I use a customer board in my project.I use dm648 DSP.we do not use PHY instead we use Broadcom switch chip 53115. The DSP is used in SGMII to SGMII mode.But I found the rate of Ethernet can only get about 24Mbps,it's too slow. I use version 1.92 NDK.I have changed something in NDK what I found in wiki.Bellow:
Q: How to properly use the SMA connectors on my DM648EVM board?
If you intend to use the SMA connectors without a PHY then you must perform the two modifications below:
- In the file <evmdm648init.c> lines 102-103, enable the SMA connectors by setting the two variables below to true:
use_SMA_on_port0 = TRUE; use_SMA_on_port1 = TRUE;
- This is the same as setting the parameter CPSW3G_INITPARAM_SPEED0 to 9999u in the device driver include file <cspw3g_init_cfg.h> line 160.
- In the device driver source file <cpsw3g_core.c> line 500, prevent the flag pi->TxOn to be reset by commenting out its line:
pi->TxOn = 0;
I want to know where must I change in order to get faster rate of Ethernet. Thanks!
