RECEIVED(TI-SCI message received): Message ID: 0x00000201
0x61C00009: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 9 Clock ID: 0
0x61C00088: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 136 Clock ID: 0
0x60400088: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 136
0x63DB8001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 46 Module Use Count: 1
0x63DA8005: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 42 Module Use Count: 5
0x645B8001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 46 Module Retention Count: 1
0x63114002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 5 PD Usage Count: 2
0x645A8004: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 42 Module Retention Count: 4
0x63114001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 5 PD Usage Count: 1
0x6310C005: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 5
0x61C00089: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 137 Clock ID: 0
0x60400089: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 137
0x63DBC001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 47 Module Use Count: 1
0x63DA8004: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 42 Module Use Count: 4
0x645BC001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 47 Module Retention Count: 1
0x63118002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 6 PD Usage Count: 2
0x645A8003: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 42 Module Retention Count: 3
0x63118001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 6 PD Usage Count: 1
0x6310C004: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 4
0x61C0008A: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 138 Clock ID: 0
0x6040008A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 138
0x63DC0001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 48 Module Use Count: 1
0x63DA8003: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 42 Module Use Count: 3
0x645C0001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 48 Module Retention Count: 1
0x6311C002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 7 PD Usage Count: 2
0x645A8002: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 42 Module Retention Count: 2
0x6311C001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 7 PD Usage Count: 1
0x6310C003: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 3
0x61C00086: Power Management: MSG_PARAM_DEV_CLK_ID(TI-SCI message content: dev/clk-ids): Device ID: 134 Clock ID: 0
0x60400086: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 134
0x64500013: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 0 Module Retention Count: 19
0x6310004B: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 75
0x6040003D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 61
0x63D00014: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 0 Module Use Count: 20
0x645B4000: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 45 Module Retention Count: 0
0x63110001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 4 PD Usage Count: 1
0x6310C002: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 2
0x60400087: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 135
0x63DB4001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 45 Module Use Count: 1
0x63DA8002: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 42 Module Use Count: 2
0x645A8001: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 42 Module Retention Count: 1
0x6310C001: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 1
0x6310004A: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 0 PD Usage Count: 74
0x604000A6: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 166
0x63DA8001: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 42 Module Use Count: 1
0x6310C000: Power Management: PD_PUT(Power Domain Put): PSC ID: 1 Power domain ID: 3 PD Usage Count: 0
0x63D88020: Power Management: MODULE_PUT(Module Put): PSC ID: 1 LPSC ID: 34 Module Use Count: 32
0x64588020: Power Management: RETENTION_PUT(Retention Put): PSC ID: 1 LPSC ID: 34 Module Retention Count: 32
0x60400001: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 1
0x60400002: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 2
0x60400003: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 3
0x60400005: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 5
0x60400006: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 6
0x60400007: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 7
0x60400008: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 8
0x60400009: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 9
0x6040000E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 14
0x6040000F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 15
0x60400010: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 16
0x60400011: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 17
0x60400012: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 18
0x60400013: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 19
0x60400014: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 20
0x60400015: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 21
0x60400016: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 22
0x60400017: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 23
0x60400018: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 24
0x60400019: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 25
0x6040001A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 26
0x6040001B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 27
0x6040001C: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 28
0x6040001D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 29
0x6040001E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 30
0x60400021: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 33
0x60400023: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 35
0x60400024: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 36
0x60400025: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 37
0x60400026: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 38
0x60400027: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 39
0x60400028: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 40
0x60400029: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 41
0x6040002A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 42
0x6040002B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 43
0x60400030: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 48
0x60400031: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 49
0x60400032: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 50
0x60400033: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 51
0x60400034: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 52
0x60400035: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 53
0x60400036: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 54
0x60400037: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 55
0x6040003B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 59
0x6040003C: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 60
0x6040003E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 62
0x6040003F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 63
0x60400040: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 64
0x60400049: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 73
0x6040004C: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 76
0x60400050: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 80
0x60400051: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 81
0x60400053: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 83
0x60400055: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 85
0x60400056: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 86
0x60400057: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 87
0x60400058: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 88
0x6040005F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 95
0x60400060: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 96
0x60400061: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 97
0x60400062: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 98
0x60400064: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 100
0x60400065: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 101
0x60400066: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 102
0x60400068: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 104
0x60400069: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 105
0x6040006A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 106
0x6040006B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 107
0x6040006E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 110
0x6040006F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 111
0x60400072: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 114
0x60400074: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 116
0x60400075: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 117
0x60400076: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 118
0x60400077: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 119
0x60400079: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 121
0x6040007D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 125
0x6040007E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 126
0x6040007F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 127
0x60400080: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 128
0x60400082: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 130
0x60400083: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 131
0x60400084: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 132
0x6040008B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 139
0x6040008C: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 140
0x6040008D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 141
0x6040008E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 142
0x6040008F: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 143
0x60400093: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 147
0x60400094: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 148
0x60400096: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 150
0x60400098: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 152
0x60400099: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 153
0x6040009A: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 154
0x6040009B: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 155
0x6040009C: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 156
0x6040009D: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 157
0x6040009E: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 158
0x604000A1: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 161
0x604000A2: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 162
0x604000A3: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 163
0x604000A4: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 164
0x604000A5: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 165
0x604000A7: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 167
0x604000A8: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 168
0x604000A9: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 169
0x604000AA: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 170
0x604000AB: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 171
0x604000AC: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 172
0x604000AD: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 173
0x604000AE: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 174
0x604000AF: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 175
0x604000B0: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 176
0x604000B1: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 177
0x604000B2: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 178
0x604000B3: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 179
0x604000B4: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 180
0x604000B5: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 181
0x604000B6: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 182
0x604000B7: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 183
0x604000B9: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 185
0x604000BB: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 187
0x604000BC: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 188
0x604000BD: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 189
0x604000BE: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 190
0x604000BF: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 191
0x604000C0: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 192
0x604000C1: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 193
0x604000E1: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 225
0x604000E3: Power Management: DEVICE_OFF(Device has been Turned OFF): Device ID: 227
0x6C000100: Power Management: PM_LPM_SEQ(Low power mode sequence): DM stub started Value: 0
0x6C000200: Power Management: PM_LPM_SEQ(Low power mode sequence): Unlocked MMRs Value: 0
0x6C000400: Power Management: PM_LPM_SEQ(Low power mode sequence): DDR in reset isolation Value: 0
0x6C007700: Power Management: PM_LPM_SEQ(Low power mode sequence): Unknown Sub Message: 0x77 Value: 0
0x6C000500: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled USB reset isolation Value: 0
0x6C000600: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled main LPSC Value: 0
0x6C000700: Power Management: PM_LPM_SEQ(Low power mode sequence): Bypassed main PLL Value: 0
0x6C000800: Power Management: PM_LPM_SEQ(Low power mode sequence): Configured wake-up sources Value: 0
0x6C000900: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled Main IO isolation Value: 0
0x6C000A00: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled second set of main LPSC Value: 0
0x6C000B00: Power Management: PM_LPM_SEQ(Low power mode sequence): Switched from MAIN PLL to MCU PLL Value: 0
0x6C000C00: Power Management: PM_LPM_SEQ(Low power mode sequence): Configured clock muxes Value: 0
0x6C000D00: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled Main PLL Value: 0
0x6C000E00: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled DM reset mask Value: 0
0x6C000F00: Power Management: PM_LPM_SEQ(Low power mode sequence): Kept main domain in reset Value: 0
0x6C001000: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled MCU domain Value: 0
0x6C001100: Power Management: PM_LPM_SEQ(Low power mode sequence): Masked main domain reset Value: 0
0x6C001200: Power Management: PM_LPM_SEQ(Low power mode sequence): Gated WWD clock Value: 0
0x6C001300: Power Management: PM_LPM_SEQ(Low power mode sequence): Bypassed MCU PLL Value: 0
0x6C001400: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled clock switch on clock loss Value: 0
0x6C001500: Power Management: PM_LPM_SEQ(Low power mode sequence): Powered off HFOSC Value: 0
0x6C001600: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled gating of clock on WFI Value: 0
The device is finally asleep as indicated by the WFI (Waiting for Interrupt). It follows the SW Architecture Suspend Sequence found in the SDK documentation: https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_01_00_08/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Power_Management/pm_sw_arch.html
But what if we cannot access the WKUP UART Port?
As of TSCI Firmware Version 9.1, a copy of the logs are stored in the R5F's TCMA (ATCM). The logs can be found at address 0x7800 in the TCMA and is stored in 8-Bit Hex Values.
These logs are not as complete as the WKUP UART method, but will show the key components of the PM_LPM_SEQ.
Code Composer Studio will be needed for these steps.
MCU+ SDK & Code Composer Studio (CCS) Setup
Installing the MCU+ SDK is not required but might be useful.
At this point, CCS should be ready to go. The next step is to run Deep Sleep so the logs will be stored in the R5F's TCMA.
Run Deep Sleep in the Linux Terminal
This should work with any other Low Power Mode.
There shouldn't be any other need for the Linux terminal now.
Now, we can connect to the R5F Core and read the memory.
Connecting to the R5F Core
Make sure the device is booted and you can access the Linux terminal (any method should work).
In CCS, connect to the target via Target Configurations:
Select the target config for the device in use. Right click and select Launch Selected Configuration:
Let the cores load. Then under Debug, connect to the Texas Instruments XDS110 USB Debug Probe_0/MAIN_Cortex_R5_0_0:
Since CCS is connected to the R5F Core, you'll notice clock errors will fill the Linux terminal like below:
cpu cpu0: _opp_config_clk_single: failed to set clock rate: -22 cpufreq: __target_index: Failed to change cpu frequency: -22 ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x64/0xe4) ti-sci 44043000.system-controller: Mbox send fail -110
If CSS gets disconnected, then the errors will stop.
Open the memory browser:
In the memory browser, set the address to 0x7800 and the output type to Character.
Then you'll see the 8-Bit Hex Values. Each value starts with 0x and separated by two periods. These are the logs we're looking for.
Setting Up the Input File for the Parser
Now that the hex values exist, they need to be parsed into Human Readable form.
Copy each value from the Memory Browser into a file like a text file & setting a new line between values. Make sure no tab characters exist in the file.
A sample below:
0x6C000100 0x6C000200 0x6C000400 0x6C007700 0x6C000500 0x6C000600 0x6C000700 0x6C000800 0x6C000900 0x6C000A00 0x6C000B00 0x6C000C00 0x6C000D00 0x6C000E00 0x6C000F00 0x6C001000 0x6C001100 0x6C001200 0x6C001300 0x6C001400 0x6C001500 0x6C001600 0x6C001700 0x6C001830 0x6C001900 0x6C001A00 0x6C001B00 0x6C001C00 0x6C001D00 0x6C001E00 0x6C001F00 0x6C002000 0x6C002500 0x6C003300 0x6C003400 0x6C002600 0x6C002700 0x6C002800 0x6C002900 0x6C002A00 0x6C002B00 0x6C002C00 0x6C002D00 0x6C002E00
Run the Parser with the New File
On the host machine:
HOST$ cd <SDK install directory>/bin HOST$ python3 sysfw_trace_parser.py -l <Logs from CCS> -o <Output File> -Tv <Version> ### Or print into the console HOST$ python3 sysfw_trace_parser.py -l <Logs from CCS> -O -Tv <Version>
Sample Output of AM62x Sleep Sequence and Wakeup using the R5F's TCMA
0x6C001700: Power Management: PM_LPM_SEQ(Low power mode sequence): DM in WFI Value: 0
0x6C001830: Power Management: PM_LPM_SEQ(Low power mode sequence): LPM wake event Value: 48
0x6C001900: Power Management: PM_LPM_SEQ(Low power mode sequence): DM exited WFI Value: 0
0x6C001A00: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled gating of clock on WFI Value: 0
0x6C001B00: Power Management: PM_LPM_SEQ(Low power mode sequence): Powered on HFOSC Value: 0
0x6C001C00: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled clock switch on clock loss Value: 0
0x6C001D00: Power Management: PM_LPM_SEQ(Low power mode sequence): Restored MCU PLL Value: 0
0x6C001E00: Power Management: PM_LPM_SEQ(Low power mode sequence): unmasked WWD clock Value: 0
0x6C001F00: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabling MCU IO isolation Value: 0
0x6C002000: Power Management: PM_LPM_SEQ(Low power mode sequence): Wrote stub magic word Value: 0
0x6C002500: Power Management: PM_LPM_SEQ(Low power mode sequence): TIFS core is ready Value: 0
0x6C003300: Power Management: PM_LPM_SEQ(Low power mode sequence): Removed DM reset mask Value: 0
0x6C003400: Power Management: PM_LPM_SEQ(Low power mode sequence): Removed main domain reset isolation Value: 0
0x6C002600: Power Management: PM_LPM_SEQ(Low power mode sequence): Loaded FS stub Value: 0
0x6C002700: Power Management: PM_LPM_SEQ(Low power mode sequence): Received continue resume Value: 0
0x6C002800: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled main IO isolation Value: 0
0x6C002900: Power Management: PM_LPM_SEQ(Low power mode sequence): Enabled remaining PLL Value: 0
0x6C002A00: Power Management: PM_LPM_SEQ(Low power mode sequence): Removed DDR reset isolation Value: 0
0x6C002B00: Power Management: PM_LPM_SEQ(Low power mode sequence): Exited DDR self reset Value: 0
0x6C002C00: Power Management: PM_LPM_SEQ(Low power mode sequence): Disabled USB reset isolation Value: 0
0x6C002D00: Power Management: PM_LPM_SEQ(Low power mode sequence): Sent continue resume to TFS Value: 0
0x6C002E00: Power Management: PM_LPM_SEQ(Low power mode sequence): Received sync resume message Value: 0
