EMIF16 to Strata P30 NOR flash problem
In our project we have several custom boards with C6678 and Strata P30 NOR flash by Nymonyx (Micron, datasheet is http://www.micron.com/~/media/Documents/Products/Data%20Sheet/NOR%20Flash/Parallel/P30/306666_P30_130nm_Discrete_DS.pdf)
All timing and other configuration of EMIF16 is fine. Sometimes we have problems when reading from flash (0xFFFF are read instead of useful data). In that cases if we are connecting to board over XDS560 and making "System Reset" - flash begins to work fine. Sometime it works fine itself after POR. How explain this strange EMIF16's behavior? What should I do and how to configure EMIF16 or reset entire board without XDS560 to reliably read data from the noticed flash?
  • Please provide a diagram showing how the EMIF16 is connected to the FLASH and the values you are writing to the EMIF16 configuration registers. Have you captured a bus access that is returning a bad value using a logic analyzer? You stated that the flash begins to work after you've issued a reset. When the EMIF16 is reset it will return the default values to the EMIF16 configuration registers which will increase the length of your access.  Have you tried adding some addition delay cycles to your read strobe to see if that improves your performance?
    Regards, Bill
  • Thanks for reply.
    Out EMIF16 configuration is:
    Async 1 Config Register (A1CR) = 0x3FFFFFFD
    Page Mode Control Register (PMCR) = 0xFDFDFDFD
    Async Wait Cycle Config Register (AWCCR) = 0xF0000080
    *(unsigned int*)0x20C00008 |= 0x80000000;
    Connections Strata Flash to EMIF16:
    EMIF16 FLASH
    EMIFD[15:0] <=> DQ[15:0]
    EMIFA[22:0] <=> A[23:1]
    EMIFA[23] <=> A[0]
    EMIFCE0 <=> CE
    EMIFOE <=> OE
    EMIFWE <=> WE
    EMIFWAIT0 <=> WAIT
    Unfortunately the most of nets are routed on internal layers and we can't analyze data bus.
    After the reset EMIF16 is configured again (configuration function  is called every time when I start my program).
    All timings are already the slowest.
  • I don't see any problems with your configuration or you connections to the EMIF interface. Can you provide details on the connections of the other pins on the flash such as WP, ADV# and RST#? When the interface fails you stated that the data input was 0xFFFF. Do all accesses return 0xFFFF until the system is reset or does a repeated read get a different value?  When it is the failure state can you probe the CS to see if the external accesses are occurring at all?
    WP is pulled up over 4.7k resistor to 1.8V;
    ADV# is pulled low over 4.7k resistor to gnd;
    RST# is directly connected to 1.8V.
    When I turned on "Continuous Refresh" mode in memory browser to observe emif16 memory space, 0xFFFF was appeared spontaneous at different addresses.
    I will try to catch this.
     P.S. When in our project C6678's resets (RESETFULL and POR) were implemented over RC-chains directly connected to RESETFULL and POR, we also had problems with flash writes (0xFFFF was returned instead of 0x0080 (ready status) even after System Reset over JTAG). After that we implemented resets over schmitt triggers. Now we don't have problems with flash writes.  Definitely there is dependency from C6678's resets.
  • I'm confused by your reference to RC-chains connected to RESETFULL and POR.  Can you provide your reset control circuit for the C6678?
  • I think problem is solved: one of address pins of strata flash was soldered bad, therefore 0xffff sometimes we have seen was read from wrong addresses.
    Thanks a lot for your attention.
  • hello  ,
    may I ask you how did you configure A1CR? I wanna connect dsp with an external FPGA. and I have no idea about how to set those cycles.
    hope you can respond me. thanks in advance.
