Question about C6670 PCIe configuration
Guru 15520 points
I have a question about C6670 PCIe configuration.
In our custom board, we use C6670 PCIe as Endpoint.
I have question about configuration of base address.
In PCIe sample program of MCSDK, OutBound and InBound Base Address for endpoint are
configured as follow:
*OutBound -> OB_LO_ADDR = 0x90000000
*InBound  -> IB_LO_ADDR = 0x70000000
What is these address ?
Is it PCIe Address space and fixed for Keystone devices?
best regards,
g.f.
  • Those address 0x7000_0000 and 0x9000_0000 are PCIE addresses across the PCIE bus. Then the PCIE inbound translation registers convert this address into a DSP internal address.
    Attached is a screenshot of the related PCIE registers in the MCSDK test example to help you understand:
    0x2180_0200 region is for OB
    0x2180_0300 region is for IB
    0x2180_1010 region is for BAR
    For example, in the EP side, OB is 0x9000_0001, it generates PCIE address 0x9000_0000 alike crossing the PCIE bus to RC. At the RC, this address matches BAR1 (0x2180_1014) range so it is accepted. Then RC's IB translates this into LL2: incoming PCIE address - 0x9000_0000 + 0x1082_2100.
    Similarly, in RC side,   OB is 0x7000_0001, it generates PCIE address 0x7000_0000 alike crossing the PCIE bus to EP. At the EP, this address matches BAR1 (0x2180_1014) range so it is accepted. Then EP's IB translates this into LL2: incoming PCIE address - 0x7000_0000 + 0x1082_2100.
    You can change above 0x7000_0000 and 0x9000_0000 to something else.
    For Keystone I device, the PCIE memory address is fixed of 256 MB starting at 0x6000_0000.
    For the above MCSDK code, when EP write something to 0x6000_1234, it generates a write with PCIE address 0x9000_1234, it lands to RC's side LL2 0x9000_1234 - 0x9000_0000 + 0x1082_2100 = 0x1082_3334.
    Hope this help.
    Regards, Eric
     3060.PCIE_translation.docx
  • Hi Eric,
    Thank you for the reply.
    Since you answered in detail, I was able to understand.
    Thank you so much.
    best regards,
    g.f.
