MessageQ problem when a data from core 0 is read in core 1
I´ve tried to change the code message_multicore found in C:\ti\ipc_1_24_03_32\packages\ti\sdo\ipc\examples\multicore\evm667x.
I ´ve changed the source core based in file "1031.05 KeyStone Intro to IPC".
i used 2 core (0 and 1)
in core 0 a create this struct
typedef struct DataMsg_int
       MessageQ_MsgHeader header;
       int *data_0;
   } dataMsg_int;
   dataMsg_int *DataMsg_int;
and use this code to connect to core 1 in my task func
 System_printf("C core 1 \n\n");
    do {
        status = MessageQ_open("CORE0", &remoteQueueId);
         if (status < 0)
            Task_sleep(1);
       } while (status < 0);
       msg = MessageQ_alloc(HEAPID, sizeof(MessageQ_MsgHeader));
             if (msg == NULL)
                 System_abort("MessageQ_alloc failed\n" );
       status = MessageQ_put(remoteQueueId, msg);
         if (status < 0)
                 System_abort("MessageQ_put had a failure/error\n");
DataMsg_int = (dataMsg_int*)MessageQ_alloc(HEAPID,sizeof(dataMsg_int));
         DataMsg_int->data_0 = (int*) HeapBufMP_alloc(heapHandle, vezes*sizeof(int), 128);
              if (DataMsg_int->data_0 == NULL)
                    System_abort("erro");
         DataMsg_int->data_0 = &vetor[4];  // veto[4] = 40;   so i want to read 40 in core 1
Cache_wbInv(DataMsg_int->data_0,sizeof(int),Cache_Type_ALL, 128);
         status = MessageQ_put(remoteQueueId,(MessageQ_Msg)DataMsg_int);
                 if (status < 0)
                         System_abort("Falhou a transmissão da dados para core 1 \n");
            MessageQ_close(&remoteQueueId);
           while(1);
core 1
typedef struct DataMsg_read_int
       int *data_read_0;
   } dataMsg_read_int;
   dataMsg_read_int *DataMsg_read_int;
          int *data_0;
      } dataMsg_int;
 messageQ = MessageQ_create("CORE0", NULL);
        if (messageQ == NULL)
            System_abort("MessageQ_create failed\n" );
        status = MessageQ_get(messageQ, &msg, MessageQ_FOREVER);
          if (status < 0)
            System_abort("This should not happen since timeout is forever\n");
          MessageQ_free(msg);
MessageQ_get(messageQ, (MessageQ_Msg*)&DataMsg_read_int, MessageQ_FOREVER);
Cache_inv(DataMsg_read_int->data_read_0,sizeof(int),Cache_Type_ALL, 128);
here my problem
the address  to my data_0 and data_read_o are the same but de value in core 0 is 40  and core 1 to may data_read_0 = 0.
any suggestion?  any mistake that I made?
Nivaldo
