Hi, Dear Expert
Because I suffer from display node created failed problem, so I try to use "basic TIDL application" to make sure Display is OK.
HW : J721S2 EVM + DISPLAY 0
SW : SDK 10.0 with default build vision app binary & data sets.
Boot Log
U-Boot SPL 2024.04-ti-g818c76aed67f (Aug 01 2024 - 19:19:47 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
SPL initial stack usage: 13456 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE: BL31: Built : 16:09:05, Feb 9 2024
I/TC:
I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2024.04-ti-g818c76aed67f (Aug 01 2024 - 19:19:47 +0000)
SoC: J721S2 SR1.0 GP
Model: Texas Instruments J721S2 EVM
Board: J721S2X-PM1-SOM rev E3
DRAM: 2 GiB (effective 16 GiB)
Core: 117 devices, 32 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
941 bytes read in 22 ms (41 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
875980 bytes read in 84 ms (9.9 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 875980 bytes: Success!
322740 bytes read in 79 ms (3.9 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 322740 bytes: Success!
Failed to load '/lib/firmware/j721s2-main-r5f1_0-fw'
Failed to load '/lib/firmware/j721s2-main-r5f1_1-fw'
15077408 bytes read in 152 ms (94.6 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 15077408 bytes: Success!
9703384 bytes read in 93 ms (99.5 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 9703384 bytes: Success!
20285952 bytes read in 233 ms (83 MiB/s)
107760 bytes read in 26 ms (4 MiB/s)
Working FDT set to 88000000
10407 bytes read in 25 ms (406.3 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=2c000000 flags=4)
Loading Device Tree to 000000008fee2000, end 000000008fffffff ... OK
Working FDT set to 8fee2000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.6.32-ti-gdb8871293143-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Thu Aug 1 19:10:56 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Texas Instruments J721S2 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a5ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a9ffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@a8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000afffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@aa000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b0000000..0x00000000b00fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b0000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0100000, size 95 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b0100000..0x00000000b5ffffff (97280 KiB) nomap non-reusable vision-apps-c71_0-memory@b0100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b6000000..0x00000000b60fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b6000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b6100000..0x00000000b7ffffff (31744 KiB) nomap non-reusable vision-apps-c71_1-memory@b6100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000bbffffff (65536 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@b8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 704 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000880000000..0x00000008abffffff (720896 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] OF: reserved mem: 0x0000000900000000..0x000000091fffffff (524288 KiB) map non-reusable vision_apps_shared-memories
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB
[ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000980000000..0x00000009b7ffffff (917504 KiB) map reusable linux-cma-buffers@980000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000bbffffff]
[ 0.000000] node 0: [mem 0x00000000bc000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008abffffff]
[ 0.000000] node 0: [mem 0x00000008ac000000-0x0000000bffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=95adb477-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128768
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 13726560K/16777216K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 2133152K reserved, 917504K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8ac800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008ac040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008ac050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008441] Console: colour dummy device 80x25
[ 0.013014] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023688] pid_max: default: 32768 minimum: 301
[ 0.028450] LSM: initializing lsm=capability,integrity
[ 0.033782] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.041559] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.050727] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.058000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.065862] rcu: Hierarchical SRCU implementation.
[ 0.070762] rcu: Max phase no-delay instances is 1000.
[ 0.076296] Platform MSI: msi-controller@1820000 domain created
[ 0.082531] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.091980] EFI services will not be available.
[ 0.096738] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.109841] Detected PIPT I-cache on CPU1
[ 0.109889] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.109903] GICv3: CPU1: using allocated LPI pending table @0x00000008ac060000
[ 0.109937] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.110003] smp: Brought up 1 node, 2 CPUs
[ 0.139356] SMP: Total of 2 processors activated.
[ 0.144161] CPU features: detected: 32-bit EL0 Support
[ 0.149415] CPU features: detected: CRC32 instructions
[ 0.154698] CPU: All CPU(s) started at EL2
[ 0.158881] alternatives: applying system-wide alternatives
[ 0.165574] devtmpfs: initialized
[ 0.177000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.186980] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.205170] pinctrl core: initialized pinctrl subsystem
[ 0.210800] DMI not present or invalid.
[ 0.215077] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.221892] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.229541] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.237877] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.246103] audit: initializing netlink subsys (disabled)
[ 0.251750] audit: type=2000 audit(0.180:1): state=initialized audit_enabled=0 res=1
[ 0.251989] thermal_sys: Registered thermal governor 'step_wise'
[ 0.259673] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.265833] cpuidle: using governor menu
[ 0.276583] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.283548] ASID allocator initialised with 65536 entries
[ 0.298236] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[ 0.309844] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector
[ 0.317895] platform dp0-connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.327067] Modules: 27680 pages in range for non-PLT usage
[ 0.327071] Modules: 519200 pages in range for PLT usage
[ 0.333260] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.345629] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.352031] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.358965] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.365367] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.372301] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.378702] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.385637] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.392903] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
[ 0.402049] iommu: Default domain type: Translated
[ 0.406952] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.413423] SCSI subsystem initialized
[ 0.417440] usbcore: registered new interface driver usbfs
[ 0.423060] usbcore: registered new interface driver hub
[ 0.428502] usbcore: registered new device driver usb
[ 0.433951] pps_core: LinuxPPS API ver. 1 registered
[ 0.439024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.448362] PTP clock support registered
[ 0.452475] EDAC MC: Ver: 3.0.0
[ 0.455954] scmi_core: SCMI protocol bus registered
[ 0.461095] FPGA manager framework
[ 0.464607] Advanced Linux Sound Architecture Driver Initialized.
[ 0.471282] vgaarb: loaded
[ 0.474228] clocksource: Switched to clocksource arch_sys_counter
[ 0.480603] VFS: Disk quotas dquot_6.6.0
[ 0.484628] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.494982] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[ 0.501291] NET: Registered PF_INET protocol family
[ 0.506638] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.519684] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.528564] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.536497] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.545179] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.553833] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.560742] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.567865] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.575515] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.581691] RPC: Registered named UNIX socket transport module.
[ 0.587759] RPC: Registered udp transport module.
[ 0.592563] RPC: Registered tcp transport module.
[ 0.597366] RPC: Registered tcp-with-tls transport module.
[ 0.602968] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.609552] NET: Registered PF_XDP protocol family
[ 0.614457] PCI: CLS 0 bytes, default 64
[ 0.619189] Initialise system trusted keyrings
[ 0.623872] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 0.630647] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.636770] NFS: Registering the id_resolver key type
[ 0.641954] Key type id_resolver registered
[ 0.646231] Key type id_legacy registered
[ 0.650335] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.657186] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.678302] Key type asymmetric registered
[ 0.682490] Asymmetric key parser 'x509' registered
[ 0.687504] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.695066] io scheduler mq-deadline registered
[ 0.699693] io scheduler kyber registered
[ 0.703811] io scheduler bfq registered
[ 0.709686] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[ 0.715715] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[ 0.721762] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[ 0.728014] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[ 0.733851] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.739904] pinctrl-single 104200.pinctrl: 20 pins, size 80
[ 0.745659] pinctrl-single 104280.pinctrl: 8 pins, size 32
[ 0.751711] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.761457] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.773012] loop: module loaded
[ 0.776884] megasas: 07.725.01.00-rc1
[ 0.782576] tun: Universal TUN/TAP device driver, 1.6
[ 0.788373] VFIO - User Level meta-driver version: 0.3
[ 0.794332] usbcore: registered new interface driver usb-storage
[ 0.800833] i2c_dev: i2c /dev entries driver
[ 0.805920] sdhci: Secure Digital Host Controller Interface driver
[ 0.812250] sdhci: Copyright(c) Pierre Ossman
[ 0.816836] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.823002] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.829323] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.836336] usbcore: registered new interface driver usbhid
[ 0.842036] usbhid: USB HID core driver
[ 0.846870] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.855543] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.860100] optee: revision 4.2 (12d7c4ee)
[ 0.876565] optee: dynamic shared memory is enabled
[ 0.886194] random: crng init done
[ 0.889730] optee: initialized driver
[ 0.894876] NET: Registered PF_PACKET protocol family
[ 0.900098] Key type dns_resolver registered
[ 0.907909] registered taskstats version 1
[ 0.912178] Loading compiled-in X.509 certificates
[ 0.924207] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[ 0.980183] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.986712] pca953x 1-0021: supply vcc not found, using dummy regulator
[ 0.993570] pca953x 1-0021: using no AI
[ 1.019025] pca953x 1-0020: supply vcc not found, using dummy regulator
[ 1.025846] pca953x 1-0020: using no AI
[ 1.030432] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.037246] pca953x 1-0022: using AI
[ 1.041536] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.047294] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
[ 1.056076] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
[ 1.065453] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
[ 1.074136] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
[ 1.082575] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.090247] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.098526] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.106803] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.116323] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 1.123275] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 1.132643] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[ 1.142528] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.149288] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.158736] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
[ 1.168909] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.175668] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.183888] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 229, base_baud = 6000000) is a 8250
[ 1.193588] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 230, base_baud = 3000000) is a 8250
[ 1.202537] printk: console [ttyS2] enabled
[ 1.210996] printk: bootconsole [ns16550a0] disabled
[ 1.224075] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.270232] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.280281] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.288564] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.301441] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.308655] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.314888] pps pps0: new PPS source ptp0
[ 1.319049] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 1.329677] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
[ 1.338474] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 1.338755] mmc0: CQHCI version 5.10
[ 1.348590] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 1.355535] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 1.362405] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 1.386240] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.478180] mmc0: Command Queue Engine enabled
[ 1.482655] mmc0: new HS400 MMC card at address 0001
[ 1.488106] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.495597] mmcblk0: p1
[ 1.498526] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.504252] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.509894] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
[ 1.668241] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[ 1.674214] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[ 2.057377] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.064888] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.072971] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.081053] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.090609] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.100968] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
[ 2.113680] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 2.118698] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 2.125349] Creating 7 MTD partitions on "47040000.spi.0":
[ 2.130834] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 2.136999] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 2.142872] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 2.148781] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 2.154436] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 2.160679] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 2.166622] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 2.178600] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 2.183700] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[ 2.190736] Creating 7 MTD partitions on "47050000.spi.0":
[ 2.196209] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[ 2.202278] 0x000000080000-0x000000280000 : "qspi.tispl"
[ 2.208076] 0x000000280000-0x000000680000 : "qspi.u-boot"
[ 2.213956] 0x000000680000-0x0000006c0000 : "qspi.env"
[ 2.219581] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[ 2.225788] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[ 2.231675] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[ 2.238501] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.282235] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.292278] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.300559] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.313448] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.320659] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.326874] pps pps0: new PPS source ptp1
[ 2.331036] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 2.345895] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 2.355582] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.356000] mmc1: CQHCI version 5.10
[ 2.363097] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.374738] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.382823] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.391863] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.399364] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.407449] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.407466] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 2.415594] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.431907] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.439416] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.447506] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.455646] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.467312] clk: Disabling unused clocks
[ 2.478823] ALSA device list:
[ 2.481785] No soundcards found.
[ 2.485398] Waiting for root device PARTUUID=95adb477-02...
[ 2.513422] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
[ 2.520477] mmcblk1: mmc1:59b4 USDU1 58.3 GiB
[ 2.526373] mmcblk1: p1 p2
[ 2.529840] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.537350] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.545431] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.553511] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.930064] EXT4-fs (mmcblk1p2): recovery complete
[ 2.936139] EXT4-fs (mmcblk1p2): mounted filesystem c0935df5-0860-4175-a19d-6f234ad7e491 r/w with ordered data mode. Quota mode: none.
[ 2.948263] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 2.955446] devtmpfs: mounted
[ 2.959343] Freeing unused kernel memory: 2432K
[ 2.963978] Run /sbin/init as init process
[ 3.141109] systemd[1]: System time before build time, advancing clock.
[ 3.172552] NET: Registered PF_INET6 protocol family
[ 3.178179] Segment Routing with IPv6
[ 3.181875] In-situ OAM (IOAM) with IPv6
[ 3.207553] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.239348] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[ 3.256300] systemd[1]: Hostname set to <j721s2-evm>.
[ 3.456795] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.518723] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.568234] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.609506] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 3.631607] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 3.655471] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 3.679159] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.702493] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.726396] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.750337] systemd[1]: Expecting device /dev/ttyS2...
[ 3.770345] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 3.790302] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.810294] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 3.830292] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 3.873683] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 3.898432] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 3.921676] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 3.942604] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 3.966981] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 3.990655] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.014637] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.030718] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.055169] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.078582] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.098591] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 4.142539] systemd[1]: Mounting Huge Pages File System...
[ 4.160851] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.186663] systemd[1]: Mounting Kernel Debug File System...
[ 4.206671] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.222551] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.244179] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.290944] systemd[1]: Starting Load Kernel Module configfs...
[ 4.318918] systemd[1]: Starting Load Kernel Module drm...
[ 4.366903] systemd[1]: Starting Load Kernel Module fuse...
[ 4.394734] systemd[1]: Starting Start psplash boot splash screen...
Starting Start psplash boot splash screen.[ 4.406520] fuse: init (API version 7.39)
[ 4.426836] systemd[1]: Starting RPC Bind...
[ 4.442568] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.481888] systemd[1]: Starting Journal Service...
[ 4.506951] systemd[1]: Starting Load Kernel Modules...
[ 4.544566] systemd-journald[112]: Collecting audit messages is enabled.
[ 4.552612] systemd[1]: Starting Generate network units from Kernel command line...
[ 4.573043] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.598189] cryptodev: loading out-of-tree module taints kernel.
[ 4.610423] cryptodev: driver 1.13 loaded.
[ 4.618818] systemd[1]: Starting Coldplug All udev Devices...
[ 4.637153] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 4.655902] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ 4.661458] EXT4-fs (mmcblk1p2): re-mounted c0935df5-0860-4175-a19d-6f234ad7e491 r/w. Quota mode: none.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas ctemd progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 5.091555] systemd-journald[112]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev gracefully...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev gracefully.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
[ 5.339951] audit: type=1334 audit(1709054766.196:2): prog-id=6 op=LOAD
[ 5.346998] audit: type=1334 audit(1709054766.204:3): prog-id=7 op=LOAD
Starting Rule-based Manager for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Finished Load/Save OS Random Seed.
[ OK ] Finished Create Volatile Files and Directories.
[ 5.551508] audit: type=1334 audit(1709054766.408:4): prog-id=8 op=LOAD
Starting Network Name Resolution...
[ 5.588747] audit: type=1334 audit(1709054766.444:5): prog-id=9 op=LOAD
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ 5.688307] audit: type=1334 audit(1709054766.544:6): prog-id=10 op=LOAD
[ 5.698322] audit: type=1334 audit(1709054766.552:7): prog-id=11 op=LOAD
[ 5.708300] audit: type=1334 audit(1709054766.552:8): prog-id=12 op=LOAD
Starting User Database Manager...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Found device /dev/ttyS2.
[ OK ] Started User Database Manager.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API...
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on PC/SC Smart Card Daemon Activation Socket.
Starting Weston socket...
[ 6.498169] audit: type=1334 audit(1709081714.884:9): prog-id=13 op=LOAD
Starting D-Bus System Message Bus...
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Listening on Weston socket.
[ OK ] Finished Reboot and dump vmcore via kexec.
[ OK ] Started D-Bus System Message Bus.
[ 6.720958] dbus-broker-lau[393]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Periodic Command Scheduler.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting Expand the rootfs partiti cto full size of the boot device....
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ 7.074963] audit: type=1334 audit(1709081715.464:10): prog-id=14 op=LOAD
[ 7.090587] audit: type=1334 audit(1709081715.480:11): prog-id=15 op=LOAD
Starting User Login Management...
Starting Telnet Server...
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Reached target Preparation for Network.
Starting Network Configuration...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Finished Telnet Server.
[ OK ] Started Telephony service.
[ 7.345593] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.358290] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.371646] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.387210] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.400852] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.411898] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.421194] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.430399] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.453410] CAN device driver interface
[ 7.473752] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.481484] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.489639] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.498578] Bluetooth: Core ver 2.22
[ 7.499708] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.504609] NET: Registered PF_BLUETOOTH protocol family
[ 7.522908] Bluetooth: HCI device and connection manager initialized
[ 7.530326] Bluetooth: HCI socket layer initialized
[ 7.537268] Bluetooth: L2CAP socket layer initialized
[ 7.542397] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.545912] Bluetooth: SCO socket layer initialized
[ 7.552583] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.563958] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.578310] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.592093] mc: Linux media interface: v0.10
[ OK ] Started User Login Management.
[ 7.611167] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.621569] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.634044] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.642749] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.759519] videodev: Linux video capture interface: v2.00
[ 7.791420] pinctrl-single 4301c068.pinctrl: pin PIN54 already requested by 42110000.gpio; cannot claim for 40200000.tscadc
[ 7.805089] pinctrl-single 4301c068.pinctrl: pin-54 (40200000.tscadc) status -22
[ 7.812699] pinctrl-single 4301c068.pinctrl: could not request pin 54 (PIN54) from group mcu-adc0-default-pins on device pinctrl-single
[ 7.827070] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
[ 7.827748] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.839495] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 7.851479] ti_am3359-tscadc 40200000.tscadc: Error applying setting, reverse things back
[ 7.862950] PVR_K: 163: Device: 4e20000000.gpu
[ 7.865887] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.871774] remoteproc remoteproc0: 64800000.dsp is available
[ 7.878165] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.891156] remoteproc remoteproc0: attaching to 64800000.dsp
[ 7.897980] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.902176] remoteproc remoteproc0: unsupported resource 65538
[ 7.913782] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 7.920751] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.923593] PVR_K: 163: Read BVNC 36.53.104.796 from HW device registers
[ 7.929634] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.947775] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.962673] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 7.970113] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.980336] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 7.986975] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.001749] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.016032] at24 0-0050: supply vcc not found, using dummy regulator
[ OK ] Finished Expand the rootfs partition to full size of the boot device..
[ 8.062511] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 8.082767] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 8.085857] PVR_K: 163: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 8.098742] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.109818] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.111538] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.124276] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.127186] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.135419] [drm] Initialized pvr 24.1.6554834 20170530 for 4e20000000.gpu on minor 0
[ 8.144373] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
[ 8.154553] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 8.159681] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 8.171634] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 8.171832] rproc-virtio rproc-virtio.16.auto: registered virtio0 (type 7)
[ 8.171840] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[ 8.179094] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.179105] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.179115] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.193913] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 8.193956] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.193970] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.193982] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.200995] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
[ 8.210901] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.210913] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.210924] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.211300] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ OK ] Started Network Configuration.[ 8.211330] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.211343] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.211354] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.230751] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 8.250573] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[ 8.271748] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ OK ] Reached target Network.
[ 8.358397] remoteproc remoteproc1: 65800000.dsp is available
[ 8.394084] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.403485] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.417137] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.430186] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 8.442316] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.454911] remoteproc remoteproc1: attaching to 65800000.dsp
[ 8.456017] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.463941] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 8.478400] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.486361] platform 41000000.r5f: configured R5F for IPC-only mode
[ 8.490813] remoteproc remoteproc1: unsupported resource 65538
[ 8.498442] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.511880] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.511906] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.511915] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
Starting Enable and configure wl18xx bluetooth[ 8.512135] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
stack...
[ 8.512165] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.512178] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.512188] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.515568] remoteproc remoteproc2: 41000000.r5f is available
Starting containerd container runtime...
[ OK ] Started Netperf Benchmark Server.
Starting Simple Network Management Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ 8.633377] remoteproc remoteproc2: attaching to 41000000.r5f
[ 8.635419] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[ 8.641511] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[ 8.653746] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.660288] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.670130] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.677426] vdec 4210000.video-codec: Product Code: 0x521c
[ 8.678875] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
[ OK ] Finished Enable and configure wl18x[ 8.694112] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
x bluetooth stack.
[ 8.705061] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 8.727403] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.739215] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 8.744809] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 8.750313] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.752415] rproc-virtio rproc-virtio.17.auto: registered virtio1 (type 7)
[ 8.765754] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.766943] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[ 8.784487] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.784497] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.784505] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.784688] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 8.784719] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.784731] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.784748] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.785638] vdec 4210000.video-codec: Firmware Revision: 320127
[ 8.794323] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.794332] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 8.794340] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 8.794524] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 8.794551] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 8.794561] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 8.794571] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 8.831259] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.856185] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.871583] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 8.883129] m_can_platform 26a1000.can: m_can device registered (irq=773, version=32)
[ 8.891868] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ OK ] Finished Permit User Sessions.[ 8.972702] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 8.984223] rproc-virtio rproc-virtio.18.auto: registered virtio2 (type 7)
[ 8.994434] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.020331] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 9.035087] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.049744] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.055833] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ 9.066507] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.066531] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ OK ] Started Getty on tty1.
[ 9.124275] m_can_platform 40528000.can: m_can device registered (irq=774, version=32)
[ OK ] Started Serial Getty on ttyS2.[ 9.140318] m_can_platform 40568000.can: m_can device registered (irq=775, version=32)
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ 9.161490] gpio-mux mux-controller-0: 2-way mux-controller registered
Starting Weston, a Wayland compositor, as a system service...
[ 9.186124] gpio-mux mux-controller-1: 2-way mux-controller registered
[ 9.186756] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.186766] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.186777] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 9.187066] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.187091] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.187103] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.187113] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.286964] m_can_platform 2731000.can: m_can device registered (irq=776, version=32)
[ 9.309998] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.319094] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.331582] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 9.340016] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.348391] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 9.354714] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.366015] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.376130] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 9.380317] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.394303] remoteproc remoteproc3: 5c00000.r5f is available
[ 9.404479] m_can_platform 2751000.can: m_can device registered (irq=777, version=32)
[ 9.419092] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.428567] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.438664] remoteproc remoteproc3: attaching to 5c00000.r5f
[ 9.441718] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 9.455201] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.465494] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.478180] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.491348] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.511868] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.518587] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 9.525234] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.536666] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ OK ] Created slice User Slice of UID 100[ 9.547196] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
0.
[ 9.580296] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
Starting User Runtime Directory /run/user/1000...
[ 9.602299] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ OK ] Finished Synchronize System and HW clocks.
[ 9.632112] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.655611] rproc-virtio rproc-virtio.19.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ OK ] Finished User Runtime Directory /ru[ 9.668066] virtio_rpmsg_bus virtio3: rpmsg host is online
n/user/1000.
[ 9.677785] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 9.679342] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.704759] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.711409] rproc-virtio rproc-virtio.19.auto: registered virtio3 (type 7)
[ 9.721205] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
Starting User Manager for UID 1000...
[ 9.733972] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
[ 9.741545] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.746843] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 9.754625] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.758801] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 9.771191] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.780906] remoteproc remoteproc4: 5d00000.r5f is available
[ 9.788733] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.793511] remoteproc remoteproc4: attaching to 5d00000.r5f
[ 9.804419] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.814292] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 9.830217] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 9.838731] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 9.845763] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 9.857970] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 9.875010] rproc-virtio rproc-virtio.20.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 9.876140] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 9.885930] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 9.893381] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 9.893515] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 9.913375] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 9.918730] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.920652] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 9.936403] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 9.943729] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 9.951406] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 9.958726] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 9.960967] rproc-virtio rproc-virtio.20.auto: registered virtio4 (type 7)
[ 9.975571] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 9.981929] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 10.008398] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 10.012936] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.022400] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 10.036387] m_can_platform 26a1000.can main_mcan16: renamed from can0
[ 10.037251] remoteproc remoteproc5: 5e00000.r5f is available
[ 10.048100] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.050372] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 10.063889] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.064017] remoteproc remoteproc5: powering up 5e00000.r5f
[ 10.077135] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 10.079316] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.094698] remoteproc remoteproc5: request_firmware failed: -2
[ 10.101555] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 10.110190] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 10.122402] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 10.132425] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.151116] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.171041] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.189334] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.198389] m_can_platform 40568000.can mcu_mcan1: renamed from can2
[ 10.198873] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 10.213104] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
Starting Virtual Console Setup...
[ 10.245832] xhci-hcd xhci-hcd.21.auto: xHCI Host Controller
[ 10.246741] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 10.266650] m_can_platform 40528000.can mcu_mcan0: renamed from can1
[ 10.273228] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.287489] xhci-hcd xhci-hcd.21.auto: new USB bus registered, assigned bus number 1
[ 10.289581] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.296421] xhci-hcd xhci-hcd.21.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
[ 10.315058] xhci-hcd xhci-hcd.21.auto: irq 778, io mem 0x06010000
[ 10.317401] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.332601] xhci-hcd xhci-hcd.21.auto: xHCI Host Controller
[ 10.344228] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.354528] xhci-hcd xhci-hcd.21.auto: new USB bus registered, assigned bus number 2
[ 10.358600] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 10.371429] xhci-hcd xhci-hcd.21.auto: Host supports USB 3.0 SuperSpeed
[ 10.380560] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 10.400683] hub 1-0:1.0: USB hub found
[ 10.406595] hub 1-0:1.0: 1 port detected
[ 10.420999] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 10.424731] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 10.442281] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.451717] hub 2-0:1.0: USB hub found
[ 10.461216] hub 2-0:1.0: 1 port detected
[ 10.465282] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.479552] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.488620] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 10.493982] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.520441] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 10.531071] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 10.534560] m_can_platform 2751000.can main_mcan5: renamed from can4
[ 10.542678] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 10.553299] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.562806] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.571562] m_can_platform 2731000.can main_mcan3: renamed from can3
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ 10.706269] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ OK ] Finished Virtual Console Setup.
[ 10.871204] hub 1-1:1.0: USB hub found
[ 10.876667] hub 1-1:1.0: 4 ports detected
[ 10.886430] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.898017] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.913915] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 10.929781] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 10.948481] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 10.957386] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.966761] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 10.978584] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 10.987056] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 10.995280] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 11.004661] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ OK ] Created slice Slice /system/systemd-fsck.
Expecting device /dev/mmcblk0p1...
[ OK ] Started User Manager for UID 1000.
[ OK ] Started Session c1 of User weston 11.173677] kauditd_printk_skb: 5 callbacks suppressed
0m.
[ 11.173684] audit: type=1006 audit(1709081719.560:15): pid=569 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[ 11.199428] audit: type=1300 audit(1709081719.560:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff196a7c8 a2=4 a3=1 items=0 ppid=1 pid=569 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[ 11.230785] audit: type=1327 audit(1709081719.560:15): proctitle="(weston)"
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1...
[ OK ] Finished File System Check on /dev/mmcblk0p1.
Mounting /run/media/rootfs-mmcblk0p1...
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
See 'systemctl status weston.service' for details.
[ 11.558574] EXT4-fs (mmcblk0p1): mounted filesystem 2f56fa0f-5605-4f0c-b7fc-7cbf85431584 r/w with ordered data mode. Quota mode: none.
[ OK ] Mounted /run/media/rootfs-mmcblk0p1.
Expecting device /dev/mmcblk1p1...
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Finished File System Check on /dev/mmcblk1p1.
Mounting /run/media/boot-mmcblk1p1...
[ OK ] Started containerd container runtime.
[ OK ] Mounted /run/media/boot-mmcblk1p1.
[ 12.102260] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
[ 12.112813] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 12.125313] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 12.154290] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 12.164852] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 12.175288] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 12.188085] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 12.196924] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
hidapi
kbd-dev
kbd-keymaps-pine
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libunistring5
m4
make
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Finished Print notice about GPLv3 packages.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j721s2-evm ttyS2
Arago 2023.10 j721s2-evm ttyS2
j721s2-evm login: [ 22.343067] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 22.349428] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 22.358472] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 22.364536] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 22.372043] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 22.380146] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 22.388237] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 22.397168] platform dp0-connector: deferred probe pending
[ 22.402665] platform regulator-dp1-prw: deferred probe pending
[ 22.408500] platform fixedregulator-dp0-prw: deferred probe pending
[ 22.414760] platform a000000.dp-bridge: deferred probe pending
[ 22.420589] platform 2910000.pcie: deferred probe pending
j721s2-evm login:
j721s2-evm login: root
[ 243.116831] audit: type=1006 audit(1709081951.504:16): pid=1098 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[ 243.131378] audit: type=1300 audit(1709081951.504:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffee4edbb8 a2=1 a3=1 items=0 ppid=1 pid=1098 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[ 243.160219] audit: type=1327 audit(1709081951.504:16): proctitle="(systemd)"
[ 243.167799] audit: type=1334 audit(1709081951.520:17): prog-id=18 op=LOAD
[ 243.174967] audit: type=1300 audit(1709081951.520:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffca85b508 a2=90 a3=0 items=0 ppid=1 pid=1098 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[ 243.201559] audit: type=1327 audit(1709081951.520:17): proctitle="(systemd)"
[ 243.209110] audit: type=1334 audit(1709081951.548:18): prog-id=18 op=UNLOAD
[ 243.216440] audit: type=1300 audit(1709081951.548:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffbf18ec60 items=0 ppid=1 pid=1098 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[ 243.242418] audit: type=1327 audit(1709081951.548:18): proctitle="(systemd)"
[ 243.249638] audit: type=1334 audit(1709081951.548:19): prog-id=19 op=LOAD
Vision App init & Start , [tivxDisplayCreate:551] DISPLAY: ERROR: Display Create Failed!
root@j721s2-evm:~# cd /opt/ root@j721s2-evm:/opt# cd vision_apps/ root@j721s2-evm:/opt/vision_apps# source ./vision_apps_init.sh root@j721s2-evm:/opt/vision_apps# [MCU2_0] 4.571025 s: CIO: Init ... Done !!! [MCU2_0] 4.571073 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 4.571096 s: CPU is running FreeRTOS [MCU2_0] 4.571112 s: APP: Init ... !!! [MCU2_0] 4.571144 s: SCICLIENT: Init ... !!! [MCU2_0] 4.571259 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)] [MCU2_0] 4.571288 s: SCICLIENT: DMSC FW revision 0xa [MCU2_0] 4.571307 s: SCICLIENT: DMSC FW ABI revision 4.0 [MCU2_0] 4.571327 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.571345 s: UDMA: Init ... !!! [MCU2_0] 4.572146 s: UDMA: Init ... Done !!! [MCU2_0] 4.572176 s: UDMA: Init for CSITX/CSIRX ... !!! [MCU2_0] 4.572581 s: UDMA: Init for CSITX/CSIRX ... Done !!! [MCU2_0] 4.572610 s: MEM: Init ... !!! [MCU2_0] 4.572631 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b9000000 of size 14680064 bytes !!! [MCU2_0] 4.572674 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 524288 bytes !!! [MCU2_0] 4.572709 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ b9e00000 of size 2097152 bytes !!! [MCU2_0] 4.572745 s: MEM: Init ... Done !!! [MCU2_0] 4.572762 s: IPC: Init ... !!! [MCU2_0] 4.572789 s: IPC: 5 CPUs participating in IPC !!! [MCU2_0] 4.572815 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 16.834564 s: IPC: HLOS is ready !!! [MCU2_0] 16.837452 s: IPC: Init ... Done !!! [MCU2_0] 16.837489 s: APP: Syncing with 4 CPUs ... !!! [MCU2_0] 17.055320 s: APP: Syncing with 4 CPUs ... Done !!! [MCU2_0] 17.055347 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 17.055516 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 17.055544 s: FVID2: Init ... !!! [MCU2_0] 17.055582 s: FVID2: Init ... Done !!! [MCU2_0] 17.055612 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2 [MCU2_0] 17.055707 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.055739 s: DSS: Init ... !!! [MCU2_0] 17.055756 s: DSS: Display type is eDP !!! [MCU2_0] 17.055773 s: DSS: M2M Path is enabled !!! [MCU2_0] 17.055791 s: DSS: SoC init ... !!! [MCU2_0] 17.055806 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0 [MCU2_0] 17.055864 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.055890 s: SCICLIENT: Sciclient_pmSetModuleState module=365 state=2 [MCU2_0] 17.056007 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.056028 s: SCICLIENT: Sciclient_pmSetModuleState module=156 state=2 [MCU2_0] 17.056169 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.056190 s: SCICLIENT: Sciclient_pmSetModuleState module=365 state=2 [MCU2_0] 17.056282 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.056302 s: SCICLIENT: Sciclient_pmSetModuleState module=156 state=2 [MCU2_0] 17.056389 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.056410 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0 [MCU2_0] 17.056482 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.056503 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=158 clk=3 freq=148500000 [MCU2_0] 17.056735 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 17.056759 s: SCICLIENT: Sciclient_pmModuleClkRequest module=158 clk=3 state=2 flag=2 [MCU2_0] 17.056949 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 17.056971 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=2 [MCU2_0] 17.057176 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.057197 s: DSS: SoC init ... Done !!! [MCU2_0] 17.057214 s: DSS: Board init ... !!! [MCU2_0] 17.057231 s: DSS: Turning on DP_PWR pin for eDP adapters ... !!! [MCU2_0] 17.602884 s: DSS: Turning on DP_PWR pin for eDP adapters ... Done!!! [MCU2_0] 17.602918 s: DSS: Board init ... Done !!! [MCU2_0] 17.628894 s: DSS: Display is not connected [MCU2_0] 17.628933 s: DSS: Init ... Done !!! [MCU2_0] 17.628952 s: VHWA: VPAC Init ... !!! [MCU2_0] 17.628968 s: SCICLIENT: Sciclient_pmSetModuleState module=361 state=2 [MCU2_0] 17.629073 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.629095 s: VHWA: LDC Init ... !!! [MCU2_0] 17.630707 s: VHWA: LDC Init ... Done !!! [MCU2_0] 17.630739 s: VHWA: MSC Init ... !!! [MCU2_0] 17.636454 s: VHWA: MSC Init ... Done !!! [MCU2_0] 17.636484 s: VHWA: NF Init ... !!! [MCU2_0] 17.637286 s: VHWA: NF Init ... Done !!! [MCU2_0] 17.637311 s: VHWA: VISS Init ... !!! [MCU2_0] 17.642626 s: VHWA: VISS Init ... Done !!! [MCU2_0] 17.642664 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 17.642697 s: VX_ZONE_INIT:Enabled [MCU2_0] 17.642716 s: VX_ZONE_ERROR:Enabled [MCU2_0] 17.642733 s: VX_ZONE_WARNING:Enabled [MCU2_0] 17.643866 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-0 [MCU2_0] 17.643958 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_NF [MCU2_0] 17.644047 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1 [MCU2_0] 17.644127 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1 [MCU2_0] 17.644201 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2 [MCU2_0] 17.644335 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1 [MCU2_0] 17.644428 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE1 [MCU2_0] 17.644514 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE2 [MCU2_0] 17.644601 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE3 [MCU2_0] 17.644694 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE4 [MCU2_0] 17.644783 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE5 [MCU2_0] 17.644893 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE6 [MCU2_0] 17.644987 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE7 [MCU2_0] 17.645089 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE8 [MCU2_0] 17.645174 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY1 [MCU2_0] 17.645263 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY2 [MCU2_0] 17.645351 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX [MCU2_0] 17.645433 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX2 [MCU2_0] 17.645509 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M1 [MCU2_0] 17.645605 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M2 [MCU2_0] 17.645684 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M3 [MCU2_0] 17.645757 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M4 [MCU2_0] 17.645791 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [MCU2_0] 17.645815 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 17.652668 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 17.652699 s: CSI2RX: Init ... !!! [MCU2_0] 17.652715 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2 [MCU2_0] 17.652776 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.652798 s: SCICLIENT: Sciclient_pmSetModuleState module=38 state=2 [MCU2_0] 17.652867 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.652893 s: SCICLIENT: Sciclient_pmSetModuleState module=39 state=2 [MCU2_0] 17.652957 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.652977 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 17.653032 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653053 s: SCICLIENT: Sciclient_pmSetModuleState module=153 state=2 [MCU2_0] 17.653102 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653230 s: CSI2RX: Init ... Done !!! [MCU2_0] 17.653252 s: CSI2TX: Init ... !!! [MCU2_0] 17.653267 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2 [MCU2_0] 17.653314 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653335 s: SCICLIENT: Sciclient_pmSetModuleState module=40 state=2 [MCU2_0] 17.653391 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653412 s: SCICLIENT: Sciclient_pmSetModuleState module=41 state=2 [MCU2_0] 17.653473 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653493 s: SCICLIENT: Sciclient_pmSetModuleState module=363 state=2 [MCU2_0] 17.653541 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653561 s: SCICLIENT: Sciclient_pmSetModuleState module=364 state=2 [MCU2_0] 17.653615 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 17.653680 s: CSI2TX: Init ... Done !!! [MCU2_0] 17.653699 s: ISS: Init ... !!! [MCU2_0] 17.653725 s: IssSensor_Init ... Done !!! [MCU2_0] 17.653782 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 17.653801 s: ISS: Init ... Done !!! [MCU2_0] 17.653818 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 17.653863 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 17.653889 s: UDMA Copy: Init ... !!! [MCU2_0] 17.654770 s: UDMA Copy: Init ... Done !!! [MCU2_0] 17.654801 s: APP: Init ... Done !!! [MCU2_0] 17.654819 s: APP: Run ... !!! [MCU2_0] 17.654834 s: IPC: Starting echo test ... [MCU2_0] 17.654943 s: APP: Run ... Done !!! [MCU2_0] 17.655534 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C7X_1[.] C7X_2[.] [MCU2_0] 17.655584 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C7X_1[P] C7X_2[.] [MCU2_0] 17.655623 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C7X_1[P] C7X_2[P] [MCU2_1] 4.644803 s: CIO: Init ... Done !!! [MCU2_1] 4.644856 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 4.644878 s: CPU is running FreeRTOS [MCU2_1] 4.644894 s: APP: Init ... !!! [MCU2_1] 4.644925 s: SCICLIENT: Init ... !!! [MCU2_1] 4.645037 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)] [MCU2_1] 4.645065 s: SCICLIENT: DMSC FW revision 0xa [MCU2_1] 4.645084 s: SCICLIENT: DMSC FW ABI revision 4.0 [MCU2_1] 4.645104 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.645122 s: UDMA: Init ... !!! [MCU2_1] 4.645932 s: UDMA: Init ... Done !!! [MCU2_1] 4.645964 s: MEM: Init ... !!! [MCU2_1] 4.645986 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ ba000000 of size 16777216 bytes !!! [MCU2_1] 4.646027 s: MEM: Init ... Done !!! [MCU2_1] 4.646044 s: IPC: Init ... !!! [MCU2_1] 4.646075 s: IPC: 5 CPUs participating in IPC !!! [MCU2_1] 4.646102 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 17.052459 s: IPC: HLOS is ready !!! [MCU2_1] 17.055256 s: IPC: Init ... Done !!! [MCU2_1] 17.055292 s: APP: Syncing with 4 CPUs ... !!! [MCU2_1] 17.055319 s: APP: Syncing with 4 CPUs ... Done !!! [MCU2_1] 17.055341 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 17.055519 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 17.055550 s: FVID2: Init ... !!! [MCU2_1] 17.055601 s: FVID2: Init ... Done !!! [MCU2_1] 17.055632 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 17.055654 s: SCICLIENT: Sciclient_pmSetModuleState module=58 state=2 [MCU2_1] 17.055761 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 17.055784 s: SCICLIENT: Sciclient_pmSetModuleState module=62 state=2 [MCU2_1] 17.055843 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 17.055864 s: VHWA: DOF Init ... !!! [MCU2_1] 17.059658 s: VHWA: DOF Init ... Done !!! [MCU2_1] 17.059694 s: VHWA: SDE Init ... !!! [MCU2_1] 17.060881 s: VHWA: SDE Init ... Done !!! [MCU2_1] 17.060909 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 17.060939 s: VX_ZONE_INIT:Enabled [MCU2_1] 17.060958 s: VX_ZONE_ERROR:Enabled [MCU2_1] 17.060975 s: VX_ZONE_WARNING:Enabled [MCU2_1] 17.062089 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-1 [MCU2_1] 17.062173 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_SDE [MCU2_1] 17.062257 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_DOF [MCU2_1] 17.062292 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [MCU2_1] 17.062317 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 17.062447 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 17.062470 s: UDMA Copy: Init ... !!! [MCU2_1] 17.063319 s: UDMA Copy: Init ... Done !!! [MCU2_1] 17.063355 s: APP: Init ... Done !!! [MCU2_1] 17.063376 s: APP: Run ... !!! [MCU2_1] 17.063392 s: IPC: Starting echo test ... [MCU2_1] 17.063488 s: APP: Run ... Done !!! [MCU2_1] 17.063893 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[.] [MCU2_1] 17.063943 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[P] [MCU2_1] 17.655429 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C7X_1[P] C7X_2[P] [C7x_1 ] 4.901841 s: CIO: Init ... Done !!! [C7x_1 ] 4.901857 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 4.901870 s: CPU is running FreeRTOS [C7x_1 ] 4.901879 s: APP: Init ... !!! [C7x_1 ] 4.901888 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.901989 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)] [C7x_1 ] 4.902003 s: SCICLIENT: DMSC FW revision 0xa [C7x_1 ] 4.902015 s: SCICLIENT: DMSC FW ABI revision 4.0 [C7x_1 ] 4.902027 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.902037 s: UDMA: Init ... !!! [C7x_1 ] 4.902787 s: UDMA: Init ... Done !!! [C7x_1 ] 4.902800 s: MEM: Init ... !!! [C7x_1 ] 4.902813 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 4.902835 s: MEM: Init ... Done !!! [C7x_1 ] 4.902844 s: IPC: Init ... !!! [C7x_1 ] 4.902860 s: IPC: 5 CPUs participating in IPC !!! [C7x_1 ] 4.902875 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 15.326192 s: IPC: HLOS is ready !!! [C7x_1 ] 15.327663 s: IPC: Init ... Done !!! [C7x_1 ] 15.327679 s: APP: Syncing with 4 CPUs ... !!! [C7x_1 ] 17.055321 s: APP: Syncing with 4 CPUs ... Done !!! [C7x_1 ] 17.055341 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 17.055500 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 17.055523 s: VX_ZONE_INIT:Enabled [C7x_1 ] 17.055535 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 17.055546 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 17.055758 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1 [C7x_1 ] 17.055840 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2 [C7x_1 ] 17.055911 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3 [C7x_1 ] 17.055978 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4 [C7x_1 ] 17.056051 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5 [C7x_1 ] 17.056122 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6 [C7x_1 ] 17.056195 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7 [C7x_1 ] 17.056263 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8 [C7x_1 ] 17.056287 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C7x_1 ] 17.056302 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 17.056462 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 17.056476 s: APP: Init ... Done !!! [C7x_1 ] 17.056486 s: APP: Run ... !!! [C7x_1 ] 17.056495 s: IPC: Starting echo test ... [C7x_1 ] 17.056576 s: APP: Run ... Done !!! [C7x_1 ] 17.057888 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[s] C7X_2[P] [C7x_1 ] 17.063885 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[s] C7X_2[P] [C7x_1 ] 17.655448 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[s] C7X_2[P] [C7x_2 ] 5.005625 s: CIO: Init ... Done !!! [C7x_2 ] 5.005642 s: ### CPU Frequency = 1000000000 Hz [C7x_2 ] 5.005655 s: CPU is running FreeRTOS [C7x_2 ] 5.005665 s: APP: Init ... !!! [C7x_2 ] 5.005673 s: SCICLIENT: Init ... !!! [C7x_2 ] 5.005777 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)] [C7x_2 ] 5.005792 s: SCICLIENT: DMSC FW revision 0xa [C7x_2 ] 5.005804 s: SCICLIENT: DMSC FW ABI revision 4.0 [C7x_2 ] 5.005816 s: SCICLIENT: Init ... Done !!! [C7x_2 ] 5.005827 s: UDMA: Init ... !!! [C7x_2 ] 5.006582 s: UDMA: Init ... Done !!! [C7x_2 ] 5.006597 s: MEM: Init ... !!! [C7x_2 ] 5.006611 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 127000000 of size 16777216 bytes !!! [C7x_2 ] 5.006633 s: MEM: Init ... Done !!! [C7x_2 ] 5.006643 s: IPC: Init ... !!! [C7x_2 ] 5.006659 s: IPC: 5 CPUs participating in IPC !!! [C7x_2 ] 5.006674 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_2 ] 15.905712 s: IPC: HLOS is ready !!! [C7x_2 ] 15.907079 s: IPC: Init ... Done !!! [C7x_2 ] 15.907094 s: APP: Syncing with 4 CPUs ... !!! [C7x_2 ] 17.055321 s: APP: Syncing with 4 CPUs ... Done !!! [C7x_2 ] 17.055340 s: REMOTE_SERVICE: Init ... !!! [C7x_2 ] 17.055509 s: REMOTE_SERVICE: Init ... Done !!! [C7x_2 ] 17.055534 s: VX_ZONE_INIT:Enabled [C7x_2 ] 17.055546 s: VX_ZONE_ERROR:Enabled [C7x_2 ] 17.055562 s: VX_ZONE_WARNING:Enabled [C7x_2 ] 17.056103 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP-1 [C7x_2 ] 17.056126 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C7x_2 ] 17.056140 s: APP: OpenVX Target kernel init ... !!! [C7x_2 ] 17.056417 s: APP: OpenVX Target kernel init ... Done !!! [C7x_2 ] 17.056432 s: UDMA Copy: Init ... !!! [C7x_2 ] 17.057523 s: UDMA Copy: Init ... Done !!! [C7x_2 ] 17.057539 s: APP: Init ... Done !!! [C7x_2 ] 17.057552 s: APP: Run ... !!! [C7x_2 ] 17.057562 s: IPC: Starting echo test ... [C7x_2 ] 17.057642 s: APP: Run ... Done !!! [C7x_2 ] 17.057893 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[P] C7X_2[s] [C7x_2 ] 17.063897 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[P] C7X_2[s] [C7x_2 ] 17.655459 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[P] C7X_2[s] root@j721s2-evm:/opt/vision_apps# ./run_app_tidl run_app_tidl.sh run_app_tidl_avp2.sh run_app_tidl_cam.sh run_app_tidl_seg.sh run_app_tidl_vl.sh run_app_tidl_16bit.sh run_app_tidl_avp3.sh run_app_tidl_od.sh run_app_tidl_seg_16bit.sh run_app_tidl_avp.sh run_app_tidl_avp4.sh run_app_tidl_od_cam.sh run_app_tidl_seg_cam.sh root@j721s2-evm:/opt/vision_apps# ./run_app_tidl.sh APP: Init ... !!! 281.168275 s: MEM: Init ... !!! 281.168341 s: MEM: Initialized DMA HEAP (fd=5) !!! 281.168494 s: MEM: Init ... Done !!! 281.168510 s: IPC: Init ... !!! 281.203127 s: IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 281.211900 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 281.215390 s: VX_ZONE_INIT:Enabled 281.215431 s: VX_ZONE_ERROR:Enabled 281.215439 s: VX_ZONE_WARNING:Enabled 281.216618 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0 281.216802 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1 281.218884 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2 281.219116 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3 281.219138 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! 281.220723 s: VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!! 281.358022 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 281.358058 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node DisplayNode 281.358078 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 281.358086 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 281.358096 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.display ... failed !!! 281.358107 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 281.358115 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed app_tidl: ERROR: Verifying display graph ... Failed !!! 281.363055 s: VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!! [MCU2_0] 281.357800 s: src/drv/disp/dss_dispApi.c @ Line 336: [MCU2_0] 281.357829 s: Display Controller registration failed for DSS [MCU2_0] 281.357872 s: VX_ZONE_ERROR:[tivxDisplayCreate:551] DISPLAY: ERROR: Display Create Failed! 281.367500 s: VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! 281.368877 s: IPC: Deinit ... !!! 281.369824 s: IPC: DeInit ... Done !!! 281.369858 s: MEM: Deinit ... !!! 281.369868 s: DDR_SHARED_MEM: Alloc's: 15 alloc's of 26911090 bytes 281.369876 s: DDR_SHARED_MEM: Free's : 15 free's of 26911090 bytes 281.369883 s: DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes 281.369894 s: MEM: Deinit ... Done !!!
Check data :
root@j721s2-evm:/opt/vision_apps# cd /opt/ root@j721s2-evm:/opt# ls containerd edgeai-test-data edgeai-tiovx-kernels imaging model_zoo tidl_test vx_app_arm_remote_log.out edgeai-apps-utils edgeai-tiovx-apps edgeai-tiovx-modules ltp oob-demo-assets vision_apps root@j721s2-evm:/opt# cd vision_apps/ root@j721s2-evm:/opt/vision_apps# cd test_data/ root@j721s2-evm:/opt/vision_apps/test_data# cd psdkra/ root@j721s2-evm:/opt/vision_apps/test_data/psdkra# cd apptidl _tidl root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl# ls -l total 18132 -rw-r--r-- 1 weston weston 786486 Apr 19 2024 0000003436_512x512.bmp -rw-r--r-- 1 weston weston 859374 Apr 19 2024 0001.bmp -rw-r--r-- 1 weston weston 758470 Apr 19 2024 0002.bmp -rw-r--r-- 1 weston weston 360054 Apr 19 2024 0003.bmp -rw-r--r-- 1 weston weston 416030 Apr 19 2024 0004.bmp -rw-r--r-- 1 weston weston 250686 Apr 19 2024 0005.bmp -rw-r--r-- 1 weston weston 819894 Apr 19 2024 0006.bmp -rw-r--r-- 1 weston weston 620254 Apr 19 2024 0007.bmp -rw-r--r-- 1 weston weston 346350 Apr 19 2024 0008.bmp -rw-r--r-- 1 weston weston 609462 Apr 19 2024 0009.bmp -rw-r--r-- 1 weston weston 451638 Apr 19 2024 0010.bmp -rw-r--r-- 1 weston weston 902454 Apr 19 2024 0011.bmp -rw-r--r-- 1 weston weston 476062 Apr 19 2024 0012.bmp -rw-r--r-- 1 weston weston 722490 Apr 19 2024 0013.bmp -rw-r--r-- 1 weston weston 606150 Apr 19 2024 0014.bmp -rw-r--r-- 1 weston weston 627894 Apr 19 2024 0015.bmp -rw-r--r-- 1 weston weston 712950 Apr 19 2024 0016.bmp -rw-r--r-- 1 weston weston 709686 Apr 19 2024 0017.bmp -rw-r--r-- 1 weston weston 307254 Apr 19 2024 0018.bmp -rw-r--r-- 1 weston weston 248886 Apr 19 2024 0019.bmp -rw-r--r-- 1 weston weston 586822 Apr 19 2024 0020.bmp -rw-r--r-- 1 weston weston 562554 Apr 19 2024 0021.bmp -rw-r--r-- 1 weston weston 388854 Apr 19 2024 0022.bmp -rw-r--r-- 1 weston weston 650614 Apr 19 2024 0023.bmp -rw-r--r-- 1 weston weston 786486 Apr 19 2024 0024.bmp -rw-r--r-- 1 weston weston 773814 Apr 19 2024 0025.bmp -rw-r--r-- 1 weston weston 775062 Apr 19 2024 0026.bmp -rw-r--r-- 1 weston weston 465054 Apr 19 2024 0027.bmp -rw-r--r-- 1 weston weston 750054 Apr 19 2024 0028.bmp -rw-r--r-- 1 weston weston 649194 Apr 19 2024 0029.bmp -rw-r--r-- 1 weston weston 510522 Apr 19 2024 0030.bmp -rw-r--r-- 1 weston weston 261 Apr 19 2024 names.txt root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl# root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl# ls 0000003436_512x512.bmp 0003.bmp 0006.bmp 0009.bmp 0012.bmp 0015.bmp 0018.bmp 0021.bmp 0024.bmp 0027.bmp 0030.bmp 0001.bmp 0004.bmp 0007.bmp 0010.bmp 0013.bmp 0016.bmp 0019.bmp 0022.bmp 0025.bmp 0028.bmp names.txt 0002.bmp 0005.bmp 0008.bmp 0011.bmp 0014.bmp 0017.bmp 0020.bmp 0023.bmp 0026.bmp 0029.bmp root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl# root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl# root@j721s2-evm:/opt/vision_apps/test_data/psdkra/app_tidl#
Do I miss anything?
As far as I know, any pre-build app binary should be work.
Thank you
Gibbs
