Other Parts Discussed in Thread: UNIFLASH, AM62P, AM62P5
Hi Aparna,
SBL OSPI also takes 12 sec how to reduce boot time. I attached a screenshot below:
How to reduce time. I read some TI threads also but not clear.
Veerapandiyan V
Hi Veerapandiyan,
Please refer this guide to optimise the linux kernel and using a tiny filesystem as mentioned: software-dl.ti.com/.../How_to_boot_quickly.html
If you have any specific doubts, follow back on this thread.
Aparna
Hi Aparna
SBL boot log: DMSC Firmware Version 9.1.8--v09.01.08 (Kool Koala) DMSC Firmware revision 0x9 DMSC ABI revision 3.1 [BOOTLOADER_PROFILE] Boot Media : FLASH [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz [BOOTLOADER_PROFILE] Boot Image Size : 213 KB [BOOTLOADER_PROFILE] Cores present : m4f0-0 r5f0-0 [BOOTLOADER PROFILE] System_init : 4846us [BOOTLOADER PROFILE] Board_init : 0us [BOOTLOADER PROFILE] Drivers_open : 296us [BOOTLOADER PROFILE] Board_driversOpen : 26548us [BOOTLOADER PROFILE] Sciclient Get Version : 9929us [BOOTLOADER PROFILE] App_waitForMcuPbist : 5us [BOOTLOADER PROFILE] App_waitForMcuLbist : 7689us [BOOTLOADER PROFILE] App_loadImages : 15548us [BOOTLOADER PROFILE] App_loadSelfcoreImage : 885us [BOOTLOADER_PROFILE] SBL Total Time Taken : 65749us Image loading done, switching to application ... Starting MCU-m4f and 2nd stage bootloader DMSC Firmware Version 9.1.8--v09.01.08 (Kool Koala) DMSC Firmware revision 0x9 DMSC ABI revision 3.1 [BOOTLOADER_PROFILE] Boot Media : FLASH [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz [BOOTLOADER_PROFILE] Boot Image Size : 1049 KB [BOOTLOADER_PROFILE] Cores present : hsm-m4f0-0 r5f0-0 a530-0 [BOOTLOADER PROFILE] System_init : 2817us [BOOTLOADER PROFILE] Board_init : 1us [BOOTLOADER PROFILE] Drivers_open : 366us [BOOTLOADER PROFILE] Board_driversOpen : 26275us [BOOTLOADER PROFILE] Sciclient Get Version : 10024us [BOOTLOADER PROFILE] App_loadImages : 272us [BOOTLOADER PROFILE] App_loadSelfcoreImage : 2800us [BOOTLOADER PROFILE] App_loadLinuxImages : 4972us [BOOTLOADER_PROFILE] SBL Total Time Taken : 47530us Image loading done, switching to application ... Starting linux and RTOS/Baremetal applications NOTICE: BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty NOTICE: BL31: Built : 09:34:15, Aug 24 2023 U-Boot SPL 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') SPL initial stack usage: 1856 bytes Error (-2): cannot determine file size Trying to boot from SPI Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 80, trying to read at 81 Board: AM62-SKEVM rev E3 DRAM: 2 GiB Core: 72 devices, 32 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 574 bytes read in 15 ms (37.1 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... ## Error: "main_cpsw0_qsgmii_phyinit" not defined 20593152 bytes read in 236 ms (83.2 MiB/s) 57500 bytes read in 18 ms (3 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4) Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Working FDT set to 8feee000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.33-g40c32565ca (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Jul 6 14:17:24 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff] [ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff] [ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=f7a418f5-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1838092K/2097152K available (12480K kernel code, 1294K rwdata, 4040K rodata, 2176K init, 498K bss, 127988K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008549] Console: colour dummy device 80x25 [ 0.013142] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023824] pid_max: default: 32768 minimum: 301 [ 0.028600] LSM: Security Framework initializing [ 0.033458] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041042] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.050876] cblist_init_generic: Setting adjustable number of callback queues. [ 0.058336] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.064639] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.071041] rcu: Hierarchical SRCU implementation. [ 0.075949] rcu: Max phase no-delay instances is 1000. [ 0.081564] Platform MSI: msi-controller@1820000 domain created [ 0.087891] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.097782] EFI services will not be available. [ 0.102716] smp: Bringing up secondary CPUs ... [ 0.108041] Detected VIPT I-cache on CPU1 [ 0.108160] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.108179] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.108238] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.108963] Detected VIPT I-cache on CPU2 [ 0.109035] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.109049] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000 [ 0.109085] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.109741] Detected VIPT I-cache on CPU3 [ 0.109824] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.109837] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000 [ 0.109868] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.109944] smp: Brought up 1 node, 4 CPUs [ 0.189676] SMP: Total of 4 processors activated. [ 0.194489] CPU features: detected: 32-bit EL0 Support [ 0.199761] CPU features: detected: CRC32 instructions [ 0.205082] CPU: All CPU(s) started at EL2 [ 0.209280] alternatives: applying system-wide alternatives [ 0.216867] devtmpfs: initialized [ 0.228454] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.238456] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.250039] pinctrl core: initialized pinctrl subsystem [ 0.256038] DMI not present or invalid. [ 0.260609] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.267883] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.275453] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.283569] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.291757] audit: initializing netlink subsys (disabled) [ 0.297469] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1 [ 0.297953] thermal_sys: Registered thermal governor 'step_wise' [ 0.305400] thermal_sys: Registered thermal governor 'power_allocator' [ 0.311587] cpuidle: using governor menu [ 0.322459] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.329491] ASID allocator initialised with 65536 entries [ 0.345939] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b [ 0.357176] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b [ 0.368124] KASLR disabled due to lack of seed [ 0.379901] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.386877] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.393289] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.400228] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.406636] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.413575] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.419983] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.426923] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.435141] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.445242] iommu: Default domain type: Translated [ 0.450311] iommu: DMA domain TLB invalidation policy: strict mode [ 0.457017] SCSI subsystem initialized [ 0.461234] usbcore: registered new interface driver usbfs [ 0.466891] usbcore: registered new interface driver hub [ 0.472385] usbcore: registered new device driver usb [ 0.478131] pps_core: LinuxPPS API ver. 1 registered [ 0.483213] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.492565] PTP clock support registered [ 0.496698] EDAC MC: Ver: 3.0.0 [ 0.500869] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.508018] FPGA manager framework [ 0.511600] Advanced Linux Sound Architecture Driver Initialized. [ 0.518853] clocksource: Switched to clocksource arch_sys_counter [ 0.525360] VFS: Disk quotas dquot_6.6.0 [ 0.529414] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.542423] NET: Registered PF_INET protocol family [ 0.547734] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.556986] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.565798] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.573739] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.581942] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.589931] TCP: Hash tables configured (established 16384 bind 16384) [ 0.596848] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.603774] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.611323] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.617595] RPC: Registered named UNIX socket transport module. [ 0.623675] RPC: Registered udp transport module. [ 0.628484] RPC: Registered tcp transport module. [ 0.633292] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.639884] NET: Registered PF_XDP protocol family [ 0.644796] PCI: CLS 0 bytes, default 64 [ 0.649629] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.659753] Initialise system trusted keyrings [ 0.664587] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.677031] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.683735] NFS: Registering the id_resolver key type [ 0.688965] Key type id_resolver registered [ 0.693243] Key type id_legacy registered [ 0.697410] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.704266] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.712035] 9p: Installing v9fs 9p2000 file system support [ 0.751542] Key type asymmetric registered [ 0.755733] Asymmetric key parser 'x509' registered [ 0.760773] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.768511] io scheduler mq-deadline registered [ 0.773151] io scheduler kyber registered [ 0.780648] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.787188] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.794098] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.808037] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.823171] loop: module loaded [ 0.827747] megasas: 07.719.03.00-rc1 [ 0.835768] tun: Universal TUN/TAP device driver, 1.6 [ 0.841728] thunder_xcv, ver 1.0 [ 0.845085] thunder_bgx, ver 1.0 [ 0.848413] nicpf, ver 1.0 [ 0.851607] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.858995] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.864516] hclge is initializing [ 0.867928] e1000: Intel(R) PRO/1000 Network Driver [ 0.872914] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.878823] e1000e: Intel(R) PRO/1000 Network Driver [ 0.883898] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.889979] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.895498] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.901219] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.907627] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.913816] sky2: driver version 1.30 [ 0.918315] VFIO - User Level meta-driver version: 0.3 [ 0.924360] usbcore: registered new interface driver usb-storage [ 0.931309] i2c_dev: i2c /dev entries driver [ 0.937891] sdhci: Secure Digital Host Controller Interface driver [ 0.944257] sdhci: Copyright(c) Pierre Ossman [ 0.949259] Synopsys Designware Multimedia Card Interface Driver [ 0.955888] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.962761] ledtrig-cpu: registered to indicate activity on CPUs [ 0.969125] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.976113] usbcore: registered new interface driver usbhid [ 0.981818] usbhid: USB HID core driver [ 0.987088] optee: probing for conduit method. [ 0.991677] optee: revision 4.0 (2a5b1d12) [ 0.992009] optee: dynamic shared memory is enabled [ 1.001587] optee: initialized driver [ 1.007250] Initializing XFRM netlink socket [ 1.011675] NET: Registered PF_PACKET protocol family [ 1.016990] 9pnet: Installing 9P2000 support [ 1.021425] Key type dns_resolver registered [ 1.026236] registered taskstats version 1 [ 1.030465] Loading compiled-in X.509 certificates [ 1.044442] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') [ 1.107715] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.115307] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.122393] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.128383] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.136734] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.145969] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.155919] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.164124] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.175289] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.185360] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.195674] printk: console [ttyS2] disabled [ 1.200137] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250 [ 1.209041] printk: console [ttyS2] enabled [ 1.209041] printk: console [ttyS2] enabled [ 1.217500] printk: bootconsole [ns16550a0] disabled [ 1.217500] printk: bootconsole [ns16550a0] disabled [ 1.230476] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.235588] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.242550] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.247943] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.254747] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.261177] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.267686] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.273876] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.280678] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.287323] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.295773] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.338881] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.348680] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.356792] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.364917] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.377776] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.384905] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.391397] pps pps0: new PPS source ptp0 [ 1.395718] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.406187] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.417756] mmc0: CQHCI version 5.10 [ 1.424050] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.430857] pca953x 1-0022: using AI [ 1.462824] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.464348] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.467949] mmc2: CQHCI version 5.10 [ 1.467968] mmc1: CQHCI version 5.10 [ 1.498804] ALSA device list: [ 1.501804] No soundcards found. [ 1.502155] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.509283] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 1.520993] Waiting for root device PARTUUID=f7a418f5-02... [ 1.563596] mmc0: Command Queue Engine enabled [ 1.568194] mmc0: new HS200 MMC card at address 0001 [ 1.574497] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.580155] mmc1: new ultra high speed SDR104 SDXC card at address aaaa [ 1.588045] mmcblk1: mmc1:aaaa SD64G 59.5 GiB [ 1.595243] mmcblk1: p1 p2 [ 1.598085] mmcblk0: p1 [ 1.601290] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.607678] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.613592] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0) [ 2.287728] EXT4-fs (mmcblk1p2): recovery complete [ 2.293466] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 2.302100] VFS: Mounted root (ext4 filesystem) on device 179:34. [ 2.311616] devtmpfs: mounted [ 2.316216] Freeing unused kernel memory: 2176K [ 2.320888] Run /sbin/init as init process [ 2.489002] systemd[1]: System time before build time, advancing clock. [ 2.538639] NET: Registered PF_INET6 protocol family [ 2.545217] Segment Routing with IPv6 [ 2.548986] In-situ OAM (IOAM) with IPv6 [ 2.587480] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 2.619452] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.04! [ 2.713931] systemd[1]: Hostname set to <am62xx-evm>. [ 2.837082] systemd-sysv-generator[158]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.864426] systemd-sysv-generator[158]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.889197] systemd-sysv-generator[158]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.915073] systemd-sysv-generator[158]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.938984] systemd-sysv-generator[158]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.962975] systemd-sysv-generator[158]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.987651] systemd-sysv-generator[158]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.014127] systemd-sysv-generator[158]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.038633] systemd-sysv-generator[158]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.063002] systemd-sysv-generator[158]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.089836] systemd-sysv-generator[158]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.115681] systemd-sysv-generator[158]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.140011] systemd-sysv-generator[158]: SysV service '/etc/init.d/resize_rootfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.164953] systemd-sysv-generator[158]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.190289] systemd-sysv-generator[158]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.214021] systemd-sysv-generator[158]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.238162] systemd-sysv-generator[158]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.476306] systemd[1]: Configuration file /etc/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.541080] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring. [ 3.553679] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring. [ 3.594681] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.656830] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.738957] systemd[1]: Queued start job for default target Graphical Interface. [ 3.812758] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 3.838187] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 3.862654] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 3.886251] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.903239] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 3.939791] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 3.967443] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 3.983124] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.003022] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.019088] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.090514] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.115326] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.159302] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.184285] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.211398] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.237828] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.261162] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.294456] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.321437] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.345762] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.370137] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.431582] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.458670] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.511561] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.527675] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.557095] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 4.611969] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 4.645755] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 4.669858] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 4.693561] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 4.711098] fuse: init (API version 7.37) [ 4.721369] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 4.753768] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 4.767593] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 4.812008] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.837887] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 4.862270] systemd[1]: Starting Generate network units from Kernel command line... [ 4.863724] cryptodev: loading out-of-tree module taints kernel. Starting Generate network …ts from Kernel co[ 4.878141] cryptodev: driver 1.12 loaded. mmand line... [ 4.901497] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 4.927999] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. [ 4.930554] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 4.962463] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 4.983822] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 5.379049] systemd-journald[174]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 5.639766] audit: type=1334 audit(1651167748.148:2): prog-id=5 op=LOAD [ 5.646649] audit: type=1334 audit(1651167748.156:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Finished Coldplug All udev Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. [ OK ] Started Rule-based Manager for Device Events and Files. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started Network Time Synchronization. [ 6.359247] random: crng init done [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ 6.423898] mc: Linux media interface: v0.10 [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ 6.447815] videodev: Linux video capture interface: v2.00 [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ 6.642082] rtc-ti-k3 2b1f0000.rtc: [Hardware Error]: Erratum i2327 unlock QUIRK! Cannot operate!! Starting Weston socket... [ 6.652238] rtc-ti-k3: probe of 2b1f0000.rtc failed with error -14 [ 6.667028] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.676221] k3-m4-rproc 5000000.m4fss: configured M4 for IPC-only mode [ 6.692532] remoteproc remoteproc0: 5000000.m4fss is available [ 6.698973] remoteproc remoteproc0: attaching to 5000000.m4fss Starting D-Bus System Message Bus... [ 6.711371] k3-m4-rproc 5000000.m4fss: M4 initialized in IPC-only mode [ 6.720762] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.750468] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 6.762476] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.762704] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.769388] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.774417] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 6.776587] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 6.776607] remoteproc remoteproc0: remote processor 5000000.m4fss is now attached [ 6.799257] remoteproc remoteproc1: 78000000.r5f is available [ 6.804942] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 6.811049] remoteproc remoteproc1: attaching to 78000000.r5f Starting Reboot and dump vmcore via kexec... [ OK ] Finished Load/Save Random Seed. [ OK ] Listening on Docker Socket for the [ 6.879199] platform 78000000.r5f: R5F core initialized in IPC-only mode API. [ 6.890433] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9da00000 [ OK ] Listening on Weston socket. [ 6.921539] sii902x 1-003b: supply iovcc not found, using dummy regulator [ OK ] Finished Reboot and dump vmcore via[ 6.949031] sii902x 1-003b: supply cvcc12 not found, using dummy regulator kexec. [ 6.968133] i2c i2c-1: Added multiplexed i2c bus 3 [ OK ] Found device /dev/ttyS2. [ 7.001131] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 7.009091] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ OK ] Reached target Socket Units. [ 7.071795] PVR_K: 205: Device: fd00000.gpu [ 7.099430] virtio_rpmsg_bus virtio1: rpmsg host is online [ 7.100406] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 7.115467] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 7.118987] PVR_K: 205: Read BVNC 33.15.11.3 from HW device registers [ OK ] Started D-Bus System Message Bus. [ 7.144473] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7) [ 7.166124] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ OK ] Reached target Basic System. [ 7.202929] PVR_K: 205: RGX Device registered with BVNC 33.15.11.3 [ 7.215437] [drm] Initialized pvr 23.1.6404501 20170530 for fd00000.gpu on minor 1 [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting startwlanap... Starting startwlansta... [ 7.387636] audit: type=1334 audit(1651175734.756:4): prog-id=7 op=LOAD [ 7.397984] audit: type=1334 audit(1651175734.764:5): prog-id=8 op=LOAD Starting User Login Management... [ OK ] Started TEE Supplicant. Starting telnetd.service... [ OK ] Started ti-apps-launcher service. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Started startwlanap. [ OK ] Started startwlansta. [ 7.511022] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ OK ] Started telnetd.service. [ OK ] Reached target Preparation for Network. Starting LSB: Expand Rootfs of boot device... Starting Network Configuration... [ 7.612941] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 7.656512] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.380013] remoteproc remoteproc2: 30074000.pru is available [ 8.400524] tps6598x 0-003f: Unable to find the interrupt, switching to polling [ 8.425398] remoteproc remoteproc3: 30078000.pru is available [ 8.512491] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22 [ OK ] Reached target Hardware activated USB gadget. [ OK ] Listening on Load/S[ 8.566738] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller ave RF …itch Status /dev/rfkill Watch. [ 8.576890] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 8.589435] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports [ 8.595742] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010 [ 8.605876] xhci-hcd xhci-hcd.3.auto: irq 459, io mem 0x31100000 [ 8.620178] hub 1-0:1.0: USB hub found [ 8.627438] hub 1-0:1.0: 1 port detected [ OK ] Started User Login Management. [ OK ] Started LSB: Expand Rootfs of boot device. [ OK ] Started Network Configuration. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 8.767573] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL) [ 8.792507] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode Starting Save/Restore Sound Card State... [ OK ] Finished Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ 8.868714] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.890610] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 8.882868] startwlanap.sh[616]: sed: unmatched '/' [ 8.913846] startwlanap.sh[618]: adding wlan1 interface [ 8.937403] startwlanap.sh[622]: command failed: No such file or directory (-2) [ 9.053991] startwlanap.sh[625]: Line 499: unknown configuration item 'wep_rekey_period' [ 9.054686] startwlanap.sh[625]: 1 errors found in configuration file '/usr/share/wl18xx/hostapd.conf' [ 9.055243] startwlanap.sh[625]: Failed to set up interface with /usr/share/wl18xx/hostapd.conf [ 9.055713] startwlanap.sh[625]: Failed to initialize interface [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma…ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland…ositor, as a system service... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ 9.911960] audit: type=1334 audit(1651175737.280:6): prog-id=9 op=LOAD [ 9.918830] audit: type=1334 audit(1651175737.284:7): prog-id=10 op=LOAD Starting User Database Manager... [ OK ] Created slice Slice /system/systemd-fsck. [ 10.004859] startwlanap.sh[715]: SIOCSIFADDR: No such device [ 10.028485] startwlanap.sh[715]: wlan1: ERROR while getting interface flags: No such device [ 10.053633] startwlanap.sh[715]: SIOCSIFNETMASK: No such device [ 10.076431] startwlanap.sh[715]: wlan1: ERROR while getting interface flags: No such device [ OK ] Started User Database Manager. [ OK ] Found device /dev/mmcblk0p1. Starting File System Check on /dev/mmcblk0p1... Starting File System Check on /dev/mmcblk1p1... [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/boot-mmcblk1p1... [ 10.626543] audit: type=1325 audit(1651175737.968:8): table=nat family=2 entries=0 op=xt_register pid=764 comm="iptables" [ 10.637872] audit: type=1300 audit(1651175737.968:8): arch=c00000b7 syscall=209 success=yes exit=0 a0=4 a1=0 a2=40 a3=fffff8baaf18 items=0 ppid=618 pid=764 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" key=(null) [ 10.666599] audit: type=1327 audit(1651175737.968:8): proctitle=69707461626C6573002D74006E6174002D4100504F5354524F5554494E47002D6F0065746830002D6A004D415351554552414445 [ OK ] Finished User Runtime Directory /ru[ 10.682600] audit: type=1325 audit(1651175737.996:9): table=nat family=2 entries=5 op=xt_replace pid=764 comm="iptables" n/user/1000.[ 10.698547] audit: type=1300 audit(1651175737.996:9): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1495f210 items=0 ppid=618 pid=764 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" key=(null) [ 10.727121] audit: type=1327 audit(1651175737.996:9): proctitle=69707461626C6573002D74006E6174002D4100504F5354524F5554494E47002D6F0065746830002D6A004D415351554552414445 [ OK ] Finished File System Check on /dev/mmcblk0p1. [ OK ] Mounted /run/media/boot-mmcblk1p1. Mounting /run/media/rootfs-mmcblk0p1... Starting User Manager for UID 1000... [ 10.844385] audit: type=1006 audit(1651175738.212:10): pid=782 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 10.857193] audit: type=1300 audit(1651175738.212:10): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe1fa5b28 a2=4 a3=ffff8506a020 items=0 ppid=1 pid=782 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 10.883932] audit: type=1327 audit(1651175738.212:10): proctitle="(systemd)" [ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon.. [ 10.897511] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none. [ OK ] Mounted /run/media/rootfs-mmcblk0p1. [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston. [ 11.487431] audit: type=1006 audit(1651175738.852:11): pid=662 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 11.500126] audit: type=1300 audit(1651175738.852:11): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe1fa5b28 a2=4 a3=ffff8506a020 items=0 ppid=1 pid=662 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 11.526602] audit: type=1327 audit(1651175738.852:11): proctitle="(weston)" [ OK ] Started containerd container runtime. [ 11.463391] startwlanap.sh[799]: iperf3: error - unable to start listener for connections: Cannot assign requested address [ 11.464106] startwlanap.sh[799]: iperf3: exiting [ 11.868070] PVR_K: 662: RGX Firmware image 'rgx.fw.33.15.11.3' loaded [ 11.884025] PVR_K: 662: Shader binary image 'rgx.sh.33.15.11.3' loaded [ OK ] Started Weston, a Wayland …mpositor, as a system service. [ OK ] Finished Print notice about GPLv3 packages. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm - Arago 2023.04 am62xx-evm - am62xx-evm login:
I've read all the steps mentioned in the above link, but I couldn't understand the changes to be made there.
Can you elaborate on the steps by giving any examples?
Veerapandiyan V
The guide is well documented, and it is out of my scope to explain it further with examples. If you have any questions specific to a given section, I can help with it.
Aparna
Hi Aparna,
I tried this step in U-Boot but not working:
How to solve this issue.
Veerapandiyan.
Hi Veerapandiyan,
Can you please reply to the questions listed below?
1. Are you using Falcon Mode? If yes, any changes to U-boot will not be used since U-boot proper stage is completely skipped. Try using the device tree method.
2. When you said you tried the step in U-boot and it did not work, do you mean to say it did not boot or that it did not reduce the boot time?
Hi Shenai,
I am used ti-processor-sdk-linux-am62xx-evm-09.00.00.03 and mcu_plus_sdk_am62x_09_02_00_38. I load the default_sbl_ospi_linux_falcon.cfg after changing the boot mode switch OSPI boot mode is coming error I attached the error log below:
� SYSFW Firmware Version 9.2.7--v09.02.07 (Kool Koala) SYSFW Firmware revision 0x9 SYSFW ABI revision 3.1 [BOOTLOADER_PROFILE] Boot Media : FLASH [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz [BOOTLOADER_PROFILE] Boot Image Size : 170 KB [BOOTLOADER_PROFILE] Cores present : m4f0-0 r5f0-0 [BOOTLOADER PROFILE] System_init : 4963us [BOOTLOADER PROFILE] Board_init : 0us [BOOTLOADER PROFILE] Drivers_open : 296us [BOOTLOADER PROFILE] Board_driversOpen : 6807us [BOOTLOADER PROFILE] Sciclient Get Version : 10204us [BOOTLOADER PROFILE] App_waitForMcuPbist : 4968us [BOOTLOADER PROFILE] App_waitForMcuLbist : 7689us [BOOTLOADER PROFILE] App_loadImages : 7294us [BOOTLOADER PROFILE] App_loadSelfcoreImage : 887us [BOOTLOADER_PROFILE] SBL Total Time Taken : 43112us Image loading done, switching to application ... Starting MCU-m4f and 2nd stage bootloader SYSFW Firmware Version 9.2.7--v09.02.07 (Kool Koala) SYSFW Firmware revision 0x9 SYSFW ABI revision 3.1 [BOOTLOADER_PROFILE] Boot Media : FLASH [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz [BOOTLOADER_PROFILE] Boot Image Size : 19649 KB [BOOTLOADER_PROFILE] Cores present : hsm-m4f0-0 r5f0-0 a530-0 [BOOTLOADER PROFILE] System_init : 2847us [BOOTLOADER PROFILE] Board_init : 1us [BOOTLOADER PROFILE] Drivers_open : 369us [BOOTLOADER PROFILE] Board_driversOpen : 28065us [BOOTLOADER PROFILE] Sciclient Get Version : 10233us [BOOTLOADER PROFILE] App_loadImages : 266us [BOOTLOADER PROFILE] App_loadSelfcoreImage : 2546us [BOOTLOADER PROFILE] App_loadLinuxImages : 172522us [BOOTLOADER_PROFILE] SBL Total Time Taken : 216853us Image loading done, switching to application ... Starting linux and RTOS/Baremetal applications NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1848340K/2097152K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 117740K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000081440000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081450000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008553] Console: colour dummy device 80x25 [ 0.013153] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023835] pid_max: default: 32768 minimum: 301 [ 0.028603] LSM: Security Framework initializing [ 0.033457] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041042] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.050857] cblist_init_generic: Setting adjustable number of callback queues. [ 0.058306] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.064605] cblist_init_generic: Setting adjustable number of callback queues. [ 0.072000] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.078389] rcu: Hierarchical SRCU implementation. [ 0.083298] rcu: Max phase no-delay instances is 1000. [ 0.088905] Platform MSI: msi-controller@1820000 domain created [ 0.095213] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.104616] EFI services will not be available. [ 0.109537] smp: Bringing up secondary CPUs ... [ 0.114860] Detected VIPT I-cache on CPU1 [ 0.114983] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.115002] GICv3: CPU1: using allocated LPI pending table @0x0000000081460000 [ 0.115061] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.115778] Detected VIPT I-cache on CPU2 [ 0.115858] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.115871] GICv3: CPU2: using allocated LPI pending table @0x0000000081470000 [ 0.115904] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.116526] Detected VIPT I-cache on CPU3 [ 0.116605] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.116619] GICv3: CPU3: using allocated LPI pending table @0x0000000081480000 [ 0.116653] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.116720] smp: Brought up 1 node, 4 CPUs [ 0.196464] SMP: Total of 4 processors activated. [ 0.201277] CPU features: detected: 32-bit EL0 Support [ 0.206551] CPU features: detected: CRC32 instructions [ 0.211868] CPU: All CPU(s) started at EL2 [ 0.216065] alternatives: applying system-wide alternatives [ 0.223595] devtmpfs: initialized [ 0.235112] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.245113] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.257071] pinctrl core: initialized pinctrl subsystem [ 0.263093] DMI not present or invalid. [ 0.267654] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.274799] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.282286] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.290349] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.298532] audit: initializing netlink subsys (disabled) [ 0.304217] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1 [ 0.304695] thermal_sys: Registered thermal governor 'step_wise' [ 0.312150] thermal_sys: Registered thermal governor 'power_allocator' [ 0.318334] cpuidle: using governor menu [ 0.329151] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.336180] ASID allocator initialised with 32768 entries [ 0.351803] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.364782] KASLR enabled [ 0.374022] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.380996] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.387406] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.394346] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.400754] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.407693] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.414101] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.421040] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.428956] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.439417] iommu: Default domain type: Translated [ 0.444486] iommu: DMA domain TLB invalidation policy: strict mode [ 0.451183] SCSI subsystem initialized [ 0.455384] usbcore: registered new interface driver usbfs [ 0.461043] usbcore: registered new interface driver hub [ 0.466516] usbcore: registered new device driver usb [ 0.472155] pps_core: LinuxPPS API ver. 1 registered [ 0.477240] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.486593] PTP clock support registered [ 0.490733] EDAC MC: Ver: 3.0.0 [ 0.494879] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.501925] FPGA manager framework [ 0.505486] Advanced Linux Sound Architecture Driver Initialized. [ 0.512647] clocksource: Switched to clocksource arch_sys_counter [ 0.519150] VFS: Disk quotas dquot_6.6.0 [ 0.523202] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.536086] NET: Registered PF_INET protocol family [ 0.541391] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.550651] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.559460] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.567397] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.575600] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.583594] TCP: Hash tables configured (established 16384 bind 16384) [ 0.590509] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.597435] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.604961] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.611240] RPC: Registered named UNIX socket transport module. [ 0.617319] RPC: Registered udp transport module. [ 0.622129] RPC: Registered tcp transport module. [ 0.626937] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.633530] NET: Registered PF_XDP protocol family [ 0.638443] PCI: CLS 0 bytes, default 64 [ 0.643302] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.653444] Initialise system trusted keyrings [ 0.658260] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.669172] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.675755] NFS: Registering the id_resolver key type [ 0.680984] Key type id_resolver registered [ 0.685261] Key type id_legacy registered [ 0.689413] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.696270] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.738233] Key type asymmetric registered [ 0.742427] Asymmetric key parser 'x509' registered [ 0.747463] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.755184] io scheduler mq-deadline registered [ 0.759833] io scheduler kyber registered [ 0.767422] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.773979] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.781524] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.793959] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.810053] loop: module loaded [ 0.814481] megasas: 07.719.03.00-rc1 [ 0.821395] tun: Universal TUN/TAP device driver, 1.6 [ 0.827340] VFIO - User Level meta-driver version: 0.3 [ 0.833400] usbcore: registered new interface driver usb-storage [ 0.840115] i2c_dev: i2c /dev entries driver [ 0.845964] sdhci: Secure Digital Host Controller Interface driver [ 0.852322] sdhci: Copyright(c) Pierre Ossman [ 0.856993] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.863591] ledtrig-cpu: registered to indicate activity on CPUs [ 0.869929] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.876885] usbcore: registered new interface driver usbhid [ 0.882587] usbhid: USB HID core driver [ 0.887434] optee: probing for conduit method. [ 0.892027] optee: revision 4.1 (012cdca4) [ 0.892335] optee: dynamic shared memory is enabled [ 0.901913] optee: initialized driver [ 0.907357] Initializing XFRM netlink socket [ 0.911787] NET: Registered PF_PACKET protocol family [ 0.917038] Key type dns_resolver registered [ 0.921810] registered taskstats version 1 [ 0.926031] Loading compiled-in X.509 certificates [ 0.940598] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)') [ 0.993937] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19 [ 1.024353] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.031758] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.038658] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.044649] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.053887] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.066247] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.074487] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.085483] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.095495] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.105679] printk: console [ttyS2] disabled [ 1.110137] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 240, base_baud = 3000000) is a 8250 [ 1.119024] printk: console [ttyS2] enabled [ 1.119024] printk: console [ttyS2] enabled [ 1.127480] printk: bootconsole [ns16550a0] disabled [ 1.127480] printk: bootconsole [ns16550a0] disabled [ 1.138942] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.184670] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.194884] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.202994] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.211122] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.224113] am65-cpsw-nuss 8000000.ethernet: Use random MAC address [ 1.230382] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.237509] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.243970] pps pps0: new PPS source ptp0 [ 1.248282] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.258681] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.270318] mmc0: CQHCI version 5.10 [ 1.275041] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.281807] pca953x 1-0022: using AI [ 1.314501] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.315285] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.319591] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.333932] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.339326] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.346087] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.352430] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.358843] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.365018] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.371816] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.378213] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.395529] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.403272] mmc2: CQHCI version 5.10 [ 1.403278] mmc1: CQHCI version 5.10 [ 1.405175] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.422819] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19 [ 1.433357] mmc0: Command Queue Engine enabled [ 1.437814] mmc0: new HS200 MMC card at address 0001 [ 1.438220] ALSA device list: [ 1.443628] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.445073] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 1.445793] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.445895] No soundcards found. [ 1.454402] mmcblk0: p1 [ 1.472034] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.478563] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.484462] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0) [ 1.491542] /dev/root: Can't open blockdev [ 1.495782] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6 [ 1.503275] Please append a correct "root=" boot option; here are the available partitions: [ 1.511659] 1f00 512 mtdblock0 [ 1.511667] (driver?) [ 1.518244] 1f01 2048 mtdblock1 [ 1.518252] (driver?) [ 1.524806] 1f02 4096 mtdblock2 [ 1.524812] (driver?) [ 1.531363] 1f03 256 mtdblock3 [ 1.531370] (driver?) [ 1.537935] 1f04 256 mtdblock4 [ 1.537941] (driver?) [ 1.544493] 1f05 57088 mtdblock5 [ 1.544500] (driver?) [ 1.551041] 1f06 256 mtdblock6 [ 1.551046] (driver?) [ 1.557587] b300 15540224 mmcblk0 [ 1.557591] driver: mmcblk [ 1.564375] b301 15540190 mmcblk0p1 5d96d6f8-a093-4432-8eb5-49c535a76a73 [ 1.564381] [ 1.573339] b320 32256 mmcblk0boot0 [ 1.573344] (driver?) [ 1.580131] b340 32256 mmcblk0boot1 [ 1.580135] (driver?) [ 1.586924] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 1.595173] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.1.80-ti-g2e423244f8c0 #1 [ 1.602554] Hardware name: Texas Instruments AM625 SK (DT) [ 1.608025] Call trace: [ 1.610462] dump_backtrace.part.0+0xdc/0xf0 [ 1.614735] show_stack+0x18/0x30 [ 1.618042] dump_stack_lvl+0x68/0x84 [ 1.621699] dump_stack+0x18/0x34 [ 1.625004] panic+0x188/0x348 [ 1.628051] mount_block_root+0x188/0x23c [ 1.632052] mount_root+0x208/0x248 [ 1.635530] prepare_namespace+0x130/0x170 [ 1.639615] kernel_init_freeable+0x258/0x284 [ 1.643961] kernel_init+0x24/0x130 [ 1.647443] ret_from_fork+0x10/0x20 [ 1.651010] SMP: stopping secondary CPUs [ 1.654925] Kernel Offset: 0x80000 from 0xffff800008000000 [ 1.660395] PHYS_OFFSET: 0x80000000 [ 1.663870] CPU features: 0x00000,00900084,0000420b [ 1.668735] Memory Limit: none [ 1.671783] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
How to solve this error.
Veerapandiyan.
You cannot mix and match the SDK versions. 9.2 is the version we recommend that has all the boot optimizations.
Hi Shenai,
I did not understand and explain briefly.
Veerapandiyan V.
Hi Shenai,
I tried ti-processor-sdk-linux-am62xx-evm-09.02.01.09 and mcu_plus_sdk_am62x_09_02_00_38. I load the default_sbl_ospi_linux_falcon.cfg after changing the boot mode switch OSPI boot mode is coming same error I attached the error log below:
m4f0-0
r5f0-0
[BOOTLOADER PROFILE] System_init : 4927us
[BOOTLOADER PROFILE] Board_driversOpen : 6806us
[BOOTLOADER PROFILE] App_waitForMcuPbist : 4967us
[BOOTLOADER PROFILE] App_loadSelfcoreImage : 890us
[BOOTLOADER_PROFILE] SBL Total Time Taken : 43077us
hsm-m4f0-0
r5f0-0
a530-0
[BOOTLOADER PROFILE] System_init : 2841us
[BOOTLOADER PROFILE] Drivers_open : 368us
[BOOTLOADER PROFILE] Board_driversOpen : 28066us
[BOOTLOADER PROFILE] Sciclient Get Version : 10242us
[BOOTLOADER PROFILE] App_loadImages : 264us
[BOOTLOADER PROFILE] App_loadSelfcoreImage : 2548us
[BOOTLOADER PROFILE] App_loadLinuxImages : 172523us
[BOOTLOADER_PROFILE] SBL Total Time Taken : 216856us
[ 0.008551] Console: colour dummy device 80x25
[ 0.013150] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023833] pid_max: default: 32768 minimum: 301
[ 0.028599] LSM: Security Framework initializing
[ 0.033452] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.041036] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050855] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.058302] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064602] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.071998] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.078390] rcu: Hierarchical SRCU implementation.
[ 0.088901] Platform MSI: msi-controller@1820000 domain created
[ 0.095204] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.104605] EFI services will not be available.
[ 0.109520] smp: Bringing up secondary CPUs ...
[ 0.114842] Detected VIPT I-cache on CPU1
[ 0.114960] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.114977] GICv3: CPU1: using allocated LPI pending table @0x0000000081460000
[ 0.115037] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.115755] Detected VIPT I-cache on CPU2
[ 0.115830] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.115844] GICv3: CPU2: using allocated LPI pending table @0x0000000081470000
[ 0.115876] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.116494] Detected VIPT I-cache on CPU3
[ 0.116571] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.116585] GICv3: CPU3: using allocated LPI pending table @0x0000000081480000
[ 0.116617] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.116685] smp: Brought up 1 node, 4 CPUs
[ 0.196430] SMP: Total of 4 processors activated.
[ 0.201243] CPU features: detected: 32-bit EL0 Support
[ 0.206517] CPU features: detected: CRC32 instructions
[ 0.211830] CPU: All CPU(s) started at EL2
[ 0.216028] alternatives: applying system-wide alternatives
[ 0.223581] devtmpfs: initialized
[ 0.235022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.245060] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.257036] pinctrl core: initialized pinctrl subsystem
[ 0.263049] DMI not present or invalid.
[ 0.267617] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.274763] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.282242] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.290300] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.298481] audit: initializing netlink subsys (disabled)
[ 0.304168] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
[ 0.304638] thermal_sys: Registered thermal governor 'step_wise'
[ 0.312100] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.318284] cpuidle: using governor menu
[ 0.329106] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.336138] ASID allocator initialised with 32768 entries
[ 0.351713] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[ 0.364685] KASLR enabled
[ 0.373954] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.380929] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.387339] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.394278] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.400686] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.407624] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.414032] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.420971] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.428875] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.439375] iommu: Default domain type: Translated
[ 0.444400] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.451103] SCSI subsystem initialized
[ 0.455303] usbcore: registered new interface driver usbfs
[ 0.460953] usbcore: registered new interface driver hub
[ 0.466409] usbcore: registered new device driver usb
[ 0.472047] pps_core: LinuxPPS API ver. 1 registered
[ 0.477133] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.486489] PTP clock support registered
[ 0.490627] EDAC MC: Ver: 3.0.0
[ 0.494767] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.501810] FPGA manager framework
[ 0.505367] Advanced Linux Sound Architecture Driver Initialized.
[ 0.512519] clocksource: Switched to clocksource arch_sys_counter
[ 0.519014] VFS: Disk quotas dquot_6.6.0
[ 0.523070] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.535975] NET: Registered PF_INET protocol family
[ 0.541280] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.550544] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.559351] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.567288] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.575491] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.583486] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.590403] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.597329] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.604856] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.611128] RPC: Registered named UNIX socket transport module.
[ 0.617215] RPC: Registered udp transport module.
[ 0.622025] RPC: Registered tcp transport module.
[ 0.626834] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.633426] NET: Registered PF_XDP protocol family
[ 0.638339] PCI: CLS 0 bytes, default 64
[ 0.643198] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.653315] Initialise system trusted keyrings
[ 0.658130] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.669038] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.675605] NFS: Registering the id_resolver key type
[ 0.680844] Key type id_resolver registered
[ 0.685122] Key type id_legacy registered
[ 0.689275] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.696131] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.738688] Key type asymmetric registered
[ 0.742884] Asymmetric key parser 'x509' registered
[ 0.747921] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.755641] io scheduler mq-deadline registered
[ 0.760289] io scheduler kyber registered
[ 0.767801] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.774366] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.781915] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.794250] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.810379] loop: module loaded
[ 0.814804] megasas: 07.719.03.00-rc1
[ 0.821699] tun: Universal TUN/TAP device driver, 1.6
[ 0.827639] VFIO - User Level meta-driver version: 0.3
[ 0.833680] usbcore: registered new interface driver usb-storage
[ 0.840407] i2c_dev: i2c /dev entries driver
[ 0.846227] sdhci: Secure Digital Host Controller Interface driver
[ 0.852588] sdhci: Copyright(c) Pierre Ossman
[ 0.857260] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.863873] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.870210] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.877161] usbcore: registered new interface driver usbhid
[ 0.882865] usbhid: USB HID core driver
[ 0.887698] optee: probing for conduit method.
[ 0.892307] optee: revision 4.1 (012cdca4)
[ 0.892619] optee: dynamic shared memory is enabled
[ 0.902193] optee: initialized driver
[ 0.907618] Initializing XFRM netlink socket
[ 0.912055] NET: Registered PF_PACKET protocol family
[ 0.917304] Key type dns_resolver registered
[ 0.922070] registered taskstats version 1
[ 0.926290] Loading compiled-in X.509 certificates
[ 0.940876] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
[ 0.994026] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
[ 1.024375] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.031811] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.038708] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.044701] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.053945] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.066310] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.074564] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.085544] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.095566] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.105762] printk: console [ttyS2] disabled
[ 1.110223] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 240, base_baud = 3000000) is a 8250
[ 1.119107] printk: console [ttyS2] enabled
[ 1.127564] printk: bootconsole [ns16550a0] disabled
[ 1.139026] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.184541] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.194761] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.202871] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.210997] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.223988] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 1.230256] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.237382] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.243845] pps pps0: new PPS source ptp0
[ 1.248149] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.258514] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.270034] mmc0: CQHCI version 5.10
[ 1.274828] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.281607] pca953x 1-0022: using AI
[ 1.314399] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.315026] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.319488] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.333823] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.339216] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.345973] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.352304] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.358710] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.364871] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.371672] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.378062] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.395316] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.403093] mmc1: CQHCI version 5.10
[ 1.403111] mmc2: CQHCI version 5.10
[ 1.404833] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
[ 1.409712] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
[ 1.430676] mmc0: Command Queue Engine enabled
[ 1.433243] ALSA device list:
[ 1.435164] mmc0: new HS200 MMC card at address 0001
[ 1.438097] No soundcards found.
[ 1.443853] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.455046] mmcblk0: p1
[ 1.458313] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.460254] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.464488] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.468733] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.484375] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.491455] /dev/root: Can't open blockdev
[ 1.495624] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 1.503113] Please append a correct "root=" boot option; here are the available partitions:
[ 1.511526] 1f00 512 mtdblock0
[ 1.511534] (driver?)
[ 1.518113] 1f01 2048 mtdblock1
[ 1.518118] (driver?)
[ 1.524685] 1f02 4096 mtdblock2
[ 1.524691] (driver?)
[ 1.531255] 1f03 256 mtdblock3
[ 1.531261] (driver?)
[ 1.537818] 1f04 256 mtdblock4
[ 1.537825] (driver?)
[ 1.544353] 1f05 57088 mtdblock5
[ 1.544359] (driver?)
[ 1.550883] 1f06 256 mtdblock6
[ 1.550887] (driver?)
[ 1.557416] b300 15540224 mmcblk0
[ 1.557420] driver: mmcblk
[ 1.564202] b301 15540190 mmcblk0p1 5d96d6f8-a093-4432-8eb5-49c535a76a73
[ 1.564208]
[ 1.573167] b320 32256 mmcblk0boot0
[ 1.573171] (driver?)
[ 1.579953] b340 32256 mmcblk0boot1
[ 1.579957] (driver?)
[ 1.586744] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.594992] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.80-ti-g2e423244f8c0 #1
[ 1.602373] Hardware name: Texas Instruments AM625 SK (DT)
[ 1.607844] Call trace:
[ 1.610280] dump_backtrace.part.0+0xdc/0xf0
[ 1.614552] show_stack+0x18/0x30
[ 1.617858] dump_stack_lvl+0x68/0x84
[ 1.621514] dump_stack+0x18/0x34
[ 1.624820] panic+0x188/0x348
[ 1.627867] mount_block_root+0x188/0x23c
[ 1.631869] mount_root+0x208/0x248
[ 1.635347] prepare_namespace+0x130/0x170
[ 1.639432] kernel_init_freeable+0x258/0x284
[ 1.643777] kernel_init+0x24/0x130
[ 1.647258] ret_from_fork+0x10/0x20
[ 1.650826] SMP: stopping secondary CPUs
[ 1.654742] Kernel Offset: 0x80000 from 0xffff800008000000
[ 1.660212] PHYS_OFFSET: 0x80000000
[ 1.663687] CPU features: 0x00000,00900084,0000420b
[ 1.668553] Memory Limit: none
[ 1.671602] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
How to solve the problem.
Veerapandiyan
Hi Veerapandiyan,
Could you share what are the steps you have followed until now?
Do the default images, without any changes work for you?
Aparna
Hi Aparna,
I tried ti-processor-sdk-linux-am62xx-evm-09.02.01.09 and mcu_plus_sdk_am62x_09_02_00_38. I load the default_sbl_ospi_linux_falcon.cfg file below:
#-----------------------------------------------------------------------------# # # # DEFAULT CONFIGURATION FILE TO BE USED WITH THE FLASHWRITER SCRIPT # # # #-----------------------------------------------------------------------------# # # By default this config file, # - points to pre-built flash writer, bootloader for this EVM # - The application image points to relative path of the ipc rpmsg linux application image for this EVM # - Make sure this application is built before running this script # - You can customized this config file to point to your own bootloader and/or application images # - You can use --operation=flashverify if you just want to verify the flash contents and not flash the file. # # First point to sbl_uart_uniflash_stage1 binary, which initialises DDR and receives sbl_uart_uniflash_stage2 binary --flash-writer=sbl_prebuilt/am62x-sk/sbl_uart_uniflash_stage1.release.tiimage # When sending sbl_uart_uniflash_stage2 binary make sure to flash at SOC memory offset 0x0. # Points to sbl_uart_uniflash_stage2 binary, which function's as a server to flash one or more files --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62x-sk/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.release.appimage --operation=flash --flash-offset=0x0 # Program the OSPI PHY tuning attack vector --operation=flash-phy-tuning-data # Now send one or more files to flash or flashverify as needed. The order of sending files does not matter # When sending bootloader make sure to flash at offset 0x0. ROM expects bootloader at offset 0x0 --file=sbl_prebuilt/am62x-sk/sbl_ospi_linux_stage1.release.tiimage --operation=flash --flash-offset=0x0 # 2nd stage bootloader is flashed at 0x80000 or to whatever offset your bootloader is configured for --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/examples/drivers/boot/sbl_ospi_linux_multistage/sbl_ospi_linux_stage2/am62x-sk/r5fss0-0_nortos/ti-arm-clang/sbl_ospi_linux_stage2.release.appimage --operation=flash --flash-offset=0x80000 # When sending application image, make sure to flash at offset 0x100000 (default) or to whatever offset your bootloader is configured for --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/examples/drivers/gpio/gpio_led_blink/am62x-sk/m4fss0-0_freertos/ti-arm-clang/gpio_led_blink.release.appimage --operation=flash --flash-offset=0x100000 # HSM image is flashed at 0x800000 or to whatever offset your bootloader is configured for --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/tools/boot/HSMAppimageGen/board/am62x-sk/hsm.appimage --operation=flash --flash-offset=0x800000 # DM image is flashed at 0xa00000 or to whatever offset your bootloader is configured for --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/examples/drivers/ipc/ipc_rpmsg_echo_linux/am62x-sk/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo_linux.release.appimage --operation=flash --flash-offset=0xA00000 # Linux image is flashed at 0xC00000 or to whatever offset your bootloader is configured for --file=/home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/tools/boot/linuxAppimageGen/board/am62x-sk/linux.appimage --operation=flash --flash-offset=0xC00000
1. Not compiling lines 16,23 and 27 this file is already built.
2. I compiled the file lines 20,31 and 40 also compiled using the command: make -s all
3. 34 file only compiles CCS software.
4. 37 HSM image compiled using the command: make -s BOARD=am62x-sk all
5. 43 Linux image compiled using the command: make -s BOARD=am62x-sk all FALCON_MODE=1
After saving the file. Next change the boot mode switch to UART boot mode open then this location /home/bpt/ti/mcu_plus_sdk_am62x_09_02_00_38/tools/boot/ open terminal use the command: sudo python3 uart_uniflash.py -p /dev/ttyUSB0 --cfg=sbl_prebuilt/am62x-sk/default_sbl_ospi_linux_falcon.cfg
Veerapandiyan V.
Hello Veerapandiyan,
The steps look correct. Is the wic image correctly flashed into the SD card ?
Linux kernel loads from SD card. Make sure the version of wic image flashed into the SD card matches with the sdk version.
Aparna
Hi Aparna,
SD card boot mode working fine 9.2 version processor SDK. I tried SBL boot default_sbl_ospi_linux.cfg mode working fine but I tried SBL boot default_sbl_ospi_linux_falcon.cfg mode only got an error. How to fixproblem
Veerapandiyan
Hi Veerapandiyan,
In falcon boot mode, since there is no U-boot, you will need to pass the the location of filesystem in bootargs. Please apply the following change and try again:
diff --git a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
index 4b8e7964c..3fbfca6e9 100644
--- a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
+++ b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
@@ -38,6 +38,7 @@ chosen {
ranges;
stdout-path = &main_uart0;
+ bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait";
framebuffer0: framebuffer@0 {
compatible = "simple-framebuffer";
Here, the boot media is SD card and filesystem is present in 2nd partition. You can make the modifications accordingly.
Aparna
Hi Aparna,
I edited the file location and then put sudo make linux command is getting an error asking how to fix it. I attached the error log file below.
+2e423244f8-ti'
make[1]: Leaving directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-linux-kernel-6.1.80+gitAUTOINC+2e423244f8-ti'
make[1]: Entering directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-linux-kernel-6.1.80+gitAUTOINC+2e423244f8-ti'
Building U-boot for R5
mkdir -p /home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/u-boot-build/r5
make -j 4 -C /home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot* ARCH=arm am62x_evm_r5_defconfig O=/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/u-boot-build/r5
make[1]: Entering directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot-2023.04+gitAUTOINC+f9b966c674'
make[2]: Entering directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/u-boot-build/r5'
GEN Makefile
# configuration written to .config
make[2]: Leaving directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/u-boot-build/r5'
make[1]: Leaving directory '/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot-2023.04+gitAUTOINC+f9b966c674'
make -j 4 -C /home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot* ARCH=arm CROSS_COMPILE=/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/k3r5-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-oe-eabi/arm-oe-eabi- \
BINMAN_INDIRS=/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/prebuilt-images/am62xx-evm O=/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/u-boot-build/r5
GEN Makefile
scripts/kconfig/conf --syncconfig Kconfig
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN Makefile
ENVC include/generated/env.txt
UPD include/generated/timestamp_autogenerated.h
ENVP include/generated/env.in
ENVT include/generated/environment.h
Using /home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot-2023.04+gitAUTOINC+f9b966c674 as source for U-Boot
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/fit_info
HOSTLD tools/fit_check_sign
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_lock_new':
threads_pthread.c:(.text+0x4a): undefined reference to `pthread_rwlock_init'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_read_lock':
threads_pthread.c:(.text+0x89): undefined reference to `pthread_rwlock_rdlock'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_write_lock':
threads_pthread.c:(.text+0xa9): undefined reference to `pthread_rwlock_wrlock'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_unlock':
threads_pthread.c:(.text+0xc9): undefined reference to `pthread_rwlock_unlock'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_lock_free':
threads_pthread.c:(.text+0xee): undefined reference to `pthread_rwlock_destroy'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_run_once':
threads_pthread.c:(.text+0x129): undefined reference to `pthread_once'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_init_local':
threads_pthread.c:(.text+0x149): undefined reference to `pthread_key_create'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_set_local':
threads_pthread.c:(.text+0x17b): undefined reference to `pthread_setspecific'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_cleanup_local':
threads_pthread.c:(.text+0x19b): undefined reference to `pthread_key_delete'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `openssl_init_fork_handlers':
threads_pthread.c:(.text+0x207): undefined reference to `pthread_once'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_get_local':
threads_pthread.c:(.text+0x167): undefined reference to `pthread_getspecific'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `/usr/bin/ld: CRYPTO_THREAD_write_lock':
threads_pthread.c:threads_pthread.c:(.text(+0x4a.text+0xa9): undefined reference to `pthread_rwlock_init'
)/usr/bin/ld: undefined reference to `: /usr/local/lib/libcrypto.a(threads_pthread.o)pthread_rwlock_wrlock'
threads_pthread.c:(.text+0x/usr/bin/ld89): undefined reference to `: pthread_rwlock_rdlock'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `/usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_write_lock':
CRYPTO_THREAD_unlockthreads_pthread.c:(':
threads_pthread.c:.text+0xa9): undefined reference to `pthread_rwlock_wrlock('
/usr/bin/ld: .text/usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_unlock':
threads_pthread.c:+0x(.text+0xc9)c9): undefined reference to `pthread_rwlock_unlock: undefined reference to `'
/usr/bin/ld: pthread_rwlock_unlock/usr/local/lib/libcrypto.a(threads_pthread.o): in function `'
/usr/bin/ldCRYPTO_THREAD_lock_free':
threads_pthread.c:(.text+0x: ee): undefined reference to `pthread_rwlock_destroy'
/usr/local/lib/libcrypto.a(threads_pthread.o)/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_run_once':
threads_pthread.c:(.text: in function `CRYPTO_THREAD_lock_free':
+0xthreads_pthread.c:(.text+0xee): undefined reference to `pthread_rwlock_destroy'
/usr/bin/ld/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_run_once':
/usr/bin/ld: : /usr/local/lib/libcrypto.a(threads_pthread.o)/usr/local/lib/libcrypto.a(threads_pthread.o): in function `: in function `CRYPTO_THREAD_init_localCRYPTO_THREAD_init_local':
threads_pthread.c:threads_pthread.c:((.text+0x.text+0x149149): undefined reference to `pthread_key_create): undefined reference to `'
/usr/bin/ldpthread_key_create'
/usr/bin/ld: : /usr/local/lib/libcrypto.a(threads_pthread.o): in function `/usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_set_local':
threads_pthread.c:CRYPTO_THREAD_set_local':
threads_pthread.c:(.text+0x(.text+0x17b): undefined reference to `17b): undefined reference to `pthread_setspecific'
pthread_setspecific/usr/bin/ld: '
/usr/bin/ld/usr/local/lib/libcrypto.a(threads_pthread.o): /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_cleanup_local':
threads_pthread.c:: in function `(CRYPTO_THREAD_cleanup_local.text':
threads_pthread.c:+0x(19b).text+0x19b: undefined reference to `pthread_key_delete'
/usr/bin/ld: ): undefined reference to `pthread_key_delete/usr/local/lib/libcrypto.a(threads_pthread.o): in function `'
/usr/bin/ldopenssl_init_fork_handlers':
threads_pthread.c:: /usr/local/lib/libcrypto.a(threads_pthread.o)(.text+0x207: in function `)openssl_init_fork_handlers: undefined reference to `pthread_once':
/usr/bin/ld: .text+0x207/usr/local/lib/libcrypto.a(threads_pthread.o): in function `): undefined reference to `pthread_onceCRYPTO_THREAD_get_local':
threads_pthread.c:'
/usr/bin/ld(.text+0x167: ): undefined reference to `/usr/local/lib/libcrypto.a(threads_pthread.o): in function `pthread_getspecific'
/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_globallookup':
dso_dlfcn.c:(.text+0x17): undefined reference to `dlopen'
/usr/bin/ld: dso_dlfcn.c:(.text+0x2a): undefined reference to `dlsym'
/usr/bin/ld: dso_dlfcn.c:(.text+0x35): undefined reference to `dlclose'
/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_bind_func':
dso_dlfcn.c:(.text+0x1b7): undefined reference to `dlsym'
/usr/bin/ld: dso_dlfcn.c:(.text+0x282): undefined reference to `dlerror'
/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_load':
dso_dlfcn.c:(.text+0x2f5): undefined reference to `dlopen'
/usr/bin/ld: dso_dlfcn.c:(.text+0x369): undefined reference to `dlclose'
/usr/bin/ld: dso_dlfcn.c:(.text+0x3a5): undefined reference to `dlerror'
/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_pathbyaddr':
dso_dlfcn.c:(.text+0x466): undefined reference to `dladdr'
/usr/bin/ld: dso_dlfcn.c:(.text+0x4d7): undefined reference to `dlerror'
/usr/bin/ld: /usr/bin/ld/usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_globallookup: ':
/usr/bin/ld/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_pathbyaddr':
dso_dlfcn.c:(.text+0x466): undefined reference to `/usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_unload':
dso_dlfcn.c:(.text+0x6b8): undefined reference to `dlclose'
: dladdr'
/usr/bin/ld: dso_dlfcn.c:(.text+0x4d7)/usr/local/lib/libcrypto.a(dso_dlfcn.o): undefined reference to `: in function `dlerrordlfcn_globallookup'
dso_dlfcn.c:(/usr/bin/ld.text: +0x/usr/local/lib/libcrypto.a(dso_dlfcn.o)17): in function `: undefined reference to `dlfcn_unloaddlopen':
dso_dlfcn.c:/usr/bin/ld(.text: +0xdso_dlfcn.c:6b8().text: undefined reference to `dlclose+0x2a'
/usr/bin/ld: dso_dlfcn.c:(.text+0x/usr/bin/ld282: ): undefined reference to `/usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_lock_new':
threads_pthread.c:(.textdlerror+0x4a): undefined reference to `pthread_rwlock_init'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o)'
/usr/bin/ld: in function `CRYPTO_THREAD_read_lock':
threads_pthread.c:(.text+0x89): undefined reference to `pthread_rwlock_rdlock: '
threads_pthread.c:(.text+0xc9): undefined reference to `/usr/local/lib/libcrypto.a(dso_dlfcn.o)pthread_rwlock_unlock'
: in function `/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_lock_free':
threads_pthread.c:(.text+0xee): undefined reference to `pthread_rwlock_destroydlfcn_load'
/usr/bin/ld: ':
dso_dlfcn.c:(/usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_run_once':
.text/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_init_local':
+0xthreads_pthread.c:(.text+0x17b): undefined reference to `pthread_setspecific'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_cleanup_local2f5): undefined reference to `dlopen':
threads_pthread.c:(.text+0x207)/usr/bin/ld: undefined reference to `pthread_once'
/usr/bin/ld: /usr/local/lib/libcrypto.a(threads_pthread.o): in function `CRYPTO_THREAD_get_local: ':
threads_pthread.c:(.text+0x167)dso_dlfcn.c:: undefined reference to `pthread_getspecific'
/usr/bin/ld: /usr/local/lib/libcrypto.a(dso_dlfcn.o): in function `dlfcn_unload':
collect2: error: ld returned 1 exit status
make[3]: *** [scripts/Makefile.host:104: tools/dumpimage] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [scripts/Makefile.host:104: tools/mkimage] Error 1
make[3]: *** [scripts/Makefile.host:104: tools/fit_check_sign] Error 1
make[3]: *** [scripts/Makefile.host:104: tools/fit_info] Error 1
make[2]: *** [/home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-u-boot-2023.04+gitAUTOINC+f9b966c674/Makefile:1848: tools] Error 2
make[1]: *** [Makefile:177: sub-make] Error 2
make: *** [makerules/Makefile_u-boot:28: u-boot-r5] Error 2
How to solve.
Veerapandiyan V.
Hi Veerapandiyan,
After making the changes, please run make linux in the SDK directory.
Aparna
Hi Aparna,
make linux command also used the same error coming how to fix it.
Veerapandiyan V.
Hi Veerapandiyan,
I couldnot reproduce the above error at my end.
Are there any additional changes in the Linux kernel?
Aparna
Hi Aparna,
I am not editing this file.
I am using the Linux version below:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
Veerapandiyan V.
Hi Aparna,
I am trying for the Ubuntu 22 version build to be done. Then I installed files on the SD card, Next, I powered up the EVM board in the SD boot mode not reducing the delay again coming 16 sec I attached the screenshot below:
Using Commands:
1. First edit the file, Next, build the Linux command make linux
2. make linux_stage
3. Insert the SD card and then open the processor SDK path to install compiled files in SD card using the command: sudo DESTDIR=/media/$USER/rootfs make linux_install
5. For GP Board copy the tiboot3 and uboot img files command below
host# sudo cp board-support/built-images/tiboot3-am62*-gp-evm.bin /media/$USER/boot/tiboot3.bin
host# sudo cp board-support/built-images/u-boot.img board-support/built-images/tispl.bin /media/$USER/boot
6. Next Insert the SD card EVM board powered up board not reducing time delay in SD card boot mode.
7. How to reduce boot time delay please update.
Veerapandiyan V.
Hi Aparna,
This problem is not solved this green color automatically comes.
Veerapandiyan V.
Hi Veerapandiyan,
From the logs shared by you, looks like the changes mentioned in documentation are not applied. Refer here
Adding "quiet" argument in bootargs, will suppress the kernel messages, and reduce ~8 secs.
Aparna
Hi Aparna,
I was adding the bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 quiet"; command the file location is /home/bpt/ti-processor-sdk-linux-am62xx-evm-09.02.01.09/board-support/ti-linux-kernel-6.1.80+gitAUTOINC+2e423244f8-ti/arch/arm64/boot/dts/ti k3-am62p5-sk.dts file edit then build using the command make linux after finishing the build. After copy the files sd card using commend below:
k3-am62p5-sk.dts
comment
1. To install in SD card directly: host# sudo DESTDIR=/media/media/bpt/rootfs make linux_install
2. host# sudo cp board-support/built-images/tiboot3-am62*-gp-evm.bin /media/bpt/boot/tiboot3.bin
3. host# sudo cp board-support/built-images/u-boot.img board-support/built-images/tispl.bin /media/bpt/boot
Otherwise how to transfer files and build please tell me.
Veerapandiyan V.
Hi Veerapandiyan,
make linux command is used to build the Linux kernel, and hence you have to modify the Image and and k3-am625-sk.dtb files in the root partition of the SD card.
Location of Image: linux/arch/arm64/boot/
Location of dtb:linux/arch/arm64/boot/dts/ti/
Aparna
Hi Aparna,
I tried make linux command is coming permission error. so I put for sudo make linux
Veerapandiyan V.
Hi Aparna,
I am using AM62X SR1.0 GP Board this board possibly fast boot please tell me. dtb file also not coming.
Veerapandiyan V.
Hi Aparna,
I am checking the AM62P HS-FS board and it is also not reducing boot time how to reduce boot time?. Please tell me
Veerapandiyan V.
Its preferred to use AM62P for fast boot. I dont understand your progress from what you have mentioned before. Please elaborate on whats done?
Aparna
HI Aparna,
Now, I have tried with am62p by the method of editing the dts file and using the commands in u-boot based on your previous reply.
Fullscreen123456789101112diff --git a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dtsindex 4b8e7964c..3fbfca6e9 100644--- a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts+++ b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts@@ -38,6 +38,7 @@ chosen {ranges;stdout-path = &main_uart0;+ bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait";framebuffer0: framebuffer@0 {compatible = "simple-framebuffer";XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXdiff --git a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts index 4b8e7964c..3fbfca6e9 100644 --- a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts +++ b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts @@ -38,6 +38,7 @@ chosen { ranges; stdout-path = &main_uart0; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait"; framebuffer0: framebuffer@0 { compatible = "simple-framebuffer";Here, the boot media is SD card and filesystem is present in 2nd partition. You can make the modifications accordingly.
I tried falcon mode and got an error when built the linuxappimage.hs_fs using this command make -s BOARD=am62px-sk all FALCON_MODE=1
kindly provide the correct steps for fast booting in am62p as earliest possible
Veerapandiyan V.
I hope you have replaced the following files before building the linuxappimage.hs_fs:ATF_BIN_NAME=bl31.bin
OPTEE_BIN_NAME=bl32.bin
KERN_BIN_NAME=Image
FDT_BIN_NAME=k3-am625-sk.dtb
Refer config.mak file in tools/boot/linuxAppimageGen/board/am62px..
If yes, then please re-build the linuxappimage.hs_fs and share the error logs.
Aparna
Hi Aparna,
I am not replacing the commands see the screenshot below:
KERN_BIN_NAME=Image
Error Msg Screenshot:
Error location screen shot:
How to fix the error. please tell me
Veerapandiyan V
I couldn't find the Image file in the above-mentioned directory. You can find this file in processor SDK. Please place the Image file into am62pxx-evm-display-cluster/ directory and try again.
Aparna
Hi Aparna,
based on your previous instructions I have tried that and the file has been created successfully but while booting, it stopped booting for your reference I have attached the screenshot kindly go through this and let me know the solutions.
update: for fast boot, I can see that bare-metal code is loading and I can see it in MCU UART, but the Linux is not loading to any point (i.e, the splash bin file is not loading) and it gets stuck to this point on the Linux side.
Veerapandiyan V.
The linux image is not booting.
Can you please re-build and try again?
https://software-dl.ti.com/mcu-plus-sdk/esd/AM62PX/09_02_00_38/exports/docs/api_guide_am62px/TOOLS_BOOT.html#LINUX_APPIMAGE_GEN_TOOL
Aparna
Hi Aparna,
I have rebuilt and tried again based on the commands provided in the above link and again i'm facing the same issue, there is no change in it.
Kindly verify and let me know the solution
Veerapandiyan V
Hello, could you try the following:
Apply the following patch to ATF source code and rebuild ATF. This patch changes the kernel image load address from 0x80080000 to 0x80200000.
diff --git a/plat/ti/k3/common/k3_bl31_setup.c b/plat/ti/k3/common/k3_bl31_setup.c
index bbfb5bbfce1c..08fb296e7811 100644
--- a/plat/ti/k3/common/k3_bl31_setup.c
+++ b/plat/ti/k3/common/k3_bl31_setup.c
@@ -80,6 +80,7 @@ void bl31_early_platform_setup2(u_register_t arg0, u_register_t arg1,
bl33_image_ep_info.pc = PRELOADED_BL33_BASE;
bl33_image_ep_info.spsr = k3_get_spsr_for_bl33_entry();
SET_SECURITY_STATE(bl33_image_ep_info.h.attr, NON_SECURE);
+ NOTICE("BL33 base: 0x%x\n", PRELOADED_BL33_BASE);
#ifdef K3_HW_CONFIG_BASE
diff --git a/plat/ti/k3/platform.mk b/plat/ti/k3/platform.mk
index bce9ef176b3c..f1a008ed4251 100644
--- a/plat/ti/k3/platform.mk
+++ b/plat/ti/k3/platform.mk
@@ -13,7 +13,7 @@ include ${PLAT_PATH}/board/${TARGET_BOARD}/board.mk
BL32_BASE ?= 0x9e800000
$(eval $(call add_define,BL32_BASE))
-PRELOADED_BL33_BASE ?= 0x80080000
+PRELOADED_BL33_BASE ?= 0x80200000
$(eval $(call add_define,PRELOADED_BL33_BASE))
K3_HW_CONFIG_BASE ?= 0x82000000Regards,
Aparna
Hi Aparna,
could please tell me the file location and the procedure in detail
Copy the new ATF binary bl31.bin to the location where the kernel FIT image for falcon boot is generated, and modify the FIT image ITS to update kernel load address from 0x80080000 to 0x80200000, then re-generate the kernel FIT image- linuxappimage
Briefly explain this, unable to understand.
Veerapandiyan.
The file location is mentioned in the shared patch. Make changes by referring to the patch, in the SDK/board-support/trusted-firmware-a-2.10+gitAUTOINC+00f1ec6b87/ directory.
Steps to build after applying patch:
https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/latest/exports/docs/linux/Foundational_Components_ATF.html
After you build the bl31.bin, copy it to the mcu+ sdk, so that new address as updated in the patch will be used and re-build the linux.appimage.hs_fs
Aparna
Hi Aparna,
I get this error when I'm trying to build the ATF file. Kindly check and let me know the solution.
Veerapandiyan V.
Hi Aparna,
Any Update? I am waiting for your reply.
Veerapandiyan.V
Could you provide absolute path of the cross compiler?
There is issue with gcc.
Aparna
