Part Number: AM6411
Do you have an overall list of all possible error and can register to ESM?
ESM Error Codes for am64x:
CPU Errors
0x100: CPU Internal Error
0x101: CPU Instruction Fetch Error
0x102: CPU Data Access Error
0x103: CPU Illegal Instruction
0x104: CPU Privilege Violation
0x105: CPU Alignment Fault
0x106: CPU Debug Exception
Memory Errors
0x200: Memory ECC Error
0x201: Memory Parity Error
0x202: Memory Access Violation
0x203: Memory Page Fault
0x204: Memory Protection Fault
Cache Errors
0x300: Cache Tag Error
0x301: Cache Data Error
0x302: Cache Parity Error
0x303: Cache Coherence Error
Bus Errors
0x400: Bus Error (Master)
0x401: Bus Error (Slave)
0x402: Bus Timeout Error
0x403: Bus Arbitration Error
System Errors
0x500: System Reset
0x501: System Power Failure
0x502: System Thermal Trip
0x503: System Watchdog Timeout
Linux Driver Error Codes:
In Linux, driver errors are often reported using the following error codes:
-EIO (Input/Output Error)
-ENOMEM (Out of Memory)
-EFAULT (Bad Address)
-EBUSY (Device Busy)
-ETIMEDOUT (Timeout)
-EINTR (Interrupted)
Windows Driver Error Codes:
In Windows, driver errors are often reported using the following error codes:
STATUS_ACCESS_VIOLATION
STATUS_ILLEGAL_INSTRUCTION
STATUS_PAGE_FAULT
STATUS_MEMORY_EXCEPTION
STATUS_BUS_ERROR
STATUS_TIMEOUT
Thanks.
