We are building our AFS from the 4AJ.2.1 release. However, when booting the images, we see the message below on the console and android will not start. If I replace the ducati-m3.bin file with the version from the pre-built images or from ./hardware/ti/omap4xxx/domx/Ducati_binary/etc/firmware/ducati-m3.bin, then the firmware loads and android will start.
I have discovered that the ducati-m3.bin installed during the build process is not from the hardware/ti directory
-rwxrwxr-x 1 jhane jhane 1388356 Jan 16 11:19 ./hardware/ti/domx/Ducati_binary/etc/firmware/ducati-m3.bin
-rwxrwxr-x 1 jhane jhane 1388356 Jan 16 12:07 ./hardware/ti/omap4xxx/domx/Ducati_binary/etc/firmware/ducati-m3.bin
-rw-r--r-- 1 jhane jhane 6852688 Jan 16 12:50 ./out/target/product/blaze_tablet/system/vendor/firmware/ducati-m3.bin
-rw-r--r-- 1 jhane jhane 6852688 Jul 18 09:53 ./out/target/product/blaze_tablet/obj/FAKE/ti-ducati.untarred_intermediates/ducati-m3.bin
-rw-r--r-- 1 jhane jhane 6852688 Jan 16 12:33 ./out/target/product/blaze_tablet/obj/FAKE/ducati-m3.bin_intermediates/ducati-m3.bin
and instead is coming from the ducati_blaze_tablet.tgz in device/ti/proprietary-open/omap4
Until we start building our own ducati firmware I need to use the pre-built version. I'm trying to figure out what is going on here and how to get a working copy of the ducati firmware into my build.
thank you,
jeff
console messages
shell@android:/ $ [ 32.756622] omap-rproc omap-rproc.1: rproc_watchdog_isr
[ 32.762207] omap-rproc omap-rproc.1: rproc_mmu_fault_isr
[ 32.768005] omap-iommu omap-iommu.0: ducati: errs:0x00000002 da:0x8054e570 pgd:0xc79e2014 *pgd:pxb3800802
[ 32.778533] dump_ipu_registers: REGISTER DUMP FOR REMOTEPROC ipu
[ 32.803833] dump_ipu_registers: PC is at 003d820a
[ 32.820648] dump_ipu_registers: LR is at 002be3d9
[ 32.825805] dump_ipu_registers: pc : [<003d820a>] lr : [<002be3d9>] psr: a1000038
[ 32.825805] sp : 8054e6c8 ip : 00000000 fp : 00000001
[ 32.859680] dump_ipu_registers: r10: 00000001 r9 : 002375a1 r8 : 00000000
[ 32.867340] dump_ipu_registers: r7 : 0000000f r6 : 8054e728 r5 : ffffffff r4 : 00000000
[ 32.890930] dump_ipu_registers: r3 : 00000000 r2 : 00000000 r1 : ffffffff r0 : bebdffff
[ 32.906585] dump_ipu_registers: Flags: NzCv IRQs on FIQs on
[ 32.913146] _event_notify: remoteproc: ipu has crashed
[ 32.929992] rpmsg_rproc_error: Fatal error in ipu
[ 32.935211] rpmsg_rproc_error: Fatal error in ipu
[ 32.953430] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 32.959655] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 32.977355] rpmsg_reset_work: reseting virtio device 8
[ 32.983154] rpmsg_resmgr rpmsg12: Enter rprm_remove
[ 33.001342] rpmsg_reset_work: reseting virtio device 9
[ 33.007019] rpmsg_resmgr rpmsg14: Enter rprm_remove
[ 33.012878] rproc_reset_poolmem: invalid pool
[ 33.017761] omap-rproc omap-rproc.1: stopped remote processor ipu
[ 33.025390] omap-rproc omap-rproc.1: powering up ipu
[ 33.031280] virtio_rpmsg_bus virtio10: rpmsg backend virtproc probed successfully
[ 33.048797] virtio_rpmsg_bus virtio11: rpmsg backend virtproc probed successfully
[ 33.085784] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 6852688
[ 33.124847] omap-rproc omap-rproc.1: remote processor ipu is now up
[ 33.143280] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 33.156555] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 33.163360] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 33.179992] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 38.292572] omap-rproc omap-rproc.1: rproc_watchdog_isr
[ 38.298217] omap-rproc omap-rproc.1: rproc_mmu_fault_isr
[ 38.303985] omap-iommu omap-iommu.0: ducati: errs:0x00000002 da:0x8054e518 pgd:0xc79e2014 *pgd:pxb3800802
[ 38.314544] dump_ipu_registers: REGISTER DUMP FOR REMOTEPROC ipu
[ 38.332824] dump_ipu_registers: PC is at 003d820a
[ 38.338073] dump_ipu_registers: LR is at 002be3d9
[ 38.343261] dump_ipu_registers: pc : [<003d820a>] lr : [<002be3d9>] psr: a1000038
[ 38.343261] sp : 8054e6c8 ip : 00000000 fp : 00000001
[ 38.357849] dump_ipu_registers: r10: 00000001 r9 : 002375a1 r8 : 00000000
[ 38.365661] dump_ipu_registers: r7 : 0000000f r6 : 8054e728 r5 : ffffffff r4 : 00000000
[ 38.374725] dump_ipu_registers: r3 : 00000000 r2 : 00000000 r1 : ffffffff r0 : bebdffff
[ 38.383758] dump_ipu_registers: Flags: NzCv IRQs on FIQs on
[ 38.390350] _event_notify: remoteproc: ipu has crashed
[ 38.395996] rpmsg_rproc_error: Fatal error in ipu
[ 38.401214] rpmsg_rproc_error: Fatal error in ipu
[ 38.406402] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 38.412658] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 38.419219] rpmsg_reset_work: reseting virtio device 10
[ 38.425354] rpmsg_resmgr rpmsg15: Enter rprm_remove
[ 38.432434] rpmsg_reset_work: reseting virtio device 11
[ 38.438690] rpmsg_resmgr rpmsg17: Enter rprm_remove
[ 38.444580] rproc_reset_poolmem: invalid pool
[ 38.449737] omap-rproc omap-rproc.1: stopped remote processor ipu
[ 38.457397] omap-rproc omap-rproc.1: powering up ipu
[ 38.463653] virtio_rpmsg_bus virtio12: rpmsg backend virtproc probed successfully
[ 38.473510] virtio_rpmsg_bus virtio13: rpmsg backend virtproc probed successfully
[ 38.520202] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 6852688
[ 38.557586] omap-rproc omap-rproc.1: remote processor ipu is now up
[ 38.576049] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 38.586791] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 38.593597] omap_rpmsg_mbox_callback: received echo reply from ipu !
