When working with a C6000 DSP, where are xdc_Uint* types defined?
Other Parts Discussed in Thread: TMS320C6678
I have a question about creating a project in CCS5.3 targeted to run on a TMS320C6678 DSP.
My project currently includes the xdctools_3_24_05_48 package.   Inside that package I can see the file /packages/xdc/std.h
On line line 246, I see the following code segment:
typedef xdc_UInt8       Uint8;
typedef xdc_UInt16      Uint16;
typedef xdc_UInt32      Uint32;
the xdc_UInt* types are not defined which is a problem because my codebase makes heavy use of these Uint* types.
I cannot figure out where xdc_UInt* is meant to be defined.   After reading the following forum post, I think I need to look in my ti/targets/std.h file, but I don’t see a ...\targets\... folder in my install.  https://e2e.ti.com/support/embedded/tirtos/f/355/t/273059
  • David,
    XDCtools 3.24.05.48 should have the directory "ti/targets" under "packages". If your installation doesn't have it, you might have an incomplete installation and I wouldn't expect any of your projects using XDCtools to build correctly. If that's the case, you should try to reinstall.
  • Aha!  I was looking in the wrong place.  On my install there's a \ti\ folder above the product folders.
    I have found ti\xdctools_3_24_05_48\packages\ti\targets\std.h which  contains the typedefs for the xdc_UInt* types.
    On line 106:
     *  ======== [U]Int<n> ========
    typedef int_least8_t    xdc_Int8;
    typedef uint_least8_t   xdc_UInt8;
    typedef int_least16_t   xdc_Int16;
    typedef uint_least16_t  xdc_UInt16;
    typedef int_least32_t   xdc_Int32;
    typedef uint_least32_t  xdc_UInt32;
    #ifdef xdc__INT64__
        typedef int_least64_t   xdc_Int64;
        typedef uint_least64_t   xdc_UInt64;
    #endif
    Tracing further, I see that uint_least*_t is defined in my compiler: ti\ccsv5\tools\compiler\c6000_7.4.1\include\stdint.h and that it traces back to primitive types.
    So now that I understand this branch of the typedef tree, my next question is: Why can't CCS5.3 find ti\xdctools_3_24_05_48\packages\ti\targets\std.h which contains the typedef for xdc_UInt*?  Is my project setup incorrectly?
  • Can you post the exact error message that you are seeing? There are two different set of types, one with an uppercase I (xdc_UInt16 for example) and then a set with a lowercase I (Uint, for example). I can't really tell which of these is not being found.
  • My apologies,
    I mistyped capitalization in all of my posts thus far.  I just went back through and edited them for clarity.  Unfortunately, I don't have an error message I can show you.  The reason I know I have an error is because I am unable to trace my type tree back to primitive types using Navigate -> Open Declaration (F3) command in CCS5.3.  To address your previous post directly, I believe that xdc_UInt* (uppercase I) is not being found.
    Based on your previous responses, I've figured out what my type tree should look like:
    • primitive types
      • uint*_t (lowercase i)
        • uint_least*_t (lowercase I)
          • xdc_UInt* (uppercase I)
            • Uint* (lowercase I)
    In other words:
    1. The types that my code base uses are Uint* (with lowercase i)
    2. The parent types of Uint* are xdc_UInt* (with uppercase I) defined in ti\xdctools_3_24_05_48\packages\xdc\std.h
    3. The parent types of xdc_UInt* are uint_least*_t (with lowercase i) defined in ti\xdctools_3_24_05_48\packages\ti\targets\std.h
      1. This is the link that seems to be broken
    4. The parent types of uint_least*_t are uint*_t (with lowercase i) defined in ti\ccsv5\tools\compiler\c6000_7.4.1\include\stdint.h
    5. The parent types of uint*_t are primitive types defined in ti\ccsv5\tools\compiler\c6000_7.4.1\include\stdint.h
    At this point, there are several ways I could force the typedefs to work, either by editing some of these standard header files, or by creating my own file that defines Uint* directly to primitive types.   But I think both options would decrease my code base's portability.  I want to know how to make this tree work automatically.
    EDIT: I just realized my project has an alternate place that it might get it's Uint* type definitions from:  \ti\pdk_C6678_1_0_0_21\packages\ti\csl\tistdtypes.h
    Perhaps that's my problem?  I have two different files attempting to define Uint*
    /* Handle the 6x ISA */
    #if defined(_TMS320C6X)
        /* Unsigned integer definitions (32bit, 16bit, 8bit) follow... */
        typedef unsigned int	Uint32;
        typedef unsigned short	Uint16;
        typedef unsigned char	Uint8;
        /* Signed integer definitions (32bit, 16bit, 8bit) follow... */
        typedef int			Int32;
        typedef short		Int16;
        typedef char		Int8;
  • It is very likely that defining the same type twice could cause a problem. Which of these do you want to use? If you want to use ones from PDK, and hide the definitions coming from XDCtools, you can use xdc__strict macro (rtsc.eclipse.org/.../Integrating_RTSC_Modules) to achieve that. Here is a thread with a similar use case: e2e.ti.com/.../1431152
    If you want to use the ones from XDCtools, you would either have to not include the header files from PDK, or you would have to edit that file. I am not aware of any mechanism similar to xdc__strict.
  • I'm all for moving away from deprecated functionality.  So, per the link you sent, I added the following line to my compile flags:
    cl6x -Dxdc__strict -Dxdc_target_types__=ti/targets/std.h -Dxdc_target_name__=C66
    However, I end up with the following error:
    Fatal error #5: could not open source file "cl6x"
    Perhaps I should remove the cl6x?
  • If you are building in CCS, it's enough to go to Project Properties->CCS Build->Compiler->Predefined Symbols, and then click on the green plus button and add "xdc__strict". The rest of the string you added to compile flags should already be a part of the command line, and there is no need to add it. If you still can't get it to work, please post the complete content of your output console when building the project.
  • I'm thinking I may have bigger issues so I'm going to take a quick step back.
    You mentioned:
    I actually don't have them defined.  And through a bit of searching I've realized that I'm suffering from the same issue listed in this thread:  https://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/257493
    I've only defined my device variant as a "Generic C66xx Device"
    I'm working with my IT department to get the keystone1 version 1.0.6.0 update.
    Am I correct in thinking that defining my device variant as TMS320C6678 might resolve my typedef woes by defining my xdc_target_name and xdc_target_types (and any other fancy magic it does) automatically for me?  Perhaps this is the better option rather than mucking about with the compiler options myself.
    Also, how do I remove "cl6x" from my compile options now?
  • I would really see where 'cl6x' shows up in the command line. I would be able to answer a couple of these questions easier if you clean and rebuild your project and post the complete console output. That will show if the right defines are showing up on the command line, and whether XDCtools are using the right target for Generic C6XX Device.
  • My apologies, but I cannot share my full build console output.  I'm afraid that my filenames and paths may reveal proprietary and personal information that would get me in trouble with my employer.
    I was able to resolve a couple of my questions however they didn't seem to fix my original typedef dilemma:
    1. In a previous post, I added several compile flags by clicking the Set Additional Flags... button under Project -> Properties -> CCS Build -> CCS Compiler.  By doing so, I accidentally added "cl6x" to the end of my compiler invocation.  Based on my build console output, I think it was trying to use "cl6x" as a compiler.  I deleted the following option from my .cproject file and my "cl6x" errors went away.
      <listOptionValue builtIn="false" value="ADDITIONAL_FLAGS__COMPILER=cl6x"/>
    2. Additionally, I was able to work with my IT department to apply the keystone1 v1.0.9.1 update that I was previously missing.  I am now able to find TMS320C6678 in the device variant dropdown on Project -> Properties -> CCS General -> Main -> Variant.  However, changing this setting did not automatically fix all my typedef errors like I hoped it would.
    So I went back to trying the xdc defines you pointed me to.
    1. I added all three predefined symbols:  xdc__strict, xdc_target_types__=ti/targets/std.h, and xdc_target_name__=C66 and attempted to build.  This caused my PDK to throw thousands of errors, complaining that all the Uint* and Int* types were undefined.
    2. So I removed xdc__strict.  At this point my compile flags looked like the following (minus any revealing --include_path flags):
      -mv6678 --abi=eabi -g --include_path="C:/Apps/ti/ccsv5/tools/compiler/c6000_7.4.1/include"  --include_path="C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/csl" --include_path="C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/platform" --include_path="C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/drv/qmss" --include_path="C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/drv/cppi" --gcc --define=_TI_ENHANCED_MATH_H --define=_DEBUG --define=xdc_target_types__=ti/targets/std.h --define=xdc_target_name__=C66 --display_error_number --diag_suppress=232 --diag_suppress=179 --diag_suppress=195 --diag_suppress=238 --diag_suppress=552 --diag_suppress=880 --diag_suppress=190 --diag_suppress=682 --diag_suppress=1116 --diag_suppress=183 --diag_suppress=681 --diag_suppress=188 --diag_suppress=270 --issue_remarks --diag_warning=225 --gen_func_subsections=on --mem_model:data=far --std_lib_func_defined --output_all_syms
      This time I only receive a couple of errors, most notably:  #20 identifier "Uint8" is undefined and #20 identifier "Uint32" is undefined.
  • I would expect that adding 'xdc__strict' would cause Uint8 and Uint32 to become undefined, but I don't know how could that happen after removing that macro. Do you know if you are currently including both tistdtypes.h and xdc/std.h? Missing definitions for Uint8 and Uint32 indicate that you are not including either. In the compiler properties, there is a tab "Parser Preprocessing Options". You can turn Mode to "manual" and then use -ppl option to generate the preprocessed source file. By looking at the files included in the source, you can follow the processing of the two files I mentioned above and verify if any of them is used, and if yes, why the types that you are missing are not included.
    Also, it is unusual that you don't have xdc_target_types__=ti/targets/std.h, and xdc_target_name__=C66 defined automatically and that you have to define them on your own. But, I don't really know much about PDK and it could be that its projects are set up that way. We'll probably have to get back to that later.
  • How do I view the preprocessed source file once it's created?  Is it just what's on my build console now?  Or do I need to search somewhere in my Debug folder?
    EDIT1:  Oh! I think I've found them.  Alongside my source files, these new .pp files have appeared.
    So, in my build console, I can see that file1.c is compiled first.  I go into file1.pp and see that the first several #line directives look like this:
    #line 1 "file1.c"
    #line 1 "file1.h"
    #line 1 "common.h"
    #line 1 "C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/csl/csl.h"
    #line 1 "C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/csl/csl_types.h"
    #line 1 "C:/Apps/ti/pdk_C6678_1_0_0_21/packages/ti/csl/tistdtypes.h"
    #line 1 "C:/Apps/ti/xdctools_3_24_05_48/packages/xdc/std.h"
    #line 1 "C:/Apps/ti/ccsv5/tools/compiler/c6000_7.4.1/include/stdarg.h"
    From this file I know that ti/csl/tistdtypes.h is included before xdc/std.h but that they're both included.
    EDIT 2:  The above exercise may have been moot.  I *think* my issue was solved by a combination of two things:
    1. adding the xdc_target_types__=ti/targets/std.h predefined symbol.
    2. I changed my #include tree such that all TI product libraries were included in 1 common.h file.  Then common.h is included in each of my header files.
    When I Open Declaration (F3) on xdc_UIn32 now, it correctly brings me to ti/targets/std.h.
    Additionally, I can look in my ti/csl/tistdtypes.h file and see the duplicate Uint32 typedefs compiled out and instead it simply includes xdc/std.h
    I wasn't the original creator of my project so I couldn't tell you what happened to make xdc_target_types__ not be defined automatically.  But if it's fixed, I'm fat, dumb, and happy.
  • There should be a file with .pp extension either in the project's top directory or in Debug (or Release).
