TDA4VM: Support Request: YOLOv8 Deployment on Board Without Cloud Dependency
Part Number: TDA4VM
Dear Texas Instruments Support Team,
I am currently working on a confidential government-related project and have a TDA4VM board from TI in hand. The goal is to deploy a YOLOv8-based object detection model on this edge device. After reviewing the available documentation and resources, I still have a few specific queries that I’d appreciate your assistance with:
  1. Native YOLOv8 Inference Support
    Can YOLOv8 models be directly used for inference on the TDA4VM board without conversion?
    If yes:
    • What is the recommended way to run such models (e.g., with OpenCV)?
    • What FPS can be expected during inference?
  2. Model Quantization Without Cloud Access
    I came across the edgeai-tidl-tools repository, which outlines a cloud-based model training, quantization, and calibration flow.
    Due to security policies, I cannot use any cloud-based services for training or deployment.
    • Is it possible to train, quantize, and calibrate YOLOv8 models on a host machine without internet access or cloud dependencies?
    • If so, could you please share the steps or documentation to support this flow?
  3. GUI Support on the Board
    As the TDA4VM board currently runs in a headless Linux shell environment:
    • Is there a way to enable and run a GUI-based application on this board?
    • If yes, could you guide me on the steps or tools required?
  4. Custom Application Development
    I intend to build a custom application that connects a camera and performs YOLO-based object detection.
    • Do you have any reference pipelines, examples, or documentation for building and deploying such applications?
  5. OS Compatibility (Ubuntu 20.04 / 22.04)
    I understand the board has specific OS support, but just to confirm:
    • Is there any possibility of running Ubuntu 20.04 or 22.04 on the TDA4VM board?
  6. Model Conversion Without Edge AI Studio
    Is there any alternative method to convert models without using Edge AI Studio?
    • If yes, could you please provide guidance or tools to support the same?
    • if no, the please mention reason in this email thread.
I’d greatly appreciate your support in helping me proceed with an offline, secure, and efficient deployment for this project.
Looking forward to your response.
  • Hi Sanyam,
    Please give me some time to investigate all your questions. Will respond as soon as possible.
    Warm regards,
    Christina
  • Hi Sanyam,
    Answers in-line...
      If yes:
        No, they need to be quantized to 8 or 16 bits first.
        The demos are GUI-based but model development and deployment are not
      • This requires Linux knowledge, a setup menu, and a display.  Beyond the expectations of an E2E post.
      • Yes, examples are in edgeai-tidl-tools.  This is a common use case.
        Not from TI, I guess it would be possible to port Ubuntu on your own.
        Again, edgeai-tidl-tools is where you start.  The recommended interchange format is ONNX, but TFLits will also work.  I would start by adding your model in examples/osrt_python/model_config.py and running your model from examples/osrt_python/ort.  Use python3 ./onnxrt_ep.py -c -m <your model name> to compile.
    Chris
