Hi all,
We are trying run vc3 application using new SDK version 5_02_01_59.
Steps used for running:-
./prcm_config_app s
insmod syslink.ko
./firmware_loader 1 vc3_m3video_debug.xem3 start mm_dm81xxbm_vc3.bin
./firmware_loader 2 vc3_m3vpss_debug.xem3 start mm_dm81xxbm_vc3.bin
insmod vpss.ko sbufaddr=0xbfb00000 i2c_mode=1
insmod ti81xxhdmi.ko
insmod ti81xxfb.ko
./vc3_a8host_debug.xv5T 127.0.0.1 2000 60
We are getting a kernel crash and the log is attached.4073.vc3_log.txt
The kernel crash that I mentioned is happening after loading Video-M3 image.
It is crashing in notify_shmdrv_isr_callback() when called from notify_shmdrv_video_isr.
This is because the notify_shm_drv_create(which internally gets called from notify_attach()) is not getting called for Video-M3.
notify_shm_drv_create is getting called with the following condition and notify_map_info[i].actualAddress in the following conditional check
is always 0 for Video-M3 since we are not giving any value to notifyk.videom3_sva in the kernel parameter. But for VPSS-M3 it is getting called since notifyk.vpssm3_sva=0xbf900000 is given in bootargs.
if (i != multiproc_self()
&& notify_map_info[i].actualAddress != 0) {
Interestingly Mailbox event is coming only for Video-M3 when loading the firmware. There is no such event for VPSS-M3
Is this the expected behaviour?
When I am giving an extra parameter in bootargs to initialize notifyk.videom3_sva to 0xbf900000 firmware loading is happening without any crash.
In this case application is hanging in omx_ilclient_utl_comp_create.
It looks like VPSS-M3 is not giving notification to the OMX command.
We have done all the step as the document and rebuild all the images(kernel image, modules, syslink, vc3 binaries).
Please suggest how we can proceed.
Thanks and Regards,
Nitish James
