Force usb 2.0 to act as usb1.1
Guru 20755 points
Hello, I would like to ask if I there is a way to force usb 2.0 to act as usb 1.1 in the OMAPL-138, Thank you very much, Ran
  • Yes, it is possible, you can disable the HS ENAB (bit D5) of POWER register.
    --- a/drivers/usb/musb/musb_core.c
    +++ b/drivers/usb/musb/musb_core.c
    @@ -980,7 +980,6 @@ void musb_start(struct musb *musb)
            /* put into basic highspeed mode and start session */
            musb_writeb(regs, MUSB_POWER, MUSB_POWER_ISOUPDATE
                                                    | MUSB_POWER_SOFTCONN
    -                                               | MUSB_POWER_HSENAB
    ravi B
  • Hi ravi, Thanks for the reply, I will try that, but before doing so, high speed is for USB 2.0, and I intend actually to work as USB 1.1. why do you set the usb to to high speed modem ? Regards, Ran
  • You need to remove the line which set the HS ENAB or comment it.
    Just i have provided snippet of code in patch format, you can see "-" symbol on extreme left means that line is removed.
    Ravi B
