SK-AM62A-LP: Specifying _c_int00_secure as the entry_point results in a runtime error.
Part Number: SK-AM62A-LP
Hi experts,
This is a continuation of the question below from the original thread.
Q: What is the correct procedure for setting this up in the c7x FreeRTOS environment?
Please let me know if there are any sample projects or user manuals.
A: The entry point for any FreeRTOS application running on C7x is set to "_c_int00_secure". This function sets up the TCR and MAIR for the C7x. Let me know if this helps answer the question.
The customer confirmed the operation of _c_int00_secure(), cache settings, and performance via sysconfig.
In the linker settings of the provided project, specifying _c_int00_secure as the entry_point seems to result in a runtime error (when executing the entry point during load).
The main difference between this and a working linker is the starting address of the user's address.
Q1:Could the following be affecting this?
AM62Ax_C7x.cmd: Starts at 0x80000000
linker.cmd: Starts at 0x99800000
O.H
  • Hi O.H,
    Can you please share the linker script of the project which is giving runtime error?
    Shreyansh
  • Hi Shreyansh,
    Sorry for the late reply.
    The problem occurs with the sample project's "linker.cmd." The problem doesn't occur with my customized "tmp2.cmd."
    --ram_model
    -heap  0x20000
    -stack 0x20000
    --args 0x1000
    --diag_suppress=10068 /* to suppress no matching section error */
    --cinit_compression=off
    -e _c_int00_secure
    #define DDR0_ALLOCATED_START  0x80000000
    #define C7X_ALLOCATED_START DDR0_ALLOCATED_START + 0x19800000
    #define C7X_RESOURCE_TABLE_BASE (C7X_ALLOCATED_START + 0x00100000)
    #define C7X_BOOT_BASE           (C7X_ALLOCATED_START + 0x00200000)
    #define C7X_VECTOR_BASE         (C7X_ALLOCATED_START + 0x00400000)
    #define C7X_DDR_SPACE_BASE      (C7X_ALLOCATED_START + 0x00410000)
    MEMORY
        L2SRAM (RWX):  org = 0x7E000000,          len = 0x00100000
        DDR0_RESERVED: org = 0x80000000,          len = 0x19800000   /*  Reserved for A53 OS */
        C7X_IPC_D:     org = C7X_ALLOCATED_START, len = 0x00100000   /*  1MB DDR */
        C7X_BOOT_D:    org = C7X_BOOT_BASE,       len = 0x400        /*  1024B DDR */
        C7X_VECS_D:    org = C7X_VECTOR_BASE,     len = 0x4000       /*  16KB DDR */
        C7X_CIO_MEM:   org = C7X_DDR_SPACE_BASE,  len = 0x1000       /*  4KB DDR */
        C7X_DDR_SPACE: org = C7X_DDR_SPACE_BASE+0x1000, len = 0x01BF0000-0x1000  /*  27.9MB - 4KB DDR  */
    SECTIONS
        boot:
          boot.*<boot.oe71>(.text)
        } load > C7X_BOOT_D ALIGN(0x200000)
        .vecs       >       C7X_VECS_D ALIGN(0x400000)
        .secure_vecs    >   C7X_DDR_SPACE ALIGN(0x200000)
        .text:_c_int00_secure > C7X_DDR_SPACE ALIGN(0x200000)
        .text       >       C7X_DDR_SPACE ALIGN(0x200000)
        .bss        >       C7X_DDR_SPACE  /* Zero-initialized data */
        RUN_START(__BSS_START)
        RUN_END(__BSS_END)
        .data       >       C7X_DDR_SPACE  /* Initialized data */
        .cinit      >       C7X_DDR_SPACE  /* could be part of const */
        .init_array >       C7X_DDR_SPACE  /* C++ initializations */
        .stack      >       C7X_DDR_SPACE ALIGN(0x2000)
        .args       >       C7X_DDR_SPACE
        .cio        >       C7X_CIO_MEM
        .const      >       C7X_DDR_SPACE
        .switch     >       C7X_DDR_SPACE /* For exception handling. */
        .sysmem     >       C7X_DDR_SPACE /* heap */
        GROUP:              >  C7X_DDR_SPACE
            .data.Mmu_tableArray          : type=NOINIT
            .data.Mmu_tableArraySlot      : type=NOINIT
            .data.Mmu_level1Table         : type=NOINIT
            .data.gMmu_tableArray_NS       : type=NOINIT
            .data.Mmu_tableArraySlot_NS   : type=NOINIT
            .data.Mmu_level1Table_NS      : type=NOINIT
        .benchmark_buffer:     > C7X_DDR_SPACE ALIGN (32)
    -heap  0xF0000   // 756 kB
    /* -stack 0x4000    //  16 kB */
    -stack 0x20000    //  128 kB
    --args 0x1000
    --diag_suppress=10068 // "no matching section"
    /* -e _c_int00_secure */
    /* #define DDR0_ALLOCATED_START  0x80000000 */
    /* #define C7X_ALLOCATED_START DDR0_ALLOCATED_START + 0x19800000 */
    #define C7X_ALLOCATED_START 0x80000000
    #define C7X_DDR_NEAR_BASE       (C7X_ALLOCATED_START + 0x01F00000)
    #define C7X_DDR_FAR_BASE        (C7X_ALLOCATED_START + 0x01F80000)
    #define C7X_DDR_EXT_BASE        (C7X_ALLOCATED_START + 0x02000000)
    MEMORY
      L2SRAM_CINIT (RWX)  : org = 0x7E000000, len = 0x000100 //for 256byte init
      L2SRAM (RWX)        : org = 0x7E000100, len = 0x0fff00 //for 1MBytes  EL2
      L2SRAMAUX   (RWX): org = 0x7F000000, len = 0x040000   // for 256 KBytes AM62A
      L1DSRAM  (RWX): org = 0x64E00000, len = 0x004000   // 16kB, for J7
      EXTMEM_STATIC   (RWX): org = 0x80000000, len = 0x200000
      EXTMEM_DATACN   (RWX): org = 0x80200000, len = 0x200000
      EXTMEM   (RWX): org = 0x80400000, len = 0x200000
      /* rem EXTMEM   (RWX): org = 0x80410000, len = 0x1F0000*/		/* 0702 実行エラー対策 */
      /* rem EXTMEM   (RWX): org = 0x80600000, len = 0x400000
       * rem EXTMEMPAGE (RWX): org = 0x80A00000, len = 0x200000 */
      EXTMEM_FXBUF (RWX):   org = 0x80600000,    len = 0x08000000			/* 128MB DDR */
    SECTIONS
        boot:
        } load > EXTMEM ALIGN(0x200000)
    	.text:_c_int00 > 		L2SRAM_CINIT
    	.text:_c_int00_secure > L2SRAM ALIGN(0x200000)
    	.text     	>			EXTMEM  	  ALIGN(0x2000)
    	.stack    	>			L2SRAM ALIGN(0x2000)
    	.vecs		>			EXTMEM ALIGN(0x80000)
    	.secure_vecs	>		EXTMEM ALIGN(0x200000)
    	.bss 		>			EXTMEM_DATACN
        RUN_END(__BSS_END)
    	.cio      	>			L2SRAM
    	.const    	>			L2SRAM
    	.data       >			EXTMEM
    	.switch     >			EXTMEM
    	.sysmem		>			EXTMEM
    	.far		>			EXTMEM
    	.args       >			EXTMEM
    	.ppinfo		>			EXTMEM
    	.ppdata		>			EXTMEM
    	.pinit		>			L2SRAM
    	.cinit     	>			EXTMEM
    	.binit		>			EXTMEM
    	.init_array >			EXTMEM
    	.neardata	>			EXTMEM
    	.fardata	>			EXTMEM
    	.rodata		>			EXTMEM
    	.c6xabi.exidx	>		EXTMEM
    	.c6xabi.extab	>		EXTMEM
    	.vectors	>			EXTMEM
    	.version_data	>		EXTMEM
    	.table		>			EXTMEM
    	.sdram		>			EXTMEM_FXBUF
    	.src_table		>		EXTMEM
        GROUP:              >  EXTMEM
        .benchmark_buffer:     > EXTMEM ALIGN (32)
    Best regrads,
    O.H
  • Hi O.H,
    The concerned expert is out of office for the rest of this week, please expect some delay in response.
    Meet.
  • Hi O.H,
    Can you also share your memory regions added in the MMU(sysconfig)?
    Are you running any specific example?
    Shreyansh
  • Hi Shreyansh,
    We apologize for the late reply.
    Here are the details of the customer's problem.
    Using AM62Ax_C7x.cmd (linker.cmd excludes from build) → Fails when entrypoint is _c_int00_secure
    Using linker.cmd (AM62Ax_C7x.cmd excludes from build) → Passes when entrypoint is _c_int00_secure
    The cmd file and the sysconfig file used in this case are also included.
    --args 0x1000
    -e _c_int00_secure
    /* -e _c_int00 */
    MEMORY
     /* rem EXTMEM   (RWX): org = 0x80400000, len = 0x200000 */
      EXTMEM   (RWX): org = 0x80400000, len = 0x08000000
      /* rem EXTMEM   (RWX): org = 0x80600000, len = 0x400000*/
      /* rem EXTMEMPAGE (RWX): org = 0x80A00000, len = 0x200000 */
      /* rem EXTMEM_FXBUF (RWX):   org = 0x80600000,    len = 0x08000000	*/		/* 128MB DDR */
    SECTIONS
        boot:
    	.text:_c_int00 > 		EXTMEM ALIGN(0x200000)
    	.text:_c_int00_secure > EXTMEM ALIGN(0x200000)
        RUN_END(__BSS_END)
    	.cio      	>			L2SRAM
    	.const    	>			L2SRAM
    	.stack    	>			EXTMEM ALIGN(0x2000)
    	.data       >			EXTMEM
    	.switch     >			EXTMEM
    	.sysmem		>			EXTMEM
    	.far		>			EXTMEM
    	.args       >			EXTMEM
    	.ppinfo		>			EXTMEM
    	.ppdata		>			EXTMEM
    	.pinit		>			L2SRAM
    	.cinit     	>			EXTMEM
    	.binit		>			EXTMEM
    	.neardata	>			EXTMEM
    	.fardata	>			EXTMEM
    	.rodata		>			EXTMEM
    	.vectors	>			EXTMEM
    	.table		>			EXTMEM
    	/* rem .sdram		>			EXTMEM_FXBUF */
    	.sdram		>			EXTMEM
    	.src_table		>		EXTMEM
        GROUP:              >  EXTMEM
    --ram_model
    -heap  0x20000
    -stack 0x20000
    --args 0x1000
    -e _c_int00_secure
    MEMORY
    /*  C7X_DDR_SPACE: org = C7X_DDR_SPACE_BASE+0x1000, len = 0x01BF0000-0x1000 */ /*  27.9MB - 4KB DDR  */
        C7X_DDR_SPACE: org = C7X_DDR_SPACE_BASE+0x1000, len = 0x04000000
    SECTIONS
        boot:
        RUN_END(__BSS_END)
        .cio        >       C7X_CIO_MEM
    	.sdram		>		C7X_DDR_SPACE
     * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
     * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
     * @cliArgs --device "AM62Ax" --package "AMB" --part "Default" --context "c75ss0-0" --product "MCU_PLUS_SDK_AM62Ax@10.00.00"
     * @versions {"tool":"1.20.0+3587"}
     * Import the modules used in this configuration.
    const i2c         = scripting.addModule("/drivers/i2c/i2c", {}, false);
    const i2c1        = i2c.addInstance();
    const mcasp       = scripting.addModule("/drivers/mcasp/mcasp", {}, false);
    const mcasp1      = mcasp.addInstance();
    const debug_log   = scripting.addModule("/kernel/dpl/debug_log");
    const mmu_armv8   = scripting.addModule("/kernel/dpl/mmu_armv8", {}, false);
    const mmu_armv81  = mmu_armv8.addInstance();
    const mmu_armv82  = mmu_armv8.addInstance();
    const mmu_armv83  = mmu_armv8.addInstance();
    const mmu_armv84  = mmu_armv8.addInstance();
    const mmu_armv85  = mmu_armv8.addInstance();
    const mmu_armv86  = mmu_armv8.addInstance();
    const mmu_armv87  = mmu_armv8.addInstance();
    const mmu_armv88  = mmu_armv8.addInstance();
    const mmu_armv89  = mmu_armv8.addInstance();
    const mmu_armv810 = mmu_armv8.addInstance();
    const mmu_armv811 = mmu_armv8.addInstance();
     * Write custom configuration values to the imported modules.
    i2c1.$name           = "CONFIG_I2C0";
    i2c1.I2C_child.$name = "drivers_i2c_v0_i2c_v0_template0";
    mcasp1.$name                                   = "CONFIG_MCASP0";
    mcasp1.enableLoopback                          = false;
    mcasp1.txDataMask                              = 0xFFFFFFFF;
    mcasp1.txActiveSlotMask                        = 0x3;
    mcasp1.txCallbackFxn                           = "mcasp_txcb";
    mcasp1.rxCallbackFxn                           = "mcasp_rxcb";
    mcasp1.rxDataMask                              = 0xFFFFFFFF;
    mcasp1.rxActiveSlotMask                        = 0x3;
    mcasp1.txFsSource                              = 0;
    mcasp1.txAclkSource                            = 0;
    mcasp1.rxFsSource                              = 0;
    mcasp1.rxAclkSource                            = 0;
    mcasp1.MCASP.$assignAllowConflicts             = "MCASP1";
    mcasp1.mcaspSer.create(2);
    mcasp1.mcaspSer[0].$name                       = "CONFIG_MCASP_SER0";
    mcasp1.mcaspSer[0].MCASP.$assignAllowConflicts = "MCASP1";
    mcasp1.mcaspSer[1].$name                       = "CONFIG_MCASP_SER1";
    mcasp1.mcaspSer[1].serNum                      = 2;
    mcasp1.mcaspSer[1].dataDir                     = "Receive";
    mcasp1.mcaspSer[1].MCASP.$assignAllowConflicts = "MCASP1";
    scripting.suppress("Resource conflict,MCASP1 is also in use by @@@.+?@@@, @@@.+?@@@", mcasp1.MCASP, "$assign");
    scripting.suppress("Resource conflict,MCASP1 is also in use by @@@.+?@@@, @@@.+?@@@", mcasp1.mcaspSer[0].MCASP, "$assign");
    scripting.suppress("Resource conflict,MCASP1 is also in use by @@@.+?@@@, @@@.+?@@@", mcasp1.mcaspSer[1].MCASP, "$assign");
    const udma         = scripting.addModule("/drivers/udma/udma", {}, false);
    const udma1        = udma.addInstance({}, false);
    udma1.$name        = "CONFIG_UDMA0";
    mcasp1.bcDmaDriver = udma1;
    const udma2         = udma.addInstance({}, false);
    udma2.$name         = "CONFIG_UDMA1";
    mcasp1.pktDmaDriver = udma2;
    debug_log.enableUartLog                   = true;
    debug_log.enableCssLog                    = false;
    debug_log.uartLog.$name                   = "CONFIG_UART0";
    debug_log.uartLog.useMcuDomainPeripherals = true;
    mmu_armv81.size  = 0x20000000;
    mmu_armv81.$name = "REGISTER_REGION_0";
    mmu_armv82.vAddr = 0x20000000;
    mmu_armv82.pAddr = 0x20000000;
    mmu_armv82.size  = 0x20000000;
    mmu_armv82.$name = "REGISTER_REGION_1";
    mmu_armv83.vAddr = 0x40000000;
    mmu_armv83.pAddr = 0x40000000;
    mmu_armv83.size  = 0x20000000;
    mmu_armv83.$name = "REGISTER_REGION_2";
    mmu_armv84.vAddr = 0x60000000;
    mmu_armv84.pAddr = 0x60000000;
    mmu_armv84.size  = 0x10000000;
    mmu_armv84.$name = "FSS0_DAT_REGION";
    mmu_armv85.vAddr = 0x7C200000;
    mmu_armv85.pAddr = 0x7C200000;
    mmu_armv85.$name = "CLEC";
    mmu_armv85.size  = 0x100000;
    mmu_armv86.$name = "DRU";
    mmu_armv86.vAddr = 0x7C400000;
    mmu_armv86.pAddr = 0x7C400000;
    mmu_armv86.size  = 0x100000;
    mmu_armv87.vAddr     = 0x80000000;
    mmu_armv87.pAddr     = 0x80000000;
    mmu_armv87.size      = 0x20000000;
    mmu_armv87.attribute = "MAIR7";
    mmu_armv87.$name     = "DDR_0";
    mmu_armv88.vAddr     = 0xA0000000;
    mmu_armv88.pAddr     = 0xA0000000;
    mmu_armv88.size      = 0x20000000;
    mmu_armv88.$name     = "DDR_1";
    mmu_armv88.attribute = "MAIR7";
    mmu_armv89.vAddr     = 0xAA000000;
    mmu_armv89.pAddr     = 0xAA000000;
    mmu_armv89.size      = 0x2000000;
    mmu_armv89.attribute = "MAIR4";
    mmu_armv89.$name     = "DDR_2";
    mmu_armv810.$name       = "MCASP";
    mmu_armv810.vAddr       = 0x2B10000;
    mmu_armv810.pAddr       = 0x2B10000;
    mmu_armv810.size        = 0x2000000;
    mmu_armv810.privExecute = false;
    mmu_armv811.$name     = "CCS_DEBUG_LOG_MEM";
    mmu_armv811.vAddr     = 0x99C10000;
    mmu_armv811.pAddr     = 0x99C10000;
    mmu_armv811.size      = 0x1000;
    mmu_armv811.attribute = "MAIR4";
     * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
     * version of the tool will not impact the pinmux you originally saw.  These lines can be completely deleted in order to
     * re-solve from scratch.
    i2c1.I2C.$suggestSolution                       = "I2C1";
    i2c1.I2C.SCL.$suggestSolution                   = "I2C1_SCL";
    i2c1.I2C.SDA.$suggestSolution                   = "I2C1_SDA";
    mcasp1.MCASP.AFSX.$suggestSolution              = "GPMC0_WAIT0";
    mcasp1.MCASP.ACLKX.$suggestSolution             = "GPMC0_BE0n_CLE";
    mcasp1.MCASP.AFSR.$suggestSolution              = "GPMC0_CSn2";
    mcasp1.MCASP.ACLKR.$suggestSolution             = "GPMC0_CSn3";
    mcasp1.SYSTEM.$suggestSolution                  = "SYSTEM0";
    mcasp1.mcaspSer[0].MCASP.AXR0.$suggestSolution  = "GPMC0_WEn";
    mcasp1.mcaspSer[1].MCASP.AXR2.$suggestSolution  = "GPMC0_ADVn_ALE";
    debug_log.uartLog.MCU_UART.$suggestSolution     = "MCU_USART0";
    debug_log.uartLog.MCU_UART.RXD.$suggestSolution = "MCU_UART0_RXD";
    debug_log.uartLog.MCU_UART.TXD.$suggestSolution = "MCU_UART0_TXD";
    The problem is that after loading the build program, it remains running without reaching main.
    Stopping it with the debugger results in the following error.
    C7XSS0_0: Trouble Halting Target CPU: (Error -1344 - (0:0:0)) Register or Memory request has failed due to a Transaction Error. This may be the result of reading from a write only register, writing to a read only register, or accessing a memory location that is not assigned. No user action required. (Emulation package 20.0.0.3178)
    C7XSS0_0: Error: (Error -1351 - (0:0:0)) Register or Memory request has timed out. The CPU is executing a High Priority Interrupt, this is typically due to a Double Page Fault. Choose 'Force' to force the CPU into a state that allows debug of why the HPI is active. (Emulation package 20.0.0.3178)
    Please let us know if any information is missing.
    Best regrads,
    O.H
  • Hi O.H,
    Are you running any example from the SDK? Would it be possible to share the code snippet which can help me reproduce the issue quickly?
    Shreyansh
  • Hi Shreyansh,
    Sorry for late.
    The .syscfg is based on the sample project below, but the entrypoint problem is the same for sample projects such as empty.
    C:\ti\mcu_plus_sdk_am62ax_11_01_00_16\examples\drivers\mcasp\mcasp_loopback
    O.H
  • Hi O.H,
    Thank you for providing the information. I am working on the issue. I will share an update as soon as I have a better understanding.
    Shreyansh
  • Hi Shreyansh,
    Sorry for rush you. Is there any update? It would be helpful if you could explain the situation.
    O.H
  • Hello
    Please expect delay this week as several team members in India are out of office due to religious holidays. Expect response/update towards the end of the week or early next week
  • Hi O.H,
    Apologies for the delay on responding to this thread.
    I found couple of issues with your linker and mmu configurations:
    Please refer to linker below:
    --args 0x1000
    -e _c_int00_secure
    /* -e _c_int00 */
    MEMORY
    SECTIONS
        boot:
    	.vecs		>			EXTMEM ALIGN(0x400000)
        RUN_END(__BSS_END)
    	.cio      	>			L2SRAM
    	.const    	>			L2SRAM
    	.data       >			EXTMEM
    	.switch     >			EXTMEM
    	.sysmem		>			EXTMEM
    	.far		>			EXTMEM
    	.args       >			EXTMEM
    	.ppinfo		>			EXTMEM
    	.ppdata		>			EXTMEM
    	.pinit		>			L2SRAM
    	.cinit     	>			EXTMEM
    	.binit		>			EXTMEM
    	.neardata	>			EXTMEM
    	.fardata	>			EXTMEM
    	.rodata		>			EXTMEM
    	.vectors	>			EXTMEM
    	.table		>			EXTMEM
    	.sdram		>			EXTMEM
    	.src_table		>		EXTMEM
        GROUP:              >  EXTMEM
    I have deleted the ".text:_c_int00 > EXTMEM ALIGN(0x200000)" section, since it was not being used. Other than this, the .vecs and .text needs to be aligned to 0x400000 and 0x200000 respectively.
    Also, you need to add the L2SRAM to the mmu configuration:
    You will also need to add L2SRAM_AUX if you intend to use that region as well.
    I tried empty project with the linker and mmu configuration, and it is working.
    Shreyansh
  • Hi Shreyansh,
    Thank you very msuch for your support despite your busy schedule. We will try the content you provided.
    O.H
