* @file ti_vcam.c
* @path ipnc_mcfw/mcfw/src_linux/mcfw_api/
* @desc This File contains.
* Copyright (c) Texas Instruments Inc 2011, 2012
* Use of this software is controlled by the terms and conditions found
* in the license agreement under which this software has been supplied
#include "ti_vsys_priv.h"
#include "ti_vcam_priv.h"
* Globals
VCAM_MODULE_CONTEXT_S gVcamModuleContext;
* Vcam module APIs
* @func Vcam_params_init
* @desc Function does the following
* @modif This function modifies the following structures
* @inputs This function takes the following inputs
* <argument name>
* Description of usage
* <argument name>
* @outputs <argument name>
* @return Return value of this function if any
Void Vcam_params_init(VCAM_PARAMS_S * pContext)
UInt16 devId, chnId, strmId;
for (devId = 0; devId < VCAM_DEV_MAX; devId++)
pContext->deviceParams[devId].portEnable = FALSE;
pContext->deviceParams[devId].portMode = VCAM_MODE_YUV420;
pContext->deviceParams[devId].dataFormat =
VCAM_MULTICHN_OPTION_SINGLE_CHN;
pContext->deviceParams[devId].signalType = VS_AUTO_DETECT;
for (chnId = 0; chnId < VCAM_CHN_MAX; chnId++)
for (strmId = 0; strmId < VCAM_STRM_MAX; strmId++)
pContext->channelParams[chnId].strmEnable[strmId] = FALSE;
pContext->channelParams[chnId].strmFormat[strmId] = VF_YUV422I_UYVY;
pContext->channelParams[chnId].strmResolution[strmId].start_X = 0;
pContext->channelParams[chnId].strmResolution[strmId].start_Y = 0;
pContext->channelParams[chnId].strmResolution[strmId].width = 0;
pContext->channelParams[chnId].strmResolution[strmId].height = 0;
pContext->channelParams[chnId].deviceId = 0;
pContext->channelParams[chnId].dynamicParams.contrast = 0;
pContext->channelParams[chnId].dynamicParams.saturation = 0;
pContext->channelParams[chnId].dynamicParams.brightness = 0;
pContext->channelParams[chnId].dynamicParams.hue = 0;
* @func Vcam_init
* <argument name>
* <argument name>
Int32 Vcam_init(VCAM_PARAMS_S * pContext)
UInt16 devId, chnId, strmId, deiId;
/* Mark all links related to camera as invalid by default, they will be
* setup with valid IDs later */
gVcamModuleContext.cameraId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.osdId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.nsfId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.vnfId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.nullSrcId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.ipcFramesOutVpssId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.ipcFramesInDspId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.glbceId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.ipcFramesOutHostId = SYSTEM_LINK_ID_INVALID;
for (deiId = 0; deiId < MAX_DEI_LINK; deiId++)
gVcamModuleContext.deiId[deiId] = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.ipcFramesOutVpssToHostId = SYSTEM_LINK_ID_INVALID;
gVcamModuleContext.ipcFramesInHostId = SYSTEM_LINK_ID_INVALID;
/* initialize counters */
gVcamModuleContext.numDevices = 0;
gVcamModuleContext.numChannels = 0;
if (pContext == NULL)
Vcam_params_init(&gVcamModuleContext.vcamConfig);
else
if (pContext->deviceParams[devId].portEnable)
gVcamModuleContext.numDevices++;
if (pContext->channelParams[chnId].strmEnable[strmId])
gVcamModuleContext.numChannels++;
memcpy(&gVcamModuleContext.vcamConfig, pContext, sizeof(VCAM_PARAMS_S));
return 0;
* @func Vcam_exit
* <argument name>
* <argument name>
Void Vcam_exit()
/* Empty for now */
* @func Vcam_start
* <argument name>
* <argument name>
Int32 Vcam_start()
UInt32 deiId;
/* start can happen in any order, except its recommended to start camera
* Link the last */
if (gVcamModuleContext.ipcFramesOutVpssToHostId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.ipcFramesOutVpssToHostId);
if (gVcamModuleContext.ipcFramesInHostId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.ipcFramesInHostId);
// if( gVcamModuleContext.ipcFramesOutHostId!=SYSTEM_LINK_ID_INVALID)
// System_linkStart(gVcamModuleContext.ipcFramesOutHostId);
* Link the last */
if (gVcamModuleContext.nsfId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.nsfId);
* Link the last */
if (gVcamModuleContext.vnfId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.vnfId);
* Link the last */
if (gVcamModuleContext.osdId != SYSTEM_LINK_ID_INVALID)
if (gVcamModuleContext.ipcFramesOutVpssId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.ipcFramesOutVpssId);
if (gVcamModuleContext.ipcFramesInDspId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.ipcFramesInDspId);
System_linkStart(gVcamModuleContext.osdId);
if (gVcamModuleContext.deiId[deiId] != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.deiId[deiId]);
if (gVcamModuleContext.nullSrcId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.nullSrcId);
/* Start taking CPU load just before starting of camera link */
MultiCh_prfLoadCalcEnable(TRUE, FALSE, FALSE);
if (gVcamModuleContext.cameraId != SYSTEM_LINK_ID_INVALID)
System_linkStart(gVcamModuleContext.cameraId);
VCAM_CHN_DYNAMIC_PARAM_S params = { 0 };
memset(¶ms, 0, sizeof(params));
Venc_setInputFrameRate(0, 25);
params.frameRate = 25;
Venc_setDynamicParam(0, 0, ¶ms, VENC_FRAMERATE);
Venc_setDynamicParam(1, 0, ¶ms, VENC_FRAMERATE);
#if defined(CAPTURE_DISPLAY_MODE) || defined(ENC_A8_DEC_USE_CASE)
params.brightness = 128;
Vcam_setDynamicParamChn(0, ¶ms, VCAM_BRIGHTNESS);
params.contrast = 128;
Vcam_setDynamicParamChn(0, ¶ms, VCAM_CONTRAST);
params.saturation = 128;
Vcam_setDynamicParamChn(0, ¶ms, VCAM_SATURATION);
params.sharpness = 128;
Vcam_setDynamicParamChn(0, ¶ms, VCAM_SHARPNESS);
#endif
return 0;
* @func Vcam_stop
* <argument name>
* <argument name>
Int32 Vcam_stop()
UInt32 deiId;
/* stop needs to be in the reseverse order of create */
System_linkStop(gVcamModuleContext.cameraId);
System_linkStop(gVcamModuleContext.nullSrcId);
System_linkStop(gVcamModuleContext.nsfId);
System_linkStop(gVcamModuleContext.vnfId);
System_linkStop(gVcamModuleContext.ipcFramesOutVpssId);
System_linkStop(gVcamModuleContext.ipcFramesInDspId);
System_linkStop(gVcamModuleContext.osdId);
for (deiId = 0; deiId < gVsysModuleContext.vsysConfig.numDeis; deiId++)
System_linkStop(gVcamModuleContext.deiId[deiId]);
System_linkStop(gVcamModuleContext.ipcFramesOutVpssToHostId);
System_linkStop(gVcamModuleContext.ipcFramesInHostId);
return 0;
* @func Vcam_setParamDevice
* <argument name>
* <argument name>
Int32 Vcam_setParamDevice(VCAM_DEV vcDevId, VCAM_DEV_PARAM_S * psvcDevParam,
VCAM_PARAMS_E paramId)
memcpy(&gVcamModuleContext.vcamConfig.deviceParams[vcDevId], psvcDevParam,
sizeof(VCAM_DEV_PARAM_S));
return 0;
* @func Vcam_getParamDevice
* <argument name>
* <argument name>
Int32 Vcam_getParamDevice(VCAM_DEV vcDevId, VCAM_DEV_PARAM_S * psvcDevParam,
memcpy(psvcDevParam, &gVcamModuleContext.vcamConfig.deviceParams[vcDevId],
return 0;
* @func Vcam_enableDevice
* <argument name>
* <argument name>
Int32 Vcam_enableDevice(VCAM_DEV vcDevId)
return 0;
* @func Vcam_disableDevice
* <argument name>
* <argument name>
Int32 Vcam_disableDevice(VCAM_DEV vcDevId)
return 0;
* @func Vcam_setParamChn
* <argument name>
* <argument name>
Int32 Vcam_setParamChn(VCAM_CHN vcChnId, VCAM_CHN_PARAM_S * psCamChnParam,
memcpy(&gVcamModuleContext.vcamConfig.channelParams[vcChnId], psCamChnParam,
sizeof(VCAM_CHN_PARAM_S));
return 0;
* @func Vcam_getParamChn
* <argument name>
* <argument name>
Int32 Vcam_getParamChn(VCAM_CHN vcChnId, VCAM_CHN_PARAM_S * psCamChnParam,
memcpy(psCamChnParam, &gVcamModuleContext.vcamConfig.channelParams[vcChnId],
return 0;
* @func Vcam_setDynamicParamChn
* <argument name>
* <argument name>
Int32 Vcam_setDynamicParamChn(VCAM_CHN vcChnId,
VCAM_CHN_DYNAMIC_PARAM_S * psCamChnDynaParam,
Int32 status = ERROR_NONE;
if (gVcamModuleContext.cameraId == SYSTEM_LINK_ID_INVALID)
return ERROR_FAIL;
switch (paramId)
case VCAM_FORMAT:
break;
case VCAM_GLBCE:
if (gVcamModuleContext.glbceId != SYSTEM_LINK_ID_INVALID)
status = System_linkControl(gVcamModuleContext.glbceId,
GLBCE_LINK_CMD_SET_DYNAMIC_PARAMS,
&(psCamChnDynaParam->enableGlbce),
sizeof(psCamChnDynaParam->enableGlbce),
TRUE);
break;
case VCAM_RESOLUTION:
CameraLink_SetDynParams params;
params.chId = vcChnId;
params.InputWidth = psCamChnDynaParam->InputWidth;
params.InputHeight = psCamChnDynaParam->InputHeight;
status = System_linkControl(gVcamModuleContext.cameraId,
CAMERA_LINK_CMD_CHANGE_RESOLUTION,
&(params), sizeof(params), TRUE);
break;
case VCAM_DCCBUFADDR:
CameraLink_DccParams params;
params.dccBufAddr = psCamChnDynaParam->dccBufAddr;
params.dccSize = psCamChnDynaParam->dccSize;
CAMERA_LINK_CMD_DCC_BUFFER,
break;
case VCAM_AEWB_VENDOR:
CAMERA_LINK_CMD_AEWB_VENDOR,
&(psCamChnDynaParam->aewbVendor),
sizeof(psCamChnDynaParam->aewbVendor),
TRUE);
break;
case VCAM_MIRROR_MODE:
CAMERA_LINK_CMD_MIRROR_MODE,
&(psCamChnDynaParam->mirrorMode),
sizeof(psCamChnDynaParam->mirrorMode),
TRUE);
break;
case VCAM_AEWB_MODE:
CAMERA_LINK_CMD_AEWB_MODE,
&(psCamChnDynaParam->aewbMode),
sizeof(psCamChnDynaParam->aewbMode),
TRUE);
break;
case VCAM_AEWB_PRIORITY:
CAMERA_LINK_CMD_AEWB_PRIORITY,
&(psCamChnDynaParam->aewbPriority),
sizeof(psCamChnDynaParam->aewbPriority),
TRUE);
break;
case VCAM_IRIS:
CAMERA_LINK_CMD_IRIS,
&(psCamChnDynaParam->IRIS),
sizeof(psCamChnDynaParam->IRIS), TRUE);
break;
case VCAM_FRAMECTRL:
CAMERA_LINK_CMD_FRAMECTRL,
&(psCamChnDynaParam->frameCtrl),
sizeof(psCamChnDynaParam->frameCtrl),
TRUE);
break;
case VCAM_CONTRAST:
CAMERA_LINK_CMD_CHANGE_CONTRAST,
&(psCamChnDynaParam->contrast),
sizeof(psCamChnDynaParam->contrast),
TRUE);
break;
case VCAM_SATURATION:
CAMERA_LINK_CMD_CHANGE_SATURATION,
&(psCamChnDynaParam->saturation),
sizeof(psCamChnDynaParam->saturation),
TRUE);
break;
case VCAM_BRIGHTNESS:
CAMERA_LINK_CMD_CHANGE_BRIGHTNESS,
&(psCamChnDynaParam->brightness),
sizeof(psCamChnDynaParam->brightness),
TRUE);
break;
case VCAM_SHARPNESS:
CAMERA_LINK_CMD_CHANGE_SHARPNESS,
&(psCamChnDynaParam->sharpness),
sizeof(psCamChnDynaParam->sharpness),
TRUE);
break;
case VCAM_BLC:
CAMERA_LINK_CMD_CHANGE_BLC,
&(psCamChnDynaParam->blc),
sizeof(psCamChnDynaParam->blc), TRUE);
break;
case VCAM_AWBMODE:
CAMERA_LINK_CMD_CHANGE_AWBMODE,
&(psCamChnDynaParam->awbMode),
sizeof(psCamChnDynaParam->awbMode),
TRUE);
break;
case VCAM_FRAMERATE:
CameraLink_FpsParams params;
params.StreamId = vcChnId;
params.targetFps = psCamChnDynaParam->frameRate;
CAMERA_LINK_CMD_CHANGE_FRAMERATE,
break;
case VCAM_AEMODE:
CAMERA_LINK_CMD_CHANGE_AEMODE,
&(psCamChnDynaParam->AEMode),
sizeof(psCamChnDynaParam->AEMode),
TRUE);
break;
case VCAM_ENV_50_60HZ:
CAMERA_LINK_CMD_CHANGE_ENV_50_60HZ,
&(psCamChnDynaParam->env50_60hz),
sizeof(psCamChnDynaParam->env50_60hz),
TRUE);
break;
case VCAM_BINNING_SKIP:
CAMERA_LINK_CMD_CHANGE_BINNING,
&(psCamChnDynaParam->binningMode),
sizeof(psCamChnDynaParam->binningMode),
TRUE);
break;
case VCAM_HUE:
CAMERA_LINK_CMD_CHANGE_HUE,
&(psCamChnDynaParam->hue),
sizeof(psCamChnDynaParam->hue), TRUE);
break;
case VCAM_LDC:
status = System_linkControl(gVcamModuleContext.vnfId,
VNF_LINK_CMD_ENABLE_LDC,
&(psCamChnDynaParam->enableLDC),
enableLDC), TRUE);
break;
case VCAM_TNF:
VNF_LINK_CMD_ENABLE_TNF,
&(psCamChnDynaParam->enableTNF),
enableTNF), TRUE);
status = System_linkControl(gVcamModuleContext.nsfId,
NSF_LINK_CMD_ENABLE_TNF,
enableTNF), TRUE);
break;
case VCAM_SNF:
VNF_LINK_CMD_ENABLE_SNF,
&(psCamChnDynaParam->enableSNF),
enableSNF), TRUE);
NSF_LINK_CMD_ENABLE_SNF,
enableTNF), TRUE);
break;
case VCAM_NF_STRENGTH:
VNF_LINK_CMD_VNF_STRENGTH,
&(psCamChnDynaParam->nfStrength),
nfStrength), TRUE);
NSF_LINK_CMD_NSF_STRENGTH,
nfStrength), TRUE);
break;
case VCAM_PORTMODE:
break;
case VCAM_SIGNALTYPE:
break;
case VCAM_SD_FORMAT:
CAMERA_LINK_CMD_SET_FORMAT,
&(psCamChnDynaParam->sdFormat),
sdFormat), TRUE);
break;
case VCAM_ALL:
TRUE);
if (status >= 0)
saturation), TRUE);
if (status >= 0)
brightness), TRUE);
if (status >= 0)
TRUE);
break;
return status;
* \brief:
* Set camera frame rate. This is an additional control in camera side itself; is really useful for secondary stream <CIF>.
* Stream 0 is D1 & Stream 1 is CIF.
* \input:
* vcChnId -- camera Channel id
* vStrmId -- Stream Id
* frameRate -- Frame Rate
* \output:
* NA
* \return
* TI_MEDIA_SUCCESS -- while success
* ERROR_CODE -- refer for err defination
* @func Vcam_setFrameRate
* <argument name>
* <argument name>
Int32 Vcam_setFrameRate(VCAM_CHN vcChnId, VCAM_STRM vStrmId, Int32 frameRate)
DeiLink_ChFpsParams params;
params.streamId = vStrmId;
params.inputFrameRate = (1000 * frameRate);
status =
System_linkControl(gVcamModuleContext.deiId[0],
DEI_LINK_CMD_SET_FRAME_RATE, ¶ms, sizeof(params),
TRUE);
#if !defined(TI_814X_BUILD) && !defined(TI_8107_BUILD)
status =
System_linkControl(gVcamModuleContext.deiId[1],
TRUE);
#endif
return status;
* \brief:
* Get camera frame rate. Not available now
* \input:
* \output:
* NA
* \return
* @func Vcam_getFrameRate
* <argument name>
* <argument name>
Int32 Vcam_getFrameRate(VCAM_CHN vcChnId, VCAM_STRM vStrmId)
return 0;
* \brief:
* Get camera Channel dynamic parameters
* \input:
* psCamChnDynaParam -- Device dynamic parameter structure
* \output:
* NA
* \return
* @func Vcam_getDynamicParamChn
* <argument name>
* <argument name>
Int32 Vcam_getDynamicParamChn(VCAM_CHN vcChnId,
VCAM_CHN_DYNAMIC_PARAM_S * psCamChnParam,
return 0;
* @func Vcam_enableDisableChn
* <argument name>
* <argument name>
Int32 Vcam_enableDisableChn(VCAM_CHN vcChnId, VCAM_STRM vcStrmId,
Bool enableChn)
char *onOffName[] = { "ON ", "OFF" };
Int32 status = ERROR_FAIL;
DeiLink_ChannelInfo channelInfo;
UInt32 cmdId, deiId;
channelInfo.channelId = vcChnId % NUM_CH_PER_DEI;
channelInfo.streamId = vcStrmId;
channelInfo.enable = enableChn;
deiId = vcChnId / NUM_CH_PER_DEI;
if (enableChn)
cmdId = DEI_LINK_CMD_ENABLE_CHANNEL;
else
cmdId = DEI_LINK_CMD_DISABLE_CHANNEL;
OSA_printf(" VCAM: CH%d STRM%d = [%s]\n", vcChnId, vcChnId,
onOffName[enableChn]);
if (deiId < MAX_DEI_LINK)
status = System_linkControl(gVcamModuleContext.deiId[deiId],
cmdId,
&(channelInfo),
sizeof(DeiLink_ChannelInfo), TRUE);
return status;
* @func Vcam_enableChn
* <argument name>
* <argument name>
Int32 Vcam_enableChn(VCAM_CHN vcChnId, VCAM_STRM vcStrmId)
return Vcam_enableDisableChn(vcChnId, vcStrmId, TRUE);
* @func Vcam_disableChn
* <argument name>
* <argument name>
Int32 Vcam_disableChn(VCAM_CHN vcChnId, VCAM_STRM vcStrmId)
return Vcam_enableDisableChn(vcChnId, vcStrmId, FALSE);
* @func Vcam_getChnBufferBlocking
* <argument name>
* <argument name>
Int32 Vcam_getChnBufferBlocking(VCAM_CHN vcChnId, UInt8 * pChnBuffer, UInt32 uiTimeoutMs) // consider
// later
return 0;
* @func Vcam_getChnBufferNonBlocking
* <argument name>
* <argument name>
Int32 Vcam_getChnBufferNonBlocking(VCAM_CHN vcChnId, UInt8 * pChnBuffer) // consider
// later
return 0;
* @func Vcam_releaseChnBuffer
* <argument name>
* <argument name>
Int32 Vcam_releaseChnBuffer(VCAM_CHN vcChnId, UInt8 * pChnBuffer) // consider
// later
return 0;
* @func Vcam_delete
* <argument name>
* <argument name>
Int32 Vcam_delete()
UInt32 i;
/* delete can be done in any order */
System_linkDelete(gVcamModuleContext.cameraId);
System_linkDelete(gVcamModuleContext.ipcFramesOutVpssId);
System_linkDelete(gVcamModuleContext.ipcFramesInDspId);
System_linkDelete(gVcamModuleContext.osdId);
for (i = 0; i < MAX_DEI_LINK; i++)
if (gVcamModuleContext.deiId[i] != SYSTEM_LINK_ID_INVALID)
System_linkDelete(gVcamModuleContext.deiId[i]);
System_linkDelete(gVcamModuleContext.nsfId);
System_linkDelete(gVcamModuleContext.vnfId);
System_linkDelete(gVcamModuleContext.ipcFramesOutVpssToHostId);
System_linkDelete(gVcamModuleContext.ipcFramesInHostId);
return 0;
static Void Vcam_copyVidFrameInfoLink2McFw(VIDEO_FRAMEBUF_S *dstBuf,
VIDFrame_Buf *srcBuf)
Int i,j;
OSA_assert(VIDEO_MAX_FIELDS == VIDFRAME_MAX_FIELDS);
OSA_assert(VIDEO_MAX_PLANES == VIDFRAME_MAX_PLANES);
for (i = 0; i < VIDEO_MAX_FIELDS; i++)
for (j = 0; j < VIDEO_MAX_PLANES; j++)
dstBuf->addr[i][j] = srcBuf->addr[i][j];
dstBuf->phyAddr[i][j] = srcBuf->phyAddr[i][j];
dstBuf->channelNum = srcBuf->channelNum;
dstBuf->fid = srcBuf->fid;
dstBuf->frameWidth = srcBuf->frameWidth;
dstBuf->frameHeight = srcBuf->frameHeight;
dstBuf->linkPrivate = srcBuf->linkPrivate;
dstBuf->timeStamp = srcBuf->timeStamp;
dstBuf->framePitch[0] = srcBuf->framePitch[0];
dstBuf->framePitch[1] = srcBuf->framePitch[1];
static Void Vcam_copyVidFrameInfoMcFw2Link(VIDFrame_Buf *dstBuf,
VIDEO_FRAMEBUF_S *srcBuf)
Int i,j;
\brief Send filled video gBuffers to framework for display
User calls this API to put full video frames for display
\param pFrameBufList [OUT] List of video frames to be displayed
\return ERROR_NONE on success
Int32 Vcam_putFullVideoFrames(VIDEO_FRAMEBUF_LIST_S *pFrameBufList)
VIDEO_FRAMEBUF_S *pSrcBuf;
VIDFrame_Buf *pDstBuf;
VIDFrame_BufList vidBufList;
UInt32 i;
Int status = 0;
if (gVcamModuleContext.ipcFramesOutHostId == SYSTEM_LINK_ID_INVALID)
return 0;
//VDIS_TRACE_FXN_ENTRY("Num bufs put:%d",pFrameBufList->numFrames);
vidBufList.numFrames = pFrameBufList->numFrames;
for (i = 0; i < vidBufList.numFrames; i++)
pSrcBuf = &pFrameBufList->frames[i];
pDstBuf = &vidBufList.frames[i];
Vcam_copyVidFrameInfoMcFw2Link(pDstBuf,pSrcBuf);
if (vidBufList.numFrames)
status =
IpcFramesOutLink_putFullVideoFrames(gVcamModuleContext.ipcFramesOutHostId,
&vidBufList);
OSA_printf("VIDFrame release :%d status:%d\n",vidBufList.numFrames, status);
return 0;
\brief :w
Give displayed video frames back to the application
Buffers that are were previously put by Vdis_putFullVideoFrames can be
freed back to the framework by invoking this API.
\param pFrameBufList [IN] List of video frames
Int32 Vcam_getEmptyVideoFrames(VIDEO_FRAMEBUF_LIST_S *pFrameBufList, UInt32 timeout)
VIDFrame_Buf *pInBuf;
VIDEO_FRAMEBUF_S *pOutBuf;
UInt32 i;
if (gVcamModuleContext.ipcFramesOutHostId== SYSTEM_LINK_ID_INVALID)
return 0;
//VDIS_TRACE_FXN_ENTRY();
pFrameBufList->numFrames = 0;
vidBufList.numFrames = 0;
IpcFramesOutLink_getEmptyVideoFrames(gVcamModuleContext.ipcFramesOutHostId,
&vidBufList);
pFrameBufList->numFrames = vidBufList.numFrames;
pOutBuf = &pFrameBufList->frames[i];
pInBuf = &vidBufList.frames[i];
Vcam_copyVidFrameInfoLink2McFw(pOutBuf,pInBuf);
OSA_printf("NumFrames Received:%d\n",pFrameBufList->numFrames);
return 0;
\brief Request filled video buffers from framework
User calls this API to get full video frames from the framework.
After getting the video frames, user will
- consume the video frames
- and then call Vcam_putEmptyVideoFrames() to free the video frames back to the framework
\param pFrameBufList [OUT] List of video frames returned by the framework
\param timeout [IN] TIMEOUT_WAIT_FOREVER or TIMEOUT_NO_WAIT or timeout in msecs
Int32 Vcam_getFullVideoFrames(VIDEO_FRAMEBUF_LIST_S *pFrameBufList, UInt32 timeout)
UInt32 i;
IpcFramesInLink_getFullVideoFrames(gVcamModuleContext.ipcFramesInHostId,
&vidBufList);
return 0;
\brief Give consumed video frames back to the application to be freed
Buffers that are were previously got from Vcam_getFullVideoFrames can be
Int32 Vcam_putEmptyVideoFrames(VIDEO_FRAMEBUF_LIST_S *pFrameBufList)
UInt32 i;
Int status = 0;
status =
IpcFramesInLink_putEmptyVideoFrames(gVcamModuleContext.ipcFramesInHostId,
&vidBufList);
return 0;
* \brief:
* register call back which will post the message
* \input:
* callback -- callback function
* \output:
* NA
* \return
Int32 Vcam_registerCallback(VCAM_CALLBACK_S * callback, Ptr arg)
gVcamModuleContext.callbackFxn = *callback;
gVcamModuleContext.callbackArg = arg;
return 0;
* \brief:
* MCFW layer call back which will invoke the app registered callback
* \input:
* \output:
* NA
* \return
Void Vcam_ipcFramesInCbFxn(Ptr cbCtx)
OSA_assert(cbCtx == &gVcamModuleContext);
if (gVcamModuleContext.callbackFxn.newDataAvailableCb)
gVcamModuleContext.callbackFxn.newDataAvailableCb(gVcamModuleContext.callbackArg);
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
#include "demos/mcfw_api_demos/multich_usecase/ti_mcfw_ipnc_main.h"
* Externs
/* Merge Link for camera streams */
//#define NUM_DUP_LINK (3)
#define NUM_MERGE_LINK (1)
#define CAM_STREAM_MERGE_IDX (0)
//#define HDMIDIS_DUP_IDX (0)
* Use case code
static SystemVideo_Ivahd2ChMap_Tbl systemVid_encDecIvaChMapTbl = {
.isPopulated = 1,
.ivaMap[0] = {
.EncNumCh = 2,
.EncChList = {0, 1},
.DecNumCh = 2,
.DecChList = {0, 1},
static Void SetIpcFramesOutInQueInfo(System_LinkQueInfo *inQueInfo)
Int i;
inQueInfo->numCh =2;// gVencModuleContext.vencConfig.numPrimaryChn;
for (i = 0; i < inQueInfo->numCh; i++)
inQueInfo->chInfo[i].bufType = SYSTEM_BUF_TYPE_VIDFRAME;
inQueInfo->chInfo[i].dataFormat = SYSTEM_DF_YUV420SP_UV;
inQueInfo->chInfo[i].memType = SYSTEM_MT_NONTILEDMEM;
inQueInfo->chInfo[i].scanFormat = SYSTEM_SF_PROGRESSIVE;
inQueInfo->chInfo[i].startX = 0;
inQueInfo->chInfo[i].startY = 0;
inQueInfo->chInfo[i].width = 1920;
inQueInfo->chInfo[i].height = 1080;
inQueInfo->chInfo[i].pitch[0] = 1920;
inQueInfo->chInfo[i].pitch[1] = 0;
inQueInfo->chInfo[i].pitch[2] = 0;
Void multich_create_uw_fullftr()
Int32 i;
// VPSS ---->A8
//A8--->c674
System_LinkInfo framesProducerLinkInfo;
//A8--->VIDEO
CameraLink_CreateParams cameraPrm;
UInt32 mergeId[NUM_MERGE_LINK];
MergeLink_CreateParams mergePrm[NUM_MERGE_LINK];
//VPSS ---->A8
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssToHostPrm;
IpcFramesInLinkHLOS_CreateParams ipcFramesInHostPrm;
//A8--->M3Video
UInt32 ipcInVideoFrameId;
IpcFramesOutLinkHLOS_CreateParams ipcFramesOutHostPrm;
IpcFramesInLinkRTOS_CreateParams ipcFramesInVideoFromHostPrm;
EncLink_CreateParams encPrm;
//M3Video --->A8
IpcBitsOutLinkRTOS_CreateParams ipcBitsOutVideoToHostPrm;
IpcBitsInLinkHLOS_CreateParams ipcBitsInHostPrm;
CameraLink_VipInstParams *pCameraInstPrm;
CameraLink_OutParams *pCameraOutPrm;
/* IPC struct init */
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams, ipcFramesOutVpssToHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkHLOS_CreateParams, ipcFramesInHostPrm);
MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams, ipcFramesOutHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams, ipcFramesInVideoFromHostPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams, ipcBitsOutVideoToHostPrm);
MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams, ipcBitsInHostPrm);
MultiCh_detectBoard();
System_linkControl(SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES, NULL, 0, TRUE);
System_linkControl(SYSTEM_LINK_ID_M3VIDEO, SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
&systemVid_encDecIvaChMapTbl, sizeof(SystemVideo_Ivahd2ChMap_Tbl), TRUE);
gVcamModuleContext.cameraId = SYSTEM_LINK_ID_CAMERA;
mergeId[CAM_STREAM_MERGE_IDX] = SYSTEM_VPSS_LINK_ID_MERGE_0;
gVcamModuleContext.ipcFramesOutVpssToHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_0;
gVcamModuleContext.ipcFramesInHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0;
ipcInVideoFrameId = SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_0;//SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
gVcamModuleContext.ipcFramesOutHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0;
gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0;
gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
/* Camera Link params */
CameraLink_CreateParams_Init(&cameraPrm);
cameraPrm.captureMode = CAMERA_LINK_CAPMODE_ISIF;
cameraPrm.outQueParams[0].nextLink = mergeId[CAM_STREAM_MERGE_IDX];
cameraPrm.outQueParams[1].nextLink = mergeId[CAM_STREAM_MERGE_IDX];
/* This is for TVP5158 Audio Channels - Change it to 16 if there are 16
* audio channels connected in cascade */
cameraPrm.numAudioChannels = 0;
cameraPrm.numVipInst = 1;
cameraPrm.tilerEnable = FALSE;
cameraPrm.vsEnable = FALSE;
pCameraInstPrm = &cameraPrm.vipInst[0];
pCameraInstPrm->vipInstId = SYSTEM_CAMERA_INST_VP_CSI2;
pCameraInstPrm->videoDecoderId = MultiCh_getSensorId(gUI_mcfw_config.sensorId);
pCameraInstPrm->inDataFormat = SYSTEM_DF_YUV420SP_UV;
pCameraInstPrm->sensorOutWidth = 1920;
pCameraInstPrm->sensorOutHeight = 1080;
pCameraInstPrm->standard = SYSTEM_STD_1080P_24;//SYSTEM_STD_1080P_30;
pCameraInstPrm->numOutput = 2;
/* First stream */
pCameraOutPrm = &pCameraInstPrm->outParams[0];
pCameraOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV;
pCameraOutPrm->scEnable = FALSE;
pCameraOutPrm->scOutWidth = 1920;
pCameraOutPrm->scOutHeight = 1080;
pCameraOutPrm->outQueId = 0;
/* second stream */
pCameraOutPrm = &pCameraInstPrm->outParams[1];
pCameraOutPrm->scOutWidth = 1920;//720;
pCameraOutPrm->scOutHeight = 1080;//480;
pCameraOutPrm->outQueId = 1;
/* 2A config*/
cameraPrm.t2aConfig.n2A_vendor = gUI_mcfw_config.n2A_vendor;
cameraPrm.t2aConfig.n2A_mode = gUI_mcfw_config.n2A_mode;
mergePrm[CAM_STREAM_MERGE_IDX].numInQue = 2;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkId = gVcamModuleContext.cameraId;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkQueId = 0;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[1].prevLinkId = gVcamModuleContext.cameraId;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[1].prevLinkQueId = 1;
mergePrm[CAM_STREAM_MERGE_IDX].outQueParams.nextLink = gVcamModuleContext.ipcFramesOutVpssToHostId;
mergePrm[CAM_STREAM_MERGE_IDX].notifyNextLink = TRUE;
//set Frames out vpss to host link info
ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = mergeId[CAM_STREAM_MERGE_IDX];
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcamModuleContext.ipcFramesInHostId;
ipcFramesOutVpssToHostPrm.baseCreateParams.numOutQue=1;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyProcessLink=FALSE;
ipcFramesInHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = FALSE;//TRUE;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcamModuleContext.ipcFramesOutVpssToHostId;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;;
ipcFramesInHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesInHostPrm.exportOnlyPhyAddr = TRUE;
ipcFramesInHostPrm.cbCtx = &gVcamModuleContext;
ipcFramesInHostPrm.cbFxn = Vcam_ipcFramesInCbFxn;
//A8 Frames to M3Video set
ipcFramesOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = FALSE;//TRUE;
ipcFramesOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesOutHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutHostPrm.baseCreateParams.outQueParams[0].nextLink = ipcInVideoFrameId;
SetIpcFramesOutInQueInfo(&ipcFramesOutHostPrm.inQueInfo);
ipcFramesInVideoFromHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesInVideoFromHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcamModuleContext.ipcFramesOutHostId;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInVideoFromHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.encId;
// init encode params
/* Video Encoder Link params */
MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
encPrm.numBufPerCh[0] = 4; //D1
encPrm.numBufPerCh[1] = 4; //CIF]]
EncLink_ChCreateParams *pLinkChPrm;
EncLink_ChDynamicParams *pLinkDynPrm;
VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
VENC_CHN_PARAMS_S *pChPrm;
for (i = 0; i < VENC_PRIMARY_CHANNELS; i++)
pLinkChPrm = &encPrm.chCreateParams[i];
pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
pDynPrm = &pChPrm->dynamicParam;
// if( i==1)
pLinkChPrm->format = IVIDEO_H264HP;
// else
// pLinkChPrm->format = IVIDEO_MJPEG;
pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[i];
pLinkChPrm->dataLayout = IVIDEO_PROGRESSIVE;
pLinkChPrm->fieldMergeEncodeEnable = FALSE;
pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
pLinkChPrm->rateControlPreset = IVIDEO_USER_DEFINED; //pChPrm->rcType;
pLinkChPrm->enableHighSpeed = FALSE;
pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
pLinkChPrm->StreamPreset = gUI_mcfw_config.StreamPreset[i];
pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval;
pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate;
pLinkDynPrm->interFrameInterval = 1;
pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate;
pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
pLinkDynPrm->qpMin = pDynPrm->qpMin;
pLinkDynPrm->qpMax = pDynPrm->qpMax;
pLinkDynPrm->qpInit = pDynPrm->qpInit;
pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
// encPrm.numBufPerCh[i] = 4;
// gVencModuleContext.encFormat[i] = pLinkChPrm->format;
/* Video Encoder Framerate */
encPrm.chCreateParams[0].defaultDynamicParams.inputFrameRate = 25;
encPrm.chCreateParams[1].defaultDynamicParams.inputFrameRate = 25;
encPrm.vsEnable = gUI_mcfw_config.vsEnable;
encPrm.isVaUseCase = 0;
for (i = VENC_PRIMARY_CHANNELS; i < (VENC_CHN_MAX - 1); i++)
encPrm.chCreateParams[i].format = IVIDEO_MJPEG;
encPrm.chCreateParams[i].profile = 0;
encPrm.chCreateParams[i].dataLayout = IVIDEO_PROGRESSIVE;
encPrm.chCreateParams[i].fieldMergeEncodeEnable = FALSE;
encPrm.chCreateParams[i].defaultDynamicParams.intraFrameInterval = 0;
encPrm.chCreateParams[i].encodingPreset = 0;
encPrm.chCreateParams[i].enableAnalyticinfo = 0;
encPrm.chCreateParams[i].enableWaterMarking = 0;
encPrm.chCreateParams[i].defaultDynamicParams.inputFrameRate = 25;
encPrm.chCreateParams[i].rateControlPreset = 0;
encPrm.chCreateParams[i].defaultDynamicParams.targetBitRate = 100 * 1000;
encPrm.chCreateParams[i].defaultDynamicParams.interFrameInterval = 0;
encPrm.chCreateParams[i].defaultDynamicParams.mvAccuracy = 0;
encPrm.inQueParams.prevLinkId = ipcInVideoFrameId;
encPrm.inQueParams.prevLinkQueId = 0;
encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId;
/* IPC Bits Out VIDEO Link params */
ipcBitsOutVideoToHostPrm.baseCreateParams.noNotifyMode = TRUE;//FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
ipcBitsOutVideoToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsOutVideoToHostPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutVideoToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoToHostPrm, TRUE);
/* IPC Bits In HOST Link params */
ipcBitsInHostPrm.baseCreateParams.noNotifyMode = TRUE;//FALSE;
ipcBitsInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcBitsInHostPrm.baseCreateParams.notifyPrevLink = FALSE;//TRUE;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm);
/* Links Creation */
/* Camera Link */
System_linkCreate(gVcamModuleContext.cameraId, &cameraPrm, sizeof(cameraPrm));
System_linkControl(gVcamModuleContext.cameraId, CAMERA_LINK_CMD_DETECT_VIDEO, NULL, 0, TRUE);
/* Merge Link */
System_linkCreate(mergeId[CAM_STREAM_MERGE_IDX], &mergePrm[CAM_STREAM_MERGE_IDX], sizeof(mergePrm[CAM_STREAM_MERGE_IDX]));
//out yuv 420 1080P to A8
System_linkCreate(gVcamModuleContext.ipcFramesOutVpssToHostId, &ipcFramesOutVpssToHostPrm, sizeof(ipcFramesOutVpssToHostPrm));
System_linkCreate(gVcamModuleContext.ipcFramesInHostId, &ipcFramesInHostPrm, sizeof(ipcFramesInHostPrm));
System_linkGetInfo(gVcamModuleContext.ipcFramesInHostId,&framesProducerLinkInfo);
OSA_assert(framesProducerLinkInfo.numQue == 1);
ipcFramesOutHostPrm.inQueInfo = framesProducerLinkInfo.queInfo[0];
//A8 out yuv420 to M3Video
System_linkCreate(gVcamModuleContext.ipcFramesOutHostId, &ipcFramesOutHostPrm, sizeof(ipcFramesOutHostPrm));
System_linkCreate(ipcInVideoFrameId, &ipcFramesInVideoFromHostPrm, sizeof(ipcFramesInVideoFromHostPrm));
// Video Encoder Link
System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
//M3Video to A8
System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoToHostPrm, sizeof(ipcBitsOutVideoToHostPrm));
System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm, sizeof(ipcBitsInHostPrm));
//start Links
System_linkStart(gVencModuleContext.ipcBitsInHLOSId);
System_linkStart(gVencModuleContext.ipcBitsOutRTOSId);
System_linkStart(gVencModuleContext.encId);
System_linkStart(ipcInVideoFrameId);
System_linkStart(mergeId[CAM_STREAM_MERGE_IDX]);
Void multich_delete_uw_fullftr()
/* display link */
/* Merge Link */
System_linkDelete(mergeId[CAM_STREAM_MERGE_IDX]);
/* Camera Link */
/* Print the HWI, SWI and all tasks load */
/* Reset the accumulated timer ticks */
MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
OSA_printf("USECASE TEARDOWN DONE\n");
* Copyright (c) 2011 Texas Instruments Incorporated - http://www.ti.com/ *
* ALL RIGHTS RESERVED *
\file ti_mcfw_ipcframes.c
\brief
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <errno.h>
#include <ctype.h>
#include <assert.h>
#include <unistd.h>
#include <fcntl.h>
#include <string.h>
#include <osa_que.h>
#include <osa_mutex.h>
#include <osa_thr.h>
#include <osa_sem.h>
#include "ti_mcfw_ipcframes.h"
#include "mcfw/interfaces/ti_vcam.h"
#include "mcfw/interfaces/ti_vdis.h"
#ifdef CUSTOM_SD_DEMO
#include <osa_dma.h>
App_IpcFramesMMapCtrl gMMapCtrl;
#define FILE_WRITE_STOPPED (0)
#define FILE_WRITE_RUNNING (1)
#endif
#define MCFW_IPC_FRAMES_NONOTIFYMODE_FRAMESIN (TRUE)
#define MCFW_IPC_FRAMES_NONOTIFYMODE_FRAMESOUT (TRUE)
#define MCFW_IPCFRAMES_SENDRECVFXN_TSK_PRI (2)
#define MCFW_IPCFRAMES_SENDRECVFXN_TSK_STACK_SIZE (0) /* 0 means system default will be used */
#define MCFW_IPCFRAMES_SENDRECVFXN_PERIOD_MS (16)
#define MCFW_IPCFRAMES_INFO_PRINT_INTERVAL (8192)
#define MCFW_IPCFRAMES_MAX_PENDING_RECV_SEM_COUNT (10)
#define MCFW_IPC_FRAMES_TRACE_ENABLE_FXN_ENTRY_EXIT (1)
#define MCFW_IPC_FRAMES_TRACE_INFO_PRINT_INTERVAL (8192)
#if MCFW_IPC_FRAMES_TRACE_ENABLE_FXN_ENTRY_EXIT
#define MCFW_IPC_FRAMES_TRACE_FXN(str,...) do { \
static Int printInterval = 0;\
if ((printInterval % MCFW_IPC_FRAMES_TRACE_INFO_PRINT_INTERVAL) == 0) \
OSA_printf("MCFW_IPCFRAMES:%s function:%s",str,__func__); \
OSA_printf(__VA_ARGS__); \
printInterval++; \
} while (0)
#define MCFW_IPC_FRAMES_TRACE_FXN_ENTRY(...) MCFW_IPC_FRAMES_TRACE_FXN("Entered",__VA_ARGS__)
#define MCFW_IPC_FRAMES_TRACE_FXN_EXIT(...) MCFW_IPC_FRAMES_TRACE_FXN("Leaving",__VA_ARGS__)
#else
#endif
//extern Int32 Vsys_allocBuf(UInt32 srRegId, UInt32 bufSize, UInt32 bufAlign, Vsys_AllocBufInfo *bufInfo);
static void App_ipcFramesPrintFrameInfo(VIDEO_FRAMEBUF_S *buf)
OSA_printf("MCFW_IPCFRAMES:VIDFRAME_INFO:"
"chNum:%d\t"
"fid:%d\t"
"frameWidth:%d\t"
"frameHeight:%d\t"
"timeStamp:%d\t"
"virtAddr[0][0]:%p\t"
"phyAddr[0][0]:%p",
buf->channelNum,
buf->fid,
buf->frameWidth,
buf->frameHeight,
buf->timeStamp,
buf->addr[0][0],
buf->phyAddr[0][0]);
static void App_ipcFramesPrintFullFrameListInfo(VIDEO_FRAMEBUF_LIST_S *bufList,
char *listName)
// static Int printStatsInterval = 0;
// if ((printStatsInterval % MCFW_IPCFRAMES_INFO_PRINT_INTERVAL) == 0)
Int i;
OSA_printf("MCFW_IPCFRAMES:VIDFRAMELIST_INFO:%s\t"
"numFullFrames:%d",
listName,
bufList->numFrames);
for (i = 0; i < bufList->numFrames; i++)
// App_ipcFramesPrintFrameInfo(&bufList->frames[i]);
// printStatsInterval++;
static void mymemcpy( VIDEO_FRAMEBUF_LIST_S* psrc, Vsys_AllocBufInfo bufinfo, VIDEO_FRAMEBUF_LIST_S *pdst )
Int32 i;
UInt32 addrphy;
UInt32 addrvir;
addrphy = (UInt32)bufinfo.physAddr;
addrvir = (UInt32)bufinfo.virtAddr;
pdst->numFrames = psrc->numFrames;
for( i=0; i<pdst->numFrames; i++ )
//change to dma cpy,
addrphy = (UInt32)bufinfo.physAddr+i*1920*1080*3/2;
addrvir = (UInt32)bufinfo.virtAddr+i*1920*1080*3/2;
pdst->frames[i].addr[0][0] = (Ptr)addrvir;//cirBufpsrc->frames[i].addr[0][0];
pdst->frames[i].phyAddr[0][0] = (Ptr)addrphy;//psrc->frames[i].phyAddr[0][0];
pdst->frames[i].addr[0][1] = (Ptr)(addrvir+1920*1080);//psrc->frames[i].addr[0][1];
pdst->frames[i].phyAddr[0][1] =(Ptr)(addrphy+1920*1080);//psrc->frames[i].phyAddr[0][1];
pdst->frames[i].channelNum = psrc->frames[i].channelNum;
pdst->frames[i].timeStamp = psrc->frames[i].timeStamp;
pdst->frames[i].fid = psrc->frames[i].fid;
pdst->frames[i].frameWidth = psrc->frames[i].frameWidth;
pdst->frames[i].frameHeight = psrc->frames[i].frameHeight;
memcpy( pdst->frames[i].framePitch, psrc->frames[i].framePitch, 4*VIDEO_MAX_PLANES );
// pdst->frames[i].linkPrivate = psrc->frames[i].linkPrivate;
static Void * App_ipcFramesSendRecvFxn(Void * prm)
App_IpcFramesCtrlThrObj *thrObj = ( App_IpcFramesCtrlThrObj *) prm;
VIDEO_FRAMEBUF_LIST_S bufList;
VIDEO_FRAMEBUF_LIST_S bufputList;
Int status;
Vsys_AllocBufInfo bufinfo;
Vsys_allocBuf( VSYS_SR1_SHAREMEM, 2*1920*1080*3/2, 128, &bufinfo);
OSA_semWait(&thrObj->framesInNotifySem,OSA_TIMEOUT_FOREVER);
while (FALSE == thrObj->exitFramesInOutThread)
status = Vcam_getFullVideoFrames(&bufList, TIMEOUT_WAIT_FOREVER);
OSA_assert(0 == status);
if (bufList.numFrames)
App_ipcFramesPrintFullFrameListInfo(&bufList, "ddddddddddddd");
mymemcpy( &bufList, bufinfo, &bufputList );
status = Vcam_putFullVideoFrames(&bufList);
bufputList.numFrames = 0;
Vcam_getEmptyVideoFrames( &bufputList, 0 );
if(bufputList.numFrames)
status = Vcam_putEmptyVideoFrames(&bufputList);
OSA_waitMsecs(MCFW_IPCFRAMES_SENDRECVFXN_PERIOD_MS);
/*while (FALSE == thrObj->exitFramesInOutThread)
//TODO:put yuv420 ---->m3video
//Vcam_getEmptyVideoFrames(&bufputList, 0);
//Vcam_putFullVideoFrames(&bufputList);
// Vcam_getFullVideoFrames( &bufputList, 0 );
//put MPout
// status = Vcam_putEmptyVideoFrames(&bufList);
// status = Vcam_putEmptyVideoFrames(&bufputList);
OSA_printf("MCFW_IPCFRAMES:%s:Leaving...",__func__);
return NULL;
static Void App_ipcFramesInitThrObj( App_IpcFramesCtrlThrObj *thrObj)
OSA_semCreate(&thrObj->framesInNotifySem,
MCFW_IPCFRAMES_MAX_PENDING_RECV_SEM_COUNT,0);
thrObj->exitFramesInOutThread = FALSE;
OSA_thrCreate(&thrObj->thrHandleFramesInOut,
App_ipcFramesSendRecvFxn,
MCFW_IPCFRAMES_SENDRECVFXN_TSK_PRI,
MCFW_IPCFRAMES_SENDRECVFXN_TSK_STACK_SIZE,
thrObj);
static Void App_ipcFramesDeInitThrObj( App_IpcFramesCtrlThrObj *thrObj)
thrObj->exitFramesInOutThread = TRUE;
OSA_thrDelete(&thrObj->thrHandleFramesInOut);
OSA_semDelete(&thrObj->framesInNotifySem);
static
Void App_ipcFramesInCbFxn (Ptr cbCtx)
App_IpcFramesCtrl *ipcFramesCtrl;
static Int printInterval;
OSA_assert(cbCtx = &gApp_ipcFramesCtrl.ipcFrames);
ipcFramesCtrl = cbCtx;
OSA_semSignal(&ipcFramesCtrl->thrObj.framesInNotifySem);
//if ((printInterval % MCFW_IPCFRAMES_INFO_PRINT_INTERVAL) == 0)
// OSA_printf("MCFW_IPCFRAMES: Callback function:%s",__func__);
printInterval++;
Void App_ipcFramesInSetCbInfo ()
VCAM_CALLBACK_S VcamCallback;
VcamCallback.newDataAvailableCb = App_ipcFramesInCbFxn;
Vcam_registerCallback(&VcamCallback, &gApp_ipcFramesCtrl.ipcFrames);
Int32 App_ipcFramesCreate(int demoId)
if(demoId == 1)
App_ipcFramesFileWriteCreate();
else
gApp_ipcFramesCtrl.fileFrameWriteChn = 0;
gApp_ipcFramesCtrl.fileFrameWriteEnable = FALSE;
#endif
App_ipcFramesInitThrObj(&gApp_ipcFramesCtrl.ipcFrames.thrObj);
return OSA_SOK;
Void App_ipcFramesStop(void)
gApp_ipcFramesCtrl.ipcFrames.thrObj.exitFramesInOutThread = TRUE;
Int32 App_ipcFramesDelete()
OSA_printf("Entered:%s...",__func__);
App_ipcFramesDeInitThrObj(&gApp_ipcFramesCtrl.ipcFrames.thrObj);
OSA_printf("Leaving:%s...",__func__);
return OSA_SOK;
Void App_ipcFramesFileWriteCreate()
OSA_printf("\nEnable RAW Frame Write\n\n");
gApp_ipcFramesCtrl.fileFrameWriteEnable = Demo_getFileWriteEnable();
if(gApp_ipcFramesCtrl.fileFrameWriteEnable)
char path[256];
Demo_getFileWritePath(path, "/dev/shm");
gApp_ipcFramesCtrl.fileFrameWriteChn = Demo_getChId("FRAME File Write", gDemo_info.maxVcamChannels);
sprintf(gApp_ipcFramesCtrl.fileFrameWriteName, "%s/VID_CH%02d.yuv", path, gApp_ipcFramesCtrl.fileFrameWriteChn);
Void App_ipcFramesFileOpen()
gApp_ipcFramesCtrl.fp = NULL;
gApp_ipcFramesCtrl.fileFrameWriteState = FILE_WRITE_STOPPED;
gApp_ipcFramesCtrl.fp = fopen(gApp_ipcFramesCtrl.fileFrameWriteName, "wb");
if(gApp_ipcFramesCtrl.fp!=NULL)
gApp_ipcFramesCtrl.fileFrameWriteState = FILE_WRITE_RUNNING;
OSA_printf(" Opened file [%s] for writing CH%d\n", gApp_ipcFramesCtrl.fileFrameWriteName, gApp_ipcFramesCtrl.fileFrameWriteChn);
else
OSA_printf(" ERROR: File open [%s] for writing CH%d FAILED !!!!\n", gApp_ipcFramesCtrl.fileFrameWriteName, gApp_ipcFramesCtrl.fileFrameWriteChn);
Void App_ipcFrameFileWrite(VIDEO_FRAMEBUF_LIST_S *pFrameBufList)
UInt32 writeDataSize;
VIDEO_FRAMEBUF_S *pBuf;
App_IpcFramesChInfo *pChInfo;
UInt32 frameSize = 0, frameId;
for(frameId=0; frameId<pFrameBufList->numFrames; frameId++)
pBuf = &pFrameBufList->frames[frameId];
if(pBuf->channelNum<VENC_CHN_MAX)
pChInfo = &gApp_ipcFramesCtrl.chFrameInfo[pBuf->channelNum];
frameSize = (pBuf->frameWidth * pBuf->frameHeight) << 1;
pChInfo->totalDataSize += frameSize;
pChInfo->numFrames++;
if(pBuf->frameWidth > pChInfo->maxWidth)
pChInfo->maxWidth = pBuf->frameWidth;
if(pBuf->frameHeight > pChInfo->maxHeight)
pChInfo->maxHeight = pBuf->frameHeight;
if(pBuf->channelNum== gApp_ipcFramesCtrl.fileFrameWriteChn && gApp_ipcFramesCtrl.fileFrameWriteState == FILE_WRITE_RUNNING)
UInt32 pMemVirtAddr;
pMemVirtAddr = 0;
App_mMap((UInt32)(pBuf->phyAddr[0][0]), frameSize, &pMemVirtAddr);
writeDataSize = fwrite((Ptr) pMemVirtAddr, 1, frameSize, gApp_ipcFramesCtrl.fp);
if(writeDataSize!=frameSize)
fclose(gApp_ipcFramesCtrl.fp);
OSA_printf(" Closing file [%s] for CH%d\n", gApp_ipcFramesCtrl.fileFrameWriteName, gApp_ipcFramesCtrl.fileFrameWriteChn);
App_unmapMem();
Int32 App_mMap(UInt32 physAddr, Uint32 memSize , UInt32 *pMemVirtAddr)
gMMapCtrl.memDevFd = open("/dev/mem",O_RDWR|O_SYNC);
if(gMMapCtrl.memDevFd < 0)
OSA_printf(" ERROR: /dev/mem open failed !!!\n");
return -1;
gMMapCtrl.memOffset = physAddr & MMAP_MEM_PAGEALIGN;
gMMapCtrl.mmapMemAddr = physAddr - gMMapCtrl.memOffset;
gMMapCtrl.mmapMemSize = memSize + gMMapCtrl.memOffset;
gMMapCtrl.pMemVirtAddr = mmap(
(void *)gMMapCtrl.mmapMemAddr,
gMMapCtrl.mmapMemSize,
PROT_READ|PROT_WRITE|PROT_EXEC,MAP_SHARED,
gMMapCtrl.memDevFd,
if (gMMapCtrl.pMemVirtAddr==NULL)
OSA_printf(" ERROR: mmap() failed !!!\n");
return -1;
*pMemVirtAddr = (UInt32)((UInt32)gMMapCtrl.pMemVirtAddr + gMMapCtrl.memOffset);
return 0;
Int32 App_unmapMem()
if(gMMapCtrl.pMemVirtAddr)
munmap((void*)gMMapCtrl.pMemVirtAddr, gMMapCtrl.mmapMemSize);
if(gMMapCtrl.memDevFd >= 0)
close(gMMapCtrl.memDevFd);
return 0;
#endif
m3Vpss----->A8------->m3Video----------------->A8
i define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_0
#define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_0 VIDEO_LINK(SYSTEM_LINK_ID_IPC_FRAMES_IN_0)
#define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_1 VIDEO_LINK(SYSTEM_LINK_ID_IPC_FRAMES_IN_1)
#define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_OUT_0 VIDEO_LINK(SYSTEM_LINK_ID_IPC_FRAMES_OUT_0)
#define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_OUT_1 VIDEO_LINK(SYSTEM_LINK_ID_IPC_FRAMES_OUT_1)
#define SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_OUT_2 VIDEO_LINK(SYSTEM_LINK_ID_IPC_FRAMES_OUT_2)
1 if i use ipcInVideoFrameId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
question is m3Video Can not get frames from A8, but A8 have send out the frames;
2 if i use ipcInVideoFrameId =SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_0;
[M3video] Assertion Line 1129 in links_m3video/iva_enc/encLink_common.c: status== FVID2_OK: failed !!!
why?
