Part Number: AM625
Following simple code caused exception:
tbl = (uint32_t)((uint8_t*)0x00AA0000);
tbu = (uint32_t)((uint8_t*)0x00AA0004);
How to make GTC counter registers accessible to M4F core at AM625X processor ?
Part Number: AM625
Hi Jim,
I have another thread where I wrote about GTC and how to use it properly. Although on AM64x, but still would apply for AM62x. The response on that thread is as follows:
The GTC is supposed to continue from the last count value it had (even upon JTAG reset). This is mentioned in the AM64x TRM, I have attached a snippet. It would be helpful if you go through it.
Additionally I think you needed the GTC counter value to reset to zero upon soft reset, hence I have written a small application which will do the same upon JTAG reset + after you run the application.
In the above screenshot, there are 4 steps mentioned(in the comments inside code below) which I have implemented and I would encourage you to use the flow mentioned in the attached C file to reset the counter value to 0.
* Copyright (C) 2021 Texas Instruments Incorporated
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <kernel/dpl/DebugP.h>
#include <inttypes.h>
#include "ti_drivers_config.h"
#include "ti_drivers_open_close.h"
#include "ti_board_open_close.h"
#include <drivers/gtc.h>
#include <drivers/soc.h>
#include <drivers/gtc/v0/cslr_gtc.h>
#include <kernel/dpl/ClockP.h>
* This is an empty project provided for all cores present in the device.
* User can use this project to start their application by adding more SysConfig modules.
* This application does driver and board init and just prints the pass string on the console.
* In case of the main core, the print is redirected to the UART console.
* For all other cores, CCS prints are used.
void GTC_disable(void);
void GTC_clearCountRegisters(void);
void hello_world_main(void *args)
int32_t retVal = SystemP_SUCCESS;
uint64_t gtcCount1 = 0, gtcCount2 = 0;
uint64_t clkRate = 0;
/* Open drivers to open the UART driver for console */
Drivers_open();
Board_driversOpen();
// This API is called to reset the 0th and 1st bit of the GTC0_GTC_CFG1_GTC_CFG1_CNTCR register
GTC_disable();
// Now clear the GTC0_GTC_CFG1_GTC_CFG1_CNTCV_LO and GTC0_GTC_CFG1_GTC_CFG1_CNTCV_HI registers
GTC_clearCountRegisters();
retVal = GTC_init();
DebugP_assert(SystemP_SUCCESS == retVal);
retVal = SOC_moduleGetClockFrequency(TISCI_DEV_GTC0, TISCI_DEV_GTC0_GTC_CLK, &clkRate);
gtcCount1 = GTC_getCount64();
ClockP_sleep(3);
gtcCount2 = GTC_getCount64();
DebugP_log("%lf is the time taken in seconds for testing GTC!!!\r\n",((Float64)((Float64)gtcCount2 - (Float64)gtcCount1) / (Float64)clkRate));
Board_driversClose();
Drivers_close();
uint32_t baseAddr = (uint32_t) AddrTranslateP_getLocalAddr(CSL_GTC0_GTC_CFG1_BASE);
HW_WR_REG32(baseAddr, 0);
return;
HW_WR_REG32(baseAddr + CSL_GTC_CFG1_CNTCV_LO, 0); // Firstly, setting LO to 0
HW_WR_REG32(baseAddr + CSL_GTC_CFG1_CNTCV_HI, 0); // Secondly, setting HI to 0
return;
Let me know if this helps you resolve your issue.
Vaibhav
