hi TI-friends,
did you know the detailed difference for the following compiler??
rdk3.x
-rwxr-xr-x 2 rd4 rd4 198548 2009-05-22 02:27 arm-none-linux-gnueabi-gcc
rdk4.0
-rwxrwxrwx 1 rd4 rd4 731051 2013-05-03 17:02 arm-arago-linux-gnueabi-gcc
hi TI-friends,
rdk3.x
rdk4.0
arm-none-linux-gnueabi-gcc used in rdk3.x is a binary pre-packaged gcc tool chain release from Codesourcery. (Codesourcery 2009q1 tag). It is GCC v4.3.3 .
arm-arago-linux-gnueabi-gcc used in rdk 4.x is a toolchain built from gcc source using arago distribution and bitbake infrastructure..It is GCC v4.5.3 .
You can use gcc -dumpspecs option to check the configuration.
ALong with the toolchain the glibc and filesystem have also been migrated to a version compatible with arm-arago-linux-gnueabi-gcc toolchain in RDK 4.0 release..You should use arm-arago-linux-gnueabi-gcc toolchain to compile your application as well when using RDK 4.0 .The detailed difference between the compiler versions are numerous
