Hello All,
I am working with a custom OMAP37xx based platform and a custom OMAP4460 based platform.
I need a USB interface (CDC_ETHERNET) between the two - OMAP3 is the device (HSUSB0 port, transceiver on TPS65950) and OMAP4 is the host (USB OTG port configured for host functionality) .
When the OMAP3 device is connected to the OMAP4 platform, kernel prints show that it is detected but it fails to enumerate as a CDC_ETHERNET device. Please see below for a log of messages.
Other observations:
- When the USB host port of OMAP4 platform is connected to USB device port an OMAP37xx EVM, it detects, enumerates and I have CDC_ETHERNET functionality between the OMAP4 platform and the OMAP3 EVM
- When the USB device port of custom OMAP3 platform is connected to a host PC running Linux, they detect, enumerate and I have CDC_ETHERNET functionality between the PC and OMAP3 custom platform.
Any suggestions on what the problem could be or where I need to look at would be extremely helpful.
Thank you very much for your time.
Kanagesh
Log Messages when custom OMAP3 platform is connected to the custom OMAP4 platform
musb_stage2_irq 843: SUSPEND (b_idle) devctl 99 power e0
musb_interrupt 1611: ** IRQ peripheral usb0004 tx0000 rx0000
musb_stage0_irq 427: <== Power=f0, DevCtl=99, int_usb=0x4
musb_stage0_irq 686: BUS RESET as b_idle
musb_g_reset 2018: <== B-Device addr=0 driver 'g_ether'
musb_interrupt 1611: ** IRQ peripheral usb0008 tx0001 rx0000
musb_g_ep0_irq 643: csr 0001, count 8, myaddr 0, ep0stage setup
musb_read_fifo 230: RX ep0 fifo fa0ab020 count 8 buf c052bed6
musb_read_setup 577: SETUP req80.06 v0100 i0000 l64
musb_g_ep0_irq 822: handled 0, csr 0001, ep0stage in
musb_g_ep0_queue 928: queue to ep0 (OUT/RX), length=18
musb_write_fifo 171: TX ep0 fifo fa0ab020 count 18 buf dfa47400
musb_g_giveback 142: ep0 done request dfa69d00, 18/18
musb_interrupt 1611: ** IRQ peripheral usb000c tx0000 rx0000
musb_stage0_irq 427: <== Power=f0, DevCtl=99, int_usb=0xc
musb_stage0_irq 686: BUS RESET as b_peripheral
musb_g_disconnect 1964: devctl 99
musb_g_ep0_irq 643: csr 0011, count 8, myaddr 0, ep0stage setup
musb_g_ep0_irq 668: SetupEnd came in a wrong ep0stage setup
