DM814x IBIS models for McASP pins
I'd like to simulate the McASP pins to get a feel for the best series termination resistance to use.  Looking at the IBIS model, the McASP pins use Selector_4, which provides for the following models:
Model_13 I/O,1.8V,Pull-up/down off,slow,IND,10%
Model_14 I/O,1.8V,Pull-down,fast,IND,10%
Model_15 I/O,1.8V,Pull-down,slow,IND,10%
Model_16 I/O,1.8V,Pull-up,fast,IND,10%
Model_17 I/O,1.8V,Pull-up/down off,fast,IND,10%
Model_18 I/O,1.8V,Pull-up,slow,IND,10%
Model_19 I/O,3.3V,Pull-up/down off,slow,IND,10%
Model_20 I/O,3.3V,Pull-down,fast,IND,10%
Model_21 I/O,3.3V,Pull-down,slow,IND,10%
Model_22 I/O,3.3V,Pull-up,fast,IND,10%
Model_23 I/O,3.3V,Pull-up/down off,fast,IND,10%
Model_24 I/O,3.3V,Pull-up,slow,IND,10%
The datasheet tells you how you can enable/disable pull up/down, but there is no mention of selecting a "fast" or "slow" speed.  How is this selected?.
thanks
Steve
  • Hi Steve,
    The reason that we have several models is due to configurability of the IO in different modes. If one is seeing some slews (faster) then this should be the behavior of the IO. Selection of one mode or another has to be checked with the device limits for that interface and what is the correct bit setting. The slew rate of the IO is a function of frequency.
    The particular model to select depends entirely on how software has the particular pin configured.
    Please refer also to the below links:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/p/155132/614508.aspx#614508
    http://e2e.ti.com/support/dsp/omap_applications_processors/f/447/p/66225/244692.aspx#244692
    http://processors.wiki.ti.com/index.php/How_to_use_the_AM335x_IBIS_Models
    http://www.ti.com.cn/cn/lit/an/spra839a/spra839a.pdf
    Pavel
  • Hi Pavel
    Thanks for your reply.
    Understood. However its not obvious (to me at least) how you would select a FAST vs SLOW pin configuration for the McASP pin - what register allows you to do this?.
    Unless , when the pin is configured as a GPIO, it automatically uses SLOW and when configured as McASP it uses FAST.  Can you confirm this?.
    regards
    Steve
  • Steve,
    It is the PINCNTLx[19] SLEWCTRL bit, it selects between Faster and Slower Slew rate, 0x0 for fast, 0x1 for slow. The reset value is pad/pin dependent. But as you can notice, this PINCNTLx[19] is documented as reserved in the DM814x datasheet and TRM. It is because of the following SiliconErrata advisory:
    http://www.ti.com/lit/er/sprz343c/sprz343c.pdf
    Advisory 2.1.88  Control Module, Pin Configuration (PINCNTLx): ROM Modifies Bit 19
    Details: Bit 19 within each PINCNTL[270:1] register is a RESERVED bit which should not be
                modified by any software during device operation. The reset value is specified to ensure
                datasheet minimum and maximum I/O timings are satisfied across all of the various
                functions mapped to the corresponding pin. The ROM bootloader initialization incorrectly
                modifies bit 19 for some of the PINCNTLx registers. Table 4 and Table 5 identify the
                PINCNTLx registers, per boot mode, affected by the ROM bootloader incorrectly
                modifying bit 19 from its default value.
    Note: The ROM bootloader will attempt successive boot methods if a previous boot
             mode fails. One or more boot modes may apply depending on the configured
             BTMODE[4:0] pins.
    Note: In addition to the ROM bootloader software, the following TI software packages
             may potentially modify bit 19 of the PINCNTLx registers. If any of the following TI
             software packages are used, care should be taken to properly reset bit 19 to the default
             value during device operation:
             • U-BOOT
             • LINUX Kernel (board init files, video drivers)
             • HDVPSS Firmware
    Workaround:
    To prevent potential datasheet I/O timing violations, software should set bit 19 for all
    PINCNTLx registers to the reset value defined in the device-specific data manual.
    Software should also ensure that bit 19 of all PINCNTLx registers is not modified during
    device operation.
    No, the pin SLOW/FAST usage depends on the reset value of PINCNTLx[19] bit.
    Pavel
  • Hi Pavel
    OK!.  Pin 19's the one.  OK, so looking at the Datasheet, I see that for McASP0, all but the CLKX/CLKR pins have the SLOW setting.  Perfect - that answers my question.
    thanks
    Steve
