I'm using the AM3352ZCZD60 with a TPS65910AA1. The common configuration of my PMIC is VDD_CORE and VDD_MPU in 1.1V - In case, OPP100, OPP100.
This configuration makes my MPU to run with 500MHz ( Table 3-3, page 82, Literature Number SPRS717F).
I want to change the frequency to 600MHz (Maximum perfomance). I'm not sure which order of the steps should I take to perform this change.
Can I change my VDD_MPU in PMIC anytime with the processor powered? Is there any trouble with that?
When booting, In SPL code there is a reg MPU_PLL_CONFIG to changing the OPP100 to OPP120. I'm using a co-processor to start-up the PMIC and control it by I2C. Is there any trouble to changing the SPL code to OPP120 without the Co-processor finish the command by I2C?
Which steps should I do first? Is there any document to help with this process?
