[FAQ] AM243x/AM64x, AM62x, AM275x: Custom Flash Attach Database
The tables below highlight the working configurations of custom OSPI and QSPI serial NOR/NAND Flash Parts
Note: After using the values for the Flash part present in the below tables, run the OSPI Flash IO example to verify if Flash operations are working as expected.
To get the values for the right Flash Part, simply search for the Name in this FAQ.
  • Working Flash configurations of Winbond Serial NAND Flash parts
    Flash Part Name
    W35N01JWTBAG
    W35N01JWTBAG
    SoC tested on
    AM62A
    AM62A
    Flash Parameters
    OSPI
    OSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial Nand Flash
    Serial Nand Flash
    Flash Name
    W35N01JWTBAG
    W35N01JWTBAG
    Protocol
    1S-8S-8S
    8D-8D-8D
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    134217728
    134217728
    Flash Page Size in Bytes
    4096
    4096
    Flash JEDEC Manufacturer ID
    0xEF
    0xEF
    Flash JEDEC Device ID
    0xDC21
    0xDC21
    Page Load Command
    0x13
    0x13
    Page Program Command
    0x10
    0x10
    Erase
    Configurations
    Flash Block Size In Bytes
    262144
    262144
    Block Erase CMD
    0xD8
    0xD8
    Protocol
    Enable
    Configuration
    Read Command
    0xCB
    0x9D
    Write/Page Program Command
    0xC4
    0x84
    Dummy Clocks (CMD)
    8
    8
    Dummy Clocks (READ)
    20
    8
    Protocol
    Configuration
    Config Is Via Addressed Reg
    Yes
    Yes
    Address Of Config Reg
    0x0
    0x0
    CMD To Read Config Reg
    0x85
    0x85
    CMD To Write To Config Reg
    0x81
    0x81
    Register
    Data
    Data Shift Bits
    0
    0
    Data Binary Mask
    0xFF
    0xFF
    Data To Be Written
    223
    231
    Dummy
    Cycle
    Configuration
    Yes
    Yes
    0x01
    0x01
    0x85
    0x85
    0x81
    0x81
    Register
    Data
    Data Shift Bits
    0
    0
    Data Binary Mask
    0xFF
    0xFF
    Data To Be Written
    20
    8
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    0x9F
    Number Of Bytes To Read
    3
    3
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    0x10
    Write Enable CMD
    0x06
    0x06
    Read Status Register CMD
    0x0F
    0x0F
    Write Status Register CMD
    0x1F
    0x1F
    WIP Status Reg Addr
    0xC0
    0xC0
    WIP Bit
    0
    0
    WIP Read CMD (xSPI)
    0x0F
    0x0F
    WIP Status Reg Addr (xSPI)
    0x0000C000
    0x0000C000
    WIP Read Status Dummy Cycle (xSPI)
    7
    7
    Flash Busy Timeout
    256000000
    256000000
    Page Program Timeout
    512
    512
    Program Status Register Address
    0xC0
    0xC0
    Program Status Register Addr (xSPI)
    0x0000C000
    0x0000C000
    Program Status Bit Position
    3
    3
    Erase Status Register Address
    0xC0
    0xC0
    Erase Status Register Address (xSPI)
    0x0000C000
    0x0000C000
    Erase Status Bit Position
    2
    2
    Write Protection Status Reg Address
    0xA0
    0xA0
    Write Protection Status Mask
    255
    255
    Command Extension Type
    REPEAT
    REPEAT
    Input Clock Frequency (Hz)
    166666666
    200000000
    Input Clock Divider
    8
    8
    Enable DMA
    Yes
    Yes
    Enable PHY Mode
    No
    No
  • Working Flash configurations of Winbond Serial NOR Flash parts
    Flash Part Name
    W25Q128JW
    W25H512JV
    W25Q512JV
    W25Q256JVFQ
                                    SoC tested on
    AM62x
    AM62x
    AM243x
    AM64x
    Flash Parameters
    QSPI
    QSPI
    QSPI
    QSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial Nor
    Flash
    Serial Nor
    Flash
    Serial Nor Flash
    Serial Nor
    Flash
    Flash Name
    W25Q128JW
    W25H512JV
    W25Q512JV
    W25Q256JVFQ
    Protocol
    1S-1S-4S
    1S-1S-4S
    1S-1S-4S
    1S-1S-4S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    16777216
    67108864
    67108864
    33554432
    256
    256
    256
    256
    0xEF
    0xEF
    0xEF
    0xEF
    0x6018
    0x9020
    0x4020
    0x7019
    Erase
    Configurations
    32768
    65536
    65536
    65536
    Flash Sector Size In Bytes
    4096
    4096
    4096
    4096
    Block Erase CMD (3B)
    0x52
    0xD8
    0xD8
    0xD8
    Block Erase CMD (4B)
    0x52
    0xDC
    0xDC
    0xD8
    Sector Erase CMD (3B)
    0x20
    0x20
    0x20
    0x20
    Sector Erase CMD (4B)
    0x20
    0x21
    0x21
    0x20
    Protocol
    Enable
    Configuration
    Read Command
    0x6B
    0x6C
    0x6C
    0x6C
    0x32
    0x34
    0x34
    0x32
    Mode Clocks (CMD)
    0
    0
    0
    0
    Mode Clocks (READ)
    0
    0
    0
    0
    Dummy Clocks (CMD)
    0
    0
    0
    0
    Dummy Clocks (READ)
    8
    8
    8
    8
    Quad Enable Type
    6
    6
    6
    4
    Octal Enable Type
    0
    0
    0
    0
    QPI Sequence
    0x00
    0x00
    0x00
    0x00
    OPI Sequence
    0x00
    0x00
    0x00
    0x00
    Protocol
    Configuration
    No
    No
    No
    No
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    0
    0
    0
    Data Binary Mask
    0x00
    0x00
    0x00
    0x00
    Data To Be Written
    0
    0
    0
    0
    Dummy
    Cycle
    Configuration
    No
    No
    No
    No
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    0
    0
    0
    Data Binary Mask
    0x00
    0x00
    0x00
    0x00
    Data To Be Written
    0
    0
    0
    0
    STR/DTR
    Configuration
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    Register Data
    Data Shift Bits
    0
    0
    0
    0
    Data Binary Mask
    0x00
    0x00
    0x00
    0x00
    Data To Be Written
    0
    0
    0
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    0x9F
    0x9F
    0x9F
    3
    3
    3
    3
    Number Of Dummy Cycles In Quad Mode
    0
    0
    0
    0
    Number Of Dummy Cycles In Octal Mode
    0
    0
    0
    4
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    0x10
    0x10
    0x30
    Flash Device Busy Type
    LEGACY POLLING OF SR
    LEGACY
    POLLING OF SR
    Write Enable CMD
    0x06
    0x06
    0x06
    0x06
    0x05
    0x05
    0x05
    0x05
    WIP Bit
    0
    0
    0
    0
    WEL Bit
    1
    1
    1
    1
    WIP Read CMD (xSPI)
    0x00
    0x00
    0x00
    0x05
    0x00
    0x00
    0x00
    0x00
    WIP Bit (xSPI)
    0
    0
    0
    0
    Chip Erase
    Command
    0xC7
    0xC7
    0xC7
    0xC7
    Flash Busy Timeout
    256000000
    256000000
    256000000
    80000000
    Page Program
    Timeout
    512
    512
    512
    704
    Enable 4 Byte
    Addressing
    No
    Yes
    Yes
    Yes
    Supported
    Addressing Modes
    1
    1
    1
    1
    4 Byte Addressing Enable Sequence
    0xA0
    0xA0
    0xA0
    0xA5
    REPEAT
    NONE
    NONE
    NONE
    200000000
    100000000
    100000000
    200000000
    Input Clock Divider
    4
    4
    4
    20
    Enable DMA
    Yes
    No
    No
    Yes
    Enable PHY Mode
    No
    No
    No
    No
  • Working Flash configurations of Cypress/Infineon Serial NOR Flash parts
    Flash Part Name
    S28HS512T
    S25HL512T
    S25FL128SA
                                        SoC tested on
    Default Sitara EVMs
    AM243x-LP
    AM263x
    Flash Parameters
    OSPI
    QSPI
    QSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial NOR
    Flash
    Serial NOR
    Flash
    Serial NOR
    Flash
    Flash Name
    S28HS512T
    S25HL512T
    S25FL128SA
    Protocol
    8D-8D-8D
    4S-4D-4D
    1S-1S-4S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    67108864
    67108864
    16777216
    256
    256
    256
    0x34
    0x34
    0x01
    0x5B1A
    0x2A1A
    0x2018
    Erase
    Configurations
    262144
    262144
    65536
    4096
    4096
    4096
    0xDC
    0xD8
    0xD8
    0xDC
    0xDC
    0xD8
    0x21
    0x20
    0x20
    0x21
    0x21
    0x20
    Protocol
    Enable
    Configuration
    Read Command
    0xEE
    0xED
    0x6B
    0x12
    0x02
    0x02
    Mode Clocks (CMD)
    0
    0
    0
    Mode Clocks (READ)
    0
    1
    0
    Dummy Clocks (CMD)
    4
    0
    0
    Dummy Clocks (READ)
    25
    15
    8
    Quad Enable Type
    0
    0
    1
    Octal Enable Type
    0
    0
    0
    QPI Sequence
    0x00
    0x08
    0x00
    OPI Sequence
    0x00
    0x00
    0x00
    Protocol
    Configuration
    Yes
    No
    No
    0x00800006
    0x00
    0x00
    0x65
    0x00
    0x00
    0x71
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    0
    0
    Data Binary Mask
    0x01
    0x00
    0x00
    Data To Be Written
    1
    0
    0
    Dummy
    Cycle
    Configuration
    Yes
    Yes
    No
    0x00800003
    0x00800003
    0x00
    0x65
    0x65
    0x00
    0x71
    0x71
    0x00
    Register
    Data
    Data Shift Bits
    0
    0
    0
    Data Binary Mask
    0x0F
    0x0F
    0x00
    Data To Be Written
    11
    15
    0
    STR/DTR
    Configuration
    Yes
    No
    No
    0x00800006
    0x00
    0x00
    0x65
    0x00
    0x00
    0x71
    0x00
    0x00
    Register Data
    Data Shift Bits
    1
    0
    0
    Data Binary Mask
    0x02
    0x00
    0x00
    Data To Be Written
    1
    0
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    0x9F
    0x00
    Address Size (bytes)
    4
    4
    0
    3
    3
    0
    0
    0
    0
    4
    4
    0
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    0x10
    0x10
    LEGACY POLLLING OF SR
    N/A
    Write Enable CMD
    0x06
    0x06
    0x06
    0x05
    0x05
    0x05
    WIP Bit
    0
    0
    0
    WEL Bit
    1
    1
    1
    WIP Read CMD (xSPI)
    0x65
    0x00
    0x00
    0x00800000
    0x00
    0x00
    WIP Bit (xSPI)
    0
    0
    0
    Chip Erase
    Command
    0xC7
    0xC7
    0xC7
    Flash Busy Timeout
    256000000
    6000000
    24000000
    Page Program
    Timeout
    512
    4000
    4000
    Enable 4 Byte
    Addressing
    Yes
    Yes
    No
    Supported
    Addressing Modes
    1
    1
    0
    0xA1
    0xA1
    0
    REPEAT
    NONE
    NONE
    133333333
    100000000
    80000000
    Input Clock Divider
    4
    4
    0
    Enable DMA
    Yes
    Yes
    No
    Enable PHY Mode
    Yes
    Yes
    No
  • Working Configurations of Macronix Serial NOR Flash parts
    Flash Part Name
    MX25UV125
    MX25L25645gzni-08g
    MX25L3233F
                                               SoC tested on
    AM62Px
    AM62x
    AM263Px
    Flash Parameters
    OSPI
    QSPI
    QSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial NOR
    Flash
    Serial NOR Flash
    Serial Nor
    Flash
    Flash Name
    MX25UV125
    MX25L25645gzni-08g
    MX25L3233F
    Protocol
    8D-8D-8D
    4D-4D-4D
    1S-1S-4S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    16777216
    33554432
    4194304
    256
    256
    256
    0xC2
    0xC2
    0xC2
    0x8138
    0x2019
    0x2016
    Erase
    Configurations
    65536
    65536
    65536
    4096
    4096
    4096
    0xD8
    0xD8
    0xD8
    0xDC
    0xDC
    0xD8
    0x20
    0x20
    0x20
    0x21
    0x21
    0x20
    Protocol
    Enable
    Configuration
    Read Command
    0xEE
    0xEB
    0x6B
    0x12
    0x02
    0x02
    Mode Clocks (CMD)
    0
    0
    0
    Mode Clocks (READ)
    0
    2
    0
    Dummy Clocks (CMD)
    4
    0
    0
    Dummy Clocks (READ)
    16
    4
    8
    Quad Enable Type
    0
    2
    2
    Octal Enable Type
    0
    0
    0
    QPI Sequence
    0x00
    0x04
    0xFF
    OPI Sequence
    0x00
    0x00
    0x00
    Protocol
    Configuration
    Yes
    No
    No
    0x0
    0x00
    0x00
    0x71
    0x00
    0x00
    0x72
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    0
    0
    Data Binary Mask
    0x03
    0x00
    0x00
    Data To Be Written
    2
    0
    0
    Dummy
    Cycle
    Configuration
    Yes
    No
    Yes
    0x300
    0x00
    0x15
    0x71
    0x00
    0x01
    0x72
    0x00
    1
    Register
    Data
    Data Shift Bits
    0
    0
    8
    Data Binary Mask
    0x07
    0x00
    0xFF
    Data To Be Written
    2
    0
    64
    STR/DTR Configuration
    0x0
    0x00
    0x00
    0x71
    0x00
    0x00
    0x72
    0x00
    0x00
    Register Data
    Data Shift Bits
    0
    0
    0
    Data Binary Mask
    0x03
    0x00
    0x00
    Data To Be Written
    2
    0
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    0x95
    0x9F
    3
    5
    3
    0
    0
    0
    4
    0
    8
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    0x10
    0x10
    Write Enable CMD
    0x06
    0x06
    0x06
    0x05
    0x05
    0x05
    WIP Bit
    0
    0
    0
    WEL Bit
    1
    1
    1
    WIP Read CMD (xSPI)
    0x05
    0x00
    0x00
    0x0
    0x00
    0x00
    WIP Bit (xSPI)
    0
    0
    0
    Chip Erase
    Command
    0xC7
    0xC7
    0xC7
    Flash Busy Timeout
    40000000
    112000000
    72000000
    Page Program
    Timeout
    512
    256
    400
    Enable 4 Byte
    Addressing
    Yes
    Yes
    No
    Supported
    Addressing Modes
    2
    1
    0
    0x20
    0x85
    0x00
    INVERSE
    NONE
    NONE
    166666666
    166666666
    133333333
    Input Clock Divider
    8
    8
    4
    Enable DMA
    Yes
    No
    Yes
    Enable PHY Mode
    Yes
    No
    No
  • Working Configurations for ISSI Serial NOR Flash Parts
    Flash Part Name
    IS25LP256D
    IS25WX512
                              SoC tested on
    AM243x
    AM275x
    Flash Parameters
    QSPI
    OSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial NOR
    Flash
    Serial NOR
    Flash
    Flash Name
    IS25LP256D
    IS25WX512
    Protocol
    4D-4D-4D
    8D-8D-8D
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    33554432
    67108864
    256
    256
    0x9D
    0x9D
    0x6019
    0x5B1A
    Erase
    Configurations
    65536
    131072
    4096
    4096
    0xD8
    0xD8
    0xD8
    0xDC
    0x20
    0x20
    0x20
    0x21
    Protocol
    Enable
    Configuration
    Read Command
    0xEB
    0xFD
    0x02
    0x02
    Mode Clocks (CMD)
    0
    0
    Mode Clocks (READ)
    2
    0
    Dummy Clocks (CMD)
    0
    8
    Dummy Clocks (READ)
    4
    20
    Quad Enable Type
    2
    0
    Octal Enable Type
    0
    0
    QPI Sequence
    0x04
    0x00
    OPI Sequence
    0x00
    0x00
    Protocol
    Configuration
    No
    Yes
    0x00
    0x00
    0x00
    0x85
    0x00
    0x81
    Register
    Data
    Data Shift Bits
    0
    0
    Data Binary Mask
    0x00
    0xFF
    Data To Be Written
    0
    231
    Dummy
    Cycle
    Configuration
    No
    Yes
    0x00
    0x01
    0x00
    0x85
    0x00
    0x81
    Register
    Data
    Data Shift Bits
    0
    0
    Data Binary Mask
    0x00
    0xFF
    Data To Be Written
    0
    20
    STR/DTR
    Configuration
    0x00
    0x00
    0x00
    0x85
    0x00
    0x81
    Register Data
    Data Shift Bits
    0
    0
    Data Binary Mask
    0x00
    0xFF
    Data To Be Written
    0
    231
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    0x9F
    5
    5
    0
    0
    0
    8
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x30
    0x30
    1
    FLAG SR
    BIT 7
    Write Enable CMD
    0x06
    0x06
    0x05
    0x05
    WIP Bit
    0
    0
    WEL Bit
    1
    1
    WIP Read CMD (xSPI)
    0x00
    0x00
    0x00
    0x00
    WIP Bit (xSPI)
    0
    0
    Chip Erase
    Command
    0xC7
    0xC7
    Flash Busy Timeout
    60000000
    256000000
    Page Program
    Timeout
    200
    512
    Enable 4 Byte
    Addressing
    Yes
    Yes
    Supported
    Addressing Modes
    0
    1
    0xA9
    0
    NONE
    REPEAT
    166666666
    200000000
    Input Clock Divider
    8
    2
    Enable DMA
    No
    Yes
    Enable PHY Mode
    No
    Yes
    Patch:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/6318.diff_5F00_phy.patch
  • Working Configurations for GigaDevice Serial NOR Flash Parts
    Flash Part Name
    GD25B64C
                                       SoC tested on
    AM273x
    Flash Parameters
    QSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial NOR
    Flash
    Flash Name
    GD25B64C
    Protocol
    1S-1S-4S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    8388608
    256
    0xC8
    0x4017
    Erase
    Configurations
    65536
    4096
    0xD8
    0x00
    0x20
    0x00
    Protocol
    Enable
    Configuration
    Read Command
    0x6B
    0x02
    Mode Clocks (CMD)
    0
    Mode Clocks (READ)
    0
    Dummy Clocks (CMD)
    0
    Dummy Clocks (READ)
    8
    Quad Enable Type
    1
    Octal Enable Type
    0
    QPI Sequence
    0x00
    OPI Sequence
    0x00
    Protocol
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    Dummy
    Cycle
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    STR/DTR
    Configuration
    0x00
    0x00
    0x00
    Register Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x00
    0
    0
    0
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    0
    Write Enable CMD
    0x06
    0x05
    WIP Bit
    0
    WEL Bit
    1
    WIP Read CMD (xSPI)
    0x00
    0x00
    WIP Bit (xSPI)
    0
    Chip Erase
    Command
    0xC7
    Flash Busy Timeout
    6000000
    Page Program
    Timeout
    4000
    Enable 4 Byte
    Addressing
    No
    Supported
    Addressing Modes
    0
    0x00
    NONE
    66666666
    Input Clock Divider
    0
    Enable DMA
    No
    Enable PHY Mode
    No
  • Working Configurations for Renesas Serial NOR Flash Parts
    Flash Part Name
    AT25SF64
                                      SoC tested on
    AM243x
    Flash Parameters
    QSPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial NOR
    Flash
    Flash Name
    AT25SF64
    Protocol
    1S-1S-4S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    8388608
    256
    0x1F
    0x8801
    Erase
    Configurations
    65536
    4096
    0xD8
    0xD8
    0x20
    0x20
    Protocol
    Enable
    Configuration
    Read Command
    0x6B
    0x02
    Mode Clocks (CMD)
    0
    Mode Clocks (READ)
    0
    Dummy Clocks (CMD)
    0
    Dummy Clocks (READ)
    8
    Quad Enable Type
    6
    Octal Enable Type
    0
    QPI Sequence
    0x00
    OPI Sequence
    0x00
    Protocol
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    Dummy
    Cycle
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    STR/DTR
    Configuration
    0x00
    0x00
    0x00
    Register Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    5
    0
    0
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    1
    Write Enable CMD
    0x06
    0x05
    WIP Bit
    0
    WEL Bit
    1
    WIP Read CMD (xSPI)
    0x00
    0x00
    WIP Bit (xSPI)
    0
    Chip Erase
    Command
    0xC7
    Flash Busy Timeout
    32000000
    Page Program
    Timeout
    448
    Enable 4 Byte
    Addressing
    No
    Supported
    Addressing Modes
    0
    0x00
    REPEAT
    133333333
    Input Clock Divider
    4
    Enable DMA
    No
    Enable PHY Mode
    No
  • Working Configurations for GigaDevice Serial NAND Flash Parts
    Flash Part Name
    GD5F2GM7UE
                                                 SoC tested on
    AM62Px
    Flash Parameters
    SPI
    Serial
    Flash
    Configuration
    Flash Type
    Serial Nand Flash
    Flash Name
    GD5F2GM7UE
    Protocol
    1S-1S-1S
    Basic
    Flash
    Configuration
    Flash Size in Bytes
    268435456
    2048
    0xC8
    0x0092
    Page Load Command
    0x13
    0x10
    Erase
    Configurations
    131072
    Block Erase CMD
    0xD8
    Protocol
    Enable
    Configuration
    Read Command
    0x03
    0x02
    Dummy Clocks (CMD)
    4
    Dummy Clocks (READ)
    8
    Protocol
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    Dummy
    Cycle
    Configuration
    No
    0x00
    0x00
    0x00
    Register
    Data
    Data Shift Bits
    0
    Data Binary Mask
    0x00
    Data To Be Written
    0
    JEDEC ID
    Read
    Configuration
    Read ID CMD
    0x9F
    2
    Advanced
    Flash
    Configuration
    Flash Reset Type
    0x10
    Write Enable CMD
    0x06
    0x0F
    0x1F
    WIP Status Reg Addr
    0xC0
    WIP Bit
    0
    WIP Read CMD (xSPI)
    0x0F
    0x000000C0
    8
    Flash Busy Timeout
    256000000
    600
    0xC0
    0x000000C0
    3
    0xC0
    0x000000C0
    2
    0xA0
    255
    NONE
    100000000
    Input Clock Divider
    4
    Enable DMA
    Yes
    Enable PHY Mode
    No
