[FAQ] PROCESSOR-SDK-AM64X: How to enable constructor / destructor attribute for A53 core using GCC
Part Number: PROCESSOR-SDK-AM64X
I was using the __attribute__((constructor(x) / destructor(y)) property in C code for A53 core with GCC compiler.
the GCC attribute is __attribute__((destructor(x))), where x means API priority number.
I am unable to see my constructor getting called before main function and destructor is also not called after main exits.
  • Please follow the below steps.
    1. Define the init and deinit functions in the boot_armv8.c file located at ${MCU+SDK}\source\kernel\nortos\dpl\a53.
    typedef void (*func_ptr)(void);
    extern func_ptr __preinit_array_start[0], __preinit_array_end[0];
    extern func_ptr __init_array_start[0], __init_array_end[0];
    extern func_ptr __fini_array_start[0], __fini_array_end[0];
    void __init()
        for ( func_ptr* func = __preinit_array_start; func != __preinit_array_end; func++ )
                (*func)();
        for ( func_ptr* func = __init_array_start; func != __init_array_end; func++ )
               (*func)();
    void __deinit()
        for ( func_ptr* func = __fini_array_start; func != __fini_array_end; func++ )
                (*func)();
    2. Modify the __system_start function with below code.
    int __system_start(void)
        volatile unsigned int * bs;
        volatile unsigned int * be;
        unsigned int * dl;
        unsigned int * ds;
        unsigned int * de;
    #if defined (SMP_FREERTOS)
        /* Initialization of bss section is done only once (From Core0) */
        if (0 == Armv8_getCoreId())
            /* initialize .bss to zero */
            bs = & __bss_start__;
            be = & __bss_end__;
            while (bs < be)
                *bs = 0;
                bs++;
            /* relocate the .data section */
            dl = & __data_load__;
            ds = & __data_start__;
            de = & __data_end__;
            if (dl != ds)
                while (ds < de)
                    *ds = *dl;
                    dl++;
                    ds++;
            /* Set flag to indicate bss initialization is done by Core0 */
            bssInitDone = 1;
        else
            /* Core1 should wait until bss initialization is done by Core0 */
            while(bssInitDone != 1)
    #else
        be = & __bss_end__;
        while (bs < be)
            *bs = 0;
            bs++;
        if (dl != ds)
            while (ds < de)
                *ds = *dl;
                dl++;
                ds++;
    #endif
        /* Wait for MMU init to be done by Core0 when running SMP FreeRTOS */
        /* This is done to synchronise between Core0 and Core1 so that MMU initialization is done by Core 0 */
        if (1 == Armv8_getCoreId())
            while(mmuInitDone != 1)
    #endif
        CacheP_enableSMP();
        /* initialize mmu and cache */
        __mmu_init();
        /* Set flag to indicate the MMU initialization completion by Core0 */
            mmuInitDone = 1;
            CacheP_wb((void *)&mmuInitDone, sizeof(mmuInitDone), CacheP_TYPE_ALL);
    #endif
        __init();
        main();
        __deinit();
        Armv8_exit();
        return(0);
    3. Build the libraries for kernel.
    cd ${MCU+SDK}/source/kernel/nortos
    gmake -s -f makefile.am64x.a53.gcc-aarch64 PROFILE=debug
    4. In the example's sysconfig file, add the below sections.
    .ARM.exidx : {} > DDR
        .preinit_array     :
    	    PROVIDE_HIDDEN (__preinit_array_start = .);
    	    KEEP (*(.preinit_array*))
    	    PROVIDE_HIDDEN (__preinit_array_end = .);
    	 } > DDR
    	 .init_array :
    	    PROVIDE_HIDDEN (__init_array_start = .);
    	    KEEP (*(SORT(.init_array.*)))
    	    KEEP (*(.init_array*))
    	    PROVIDE_HIDDEN (__init_array_end = .);
    	 } > DDR
    	 .fini_array :
    	    PROVIDE_HIDDEN (__fini_array_start = .);
    	    KEEP (*(SORT(.fini_array.*)))
    	    KEEP (*(.fini_array*))
    	    PROVIDE_HIDDEN (__fini_array_end = .);
    	 } > DDR
    5. Rebuild the application.
    The constructor and destructor functions will then be able to execute.
    Tushar
