AM623: SDK9.2 UART boot hang and reset if doesn't stop
Part Number: AM623
Boot from UART, after UBoot run up  and doesn't Hit to stop autoboot within 3 second, it will scan boot device, then report error and reset.
ü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
[2024-04-26 12:13:50.346] U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
[2024-04-26 12:13:50.379] SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
[2024-04-26 12:13:50.426] SPL initial stack usage: 13408 bytes
[2024-04-26 12:13:50.445] Trying to boot from UART
[2024-04-26 12:13:50.445] CCLoaded 1182907 bytes
[2024-04-26 12:16:23.790] Starting ATF on ARM64 core...
[2024-04-26 12:16:23.790] NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
[2024-04-26 12:16:23.790] NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
[2024-04-26 12:16:24.144]
[2024-04-26 12:16:24.144] U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
[2024-04-26 12:16:24.144] SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
[2024-04-26 12:16:24.208] SPL initial stack usage: 1856 bytes
[2024-04-26 12:16:26.210] MMC: no card present
[2024-04-26 12:16:26.224] ** Bad device specification mmc 1 **
[2024-04-26 12:16:26.224] Couldn't find partition mmc 1:1
[2024-04-26 12:16:26.224] Error: could not access storage.
[2024-04-26 12:16:26.224] Trying to boot from UART
[2024-04-26 12:16:26.224] CCLoaded 987683 bytes
[2024-04-26 12:18:28.521]
[2024-04-26 12:18:28.522]
[2024-04-26 12:18:28.522] U-Boot 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
[2024-04-26 12:18:28.522] SoC:   AM62X SR1.0 HS-FS
[2024-04-26 12:18:28.522] Model: Texas Instruments AM625 SK
[2024-04-26 12:18:28.568] EEPROM not available at 80, trying to read at 81
[2024-04-26 12:18:28.584] Board: AM62B-SKEVM rev A
[2024-04-26 12:18:28.584] DRAM:  no bloblist found!2 GiB
[2024-04-26 12:18:28.888] Core:  72 devices, 32 uclasses, devicetree: separate
[2024-04-26 12:18:28.888] MMC:   mmc@fa10000: 0, mmc@fa00000: 1
[2024-04-26 12:18:28.904] Loading Environment from nowhere... OK
[2024-04-26 12:18:28.919] In:    serial
[2024-04-26 12:18:28.919] Out:   serial
[2024-04-26 12:18:28.919] Err:   serial
[2024-04-26 12:18:28.919] Net:   eth0: ethernet@8000000port@1
[2024-04-26 12:18:28.936] Hit any key to stop autoboot:  2  1  0
[2024-04-26 12:18:32.935] MMC: no card present
[2024-04-26 12:18:33.016] SD/MMC found on device 1
[2024-04-26 12:18:35.016] MMC: no card present
[2024-04-26 12:18:35.016] ** Bad device specification mmc 1 **
[2024-04-26 12:18:35.016] Couldn't find partition mmc 1
[2024-04-26 12:18:35.033] Can't set block device
[2024-04-26 12:18:37.032] MMC: no card present
[2024-04-26 12:18:37.032] ** Bad device specification mmc 1 **
[2024-04-26 12:18:37.032] Couldn't find partition mmc 1
[2024-04-26 12:18:37.032] Can't set block device
[2024-04-26 12:18:39.031] MMC: no card present
[2024-04-26 12:18:39.031] ** Bad device specification mmc 1 **
[2024-04-26 12:18:39.047] ## Error: "main_cpsw0_qsgmii_phyinit" not defined
[2024-04-26 12:18:41.047] MMC: no card present
[2024-04-26 12:18:41.047] ** Bad device specification mmc 1 **
[2024-04-26 12:18:41.047] Couldn't find partition mmc 1:2
[2024-04-26 12:18:41.062] Can't set block device
[2024-04-26 12:18:43.063] MMC: no card present
[2024-04-26 12:18:43.063] ** Bad device specification mmc 1 **
[2024-04-26 12:18:43.063] Couldn't find partition mmc 1:2
[2024-04-26 12:18:43.063] Can't set block device
[2024-04-26 12:18:43.063] libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[2024-04-26 12:18:43.079] No FDT memory address configured. Please configure
[2024-04-26 12:18:43.079] the FDT address via "fdt addr <address>" command.
[2024-04-26 12:18:43.079] Aborting!
[2024-04-26 12:18:43.079] Bad Linux ARM64 Image magic!
[2024-04-26 12:18:43.239] switch to partitions #0, OK
[2024-04-26 12:18:43.239] mmc0(part 0) is current device
[2024-04-26 12:18:43.288] Scanning mmc 0:1...
[2024-04-26 12:18:45.320] MMC: no card present
[2024-04-26 12:18:45.320] No EFI system partition
[2024-04-26 12:18:45.320] Failed to persist EFI variables
[2024-04-26 12:18:45.335] "Synchronous Abort" handler, esr 0x96000044
[2024-04-26 12:18:45.335] elr: 000000008085909c lr : 0000000080859038 (reloc)
[2024-04-26 12:18:45.335] elr: 00000000fff5f09c lr : 00000000fff5f038
[2024-04-26 12:18:45.352] x0 : 00000000fdf06110 x1 : ffffffffff700000
[2024-04-26 12:18:45.352] x2 : fffffffffffca000 x3 : 0000000000000000
[2024-04-26 12:18:45.352] x4 : 0000000000000000 x5 : 0000000000000000
[2024-04-26 12:18:45.352] x6 : 00000000fdf06110 x7 : 0000000000000000
[2024-04-26 12:18:45.367] x8 : 00000000fded7820 x9 : 0000000000000008
[2024-04-26 12:18:45.367] x10: 00000000000024bc x11: 00000000fded527c
[2024-04-26 12:18:45.367] x12: 0000000000002488 x13: 0000000000000000
[2024-04-26 12:18:45.367] x14: 00000000fded7820 x15: 0000000000000002
[2024-04-26 12:18:45.384] x16: 00000000fff5f0cc x17: 0000000000000000
[2024-04-26 12:18:45.384] x18: 00000000fdee6d80 x19: 0000000000000000
[2024-04-26 12:18:45.384] x20: 00000000fdeea650 x21: 00000000fded5570
[2024-04-26 12:18:45.384] x22: 00000000fffb5491 x23: 0000000000000002
[2024-04-26 12:18:45.399] x24: 00000000fffe4574 x25: 0000000000000000
[2024-04-26 12:18:45.399] x26: 0000000000000000 x27: 0000000000000000
[2024-04-26 12:18:45.399] x28: 00000000fdf01900 x29: 00000000fded5510
[2024-04-26 12:18:45.399] Code: f9401001 8b020022 eb02003f 54fffec2 (b8004433)
[2024-04-26 12:18:45.415] Resetting CPU ...
[2024-04-26 12:18:45.415] resetting ...
[2024-04-26 12:18:45.511] 02000000011a0000616d3632780000000000000048534653010001000100010002a6000000000000d68ecb2c055dff11ade95bd927e837d2a53bc23b0a2800cebce4f106bcf309df2213912d77a157a8b7c2df40672a06a918034aa4c7d603e462481475225d49b8ad0bc40b0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005daa24a20a39caa401ce063b897b24b9d34f88a1fb620ff51db193811002a3caCCCC
With previous SDK, can ctrl+C to stop to enter command:
[2024-04-26 12:43:28.274] U-Boot SPL 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
[2024-04-26 12:43:28.305] SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
[2024-04-26 12:43:28.339] SPL initial stack usage: 13384 bytes
[2024-04-26 12:43:28.353] Trying to boot from UART
[2024-04-26 12:43:28.353] CCCCCCCCLoaded 970443 bytes
[2024-04-26 12:48:47.227]
[2024-04-26 12:48:47.227] U-Boot 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
[2024-04-26 12:48:47.227] SoC:   AM62X SR1.0 HS-FS
[2024-04-26 12:48:47.242] Model: Texas Instruments AM625 SK
[2024-04-26 12:48:47.274] EEPROM not available at 80, trying to read at 81
[2024-04-26 12:48:47.289] Board: AM62B-SKEVM rev A
[2024-04-26 12:48:47.308] DRAM:  2 GiB
[2024-04-26 12:48:47.530] Core:  72 devices, 32 uclasses, devicetree: separate
[2024-04-26 12:48:47.530] MMC:   mmc@fa10000: 0, mmc@fa00000: 1
[2024-04-26 12:48:47.544] Loading Environment from nowhere... OK
[2024-04-26 12:48:47.560] In:    serial
[2024-04-26 12:48:47.560] Out:   serial
[2024-04-26 12:48:47.560] Err:   serial
[2024-04-26 12:48:47.560] Net:   eth0: ethernet@8000000port@1
[2024-04-26 12:48:47.575] Hit any key to stop autoboot:  2  1  0
[2024-04-26 12:48:51.577] MMC: no card present
[2024-04-26 12:48:51.663] SD/MMC found on device 1
[2024-04-26 12:48:53.661] MMC: no card present
[2024-04-26 12:48:53.661] ** Bad device specification mmc 1 **
[2024-04-26 12:48:53.661] Couldn't find partition mmc 1
[2024-04-26 12:48:53.661] Can't set block device
[2024-04-26 12:48:55.675] MMC: no card present
[2024-04-26 12:48:55.675] ** Bad device specification mmc 1 **
[2024-04-26 12:48:55.675] Couldn't find partition mmc 1
[2024-04-26 12:48:55.675] Can't set block device
[2024-04-26 12:48:57.670] MMC: no card present
[2024-04-26 12:48:57.670] ** Bad device specification mmc 1 **
[2024-04-26 12:48:57.685] ## Error: "main_cpsw0_qsgmii_phyinit" not defined
[2024-04-26 12:48:59.688] MMC: no card present
[2024-04-26 12:48:59.688] ** Bad device specification mmc 1 **
[2024-04-26 12:48:59.688] Couldn't find partition mmc 1:2
[2024-04-26 12:48:59.688] Can't set block device
[2024-04-26 12:49:01.704] MMC: no card present
[2024-04-26 12:49:01.704] ** Bad device specification mmc 1 **
[2024-04-26 12:49:01.704] Couldn't find partition mmc 1:2
[2024-04-26 12:49:01.704] Can't set block device
[2024-04-26 12:49:01.704] libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[2024-04-26 12:49:01.704] No FDT memory address configured. Please configure
[2024-04-26 12:49:01.718] the FDT address via "fdt addr <address>" command.
[2024-04-26 12:49:01.718] Aborting!
[2024-04-26 12:49:01.718] Bad Linux ARM64 Image magic!
[2024-04-26 12:49:01.871] switch to partitions #0, OK
[2024-04-26 12:49:01.878] mmc0(part 0) is current device
[2024-04-26 12:49:01.929] Scanning mmc 0:1...
[2024-04-26 12:49:03.962] MMC: no card present
[2024-04-26 12:49:03.962] No EFI system partition
[2024-04-26 12:49:03.962] Failed to persist EFI variables
[2024-04-26 12:49:03.993] BootOrder not defined
[2024-04-26 12:49:03.993] EFI boot manager: Cannot load any image
[2024-04-26 12:49:05.991] MMC: no card present
[2024-04-26 12:49:05.991] starting USB...
[2024-04-26 12:49:05.991] Bus usb@31100000: generic_phy_get_bulk : no phys property
[2024-04-26 12:49:06.408] Register 1000840 NbrPorts 1
[2024-04-26 12:49:06.408] Starting the controller
[2024-04-26 12:49:06.408] USB XHCI 1.10
[2024-04-26 12:49:06.408] scanning bus usb@31100000 for devices... 1 USB Device(s) found
[2024-04-26 12:49:07.546]        scanning usb for storage devices... 0 Storage Device(s) found
[2024-04-26 12:49:07.546] Device 0: unknown device
[2024-04-26 12:49:07.557] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:11.628] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:11.628] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:11.639] missing environment variable: pxeuuid
[2024-04-26 12:49:11.639] Retrieving file: pxelinux.cfg/01-1c-63-49-0f-60-9b
[2024-04-26 12:49:11.639] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:15.722] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:15.722] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:15.722] Retrieving file: pxelinux.cfg/00000000
[2024-04-26 12:49:15.735] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:19.798] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:19.798] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:19.813] Retrieving file: pxelinux.cfg/0000000
[2024-04-26 12:49:19.813] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:23.880] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:23.893] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:23.893] Retrieving file: pxelinux.cfg/000000
[2024-04-26 12:49:23.908] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:27.975] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:27.975] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:27.989] Retrieving file: pxelinux.cfg/00000
[2024-04-26 12:49:27.989] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:32.054] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:32.071] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:32.071] Retrieving file: pxelinux.cfg/0000
[2024-04-26 12:49:32.071] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:36.149] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:36.149] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:36.149] Retrieving file: pxelinux.cfg/000
[2024-04-26 12:49:36.166] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete....user interrupt!
[2024-04-26 12:49:38.020] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:38.038] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:38.038] Retrieving file: pxelinux.cfg/00
[2024-04-26 12:49:38.038] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:42.121] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:42.121] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:42.121] Retrieving file: pxelinux.cfg/0
[2024-04-26 12:49:42.133] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:46.201] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:46.201] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:46.214] Retrieving file: pxelinux.cfg/default-arm-k3-am62x
[2024-04-26 12:49:46.214] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2024-04-26 12:49:50.292] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:50.292] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:50.292] Retrieving file: pxelinux.cfg/default-arm-k3
[2024-04-26 12:49:50.308] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete.....user interrupt!
[2024-04-26 12:49:52.819] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:52.819] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:52.835] Retrieving file: pxelinux.cfg/default-arm
[2024-04-26 12:49:52.835] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete...user interrupt!
[2024-04-26 12:49:53.943] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:53.957] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:53.957] Retrieving file: pxelinux.cfg/default
[2024-04-26 12:49:53.970] ethernet@8000000port@1 Waiting for PHY auto negotiation to complete..user interrupt!
[2024-04-26 12:49:54.773] am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
[2024-04-26 12:49:54.790] am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
[2024-04-26 12:49:54.790] Config file not found
[2024-04-26 12:49:54.790] =>
[2024-04-26 12:49:56.196] => pri
[2024-04-26 12:50:09.907] addr_fit=0x90000000
[2024-04-26 12:50:09.907] arch=arm
[2024-04-26 12:50:09.907] args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 ${mtdparts}
[2024-04-26 12:50:09.923] args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
[2024-04-26 12:50:09.923] args_nand=setenv bootargs console=${console} ${optargs} ubi.mtd=${nbootpart} root=${nbootvolume} rootfstype=ubifs
[2024-04-26 12:50:09.940] args_ospi_nand=setenv bootargs console=${console} ${optargs} ubi.mtd=${ospi_nand_bootpart} root=${ospi_nand_bootvolume} rootfstype=ubifs
[2024-04-26 12:50:09.955] baudrate=115200
[2024-04-26 12:50:09.955] board=am62x
[2024-04-26 12:50:09.955] board_name=am62x_skevm
[2024-04-26 12:50:09.955] board_rev=A
[2024-04-26 12:50:09.955] board_serial=0115
[2024-04-26 12:50:09.955] board_software_revision=01
[2024-04-26 12:50:09.955] boot=mmc
[2024-04-26 12:50:09.955] boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
[2024-04-26 12:50:09.971] boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
[2024-04-26 12:50:09.990] boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
[2024-04-26 12:50:10.002] boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
[2024-04-26 12:50:10.002] boot_fdt=try
[2024-04-26 12:50:10.002] boot_fit=0
[2024-04-26 12:50:10.002] boot_net_usb_start=usb start
[2024-04-26 12:50:10.021] boot_prefixes=/ /boot/
[2024-04-26 12:50:10.021] boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init; run boot_rprocs_mmc; fi;
[2024-04-26 12:50:10.021] boot_rprocs_mmc=env set rproc_id; env set rproc_fw; env set secure_suffix; if test ${secure_rprocs} -eq 1; then env set secure_suffix -sec; fi; for i in ${rproc_fw_binaries} ; do if test -z "${rproc_id}" ; then env set rproc_id $i; else env set rproc_fw $i${secure_suffix}; run rproc_load_and_boot_one; env set rproc_id; env set rproc_fw; fi; done
[2024-04-26 12:50:10.051] boot_script_dhcp=boot.scr.uimg
[2024-04-26 12:50:10.051] boot_scripts=boot.scr.uimg boot.scr
[2024-04-26 12:50:10.067] boot_syslinux_conf=extlinux/extlinux.conf
[2024-04-26 12:50:10.067] boot_targets=ti_mmc mmc0 mmc1 usb0 pxe dhcp
[2024-04-26 12:50:10.067] bootargs=console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID= rw rootfstype=ext4 rootwait
[2024-04-26 12:50:10.100] bootcmd=run envboot; run distro_bootcmd;
[2024-04-26 12:50:10.114] bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
[2024-04-26 12:50:10.163] bootcmd_mmc0=devnum=0; run mmc_boot
[2024-04-26 12:50:10.163] bootcmd_mmc1=devnum=1; run mmc_boot
[2024-04-26 12:50:10.163] bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
[2024-04-26 12:50:10.180] bootcmd_ti_mmc=run findfdt; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_fit_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;
[2024-04-26 12:50:10.195] bootcmd_usb0=devnum=0; run usb_boot
[2024-04-26 12:50:10.214] bootdelay=2
[2024-04-26 12:50:10.214] bootdir=/boot
[2024-04-26 12:50:10.214] bootenvfile=uEnv.txt
[2024-04-26 12:50:10.214] bootfstype=fat
[2024-04-26 12:50:10.214] bootm_size=0x10000000
[2024-04-26 12:50:10.214] bootpart=1:2
[2024-04-26 12:50:10.214] bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
[2024-04-26 12:50:10.214] console=ttyS2,115200n8
[2024-04-26 12:50:10.227] cpu=armv8
[2024-04-26 12:50:10.227] default_device_tree=ti/k3-am625-sk.dtb
[2024-04-26 12:50:10.227] dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1; rootfs part 0 1; tiboot3.bin.raw raw 0x0 0x400 mmcpart 1; tispl.bin.raw raw 0x400 0x1000 mmcpart 1; u-boot.img.raw raw 0x1400 0x2000 mmcpart 1; u-env.raw raw 0x3400 0x100 mmcpart 1; sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
[2024-04-26 12:50:10.241] dfu_alt_info_mmc=boot part 1 1; rootfs part 1 2; tiboot3.bin fat 1 1; tispl.bin fat 1 1; u-boot.img fat 1 1; uEnv.txt fat 1 1; sysfw.itb fat 1 1
[2024-04-26 12:50:10.257] dfu_alt_info_nand=NAND.tiboot3 part 0 1; NAND.tispl part 0 2; NAND.tiboot3.backup part 0 3; NAND.u-boot part 0 4; NAND.u-boot-env part 0 5; NAND.u-boot-env.backup part 0 6; NAND.file-system part 0 7
[2024-04-26 12:50:10.274] dfu_alt_info_ospi=tiboot3.bin raw 0x0 0x080000; tispl.bin raw 0x080000 0x200000; u-boot.img raw 0x280000 0x400000; u-boot-env raw 0x680000 0x020000; sysfw.itb raw 0x6c0000 0x100000; rootfs raw 0x800000 0x3800000
[2024-04-26 12:50:10.291] dfu_alt_info_ospi_nand=ospi_nand.tiboot3 part 1; ospi_nand.tispl part 2; ospi_nand.u-boot part 3; ospi_nand.env part 4; ospi_nand.env.backup part 5; ospi_nand.rootfs part 6; ospi_nand.phypattern part 7
[2024-04-26 12:50:10.322] dfu_alt_info_ram=tispl.bin ram 0x80080000 0x200000; u-boot.img ram 0x81000000 0x400000
[2024-04-26 12:50:10.322] distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
[2024-04-26 12:50:10.322] distro_bootpart_uuid=e1a747d7-cc59-2249-a8dc-3e7799ddd238
[2024-04-26 12:50:10.338] dorprocboot=0
[2024-04-26 12:50:10.338] dtboaddr=0x89000000
[2024-04-26 12:50:10.338] efi_dtb_prefixes=/ /dtb/ /dtb/current/
[2024-04-26 12:50:10.338] envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev}; if run loadbootscript; then run bootscript; else if run loadbootenv; then echo Loaded env from ${bootenvfile}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; fi; fi;
[2024-04-26 12:50:10.369] eth1addr=70:ff:76:1e:d4:30
[2024-04-26 12:50:10.369] ethact=ethernet@8000000port@1
[2024-04-26 12:50:10.369] ethaddr=1c:63:49:0f:60:9b
[2024-04-26 12:50:10.369] fdt_addr_r=0x88000000
[2024-04-26 12:50:10.369] fdtaddr=0x88000000
[2024-04-26 12:50:10.369] fdtcontroladdr=fd5eb4c0
[2024-04-26 12:50:10.386] fdtfile=ti/k3-am625-sk.dtb
[2024-04-26 12:50:10.386] fdtoverlay_addr_r=0x89000000
[2024-04-26 12:50:10.386] findfdt=setenv name_fdt ${default_device_tree}; if test $board_name = am62x_skevm; then setenv name_fdt ti/k3-am625-sk.dtb; fi; if test $board_name = am62b_p1_skevm; then setenv name_fdt ti/k3-am625-sk.dtb; fi; if test $board_name = am62x_sip_skevm; then setenv name_fdt ti/k3-am625-sk.dtb; fi; if test $board_name = am62x_lp_skevm; then setenv name_fdt ti/k3-am62-lp-sk.dtb; fi; if test $board_name = am62x_beagleplay; then setenv name_fdt ti/k3-am625-beagleplay.dtb; fi; setenv fdtfile ${name_fdt}
[2024-04-26 12:50:10.434] finduuid=part uuid ${boot} ${bootpart} uuid
[2024-04-26 12:50:10.434] get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/dtb/${name_fdt}
[2024-04-26 12:50:10.434] get_fdt_nand=ubifsload ${fdtaddr} ${bootdir}/${fdtfile};
[2024-04-26 12:50:10.450] get_fdt_ospi_nand=ubifsload ${fdtaddr} ${bootdir}/dtb/${fdtfile};
[2024-04-26 12:50:10.450] get_fit_config=setexpr name_fit_config gsub / _ conf-${fdtfile}
[2024-04-26 12:50:10.450] get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}
[2024-04-26 12:50:10.466] get_fit_nand=ubifsload ${addr_fit} ${bootdir}/${name_fit}
[2024-04-26 12:50:10.466] get_fit_ospi_nand=ubifsload ${addr_fit} ${bootdir}/${name_fit}
[2024-04-26 12:50:10.466] get_fit_overlaystring=for overlay in $name_overlays; do; setexpr name_fit_overlay gsub / _ conf-${overlay}; setenv overlaystring ${overlaystring}'#'${name_fit_overlay}; done;
[2024-04-26 12:50:10.481] get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
[2024-04-26 12:50:10.497] get_kern_nand=ubifsload ${loadaddr} ${bootdir}/${name_kern}
[2024-04-26 12:50:10.497] get_kern_ospi_nand=ubifsload ${loadaddr} ${bootdir}/${name_kern}
[2024-04-26 12:50:10.497] get_overlay_mmc=fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in $name_overlays; do; load mmc ${bootpart} ${dtboaddr} ${bootdir}/dtb/ti/${overlay} && fdt apply ${dtboaddr}; done;
[2024-04-26 12:50:10.514] get_overlay_nand=fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in $name_overlays; do; ubifsload ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr}; done;
[2024-04-26 12:50:10.530] get_overlay_ospi_nand=fdt address ${fdtaddr} fdt resize 0x100000; for overlay in $name_overlays; do; ubifsload ${dtboaddr} ${bootdir}/dtb/${overlay} && fdt apply ${dtboaddr}; done;
[2024-04-26 12:50:10.546] importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
[2024-04-26 12:50:10.562] init_mmc=run args_all args_mmc
[2024-04-26 12:50:10.562] init_nand=run args_all args_nand ubi_init
[2024-04-26 12:50:10.562] init_ospi_nand=run args_all args_ospi_nand ospi_nand_ubi_init
[2024-04-26 12:50:10.577] kernel_addr_r=0x82000000
[2024-04-26 12:50:10.577] load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
[2024-04-26 12:50:10.577] loadaddr=0x82000000
[2024-04-26 12:50:10.577] loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
[2024-04-26 12:50:10.595] loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr
[2024-04-26 12:50:10.595] loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/dtb/${fdtfile}
[2024-04-26 12:50:10.595] loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
[2024-04-26 12:50:10.611] mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
[2024-04-26 12:50:10.611] mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev}; if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run mmcloados; fi; fi; fi;
[2024-04-26 12:50:10.642] mmcdev=1
[2024-04-26 12:50:10.642] mmcloados=if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run get_fdt_mmc; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
[2024-04-26 12:50:10.661] mmcrootfstype=ext4 rootwait
[2024-04-26 12:50:10.661] mtdids=spi-nand0=spi-nand0,nand0=omap2-nand.0
[2024-04-26 12:50:10.661] mtdparts=mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system)
[2024-04-26 12:50:10.692] name_fdt=ti/k3-am625-sk.dtb
[2024-04-26 12:50:10.692] name_fit=fitImage
[2024-04-26 12:50:10.692] name_kern=Image
[2024-04-26 12:50:10.692] nandargs=setenv bootargs console=${console} ${optargs} root=${nandroot} rootfstype=${nandrootfstype}
[2024-04-26 12:50:10.708] nandboot=echo Booting from nand ...; run nandargs; nand read ${fdtaddr} NAND.u-boot-spl-os; nand read ${loadaddr} NAND.kernel; bootz ${loadaddr} - ${fdtaddr}
[2024-04-26 12:50:10.725] nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048
[2024-04-26 12:50:10.725] nandrootfstype=ubifs rootwait
[2024-04-26 12:50:10.725] nbootpart=NAND.file-system
[2024-04-26 12:50:10.725] nbootvolume=ubi0:rootfs
[2024-04-26 12:50:10.740] optargs=earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system)
[2024-04-26 12:50:10.756] ospi_nand_bootpart=ospi_nand.rootfs
[2024-04-26 12:50:10.772] ospi_nand_bootvolume=ubi0:rootfs
[2024-04-26 12:50:10.772] ospi_nand_ubi_init=ubi part ${ospi_nand_bootpart}; ubifsmount ${ospi_nand_bootvolume};
[2024-04-26 12:50:10.772] partitions=name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
[2024-04-26 12:50:10.789] pxefile_addr_r=0x80100000
[2024-04-26 12:50:10.789] ramdisk_addr_r=0x88080000
[2024-04-26 12:50:10.789] rd_spec=-
[2024-04-26 12:50:10.789] rdaddr=0x88080000
[2024-04-26 12:50:10.789] rproc_fw_binaries= 0 /lib/firmware/am62-mcu-m4f0_0-fw
[2024-04-26 12:50:10.789] rproc_load_and_boot_one=if load mmc ${bootpart} $loadaddr ${rproc_fw}; then if rproc load ${rproc_id} ${loadaddr} ${filesize}; then rproc start ${rproc_id}; fi; fi
[2024-04-26 12:50:10.804] run_fit=run get_fit_config; bootm ${addr_fit}#${name_fit_config}${overlaystring}
[2024-04-26 12:50:10.820] run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
[2024-04-26 12:50:10.820] scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
[2024-04-26 12:50:10.835] scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
[2024-04-26 12:50:10.867] scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
[2024-04-26 12:50:10.898] scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing...; fi
[2024-04-26 12:50:10.917] scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
[2024-04-26 12:50:10.948] scriptaddr=0x80000000
[2024-04-26 12:50:10.948] secure_rprocs=0
[2024-04-26 12:50:10.948] serial#=0000000000000115
[2024-04-26 12:50:10.948] soc=k3
[2024-04-26 12:50:10.948] splashfile=ti_logo_414x97_32bpp.bmp.gz
[2024-04-26 12:50:10.948] splashimage=0x80200000
[2024-04-26 12:50:10.963] splashpos=m,m
[2024-04-26 12:50:10.963] splashsource=mmc
[2024-04-26 12:50:10.963] ubi_init=ubi part ${nbootpart}; ubifsmount ${nbootvolume};
[2024-04-26 12:50:10.963] update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
[2024-04-26 12:50:10.963] usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
[2024-04-26 12:50:10.980] vendor=ti
[2024-04-26 12:50:10.980] Environment size: 12235/126972 bytes
[2024-04-26 12:50:10.980] =>
As will use UART boot during develop stage, if forget to Hit in to stop autoboot within 3 second, it will reset to boot again, will waste time. so need to fix it on SDK9.2
