Moving default system heap memory dynamically to a different region
hi,
In DSP/BIOS 5.xx, MEM_redefine of MEM module can be used for moving default heap memory to a different region. But this API is not working fine for SYS/BIOS 6.xx. Is there any way, I can move the default system heap memory runtime in SYS/BIOS 6.xx?
Please help me in this regard.
Thanks and regards,
Lijo
  • Hi Lijo,
    In BIOS 6.xx, the dafault system heap located in target's default data section.
    And you can reassign it in ti.sysbios.BIOS module by the following option:
    BIOS.heapSection = ''myheap";
    BIOS.heapSize = 0x4000;
    Through these options, you put the system heap in a section called "myheap" and a size of 0x4000. Then put the section "myheap" into any region in your cmd link file like
    SECTIONS{
    myheap > DDR3
    or directly setup in cfg file like:
    Program.sectMap["myheap"]      = "DDR3";
  • Thank you for the reply.
    This approach will move the default heap statically.  The heap will be assigned while linking.
    What I am looking for is, to move the default heap dynamically (Runtime.) . I need to move the system heap to a specific location in the main function.
  • Hi Lijo --
    Which version of SYS/BIOS are you using?  And which device?
    You can use HeapMem_construct() for this.   You need to create a small heap in local L2 memory.  64 bytes is big enough.  For ELF targets, this local heap is used during boot time to allocate a small structure for atexit().  Then you can use HeapMem_construct() to reconstruct this heap with different parameters.
    I've attached some sample code that should help.
    4645.memconstruct.zip
    Note that you need something like this in your .cfg file:
     * The BIOS module will create the default heap for the system.
     * Specify the size of this default heap.
    // BIOS.heapSize = 0x1000;
    var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
    var myHeapParams = new HeapMem.Params;
    myHeapParams.sectionName = ".bootHeap";
    myHeapParams.size = 64;
    Program.global.myHeap = HeapMem.create(myHeapParams);
    Memory.defaultHeapInstance = Program.global.myHeap;
    Program.sectMap[".bootHeap"] = new Program.SectionSpec();
    Program.sectMap[".bootHeap"].loadSegment = "L2SRAM";
    and something like this in main():
    Void main()
        Task_Handle task;
        Error_Block eb;
        HeapMem_Params heapParams;
        HeapMem_Params_init(&heapParams);
        heapParams.buf = memoryBlock;
        heapParams.size = MEMORYBLOCKSIZE;
        HeapMem_construct((HeapMem_Struct *)myHeap, &heapParams);
    -Karl-
  • Hi Karl,
    Thank you for the fix. With this, the application seems working as the way I wanted.
    I am using c6678l EVM. with sys-bios version bios_6_32_04_49 .
    Thanks and regards,
    Lijo
