TMS320C6742 I2S circuit connect issue
Other Parts Discussed in Thread: TMS320C6742
Hi there,
   I've met a problem about DSP (TMS320C6742) I2S circuit connection. My application is to transmit  I2S data & clock from McASP  TX through the cable to audio CODEC which is on another daughter board . I found that the clock signal  on pin OSCIN would be abnormal (waveform is distortion, not a perfect sin wave), and all of  the signal related to DSP input/output port  have noise on it. Once I set the McASP master clock from output to input mode, or cut off the I2S connection between DSP and daughter board,  it will become normal !
I wonder if there is anyone meet this situation before?
